JN5169 - i2c Communication - Raspberry Pi.
3,425 次查看
matthew3
Hello Community,
   I have a PCB Board which  as on it the JN5169 microcontroller (Slave). I have a Sesnor attached to this through an amplifier board . I am reading this through one of the 6 ADC channels but i want to send this to a Raspberry Pi (Master) using i2c communication.
What i am asking the community is there any examples out there or could i be pointed to an application note where i2c is used. I have searched on NXP or the internet but not succesful in finding exactly what i am looking for.
Matthew
标记 (2)
5 回复数
3,206 次查看
mario_castaneda
Hi Matthew,
Please look at 13. Serial Interface (SI).
JN516x Integrated Peripherals API User Guide
If you will work with interrupt service routine.
OS_ISR(vI2C_SlaveIsr)
    /* Read interrupt status */
    uint32 u32SiStat = u32REG_SiSlaveRead(REG_SI_STAT);
    /* Clear interrupt status (for ALL interrupts that just occurred) */
    vREG_SiSlaveWrite(REG_SI_STAT, u32SiStat);
    /* Handle interrupt */
    if (u32SiStat & E_AHI_SIS_DATA_RR_MASK)
    else if (/* Other masks */)
Hope it helps.
Mario
3,206 次查看
matthew3
Hi Mario,
   Thank you for the reply.
Just another question. The code above that you replied with. Is that from an application note or is it direclty what you have typed out to show me?
Matthew
3,206 次查看
mario_castaneda
Hi Matthew,
The User Guide provides the information to how enabled the SI.
The code is an implementation for the ISR cleaning the SI flag.
Mario
3,206 次查看
matthew3
Hi Mario,
   Thank you for the help. Will look at the User Guide and figure out how to write complete code for my application.
Matthew
3,206 次查看
mario_castaneda
Hi Matthew Wood,
Please let me know if you have issues with your implementation and I could provide some advice.
Mario
