841-RDFXWIN8USB - is it compatible with Windows 10?
shellyrosenfeld
michaelestanley
Shelly,
I'll have to do some research to determine the internal sampling interval.
Given the nature of your questions, I think you might want to consider a different platform: specifically our Sensor Fusion for Kinetis MCUs library (nxp.com/sensorfusion) runs on a variety of ARM-based Freedom boards available at nxp.com/freedom.  Full source code is supplied, and you have total control.  The Windows 8 reference design was targeted at OEMs developing Windows-based computers and tablets.  The onlyY defined interface to the module is via the Windows 8 HID standard.
What is your application?
Mike
michaelestanley
Shelly,
We haven't requalified against the Microsoft Windows 10 regression suite.  So technically, no.
Mike
shellyrosenfeld
Thank you for your reply.
Is there a way with RDFXWIN8USB to change the sampling frequency?
The SpWin8View Demo sowtware output a log every 63mSec (15Hz).
As for the accelerometer the MMA8451Q have ODR of 1.56 to 800Hz.
Is there a way to write code and communicate with the with the MCF51Jx: ColdFire?
Thank you,
Shelly
michaelestanley
Shelly,
The board is compatible with Microsoft's "HID Sensor Class.
Here is the spec:
https://msdn.microsoft.com/en-us/library/windows/hardware/dn613934(v=vs.85).aspx
You can communicate with the HID sensor using the Accelerometer
class in the Windows.Devices.Sensors namespace. For example, you can change the
sample rate by setting the ReportInterval property.
https://msdn.microsoft.com/library/windows/apps/windows.devices.sensors
The RDFXWIN8USB isn't designed for general development use, but rather as a reference design for the HID interface.  So we're not supplying libraries as part of our general enablement.
Mike
shellyrosenfeld
Thank you for the information
What is the minimum sampling interval possible?
Is there a way to interrupt the MCU code?
Shelly
%3CLINGO-SUB%20id%3D%22lingo-sub-480108%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E841-RDFXWIN8USB%20-%20is%20it%20compatible%20with%20Windows%2010%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-480108%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E841-RDFXWIN8USB%20-%20is%20it%20compatible%20with%20Windows%2010%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-480108%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ESensorFusion%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-480113%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%20841-RDFXWIN8USB%20-%20is%20it%20compatible%20with%20Windows%2010%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-480113%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EShelly%2C%3C%2FP%3E%3CP%3EI'll%20have%20to%20do%20some%20research%20to%20determine%20the%20internal%20sampling%20interval.%20%3C%2FP%3E%3CP%3EGiven%20the%20nature%20of%20your%20questions%2C%20I%20think%20you%20might%20want%20to%20consider%20a%20different%20platform%3A%20specifically%20our%20Sensor%20Fusion%20for%20Kinetis%20MCUs%20library%20(nxp.com%2Fsensorfusion)%20runs%20on%20a%20variety%20of%20ARM-based%20Freedom%20boards%20available%20at%20nxp.com%2Ffreedom.%26nbsp%3B%20Full%20source%20code%20is%20supplied%2C%20and%20you%20have%20total%20control.%26nbsp%3B%20The%20Windows%208%20reference%20design%20was%20targeted%20at%20OEMs%20developing%20Windows-based%20computers%20and%20tablets.%26nbsp%3B%20The%20onlyY%20defined%20interface%20to%20the%20module%20is%20via%20the%20Windows%208%20HID%20standard.%3C%2FP%3E%3CP%3EWhat%20is%20your%20application%3F%3C%2FP%3E%3CP%3EMike%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-480112%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%20841-RDFXWIN8USB%20-%20is%20it%20compatible%20with%20Windows%2010%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-480112%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22text-align%3A%20right%3B%22%3EHi%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20right%3B%22%3EThank%20you%20for%20the%20information%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20right%3B%22%3EWhat%20is%20the%20minimum%20sampling%20interval%20possible%3F%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20right%3B%22%3EIs%20there%20a%20way%20to%20interrupt%20the%20MCU%20code%3F%20%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20right%3B%22%3EThanks%2C%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20right%3B%22%3EShelly%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-480111%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%26nbsp%3B%20841-RDFXWIN8USB%20-%20is%20it%20compatible%20with%20Windows%2010%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-480111%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20font-size%3A%2012pt%3B%22%3EShelly%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20font-size%3A%2012pt%3B%22%3EThe%20board%20is%20compatible%20with%20Microsoft's%20%22HID%20Sensor%20Class.%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20font-size%3A%2012pt%3B%22%3EHere%20is%20the%20spec%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20font-size%3A%2012pt%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fmsdn.microsoft.com%2Fen-us%2Flibrary%2Fwindows%2Fhardware%2Fdn613934(v%3Dvs.85).aspx%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fmsdn.microsoft.com%2Fen-us%2Flibrary%2Fwindows%2Fhardware%2Fdn613934(v%3Dvs.85).aspx%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20font-size%3A%2012pt%3B%22%3EYou%20can%20communicate%20with%20the%20HID%20sensor%20using%20the%20Accelerometer%3CBR%20%2F%3Eclass%20in%20the%20Windows.Devices.Sensors%20namespace.%20For%20example%2C%20you%20can%20change%20the%3CBR%20%2F%3Esample%20rate%20by%20setting%20the%20ReportInterval%20property.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20font-size%3A%2012pt%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fmsdn.microsoft.com%2Flibrary%2Fwindows%2Fapps%2Fwindows.devices.sensors%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fmsdn.microsoft.com%2Flibrary%2Fwindows%2Fapps%2Fwindows.devices.sensors%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20font-size%3A%2012pt%3B%22%3EThe%20RDFXWIN8USB%20isn't%20designed%20for%20general%20development%20use%2C%20but%20rather%20as%20a%20reference%20design%20for%20the%20HID%20interface.%26nbsp%3B%20So%20we're%20not%20supplying%20libraries%20as%20part%20of%20our%20general%20enablement.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20font-size%3A%2012pt%3B%22%3EMike%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-480110%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%26nbsp%3B%20841-RDFXWIN8USB%20-%20is%20it%20compatible%20with%20Windows%2010%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-480110%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22direction%3A%20ltr%3B%22%3EHi%2C%20%3C%2FP%3E%3CP%20style%3D%22direction%3A%20ltr%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22direction%3A%20ltr%3B%22%3EThank%20you%20for%20your%20reply.%20%3C%2FP%3E%3CP%20style%3D%22direction%3A%20ltr%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22direction%3A%20ltr%3B%22%3EIs%20there%20a%20way%20with%20%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20font-size%3A%2014px%3B%22%3ERDFXWIN8USB%3C%2FSPAN%3E%20to%20change%20the%20sampling%20frequency%3F%3C%2FP%3E%3CP%20style%3D%22direction%3A%20ltr%3B%22%3EThe%20SpWin8View%20Demo%20sowtware%20output%20a%20log%20every%2063mSec%20(15Hz).%20%3C%2FP%3E%3CP%20style%3D%22direction%3A%20ltr%3B%22%3EAs%20for%20the%20accelerometer%20the%20MMA8451Q%20have%20ODR%20of%201.56%20to%20800Hz.%3C%2FP%3E%3CP%20style%3D%22direction%3A%20ltr%3B%22%3EIs%20there%20a%20way%20to%20write%20code%20and%20communicate%20with%20the%20with%20the%20MCF51Jx%3A%20ColdFire%3F%3C%2FP%3E%3CP%20style%3D%22direction%3A%20ltr%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22direction%3A%20ltr%3B%22%3EThank%20you%2C%3C%2FP%3E%3CP%20style%3D%22direction%3A%20ltr%3B%22%3EShelly%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-480109%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%20841-RDFXWIN8USB%20-%20is%20it%20compatible%20with%20Windows%2010%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-480109%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EShelly%2C%3C%2FP%3E%3CP%3EWe%20haven't%20requalified%20against%20the%20Microsoft%20Windows%2010%20regression%20suite.%26nbsp%3B%20So%20technically%2C%20no.%3C%2FP%3E%3CP%3ERegards%2C%3C%2FP%3E%3CP%3EMike%3C%2FP%3E%3C%2FLINGO-BODY%3E
