Accelerometer FXOS8700CQ
1,663件の閲覧回数
joãopaulo
I am not able to use the FXOS8700CQ accelerometer present on the kv31f board.
I would like to use the freefall function and for this I configured the following registers.
Freefall ConfigurationZ < 0,3g using MFF Function 4g, 100 Hz ODR, Normal Mode
Register NameRegister AddrData (R/W)Description
CTRL_REG10x2A0x00 WStandby mode for writable operations
WHO_AM_I0x0DReadCheck device communication (0xC7)
XYZ_DATA_CFG0x0E0x01 WHight-pass filter disabled, +/-0.488mg/LSB
CTRL_REG10x2A0x18 WSet the device in 100 Hz ODR, Standby
A_FFMT_CFG0x150xA0 WLatch enable, Freefall, Z axis
A_FFMT_THS0x170x05 W0,3g threshold
A_FFMT_COUNT0x180x0A WDebounce 100ms
CTRL_REG40x2D0x04 WFF interrupt enable
CTRL_REG50x2E0x04 Winterrupt routed to INT1 pin
CTRL_REG10x2A0x19 WSet the device in 100 Hz ODR, Active Mode
- The communication is working properly because I can read the WHO_AM_I register,
- I've already followed the AN4070 document,
But it's not working, the Freefall interrupt isn't happening,
I've tried to use the 3 axes and then only one but none worked.
Is there any other register that I need to configure?
What else should I do?
タグ(1)
2 返答(返信)
1,442件の閲覧回数
david_diaz
Hello Paulo,
Your configuration seems correct.
Please make sure you have the correct pin configuration using the FRDM-KV31F as mentioned below, especially the INT1 pin:
Please try to decrease the value of the debounce counter (A_FFMT_COUNT = 0x01). Can you share your results? Is the interrupt generated at the PTD0 pin?
David
1,443件の閲覧回数
joãopaulo
There was a mistake on I2C write messages,
So I could read the Who_Am_I but when I was trying to write to registers it was working..
In the end the configuration that I did was:
CTRL_REG20x2B0x40 WReset all registers to POR values
XYZ_DATA_CFG0x0E0x00 WHight-pass filter disabled, +/-0.244mg/LSB, Full-Scale range +/-2g
M_CTRL_REG0x5B0x00 WOnly accelerometer sensor is active
CTRL_REG20x2B0x02 WHigh Resolution mode
CTRL_REG30x2C0x00 WPush-pull, active low interrupt
A_FFMT_CFG0x150x08 WFreefall detection for X axis
A_FFMT_THS0x170x04 WThreshold Setting Value for the Freefall detection of 0.2g (4 * 0.063)
A_FFMT_COUNT0x180x0A WSet the debounce counter to 1,6s timer (160ms * 10)
CTRL_REG10x2A0x35 WODR = 6.25Hz, Reduced noise, Active mode
João Paulo
%3CLINGO-SUB%20id%3D%22lingo-sub-695340%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%8A%A0%E9%80%9F%E5%BA%A6%E3%82%BB%E3%83%B3%E3%82%B5%20FXOS8700CQ%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-695340%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ekv31f%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E6%90%AD%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%20FXOS8700CQ%20%E5%8A%A0%E9%80%9F%E5%BA%A6%E3%82%BB%E3%83%B3%E3%82%B5%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%E3%83%95%E3%83%AA%E3%83%BC%E3%83%95%E3%82%A9%E3%83%BC%E3%83%AB%E6%A9%9F%E8%83%BD%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%81%84%E3%81%AE%E3%81%A7%E3%80%81%E6%AC%A1%E3%81%AE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CTABLE%20border%3D%221%22%20cellpadding%3D%220%22%20cellspacing%3D%220%22%20dir%3D%22ltr%22%20style%3D%22border%3A%20none%3B%20font-size%3A%2010pt%3B%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20colspan%3D%223%22%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E%E3%83%95%E3%83%AA%E3%83%BC%E3%83%95%E3%82%A9%E3%83%BC%E3%83%AB%E6%A7%8B%E6%88%90%3C%2FTD%3E%3CTD%20colspan%3D%224%22%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3EZ%20%26lt%3B%200.3g%E3%80%81MFF%E6%A9%9F%E8%83%BD4g%E3%80%81100%20Hz%20ODR%E3%80%81%E9%80%9A%E5%B8%B8%E3%83%A2%E3%83%BC%E3%83%89%E4%BD%BF%E7%94%A8%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E5%90%8D%3C%2FTD%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3C%2FTD%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E%E3%83%87%E3%83%BC%E3%82%BF%EF%BC%88%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%2F%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%EF%BC%89%3C%2FTD%3E%3CTD%20colspan%3D%224%22%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E%E8%AA%AC%E6%98%8E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3ECTRL_REG1%3C%2FTD%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E0x2A%3C%2FTD%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E0x00%20W%3C%2FTD%3E%3CTD%20colspan%3D%224%22%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E6%93%8D%E4%BD%9C%E3%81%AE%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%90%E3%82%A4%E3%83%A2%E3%83%BC%E3%83%89%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E%E7%A7%81%E3%81%AF%E8%AA%B0%E3%81%A7%E3%81%99%E3%81%8B%3C%2FTD%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E0x0D%3C%2FTD%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%3C%2FTD%3E%3CTD%20colspan%3D%224%22%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E9%80%9A%E4%BF%A1%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%20(0xC7)%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3EXYZ_%E3%83%87%E3%83%BC%E3%82%BF_CFG%3C%2FTD%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E0x0E%3C%2FTD%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E0x01%20W%3C%2FTD%3E%3CTD%20colspan%3D%224%22%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E%E3%83%8F%E3%82%A4%E3%83%91%E3%82%B9%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E7%84%A1%E5%8A%B9%E3%80%81%2B%2F-0.488mg%2FLSB%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3ECTRL_REG1%3C%2FTD%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E0x2A%3C%2FTD%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E0x18%20W%3C%2FTD%3E%3CTD%20colspan%3D%224%22%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92100%20Hz%20ODR%E3%80%81%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%90%E3%82%A4%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3EA_FFMT_CFG%3C%2FTD%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E0x15%3C%2FTD%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E0xA0%20W%3C%2FTD%3E%3CTD%20colspan%3D%224%22%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E%E3%83%A9%E3%83%83%E3%83%81%E6%9C%89%E5%8A%B9%E5%8C%96%E3%80%81%E3%83%95%E3%83%AA%E3%83%BC%E3%83%95%E3%82%A9%E3%83%BC%E3%83%AB%E3%80%81Z%E8%BB%B8%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3EA_FFMT_THS%3C%2FTD%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E0x17%3C%2FTD%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E0x05%20W%3C%2FTD%3E%3CTD%20colspan%3D%224%22%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E0.3g%E3%81%AE%E9%96%BE%E5%80%A4%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3EA_FFMT_COUNT%3C%2FTD%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E0x18%3C%2FTD%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E0x0A%20W%3C%2FTD%3E%3CTD%20colspan%3D%224%22%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E%E3%83%87%E3%83%90%E3%82%A6%E3%83%B3%E3%82%B9%20100ms%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3ECTRL_REG4%3C%2FTD%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E0x2D%3C%2FTD%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E0x04%20W%3C%2FTD%3E%3CTD%20colspan%3D%224%22%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3EFF%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E6%9C%89%E5%8A%B9%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3ECTRL_REG5%3C%2FTD%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E0x2E%3C%2FTD%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E0x04%20W%3C%2FTD%3E%3CTD%20colspan%3D%224%22%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%AFINT1%E3%83%94%E3%83%B3%E3%81%AB%E3%83%AB%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3ECTRL_REG1%3C%2FTD%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E0x2A%3C%2FTD%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E0x19%20W%3C%2FTD%3E%3CTD%20colspan%3D%224%22%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92100%20Hz%20ODR%E3%80%81%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E-%20WHO_AM_I%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%AE%E3%81%A7%E3%80%81%E9%80%9A%E4%BF%A1%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E-%20AN4070%E6%96%87%E6%9B%B8%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%E9%81%B5%E5%AE%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E6%A9%9F%E8%83%BD%E3%81%9B%E3%81%9A%E3%80%81%E3%83%95%E3%83%AA%E3%83%BC%E3%83%95%E3%82%A9%E3%83%BC%E3%83%AB%E3%81%AE%E4%B8%AD%E6%96%AD%E3%81%AF%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E3%20%E3%81%A4%E3%81%AE%E8%BB%B8%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%811%20%E3%81%A4%E3%81%AE%E8%BB%B8%E3%81%A0%E3%81%91%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%A9%E3%82%8C%E3%82%82%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%96%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E4%BB%96%E3%81%AB%E4%BD%95%E3%82%92%E3%81%99%E3%82%8C%E3%81%B0%E3%81%84%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-695342%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%20Accelerometer%20FXOS8700CQ%20%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-695342%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3EI2C%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AB%E8%AA%A4%E3%82%8A%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3ESO%E3%80%81Who_Am_I%20%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%82%E3%81%86%E3%81%A8%E3%81%97%E3%81%9F%E3%81%A8%E3%81%8D%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E6%9C%80%E7%B5%82%E7%9A%84%E3%81%AB%E7%A7%81%E3%81%8C%E8%A1%8C%E3%81%A3%E3%81%9F%E6%A7%8B%E6%88%90%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CTABLE%20border%3D%221%22%20cellpadding%3D%220%22%20cellspacing%3D%220%22%20dir%3D%22ltr%22%20style%3D%22border%3A%20none%3B%20font-size%3A%2010pt%3B%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E5%90%8D%3C%2FTD%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3C%2FTD%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E%E3%83%87%E3%83%BC%E3%82%BF%EF%BC%88%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%2F%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%EF%BC%89%3C%2FTD%3E%3CTD%20style%3D%22border-bottom%3A%201px%20solid%20%23000000%3B%20padding%3A%202px%203px%202px%203px%3B%22%3E%3C%2FTD%3E%3CTD%20style%3D%22border-bottom%3A%201px%20solid%20%23000000%3B%20padding%3A%202px%203px%202px%203px%3B%22%3E%3C%2FTD%3E%3CTD%20style%3D%22border-bottom%3A%201px%20solid%20%23000000%3B%20padding%3A%202px%203px%202px%203px%3B%22%3E%3C%2FTD%3E%3CTD%20style%3D%22border-bottom%3A%201px%20solid%20%23000000%3B%20padding%3A%202px%203px%202px%203px%3B%22%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3ECTRL_REG2%3C%2FTD%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E0x2B%3C%2FTD%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E0x40%20W%3C%2FTD%3E%3CTD%20colspan%3D%224%22%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92POR%E5%80%A4%E3%81%AB%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%99%E3%82%8B%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3EXYZ_%E3%83%87%E3%83%BC%E3%82%BF_CFG%3C%2FTD%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E0x0E%3C%2FTD%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E0x00%20W%3C%2FTD%3E%3CTD%20colspan%3D%224%22%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E%E3%83%8F%E3%82%A4%E3%83%91%E3%82%B9%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E7%84%A1%E5%8A%B9%E3%80%81%2B%2F-0.244mg%2FLSB%E3%80%81%E3%83%95%E3%83%AB%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E7%AF%84%E5%9B%B2%20%2B%2F-2g%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3EM_CTRL_REG%3C%2FTD%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E0x5B%3C%2FTD%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E0x00%20W%3C%2FTD%3E%3CTD%20colspan%3D%224%22%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E%E5%8A%A0%E9%80%9F%E5%BA%A6%E3%82%BB%E3%83%B3%E3%82%B5%E3%81%AE%E3%81%BF%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3ECTRL_REG2%3C%2FTD%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E0x2B%3C%2FTD%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E0x02%20W%3C%2FTD%3E%3CTD%20colspan%3D%224%22%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E%E9%AB%98%E8%A7%A3%E5%83%8F%E5%BA%A6%E3%83%A2%E3%83%BC%E3%83%89%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3ECTRL_REG3%3C%2FTD%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E0x2C%3C%2FTD%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E0x00%20W%3C%2FTD%3E%3CTD%20colspan%3D%224%22%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E%E3%83%97%E3%83%83%E3%82%B7%E3%83%A5%E3%83%97%E3%83%AB%E3%80%81%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%83%AD%E3%83%BC%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3EA_FFMT_CFG%3C%2FTD%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E0x15%3C%2FTD%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E0x08%20W%3C%2FTD%3E%3CTD%20colspan%3D%224%22%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3EX%E8%BB%B8%E3%81%AE%E8%87%AA%E7%94%B1%E8%90%BD%E4%B8%8B%E6%A4%9C%E5%87%BA%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3EA_FFMT_THS%3C%2FTD%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E0x17%3C%2FTD%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E0x04%20W%3C%2FTD%3E%3CTD%20colspan%3D%224%22%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E%E8%87%AA%E7%94%B1%E8%90%BD%E4%B8%8B%E6%A4%9C%E5%87%BA%E9%96%BE%E5%80%A4%E8%A8%AD%E5%AE%9A%E5%80%A4%200.2g%20(4%20*%200.063)%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3EA_FFMT_COUNT%3C%2FTD%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E0x18%3C%2FTD%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E0x0A%20W%3C%2FTD%3E%3CTD%20colspan%3D%224%22%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E%E3%83%87%E3%83%90%E3%82%A6%E3%83%B3%E3%82%B9%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%E3%82%921.6%E7%A7%92%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%EF%BC%88160ms%20*%2010%EF%BC%89%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3ECTRL_REG4%3C%2FTD%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E0x2D%3C%2FTD%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E0x04%20W%3C%2FTD%3E%3CTD%20colspan%3D%224%22%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3EFF%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E6%9C%89%E5%8A%B9%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3ECTRL_REG5%3C%2FTD%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E0x2E%3C%2FTD%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E0x04%20W%3C%2FTD%3E%3CTD%20colspan%3D%224%22%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%AFINT1%E3%83%94%E3%83%B3%E3%81%AB%E3%83%AB%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3ECTRL_REG1%3C%2FTD%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E0x2A%3C%2FTD%3E%3CTD%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3E0x35%20W%3C%2FTD%3E%3CTD%20colspan%3D%224%22%20data-sheets-value%3D%22%7B%22%201%3D%22%22%3EODR%20%3D%206.25Hz%E3%80%81%E3%83%8E%E3%82%A4%E3%82%BA%E4%BD%8E%E6%B8%9B%E3%80%81%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%83%A2%E3%83%BC%E3%83%89%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B8%E3%83%A7%E3%82%A2%E3%83%B3%E3%83%BB%E3%83%91%E3%82%A6%E3%83%AD%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-695341%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%20Accelerometer%20FXOS8700CQ%20%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-695341%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%91%E3%82%A6%E3%83%AD%E3%81%95%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%A8%AD%E5%AE%9A%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B8%8B%E8%A8%98%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%80%81FRDM-KV31F%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E7%89%B9%E3%81%AB%20INT1%20%E3%83%94%E3%83%B3%E3%81%AE%E3%83%94%E3%83%B3%E6%A7%8B%E6%88%90%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pinout.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pinout.jpg%22%20style%3D%22width%3A%20977px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F27095i171128EAA2CE8A5D%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pinout.jpg%22%20alt%3D%22pinout.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%E3%83%87%E3%83%90%E3%82%A6%E3%83%B3%E3%82%B9%20%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%E3%81%AE%E5%80%A4%E3%82%92%E6%B8%9B%E3%82%89%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%20(A_FFMT_COUNT%20%3D%200x01)%E3%80%82%E7%B5%90%E6%9E%9C%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3FPTD0%20%E3%83%94%E3%83%B3%E3%81%A7%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%AF%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%E3%83%87%E3%83%93%E3%83%83%E3%83%89%3C%2FP%3E%3C%2FLINGO-BODY%3E
