For MMA685x Accelerometer, what is the maximum junction temperature Tj?
gerardseipelt
For MMA685x Accelerometer, what is the maximum junction temperature Tj?  The datasheet lists a Storage Temperature Range of -40C to +125C, but Max Tj is not provided.
TomasVaverka
Hi Gerard,
I do not have an exact number, but the very low power consumption leads to a negligable increase of the junction temperature (<< 1 °C).
Tomas
gerardseipelt
Thank you Tomas for the quick response.
I do not anticipate the device exceeding the Max Tj in our application; the worst case hot operating temperature is around 70°C. However, the Reliability Report I am compiling requires documentation of the manufacturer’s Max Tj for all semiconductor devices and microcircuits in the design.
Since the Max Storage Temperature is listed as 125°C, is it a reasonable to also use this as Freescale’s rating for the Max Tj? If not, can Freescale provide a value for the Max Tj rating?
Gerry Seipelt
L-3 Communications
O: 513.943.2226
TomasVaverka
Hi Gerard,
OK, I need to check on this. I have emailed our apps/design team and will update this thread once I have their answer.
Tomas
TomasVaverka
Hi Gerard,
I just got an answer from our apps/design team, the maximum junction temperature Tj is 85 °C.
Tomas
%3CLINGO-SUB%20id%3D%22lingo-sub-461199%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFor%20MMA685x%20Accelerometer%2C%20what%20is%20the%20maximum%20junction%20temperature%20Tj%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-461199%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EFor%20MMA685x%20Accelerometer%2C%20what%20is%20the%20maximum%20junction%20temperature%20Tj%3F%26nbsp%3B%20The%20datasheet%20lists%20a%20Storage%20Temperature%20Range%20of%20-40C%20to%20%2B125C%2C%20but%20Max%20Tj%20is%20not%20provided.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-461199%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EAccelerometers%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-461203%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20For%20MMA685x%20Accelerometer%2C%20what%20is%20the%20maximum%20junction%20temperature%20Tj%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-461203%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Gerard%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20just%20got%20an%20answer%20from%20our%20apps%2Fdesign%20team%2C%20the%20maximum%20junction%20temperature%20Tj%20is%2085%20%C2%B0C.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ERegards%2C%3C%2FP%3E%3CP%3ETomas%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-461202%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20For%20MMA685x%20Accelerometer%2C%20what%20is%20the%20maximum%20junction%20temperature%20Tj%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-461202%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Gerard%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EOK%2C%20I%20need%20to%20check%20on%20this.%20I%20have%20emailed%20our%20apps%2Fdesign%20team%20and%20will%20update%20this%20thread%20once%20I%20have%20their%20answer.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ERegards%2C%3C%2FP%3E%3CP%3ETomas%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-461201%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20For%20MMA685x%20Accelerometer%2C%20what%20is%20the%20maximum%20junction%20temperature%20Tj%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-461201%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThank%20you%20Tomas%20for%20the%20quick%20response.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20do%20not%20anticipate%20the%20device%20exceeding%20the%20Max%20Tj%20in%20our%20application%3B%20the%20worst%20case%20hot%20operating%20temperature%20is%20around%2070%C2%B0C.%20%20However%2C%20the%20Reliability%20Report%20I%20am%20compiling%20requires%20documentation%20of%20the%20manufacturer%E2%80%99s%20Max%20Tj%20for%20all%20semiconductor%20devices%20and%20microcircuits%20in%20the%20design.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESince%20the%20Max%20Storage%20Temperature%20is%20listed%20as%20125%C2%B0C%2C%20is%20it%20a%20reasonable%20to%20also%20use%20this%20as%20Freescale%E2%80%99s%20rating%20for%20the%20Max%20Tj%3F%20If%20not%2C%20can%20Freescale%20provide%20a%20value%20for%20the%20Max%20Tj%20rating%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ERegards%2C%3C%2FP%3E%3CP%3EGerry%20Seipelt%3C%2FP%3E%3CP%3EL-3%20Communications%3C%2FP%3E%3CP%3EO%3A%20513.943.2226%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-461200%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20For%20MMA685x%20Accelerometer%2C%20what%20is%20the%20maximum%20junction%20temperature%20Tj%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-461200%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Gerard%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN%22%3EI%20do%20not%20have%20an%20exact%20number%2C%20but%20the%20very%20low%20power%20consumption%20leads%20to%20a%20negligable%20increase%20of%20the%20junction%20temperature%20(%26lt%3B%26lt%3B%201%20%C2%B0C).%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN%22%3ERegards%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN%22%3ETomas%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
