MM9Z1_638 Microcontroller Programming
mfatihkoseoglu
I am using MM9Z1638 microcontroller and i donwload code warior ide. I am looking a few example for MM9Z1638 but ı don't find any example.
Are there any example? If is not, how can i programming this microcontroller.
Thank you.
TomasVaverka
Hello Muhammed,
Please download the MM9Z1_638 Demo and Driver Library from: https://file.io/FHxXb4Tcqc3W
Below is a list of the demo supported by this library:
  • RD9Z1-638-12V-C
  • RD9Z1-638-12V-L
  • KIT9Z1J638EVM (SCI Demo)
  • KIT9Z1J638EVM (LIN Demo)
  • KIT9Z1J638EVM (CAN Demo)
For more information, please have a look at the Documentation.html file in the MM9Z1J638-Demo-APPSW\638_drv_lib\docu folder.
Tomas
mfatihkoseoglu
Hello Tomas
I will examine and work this driver library, thank you so much.
TomasVaverka
Hello Muhammed,
  • RD9Z1-638-12V-C
  • RD9Z1-638-12V-L
Tomas
senseXiao
Hello, I saw your post when I was searching for the example of 638, but the link to open is no longer valid, could you please do it again? Thank you very much.
mfatihkoseoglu
Thank you.
