Where is jcsim.bat?
Where is jcsim.bat?
markpotts123
I recently obtained access to JCOP Tools and have installed and activated the plugin under Eclipse.
Following the NXP tutorial I started experimenting with JCShell which I was able to successfully load via jcshell.bat from the NXP_JCShell folder.
In order to use the JCOP simulator the tutorial says to first run jcsim.bat however I cannot find this file or the JCOP_Simulation folder shown in the example. Do I have to separately request access to this package?
Any advice appreciated.
Mark
