How to handle ReduceTransmisionForVGACalib flag?
738 次查看
squareroots
the function Helper_ES2_CalTXRFRangeCheck() in the SDK v1.2.0 checks for CalStart flags and reduce flag:
if ((ReduceTransmisionForVGACalib == TRUE) && (pEnableTxRfCalibration->VgaCalStart == TRUE) && (pEnableTxRfCalibration->PoutCalStart == TRUE))
    ErrCode = BC_ERR_TX_POUT_VGA_REDUCETX_NOTSUPPORTED;
What does "NOTSUPPORTED" means:
  • It does not work?
  • It is not implemented yet?
How can I use reduced transmission if I have enabled PoutCalStart, VgaCalStart and ReduceTransmisionForVGACalib? Is there any detailed sequence diagram for this use case?
标记 (3)
579 次查看
RafaR
Hi Squareroots
Okay, I was working and trying to make examples and I concluded that "NORSUPPORTED" refers to the fact that it is not yet implemented.
For the diagram I can't find any official document so I contacted a colleague to double check with another team, I will get back to you when I get a response.
Have a great day and best of luck.
689 次查看
RafaR
Hi Squareroots
I am starting to work on your case, I will contact you soon.
