Example FXOS8700CQ Driver Code in Datasheet gives 0,0,256 for magnetometer x,y,z values
peter_macleod_t
The FXOS8700 is connected to Beaglebone Black via i2c.    The example code from the Datasheet is copied - print statements were added.   The accelerometer data seems fine but the magnetometer data is consistently 0,0,256.
The magnetometer control register 2,  FXOS8700CQ_M_CTRL_REG2, is being set to 0x20 for a burst read but it does not seem to work.
Not sure if this is being posted in the correct location....#
Peter
TomasVaverka
Hi Peter,
First off, please double check if m_hms[1:0] = 0b11 (hybrid mode).
Then I would recommend to check what is going on the bus using an oscilloscope or a logic analyzer. I have used a burst read in my example without any problems.
Tomas
%3CLINGO-SUB%20id%3D%22lingo-sub-899111%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EExample%20FXOS8700CQ%20Driver%20Code%20in%20Datasheet%20gives%200%2C0%2C256%20for%20magnetometer%20x%2Cy%2Cz%20values%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-899111%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThe%20FXOS8700%20is%20connected%20to%20Beaglebone%20Black%20via%20i2c.%26nbsp%3B%26nbsp%3B%26nbsp%3B%20The%20example%20code%20from%20the%20Datasheet%20is%20copied%20-%20print%20statements%20were%20added.%26nbsp%3B%26nbsp%3B%20The%20accelerometer%20data%20seems%20fine%20but%20the%20magnetometer%20data%20is%20consistently%200%2C0%2C256.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThe%20magnetometer%20control%20register%202%2C%26nbsp%3B%20FXOS8700CQ_M_CTRL_REG2%2C%20is%20being%20set%20to%200x20%20for%20a%20burst%20read%20but%20it%20does%20not%20seem%20to%20work.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ENot%20sure%20if%20this%20is%20being%20posted%20in%20the%20correct%20location....%23%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EPeter%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-899112%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Example%20FXOS8700CQ%20Driver%20Code%20in%20Datasheet%20gives%200%2C0%2C256%20for%20magnetometer%20x%2Cy%2Cz%20values%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-899112%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Peter%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EFirst%20off%2C%20please%20double%20check%20if%26nbsp%3Bm_hms%5B1%3A0%5D%20%3D%200b11%20(hybrid%20mode).%26nbsp%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThen%20I%20would%20recommend%20to%20check%20what%20is%20going%20on%20the%20bus%20using%20an%20oscilloscope%20or%20a%20logic%20analyzer.%20I%20have%20used%20a%20burst%20read%20in%20my%20%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-101073%22%20target%3D%22_blank%22%3Eexample%3C%2FA%3E%26nbsp%3Bwithout%20any%20problems.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBest%20regards%2C%3C%2FP%3E%3CP%3ETomas%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E
