MMA690xKQ interface sample codes
jayarao
Hi any one share sample code of MMA690xKQ interface sample codes
TomasVaverka
Hi Jaya,
The only example code I am aware of is part of the TWR_SENSOR_AUTO_FW package that can be downloaded from the following website:
Automotive Low-g Accelerometer Tower® Plug-In|NXP
Scroll down to the bottom of the page and download the TWR_SENSOR_AUTO_FW.zip file.
I hope it helps!
Tomas
jayarao
Hi Tomas
Thanks for the reply
I was tried with same example aswell
pelase find tehresponses attached
Always I am getting E6,BC,00...
jayarao
mcm_internal_get_srv_id_for_msg_id: *** msg_id: 600 | MIN: b00 | MAX: b10
mcm_internal_get_srv_id_for_msg_id: *** msg_id: 600 | MIN: 100 | MAX: 10c
mcm_internal_get_srv_id_for_msg_id: *** msg_id: 600 | MIN: 400 | MAX: 427
mcm_internal_get_srv_id_for_msg_id: *** msg_id: 600 | MIN: 300 | MAX: 316
mcm_internal_get_srv_id_for_msg_id: *** msg_id: 600 | MIN: 600 | MAX: 600
mcm_internal_get_srv_id_for_msg_id: found service_id iter:8
server_execute_sync: server_execute_sync Enter
server_execute_sync: user_handle:7, msg_id:600, req_c_struct:e190, req_c_struct_len:208, resp_c_struct:e3a0, resp_c_struct_len:1010
mcm_client_execute_command_sync_ex: mcm_client_execute_command_sync_ex SUCCESS EXITAT command sent:
AT#V24=2,1OK
rx_word-0xbc00
ptr_read[index].word-0xbc00
index - 13AT command sent:
AT#V24=2,0OK
register address:14message transmittedspi read message successfullSTATUS is 0xe6-0x00-0x00-0x00
register address:emessage transmittedspi read message successfullSTATUS is 0x00-0x00-0x00-0x00AT command sent:
AT#V24=2,1OK
rx_word-0xe600AT command sent:
AT#V24=2,0OK
register address:20message transmittedspi read message successfullSTATUS is 0xbc-0x00-0x00-0x00
register address:0message transmittedspi read message successfullSTATUS is 0x00-0x00-0x00-0x00AT command sent:
AT#V24=2,1OK
rx_word-0xbc00
index - 14AT command sent:
AT#V24=2,0OK
register address:10message transmittedspi read message successfullSTATUS is 0x00-0x00-0x00-0x00
register address:fmessage transmittedspi read message successfullSTATUS is 0xe6-0x00-0x00-0x00
AT command sent:
AT#V24=2,1OK
rx_word-0xe6AT command sent:
AT#V24=2,0OK
AT#V24=2,1OK
rx_word-0xbc00
index - 15AT command sent:
AT#V24=2,0OK
register address:10message transmittedspi read message successfullSTATUS is 0xe6-0x00-0x00-0x00AT command sent:
AT#V24=2,1OK
rx_word-0xe6e6AT command sent:
AT#V24=2,0OK
register address:20message transmittedspi read message successfullSTATUS is 0xe6-0x00-0x00-0x00
register address:0message transmittedspi read message successfullSTATUS is 0xff-0x00-0x00-0x00AT command sent:
AT#V24=2,1OK
rx_word-0xe6ff
ptr_read[index].word-0xe6ff
index - 16AT command sent:
AT#V24=2,0OK
register address:11message transmittedspi read message successfullSTATUS is 0xe6-0x00-0x00-0x00AT command sent:
AT#V24=2,1OK
AT#V24=2,0OK
AT#V24=2,1OK
rx_word-0xbc00
index - 17AT command sent:
AT#V24=2,0OK
register address:14message transmittedspi read message successfullSTATUS is 0x00-0x00-0x00-0x00
register address:20message transmittedspi read message successfullSTATUS is 0xbc-0x00-0x00-0x00AT command sent:
AT#V24=2,1OK
rx_word-0xbcAT command sent:
AT#V24=2,0OK
AT#V24=2,1OK
rx_word-0xe6ff
index - 18AT command sent:
AT#V24=2,0OK
register address:21message transmittedspi read message successfullSTATUS is 0xe6-0x00-0x00-0x00AT command sent:
AT#V24=2,1OK
AT#V24=2,0OK
AT#V24=2,1OK
rx_word-0xbc00
index - 19
AT command sent:
AT#V24=2,0OK
register address:22message transmittedspi read message successfullSTATUS is 0xff-0x00-0x00-0x00AT command sent:
AT#V24=2,1OK
rx_word-0xe6ffAT command sent:
AT#V24=2,0OK
register address:0message transmittedspi read message successfullSTATUS is 0xe6-0x00-0x00-0x00AT command sent:
AT#V24=2,1OK
rx_word-0xe6e6
ptr_read[index].word-0xe6e6
index - 20AT command sent:
AT#V24=2,0OK
register address:23message transmittedspi read message successfullSTATUS is 0xbc-0x00-0x00-0x00AT command sent:
AT#V24=2,1OK
rx_word-0xbc
AT command sent:
AT#V24=2,0OK
AT#V24=2,1OK
rx_word-0xe6e6
index - 21AT command sent:
AT#V24=2,0OK
register address:10message transmittedspi read message successfullSTATUS is 0xff-0x00-0x00-0x00
register address:24message transmittedspi read message successfullSTATUS is 0xbc-0x00-0x00-0x00AT command sent:
AT#V24=2,1OK
rx_word-0xffbcAT command sent:
AT#V24=2,0OK
AT#V24=2,1OK
rx_word-0xe6e6
index - 22
AT command sent:
AT#V24=2,0OK
register address:25message transmittedspi read message successfullSTATUS is 0xe6-0x00-0x00-0x00AT command sent:
AT#V24=2,1OK
rx_word-0xe6
AT command sent:
AT#V24=2,0OK
AT#V24=2,1OK
rx_word-0xbc00
index - 23AT command sent:
AT#V24=2,0OK
register address:26message transmittedspi read message successfullSTATUS is 0xe6-0x00-0x00-0x00AT command sent:
AT#V24=2,1OK
rx_word-0xe6e6
AT command sent:
AT#V24=2,0OK
AT#V24=2,1OK
rx_word-0xe6e6
index - 24AT command sent:
AT#V24=2,0OK
register address:27message transmittedspi read message successfullSTATUS is 0xbc-0x00-0x00-0x00AT command sent:
AT#V24=2,1OK
AT#V24=2,0OK
AT#V24=2,1OK
rx_word-0xbc00
index - 25
AT command sent:
AT#V24=2,0OK
AT#V24=2,1OK
rx_word-0x00AT command sent:
AT#V24=2,0OK
AT#V24=2,1OK
rx_word-0xe6ff
index - 26AT command sent:
AT#V24=2,0OK
register address:24message transmittedspi read message successfullSTATUS is 0xe6-0x00-0x00-0x00AT command sent:
AT#V24=2,1OK
rx_word-0xe6
XL AXIS - 230AT command sent:
AT#V24=2,0OK
AT#V24=2,1OK
rx_word-0xbc00AT command sent:
AT#V24=2,0OK
register address:25message transmittedspi read message successfullSTATUS is 0x00-0x00-0x00-0x00AT command sent:
AT#V24=2,1OK
rx_word-0xe600
XH AXIS - 58880AT command sent:
AT#V24=2,0OK
AT#V24=2,1OK
AT#V24=2,0OK
register address:26message transmittedspi read message successfullSTATUS is 0xbc-0x00-0x00-0x00AT command sent:
AT#V24=2,1OK
rx_word-0xbc
YL AXIS - 188AT command sent:
AT#V24=2,0OK
AT#V24=2,1OK
AT#V24=2,0OK
AT#V24=2,1OK
rx_word-0xbc
YH AXIS - 188AT command sent:
AT#V24=2,0OK
register address:20message transmittedspi read message successfullSTATUS is 0xff-0x00-0x00-0x00
AT#V24=2,1OK
rx_word-0xff00
X AXIS - 0
Y AXIS - 58880
X AXIS - 58880-230
Y AXIS - 188-188
mma6900->w_regs -  0
last_write -  0
X AXIS - 0
Y AXIS - 58880
X AXIS - 58880-230
Y AXIS - 188-188
%3CLINGO-SUB%20id%3D%22lingo-sub-815632%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMMA690xKQ%20interface%20sample%20codes%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-815632%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20any%20one%20share%20sample%20code%20of%20MMA690xKQ%20interface%20sample%20codes%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-815632%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EAccelerometers%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-815635%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MMA690xKQ%20interface%20sample%20codes%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-815635%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Tomas%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThanks%20for%20the%20reply%3C%2FP%3E%3CP%3EI%20was%20tried%20with%20same%20example%20aswell%3C%2FP%3E%3CP%3Epelase%20find%20tehresponses%20attached%3C%2FP%3E%3CP%3EAlways%20I%20am%20getting%20E6%2CBC%2C00...%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-815634%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MMA690xKQ%20interface%20sample%20codes%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-815634%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Emcm_internal_get_srv_id_for_msg_id%3A%20***%20msg_id%3A%20600%20%7C%20MIN%3A%20b00%20%7C%20MAX%3A%20b10%3CBR%20%2F%3Emcm_internal_get_srv_id_for_msg_id%3A%20***%20msg_id%3A%20600%20%7C%20MIN%3A%20100%20%7C%20MAX%3A%2010c%3CBR%20%2F%3Emcm_internal_get_srv_id_for_msg_id%3A%20***%20msg_id%3A%20600%20%7C%20MIN%3A%20400%20%7C%20MAX%3A%20427%3CBR%20%2F%3Emcm_internal_get_srv_id_for_msg_id%3A%20***%20msg_id%3A%20600%20%7C%20MIN%3A%20300%20%7C%20MAX%3A%20316%3CBR%20%2F%3Emcm_internal_get_srv_id_for_msg_id%3A%20***%20msg_id%3A%20600%20%7C%20MIN%3A%20600%20%7C%20MAX%3A%20600%3CBR%20%2F%3Emcm_internal_get_srv_id_for_msg_id%3A%20found%20service_id%20iter%3A8%3CBR%20%2F%3Eserver_execute_sync%3A%20server_execute_sync%20Enter%3CBR%20%2F%3Eserver_execute_sync%3A%20user_handle%3A7%2C%20msg_id%3A600%2C%20req_c_struct%3Ae190%2C%20req_c_struct_len%3A208%2C%20resp_c_struct%3Ae3a0%2C%20resp_c_struct_len%3A1010%3CBR%20%2F%3Emcm_client_execute_command_sync_ex%3A%20mcm_client_execute_command_sync_ex%20SUCCESS%20EXITAT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C1OK%3CBR%20%2F%3Erx_word-0xbc00%3CBR%20%2F%3Eptr_read%5Bindex%5D.word-0xbc00%3CBR%20%2F%3Eindex%20-%2013AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C0OK%3CBR%20%2F%3Eregister%20address%3A14message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200xe6-0x00-0x00-0x00%3CBR%20%2F%3Eregister%20address%3Aemessage%20transmittedspi%20read%20message%20successfullSTATUS%20is%200x00-0x00-0x00-0x00AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C1OK%3CBR%20%2F%3Erx_word-0xe600AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C0OK%3CBR%20%2F%3Eregister%20address%3A20message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200xbc-0x00-0x00-0x00%3CBR%20%2F%3Eregister%20address%3A0message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200x00-0x00-0x00-0x00AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C1OK%3CBR%20%2F%3Erx_word-0xbc00%3CBR%20%2F%3Eptr_read%5Bindex%5D.word-0xbc00%3CBR%20%2F%3Eindex%20-%2014AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C0OK%3CBR%20%2F%3Eregister%20address%3A10message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200x00-0x00-0x00-0x00%3CBR%20%2F%3Eregister%20address%3Afmessage%20transmittedspi%20read%20message%20successfullSTATUS%20is%200xe6-0x00-0x00-0x00%3CBR%20%2F%3EAT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C1OK%3CBR%20%2F%3Erx_word-0xe6AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C0OK%3CBR%20%2F%3Eregister%20address%3A20message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200xbc-0x00-0x00-0x00%3CBR%20%2F%3Eregister%20address%3A0message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200x00-0x00-0x00-0x00AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C1OK%3CBR%20%2F%3Erx_word-0xbc00%3CBR%20%2F%3Eptr_read%5Bindex%5D.word-0xbc00%3CBR%20%2F%3Eindex%20-%2015AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C0OK%3CBR%20%2F%3Eregister%20address%3A14message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200xe6-0x00-0x00-0x00%3CBR%20%2F%3Eregister%20address%3A10message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200xe6-0x00-0x00-0x00AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C1OK%3CBR%20%2F%3Erx_word-0xe6e6AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C0OK%3CBR%20%2F%3Eregister%20address%3A20message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200xe6-0x00-0x00-0x00%3CBR%20%2F%3Eregister%20address%3A0message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200xff-0x00-0x00-0x00AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C1OK%3CBR%20%2F%3Erx_word-0xe6ff%3CBR%20%2F%3Eptr_read%5Bindex%5D.word-0xe6ff%3CBR%20%2F%3Eindex%20-%2016AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C0OK%3CBR%20%2F%3Eregister%20address%3A10message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200x00-0x00-0x00-0x00%3CBR%20%2F%3Eregister%20address%3A11message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200xe6-0x00-0x00-0x00AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C1OK%3CBR%20%2F%3Erx_word-0xe6AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C0OK%3CBR%20%2F%3Eregister%20address%3A20message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200xbc-0x00-0x00-0x00%3CBR%20%2F%3Eregister%20address%3A0message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200x00-0x00-0x00-0x00AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C1OK%3CBR%20%2F%3Erx_word-0xbc00%3CBR%20%2F%3Eptr_read%5Bindex%5D.word-0xbc00%3CBR%20%2F%3Eindex%20-%2017AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C0OK%3CBR%20%2F%3Eregister%20address%3A14message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200x00-0x00-0x00-0x00%3CBR%20%2F%3Eregister%20address%3A20message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200xbc-0x00-0x00-0x00AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C1OK%3CBR%20%2F%3Erx_word-0xbcAT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C0OK%3CBR%20%2F%3Eregister%20address%3A20message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200xe6-0x00-0x00-0x00%3CBR%20%2F%3Eregister%20address%3A0message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200xff-0x00-0x00-0x00AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C1OK%3CBR%20%2F%3Erx_word-0xe6ff%3CBR%20%2F%3Eptr_read%5Bindex%5D.word-0xe6ff%3CBR%20%2F%3Eindex%20-%2018AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C0OK%3CBR%20%2F%3Eregister%20address%3A10message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200x00-0x00-0x00-0x00%3CBR%20%2F%3Eregister%20address%3A21message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200xe6-0x00-0x00-0x00AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C1OK%3CBR%20%2F%3Erx_word-0xe6AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C0OK%3CBR%20%2F%3Eregister%20address%3A20message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200xbc-0x00-0x00-0x00%3CBR%20%2F%3Eregister%20address%3A0message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200x00-0x00-0x00-0x00AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C1OK%3CBR%20%2F%3Erx_word-0xbc00%3CBR%20%2F%3Eptr_read%5Bindex%5D.word-0xbc00%3CBR%20%2F%3Eindex%20-%2019%3CBR%20%2F%3EAT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C0OK%3CBR%20%2F%3Eregister%20address%3A10message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200xe6-0x00-0x00-0x00%3CBR%20%2F%3Eregister%20address%3A22message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200xff-0x00-0x00-0x00AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C1OK%3CBR%20%2F%3Erx_word-0xe6ffAT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C0OK%3CBR%20%2F%3Eregister%20address%3A20message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200xe6-0x00-0x00-0x00%3CBR%20%2F%3Eregister%20address%3A0message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200xe6-0x00-0x00-0x00AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C1OK%3CBR%20%2F%3Erx_word-0xe6e6%3CBR%20%2F%3Eptr_read%5Bindex%5D.word-0xe6e6%3CBR%20%2F%3Eindex%20-%2020AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C0OK%3CBR%20%2F%3Eregister%20address%3A14message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200x00-0x00-0x00-0x00%3CBR%20%2F%3Eregister%20address%3A23message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200xbc-0x00-0x00-0x00AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C1OK%3CBR%20%2F%3Erx_word-0xbc%3CBR%20%2F%3EAT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C0OK%3CBR%20%2F%3Eregister%20address%3A20message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200xe6-0x00-0x00-0x00%3CBR%20%2F%3Eregister%20address%3A0message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200xe6-0x00-0x00-0x00AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C1OK%3CBR%20%2F%3Erx_word-0xe6e6%3CBR%20%2F%3Eptr_read%5Bindex%5D.word-0xe6e6%3CBR%20%2F%3Eindex%20-%2021AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C0OK%3CBR%20%2F%3Eregister%20address%3A10message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200xff-0x00-0x00-0x00%3CBR%20%2F%3Eregister%20address%3A24message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200xbc-0x00-0x00-0x00AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C1OK%3CBR%20%2F%3Erx_word-0xffbcAT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C0OK%3CBR%20%2F%3Eregister%20address%3A20message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200xe6-0x00-0x00-0x00%3CBR%20%2F%3Eregister%20address%3A0message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200xe6-0x00-0x00-0x00AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C1OK%3CBR%20%2F%3Erx_word-0xe6e6%3CBR%20%2F%3Eptr_read%5Bindex%5D.word-0xe6e6%3CBR%20%2F%3Eindex%20-%2022%3CBR%20%2F%3EAT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C0OK%3CBR%20%2F%3Eregister%20address%3A14message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200x00-0x00-0x00-0x00%3CBR%20%2F%3Eregister%20address%3A25message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200xe6-0x00-0x00-0x00AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C1OK%3CBR%20%2F%3Erx_word-0xe6%3CBR%20%2F%3EAT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C0OK%3CBR%20%2F%3Eregister%20address%3A20message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200xbc-0x00-0x00-0x00%3CBR%20%2F%3Eregister%20address%3A0message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200x00-0x00-0x00-0x00AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C1OK%3CBR%20%2F%3Erx_word-0xbc00%3CBR%20%2F%3Eptr_read%5Bindex%5D.word-0xbc00%3CBR%20%2F%3Eindex%20-%2023AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C0OK%3CBR%20%2F%3Eregister%20address%3A14message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200xe6-0x00-0x00-0x00%3CBR%20%2F%3Eregister%20address%3A26message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200xe6-0x00-0x00-0x00AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C1OK%3CBR%20%2F%3Erx_word-0xe6e6%3CBR%20%2F%3EAT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C0OK%3CBR%20%2F%3Eregister%20address%3A20message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200xe6-0x00-0x00-0x00%3CBR%20%2F%3Eregister%20address%3A0message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200xe6-0x00-0x00-0x00AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C1OK%3CBR%20%2F%3Erx_word-0xe6e6%3CBR%20%2F%3Eptr_read%5Bindex%5D.word-0xe6e6%3CBR%20%2F%3Eindex%20-%2024AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C0OK%3CBR%20%2F%3Eregister%20address%3A10message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200x00-0x00-0x00-0x00%3CBR%20%2F%3Eregister%20address%3A27message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200xbc-0x00-0x00-0x00AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C1OK%3CBR%20%2F%3Erx_word-0xbcAT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C0OK%3CBR%20%2F%3Eregister%20address%3A20message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200xbc-0x00-0x00-0x00%3CBR%20%2F%3Eregister%20address%3A0message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200x00-0x00-0x00-0x00AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C1OK%3CBR%20%2F%3Erx_word-0xbc00%3CBR%20%2F%3Eptr_read%5Bindex%5D.word-0xbc00%3CBR%20%2F%3Eindex%20-%2025%3CBR%20%2F%3EAT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C0OK%3CBR%20%2F%3Eregister%20address%3A10message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200x00-0x00-0x00-0x00%3CBR%20%2F%3Eregister%20address%3A0message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200x00-0x00-0x00-0x00AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C1OK%3CBR%20%2F%3Erx_word-0x00AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C0OK%3CBR%20%2F%3Eregister%20address%3A20message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200xe6-0x00-0x00-0x00%3CBR%20%2F%3Eregister%20address%3A0message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200xff-0x00-0x00-0x00AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C1OK%3CBR%20%2F%3Erx_word-0xe6ff%3CBR%20%2F%3Eptr_read%5Bindex%5D.word-0xe6ff%3CBR%20%2F%3Eindex%20-%2026AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C0OK%3CBR%20%2F%3Eregister%20address%3A10message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200x00-0x00-0x00-0x00%3CBR%20%2F%3Eregister%20address%3A24message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200xe6-0x00-0x00-0x00AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C1OK%3CBR%20%2F%3Erx_word-0xe6%3CBR%20%2F%3EXL%20AXIS%20-%20230AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C0OK%3CBR%20%2F%3Eregister%20address%3A20message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200xbc-0x00-0x00-0x00%3CBR%20%2F%3Eregister%20address%3A0message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200x00-0x00-0x00-0x00AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C1OK%3CBR%20%2F%3Erx_word-0xbc00AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C0OK%3CBR%20%2F%3Eregister%20address%3A14message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200xe6-0x00-0x00-0x00%3CBR%20%2F%3Eregister%20address%3A25message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200x00-0x00-0x00-0x00AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C1OK%3CBR%20%2F%3Erx_word-0xe600%3CBR%20%2F%3EXH%20AXIS%20-%2058880AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C0OK%3CBR%20%2F%3Eregister%20address%3A20message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200xbc-0x00-0x00-0x00%3CBR%20%2F%3Eregister%20address%3A0message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200x00-0x00-0x00-0x00AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C1OK%3CBR%20%2F%3Erx_word-0xbc00AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C0OK%3CBR%20%2F%3Eregister%20address%3A14message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200x00-0x00-0x00-0x00%3CBR%20%2F%3Eregister%20address%3A26message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200xbc-0x00-0x00-0x00AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C1OK%3CBR%20%2F%3Erx_word-0xbc%3CBR%20%2F%3EYL%20AXIS%20-%20188AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C0OK%3CBR%20%2F%3Eregister%20address%3A20message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200xe6-0x00-0x00-0x00%3CBR%20%2F%3Eregister%20address%3A0message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200xe6-0x00-0x00-0x00AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C1OK%3CBR%20%2F%3Erx_word-0xe6e6AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C0OK%3CBR%20%2F%3Eregister%20address%3A10message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200x00-0x00-0x00-0x00%3CBR%20%2F%3Eregister%20address%3A27message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200xbc-0x00-0x00-0x00AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C1OK%3CBR%20%2F%3Erx_word-0xbc%3CBR%20%2F%3EYH%20AXIS%20-%20188AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C0OK%3CBR%20%2F%3Eregister%20address%3A20message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200xff-0x00-0x00-0x00%3CBR%20%2F%3Eregister%20address%3A0message%20transmittedspi%20read%20message%20successfullSTATUS%20is%200x00-0x00-0x00-0x00AT%20command%20sent%3A%20%3CBR%20%2F%3EAT%23V24%3D2%2C1OK%3CBR%20%2F%3Erx_word-0xff00%3CBR%20%2F%3EX%20AXIS%20-%200%3CBR%20%2F%3EY%20AXIS%20-%2058880%3CBR%20%2F%3EX%20AXIS%20-%2058880-230%3CBR%20%2F%3EY%20AXIS%20-%20188-188%3CBR%20%2F%3Emma6900-%26gt%3Bw_regs%20-%26nbsp%3B%200%3CBR%20%2F%3Elast_write%20-%26nbsp%3B%200%3CBR%20%2F%3EX%20AXIS%20-%200%3CBR%20%2F%3EY%20AXIS%20-%2058880%3CBR%20%2F%3EX%20AXIS%20-%2058880-230%3CBR%20%2F%3EY%20AXIS%20-%20188-188%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-815633%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MMA690xKQ%20interface%20sample%20codes%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-815633%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Jaya%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3EThe%20only%20example%20code%20I%20am%20aware%20of%20is%20part%20of%20the%26nbsp%3BTWR_SENSOR_AUTO_FW%20package%20that%20can%20be%20downloaded%20from%20the%20following%20website%3A%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fsupport%2Fdeveloper-resources%2Fevaluation-and-development-boards%2Ftower-development-boards%2Fplug-in-modules%2Fautomotive-low-g-accelerometer-tower-system-plug-in%3ATWRPI-MMA6900%3Ftab%3DDesign_Tools_Tab%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fsupport%2Fdeveloper-resources%2Fevaluation-and-development-boards%2Ftower-development-boards%2Fplug-in-modules%2Fautomotive-low-g-accelerometer-tower-system-plug-in%3ATWRPI-MMA6900%3Ftab%3DDesign_Tools_Tab%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EAutomotive%20Low-g%20Accelerometer%20Tower%C2%AE%20Plug-In%7CNXP%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3EScroll%20down%26nbsp%3Bto%20the%20bottom%20of%20the%20page%20and%20download%20the%20TWR_SENSOR_AUTO_FW.zip%20file.%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3EI%20hope%20it%20helps!%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3EBest%20regards%2C%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3ETomas%3C%2FP%3E%3C%2FLINGO-BODY%3E
