MMA8652 Sensitivity Value
tuurbo46
I am just working through the MMA8652 example code, and generating my define values.
After searching the net I cannot find an example define value for the  SENSITIVITY_2G.  So would the below be correct for the example code?
#define SENSITIVITY_2G    1024
Z_offset = (Zout_12_bit - SENSITIVITY_2G) / 2 * (-1);          // Compute Z-axis offset correction value
Rocketman46
TomasVaverka
Yes, it is correct:
// MMA8652FC Sensitivity
#define SENSITIVITY_4G  512
#define SENSITIVITY_8G  256
* Simple accelerometer offset calibration
void MMA8652FC_Calibration (void)
  char X_offset, Y_offset, Z_offset;
  DataReady = 0;
  while (!DataReady){} // Is a first set of data ready?
  DataReady = 0;
  I2C_WriteRegister(MMA8652FC_I2C_ADDRESS, CTRL_REG1, 0x00); // Standby mode
  I2C_ReadMultiRegisters(MMA8652FC_I2C_ADDRESS, OUT_X_MSB_REG, 6, AccelData); // Read data output registers 0x01-0x06
  Xout_12_bit = ((short) (AccelData[0]<<8 | AccelData[1])) >> 4; // Compute 12-bit X-axis acceleration output value
  Yout_12_bit = ((short) (AccelData[2]<<8 | AccelData[3])) >> 4; // Compute 12-bit Y-axis acceleration output value
  Zout_12_bit = ((short) (AccelData[4]<<8 | AccelData[5])) >> 4; // Compute 12-bit Z-axis acceleration output value
  X_offset = Xout_12_bit / 2 * (-1); // Compute X-axis offset correction value
  Y_offset = Yout_12_bit / 2 * (-1); // Compute Y-axis offset correction value
  I2C_WriteRegister(MMA8652FC_I2C_ADDRESS, OFF_X_REG, X_offset);
  I2C_WriteRegister(MMA8652FC_I2C_ADDRESS, OFF_Y_REG, Y_offset);
  I2C_WriteRegister(MMA8652FC_I2C_ADDRESS, OFF_Z_REG, Z_offset);
  I2C_WriteRegister(MMA8652FC_I2C_ADDRESS, CTRL_REG1, 0x39); // Active mode again
Take a look at my complete example code here​.
Tomas
PS: If my answer helps to solve your question, please mark it as "Correct". Thank you.
tuurbo46
OK thank you  for your fast reply.  I am converting the code for another MCU.  Can you explain the below command.  I have outlined what I think is happening, is this correct?
* MMA8652FC_I2C_ADDRESS = I2C address.
* OUT_X_MSB_REG = register.
* AccelData = int16_t AccelData[8];
* Is the 6 in the I2C_ReadMultiRegisters() just reading the low 6 bits?
* If the above is correct, therefore my command is wrong as I am reading the whole word, read_word(MMA8652FC_I2C_ADDRESS, OUT_X_MSB, AccelData);
NXP Original code Code:
Rocektman46
TomasVaverka
I do not quite understand your question.
I believe it is obvious that the burst read is performed using the I2C_ReadMultiRegisters(MMA8652FC_I2C_ADDRESS, OUT_X_MSB_REG, 6, AccelData) function, given the 7-bit slave address of the chip (0x1D), the address of the first register to read (0x01), the number of bytes to read (a value of 6 reads all six data output registers 0x01 – 0x06) and the name of an array of six bytes to store the data in. Such a burst read of 6 bytes from registers 0x01 to 0x06 looks like this:
Hope it is clearer now.
Tomas
tuurbo46
Hi Tomas,
I do not have the I2C_ReadMultiRegisters() function so I am trying to write my own.  Is my below function correct although I have commented it for 6 bytes.
//I2C_ReadMultiRegisters(MMA8652FC_I2C_ADDRESS, OUT_X_MSB, 6, AccelData);   // Read data output registers 0x01-0x06
void read_multi_registers(uint8_t MPU_Addr, uint8_t Address, uint8_t Number_Of_Bytes, uint16_t Data)
  int8_t i;
  i2c_start_wait(MPU_Addr + I2C_WRITE);
  i2c_write(Address);
  i2c_stop();
  i2c_write(Address);
  i2c_rep_start(0x3B + I2C_READ);
  // read first 5 bytes of data
  for(i = 0; i < Number_Of_Bytes-1; i++)
       AccelData[i] = i2c_readAck();
       i2c_stop();
  // read last 6th byte of data
  AccelData[i+1] = i2c_readNak();
  i2c_stop();
Thanks Rocketman46
TomasVaverka
It is usually hard to say whether the function is correct or not without seeing what is going on the bus. Do you have a logic analyzer or an oscilloscope to see the traffic on the bus?
Both the single and multiple bytes read transactions are described in the MMA8652FC data sheet (chapters 5.11.1 and 5.11.2). In my source code, you can find the I2C routines in the I2C.c file within the Sources folder.
Tomas
tuurbo46
OK thanks.
One last question, can I read the data without configuring the interrupt.  I mean just send a command and read data?
Rocketman46
TomasVaverka
Yes, there is an example illustrating it in the AN4076, chapter 9.1.
Tomas
%3CLINGO-SUB%20id%3D%22lingo-sub-486375%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMMA8652%20Sensitivity%20Value%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-486375%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20am%20just%20working%20through%20the%20MMA8652%20example%20code%2C%20and%20generating%20my%20define%20values.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAfter%20searching%20the%20net%20I%20cannot%20find%20an%20example%20define%20value%20for%20the%26nbsp%3B%20SENSITIVITY_2G.%26nbsp%3B%20So%20would%20the%20below%20be%20correct%20for%20the%20example%20code%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%23define%20SENSITIVITY_2G%26nbsp%3B%26nbsp%3B%26nbsp%3B%201024%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%20Z_offset%20%3D%20(Zout_12_bit%20-%20SENSITIVITY_2G)%20%2F%202%20*%20(-1)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20Compute%20Z-axis%20offset%20correction%20value%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThanks%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ERocketman46%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-486375%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EAccelerometers%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-486382%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MMA8652%20Sensitivity%20Value%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-486382%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EYes%2C%20there%20is%20an%20example%20illustrating%20it%20in%20the%20%3CA%20href%3D%22http%3A%2F%2Fcache.nxp.com%2Ffiles%2Fsensors%2Fdoc%2Fapp_note%2FAN4076.pdf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EAN4076%3C%2FA%3E%2C%20chapter%209.1.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ERegards%2C%3C%2FP%3E%3CP%3ETomas%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-486381%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MMA8652%20Sensitivity%20Value%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-486381%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EOK%20thanks.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EOne%20last%20question%2C%20can%20I%20read%20the%20data%20without%20configuring%20the%20interrupt.%26nbsp%3B%20I%20mean%20just%20send%20a%20command%20and%20read%20data%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThanks%2C%3C%2FP%3E%3CP%3ERocketman46%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-486380%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MMA8652%20Sensitivity%20Value%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-486380%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EIt%20is%20usually%20hard%20to%20say%20whether%20the%20function%20is%20correct%20or%20not%20without%20seeing%20what%20is%20going%20on%20the%20bus.%20Do%20you%20have%20a%20logic%20analyzer%20or%20an%20oscilloscope%20to%20see%20the%20traffic%20on%20the%20bus%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBoth%20the%20single%20and%20multiple%20bytes%20read%20transactions%20are%20described%20in%20the%20%3CA%20href%3D%22http%3A%2F%2Fcache.nxp.com%2Ffiles%2Fsensors%2Fdoc%2Fdata_sheet%2FMMA8652FC.pdf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EMMA8652FC%20data%20sheet%3C%2FA%3E%20(chapters%205.11.1%20and%205.11.2).%20In%20my%20source%20code%2C%20you%20can%20find%20the%20I%3CSUP%3E2%3C%2FSUP%3EC%20routines%20in%20the%20I2C.c%20file%20within%20the%20Sources%20folder.%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ERegards%2C%3C%2FP%3E%3CP%3ETomas%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-486379%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MMA8652%20Sensitivity%20Value%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-486379%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Tomas%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20do%20not%20have%20the%20I2C_ReadMultiRegisters()%20function%20so%20I%20am%20trying%20to%20write%20my%20own.%26nbsp%3B%20Is%20my%20below%20function%20correct%20although%20I%20have%20commented%20it%20for%206%20bytes.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2F%2FI2C_ReadMultiRegisters(MMA8652FC_I2C_ADDRESS%2C%20OUT_X_MSB%2C%206%2C%20AccelData)%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20Read%20data%20output%20registers%200x01-0x06%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Evoid%20read_multi_registers(uint8_t%20MPU_Addr%2C%20uint8_t%20Address%2C%20uint8_t%20Number_Of_Bytes%2C%20uint16_t%20Data)%3C%2FP%3E%3CP%3E%7B%3C%2FP%3E%3CP%3E%26nbsp%3B%20int8_t%20i%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20i2c_start_wait(MPU_Addr%20%2B%20I2C_WRITE)%3B%20%3C%2FP%3E%3CP%3E%26nbsp%3B%20i2c_write(Address)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%26nbsp%3B%20i2c_stop()%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20i2c_start_wait(MPU_Addr%20%2B%20I2C_WRITE)%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%20i2c_write(Address)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20i2c_rep_start(0x3B%20%2B%20I2C_READ)%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20%2F%2F%20read%20first%205%20bytes%20of%20data%3C%2FP%3E%3CP%3E%26nbsp%3B%20for(i%20%3D%200%3B%20i%20%26lt%3B%20Number_Of_Bytes-1%3B%20i%2B%2B)%3C%2FP%3E%3CP%3E%26nbsp%3B%20%7B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20AccelData%5Bi%5D%20%3D%20i2c_readAck()%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20i2c_stop()%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%20%7D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20%2F%2F%20read%20last%206th%20byte%20of%20data%3C%2FP%3E%3CP%3E%26nbsp%3B%20AccelData%5Bi%2B1%5D%20%3D%20i2c_readNak()%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%20i2c_stop()%3B%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThanks%20Rocketman46%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-486378%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MMA8652%20Sensitivity%20Value%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-486378%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20do%20not%20quite%20understand%20your%20question.%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20believe%20it%20is%20obvious%20that%20the%20burst%20read%20is%20performed%20using%20the%20I2C_ReadMultiRegisters(MMA8652FC_I2C_ADDRESS%2C%20OUT_X_MSB_REG%2C%206%2C%20AccelData)%20function%2C%20given%20the%207-bit%20slave%20address%20of%20the%20chip%20(0x1D)%2C%20the%20address%20of%20the%20first%20register%20to%20read%20(0x01)%2C%20the%20number%20of%20bytes%20to%20read%20(a%20value%20of%206%20reads%20all%20six%20data%20output%20registers%200x01%20%E2%80%93%200x06)%20and%20the%20name%20of%20an%20array%20of%20six%20bytes%20to%20store%20the%20data%20in.%20Such%20a%20burst%20read%20of%206%20bytes%20from%20registers%200x01%20to%200x06%20looks%20like%20this%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Burst%2BRead.JPG.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Burst%2BRead.JPG.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F55078i1EB22968F0796035%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Burst%2BRead.JPG.jpg%22%20alt%3D%22Burst%2BRead.JPG.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EBurst%2BRead.JPG.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EHope%20it%20is%20clearer%20now.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ERegards%2C%3C%2FP%3E%3CP%3ETomas%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-486377%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MMA8652%20Sensitivity%20Value%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-486377%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EOK%20thank%20you%26nbsp%3B%20for%20your%20fast%20reply.%26nbsp%3B%20I%20am%20converting%20the%20code%20for%20another%20MCU.%26nbsp%3B%20Can%20you%20explain%20the%20below%20command.%26nbsp%3B%20I%20have%20outlined%20what%20I%20think%20is%20happening%2C%20is%20this%20correct%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20Consolas%2C%20'Courier%20New'%2C%20Courier%2C%20mono%2C%20serif%3B%20font-size%3A%2012px%3B%22%3E*%20MMA8652FC_I2C_ADDRESS%20%3D%20I2C%20address.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20Consolas%2C%20'Courier%20New'%2C%20Courier%2C%20mono%2C%20serif%3B%20font-size%3A%2012px%3B%22%3E*%20%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20Consolas%2C%20'Courier%20New'%2C%20Courier%2C%20mono%2C%20serif%3B%20font-size%3A%2012px%3B%22%3EOUT_X_MSB_REG%20%3D%20register.%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E*%20%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20Consolas%2C%20'Courier%20New'%2C%20Courier%2C%20mono%2C%20serif%3B%20font-size%3A%2012px%3B%22%3EAccelData%20%3D%20int16_t%20AccelData%5B8%5D%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20Consolas%2C%20'Courier%20New'%2C%20Courier%2C%20mono%2C%20serif%3B%20font-size%3A%2012px%3B%22%3E*%20Is%20the%206%20in%20the%20%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20Consolas%2C%20'Courier%20New'%2C%20Courier%2C%20mono%2C%20serif%3B%20font-size%3A%2012px%3B%22%3EI2C_ReadMultiRegisters()%20just%20reading%20the%20low%206%20bits%3F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-size%3A%2012px%3B%20font-family%3A%20Consolas%2C%20'Courier%20New'%2C%20Courier%2C%20mono%2C%20serif%3B%22%3E*%20If%20the%20above%20is%20correct%2C%20therefore%20my%20command%20is%20wrong%20as%20I%20am%20reading%20the%20whole%20word%2C%20read_word(MMA8652FC_I2C_ADDRESS%2C%20OUT_X_MSB%2C%20AccelData)%3B%20%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%20background%3A%20white%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-size%3A%2012px%3B%20font-family%3A%20Consolas%2C%20'Courier%20New'%2C%20Courier%2C%20mono%2C%20serif%3B%22%3ENXP%20Original%20code%20Code%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20Consolas%2C%20'Courier%20New'%2C%20Courier%2C%20mono%2C%20serif%3B%20font-size%3A%2012px%3B%22%3E%20I2C_ReadMultiRegisters(MMA8652FC_I2C_ADDRESS%2C%20OUT_X_MSB_REG%2C%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%22%20style%3D%22font-size%3A%2012px%3B%20font-family%3A%20Consolas%2C%20'Courier%20New'%2C%20Courier%2C%20mono%2C%20serif%3B%20color%3A%20green%3B%22%3E6%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012px%3B%20font-family%3A%20Consolas%2C%20'Courier%20New'%2C%20Courier%2C%20mono%2C%20serif%3B%20color%3A%20%23000000%3B%22%3E%2C%20AccelData)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22comment%22%20style%3D%22font-size%3A%2012px%3B%20font-family%3A%20Consolas%2C%20'Courier%20New'%2C%20Courier%2C%20mono%2C%20serif%3B%20color%3A%20%23008200%3B%22%3E%2F%2F%20Read%20data%20output%20registers%200x01-0x06%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012px%3B%20font-family%3A%20Consolas%2C%20'Courier%20New'%2C%20Courier%2C%20mono%2C%20serif%3B%20color%3A%20%23000000%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%20Xout_12_bit%20%3D%20((%3C%2FSPAN%3E%3CSTRONG%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20'inherit'%2C'serif'%3B%22%3Eshort%3C%2FSTRONG%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E)%20(AccelData%5B0%5D%26lt%3B%26lt%3B8%20%7C%20AccelData%5B1%5D))%20%26gt%3B%26gt%3B%204%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20Compute%2012-bit%20X-axis%20acceleration%20output%20value%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%20Yout_12_bit%20%3D%20((%3C%2FSPAN%3E%3CSTRONG%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20'inherit'%2C'serif'%3B%22%3Eshort%3C%2FSTRONG%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E)%20(AccelData%5B2%5D%26lt%3B%26lt%3B8%20%7C%20AccelData%5B3%5D))%20%26gt%3B%26gt%3B%204%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20Compute%2012-bit%20Y-axis%20acceleration%20output%20value%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%20Zout_12_bit%20%3D%20((%3C%2FSPAN%3E%3CSTRONG%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20'inherit'%2C'serif'%3B%22%3Eshort%3C%2FSTRONG%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E)%20(AccelData%5B4%5D%26lt%3B%26lt%3B8%20%7C%20AccelData%5B5%5D))%20%26gt%3B%26gt%3B%204%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20Compute%2012-bit%20Z-axis%20acceleration%20output%20value%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012px%3B%20font-family%3A%20Consolas%2C%20'Courier%20New'%2C%20Courier%2C%20mono%2C%20serif%3B%20color%3A%20%23000000%3B%22%3EThanks%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012px%3B%20font-family%3A%20Consolas%2C%20'Courier%20New'%2C%20Courier%2C%20mono%2C%20serif%3B%20color%3A%20%23000000%3B%22%3ERocektman46%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-486376%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MMA8652%20Sensitivity%20Value%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-486376%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EYes%2C%20it%20is%20correct%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MMA8652FC%20Sensitivity.JPG%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MMA8652FC%20Sensitivity.JPG%22%20style%3D%22width%3A%20678px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F55442iA019533764EBFB56%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22MMA8652FC%20Sensitivity.JPG%22%20alt%3D%22MMA8652FC%20Sensitivity.JPG%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EMMA8652FC%20Sensitivity.JPG%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22c%2B%2B%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14564791321111620%20jive_text_macro%22%20data-renderedposition%3D%22246.17897033691406_7.997159004211426_1192_77%22%20jivemacro_uid%3D%22_14564791321111620%22%20modifiedtitle%3D%22true%22%3E%3CP%3E%2F%2F%20MMA8652FC%20Sensitivity%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%23define%20SENSITIVITY_2G%26nbsp%3B%201024%3C%2FP%3E%3CP%3E%23define%20SENSITIVITY_4G%26nbsp%3B%20512%3C%2FP%3E%3CP%3E%23define%20SENSITIVITY_8G%26nbsp%3B%20256%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22c%2B%2B%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14564792264049802%20jive_text_macro%22%20data-renderedposition%3D%22348.90625_7.997159004211426_1192_464%22%20jivemacro_uid%3D%22_14564792264049802%22%3E%3CP%3E%2F******************************************************************************%3C%2FP%3E%3CP%3E*%20Simple%20accelerometer%20offset%20calibration%3C%2FP%3E%3CP%3E******************************************************************************%2F%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Evoid%20MMA8652FC_Calibration%20(void)%3C%2FP%3E%3CP%3E%7B%3C%2FP%3E%3CP%3E%26nbsp%3B%20char%20X_offset%2C%20Y_offset%2C%20Z_offset%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20DataReady%20%3D%200%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%20while%20(!DataReady)%7B%7D%20%2F%2F%20Is%20a%20first%20set%20of%20data%20ready%3F%20%3C%2FP%3E%3CP%3E%26nbsp%3B%20DataReady%20%3D%200%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20I2C_WriteRegister(MMA8652FC_I2C_ADDRESS%2C%20CTRL_REG1%2C%200x00)%3B%20%2F%2F%20Standby%20mode%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20I2C_ReadMultiRegisters(MMA8652FC_I2C_ADDRESS%2C%20OUT_X_MSB_REG%2C%206%2C%20AccelData)%3B%20%2F%2F%20Read%20data%20output%20registers%200x01-0x06%26nbsp%3B%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20Xout_12_bit%20%3D%20((short)%20(AccelData%5B0%5D%26lt%3B%26lt%3B8%20%7C%20AccelData%5B1%5D))%20%26gt%3B%26gt%3B%204%3B%20%2F%2F%20Compute%2012-bit%20X-axis%20acceleration%20output%20value%3C%2FP%3E%3CP%3E%26nbsp%3B%20Yout_12_bit%20%3D%20((short)%20(AccelData%5B2%5D%26lt%3B%26lt%3B8%20%7C%20AccelData%5B3%5D))%20%26gt%3B%26gt%3B%204%3B%20%2F%2F%20Compute%2012-bit%20Y-axis%20acceleration%20output%20value%3C%2FP%3E%3CP%3E%26nbsp%3B%20Zout_12_bit%20%3D%20((short)%20(AccelData%5B4%5D%26lt%3B%26lt%3B8%20%7C%20AccelData%5B5%5D))%20%26gt%3B%26gt%3B%204%3B%20%2F%2F%20Compute%2012-bit%20Z-axis%20acceleration%20output%20value%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20X_offset%20%3D%20Xout_12_bit%20%2F%202%20*%20(-1)%3B%20%2F%2F%20Compute%20X-axis%20offset%20correction%20value%3C%2FP%3E%3CP%3E%26nbsp%3B%20Y_offset%20%3D%20Yout_12_bit%20%2F%202%20*%20(-1)%3B%20%2F%2F%20Compute%20Y-axis%20offset%20correction%20value%3C%2FP%3E%3CP%3E%26nbsp%3B%20Z_offset%20%3D%20(Zout_12_bit%20-%20SENSITIVITY_2G)%20%2F%202%20*%20(-1)%3B%20%2F%2F%20Compute%20Z-axis%20offset%20correction%20value%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20I2C_WriteRegister(MMA8652FC_I2C_ADDRESS%2C%20OFF_X_REG%2C%20X_offset)%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%20I2C_WriteRegister(MMA8652FC_I2C_ADDRESS%2C%20OFF_Y_REG%2C%20Y_offset)%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%20I2C_WriteRegister(MMA8652FC_I2C_ADDRESS%2C%20OFF_Z_REG%2C%20Z_offset)%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20I2C_WriteRegister(MMA8652FC_I2C_ADDRESS%2C%20CTRL_REG1%2C%200x39)%3B%20%2F%2F%20Active%20mode%20again%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3ETake%20a%20look%20at%20my%20complete%20example%20code%20%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-101192%22%20target%3D%22_blank%22%3Ehere%3C%2FA%3E%E2%80%8B.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ERegards%2C%3C%2FP%3E%3CP%3ETomas%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CEM%20style%3D%22font-size%3A%2011px%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3EPS%3A%20If%20my%20answer%20helps%20to%20solve%20your%20question%2C%20please%20mark%20it%20as%20%22Correct%22.%20Thank%20you.%3C%2FEM%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
