pkcs11-tool generates 2 private keys for keypairgen
5,601 次查看
user4
I'm expecting to have a public and a private key pair when I execute pkcs11-tool command with --keypairgen option, but the outputs says generated 2 private keys.
Is that an expected behavior of se050? If not, am I missing something important?
<Environment>
platform: Debian (bullseye)
module variant: SE050C1
<Outputs>
# pkcs11-tool --module $PKCS11_MODULE --keypairgen --key-type rsa:2048 --label "sss:20202020"
Using slot 0 with a present token (0x1)
smCom :WARN :Invalid conn_ctx
App   :INFO :Using PortName='/dev/i2c-1:0x48' (ENV: EX_SSS_BOOT_SSS_PORT=/dev/i2c-1:0x48)
sss   :INFO :atr (Len=35)
      00 A0 00 00    03 96 04 03    E8 00 FE 02    0B 03 E8 08
      01 00 00 00    00 64 00 00    0A 4A 43 4F    50 34 20 41
      54 50 4F
sss   :WARN :Communication channel is Plain.
sss   :WARN :!!!Not recommended for production use.!!!
Key pair generated:
Private Key Object; RSA
  label:      sss:20202020
  Usage:      decrypt, sign
  Access:     sensitive, always sensitive
  Allowed mechanisms: RSA-PKCS,SHA1-RSA-PKCS,SHA224-RSA-PKCS,SHA256-RSA-PKCS,SHA384-RSA-PKCS,SHA512-RSA-PKCS,RSA-PKCS-PSS,SHA1-RSA-PKCS-PSS,SHA224-RSA-PKCS-PSS,SHA256-RSA-PKCS-PSS,SHA384-RSA-PKCS-PSS,SHA512-RSA-PKCS-PSS,RSA-PP
  label:      sss:20202020
5,503 次查看
Kan_Li
Hi @user4 ,
Thanks for the information! I have tied the same with MW ver 4.5.1 , it just works as expected. Maybe you have to update the MW to the latest. Please kindly refer to the following for details.
Kan
4 回复数
5,580 次查看
Kan_Li
Hi @user4 ,
May I have the MW version?
Kan
5,567 次查看
user4
Hi Kan,
Thank you for responding.
Unfortunately, I don't know the specific version of MW because this environment was built by another company, but guessing it might be 4.2.0:
# dpkg -L plug-and-trust
/etc
/etc/plug-and-trust
/etc/plug-and-trust/openssl11_sss_se050.cnf
/usr
/usr/lib
/usr/lib/arm-linux-gnueabihf
/usr/lib/arm-linux-gnueabihf/engines-1.1
/usr/lib/arm-linux-gnueabihf/engines-1.1/e4sss.so
/usr/lib/arm-linux-gnueabihf/libsssapisw.so.4.2.0
/usr/lib/arm-linux-gnueabihf/plug-and-trust
/usr/lib/arm-linux-gnueabihf/plug-and-trust/libsss_pkcs11.so
/usr/share
/usr/share/doc
/usr/share/doc/plug-and-trust
/usr/share/doc/plug-and-trust/changelog.Debian.gz
/usr/share/doc/plug-and-trust/copyright
5,504 次查看
Kan_Li
Hi @user4 ,
Kan
5,493 次查看
user4
Hi Kan,
Thank you for the inputs. I've also verified that using the libraries in that version does solve the problem, so will consider to ask the package provider to update the MW.
%3CLINGO-SUB%20id%3D%22lingo-sub-1855553%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Epkcs11-tool%20%E4%B8%BA%20keypairgen%20%E7%94%9F%E6%88%90%202%20%E4%B8%AA%E7%A7%81%E9%92%A5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1855553%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%BD%93%E6%88%91%E4%BD%BF%E7%94%A8%20--keypairgen%20%E9%80%89%E9%A1%B9%E6%89%A7%E8%A1%8C%20pkcs11-tool%20%E5%91%BD%E4%BB%A4%E6%97%B6%EF%BC%8C%E6%88%91%E5%B8%8C%E6%9C%9B%E5%BE%97%E5%88%B0%E4%B8%80%E4%B8%AA%E5%85%AC%E9%92%A5%E5%92%8C%E4%B8%80%E4%B8%AA%E7%A7%81%E9%92%A5%E5%AF%B9%EF%BC%8C%E4%BD%86%E8%BE%93%E5%87%BA%E6%98%BE%E7%A4%BA%E7%94%9F%E6%88%90%E4%BA%86%202%20%E4%B8%AA%E7%A7%81%E9%92%A5%E3%80%82%3C%2FP%3E%3CP%3E%E8%BF%99%E6%98%AF%20se050%20%E7%9A%84%E9%A2%84%E6%9C%9F%E8%A1%8C%E4%B8%BA%E5%90%97%EF%BC%9F%E5%A6%82%E6%9E%9C%E6%B2%A1%E6%9C%89%EF%BC%8C%E6%88%91%E6%98%AF%E5%90%A6%E9%81%97%E6%BC%8F%E4%BA%86%E6%9F%90%E4%BA%9B%E9%87%8D%E8%A6%81%E7%9A%84%E4%B8%9C%E8%A5%BF%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CENVIRONMENT%3E%3C%2FENVIRONMENT%3E%3C%2FP%3E%3CP%3E%E5%B9%B3%E5%8F%B0%EF%BC%9ADebian%EF%BC%88%E9%9D%B6%E5%BF%83%EF%BC%89%3C%2FP%3E%3CP%3Emodule%20variant%3A%20SE050C1%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3COUTPUTS%3E%3C%2FOUTPUTS%3E%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%23%20pkcs11-tool%20--module%20%24PKCS11_MODULE%20--keypairgen%20--key-type%20rsa%3A2048%20--label%20%22sss%3A20202020%22%0AUsing%20slot%200%20with%20a%20present%20token%20(0x1)%0AsmCom%20%3AWARN%20%3AInvalid%20conn_ctx%0AApp%20%20%20%3AINFO%20%3AUsing%20PortName%3D'%2Fdev%2Fi2c-1%3A0x48'%20(ENV%3A%20EX_SSS_BOOT_SSS_PORT%3D%2Fdev%2Fi2c-1%3A0x48)%0Asss%20%20%20%3AINFO%20%3Aatr%20(Len%3D35)%0A%20%20%20%20%20%2000%20A0%2000%2000%20%20%20%2003%2096%2004%2003%20%20%20%20E8%2000%20FE%2002%20%20%20%200B%2003%20E8%2008%20%0A%20%20%20%20%20%2001%2000%2000%2000%20%20%20%2000%2064%2000%2000%20%20%20%200A%204A%2043%204F%20%20%20%2050%2034%2020%2041%20%0A%20%20%20%20%20%2054%2050%204F%20%0Asss%20%20%20%3AWARN%20%3ACommunication%20channel%20is%20Plain.%0Asss%20%20%20%3AWARN%20%3A!!!Not%20recommended%20for%20production%20use.!!!%0AKey%20pair%20generated%3A%0APrivate%20Key%20Object%3B%20RSA%20%0A%20%20label%3A%20%20%20%20%20%20sss%3A20202020%0A%20%20ID%3A%20%20%20%20%20%20%20%20%2020202020%0A%20%20Usage%3A%20%20%20%20%20%20decrypt%2C%20sign%0A%20%20Access%3A%20%20%20%20%20sensitive%2C%20always%20sensitive%0A%20%20Allowed%20mechanisms%3A%20RSA-PKCS%2CSHA1-RSA-PKCS%2CSHA224-RSA-PKCS%2CSHA256-RSA-PKCS%2CSHA384-RSA-PKCS%2CSHA512-RSA-PKCS%2CRSA-PKCS-PSS%2CSHA1-RSA-PKCS-PSS%2CSHA224-RSA-PKCS-PSS%2CSHA256-RSA-PKCS-PSS%2CSHA384-RSA-PKCS-PSS%2CSHA512-RSA-PKCS-PSS%2CRSA-PP%0APrivate%20Key%20Object%3B%20RSA%20%0A%20%20label%3A%20%20%20%20%20%20sss%3A20202020%0A%20%20ID%3A%20%20%20%20%20%20%20%20%2020202020%0A%20%20Usage%3A%20%20%20%20%20%20decrypt%2C%20sign%0A%20%20Access%3A%20%20%20%20%20sensitive%2C%20always%20sensitive%0A%20%20Allowed%20mechanisms%3A%20RSA-PKCS%2CSHA1-RSA-PKCS%2CSHA224-RSA-PKCS%2CSHA256-RSA-PKCS%2CSHA384-RSA-PKCS%2CSHA512-RSA-PKCS%2CRSA-PKCS-PSS%2CSHA1-RSA-PKCS-PSS%2CSHA224-RSA-PKCS-PSS%2CSHA256-RSA-PKCS-PSS%2CSHA384-RSA-PKCS-PSS%2CSHA512-RSA-PKCS-PSS%2CRSA-PP%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1855553%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ESE050%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1860031%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9Apkcs11-tool%20%E4%B8%BA%20keypairgen%20%E7%94%9F%E6%88%90%202%20%E4%B8%AA%E7%A7%81%E9%92%A5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1860031%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Kan%2C%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E8%BE%93%E5%85%A5%E3%80%82%E6%88%91%E8%BF%98%E9%AA%8C%E8%AF%81%E4%BA%86%E4%BD%BF%E7%94%A8%E8%AF%A5%E7%89%88%E6%9C%AC%E4%B8%AD%E7%9A%84%E5%BA%93%E7%A1%AE%E5%AE%9E%E5%8F%AF%E4%BB%A5%E8%A7%A3%E5%86%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E5%9B%A0%E6%AD%A4%E4%BC%9A%E8%80%83%E8%99%91%E8%A6%81%E6%B1%82%E8%BD%AF%E4%BB%B6%E5%8C%85%E6%8F%90%E4%BE%9B%E5%95%86%E6%9B%B4%E6%96%B0%20MW%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1859378%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9Apkcs11-tool%20%E4%B8%BA%20keypairgen%20%E7%94%9F%E6%88%90%202%20%E4%B8%AA%E7%A7%81%E9%92%A5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1859378%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F232787%22%20target%3D%22_blank%22%3E%40user4%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%B0%A2%E8%B0%A2%E6%82%A8%E7%9A%84%E4%BF%A1%E6%81%AF%EF%BC%81%E6%88%91%E5%B7%B2%E7%BB%8F%E5%B0%86%E5%85%B6%E4%B8%8E%20MW%20ver%204.5.1%20%E7%BB%91%E5%AE%9A%EF%BC%8C%E5%AE%83%E5%8F%AF%E4%BB%A5%E6%8C%89%E9%A2%84%E6%9C%9F%E5%B7%A5%E4%BD%9C%E3%80%82%E4%B9%9F%E8%AE%B8%E6%82%A8%E5%BF%85%E9%A1%BB%E5%B0%86%20MW%20%E6%9B%B4%E6%96%B0%E5%88%B0%E6%9C%80%E6%96%B0%E7%89%88%E6%9C%AC%E3%80%82%E8%AF%B7%E5%8F%82%E9%98%85%E4%BB%A5%E4%B8%8B%E5%86%85%E5%AE%B9%E4%BB%A5%E4%BA%86%E8%A7%A3%E8%AF%A6%E6%83%85%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Kan_Li_0-1714972873727.png%22%20style%3D%22width%3A%20539px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1714972873727.png%22%20style%3D%22width%3A%20539px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F277157i5E72F8A6E9A37C13%2Fimage-dimensions%2F539x248%3Fv%3Dv2%22%20width%3D%22539%22%20height%3D%22248%22%20role%3D%22button%22%20title%3D%22Kan_Li_0-1714972873727.png%22%20alt%3D%22Kan_Li_0-1714972873727.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%A5%9D%E4%BD%A0%E6%9C%89%E7%BE%8E%E5%A5%BD%E7%9A%84%E4%B8%80%E5%A4%A9%EF%BC%8C%3CBR%20%2F%3E%E5%9D%8E%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E--------------------------------------------------------------------------------%3CBR%20%2F%3E%E7%AC%94%E8%AE%B0%EF%BC%9A%3CBR%20%2F%3E%20-%20%E5%A6%82%E6%9E%9C%E8%BF%99%E7%AF%87%E6%96%87%E7%AB%A0%E5%9B%9E%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%E2%80%9C%E6%A0%87%E8%AE%B0%E6%AD%A3%E7%A1%AE%E2%80%9D%E6%8C%89%E9%92%AE%E3%80%82%E8%B0%A2%E8%B0%A2%E4%BD%A0%EF%BC%81%3CBR%20%2F%3E%20-%20%E6%88%91%E4%BB%AC%E4%BC%9A%E5%85%B3%E6%B3%A8%E4%B8%8A%E6%AC%A1%E5%8F%91%E5%B8%96%E5%90%8E%E4%B8%83%E5%91%A8%E7%9A%84%E5%B8%96%E5%AD%90%EF%BC%8C%E4%B9%8B%E5%90%8E%E7%9A%84%E5%9B%9E%E5%A4%8D%E5%B0%86%E8%A2%AB%E5%BF%BD%E7%95%A5%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E7%A8%8D%E5%90%8E%E6%9C%89%E7%9B%B8%E5%85%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E6%89%93%E5%BC%80%E4%B8%80%E4%B8%AA%E6%96%B0%E7%BA%BF%E7%A8%8B%E5%B9%B6%E5%8F%82%E8%80%83%E5%B7%B2%E5%85%B3%E9%97%AD%E7%9A%84%E7%BA%BF%E7%A8%8B%E3%80%82%3CBR%20%2F%3E--------------------------------------------------------------------------------%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1857078%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9Apkcs11-tool%20%E4%B8%BA%20keypairgen%20%E7%94%9F%E6%88%90%202%20%E4%B8%AA%E7%A7%81%E9%92%A5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1857078%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Kan%2C%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%3CP%3E%E4%B8%8D%E5%B9%B8%E7%9A%84%E6%98%AF%EF%BC%8C%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93MW%E7%9A%84%E5%85%B7%E4%BD%93%E7%89%88%E6%9C%AC%EF%BC%8C%E5%9B%A0%E4%B8%BA%E8%BF%99%E4%B8%AA%E7%8E%AF%E5%A2%83%E6%98%AF%E7%94%B1%E5%8F%A6%E4%B8%80%E5%AE%B6%E5%85%AC%E5%8F%B8%E6%9E%84%E5%BB%BA%E7%9A%84%EF%BC%8C%E4%BD%86%E7%8C%9C%E6%B5%8B%E5%AE%83%E5%8F%AF%E8%83%BD%E6%98%AF4.2.0%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%23%20dpkg%20-L%20plug-and-trust%0A%2F.%0A%2Fetc%0A%2Fetc%2Fplug-and-trust%0A%2Fetc%2Fplug-and-trust%2Fopenssl11_sss_se050.cnf%0A%2Fusr%0A%2Fusr%2Flib%0A%2Fusr%2Flib%2Farm-linux-gnueabihf%0A%2Fusr%2Flib%2Farm-linux-gnueabihf%2Fengines-1.1%0A%2Fusr%2Flib%2Farm-linux-gnueabihf%2Fengines-1.1%2Fe4sss.so%0A%2Fusr%2Flib%2Farm-linux-gnueabihf%2Flibsssapisw.so.4.2.0%0A%2Fusr%2Flib%2Farm-linux-gnueabihf%2Fplug-and-trust%0A%2Fusr%2Flib%2Farm-linux-gnueabihf%2Fplug-and-trust%2Flibsss_pkcs11.so%0A%2Fusr%2Fshare%0A%2Fusr%2Fshare%2Fdoc%0A%2Fusr%2Fshare%2Fdoc%2Fplug-and-trust%0A%2Fusr%2Fshare%2Fdoc%2Fplug-and-trust%2Fchangelog.Debian.gz%0A%2Fusr%2Fshare%2Fdoc%2Fplug-and-trust%2Fcopyright%0A%2Fusr%2Flib%2Farm-linux-gnueabihf%2Flibsssapisw.so.4%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1856536%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9Apkcs11-tool%20%E4%B8%BA%20keypairgen%20%E7%94%9F%E6%88%90%202%20%E4%B8%AA%E7%A7%81%E9%92%A5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1856536%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F232787%22%20target%3D%22_blank%22%3E%40user4%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%88%91%E5%8F%AF%E4%BB%A5%E6%8B%A5%E6%9C%89%20MW%20%E7%89%88%E6%9C%AC%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%A5%9D%E4%BD%A0%E6%9C%89%E7%BE%8E%E5%A5%BD%E7%9A%84%E4%B8%80%E5%A4%A9%EF%BC%8C%3CBR%20%2F%3E%E5%9D%8E%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E--------------------------------------------------------------------------------%3CBR%20%2F%3E%E7%AC%94%E8%AE%B0%EF%BC%9A%3CBR%20%2F%3E%20-%20%E5%A6%82%E6%9E%9C%E8%BF%99%E7%AF%87%E6%96%87%E7%AB%A0%E5%9B%9E%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%E2%80%9C%E6%A0%87%E8%AE%B0%E6%AD%A3%E7%A1%AE%E2%80%9D%E6%8C%89%E9%92%AE%E3%80%82%E8%B0%A2%E8%B0%A2%E4%BD%A0%EF%BC%81%3CBR%20%2F%3E%20-%20%E6%88%91%E4%BB%AC%E4%BC%9A%E5%85%B3%E6%B3%A8%E4%B8%8A%E6%AC%A1%E5%8F%91%E5%B8%96%E5%90%8E%E4%B8%83%E5%91%A8%E7%9A%84%E5%B8%96%E5%AD%90%EF%BC%8C%E4%B9%8B%E5%90%8E%E7%9A%84%E5%9B%9E%E5%A4%8D%E5%B0%86%E8%A2%AB%E5%BF%BD%E7%95%A5%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E7%A8%8D%E5%90%8E%E6%9C%89%E7%9B%B8%E5%85%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E6%89%93%E5%BC%80%E4%B8%80%E4%B8%AA%E6%96%B0%E7%BA%BF%E7%A8%8B%E5%B9%B6%E5%8F%82%E8%80%83%E5%B7%B2%E5%85%B3%E9%97%AD%E7%9A%84%E7%BA%BF%E7%A8%8B%E3%80%82%3CBR%20%2F%3E--------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E
