FXLS8964 - Config
FXLS8964 - Config
1,539件の閲覧回数
MaTa
Is there a configuration for this sensor family where the sensor can generate an interrupt for both ~2g transient acceleration and ~3 degree tilt angle change? Would like to set up a HPF and LPF respectively on the sensor, so there is minimum processing on the host side.
3 返答(返信)
1,486件の閲覧回数
MaTa
Thanks for the reply Jozef, the orientation engine depends on the z-lock condition correct? The ~3 degree tilt detection would be the angle between gravity vector and the Z-axes.
1,446件の閲覧回数
JozefKozon
Dear Matt,
yes, your understanding is correct.
  • Orientation Engine and Z-Lock
    The FXLS8964AF orientation engine uses the z-lock condition to determine whether the device is in a stable orientation relative to gravity. Z-lock essentially checks if the Z-axis is aligned closely enough with the gravity vector (within a configurable threshold). When z-lock is active, the orientation engine can reliably classify the device as "face-up" or "face-down."
  • Tilt Detection (~3°)
    The tilt angle is indeed calculated as the angle between the gravity vector (derived from accelerometer readings) and the Z-axis of the sensor. A 3° tilt means the Z-axis deviates by about 3° from the gravity vector, which is typically used to detect slight movements or confirm orientation stability.
With Best Regards,
Jozef
1,502件の閲覧回数
JozefKozon
Dear Matt,
yes, FXLS8964AF supports a configuration where:
  • Transient detection (~2 g) uses SDCD in relative mode (HPF-like behavior).
  • Tilt detection (~3°) uses the orientation engine (LPF-based). Both can assert hardware interrupts, minimizing host-side computation.
Please try following settings.
With Best Regards,
Jozef
%3CLINGO-SUB%20id%3D%22lingo-sub-2292059%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFXLS8964%20-%20%E6%A7%8B%E6%88%90%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2292059%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%81%AE%E3%82%BB%E3%83%B3%E3%82%B5%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%81%AB%E3%81%AF%E3%80%81%E7%B4%84%202g%20%E3%81%AE%E9%81%8E%E6%B8%A1%E5%8A%A0%E9%80%9F%E5%BA%A6%E3%81%A8%E7%B4%84%203%20%E5%BA%A6%E3%81%AE%E5%82%BE%E3%81%8D%E8%A7%92%E5%BA%A6%E3%81%AE%E5%A4%89%E5%8C%96%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%E3%82%BB%E3%83%B3%E3%82%B5%E3%81%8C%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%E7%94%9F%E6%88%90%E3%81%A7%E3%81%8D%E3%82%8B%E6%A7%8B%E6%88%90%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%83%9B%E3%82%B9%E3%83%88%E5%81%B4%E3%81%A7%E3%81%AE%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B7%E3%83%B3%E3%82%B0%E3%81%8C%E6%9C%80%E5%B0%8F%E9%99%90%E3%81%AB%E3%81%AA%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E3%82%BB%E3%83%B3%E3%82%B5%E3%81%AB%E3%81%9D%E3%82%8C%E3%81%9E%E3%82%8C%20HPF%20%E3%81%A8%20LPF%20%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2292059%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%8A%A0%E9%80%9F%E5%BA%A6%E3%82%BB%E3%83%B3%E3%82%B5%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2292960%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FXLS8964%20-%20Config%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2292960%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%9E%E3%83%83%E3%83%88%E6%A7%98%3C%2FP%3E%0A%3CP%3E%E3%81%AF%E3%81%84%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E7%90%86%E8%A7%A3%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CDIV%3E%0A%3CUL%3E%0A%3CLI%3E%0A%3CP%3E%E3%82%AA%E3%83%AA%E3%82%A8%E3%83%B3%E3%83%86%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%B3%E3%81%A8Z%E3%83%AD%E3%83%83%E3%82%AF%3CBR%20%2F%3EFXLS8964AF%20%E6%96%B9%E5%90%91%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%B3%E3%81%AF%E3%80%81Z%20%E3%83%AD%E3%83%83%E3%82%AF%E6%9D%A1%E4%BB%B6%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E9%87%8D%E5%8A%9B%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%E5%AE%89%E5%AE%9A%E3%81%97%E3%81%9F%E6%96%B9%E5%90%91%E3%81%AB%E3%81%82%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E5%88%A4%E6%96%AD%E3%81%97%E3%81%BE%E3%81%99%E3%80%82Z%20%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AF%E5%9F%BA%E6%9C%AC%E7%9A%84%E3%81%AB%E3%80%81Z%20%E8%BB%B8%E3%81%8C%E9%87%8D%E5%8A%9B%E3%83%99%E3%82%AF%E3%83%88%E3%83%AB%E3%81%A8%E5%8D%81%E5%88%86%E3%81%AB%E8%BF%91%E3%81%84%E4%BD%8D%E7%BD%AE%E3%81%AB%E3%81%82%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%20(%E8%A8%AD%E5%AE%9A%E5%8F%AF%E8%83%BD%E3%81%AA%E3%81%97%E3%81%8D%E3%81%84%E5%80%A4%E5%86%85)%20%E3%82%92%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%99%E3%80%82Z%20%E3%83%AD%E3%83%83%E3%82%AF%E3%81%8C%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%81%AA%E5%A0%B4%E5%90%88%E3%80%81%E6%96%B9%E5%90%91%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%B3%E3%81%AF%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%80%8C%E4%B8%8A%E5%90%91%E3%81%8D%E3%80%8D%E3%81%BE%E3%81%9F%E3%81%AF%E3%80%8C%E4%B8%8B%E5%90%91%E3%81%8D%E3%80%8D%E3%81%A8%E3%81%97%E3%81%A6%E7%A2%BA%E5%AE%9F%E3%81%AB%E5%88%86%E9%A1%9E%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3E%E5%82%BE%E3%81%8D%E6%A4%9C%E5%87%BA%EF%BC%88%E7%B4%843%C2%B0%EF%BC%89%3CBR%20%2F%3E%E5%82%BE%E6%96%9C%E8%A7%92%E5%BA%A6%E3%81%AF%E3%80%81%E5%AE%9F%E9%9A%9B%E3%81%AB%E3%81%AF%E9%87%8D%E5%8A%9B%E3%83%99%E3%82%AF%E3%83%88%E3%83%AB%20(%E5%8A%A0%E9%80%9F%E5%BA%A6%E3%82%BB%E3%83%B3%E3%82%B5%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E5%80%A4%E3%81%8B%E3%82%89%E5%B0%8E%E5%87%BA)%20%E3%81%A8%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%81%AE%20Z%20%E8%BB%B8%E3%81%AE%E9%96%93%E3%81%AE%E8%A7%92%E5%BA%A6%E3%81%A8%E3%81%97%E3%81%A6%E8%A8%88%E7%AE%97%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%823%C2%B0%20%E3%81%AE%E5%82%BE%E3%81%8D%E3%81%AF%E3%80%81Z%20%E8%BB%B8%E3%81%8C%E9%87%8D%E5%8A%9B%E3%83%99%E3%82%AF%E3%83%88%E3%83%AB%E3%81%8B%E3%82%89%E7%B4%84%203%C2%B0%20%E3%81%9A%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E9%80%9A%E5%B8%B8%E3%80%81%E3%82%8F%E3%81%9A%E3%81%8B%E3%81%AA%E5%8B%95%E3%81%8D%E3%82%92%E6%A4%9C%E5%87%BA%E3%81%97%E3%81%9F%E3%82%8A%E3%80%81%E6%96%B9%E5%90%91%E3%81%AE%E5%AE%89%E5%AE%9A%E6%80%A7%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E6%95%AC%E5%85%B7%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%83%A8%E3%82%BC%E3%83%95%3C%2FP%3E%0A%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2292758%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FXLS8964%20-%20Config%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2292758%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%81Jozef%E3%80%82%E6%96%B9%E5%90%91%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%B3%E3%81%AF%20Z%20%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E7%8A%B6%E6%85%8B%E3%81%AB%E4%BE%9D%E5%AD%98%E3%81%99%E3%82%8B%E3%82%93%E3%81%A7%E3%81%99%E3%82%88%E3%81%AD%EF%BC%9F%E7%B4%84%203%20%E5%BA%A6%E3%81%AE%E5%82%BE%E3%81%8D%E3%81%AE%E6%A4%9C%E5%87%BA%E3%81%AF%E3%80%81%E9%87%8D%E5%8A%9B%E3%83%99%E3%82%AF%E3%83%88%E3%83%AB%E3%81%A8%20Z%20%E8%BB%B8%E9%96%93%E3%81%AE%E8%A7%92%E5%BA%A6%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2292233%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FXLS8964%20-%20Config%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2292233%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E%E3%83%9E%E3%83%83%E3%83%88%E6%A7%98%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E%E3%81%AF%E3%81%84%E3%80%81FXLS8964AF%20%E3%81%AF%E6%AC%A1%E3%81%AE%E6%A7%8B%E6%88%90%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%3A%3C%2FFONT%3E%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CFONT%20size%3D%222%22%3E%E9%81%8E%E6%B8%A1%E6%A4%9C%E5%87%BA%20(~2%20g)%20%E3%81%A7%E3%81%AF%E7%9B%B8%E5%AF%BE%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%20SDCD%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%20(HPF%20%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E5%8B%95%E4%BD%9C)%E3%80%82%3C%2FFONT%3E%3C%2FLI%3E%0A%3CLI%3E%3CFONT%20size%3D%222%22%3E%E5%82%BE%E3%81%8D%E6%A4%9C%E5%87%BA%20(%E7%B4%84%203%C2%B0)%20%E3%81%AB%E3%81%AF%E6%96%B9%E5%90%91%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%B3%20(LPF%20%E3%83%99%E3%83%BC%E3%82%B9)%20%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%A9%E3%81%A1%E3%82%89%E3%82%82%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%E3%82%A2%E3%82%B5%E3%83%BC%E3%83%88%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%83%9B%E3%82%B9%E3%83%88%E5%81%B4%E3%81%AE%E8%A8%88%E7%AE%97%E3%81%8C%E6%9C%80%E5%B0%8F%E9%99%90%E3%81%AB%E6%8A%91%E3%81%88%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FFONT%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E3%81%8A%E8%A9%A6%E3%81%97%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%0A%3CFONT%20size%3D%222%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22JozefKozon_0-1768286537626.png%22%20style%3D%22width%3A%20521px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JozefKozon_0-1768286537626.png%22%20style%3D%22width%3A%20521px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F372597i4D19BA7A68827E8F%2Fimage-dimensions%2F521x532%3Fv%3Dv2%22%20width%3D%22521%22%20height%3D%22532%22%20role%3D%22button%22%20title%3D%22JozefKozon_0-1768286537626.png%22%20alt%3D%22JozefKozon_0-1768286537626.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FFONT%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E%E6%95%AC%E5%85%B7%E3%80%81%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E%E3%83%A8%E3%82%BC%E3%83%95%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
