Accelerometer FXLS896xAF - bug in library ?
已解决
跳至解决方案
3,657 次查看
adde_ado
I'm testing the FXLS8964AF sensor on our custom board and I'm not getting any interrupts on INT1 when I configure my sensor for shake detection.
In a struct named gFxls896xafShakeConfig I have found the following comment but FXLS896xAF_INT_PIN_SEL_SDCD_OT_INT2_DIS is equal to 0x00. Is this a bug or have I missed something?
/* SDCD_WT_ENenabled for INT2 */
Our BT_MODE pin is connected to GND and my intention is to use  INT1 as our interrupt pin.
This is our register configuration (pretty much the same as it is explained in AN12004 on page 12):
Register      Data
0x15            0x00
0x15            0x02               FSR = 4 g and Standby mode
0x17            0x33               Wake ODR = 400 Hz and Sleep ODR = 400 Hz
0x2F            0x20               Enable X axis only for SDCD OT function
0x30            0xF0
0x31            0x04               Debounce time = 4 × (1/400) = 10 ms
0x33            0xFE
0x34            0xFA
0x35            0x02
0x36            0x05
0x20            0xA0             Enabling DRDY_EN and SDCD_OT_EN
0x21            0x00              Routing DRDY interrupt to INT1 pin
0x15            0x03              FSR = 4 g and ACTIVE = 1
Adde
标签 (1)
1 解答
3,579 次查看
AmitPurohit
Thanks Tomas.
Hi Adde,
FXLS896xAF_INT_PIN_SEL_SDCD_OT_INT2_DIS set to 0x00 configures INT1 pin for routing SDCD OT interrupt.
You can try following sensor configuration for shake detection:
Register Name
Offset
Value (to write)
Description
SENS_CONFIG1
0x15
0x02
FSR = +/-4g and Standby mode
SENS_CONFIG3
0x17
0x33
Wake ODR=400 Hz and Sleep ODR = 400 Hz
SENS_CONFIG4
0x18
0x21
Enable SDCD outside of thresholds event Auto-WAKE/SLEEP transition source enable and INT polarity set to high
SDCD_CONFIG1
0x2F
0x20
Enabling SDCD OT for X-axis
SDCD_CONFIG2
0x30
0xF0
Enable SDCD function, Enable Absolute Reference Mode and set OT Debounce counter to clear immediately when threshold criteria is false
SDCD_OT_DBCNT
0x31
0x04
Debounce time = 4 for transient detection
SDCD_LTHS_LSB
0x33
0xFF
Registers 33h and 34h set the OT LOWER threshold. In this example it is set to
hex2dec (FAFE) × 1.95 mg/LSB = -2.5 g.
SDCD_LTHS_MSB
0x34
0xFA
SDCD_UTHS_LSB
0x35
0x02
Registers 35h and 36h set the OT UPPER threshold. In this case it is set to
hex2dec (0502) × 1.95mg/LSB = +2.5 g
SDCD_UTHS_MSB
0x36
0x05
ASLP_COUNT_LSB
0x1E
0xFF
Registers 1Eh and 1Fh enable the ASLP function and set the sleep mode transition timer.
In this example it is set to hex2dec (07D0) × 2.5 ms (400 Hz Wake ODR) = 5 sec
ASLP_COUNT_MSB
0x1F
0x08
INT_EN
0x20
0x01
Enabling WAKE_OUT_EN
INT_PIN_SEL
0x21
0x00
Routing WAKE_OUT_EN interrupt to INT1 pin
SENS_CONFIG1
0x15
0x03
FSR = +/-4 g and ACTIVE = 1
Please try suggested sensor configuration.
Amit Purohit.
在原帖中查看解决方案
2 回复数
3,580 次查看
AmitPurohit
Thanks Tomas.
Hi Adde,
Register Name
Offset
Value (to write)
Description
SENS_CONFIG1
0x15
0x02
SENS_CONFIG3
0x17
0x33
SENS_CONFIG4
0x18
0x21
SDCD_CONFIG1
0x2F
0x20
SDCD_CONFIG2
0x30
0xF0
SDCD_OT_DBCNT
0x31
0x04
SDCD_LTHS_LSB
0x33
0xFF
SDCD_LTHS_MSB
0x34
0xFA
SDCD_UTHS_LSB
0x35
0x02
SDCD_UTHS_MSB
0x36
0x05
ASLP_COUNT_LSB
0x1E
0xFF
ASLP_COUNT_MSB
0x1F
0x08
INT_EN
0x20
0x01
INT_PIN_SEL
0x21
0x00
SENS_CONFIG1
0x15
0x03
Amit Purohit.
3,645 次查看
TomasVaverka
+ @AmitPurohit - can you please look into it and comment?
Thanks & Regards,
Tomas
%3CLINGO-SUB%20id%3D%22lingo-sub-1527597%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%8A%A0%E9%80%9F%E5%BA%A6%E8%AE%A1%20FXLS896xAF%20-%20%E7%A8%8B%E5%BA%8F%E5%BA%93%E4%B8%AD%E7%9A%84%E9%94%99%E8%AF%AF%EF%BC%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1527597%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E6%88%91%E4%BB%AC%E7%9A%84%E5%AE%9A%E5%88%B6%E6%9D%BF%E4%B8%8A%E6%B5%8B%E8%AF%95%20FXLS8964AF%20%E4%BC%A0%E6%84%9F%E5%99%A8%EF%BC%8C%E5%BD%93%E6%88%91%E5%B0%86%E4%BC%A0%E6%84%9F%E5%99%A8%E9%85%8D%E7%BD%AE%E4%B8%BA%E6%8A%96%E5%8A%A8%E6%A3%80%E6%B5%8B%E6%97%B6%EF%BC%8CINT1%20%E4%B8%8A%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E4%B8%AD%E6%96%AD%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%A8%E5%90%8D%E4%B8%BA%20gFxls896xafShakeConfig%20%E7%9A%84%E7%BB%93%E6%9E%84%E4%BD%93%E4%B8%AD%EF%BC%8C%E6%88%91%E5%8F%91%E7%8E%B0%E4%BA%86%E4%BB%A5%E4%B8%8B%E6%B3%A8%E9%87%8A%EF%BC%8C%E4%BD%86%20FXLS896xAF_INT_PIN_SEL_SDCD_OT_INT2_DIS%20%E7%AD%89%E4%BA%8E%200x00%E3%80%82%E8%BF%99%E6%98%AF%E4%B8%80%E4%B8%AA%E9%94%99%E8%AF%AF%E8%BF%98%E6%98%AF%E6%88%91%E9%81%97%E6%BC%8F%E4%BA%86%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3E%2F*%20SDCD_WT_ENenabled%20for%20INT2%20*%2F%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E4%BB%AC%E7%9A%84%20BT_MODE%20%E5%BC%95%E8%84%9A%E8%BF%9E%E6%8E%A5%E8%87%B3%20GND%EF%BC%8C%E6%88%91%E6%89%93%E7%AE%97%E4%BD%BF%E7%94%A8%20INT1%20%E4%BD%9C%E4%B8%BA%E4%B8%AD%E6%96%AD%E5%BC%95%E8%84%9A%E3%80%82%3C%2FP%3E%3CP%3E%E8%BF%99%E5%B0%B1%E6%98%AF%E6%88%91%E4%BB%AC%E7%9A%84%E5%AF%84%E5%AD%98%E5%99%A8%E9%85%8D%E7%BD%AE%EF%BC%88%E4%B8%8E%20AN12004%20%E7%AC%AC%2012%20%E9%A1%B5%E7%9A%84%E8%AF%B4%E6%98%8E%E5%9F%BA%E6%9C%AC%E7%9B%B8%E5%90%8C%EF%BC%89%EF%BC%9A%3C%2FP%3E%3CP%3E%E6%B3%A8%E5%86%8C%E6%95%B0%E6%8D%AE%3C%2FP%3E%3CP%3E0x15%200x00%3C%2FP%3E%3CP%3E0x15%200x02%20FSR%20%3D%204%20g%20%E5%92%8C%E5%BE%85%E6%9C%BA%E6%A8%A1%E5%BC%8F%3C%2FP%3E%3CP%3E0x17%200x33%20%E5%94%A4%E9%86%92%20ODR%20%3D%20400%20Hz%20%E5%92%8C%E7%9D%A1%E7%9C%A0%20ODR%20%3D%20400%20Hz%3C%2FP%3E%3CP%3E0x2F%200x20%20%E4%BB%85%E4%B8%BA%20SDCD%20OT%20%E5%8A%9F%E8%83%BD%E5%90%AF%E7%94%A8%20X%20%E8%BD%B4%3C%2FP%3E%3CP%3E0x30%200xF0%3C%2FP%3E%3CP%3E0x31%200x04%20%E5%8E%BB%E6%8A%96%E5%8A%A8%E6%97%B6%E9%97%B4%20%3D%204%20%C3%97%20(1%2F400)%20%3D%2010%20%E6%AF%AB%E7%A7%92%3C%2FP%3E%3CP%3E0x33%200xFE%3C%2FP%3E%3CP%3E0x34%200xFA%3C%2FP%3E%3CP%3E0x35%200x02%20%3C%2FP%3E%3CP%3E0x36%200x05%3C%2FP%3E%3CP%3E0x20%200xA0%20%E5%90%AF%E7%94%A8%20DRDY_EN%20%E5%92%8C%20SDCD_OT_EN%3C%2FP%3E%3CP%3E0x21%200x00%20%E8%B7%AF%E7%94%B1%20DRDY%20%E4%B8%AD%E6%96%AD%E8%87%B3%20INT1%20%E5%BC%95%E8%84%9A%3C%2FP%3E%3CP%3E0x15%200x03%20FSR%20%3D%204%20g%EF%BC%8CACTIVE%20%3D%201%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3E%E5%8A%A0%E6%B3%95%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1527597%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%8A%A0%E9%80%9F%E5%BA%A6%E4%BC%A0%E6%84%9F%E5%99%A8%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1529816%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Accelerometer%20FXLS896xAF%20-%20bug%20in%20library%20%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1529816%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E4%BD%A0%EF%BC%8C%E6%89%98%E9%A9%AC%E6%96%AF%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%97%A8%EF%BC%8C%E9%98%BF%E5%BE%B7%E3%80%81%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EFXLS896xAF_INT_PIN_SEL_SDCD_OT_INT2_DIS%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%200x00%20%E6%97%B6%EF%BC%8CINT1%20%E5%BC%95%E8%84%9A%E5%B0%86%E9%85%8D%E7%BD%AE%E4%B8%BA%E8%B7%AF%E7%94%B1%20SDCD%20OT%20%E4%B8%AD%E6%96%AD%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%E4%BB%A5%E4%B8%8B%E4%BC%A0%E6%84%9F%E5%99%A8%E9%85%8D%E7%BD%AE%E6%9D%A5%E8%BF%9B%E8%A1%8C%E6%8A%96%E5%8A%A8%E6%A3%80%E6%B5%8B%EF%BC%9A%3C%2FP%3E%0A%3CTABLE%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22129%22%3E%0A%3CP%3E%E5%AF%84%E5%AD%98%E5%99%A8%E5%90%8D%E7%A7%B0%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2283%22%3E%0A%3CP%3E%E5%81%8F%E7%A7%BB%E9%87%8F%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22108%22%3E%0A%3CP%3E%E5%80%BC%EF%BC%88%E5%86%99%EF%BC%89%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22340%22%3E%0A%3CP%3E%E8%AF%B4%E6%98%8E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22129%22%3E%0A%3CP%3ESENS_CONFIG1%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2283%22%3E%0A%3CP%3E0x15%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22108%22%3E%0A%3CP%3E0x02%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22340%22%3E%0A%3CP%3EFSR%20%3D%20%2B%2F-4g%20%E5%92%8C%E5%BE%85%E6%9C%BA%E6%A8%A1%E5%BC%8F%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22129%22%3E%0A%3CP%3ESENS_CONFIG3%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2283%22%3E%0A%3CP%3E0x17%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22108%22%3E%0A%3CP%3E0x33%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22340%22%3E%0A%3CP%3E%E5%94%A4%E9%86%92%20ODR%3D400%20Hz%EF%BC%8C%E7%9D%A1%E7%9C%A0%20ODR%3D400%20Hz%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22129%22%3E%0A%3CP%3ESENS_CONFIG4%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2283%22%3E%0A%3CP%3E0x18%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22108%22%3E%0A%3CP%3E0x21%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22340%22%3E%0A%3CP%3E%E5%9C%A8%E9%98%88%E5%80%BC%E4%BA%8B%E4%BB%B6%E4%B9%8B%E5%A4%96%E5%90%AF%E7%94%A8%20SDCD%20%E8%87%AA%E5%8A%A8%E5%94%A4%E9%86%92%2F%E7%9D%A1%E7%9C%A0%E8%BD%AC%E6%8D%A2%E6%BA%90%E5%90%AF%E7%94%A8%EF%BC%8CINT%20%E6%9E%81%E6%80%A7%E8%AE%BE%E7%BD%AE%E4%B8%BA%E9%AB%98%E7%94%B5%E5%B9%B3%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22129%22%3E%0A%3CP%3ESDCD_CONFIG1%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2283%22%3E%0A%3CP%3E0x2F%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22108%22%3E%0A%3CP%3E0x20%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22340%22%3E%0A%3CP%3E%E4%B8%BA%20X%20%E8%BD%B4%E5%90%AF%E7%94%A8%20SDCD%20OT%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22129%22%3E%0A%3CP%3ESDCD_CONFIG2%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2283%22%3E%0A%3CP%3E0x30%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22108%22%3E%0A%3CP%3E0xF0%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22340%22%3E%0A%3CP%3E%E5%90%AF%E7%94%A8%20SDCD%20%E5%8A%9F%E8%83%BD%EF%BC%8C%E5%90%AF%E7%94%A8%E7%BB%9D%E5%AF%B9%E5%8F%82%E8%80%83%E6%A8%A1%E5%BC%8F%EF%BC%8C%E5%B9%B6%E5%B0%86%20OT%20Debounce%20%E8%AE%A1%E6%95%B0%E5%99%A8%E8%AE%BE%E7%BD%AE%E4%B8%BA%E5%9C%A8%E9%98%88%E5%80%BC%E6%A0%87%E5%87%86%E4%B8%BA%E5%81%87%E6%97%B6%E7%AB%8B%E5%8D%B3%E6%B8%85%E9%99%A4%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22129%22%3E%0A%3CP%3ESDCD_OT_DBCNT%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2283%22%3E%0A%3CP%3E0x31%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22108%22%3E%0A%3CP%3E0x04%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22340%22%3E%0A%3CP%3E%E7%94%A8%E4%BA%8E%E7%9E%AC%E6%80%81%E6%A3%80%E6%B5%8B%E7%9A%84%E6%B6%88%E6%8A%96%E6%97%B6%E9%97%B4%20%3D%204%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22129%22%3E%0A%3CP%3ESDCD_LTHS_LSB%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2283%22%3E%0A%3CP%3E0x33%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22108%22%3E%0A%3CP%3E0xFF%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20rowspan%3D%222%22%20width%3D%22340%22%3E%0A%3CP%3E%E5%AF%84%E5%AD%98%E5%99%A8%2033h%20%E5%92%8C%2034h%20%E8%AE%BE%E7%BD%AE%20OT%20%E4%B8%8B%E9%99%90%E9%98%88%E5%80%BC%E3%80%82%E5%9C%A8%E6%9C%AC%E4%BE%8B%E4%B8%AD%EF%BC%8C%E5%AE%83%E8%A2%AB%E8%AE%BE%E7%BD%AE%E4%B8%BA%3C%2FP%3E%0A%3CP%3Ehex2dec%20(FAFE)%20%C3%97%201.95%20mg%2FLSB%20%3D%20-2.5%20g%E3%80%82%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22129%22%3E%0A%3CP%3ESDCD_LTHS_MSB%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2283%22%3E%0A%3CP%3E0x34%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22108%22%3E%0A%3CP%3E0xFA%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22129%22%3E%0A%3CP%3ESDCD_UTHS_LSB%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2283%22%3E%0A%3CP%3E0x35%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22108%22%3E%0A%3CP%3E0x02%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20rowspan%3D%222%22%20width%3D%22340%22%3E%0A%3CP%3E%E5%AF%84%E5%AD%98%E5%99%A8%2035h%20%E5%92%8C%2036h%20%E8%AE%BE%E7%BD%AE%20OT%20%E4%B8%8A%E9%99%90%E5%80%BC%E3%80%82%E5%9C%A8%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%E5%AE%83%E8%A2%AB%E8%AE%BE%E7%BD%AE%E4%B8%BA%3C%2FP%3E%0A%3CP%3Ehex2dec%20(0502)%20%C3%97%201.95mg%2FLSB%20%3D%20%2B2.5%20g%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22129%22%3E%0A%3CP%3ESDCD_UTHS_MSB%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2283%22%3E%0A%3CP%3E0x36%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22108%22%3E%0A%3CP%3E0x05%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22129%22%3E%0A%3CP%3EASLP_COUNT_LSB%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2283%22%3E%0A%3CP%3E0x1E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22108%22%3E%0A%3CP%3E0xFF%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20rowspan%3D%222%22%20width%3D%22340%22%3E%0A%3CP%3E%E5%AF%84%E5%AD%98%E5%99%A8%201Eh%20%E5%92%8C%201Fh%20%E5%8F%AF%E5%90%AF%E7%94%A8%20ASLP%20%E5%8A%9F%E8%83%BD%E5%B9%B6%E8%AE%BE%E7%BD%AE%E7%9D%A1%E7%9C%A0%E6%A8%A1%E5%BC%8F%E8%BD%AC%E6%8D%A2%E8%AE%A1%E6%97%B6%E5%99%A8%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%9C%A8%E6%AD%A4%E7%A4%BA%E4%BE%8B%E4%B8%AD%EF%BC%8C%E5%AE%83%E8%AE%BE%E7%BD%AE%E4%B8%BA%20hex2dec%20(07D0)%20%C3%97%202.5%20ms%20(400%20Hz%20Wake%20ODR)%20%3D%205%20%E7%A7%92%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22129%22%3E%0A%3CP%3EASLP_COUNT_MSB%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2283%22%3E%0A%3CP%3E0x1F%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22108%22%3E%0A%3CP%3E0x08%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22129%22%3E%0A%3CP%3EINT_EN%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2283%22%3E%0A%3CP%3E0x20%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22108%22%3E%0A%3CP%3E0x01%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22340%22%3E%0A%3CP%3E%E5%90%AF%E7%94%A8%20WAKE_OUT_EN%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22129%22%3E%0A%3CP%3EINT_PIN_SEL%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2283%22%3E%0A%3CP%3E0x21%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22108%22%3E%0A%3CP%3E0x00%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22340%22%3E%0A%3CP%3E%E5%B0%86%20WAKE_OUT_EN%20%E4%B8%AD%E6%96%AD%E8%B7%AF%E7%94%B1%E8%87%B3%20INT1%20%E5%BC%95%E8%84%9A%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22129%22%3E%0A%3CP%3ESENS_CONFIG1%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2283%22%3E%0A%3CP%3E0x15%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22108%22%3E%0A%3CP%3E0x03%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22340%22%3E%0A%3CP%3EFSR%20%3D%20%2B%2F-4%20g%20%E5%92%8C%20ACTIVE%20%3D%201%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3E%E8%AF%B7%E5%B0%9D%E8%AF%95%E5%BB%BA%E8%AE%AE%E7%9A%84%E4%BC%A0%E6%84%9F%E5%99%A8%E9%85%8D%E7%BD%AE%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E9%98%BF%E7%B1%B3%E7%89%B9-%E6%99%AE%E7%BD%97%E5%B8%8C%E7%89%B9%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1527673%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Accelerometer%20FXLS896xAF%20-%20bug%20in%20library%20%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1527673%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%2B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F24351%22%20target%3D%22_blank%22%3E%40AmitPurohit%3C%2FA%3E-%20%E4%BD%A0%E8%83%BD%E8%B0%83%E6%9F%A5%E4%B8%80%E4%B8%8B%E5%B9%B6%E5%8F%91%E8%A1%A8%E8%AF%84%E8%AE%BA%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E8%B0%A2%E8%B0%A2%26amp%3B%20%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%89%98%E9%A9%AC%E6%96%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E
