MMA7660 Auto-Wake / Auto Sleep mode
3,806件の閲覧回数
akircher
I try to set up mma7660, that it runs in Auto Sleep with high sample rate and in Auto-Wake in low sample rate.
During the transition from Auto-Wake to Auto-Sleep I would like to fire an interrupt.
The interrupt trigger should be the Delta G condition.
Unfortunately I can not make it work. The initialisation looks like this:
void setup(){
   write(MODE,0x00);//0x00 = Stan dby Mode -- allows config to be written
    write(INTSU, INTSU_ASINT );// Interrupts for exiting Auto sleep
    write(PDET,PDET_XDA|PDET_YDA|PDET_ZDA);//Tap detection is disabled, no threshold
    write(PD,0x0);//No Tap Filtering
    write(SR,SR_AMSR_AM16 |SR_AWSR_AW1); // Sampling Rate aktive 16 hz ; sleep 16 hz
    write(SPCNT, 16);    //  counts for sleep counter register until sleep / wake occurs
    write(MODE,MODE_MODE| MODE_AWE  /*|MODE_ASE /*|MODE_IAH*/ );// MODE_MODE = Active Mode ; MODE_AWE = Auto Wake ;
To understand MMA7660 is in sleep or active mode I use following code
uint8_t GetwakeState(){
    uint8_t   s =  read(SRST);
    if ( s & SRST_AMSRS )    return 1 ;  // AUTO SLEEP == active
    if ( s & SRST_AWSRS )  return 0 ;  // AUTO WAKE  == sleeping
    return -1;
Unfortunately between the transistions (sleep to wake or vice versa) I do not get always an interrupt,
If an interrupt occurs there are plenty in a row and not necessarly linked to the state change.
Output of log file
Ws: 0 = sleep ; 1 = active
Int : number of recived interrups
x,y,z = accelarations in x,y,z direction
Ws 0 Int 92 x = 2 y = -3 z = -13
Ws 0 Int 92 x = 4 y = -3 z = -21
Ws 0 Int 109 x = 4 y = -3 z = -21
Ws 0 Int 112 x = 4 y = -6 z = -25
Ws 2 Int 112 x = 3 y = -3 z = -21
Ws 0 Int 112 x = 2 y = -3 z = -17
Ws 0 Int 118 x = 2 y = -3 z = -17
Ws 0 Int 121 x = 4 y = -4 z = -27
Ws 1 Int 121 x = -3 y = 1 z = -18
Ws 1 Int 121 x = 1 y = 5 z = -23
Ws 1 Int 121 x = 1 y = 2 z = -22
Ws 2 Int 121 x = 3 y = 0 z = -17
Ws 1 Int 121 x = 1 y = 3 z = -19
Ws 0 Int 121 x = -2 y = -2 z = -24
Ws 1 Int 135 x = -7 y = -2 z = -20
Ws 2 Int 135 x = -1 y = 1 z = -23
If you can provide any sample code making use of the sleep / wake functionlity would be helpfull
Thanks a lot Andreas
2,207件の閲覧回数
TomasVaverka
Hi Andreas,
Just a quick note, the MMA7660FC is a pretty old device, not recommended for new designs. I strongly suggest using newer accelerometers such as the MMA845xQ, MMA865xFC or FXLS8471Q. There is also an app note AN4074 illustrating the use of the auto wake/sleep function on these devices.
Tomas
2 返答(返信)
2,207件の閲覧回数
akircher
Thanks for this tip!
2,208件の閲覧回数
TomasVaverka
Hi Andreas,
Tomas
%3CLINGO-SUB%20id%3D%22lingo-sub-477325%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMMA7660%20%E8%87%AA%E5%8B%95%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%2F%E8%87%AA%E5%8B%95%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%E3%83%A2%E3%83%BC%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-477325%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3Emma7660%20%E3%82%92%E3%80%81%E9%AB%98%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%20%E3%83%AC%E3%83%BC%E3%83%88%E3%81%A7%E8%87%AA%E5%8B%95%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%E3%81%97%E3%80%81%E4%BD%8E%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%20%E3%83%AC%E3%83%BC%E3%83%88%E3%81%A7%E8%87%AA%E5%8B%95%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E8%87%AA%E5%8B%95%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%81%8B%E3%82%89%E8%87%AA%E5%8B%95%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%E3%81%B8%E3%81%AE%E7%A7%BB%E8%A1%8C%E4%B8%AD%E3%81%AB%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%E7%99%BA%E7%94%9F%E3%81%95%E3%81%9B%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%81%AF%20Delta%20G%20%E6%9D%A1%E4%BB%B6%E3%81%A7%E3%81%82%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%AE%8B%E5%BF%B5%E3%81%AA%E3%81%8C%E3%82%89%E5%8B%95%E4%BD%9C%E3%81%95%E3%81%9B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Evoid%20%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97()%7B%3C%2FP%3E%3CP%3Ewrite(MODE%2C0x00)%3B%2F%2F0x00%20%3D%20%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%90%E3%82%A4%E3%83%A2%E3%83%BC%E3%83%89%20--%20%E8%A8%AD%E5%AE%9A%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%92%E8%A8%B1%E5%8F%AF%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Ewrite(INTSU%2C%20INTSU_ASINT)%3B%2F%2F%20%E8%BB%8A%E8%BC%89%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%E7%B5%82%E4%BA%86%E6%99%82%E3%81%AE%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%3C%2FP%3E%3CP%3Ewrite(PDET%2CPDET_XDA%7CPDET_YDA%7CPDET_ZDA)%3B%2F%2F%E3%82%BF%E3%83%83%E3%83%97%E6%A4%9C%E5%87%BA%E3%81%AF%E7%84%A1%E5%8A%B9%E3%80%81%E3%81%97%E3%81%8D%E3%81%84%E5%80%A4%E3%81%AA%E3%81%97%3C%2FP%3E%3CP%3Ewrite(PD%2C0x0)%3B%2F%2F%E3%82%BF%E3%83%83%E3%83%97%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%AA%E3%81%97%3C%2FP%3E%3CP%3Ewrite(SR%2CSR_AMSR_AM16%20%7CSR_AWSR_AW1)%3B%20%2F%2F%20%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AA%E3%83%B3%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%88%20%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%2016%20Hz%E3%80%81%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%2016%20Hz%3C%2FP%3E%3CP%3Ewrite(SPCNT%2C%2016)%3B%20%2F%2F%20%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%2F%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E3%81%BE%E3%81%A7%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Ewrite(MODE%2CMODE_MODE%7C%20MODE_AWE%20%2F*%7CMODE_ASE%20%2F*%7CMODE_IAH*%2F%20)%3B%2F%2F%20MODE_MODE%20%3D%20%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%20%E3%83%A2%E3%83%BC%E3%83%89%3B%20MODE_AWE%20%3D%20%E8%87%AA%E5%8B%95%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EMMA7660%E3%81%8C%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%E3%83%A2%E3%83%BC%E3%83%89%E3%81%8B%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%83%A2%E3%83%BC%E3%83%89%E3%81%8B%E3%82%92%E7%9F%A5%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Euint8_t%20GetwakeState()%7B%3C%2FP%3E%3CP%3Euint8_t%20s%20%3D%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A(SRST)%3B%3C%2FP%3E%3CP%3Eif%20(%20s%20%26amp%3B%20SRST_AMSRS%20)%20return%201%20%3B%20%2F%2F%20%E8%BB%8A%E8%BC%89%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%20%3D%3D%20%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%3C%2FP%3E%3CP%3Eif%20(%20s%20%26amp%3B%20SRST_AWSRS%20)%20return%200%20%3B%20%2F%2F%20%E8%BB%8A%E8%BC%89%20WAKE%20%3D%3D%20%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%3C%2FP%3E%3CP%3E-1%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CP%3E%E6%AE%8B%E5%BF%B5%E3%81%AA%E3%81%8C%E3%82%89%E3%80%81%E9%81%B7%E7%A7%BB%EF%BC%88%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%E3%81%8B%E3%82%89%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E3%81%9D%E3%81%AE%E9%80%86%EF%BC%89%E3%81%AE%E9%96%93%E3%81%AB%E5%B8%B8%E3%81%AB%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E3%82%8F%E3%81%91%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E9%80%A3%E7%B6%9A%E3%81%97%E3%81%A6%E5%A4%9A%E6%95%B0%E7%99%BA%E7%94%9F%E3%81%97%E3%80%81%E5%BF%85%E3%81%9A%E3%81%97%E3%82%82%E7%8A%B6%E6%85%8B%E3%81%AE%E5%A4%89%E5%8C%96%E3%81%AB%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%95%E3%82%8C%E3%82%8B%E3%82%8F%E3%81%91%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%AD%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E5%87%BA%E5%8A%9B%3C%2FP%3E%3CP%3EWs%3A%200%20%3D%20%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%3B%201%20%3D%20%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%3C%2FP%3E%3CP%3EInt%3A%20%E5%8F%97%E4%BF%A1%E3%81%97%E3%81%9F%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%AE%E6%95%B0%3C%2FP%3E%3CP%3Ex%2Cy%2Cz%20%3D%20x%2Cy%2Cz%E6%96%B9%E5%90%91%E3%81%AE%E5%8A%A0%E9%80%9F%E5%BA%A6%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EWs%200%20Int%2092%20x%20%3D%202%20y%20%3D%20-3%20z%20%3D%20-13%3C%2FP%3E%3CP%3EWs%200%20Int%2092%20x%20%3D%202%20y%20%3D%20-3%20z%20%3D%20-13%3C%2FP%3E%3CP%3EWs%200%20Int%2092%20x%20%3D%204%20y%20%3D%20-3%20z%20%3D%20-21%3C%2FP%3E%3CP%3EWs%200%20Int%20109%20x%20%3D%204%20y%20%3D%20-3%20z%20%3D%20-21%3C%2FP%3E%3CP%3EWs%200%20Int%20112%20x%20%3D%204%20y%20%3D%20-6%20z%20%3D%20-25%3C%2FP%3E%3CP%3EWs%202%20Int%20112%20x%20%3D%203%20y%20%3D%20-3%20z%20%3D%20-21%3C%2FP%3E%3CP%3EWs%202%20Int%20112%20x%20%3D%203%20y%20%3D%20-3%20z%20%3D%20-21%3C%2FP%3E%3CP%3EWs%200%20Int%20112%20x%20%3D%202%20y%20%3D%20-3%20z%20%3D%20-17%3C%2FP%3E%3CP%3EWs%200%20Int%20118%20x%20%3D%202%20y%20%3D%20-3%20z%20%3D%20-17%3C%2FP%3E%3CP%3EWs%200%20Int%20121%20x%20%3D%204%20y%20%3D%20-4%20z%20%3D%20-27%3C%2FP%3E%3CP%3EWs%200%20Int%20121%20x%20%3D%204%20y%20%3D%20-4%20z%20%3D%20-27%3C%2FP%3E%3CP%3EWs%201%20Int%20121%20x%20%3D%20-3%20y%20%3D%201%20z%20%3D%20-18%3C%2FP%3E%3CP%3EWs%201%20Int%20121%20x%20%3D%201%20y%20%3D%205%20z%20%3D%20-23%3C%2FP%3E%3CP%3EWs%201%20Int%20121%20x%20%3D%201%20y%20%3D%205%20z%20%3D%20-23%3C%2FP%3E%3CP%3EWs%201%20Int%20121%20x%20%3D%201%20y%20%3D%202%20z%20%3D%20-22%3C%2FP%3E%3CP%3EWs%201%20Int%20121%20x%20%3D%201%20y%20%3D%202%20z%20%3D%20-22%3C%2FP%3E%3CP%3EWs%202%20Int%20121%20x%20%3D%203%20y%20%3D%200%20z%20%3D%20-17%3C%2FP%3E%3CP%3EWs%202%20Int%20121%20x%20%3D%203%20y%20%3D%200%20z%20%3D%20-17%3C%2FP%3E%3CP%3EWs%201%20Int%20121%20x%20%3D%201%20y%20%3D%203%20z%20%3D%20-19%3C%2FP%3E%3CP%3EWs%201%20Int%20121%20x%20%3D%201%20y%20%3D%203%20z%20%3D%20-19%3C%2FP%3E%3CP%3EWs%200%20Int%20121%20x%20%3D%20-2%20y%20%3D%20-2%20z%20%3D%20-24%3C%2FP%3E%3CP%3EWs%201%20Int%20135%20x%20%3D%20-7%20y%20%3D%20-2%20z%20%3D%20-20%3C%2FP%3E%3CP%3EWs%201%20Int%20135%20x%20%3D%20-7%20y%20%3D%20-2%20z%20%3D%20-20%3C%2FP%3E%3CP%3EWs%202%20Int%20135%20x%20%3D%20-1%20y%20%3D%201%20z%20%3D%20-23%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%2F%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E6%A9%9F%E8%83%BD%E3%82%92%E5%88%A9%E7%94%A8%E3%81%97%E3%81%9F%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8C%E3%81%B0%E5%8A%A9%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81%E3%82%A2%E3%83%B3%E3%83%89%E3%83%AC%E3%82%A2%E3%82%B9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-477325%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%8A%A0%E9%80%9F%E5%BA%A6%E3%82%BB%E3%83%B3%E3%82%B5%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-477327%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MMA7660%20Auto-Wake%20%2F%20Auto%20Sleep%20mode%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-477327%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%81%AE%E3%83%92%E3%83%B3%E3%83%88%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-477326%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MMA7660%20Auto-Wake%20%2F%20Auto%20Sleep%20mode%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-477326%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%82%A2%E3%83%B3%E3%83%89%E3%83%AC%E3%82%A2%E3%82%B9%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%B0%A1%E5%8D%98%E3%81%AB%E8%A8%80%E3%81%86%E3%81%A8%E3%80%81%20%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fproducts%2Fsensors%2Faccelerometers%2F3-axis-accelerometers%2F1.5g-low-g-digital-accelerometer%3AMMA7660FC%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EMMA7660FC%3C%2FA%3E%E3%81%AF%E3%81%8B%E3%81%AA%E3%82%8A%E5%8F%A4%E3%81%84%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AA%E3%81%AE%E3%81%A7%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%81%AB%E3%81%AF%E6%8E%A8%E5%A5%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fproducts%2Fsensors%2Faccelerometers%2F3-axis-accelerometers%2F2g-4g-8g-low-g-14-bit-digital-accelerometer%3AMMA8451Q%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EMMA845xQ%3C%2FA%3E%20%E3%80%81%20%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fproducts%2Fsensors%2Faccelerometers%2F3-axis-accelerometers%2F2g-4g-8g-low-g-12-bit-digital-accelerometer%3AMMA8652FC%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EMMA865xFC%3C%2FA%3E%20%E3%80%81%20%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fproducts%2Fsensors%2Faccelerometers%2F3-axis-accelerometers%2F2g-4g-8g-low-g-14-bit-digital-accelerometer%3AFXLS8471Q%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EFXLS8471Q%3C%2FA%3E%E3%81%AA%E3%81%A9%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%E5%8A%A0%E9%80%9F%E5%BA%A6%E3%82%BB%E3%83%B3%E3%82%B5%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E5%BC%B7%E3%81%8F%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E8%87%AA%E5%8B%95%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%2F%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%E6%A9%9F%E8%83%BD%E3%81%AE%E4%BD%BF%E7%94%A8%E6%96%B9%E6%B3%95%E3%82%92%E8%AA%AC%E6%98%8E%E3%81%99%E3%82%8B%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20%E3%83%8E%E3%83%BC%E3%83%88%3CA%20href%3D%22http%3A%2F%2Fcache.nxp.com%2Ffiles%2Fsensors%2Fdoc%2Fapp_note%2FAN4074.pdf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EAN4074%3C%2FA%3E%E3%82%82%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%88%E3%83%BC%E3%83%9E%E3%82%B9%3C%2FP%3E%3C%2FLINGO-BODY%3E
