Using correct ENV Variable with nx_personalization demo for A30
6,303件の閲覧回数
Jansch
I'm currently trying things out with the new A30 and I can't get the nx_personalization demo to work for the SIGMA-I authentication. I changed the ENV variable accordingly but still get an error. My output is as follows:
nx_mw :INFO :Session Open Succeed nx_mw :INFO :Nx provision start
nx_mw :INFO :******************************* NOTE ********************************************
nx_mw :INFO :Default top level certificate directory is: /tmp/configuration/a30_hostcert_depth2_x509_rev3_nistp/
nx_mw :INFO :To override this directory path, you need to set env variable as follows:
nx_mw :INFO :NX_AUTH_CERT_DIR=..\nx-mw-top\binaries\configuration\cert_depth3_PKCS7_rev1
nx_mw :INFO :*********************************************************************************
nx_mw :INFO :Using certificate/key from:'..\nx-mw-top\binaries\configuration\cert_depth3_PKCS7_rev1' (ENV=NX_AUTH_CERT_DIR)
nx_mw :WARN :Potential directory traversal
nx_mw :WARN :host_root_certificates is not found. Use leaf certificate which is assumed to be self signed
nx_mw :WARN :nxEnsure:'status == kStatus_SSS_Success' failed. At Line:741 Function:nx_load_host_root_CA_pubkey
nx_mw :WARN :nxEnsure:'status == kStatus_SSS_Success' failed. At Line:976 Function:ex_sss_entry
nx_mw :ERROR:nx_Personalization Example Failed !!!... nx_mw :INFO :ex_sss Finished
nx_mw :ERROR:ex_sss_entry Failed nx_mw :ERROR:!ERROR! ret != 0.
10 返答(返信)
3,821件の閲覧回数
jesssaid
您好,我需要开发A1006UK ,有经验的帮助我一下 ,谢谢!
タグ(1)
6,286件の閲覧回数
Kan_Li
Hi @Jansch ,
Yes, please use the certs and keys in nx-mw-top\binaries\configuration\a30_hostcert_depth2_x509_rev3_nistp to personalize the certificate for A30 . you may simply run the bat file : nxclitool_prov_host_root_cert for that purpose, please kindly refer to NXMW.pdf , section 2.1 set up A30/NTAG_X_DNA sample for more details.
Hope that helps,
Kan
6,281件の閲覧回数
Jansch
Hello @Kan_Li,
I'm running this setup on raspbian, therefore I'm unable to run a .bat file.
I have followed the nxmw.pdf section 2.5, which refers me to the nx_Personalization example.
I had the ENV variable set up wrongly, now I have the correct one. I can read the files, which the output is also indicating but I am still failing at some point:
I am opening the session correctly, indicating a correct Symmetric Key being used. Maybe I need to select differen t options on linux when executing the command. I am not sure.
nx_mw :INFO :******************************* NOTE ******************************************** nx_mw :INFO :Default top level certificate directory is: /tmp/configuration/a30_hostcert_depth2_x509_rev3_nistp/ nx_mw :INFO :To override this directory path, you need to set env variable as follows: nx_mw :INFO :NX_AUTH_CERT_DIR=..\nx-mw-top\binaries\configuration\cert_depth3_PKCS7_rev1 nx_mw :INFO :********************************************************************************* nx_mw :INFO :Using certificate/key from:'/home/pi/a30mw/nxmw-main/binaries/configuration/cert_depth3_PKCS7_rev1' (ENV=NX_AUTH_CERT_DIR) nx_mw :INFO :Read file from /home/pi/a30mw/nxmw-main/binaries/configuration/cert_depth3_PKCS7_rev1/cert_and_key/nist_p/host_root_certificate.der nx_mw :INFO :Read file from /home/pi/a30mw/nxmw-main/binaries/configuration/cert_depth3_PKCS7_rev1/cert_and_key/nist_p/device_leaf_certificate.der nx_mw :INFO :Read file from /home/pi/a30mw/nxmw-main/binaries/configuration/cert_depth3_PKCS7_rev1/cert_and_key/nist_p/device_leaf_keypair.der nx_mw :WARN :nxEnsure:'(ret == SM_OK) || (ret == SM_OK_ALT)' failed. At Line:3713 Function:sss_nx_TXn_AES_EV2 nx_mw :ERROR:nx_ManageCertRepo_CreateCertRepo Failed nx_mw :WARN :nxEnsure:'status == kStatus_SSS_Success' failed. At Line:812 Function:nx_load_se_leaf_keypair_and_cert nx_mw :WARN :nxEnsure:'status == kStatus_SSS_Success' failed. At Line:980 Function:ex_sss_entry nx_mw :ERROR:nx_Personalization Example Failed !!!... nx_mw :INFO :ex_sss Finished nx_mw :ERROR:ex_sss_entry Failed nx_mw :ERROR:!ERROR! ret != 0.
6,270件の閲覧回数
Kan_Li
Hi @Jansch ,
I understand you are following the steps as listed in section 2.5.3 in nxmw.pdf , but halted in the following step, right?
and then you followed the steps in section 4.1.1 to Nx Personalization example with a self defined ENV, right? What is the setting for NX_AUTH_CERT_DIR in this case? Would you please clarify?
Please kindly let me know if I made any misunderstanding here.
Kan
6,257件の閲覧回数
Jansch
Hi @Kan_Li
Yes, exactly. I can run every other demo and have tried a cuople things that all work, I just struggle to get the SIGMA-I authentication to work.
NX_AUTH_CERT_DIR has been changed by me to refer to the folder indicated by section 4.1.1:
"Hard coded certificates defined in
nx-mw-top/demos/nx/nx_Personalization/nx_Personalization.h"
The actual folder for me is found at:
~/a30mw/nxmw_main/demos/nx/nx_Personalization/nx_Personalization.h
This is the content of my NX_AUTH_CERT_DIR aswell. Looking into that folder I have various certificates in plaintext, so everything seems to be in order.
Greetings
Jan
6,251件の閲覧回数
Kan_Li
Hi @Jansch ,
Thanks for the clarification! Is it possible to give us a more detailed log by enabling the following cmake option?
-DNXMW_Log=Verbose
Kan
6,246件の閲覧回数
Jansch
Hey @Kan_Li
I wrote the wrong directory in the last message, this is the correct one:
The output for verbose logs is long, as following:
nx_mw :INFO :******************************* NOTE ******************************************** nx_mw :INFO :Default top level certificate directory is: /tmp/configuration/a30_hostcert_depth2_x509_rev3_nistp/ nx_mw :INFO :To override this directory path, you need to set env variable as follows: nx_mw :INFO :NX_AUTH_CERT_DIR=..\nx-mw-top\binaries\configuration\cert_depth3_PKCS7_rev1 nx_mw :INFO :********************************************************************************* nx_mw :INFO :Using certificate/key from:'/home/pi/a30mw/nxmw-main/binaries/configuration/cert_depth3_PKCS7_rev1' (ENV=NX_AUTH_CERT_DIR) nx_mw :DEBUG:Number of characters read = 523 nx_mw :INFO :Read file from /home/pi/a30mw/nxmw-main/binaries/configuration/cert_depth3_PKCS7_rev1/cert_and_key/nist_p/host_root_certificate.der nx_mw :DEBUG:openssl parse certificates failed. It maybe PKCS#7 certificate APDU :DEBUG:GetKeySettings [CARootKeyList] APDU :DEBUG: [Option] = 0x2 nx_mw :DEBUG: Input:Native Command code (Len=1) 45 nx_mw :DEBUG: Input:Native Command Header (Len=1) 02 nx_mw :DEBUG:FN: nx_AES_EV2_MAC_CommandAPDU nx_mw :DEBUG:Command counter = 1 nx_mw :DEBUG:APDU Tx> (Len=15) 90 45 00 00 09 02 69 8F 94 02 2C AD 68 40 00 nx_mw :DEBUG:Enter phNxpEseProto7816_Transceive nx_mw :DEBUG:Transceive data ptr 0x0x7ffff91e9870 len:15 nx_mw :DEBUG:I-Frame Data Len: 15 Seq. no:1 nx_mw :DEBUG:TransceiveProcess nextTransceiveState 1 nx_mw :DEBUG:phNxpEse_WriteFrame Enter .. nx_mw :DEBUG:TX (axI2CWrite) > (Len=21) 21 40 00 0F 90 45 00 00 09 02 69 8F 94 02 2C AD 68 40 00 66 0A nx_mw :DEBUG:Done with rv = 0c nx_mw :DEBUG:RAW Tx> (Len=21) 21 40 00 0F 90 45 00 00 09 02 69 8F 94 02 2C AD 68 40 00 66 0A nx_mw :DEBUG:phNxpEse_read Enter .. nx_mw :DEBUG:phPalEse_i2c_read Read Requested 2 bytes nx_mw :DEBUG:Done with rv = 0d nx_mw :DEBUG:RX (axI2CRead): (Len=2) 00 00 nx_mw :DEBUG:_i2c_read() error : 13 nx_mw :DEBUG:_i2c_read() failed. Going to retry, counter:1 ! nx_mw :DEBUG:Done with rv = 0c nx_mw :DEBUG:RX (axI2CRead): (Len=2) 12 40 nx_mw :DEBUG:phNxpEse_readPacket Read HDR nx_mw :DEBUG:phNxpEse_readPacket SOF FOUND nx_mw :DEBUG:phPalEse_i2c_read Read Requested 2 bytes nx_mw :DEBUG:Done with rv = 0c nx_mw :DEBUG:RX (axI2CRead): (Len=2) 00 12 nx_mw :DEBUG:poll_sof_chained_delay value is 0 nx_mw :DEBUG:phPalEse_i2c_read Read Requested 20 bytes nx_mw :DEBUG:Done with rv = 0c nx_mw :DEBUG:RX (axI2CRead): (Len=20) 01 00 0C FF 3F 30 3F 00 7A 0B 9B FC 58 3F DC CD 91 00 90 5D nx_mw :DEBUG:RAW Rx< (Len=24) 12 40 00 12 01 00 0C FF 3F 30 3F 00 7A 0B 9B FC 58 3F DC CD 91 00 90 5D nx_mw :DEBUG:phNxpEseProto7816_ProcessResponse p_data ----> 0x55562b33cab0 len ----> 0x18 nx_mw :DEBUG:Received CRC:0x905d Calculated CRC:0x905d nx_mw :DEBUG:Retry Counter = 0 nx_mw :DEBUG:phNxpEseProto7816_DecodeFrame I-Frame Received nx_mw :DEBUG:phNxpEseProto7816_DecodeFrame I-Frame lastRcvdIframeInfo.seqNo:0x1 nx_mw :DEBUG:Data[0]=0x1 len=18 Data[17]=0x91 Data[18]=0x0 nx_mw :DEBUG: phNxpEse_Transceive Exit status 0x0 nx_mw :DEBUG:APDU Rx< (Len=18) 01 00 0C FF 3F 30 3F 00 7A 0B 9B FC 58 3F DC CD 91 00 nx_mw :DEBUG:FN: nx_DeCrypt nx_mw :DEBUG: Input:rspBuf (Len=18) 01 00 0C FF 3F 30 3F 00 7A 0B 9B FC 58 3F DC CD 91 00 nx_mw :DEBUG:Mac verified : (Len=16) 09 7A 96 0B 06 9B E5 FC 5B 58 13 3F CD DC 18 CD nx_mw :DEBUG:Decrypted the response (Len=10) 01 00 0C FF 3F 30 3F 00 91 00 APDU :DEBUG:ManageCARootKey [] APDU :DEBUG: [KeyNo] = 0x0 APDU :DEBUG: [curveID] = 0xC APDU :DEBUG: [accessRight(LSB)] = 0x3FFF APDU :DEBUG: [writeAccessCond] = 0x30 APDU :DEBUG: [readAccessCond] = 0x3F APDU :DEBUG: [Reserved] = 0x0 APDU :DEBUG: [Public key] (Len=65) 04 C2 3A B7 F3 EB 7E CD F9 4E 1C 43 B2 8B 0C 2F 49 C9 61 35 A1 4A E0 58 BC A9 FE F9 4D 18 D4 46 28 C1 2F 8D 00 5B C4 8C C4 02 74 86 90 42 75 AE 55 96 0B 23 C7 6E 96 EF 96 80 27 04 2A 16 7D E5 AD APDU :DEBUG: [CA Subject Name Len] = 0x64 APDU :DEBUG: [CA Issuer Name] (Len=100) 30 62 31 0B 30 09 06 03 55 04 06 13 02 4E 4C 31 12 30 10 06 03 55 04 08 0C 09 45 69 6E 64 68 6F 76 65 6E 31 12 30 10 06 03 55 04 07 0C 09 45 69 6E 64 68 6F 76 65 6E 31 0C 30 0A 06 03 55 04 0A 0C 03 4E 58 50 31 1D 30 1B 06 03 55 04 03 0C 14 4E 58 50 20 41 75 74 68 20 52 6F 6F 74 43 41 76 45 32 30 31 nx_mw :DEBUG: Input:Native Command code (Len=1) 48 nx_mw :DEBUG: Input:Native Command Header (Len=7) 00 0C FF 3F 30 3F 00 nx_mw :DEBUG: Input:Native Command Data (Len=166) 04 C2 3A B7 F3 EB 7E CD F9 4E 1C 43 B2 8B 0C 2F 49 C9 61 35 A1 4A E0 58 BC A9 FE F9 4D 18 D4 46 28 C1 2F 8D 00 5B C4 8C C4 02 74 86 90 42 75 AE 55 96 0B 23 C7 6E 96 EF 96 80 27 04 2A 16 7D E5 AD 64 30 62 31 0B 30 09 06 03 55 04 06 13 02 4E 4C 31 12 30 10 06 03 55 04 08 0C 09 45 69 6E 64 68 6F 76 65 6E 31 12 30 10 06 03 55 04 07 0C 09 45 69 6E 64 68 6F 76 65 6E 31 0C 30 0A 06 03 55 04 0A 0C 03 4E 58 50 31 1D 30 1B 06 03 55 04 03 0C 14 4E 58 50 20 41 75 74 68 20 52 6F 6F 74 43 41 76 45 32 30 31 nx_mw :DEBUG:FN: nx_AES_EV2_Encrypt_CommandAPDU nx_mw :DEBUG:FN: nx_PadCommandAPDU nx_mw :DEBUG:Input: cmdApduBuf (Len=176) 04 C2 3A B7 F3 EB 7E CD F9 4E 1C 43 B2 8B 0C 2F 49 C9 61 35 A1 4A E0 58 BC A9 FE F9 4D 18 D4 46 28 C1 2F 8D 00 5B C4 8C C4 02 74 86 90 42 75 AE 55 96 0B 23 C7 6E 96 EF 96 80 27 04 2A 16 7D E5 AD 64 30 62 31 0B 30 09 06 03 55 04 06 13 02 4E 4C 31 12 30 10 06 03 55 04 08 0C 09 45 69 6E 64 68 6F 76 65 6E 31 12 30 10 06 03 55 04 07 0C 09 45 69 6E 64 68 6F 76 65 6E 31 0C 30 0A 06 03 55 04 0A 0C 03 4E 58 50 31 1D 30 1B 06 03 55 04 03 0C 14 4E 58 50 20 41 75 74 68 20 52 6F 6F 74 43 41 76 45 32 30 31 80 00 00 00 00 00 00 00 00 00 nx_mw :DEBUG:FN: nx_AES_EV2_MAC_CommandAPDU nx_mw :DEBUG:Command counter = 2 nx_mw :DEBUG:APDU Tx> (Len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nx_mw :DEBUG:Enter phNxpEseProto7816_Transceive nx_mw :DEBUG:Transceive data ptr 0x0x7ffff91ea760 len:197 nx_mw :DEBUG:I-Frame Data Len: 197 Seq. no:0 nx_mw :DEBUG:TransceiveProcess nextTransceiveState 1 nx_mw :DEBUG:phNxpEse_WriteFrame Enter .. nx_mw :DEBUG:TX (axI2CWrite) > (Len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nx_mw :DEBUG:Done with rv = 0c nx_mw :DEBUG:RAW Tx> (Len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nx_mw :DEBUG:phNxpEse_read Enter .. nx_mw :DEBUG:phPalEse_i2c_read Read Requested 2 bytes nx_mw :DEBUG:Done with rv = 0d nx_mw :DEBUG:RX (axI2CRead): (Len=2) 00 00 nx_mw :DEBUG:_i2c_read() error : 13 nx_mw :DEBUG:_i2c_read() failed. Going to retry, counter:1 ! nx_mw :DEBUG:Done with rv = 0d nx_mw :DEBUG:RX (axI2CRead): (Len=2) 00 00 nx_mw :DEBUG:_i2c_read() error : 13 nx_mw :DEBUG:_i2c_read() failed. Going to retry, counter:2 ! nx_mw :DEBUG:Done with rv = 0d nx_mw :DEBUG:RX (axI2CRead): (Len=2) 00 00 nx_mw :DEBUG:_i2c_read() error : 13 nx_mw :DEBUG:_i2c_read() failed. Going to retry, counter:3 ! nx_mw :DEBUG:Done with rv = 0d nx_mw :DEBUG:RX (axI2CRead): (Len=2) 00 00 nx_mw :DEBUG:_i2c_read() error : 13 nx_mw :DEBUG:_i2c_read() failed. Going to retry, counter:4 ! nx_mw :DEBUG:Done with rv = 0c nx_mw :DEBUG:RX (axI2CRead): (Len=2) 12 00 nx_mw :DEBUG:phNxpEse_readPacket Read HDR nx_mw :DEBUG:phNxpEse_readPacket SOF FOUND nx_mw :DEBUG:phPalEse_i2c_read Read Requested 2 bytes nx_mw :DEBUG:Done with rv = 0c nx_mw :DEBUG:RX (axI2CRead): (Len=2) 00 0A nx_mw :DEBUG:poll_sof_chained_delay value is 0 nx_mw :DEBUG:phPalEse_i2c_read Read Requested 12 bytes nx_mw :DEBUG:Done with rv = 0c nx_mw :DEBUG:RX (axI2CRead): (Len=12) 05 98 F4 58 9A 1B FB D3 91 00 FE D5 nx_mw :DEBUG:RAW Rx< (Len=16) 12 00 00 0A 05 98 F4 58 9A 1B FB D3 91 00 FE D5 nx_mw :DEBUG:phNxpEseProto7816_ProcessResponse p_data ----> 0x55562b33cab0 len ----> 0x10 nx_mw :DEBUG:Received CRC:0xfed5 Calculated CRC:0xfed5 nx_mw :DEBUG:Retry Counter = 0 nx_mw :DEBUG:phNxpEseProto7816_DecodeFrame I-Frame Received nx_mw :DEBUG:phNxpEseProto7816_DecodeFrame I-Frame lastRcvdIframeInfo.seqNo:0x0 nx_mw :DEBUG:Data[0]=0x5 len=10 Data[9]=0x91 Data[10]=0x0 nx_mw :DEBUG: phNxpEse_Transceive Exit status 0x0 nx_mw :DEBUG:APDU Rx< (Len=10) 05 98 F4 58 9A 1B FB D3 91 00 nx_mw :DEBUG:FN: nx_DeCrypt nx_mw :DEBUG: Input:rspBuf (Len=10) 05 98 F4 58 9A 1B FB D3 91 00 nx_mw :DEBUG:Mac verified : (Len=16) 43 05 90 98 C4 F4 1B 58 42 9A 1F 1B 62 FB EE D3 nx_mw :DEBUG:Decrypted the response (Len=2) 91 00 nx_mw :DEBUG:Using certificate/key from:'/home/pi/a30mw/nxmw-main/binaries/configuration/cert_depth3_PKCS7_rev1' (ENV=NX_AUTH_CERT_DIR) nx_mw :DEBUG:Number of characters read = 500 nx_mw :INFO :Read file from /home/pi/a30mw/nxmw-main/binaries/configuration/cert_depth3_PKCS7_rev1/cert_and_key/nist_p/device_leaf_certificate.der nx_mw :DEBUG:Using certificate/key from:'/home/pi/a30mw/nxmw-main/binaries/configuration/cert_depth3_PKCS7_rev1' (ENV=NX_AUTH_CERT_DIR) nx_mw :DEBUG:Number of characters read = 121 nx_mw :INFO :Read file from /home/pi/a30mw/nxmw-main/binaries/configuration/cert_depth3_PKCS7_rev1/cert_and_key/nist_p/device_leaf_keypair.der APDU :DEBUG:GetKeySettings [ECCPrivateKeyList] APDU :DEBUG: [Option] = 0x1 nx_mw :DEBUG: Input:Native Command code (Len=1) 45 nx_mw :DEBUG: Input:Native Command Header (Len=1) 01 nx_mw :DEBUG:FN: nx_AES_EV2_MAC_CommandAPDU nx_mw :DEBUG:Command counter = 3 nx_mw :DEBUG:APDU Tx> (Len=15) 90 45 00 00 09 01 63 3C E6 71 4F 32 9A AE 00 nx_mw :DEBUG:Enter phNxpEseProto7816_Transceive nx_mw :DEBUG:Transceive data ptr 0x0x7ffff91e97f0 len:15 nx_mw :DEBUG:I-Frame Data Len: 15 Seq. no:1 nx_mw :DEBUG:TransceiveProcess nextTransceiveState 1 nx_mw :DEBUG:phNxpEse_WriteFrame Enter .. nx_mw :DEBUG:TX (axI2CWrite) > (Len=21) 21 40 00 0F 90 45 00 00 09 01 63 3C E6 71 4F 32 9A AE 00 1F 2E nx_mw :DEBUG:Done with rv = 0c nx_mw :DEBUG:RAW Tx> (Len=21) 21 40 00 0F 90 45 00 00 09 01 63 3C E6 71 4F 32 9A AE 00 1F 2E nx_mw :DEBUG:phNxpEse_read Enter .. nx_mw :DEBUG:phPalEse_i2c_read Read Requested 2 bytes nx_mw :DEBUG:Done with rv = 0d nx_mw :DEBUG:RX (axI2CRead): (Len=2) 00 00 nx_mw :DEBUG:_i2c_read() error : 13 nx_mw :DEBUG:_i2c_read() failed. Going to retry, counter:1 ! nx_mw :DEBUG:Done with rv = 0c nx_mw :DEBUG:RX (axI2CRead): (Len=2) 12 40 nx_mw :DEBUG:phNxpEse_readPacket Read HDR nx_mw :DEBUG:phNxpEse_readPacket SOF FOUND nx_mw :DEBUG:phPalEse_i2c_read Read Requested 2 bytes nx_mw :DEBUG:Done with rv = 0c nx_mw :DEBUG:RX (axI2CRead): (Len=2) 00 3F nx_mw :DEBUG:poll_sof_chained_delay value is 0 nx_mw :DEBUG:phPalEse_i2c_read Read Requested 65 bytes nx_mw :DEBUG:Done with rv = 0c nx_mw :DEBUG:RX (axI2CRead): (Len=65) 04 00 0C 04 00 30 00 00 00 00 00 00 00 00 02 0C 30 00 30 00 00 00 00 00 00 00 00 03 0D 04 00 30 00 00 00 00 00 00 00 00 04 0C 08 00 30 00 00 00 00 00 00 00 00 94 8F 21 C9 D4 42 97 1C 91 00 61 71 nx_mw :DEBUG:RAW Rx< (Len=69) 12 40 00 3F 04 00 0C 04 00 30 00 00 00 00 00 00 00 00 02 0C 30 00 30 00 00 00 00 00 00 00 00 03 0D 04 00 30 00 00 00 00 00 00 00 00 04 0C 08 00 30 00 00 00 00 00 00 00 00 94 8F 21 C9 D4 42 97 1C 91 00 61 71 nx_mw :DEBUG:phNxpEseProto7816_ProcessResponse p_data ----> 0x55562b33cab0 len ----> 0x45 nx_mw :DEBUG:Received CRC:0x6171 Calculated CRC:0x6171 nx_mw :DEBUG:Retry Counter = 0 nx_mw :DEBUG:phNxpEseProto7816_DecodeFrame I-Frame Received nx_mw :DEBUG:phNxpEseProto7816_DecodeFrame I-Frame lastRcvdIframeInfo.seqNo:0x1 nx_mw :DEBUG:Data[0]=0x4 len=63 Data[62]=0x91 Data[63]=0x0 nx_mw :DEBUG: phNxpEse_Transceive Exit status 0x0 nx_mw :DEBUG:APDU Rx< (Len=63) 04 00 0C 04 00 30 00 00 00 00 00 00 00 00 02 0C 30 00 30 00 00 00 00 00 00 00 00 03 0D 04 00 30 00 00 00 00 00 00 00 00 04 0C 08 00 30 00 00 00 00 00 00 00 00 94 8F 21 C9 D4 42 97 1C 91 00 nx_mw :DEBUG:FN: nx_DeCrypt nx_mw :DEBUG: Input:rspBuf (Len=63) 04 00 0C 04 00 30 00 00 00 00 00 00 00 00 02 0C 30 00 30 00 00 00 00 00 00 00 00 03 0D 04 00 30 00 00 00 00 00 00 00 00 04 0C 08 00 30 00 00 00 00 00 00 00 00 94 8F 21 C9 D4 42 97 1C 91 00 nx_mw :DEBUG:Mac verified : (Len=16) D0 94 C2 8F 88 21 4F C9 10 D4 FE 42 1B 97 B9 1C nx_mw :DEBUG:Decrypted the response (Len=55) 04 00 0C 04 00 30 00 00 00 00 00 00 00 00 02 0C 30 00 30 00 00 00 00 00 00 00 00 03 0D 04 00 30 00 00 00 00 00 00 00 00 04 0C 08 00 30 00 00 00 00 00 00 00 00 91 00 APDU :DEBUG:ManageKeyPair [] APDU :DEBUG: [KeyNo] = 0x0 APDU :DEBUG: [Option] = 0x1 APDU :DEBUG: [curveID] = 0xC APDU :DEBUG: [KeyPolicy(LSB)] = 0x4 APDU :DEBUG: [writeAccessCond] = 0x30 APDU :DEBUG: [KUCLimit(LSB)] = 0x0 APDU :DEBUG: [Private key] (Len=32) 2F 0A 6C 8F AC A9 E6 E3 B2 8D C1 24 F6 39 D3 9F E2 83 27 C6 6B 25 0C 18 75 F0 2C 94 8B 15 CC 47 nx_mw :DEBUG: Input:Native Command code (Len=1) 46 nx_mw :DEBUG: Input:Native Command Header (Len=10) 00 01 0C 04 00 30 00 00 00 00 nx_mw :DEBUG: Input:Native Command Data (Len=32) 2F 0A 6C 8F AC A9 E6 E3 B2 8D C1 24 F6 39 D3 9F E2 83 27 C6 6B 25 0C 18 75 F0 2C 94 8B 15 CC 47 nx_mw :DEBUG:FN: nx_AES_EV2_Encrypt_CommandAPDU nx_mw :DEBUG:FN: nx_PadCommandAPDU nx_mw :DEBUG:Input: cmdApduBuf (Len=48) 2F 0A 6C 8F AC A9 E6 E3 B2 8D C1 24 F6 39 D3 9F E2 83 27 C6 6B 25 0C 18 75 F0 2C 94 8B 15 CC 47 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 nx_mw :DEBUG:FN: nx_AES_EV2_MAC_CommandAPDU nx_mw :DEBUG:Command counter = 4 nx_mw :DEBUG:APDU Tx> (Len=72) 90 46 00 00 42 00 01 0C 04 00 30 00 00 00 00 A2 B1 30 6A AE CF 30 47 D5 96 D7 EB 69 EF DB A3 66 8D F0 B1 0F FD 3D FE 42 98 DF 73 71 EA 7D 82 98 B6 31 9E CE F0 FF 8C D6 14 53 D5 22 03 CD 78 C9 ED 69 98 30 1A BF DA 00 nx_mw :DEBUG:Enter phNxpEseProto7816_Transceive nx_mw :DEBUG:Transceive data ptr 0x0x7ffff91ea740 len:72 nx_mw :DEBUG:I-Frame Data Len: 72 Seq. no:0 nx_mw :DEBUG:TransceiveProcess nextTransceiveState 1 nx_mw :DEBUG:phNxpEse_WriteFrame Enter .. nx_mw :DEBUG:TX (axI2CWrite) > (Len=78) 21 00 00 48 90 46 00 00 42 00 01 0C 04 00 30 00 00 00 00 A2 B1 30 6A AE CF 30 47 D5 96 D7 EB 69 EF DB A3 66 8D F0 B1 0F FD 3D FE 42 98 DF 73 71 EA 7D 82 98 B6 31 9E CE F0 FF 8C D6 14 53 D5 22 03 CD 78 C9 ED 69 98 30 1A BF DA 00 68 F3 nx_mw :DEBUG:Done with rv = 0c nx_mw :DEBUG:RAW Tx> (Len=78) 21 00 00 48 90 46 00 00 42 00 01 0C 04 00 30 00 00 00 00 A2 B1 30 6A AE CF 30 47 D5 96 D7 EB 69 EF DB A3 66 8D F0 B1 0F FD 3D FE 42 98 DF 73 71 EA 7D 82 98 B6 31 9E CE F0 FF 8C D6 14 53 D5 22 03 CD 78 C9 ED 69 98 30 1A BF DA 00 68 F3 nx_mw :DEBUG:phNxpEse_read Enter .. nx_mw :DEBUG:phPalEse_i2c_read Read Requested 2 bytes nx_mw :DEBUG:Done with rv = 0d nx_mw :DEBUG:RX (axI2CRead): (Len=2) 00 00 nx_mw :DEBUG:_i2c_read() error : 13 nx_mw :DEBUG:_i2c_read() failed. Going to retry, counter:1 ! nx_mw :DEBUG:Done with rv = 0d nx_mw :DEBUG:RX (axI2CRead): (Len=2) 00 00 nx_mw :DEBUG:_i2c_read() error : 13 nx_mw :DEBUG:_i2c_read() failed. Going to retry, counter:2 ! nx_mw :DEBUG:Done with rv = 0d nx_mw :DEBUG:RX (axI2CRead): (Len=2) 00 00 nx_mw :DEBUG:_i2c_read() error : 13 nx_mw :DEBUG:_i2c_read() failed. Going to retry, counter:3 ! nx_mw :DEBUG:Done with rv = 0d nx_mw :DEBUG:RX (axI2CRead): (Len=2) 00 00 nx_mw :DEBUG:_i2c_read() error : 13 nx_mw :DEBUG:_i2c_read() failed. Going to retry, counter:4 ! nx_mw :DEBUG:Done with rv = 0d nx_mw :DEBUG:RX (axI2CRead): (Len=2) 00 00 nx_mw :DEBUG:_i2c_read() error : 13 nx_mw :DEBUG:_i2c_read() failed. Going to retry, counter:5 ! nx_mw :DEBUG:Done with rv = 0d nx_mw :DEBUG:RX (axI2CRead): (Len=2) 00 00 nx_mw :DEBUG:_i2c_read() error : 13 nx_mw :DEBUG:_i2c_read() failed. Going to retry, counter:6 ! nx_mw :DEBUG:Done with rv = 0c nx_mw :DEBUG:RX (axI2CRead): (Len=2) 12 00 nx_mw :DEBUG:phNxpEse_readPacket Read HDR nx_mw :DEBUG:phNxpEse_readPacket SOF FOUND nx_mw :DEBUG:phPalEse_i2c_read Read Requested 2 bytes nx_mw :DEBUG:Done with rv = 0c nx_mw :DEBUG:RX (axI2CRead): (Len=2) 00 0A nx_mw :DEBUG:poll_sof_chained_delay value is 0 nx_mw :DEBUG:phPalEse_i2c_read Read Requested 12 bytes nx_mw :DEBUG:Done with rv = 0c nx_mw :DEBUG:RX (axI2CRead): (Len=12) 7F 8B 20 25 EA 16 35 E6 91 00 86 F6 nx_mw :DEBUG:RAW Rx< (Len=16) 12 00 00 0A 7F 8B 20 25 EA 16 35 E6 91 00 86 F6 nx_mw :DEBUG:phNxpEseProto7816_ProcessResponse p_data ----> 0x55562b33cab0 len ----> 0x10 nx_mw :DEBUG:Received CRC:0x86f6 Calculated CRC:0x86f6 nx_mw :DEBUG:Retry Counter = 0 nx_mw :DEBUG:phNxpEseProto7816_DecodeFrame I-Frame Received nx_mw :DEBUG:phNxpEseProto7816_DecodeFrame I-Frame lastRcvdIframeInfo.seqNo:0x0 nx_mw :DEBUG:Data[0]=0x7f len=10 Data[9]=0x91 Data[10]=0x0 nx_mw :DEBUG: phNxpEse_Transceive Exit status 0x0 nx_mw :DEBUG:APDU Rx< (Len=10) 7F 8B 20 25 EA 16 35 E6 91 00 nx_mw :DEBUG:FN: nx_DeCrypt nx_mw :DEBUG: Input:rspBuf (Len=10) 7F 8B 20 25 EA 16 35 E6 91 00 nx_mw :DEBUG:Mac verified : (Len=16) 28 7F 86 8B E1 20 6F 25 BE EA C1 16 1B 35 B5 E6 nx_mw :DEBUG:Decrypted the response (Len=2) 91 00 APDU :DEBUG:GetConfiguration [Certificate Management] APDU :DEBUG: [Option] = 0x13 nx_mw :DEBUG: Input:Native Command code (Len=1) 65 nx_mw :DEBUG: Input:Native Command Header (Len=1) 13 nx_mw :DEBUG:FN: nx_AES_EV2_MAC_CommandAPDU nx_mw :DEBUG:Command counter = 5 nx_mw :DEBUG:APDU Tx> (Len=15) 90 65 00 00 09 13 A2 19 25 9F 28 A9 67 A0 00 nx_mw :DEBUG:Enter phNxpEseProto7816_Transceive nx_mw :DEBUG:Transceive data ptr 0x0x7ffff91ea0c0 len:15 nx_mw :DEBUG:I-Frame Data Len: 15 Seq. no:1 nx_mw :DEBUG:TransceiveProcess nextTransceiveState 1 nx_mw :DEBUG:phNxpEse_WriteFrame Enter .. nx_mw :DEBUG:TX (axI2CWrite) > (Len=21) 21 40 00 0F 90 65 00 00 09 13 A2 19 25 9F 28 A9 67 A0 00 7A 7F nx_mw :DEBUG:Done with rv = 0c nx_mw :DEBUG:RAW Tx> (Len=21) 21 40 00 0F 90 65 00 00 09 13 A2 19 25 9F 28 A9 67 A0 00 7A 7F nx_mw :DEBUG:phNxpEse_read Enter .. nx_mw :DEBUG:phPalEse_i2c_read Read Requested 2 bytes nx_mw :DEBUG:Done with rv = 0d nx_mw :DEBUG:RX (axI2CRead): (Len=2) 00 00 nx_mw :DEBUG:_i2c_read() error : 13 nx_mw :DEBUG:_i2c_read() failed. Going to retry, counter:1 ! nx_mw :DEBUG:Done with rv = 0c nx_mw :DEBUG:RX (axI2CRead): (Len=2) 12 40 nx_mw :DEBUG:phNxpEse_readPacket Read HDR nx_mw :DEBUG:phNxpEse_readPacket SOF FOUND nx_mw :DEBUG:phPalEse_i2c_read Read Requested 2 bytes nx_mw :DEBUG:Done with rv = 0c nx_mw :DEBUG:RX (axI2CRead): (Len=2) 00 1A nx_mw :DEBUG:poll_sof_chained_delay value is 0 nx_mw :DEBUG:phPalEse_i2c_read Read Requested 28 bytes nx_mw :DEBUG:Done with rv = 0c nx_mw :DEBUG:RX (axI2CRead): (Len=28) 2E 7F BE 71 08 3B 2B FF 46 F0 2B E5 66 16 DA 32 F7 34 39 B6 4D EA C7 D7 91 00 BB AF nx_mw :DEBUG:RAW Rx< (Len=32) 12 40 00 1A 2E 7F BE 71 08 3B 2B FF 46 F0 2B E5 66 16 DA 32 F7 34 39 B6 4D EA C7 D7 91 00 BB AF nx_mw :DEBUG:phNxpEseProto7816_ProcessResponse p_data ----> 0x55562b33cab0 len ----> 0x20 nx_mw :DEBUG:Received CRC:0xbbaf Calculated CRC:0xbbaf nx_mw :DEBUG:Retry Counter = 0 nx_mw :DEBUG:phNxpEseProto7816_DecodeFrame I-Frame Received nx_mw :DEBUG:phNxpEseProto7816_DecodeFrame I-Frame lastRcvdIframeInfo.seqNo:0x1 nx_mw :DEBUG:Data[0]=0x2e len=26 Data[25]=0x91 Data[26]=0x0 nx_mw :DEBUG: phNxpEse_Transceive Exit status 0x0 nx_mw :DEBUG:APDU Rx< (Len=26) 2E 7F BE 71 08 3B 2B FF 46 F0 2B E5 66 16 DA 32 F7 34 39 B6 4D EA C7 D7 91 00 nx_mw :DEBUG:FN: nx_DeCrypt nx_mw :DEBUG: Input:rspBuf (Len=26) 2E 7F BE 71 08 3B 2B FF 46 F0 2B E5 66 16 DA 32 F7 34 39 B6 4D EA C7 D7 91 00 nx_mw :DEBUG:Mac verified : (Len=16) 98 F7 45 34 5C 39 81 B6 E5 4D 5F EA 56 C7 C2 D7 nx_mw :DEBUG:Decrypted the response (Len=6) 05 04 08 10 91 00 APDU :DEBUG:ManageCertRepo [CreateCertRepo] APDU :DEBUG: [action] = 0x0 APDU :DEBUG: [repoID] = 0x0 APDU :DEBUG: [cert private keyID] = 0x0 APDU :DEBUG: [repoSize(LSB)] = 0xC00 APDU :DEBUG: [writeAccess] = 0x30 APDU :DEBUG: [readAccess] = 0x30 nx_mw :DEBUG: Input:Native Command code (Len=1) 49 nx_mw :DEBUG: Input:Native Command Header (Len=7) 00 00 00 00 0C 30 30 nx_mw :DEBUG:FN: nx_AES_EV2_MAC_CommandAPDU nx_mw :DEBUG:Command counter = 6 nx_mw :DEBUG:APDU Tx> (Len=21) 90 49 00 00 0F 00 00 00 00 0C 30 30 21 50 44 1A 00 AA 84 A7 00 nx_mw :DEBUG:Enter phNxpEseProto7816_Transceive nx_mw :DEBUG:Transceive data ptr 0x0x7ffff91eaf20 len:21 nx_mw :DEBUG:I-Frame Data Len: 21 Seq. no:0 nx_mw :DEBUG:TransceiveProcess nextTransceiveState 1 nx_mw :DEBUG:phNxpEse_WriteFrame Enter .. nx_mw :DEBUG:TX (axI2CWrite) > (Len=27) 21 00 00 15 90 49 00 00 0F 00 00 00 00 0C 30 30 21 50 44 1A 00 AA 84 A7 00 FA 77 nx_mw :DEBUG:Done with rv = 0c nx_mw :DEBUG:RAW Tx> (Len=27) 21 00 00 15 90 49 00 00 0F 00 00 00 00 0C 30 30 21 50 44 1A 00 AA 84 A7 00 FA 77 nx_mw :DEBUG:phNxpEse_read Enter .. nx_mw :DEBUG:phPalEse_i2c_read Read Requested 2 bytes nx_mw :DEBUG:Done with rv = 0c nx_mw :DEBUG:RX (axI2CRead): (Len=2) 12 00 nx_mw :DEBUG:phNxpEse_readPacket Read HDR nx_mw :DEBUG:phNxpEse_readPacket SOF FOUND nx_mw :DEBUG:phPalEse_i2c_read Read Requested 2 bytes nx_mw :DEBUG:Done with rv = 0c nx_mw :DEBUG:RX (axI2CRead): (Len=2) 00 02 nx_mw :DEBUG:poll_sof_chained_delay value is 0 nx_mw :DEBUG:phPalEse_i2c_read Read Requested 4 bytes nx_mw :DEBUG:Done with rv = 0c nx_mw :DEBUG:RX (axI2CRead): (Len=4) 91 DE 37 A7 nx_mw :DEBUG:RAW Rx< (Len=8) 12 00 00 02 91 DE 37 A7 nx_mw :DEBUG:phNxpEseProto7816_ProcessResponse p_data ----> 0x55562b33cab0 len ----> 0x8 nx_mw :DEBUG:Received CRC:0x37a7 Calculated CRC:0x37a7 nx_mw :DEBUG:Retry Counter = 0 nx_mw :DEBUG:phNxpEseProto7816_DecodeFrame I-Frame Received nx_mw :DEBUG:phNxpEseProto7816_DecodeFrame I-Frame lastRcvdIframeInfo.seqNo:0x0 nx_mw :DEBUG:Data[0]=0x91 len=2 Data[1]=0x91 Data[2]=0xde nx_mw :DEBUG: phNxpEse_Transceive Exit status 0x0 nx_mw :DEBUG:APDU Rx< (Len=2) 91 DE nx_mw :DEBUG:FN: nx_DeCrypt nx_mw :DEBUG: Input:rspBuf (Len=2) 91 DE nx_mw :WARN :nxEnsure:'(ret == SM_OK) || (ret == SM_OK_ALT)' failed. At Line:3713 Function:sss_nx_TXn_AES_EV2 nx_mw :ERROR:nx_ManageCertRepo_CreateCertRepo Failed nx_mw :WARN :nxEnsure:'status == kStatus_SSS_Success' failed. At Line:812 Function:nx_load_se_leaf_keypair_and_cert nx_mw :WARN :nxEnsure:'status == kStatus_SSS_Success' failed. At Line:980 Function:ex_sss_entry nx_mw :ERROR:nx_Personalization Example Failed !!!... nx_mw :INFO :ex_sss Finished nx_mw :ERROR:ex_sss_entry Failed nx_mw :DEBUG:Close i2c device 3. nx_mw :DEBUG:phNxpEse_close - ESE Context deinit completed nx_mw :ERROR:!ERROR! ret != 0.
6,209件の閲覧回数
Kan_Li
Hi @Jansch ,
Thanks for the info! We noticed the 91 DE error in the error log which indicates it's already personalized, so it can not be personalized any more. and as you mentioned , All example are working but nx_Personalization is failed.
Question 1) Have you played with all example works with Symmetric authentication? I understand you didn't try with Sigma-I-Authentication, right?
Please kindly clarify.
Kan
6,205件の閲覧回数
Jansch
Hello @Kan_Li
You are absolutely right, I didn't realise that was the issue with the nx_Personalization, as I don't have the chip first hand.
I also wanted to apologize for the formatting, if I only use quick reply, it doesn't format properly.
When running the Minimal example using SIGMA-I I receive this error still though. Is this the wrong directory?
nx_mw :INFO :Read file from /home/pi/a30mw/nxmw-main/binaries/configuration/cert_depth3_PKCS7_rev1/cert_and_key/nist_p/device_root_certificate.der
nx_mw :WARN :nxEnsure:'status == kStatus_SSS_Success' failed. At Line:1963 Function:nx_verify_leaf_cert_hash_signature
nx_mw :WARN :nxEnsure:'status == kStatus_SSS_Success' failed. At Line:3512 Function:nx_sigma_i_authenticate_channel
nx_mw :ERROR:Could not set SIGMA-I Verifier Secure Channel
nx_mw :WARN :nxEnsure:'kStatus_SSS_Success == status' failed. At Line:174 Function:ex_sss_boot_nx_open nx_mw :ERROR:ex_sss_session_open Failed
6,192件の閲覧回数
Kan_Li
Hi @Jansch ,
Thanks for the info! Actually A30 can only be personalized once, I am not sure how you configure nxMW for the first personalization, but please keep align with the first configuration when you do the first personalization,  I think it should also be done by yourself , right? if you personalize the chip with the keys and certs in folder A but run demos with ENV to folder B , there would be issues for sure.
BTW, Is it possible to share your current nxMW cmake options for a review?
Kan
%3CLINGO-SUB%20id%3D%22lingo-sub-2045241%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EA30%20%E3%81%AE%20nx_personalization%20%E3%83%87%E3%83%A2%E3%81%A7%E6%AD%A3%E3%81%97%E3%81%84%20ENV%20%E5%A4%89%E6%95%B0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2045241%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%20A30%20%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81SIGMA-I%20%E8%AA%8D%E8%A8%BC%E3%81%A7%20nx_personalization%20%E3%83%87%E3%83%A2%E3%82%92%E5%8B%95%E4%BD%9C%E3%81%95%E3%81%9B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82ENV%20%E5%A4%89%E6%95%B0%E3%82%92%E3%81%9D%E3%82%8C%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A7%E3%82%82%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%87%BA%E5%8A%9B%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%20nx_mw%3AINFO%3A%E3%82%BB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E6%88%90%E5%8A%9F%20nx_mw%3AINFO%3ANx%E3%83%97%E3%83%AD%E3%83%93%E3%82%B8%E3%83%A7%E3%83%8B%E3%83%B3%E3%82%B0%E9%96%8B%E5%A7%8B%3C%2FP%3E%3CP%3Enx_mw%20%3A%E6%83%85%E5%A0%B1%3A********************************%20%E6%B3%A8%E8%A8%98%20********************************************%3C%2FP%3E%3CP%3Enx_mw%20%3AINFO%20%3A%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E6%9C%80%E4%B8%8A%E4%BD%8D%E8%A8%BC%E6%98%8E%E6%9B%B8%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%3A%20%2Ftmp%2Fconfiguration%2Fa30_hostcert_depth2_x509_rev3_nistp%2F%3C%2FP%3E%3CP%3Enx_mw%20%3AINFO%20%3A%E3%81%93%E3%81%AE%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%20%E3%83%91%E3%82%B9%E3%82%92%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%A9%E3%82%A4%E3%83%89%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E7%92%B0%E5%A2%83%E5%A4%89%E6%95%B0%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Enx_mw%20%3AINFO%20%3ANX_AUTH_CERT_DIR%3D..%5Cnx-mw-top%5Cbinaries%5Cconfiguration%5Ccert_depth3_PKCS7_rev1%3C%2FP%3E%3CP%3Enx_mw%20%3A%E6%83%85%E5%A0%B1%20%3A********************************************************************************%3C%2FP%3E%3CP%3Enx_mw%3AINFO%3A'..%5Cnx-mw-top%5Cbinaries%5Cconfiguration%5Ccert_depth3_PKCS7_rev1'%20%E3%81%8B%E3%82%89%E3%81%AE%E8%A8%BC%E6%98%8E%E6%9B%B8%2F%E3%82%AD%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20(ENV%3DNX_AUTH_CERT_DIR)%3C%2FP%3E%3CP%3Enx_mw%20%3A%E8%AD%A6%E5%91%8A%20%3A%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%83%88%E3%83%A9%E3%83%90%E3%83%BC%E3%82%B5%E3%83%AB%E3%81%AE%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Enx_mw%3A%E8%AD%A6%E5%91%8A%3Ahost_root_certificates%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E8%87%AA%E5%B7%B1%E7%BD%B2%E5%90%8D%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E6%83%B3%E5%AE%9A%E3%81%95%E3%82%8C%E3%82%8B%E3%83%AA%E3%83%BC%E3%83%95%E8%A8%BC%E6%98%8E%E6%9B%B8%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3Enx_mw%3AINFO%3A'..%5Cnx-mw-top%5Cbinaries%5Cconfiguration%5Ccert_depth3_PKCS7_rev1'%20%E3%81%8B%E3%82%89%E3%81%AE%E8%A8%BC%E6%98%8E%E6%9B%B8%2F%E3%82%AD%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20(ENV%3DNX_AUTH_CERT_DIR)%3C%2FP%3E%3CP%3Enx_mw%20%3A%E8%AD%A6%E5%91%8A%20%3A%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%83%88%E3%83%A9%E3%83%90%E3%83%BC%E3%82%B5%E3%83%AB%E3%81%AE%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Enx_mw%3A%E8%AD%A6%E5%91%8A%3AnxEnsure%3A'status%20%3D%3D%20kStatus_SSS_Success'%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E8%A1%8C%3A741%20%E9%96%A2%E6%95%B0%3Anx_load_host_root_CA_pubkey%3C%2FP%3E%3CP%3Enx_mw%3A%E8%AD%A6%E5%91%8A%3AnxEnsure%3A'status%20%3D%3D%20kStatus_SSS_Success'%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E8%A1%8C%3A976%20%E9%96%A2%E6%95%B0%3Aex_sss_entry%3C%2FP%3E%3CP%3Enx_mw%3A%E3%82%A8%E3%83%A9%E3%83%BC%3Anx_Personalization%E3%81%AE%E4%BE%8B%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F!!!...%20nx_mw%3AINFO%3Aex_sss%E3%81%8C%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Enx_mw%3AERROR%3Aex_sss_entry%20%E5%A4%B1%E6%95%97%20nx_mw%3AERROR%3A!ERROR!ret%20!%3D%200%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2270359%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Using%20correct%20ENV%20Variable%20with%20nx_personalization%20demo%20for%20A30%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2270359%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82A1006UK%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E9%96%8B%E7%99%BA%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%94%E7%B5%8C%E9%A8%93%E3%81%AE%E3%81%82%E3%82%8B%E6%96%B9%E3%80%81%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%AA%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2048821%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Using%20correct%20ENV%20Variable%20with%20nx_personalization%20demo%20for%20A30%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2048821%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F241789%22%20target%3D%22_blank%22%3E%40Jansch%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%83%85%E5%A0%B1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%E5%AE%9F%E9%9A%9B%E3%81%AB%E3%81%AF%E3%80%81A30%20%E3%81%AF%E4%B8%80%E5%BA%A6%E3%81%97%E3%81%8B%E3%83%91%E3%83%BC%E3%82%BD%E3%83%8A%E3%83%A9%E3%82%A4%E3%82%BA%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E6%9C%80%E5%88%9D%E3%81%AE%E3%83%91%E3%83%BC%E3%82%BD%E3%83%8A%E3%83%A9%E3%82%A4%E3%82%BA%E3%81%A7%20nxMW%20%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E6%A7%8B%E6%88%90%E3%81%99%E3%82%8B%E3%81%8B%E3%81%AF%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E6%9C%80%E5%88%9D%E3%81%AE%E3%83%91%E3%83%BC%E3%82%BD%E3%83%8A%E3%83%A9%E3%82%A4%E3%82%BA%E3%82%92%E8%A1%8C%E3%81%86%E3%81%A8%E3%81%8D%E3%81%AF%E3%80%81%E6%9C%80%E5%88%9D%E3%81%AE%E6%A7%8B%E6%88%90%E3%81%AB%E5%90%88%E3%82%8F%E3%81%9B%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%93%E3%82%8C%E3%82%82%E8%87%AA%E5%88%86%E3%81%A7%E8%A1%8C%E3%81%86%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%83%BC%20A%20%E3%81%AE%E3%82%AD%E3%83%BC%E3%81%A8%E8%A8%BC%E6%98%8E%E6%9B%B8%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%81%E3%83%83%E3%83%97%E3%82%92%E3%83%91%E3%83%BC%E3%82%BD%E3%83%8A%E3%83%A9%E3%82%A4%E3%82%BA%E3%81%97%E3%80%81%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%83%BC%20B%20%E3%81%AB%20ENV%20%E3%82%92%E6%8C%87%E5%AE%9A%E3%81%97%E3%81%A6%E3%83%87%E3%83%A2%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E7%A2%BA%E5%AE%9F%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%A8%E3%81%93%E3%82%8D%E3%81%A7%E3%80%81%E3%83%AC%E3%83%93%E3%83%A5%E3%83%BC%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E7%8F%BE%E5%9C%A8%E3%81%AE%20nxMW%20cmake%20%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8F%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%99%E3%81%A6%E3%81%8D%E3%81%AA%E4%B8%80%E6%97%A5%E3%82%92%E3%80%81%3CBR%20%2F%3E%E3%82%AB%E3%83%B3%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E---------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%E8%A8%98%EF%BC%9A%3CBR%20%2F%3E%20-%20%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%8C%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%B8%E3%81%AE%E5%9B%9E%E7%AD%94%E3%81%A7%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%80%8C%E6%AD%A3%E8%A7%A3%E3%81%A8%E3%81%97%E3%81%A6%E3%83%9E%E3%83%BC%E3%82%AF%E3%80%8D%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%EF%BC%81%3CBR%20%2F%3E%20-%20Thread%E3%81%AF%E6%9C%80%E5%BE%8C%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%8B%E3%82%897%E9%80%B1%E9%96%93%E3%83%95%E3%82%A9%E3%83%AD%E3%83%BC%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E4%BB%A5%E9%99%8D%E3%81%AE%E8%BF%94%E4%BF%A1%E3%81%AF%E7%84%A1%E8%A6%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E5%BE%8C%E3%81%BB%E3%81%A9%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%96%B0%E3%81%97%E3%81%84Thread%E3%82%92%E9%96%8B%E3%81%84%E3%81%A6%E3%80%81%E9%96%89%E3%81%98%E3%81%9FThread%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E---------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2047921%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Using%20correct%20ENV%20Variable%20with%20nx_personalization%20demo%20for%20A30%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2047921%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59276%22%20target%3D%22_blank%22%3E%40Kan_Li%3C%2FA%3E%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%A3%E3%81%9F%E3%81%8F%E3%81%9D%E3%81%AE%E9%80%9A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%E3%83%81%E3%83%83%E3%83%97%E3%82%92%E7%9B%B4%E6%8E%A5%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%80%81%E3%81%9D%E3%82%8C%E3%81%8C%20nx_Personalization%20%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%A0%E3%81%A8%E3%81%AF%E6%B0%97%E3%81%A5%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%82%82%E3%81%8A%E8%A9%AB%E3%81%B3%E7%94%B3%E3%81%97%E4%B8%8A%E3%81%92%E3%81%BE%E3%81%99%E3%80%82%E3%82%AF%E3%82%A4%E3%83%83%E3%82%AF%E8%BF%94%E4%BF%A1%E3%81%AE%E3%81%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%E3%81%8C%E9%81%A9%E5%88%87%E3%81%AB%E8%A1%8C%E3%82%8F%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81SIGMA-I%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20Minimal%20%E3%81%AE%E4%BE%8B%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E4%BE%9D%E7%84%B6%E3%81%A8%E3%81%97%E3%81%A6%E3%81%93%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E9%96%93%E9%81%95%E3%81%A3%E3%81%9F%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3Enx_mw%3AINFO%3A%2Fhome%2Fpi%2Fa30mw%2Fnxmw-main%2Fbinaries%2Fconfiguration%2Fcert_depth3_PKCS7_rev1%2Fcert_and_key%2Fnist_p%2Fdevice_root_certificate.der%E3%81%8B%E3%82%89%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Enx_mw%3A%E8%AD%A6%E5%91%8A%3AnxEnsure%3A'status%20%3D%3D%20kStatus_SSS_Success'%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E8%A1%8C%3A1963%20%E9%96%A2%E6%95%B0%3Anx_verify_leaf_cert_hash_signature%3C%2FP%3E%3CP%3Enx_mw%3A%E8%AD%A6%E5%91%8A%3AnxEnsure%3A'status%20%3D%3D%20kStatus_SSS_Success'%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E8%A1%8C%3A3512%20%E9%96%A2%E6%95%B0%3Anx_sigma_i_authenticate_channel%3C%2FP%3E%3CP%3Enx_mw%3A%E3%82%A8%E3%83%A9%E3%83%BC%3ASIGMA-I%E6%A4%9C%E8%A8%BC%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Enx_mw%3A%E8%AD%A6%E5%91%8A%3AnxEnsure%3A'kStatus_SSS_Success%20%3D%3D%20status'%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E8%A1%8C%3A174%20%E9%96%A2%E6%95%B0%3Aex_sss_boot_nx_open%20nx_mw%3A%E3%82%A8%E3%83%A9%E3%83%BC%3Aex_sss_session_open%20%E5%A4%B1%E6%95%97%3C%2FP%3E%3CP%3Enx_mw%20%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A!%E3%82%A8%E3%83%A9%E3%83%BC!ret%20!%3D%200%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2047897%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Using%20correct%20ENV%20Variable%20with%20nx_personalization%20demo%20for%20A30%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2047897%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F241789%22%20target%3D%22_blank%22%3E%40Jansch%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%83%85%E5%A0%B1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3CSPAN%20data-teams%3D%22true%22%3E%E3%82%A8%E3%83%A9%E3%83%BC%20%E3%83%AD%E3%82%B0%E3%81%AB%2091%20DE%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E8%A8%98%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%E3%83%91%E3%83%BC%E3%82%BD%E3%83%8A%E3%83%A9%E3%82%A4%E3%82%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%81%93%E3%82%8C%E4%BB%A5%E4%B8%8A%E3%83%91%E3%83%BC%E3%82%BD%E3%83%8A%E3%83%A9%E3%82%A4%E3%82%BA%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%E3%81%8A%E3%81%A3%E3%81%97%E3%82%83%E3%82%8B%E3%81%A8%E3%81%8A%E3%82%8A%E3%80%81%3C%2FSPAN%3E%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E4%BE%8B%E3%81%AF%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81nx_Personalization%20%E3%81%AF%E5%A4%B1%E6%95%97%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%B3%AA%E5%95%8F%201)%20%E5%AF%BE%E7%A7%B0%E8%AA%8D%E8%A8%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E4%BD%9C%E5%93%81%E3%82%92%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3FSigma-I-Authentication%20%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%AE%E3%81%AF%E7%90%86%E8%A7%A3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%82%88%E3%81%AD%3F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%94%E8%AA%AC%E6%98%8E%E3%82%92%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%99%E3%81%A6%E3%81%8D%E3%81%AA%E4%B8%80%E6%97%A5%E3%82%92%E3%80%81%3CBR%20%2F%3E%E3%82%AB%E3%83%B3%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E---------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%E8%A8%98%EF%BC%9A%3CBR%20%2F%3E%20-%20%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%8C%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%B8%E3%81%AE%E5%9B%9E%E7%AD%94%E3%81%A7%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%80%8C%E6%AD%A3%E8%A7%A3%E3%81%A8%E3%81%97%E3%81%A6%E3%83%9E%E3%83%BC%E3%82%AF%E3%80%8D%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%EF%BC%81%3CBR%20%2F%3E%20-%20Thread%E3%81%AF%E6%9C%80%E5%BE%8C%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%8B%E3%82%897%E9%80%B1%E9%96%93%E3%83%95%E3%82%A9%E3%83%AD%E3%83%BC%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E4%BB%A5%E9%99%8D%E3%81%AE%E8%BF%94%E4%BF%A1%E3%81%AF%E7%84%A1%E8%A6%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E5%BE%8C%E3%81%BB%E3%81%A9%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%96%B0%E3%81%97%E3%81%84Thread%E3%82%92%E9%96%8B%E3%81%84%E3%81%A6%E3%80%81%E9%96%89%E3%81%98%E3%81%9FThread%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E---------------------------------------------------------------------------------%3C%2FP%3E%0A%3CP%3E%3CLI-WRAPPER%3E%3C%2FLI-WRAPPER%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2047187%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Using%20correct%20ENV%20Variable%20with%20nx_personalization%20demo%20for%20A30%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2047187%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59276%22%20target%3D%22_blank%22%3E%40Kan_Li%3C%2FA%3E%3C%2FP%3E%3CP%3E%E5%89%8D%E5%9B%9E%E3%81%AE%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%A7%E3%81%AF%E9%96%93%E9%81%95%E3%81%A3%E3%81%9F%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%82%92%E8%A8%98%E8%BC%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E6%AD%A3%E3%81%97%E3%81%84%E3%81%AE%E3%81%AF%E6%AC%A1%E3%81%AE%E9%80%9A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Enx_mw%3AINFO%3A'%2Fhome%2Fpi%2Fa30mw%2Fnxmw-main%2Fbinaries%2Fconfiguration%2Fcert_depth3_PKCS7_rev1'%20%E3%81%8B%E3%82%89%E3%81%AE%E8%A8%BC%E6%98%8E%E6%9B%B8%2F%E3%82%AD%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20(ENV%3DNX_AUTH_CERT_DIR)%3C%2FP%3E%3CP%3Enx_mw%3AINFO%3A%2Fhome%2Fpi%2Fa30mw%2Fnxmw-main%2Fbinaries%2Fconfiguration%2Fcert_depth3_PKCS7_rev1%2Fcert_and_key%2Fnist_p%2Fhost_root_certificate.der%E3%81%8B%E3%82%89%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Enx_mw%3AINFO%3A%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fpi%2Fa30mw%2Fnxmw-main%2Fbinaries%2Fconfiguration%2Fcert_depth3_PKCS7_rev1%2Fcert_and_key%2Fnist_p%2Fdevice_leaf_certificate.der%E3%81%8B%E3%82%89%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Enx_mw%3AINFO%3A%E3%83%9B%E3%83%BC%E3%83%A0%2Fpi%2Fa30mw%2Fnxmw-main%2Fbinaries%2Fconfiguration%2Fcert_depth3_PKCS7_rev1%2Fcert_and_key%2Fnist_p%2Fdevice_leaf_keypair.der%20%E3%81%8B%E3%82%89%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%BE%E3%81%99%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%A9%B3%E7%B4%B0%E3%83%AD%E3%82%B0%E3%81%AE%E5%87%BA%E5%8A%9B%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E9%95%B7%E3%81%8F%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3Enx_mw%3AINFO%3A%E3%82%BB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E6%88%90%E5%8A%9F%20nx_mw%3AINFO%3ANx%E3%83%97%E3%83%AD%E3%83%93%E3%82%B8%E3%83%A7%E3%83%8B%E3%83%B3%E3%82%B0%E9%96%8B%E5%A7%8B%3C%2FP%3E%3CP%3Enx_mw%3AINFO%3A********************************%20%E6%B3%A8%E6%84%8F********************************************%20nx_mw%3AINFO%3A%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E6%9C%80%E4%B8%8A%E4%BD%8D%E8%A8%BC%E6%98%8E%E6%9B%B8%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%3A%20%2Ftmp%2Fconfiguration%2Fa30_hostcert_depth2_x509_rev3_nistp%2F%20nx_mw%3AINFO%3A%E3%81%93%E3%81%AE%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%20%E3%83%91%E3%82%B9%E3%82%92%E4%B8%8A%E6%9B%B8%E3%81%8D%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E7%92%B0%E5%A2%83%E5%A4%89%E6%95%B0%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3A%20nx_mw%3AINFO%3ANX_AUTH_CERT_DIR%3D..%5Cnx-mw-top%5Cbinaries%5Cconfiguration%5Ccert_depth3_PKCS7_rev1%20nx_mw%3AINFO%3A********************************************************************************%20nx_mw%3AINFO%3A%E8%A8%BC%E6%98%8E%E6%9B%B8%2F%E3%82%AD%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99from%3A'%2Fhome%2Fpi%2Fa30mw%2Fnxmw-main%2Fbinaries%2Fconfiguration%2Fcert_depth3_PKCS7_rev1'%20(ENV%3DNX_AUTH_CERT_DIR)%20nx_mw%3ADEBUG%3A%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%89%E3%82%8C%E3%81%9F%E6%96%87%E5%AD%97%E6%95%B0%20%3D%20523%20nx_mw%3AINFO%3A%2Fhome%2Fpi%2Fa30mw%2Fnxmw-main%2Fbinaries%2Fconfiguration%2Fcert_depth3_PKCS7_rev1%2Fcert_and_key%2Fnist_p%2Fhost_root_certificate.der%20%E3%81%8B%E3%82%89%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%20nx_mw%3ADEBUG%3Aopenssl%20%E3%81%A7%E8%A8%BC%E6%98%8E%E6%9B%B8%E3%82%92%E8%A7%A3%E6%9E%90%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82PKCS%237%20%E8%A8%BC%E6%98%8E%E6%9B%B8%E3%81%AE%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%20APDU%20%3ADEBUG%3AGetKeySettings%20%5BCARootKeyList%5D%20APDU%20%3ADEBUG%3A%20%5BOption%5D%20%3D%200x2%20nx_mw%20%3ADEBUG%3A%20%E5%85%A5%E5%8A%9B%3A%E3%83%8D%E3%82%A4%E3%83%86%E3%82%A3%E3%83%96%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%20%E3%82%B3%E3%83%BC%E3%83%89%20(Len%3D1)%2045%20nx_mw%20%3ADEBUG%3A%20%E5%85%A5%E5%8A%9B%3A%E3%83%8D%E3%82%A4%E3%83%86%E3%82%A3%E3%83%96%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%20%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%20(Len%3D1)%2002%20nx_mw%20%3ADEBUG%3AFN%3A%20nx_AES_EV2_MAC_CommandAPDU%20nx_mw%20%3ADEBUG%3A%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%20%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%20%3D%201%20nx_mw%20%3ADEBUG%3AAPDU%20Tx%26gt%3B%20(Len%3D15)%2090%2045%2000%2000%2009%2002%2069%208F%2094%2002%202C%20AD%2068%2040%2000%20nx_mw%20%3ADEBUG%3AEnter%20phNxpEseProto7816_Transceive%20nx_mw%20%3ADEBUG%3A%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B7%E3%83%BC%E3%83%96%20%E3%83%87%E3%83%BC%E3%82%BF%20ptr%200x0x7ffff91e9870%20len%3A15%20nx_mw%20%3ADEBUG%3AI%20%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%20%E3%83%87%E3%83%BC%E3%82%BF%20Len%3A%2015%20Seq.no%3A1%20nx_mw%20%3ADEBUG%3ATransceiveProcess%20nextTransceiveState%201%20nx_mw%20%3ADEBUG%3AphNxpEse_WriteFrame%20%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82nx_mw%20%3ADEBUG%3ATX%20(axI2CWrite)%20%26gt%3B%20(Len%3D21)%2021%2040%2000%200F%2090%2045%2000%2000%2009%2002%2069%208F%2094%2002%202C%20AD%2068%2040%2000%2066%200A%20nx_mw%20%3ADEBUG%3Arv%20%3D%200c%20%E3%81%A7%E5%AE%8C%E4%BA%86%20nx_mw%20%3ADEBUG%3ARAW%20Tx%26gt%3B%20(Len%3D21)%2021%2040%2000%200F%2090%2045%2000%2000%2009%2002%2069%208F%2094%2002%202C%20AD%2068%2040%2000%2066%200A%20nx_mw%3ADEBUG%3AphNxpEse_read%20%E3%82%92%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82nx_mw%3ADEBUG%3AphPalEse_i2c_read%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E8%A6%81%E6%B1%82%E3%81%AF%202%20%E3%83%90%E3%82%A4%E3%83%88%E3%81%A7%E3%81%99%E3%80%82nx_mw%3ADEBUG%3Arv%20%3D%200d%20%E3%81%A7%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82nx_mw%3ADEBUG%3ARX%20(axI2CRead)%3A%20(Len%3D2)%2000%2000%20nx_mw%3ADEBUG%3A_i2c_read()%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%2013%20nx_mw%3ADEBUG%3A_i2c_read()%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%86%8D%E8%A9%A6%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%3A1!nx_mw%20%3ADEBUG%3Arv%20%3D%200c%20%E3%81%A7%E5%AE%8C%E4%BA%86%20nx_mw%20%3ADEBUG%3ARX%20(axI2CRead)%3A%20(Len%3D2)%2012%2040%20nx_mw%20%3ADEBUG%3AphNxpEse_readPacket%20HDR%20%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%20nx_mw%20%3ADEBUG%3AphNxpEse_readPacket%20SOF%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%20nx_mw%20%3ADEBUG%3AphPalEse_i2c_read%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E8%A6%81%E6%B1%82%202%20%E3%83%90%E3%82%A4%E3%83%88%20nx_mw%20%3ADEBUG%3Arv%20%3D%200c%20%E3%81%A7%E5%AE%8C%E4%BA%86%20nx_mw%20%3ADEBUG%3ARX%20(axI2CRead)%3A%20(Len%3D2)%2000%2012%20nx_mw%20%3ADEBUG%3Apoll_sof_chained_delay%20%E3%81%AE%E5%80%A4%E3%81%AF%200%20%E3%81%A7%E3%81%99%20nx_mw%20%3ADEBUG%3AphPalEse_i2c_read%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E8%A6%81%E6%B1%82%2020%20%E3%83%90%E3%82%A4%E3%83%88%20nx_mw%20%3ADEBUG%3Arv%20%3D%200c%20%E3%81%A7%E5%AE%8C%E4%BA%86%20nx_mw%20%3ADEBUG%3ARX%20(axI2CRead)%3A%20(Len%3D20)%2001%2000%200C%20FF%203F%2030%203F%2000%207A%200B%209B%20FC%2058%203F%20DC%20CD%2091%2000%2090%205D%20nx_mw%20%3ADEBUG%3ARAW%20Rx%26lt%3B%20(Len%3D24)%2012%2040%2000%2012%2001%2000%200C%20FF%203F%2030%203F%2000%207A%200B%209B%20FC%2058%203F%20DC%20CD%2091%2000%2090%205D%20nx_mw%20%3ADEBUG%3AphNxpEseProto7816_ProcessResponse%20p_data%20----%26gt%3B%200x55562b33cab0%20len%20----%26gt%3B%200x18%20nx_mw%20%3ADEBUG%3A%E5%8F%97%E4%BF%A1CRC%3A0x905d%20%E8%A8%88%E7%AE%97%E3%81%95%E3%82%8C%E3%81%9FCRC%3A0x905d%20nx_mw%20%3ADEBUG%3A%E5%86%8D%E8%A9%A6%E8%A1%8C%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%20%3D%200%20nx_mw%20%3ADEBUG%3AphNxpEseProto7816_DecodeFrame%20I%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20nx_mw%20%3ADEBUG%3AphNxpEseProto7816_DecodeFrame%20I%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%20lastRcvdIframeInfo.seqNo%3A0x1nx_mw%20%3ADEBUG%3AData%5B0%5D%3D0x1%20len%3D18%20Data%5B17%5D%3D0x91%20Data%5B18%5D%3D0x0%20nx_mw%20%3ADEBUG%3A%20phNxpEse_Transceive%20%E7%B5%82%E4%BA%86%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%200x0%20nx_mw%20%3ADEBUG%3AAPDU%20Rx%26lt%3B%20(Len%3D18)%2001%2000%200C%20FF%203F%2030%203F%2000%207A%200B%209B%20FC%2058%203F%20DC%20CD%2091%2000%20nx_mw%20%3ADEBUG%3AFN%3A%20nx_DeCrypt%20nx_mw%20%3ADEBUG%3A%20%E5%85%A5%E5%8A%9B%3ArspBuf%20(Len%3D18)%2001%2000%200C%20FF%203F%2030%203F%2000%207A%200B%209B%20FC%2058%203F%20DC%20CD%2091%2000%20nx_mw%20%3ADEBUG%3AMac%20%E6%A4%9C%E8%A8%BC%E6%B8%88%E3%81%BF%3A%20(Len%3D16)%2009%207A%2096%200B%2006%209B%20E5%20FC%205B%2058%2013%203F%20CD%20DC%2018%20CD%20nx_mw%20%3ADEBUG%3A%E5%BF%9C%E7%AD%94%E3%82%92%E5%BE%A9%E5%8F%B7%E5%8C%96%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20(Len%3D10)%2001%2000%200C%20FF%203F%2030%203F%2000%2091%2000%20APDU%20%3ADEBUG%3AManageCARootKey%20%5B%5D%20APDU%20%3ADEBUG%3A%20%5BKeyNo%5D%20%3D%200x0%20APDU%20%3ADEBUG%3A%20%5BcurveID%5D%20%3D%200xC%20APDU%20%3ADEBUG%3A%20%5BaccessRight(LSB)%5D%20%3D%200x3FFF%20APDU%20%3ADEBUG%3A%20%5BwriteAccessCond%5D%20%3D%200x30%20APDU%20%3ADEBUG%3A%20%5BreadAccessCond%5D%20%3D%200x3F%20APDU%20%3ADEBUG%3A%20%5BReserved%5D%20%3D%200x0%20APDU%20%3ADEBUG%3A%20%5B%E5%85%AC%E9%96%8B%E9%8D%B5%5D%20(Len%3D65)%2004%20C2%203A%20B7%20F3%20EB%207E%20CD%20F9%204E%201C%2043%20B2%208B%200C%202F%2049%20C9%2061%2035%20A1%204A%20E0%2058%20BC%20A9%20FE%20F9%204D%2018%20D4%2046%2028%20C1%202F%208D%2000%205B%20C4%208C%20C4%2002%2074%2086%2090%2042%2075%20AE%2055%2096%200B%2023%20C7%206E%2096%20EF%2096%2080%2027%2004%202A%2016%207D%20E5%20AD%20APDU%20%3ADEBUG%3A%20%5BCA%20%E3%82%B5%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E5%90%8D%20Len%5D%20%3D%200x64%20APDU%20%3ADEBUG%3A%20%5BCA%20%E7%99%BA%E8%A1%8C%E8%80%85%E5%90%8D%5D%20(Len%3D100)%2030%2062%2031%200B%2030%2009%2006%2003%2055%2004%2006%2013%2002%204E%204C%2031%2012%2030%2010%2006%2003%2055%2004%2008%200C%2009%2045%2069%206E%2064%2068%206F%2076%2065%206E%2031%2012%2030%2010%2006%2003%2055%2004%2007%200C%2009%2045%2069%206E%2064%2068%206F%2076%2065%206E%2031%200C%2030%200A%2006%2003%2055%2004%200A%200C%2003%204E%2058%2050%2031%201D%2030%201B%2006%2003%2055%2004%2003%200C%2014%204E%2058%2050%2020%2041%2075%2074%2068%2020%2052%206F%206F%2074%2043%2041%2076%2045%2032%2030%2031%20nx_mw%20%3ADEBUG%3A%20%E5%85%A5%E5%8A%9B%3A%E3%83%8D%E3%82%A4%E3%83%86%E3%82%A3%E3%83%96%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%B3%E3%83%BC%E3%83%89%20(Len%3D1)%2048%20nx_mw%20%3ADEBUG%3A%20%E5%85%A5%E5%8A%9B%3A%E3%83%8D%E3%82%A4%E3%83%86%E3%82%A3%E3%83%96%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%20(Len%3D7)%2000%200C%20FF%203F%2030%203F%2000%20nx_mw%20%3ADEBUG%3A%20%E5%85%A5%E5%8A%9B%3A%E3%83%8D%E3%82%A4%E3%83%86%E3%82%A3%E3%83%96%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%87%E3%83%BC%E3%82%BF%20(Len%3D166)%2004%20C2%203A%20B7%20F3%20EB%207E%20CD%20F9%204E%201C%2043%20B2%208B%200C%202F%2049%20C9%2061%2035%20A1%204A%20E0%2058%20BC%20A9%20FE%20F9%204D%2018%20D4%2046%2028%20C1%202F%208D%2000%205B%20C4%208C%20C4%2002%2074%2086%2090%2042%2075%20AE%2055%2096%200B%2023%20C7%206E%2096%20EF%2096%2080%2027%2004%202A%2016%207D%20E5%20AD%2064%2030%2062%2031%200B%2030%2009%2006%2003%2055%2004%2006%2013%2002%204E%204C%2031%2012%2030%2010%2006%2003%2055%2004%2008%200C%2009%2045%2069%206E%2064%2068%206F%2076%2065%206E%2031%2012%2030%2010%2006%2003%2055%2004%2007%200C%2009%2045%2069%206E%2064%2068%206F%2076%2065%206E%2031%200C%2030%200A%2006%2003%2055%2004%200A%200C%2003%204E%2058%2050%2031%201D%2030%201B%2006%2003%2055%2004%2003%200C%2014%204E%2058%2050%2020%2041%2075%2074%2068%2020%2052%206F%206F%2074%2043%2041%2076%2045%2032%2030%2031%20nx_mw%20%3ADEBUG%3AFN%3A%20nx_AES_EV2_Encrypt_CommandAPDU%20nx_mw%20%3ADEBUG%3AFN%3A%20nx_PadCommandAPDU%20nx_mw%20%3ADEBUG%3AInput%3A%20cmdApduBuf%20(Len%3D176)%2004%20C2%203A%20B7%20F3%20EB%207E%20CD%20F9%204E%201C%2043%20B2%208B%200C%202F%2049%20C9%2061%2035%20A1%204A%20E0%2058%20BC%20A9%20FE%20F9%204D%2018%20D4%2046%2028%20C1%202F%208D%2000%205B%20C4%208C%20C4%2002%2074%2086%2090%2042%2075%20AE%2055%2096%200B%2023%20C7%206E%2096%20EF%2096%2080%2027%2004%202A%2016%207D%20E5%20AD%2064%2030%2062%2031%200B%2030%2009%2006%2003%2055%2004%2006%2013%2002%204E%204C%2031%2012%2030%2010%2006%2003%2055%2004%2008%200C%2009%2045%2069%206E%2064%2068%206F%2076%2065%206E%2031%2012%2030%2010%2006%2003%2055%2004%2007%200C%2009%2045%2069%206E%2064%2068%206F%2076%2065%206E%2031%200C%2030%200A%2006%2003%2055%2004%200A%200C%2003%204E%2058%2050%2031%201D%2030%201B%2006%2003%2055%2004%2003%200C%2014%204E%2058%2050%2020%2041%2075%2074%2068%2020%2052%206F%206F%2074%2043%2041%2076%2045%2032%2030%2031%2080%2000%2000%2000%2000%2000%2000%2000%2000%2000%20nx_mw%20%3ADEBUG%3AFN%3A%20nx_AES_EV2_MAC_CommandAPDU%20nx_mw%20%3ADEBUG%3A%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%20%3D%202%20nx_mw%20%3ADEBUG%3AAPDU%20Tx%26gt%3B%20(Len%3D197)%2090%2048%2000%2000%20BF%2000%200C%20FF%203F%2030%203F%2000%20F5%20AE%201D%2020%20C9%203C%20EA%204A%20A7%206D%2067%203E%201D%20E5%2079%206B%20D7%20C1%2091%2023%2004%209E%2000%2052%200A%20F5%20DA%2093%208F%2083%20D0%201E%20EC%2098%203B%2007%2030%20BE%2085%2097%2047%205A%208A%20CF%20CF%2052%2079%208F%20CC%20A0%2047%2006%20F8%206E%203B%20B9%20A9%20E5%20FB%2084%20FC%20F9%20F0%2019%200E%202A%20F4%2000%20C4%20F4%20C4%20BD%2056%20B9%2021%2003%20AC%2010%2090%20C8%20A1%20A3%203C%209C%2075%204E%2010%205A%20BD%20F8%20AA%202D%208E%20BA%20CB%2089%20CE%2004%2050%20F9%20CB%204E%20CF%2056%2045%20E2%20E4%20BF%20D9%20FF%20D4%20AA%2035%2081%202A%2032%20F4%20CB%20B3%20B3%20EE%20E1%20F0%20AB%2047%20A5%20DF%2095%208D%2043%20CA%206F%2005%2014%2036%20AE%2013%2073%201C%2029%20E7%20CE%20EB%2038%203E%2037%2020%2041%2095%20B1%20AD%2015%205A%201A%20D8%2089%2029%204F%209A%2048%209F%20AE%2013%20F8%2038%2003%20D3%20DB%2016%2099%20E3%200B%207F%2024%20E8%20C0%202E%20E1%2098%20E2%20D7%2011%20C7%20FB%2000%20nx_mw%20%3ADEBUG%3AEnter%20phNxpEseProto7816_Transceive%20nx_mw%20%3ADEBUG%3A%E9%80%81%E5%8F%97%E4%BF%A1%E3%83%87%E3%83%BC%E3%82%BF%20ptr%200x0x7ffff91ea760%20len%3A197%20nx_mw%20%3ADEBUG%3AI%20%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%20%E3%83%87%E3%83%BC%E3%82%BF%E9%95%B7%3A%20197%20%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9no%3A0%20nx_mw%3ADEBUG%3ATransceiveProcess%20nextTransceiveState%201%20nx_mw%3ADEBUG%3AphNxpEse_WriteFrame%20%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84..%20nx_mw%3ADEBUG%3ATX%20(axI2CWrite)%20%26gt%3B%20(Len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nx_mw%20%3ADEBUG%3ADone%20with%20rv%20%3D%200c%20nx_mw%20%3ADEBUG%3ARAW%20Tx%26gt%3B%20(Len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nx_mw%20%3ADEBUG%3AphNxpEse_read%20Enter%20..%20nx_mw%20%3ADEBUG%3AphPalEse_i2c_read%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E8%A6%81%E6%B1%82%202%20%E3%83%90%E3%82%A4%E3%83%88nx_mw%20%3ADEBUG%3Arv%20%E3%81%A7%E5%AE%8C%E4%BA%86%3D%200d%20nx_mw%3ADEBUG%3ARX%20(axI2CRead)%3A%20(Len%3D2)%2000%2000%20nx_mw%3ADEBUG%3A_i2c_read()%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%2013%20nx_mw%3ADEBUG%3A_i2c_read()%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%86%8D%E8%A9%A6%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%3A1!nx_mw%3ADEBUG%3Arv%20%3D%200d%20%E3%81%A7%E5%AE%8C%E4%BA%86%20nx_mw%3ADEBUG%3ARX%20(axI2CRead)%3A%20(Len%3D2)%2000%2000%20nx_mw%3ADEBUG%3A_i2c_read()%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%2013%20nx_mw%3ADEBUG%3A_i2c_read()%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%86%8D%E8%A9%A6%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%3A2!nx_mw%3ADEBUG%3Arv%20%3D%200d%20%E3%81%A7%E5%AE%8C%E4%BA%86%20nx_mw%3ADEBUG%3ARX%20(axI2CRead)%3A%20(Len%3D2)%2000%2000%20nx_mw%3ADEBUG%3A_i2c_read()%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%2013%20nx_mw%3ADEBUG%3A_i2c_read()%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%86%8D%E8%A9%A6%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%3A3%20!nx_mw%3ADEBUG%3Arv%20%3D%200d%20%E3%81%A7%E5%AE%8C%E4%BA%86%20nx_mw%3ADEBUG%3ARX%20(axI2CRead)%3A%20(Len%3D2)%2000%2000%20nx_mw%3ADEBUG%3A_i2c_read()%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%2013%20nx_mw%3ADEBUG%3A_i2c_read()%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%86%8D%E8%A9%A6%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%3A4%20!nx_mw%20%3ADEBUG%3Arv%20%3D%200c%20%E3%81%A7%E5%AE%8C%E4%BA%86%20nx_mw%20%3ADEBUG%3ARX%20(axI2CRead)%3A%20(Len%3D2)%2012%2000%20nx_mw%20%3ADEBUG%3AphNxpEse_readPacket%20HDR%20%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%20nx_mw%20%3ADEBUG%3AphNxpEse_readPacket%20SOF%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%20nx_mw%20%3ADEBUG%3AphPalEse_i2c_read%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E8%A6%81%E6%B1%82%202%20%E3%83%90%E3%82%A4%E3%83%88%20nx_mw%20%3ADEBUG%3Arv%20%3D%200c%20%E3%81%A7%E5%AE%8C%E4%BA%86%20nx_mw%20%3ADEBUG%3ARX%20(axI2CRead)%3A%20(Len%3D2)%2000%200A%20nx_mw%20%3ADEBUG%3Apoll_sof_chained_delay%20%E3%81%AE%E5%80%A4%E3%81%AF%200%20%E3%81%A7%E3%81%99%20nx_mw%20%3ADEBUG%3AphPalEse_i2c_read%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E8%A6%81%E6%B1%82%2012%20%E3%83%90%E3%82%A4%E3%83%88%20nx_mw%20%3ADEBUG%3Arv%20%3D%200c%20%E3%81%A7%E5%AE%8C%E4%BA%86%20nx_mw%20%3ADEBUG%3ARX%20(axI2CRead)%3A%20(Len%3D12)%2005%2098%20F4%2058%209A%201B%20FB%20D3%2091%2000%20FE%20D5%20nx_mw%20%3ADEBUG%3ARAW%20Rx%26lt%3B%20(Len%3D16)%2012%2000%2000%200A%2005%2098%20F4%2058%209A%201B%20FB%20D3%2091%2000%20FE%20D5%20nx_mw%20%3ADEBUG%3AphNxpEseProto7816_ProcessResponse%20p_data%20----%26gt%3B%200x55562b33cab0%20len%20----%26gt%3B%200x10%20nx_mw%20%3ADEBUG%3A%E5%8F%97%E4%BF%A1CRC%3A0xfed5%20%E8%A8%88%E7%AE%97%E3%81%95%E3%82%8C%E3%81%9FCRC%3A0xfed5%20nx_mw%20%3ADEBUG%3A%E5%86%8D%E8%A9%A6%E8%A1%8C%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%20%3D%200%20nx_mw%20%3ADEBUG%3AphNxpEseProto7816_DecodeFrame%20I%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E5%8F%97%E4%BF%A1%20nx_mw%20%3ADEBUG%3AphNxpEseProto7816_DecodeFrame%20I%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%20lastRcvdIframeInfo.seqNo%3A0x0nx_mw%20%3ADEBUG%3AData%5B0%5D%3D0x5%20len%3D10%20Data%5B9%5D%3D0x91%20Data%5B10%5D%3D0x0%20nx_mw%20%3ADEBUG%3A%20phNxpEse_Transceive%20%E7%B5%82%E4%BA%86%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%200x0%20nx_mw%20%3ADEBUG%3AAPDU%20Rx%26lt%3B%20(Len%3D10)%2005%2098%20F4%2058%209A%201B%20FB%20D3%2091%2000%20nx_mw%20%3ADEBUG%3AFN%3A%20nx_DeCrypt%20nx_mw%20%3ADEBUG%3A%20Input%3ArspBuf%20(Len%3D10)%2005%2098%20F4%2058%209A%201B%20FB%20D3%2091%2000%20nx_mw%20%3ADEBUG%3AMac%20%E6%A4%9C%E8%A8%BC%E6%B8%88%E3%81%BF%3A%20(Len%3D16)%2043%2005%2090%2098%20C4%20F4%201B%2058%2042%209A%201F%201B%2062%20FB%20EE%20D3%20nx_mw%3ADEBUG%3A%E5%BF%9C%E7%AD%94%E3%82%92%E5%BE%A9%E5%8F%B7%E5%8C%96%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20(Len%3D2)%2091%2000%20nx_mw%3ADEBUG%3A'%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fpi%2Fa30mw%2Fnxmw-main%2Fbinaries%2Fconfiguration%2Fcert_depth3_PKCS7_rev1'%20%E3%81%8B%E3%82%89%E3%81%AE%E8%A8%BC%E6%98%8E%E6%9B%B8%2F%E3%82%AD%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20(ENV%3DNX_AUTH_CERT_DIR)%20nx_mw%3ADEBUG%3A%E8%AA%AD%E3%81%BF%E5%8F%96%E3%81%A3%E3%81%9F%E6%96%87%E5%AD%97%E6%95%B0%20%3D%20500%20nx_mw%3AINFO%3A%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fpi%2Fa30mw%2Fnxmw-main%2Fbinaries%2Fconfiguration%2Fcert_depth3_PKCS7_rev1%2Fcert_and_key%2Fnist_p%2Fdevice_leaf_certificate.der%20%E3%81%8B%E3%82%89%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%20nx_mw%3ADEBUG%3A%E8%A8%BC%E6%98%8E%E6%9B%B8%2F%E3%82%AD%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99from%3A'%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fpi%2Fa30mw%2Fnxmw-main%2Fbinaries%2Fconfiguration%2Fcert_depth3_PKCS7_rev1'%20(ENV%3DNX_AUTH_CERT_DIR)%20nx_mw%20%3ADEBUG%3A%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%89%E3%82%8C%E3%81%9F%E6%96%87%E5%AD%97%E6%95%B0%20%3D%20121%20nx_mw%20%3AINFO%20%3A%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fpi%2Fa30mw%2Fnxmw-main%2Fbinaries%2Fconfiguration%2Fcert_depth3_PKCS7_rev1%2Fcert_and_key%2Fnist_p%2Fdevice_leaf_keypair.der%20%E3%81%8B%E3%82%89%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%BE%E3%81%99%20APDU%20%3ADEBUG%3AGetKeySettings%20%5BECCPrivateKeyList%5D%20APDU%20%3ADEBUG%3A%20%5B%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%5D%20%3D%200x1%20nx_mw%20%3ADEBUG%3A%E5%85%A5%E5%8A%9B%3A%E3%83%8D%E3%82%A4%E3%83%86%E3%82%A3%E3%83%96%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%20%E3%82%B3%E3%83%BC%E3%83%89%20(Len%3D1)%2045%20nx_mw%20%3ADEBUG%3A%E5%85%A5%E5%8A%9B%3A%E3%83%8D%E3%82%A4%E3%83%86%E3%82%A3%E3%83%96%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%20%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%20(Len%3D1)%2001%20nx_mw%20%3ADEBUG%3AFN%3A%20nx_AES_EV2_MAC_CommandAPDU%20nx_mw%20%3ADEBUG%3A%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%20%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%20%3D%203%20nx_mw%20%3ADEBUG%3AAPDU%20Tx%26gt%3B%20(Len%3D15)%2090%2045%2000%2000%2009%2001%2063%203C%20E6%2071%204F%2032%209A%20AE%2000%20nx_mw%20%3ADEBUG%3AEnter%20phNxpEseProto7816_Transceive%20nx_mw%20%3ADEBUG%3A%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B7%E3%83%BC%E3%83%96%20%E3%83%87%E3%83%BC%E3%82%BF%20%E3%83%9D%E3%82%A4%E3%83%B3%E3%82%BF%200x0x7ffff91e97f0%20len%3A15%20nx_mw%20%3ADEBUG%3AI%20%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%20%E3%83%87%E3%83%BC%E3%82%BF%20Len%3A%2015%20Seq.no%3A1%20nx_mw%20%3ADEBUG%3ATransceiveProcess%20nextTransceiveState%201%20nx_mw%20%3ADEBUG%3AphNxpEse_WriteFrame%20%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82nx_mw%20%3ADEBUG%3ATX%20(axI2CWrite)%20%26gt%3B%20(Len%3D21)%2021%2040%2000%200F%2090%2045%2000%2000%2009%2001%2063%203C%20E6%2071%204F%2032%209A%20AE%2000%201F%202E%20nx_mw%20%3ADEBUG%3Arv%20%3D%200c%20%E3%81%A7%E5%AE%8C%E4%BA%86%20nx_mw%20%3ADEBUG%3ARAW%20Tx%26gt%3B%20(Len%3D21)%2021%2040%2000%200F%2090%2045%2000%2000%2009%2001%2063%203C%20E6%2071%204F%2032%209A%20AE%2000%201F%202E%20nx_mw%3ADEBUG%3AphNxpEse_read%20%E3%82%92%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82nx_mw%3ADEBUG%3AphPalEse_i2c_read%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E8%A6%81%E6%B1%82%E3%81%AF%202%20%E3%83%90%E3%82%A4%E3%83%88%E3%81%A7%E3%81%99%E3%80%82nx_mw%3ADEBUG%3Arv%20%3D%200d%20%E3%81%A7%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82nx_mw%3ADEBUG%3ARX%20(axI2CRead)%3A%20(Len%3D2)%2000%2000%20nx_mw%3ADEBUG%3A_i2c_read()%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%2013%20nx_mw%3ADEBUG%3A_i2c_read()%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%86%8D%E8%A9%A6%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%3A1!nx_mw%20%3ADEBUG%3Arv%20%3D%200c%20%E3%81%A7%E5%AE%8C%E4%BA%86%20nx_mw%20%3ADEBUG%3ARX%20(axI2CRead)%3A%20(Len%3D2)%2012%2040%20nx_mw%20%3ADEBUG%3AphNxpEse_readPacket%20HDR%20%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%20nx_mw%20%3ADEBUG%3AphNxpEse_readPacket%20SOF%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%20nx_mw%20%3ADEBUG%3AphPalEse_i2c_read%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E8%A6%81%E6%B1%82%202%20%E3%83%90%E3%82%A4%E3%83%88%20nx_mw%20%3ADEBUG%3Arv%20%3D%200c%20%E3%81%A7%E5%AE%8C%E4%BA%86%20nx_mw%20%3ADEBUG%3ARX%20(axI2CRead)%3A%20(Len%3D2)%2000%203F%20nx_mw%20%3ADEBUG%3Apoll_sof_chained_delay%20%E3%81%AE%E5%80%A4%E3%81%AF%200%20%E3%81%A7%E3%81%99%20nx_mw%20%3ADEBUG%3AphPalEse_i2c_read%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E8%A6%81%E6%B1%82%2065%20%E3%83%90%E3%82%A4%E3%83%88%20nx_mw%20%3ADEBUG%3Arv%20%3D%200c%20%E3%81%A7%E5%AE%8C%E4%BA%86%20nx_mw%20%3ADEBUG%3ARX%20(axI2CRead)%3A%20(Len%3D65)%2004%2000%200C%2004%2000%2030%2000%2000%2000%2000%2000%2000%2000%2000%2002%200C%2030%2000%2030%2000%2000%2000%2000%2000%2000%2000%2000%2000%2003%200D%2004%2000%2030%2000%2000%2000%2000%2000%2000%2000%2000%2004%200C%2008%2000%2030%2000%2000%2000%2000%2000%2000%2000%2000%2000%2094%208F%2021%20C9%20D4%2042%2097%201C%2091%2000%2061%2071%20nx_mw%20%3ADEBUG%3ARAW%20Rx%26lt%3B%20(%E9%95%B7%E3%81%95%3D69)%2012%2040%2000%203F%2004%2000%200C%2004%2000%2030%2000%2000%2000%2000%2000%2000%2000%2000%2002%200C%2030%2000%2030%2000%2000%2000%2000%2000%2000%2000%2000%2000%2003%200D%2004%2000%2030%2000%2000%2000%2000%2000%2000%2000%2000%2004%200C%2008%2000%2030%2000%2000%2000%2000%2000%2000%2000%2000%2000%2094%208F%2021%20C9%20D4%2042%2097%201C%2091%2000%2061%2071%20nx_mw%20%3ADEBUG%3AphNxpEseProto7816_ProcessResponse%20p_data%20----%26gt%3B%200x55562b33cab0%20len%20----%26gt%3B%200x45%20nx_mw%20%3ADEBUG%3A%E5%8F%97%E4%BF%A1CRC%3A0x6171%20%E8%A8%88%E7%AE%97%E3%81%95%E3%82%8C%E3%81%9FCRC%3A0x6171%20nx_mw%20%3ADEBUG%3A%E5%86%8D%E8%A9%A6%E8%A1%8C%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%20%3D%200%20nx_mw%20%3ADEBUG%3AphNxpEseProto7816_DecodeFrame%20I%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20nx_mw%20%3ADEBUG%3AphNxpEseProto7816_DecodeFrame%20I%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%20lastRcvdIframeInfo.seqNo%3A0x1nx_mw%20%3ADEBUG%3AData%5B0%5D%3D0x4%20len%3D63%20Data%5B62%5D%3D0x91%20Data%5B63%5D%3D0x0%20nx_mw%20%3ADEBUG%3A%20phNxpEse_Transceive%20%E7%B5%82%E4%BA%86%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%200x0%20nx_mw%20%3ADEBUG%3AAPDU%20Rx%26lt%3B%20(Len%3D63)%2004%2000%200C%2004%2000%2030%2000%2000%2000%2000%2000%2000%2000%2000%2002%200C%2030%2000%2030%2000%2000%2000%2000%2000%2000%2000%2000%2003%200D%2004%2000%2030%2000%2000%2000%2000%2000%2000%2000%2000%2004%200C%2008%2000%2030%2000%2000%2000%2000%2000%2000%2000%2000%2000%2094%208F%2021%20C9%20D4%2042%2097%201C%2091%2000%20nx_mw%20%3ADEBUG%3AFN%3A%20nx_DeCrypt%20nx_mw%20%3ADEBUG%3A%20%E5%85%A5%E5%8A%9B%3ArspBuf%20(Len%3D63)%2004%2000%200C%2004%2000%2030%2000%2000%2000%2000%2000%2000%2000%2000%2002%200C%2030%2000%2030%2000%2000%2000%2000%2000%2000%2000%2000%2003%200D%2004%2000%2030%2000%2000%2000%2000%2000%2000%2000%2000%2004%200C%2008%2000%2030%2000%2000%2000%2000%2000%2000%2000%2000%2000%2094%208F%2021%20C9%20D4%2042%2097%201C%2091%2000%20nx_mw%20%3ADEBUG%3AMac%20%E6%A4%9C%E8%A8%BC%E6%B8%88%E3%81%BF%3A%20(Len%3D16)%20D0%2094%20C2%208F%2088%2021%204F%20C9%2010%20D4%20FE%2042%201B%2097%20B9%201C%20nx_mw%20%3ADEBUG%3A%E5%BF%9C%E7%AD%94%E3%82%92%E5%BE%A9%E5%8F%B7%E5%8C%96%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20(Len%3D55)%2004%2000%200C%2004%2000%2030%2000%2000%2000%2000%2000%2000%2000%2000%2002%200C%2030%2000%2030%2000%2000%2000%2000%2000%2000%2000%2000%2003%200D%2004%2000%2030%2000%2000%2000%2000%2000%2000%2000%2000%2004%200C%2008%2000%2030%2000%2000%2000%2000%2000%2000%2000%2000%2000%2091%2000%20APDU%3ADEBUG%3AManageKeyPair%5B%5D%20APDU%3ADEBUG%3A%5BKeyNo%5D%20%3D%200x0%20APDU%3ADEBUG%3A%5BOption%5D%20%3D%200x1%20APDU%3ADEBUG%3A%5BcurveID%5D%20%3D%200xC%20APDU%3ADEBUG%3A%5BKeyPolicy(LSB)%5D%20%3D%200x4%20APDU%3ADEBUG%3A%5BwriteAccessCond%5D%20%3D%200x30%20APDU%3ADEBUG%3A%5BKUCLimit(LSB)%5D%20%3D%200x0%20APDU%3ADEBUG%3A%5BPrivate%20key%5D%20(Len%3D32)%202F%200A%206C%208F%20AC%20A9%20E6%20E3%20B2%208D%20C1%2024%20F6%2039%20D3%209F%20E2%2083%2027%20C6%206B%2025%200C%2018%2075%20F0%202C%2094%208B%2015%20CC%2047%20nx_mw%20%3ADEBUG%3A%20%E5%85%A5%E5%8A%9B%3A%E3%83%8D%E3%82%A4%E3%83%86%E3%82%A3%E3%83%96%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%B3%E3%83%BC%E3%83%89%20(Len%3D1)%2046%20nx_mw%20%3ADEBUG%3A%20%E5%85%A5%E5%8A%9B%3A%E3%83%8D%E3%82%A4%E3%83%86%E3%82%A3%E3%83%96%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%20(Len%3D10)%2000%2001%200C%2004%2000%2030%2000%2000%2000%2000%20nx_mw%20%3ADEBUG%3A%20%E5%85%A5%E5%8A%9B%3A%E3%83%8D%E3%82%A4%E3%83%86%E3%82%A3%E3%83%96%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%87%E3%83%BC%E3%82%BF%20(Len%3D32)%202F%200A%206C%208F%20AC%20A9%20E6%20E3%20B2%208D%20C1%2024%20F6%2039%20D3%209F%20E2%2083%2027%20C6%206B%2025%200C%2018%2075%20F0%202C%2094%208B%2015%20CC%2047%20nx_mw%20%3ADEBUG%3AFN%3A%20nx_AES_EV2_Encrypt_CommandAPDU%20nx_mw%20%3ADEBUG%3AFN%3A%20nx_PadCommandAPDU%20nx_mw%20%3ADEBUG%3AInput%3A%20cmdApduBuf%20(Len%3D48)%202F%200A%206C%208F%20AC%20A9%20E6%20E3%20B2%208D%20C1%2024%20F6%2039%20D3%209F%20E2%2083%2027%20C6%206B%2025%200C%2018%2075%20F0%202C%2094%208B%2015%20CC%2047%2080%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%20nx_mw%20%3ADEBUG%3AFN%3A%20nx_AES_EV2_MAC_CommandAPDU%20nx_mw%20%3ADEBUG%3A%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%20%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%20%3D%204%20nx_mw%20%3ADEBUG%3AAPDU%20Tx%26gt%3B%20(Len%3D72)%2090%2046%2000%2000%2042%2000%2001%200C%2004%2000%2030%2000%2000%2000%2000%20A2%20B1%2030%206A%20AE%20CF%2030%2047%20D5%2096%20D7%20EB%2069%20EF%20DB%20A3%2066%208D%20F0%20B1%200F%20FD%203D%20FE%2042%2098%20DF%2073%2071%20EA%207D%2082%2098%20B6%2031%209E%20CE%20F0%20FF%208C%20D6%2014%2053%20D5%2022%2003%20CD%2078%20C9%20ED%2069%2098%2030%201A%20BF%20DA%2000%20nx_mw%20%3ADEBUG%3AEnter%20phNxpEseProto7816_Transceive%20nx_mw%20%3ADEBUG%3ATransceive%E3%83%87%E3%83%BC%E3%82%BF%E3%83%9D%E3%82%A4%E3%83%B3%E3%82%BF%200x0x7ffff91ea740%20len%3A72%20nx_mw%20%3ADEBUG%3AI%20%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%20%E3%83%87%E3%83%BC%E3%82%BF%E9%95%B7%E3%81%95%3A%2072%20%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%E3%80%82no%3A0%20nx_mw%3ADEBUG%3ATransceiveProcess%20nextTransceiveState%201%20nx_mw%3ADEBUG%3AphNxpEse_WriteFrame%20%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84..%20nx_mw%3ADEBUG%3ATX%20(axI2CWrite)%20%26gt%3B%20(Len%3D78)%2021%2000%2000%2048%2090%2046%2000%2000%2042%2000%2001%200C%2004%2000%2030%2000%2000%2000%2000%20A2%20B1%2030%206A%20AE%20CF%2030%2047%20D5%2096%20D7%20EB%2069%20EF%20DB%20A3%2066%208D%20F0%20B1%200F%20FD%203D%20FE%2042%2098%20DF%2073%2071%20EA%207D%2082%2098%20B6%2031%209E%20CE%20F0%20FF%208C%20D6%2014%2053%20D5%2022%2003%20CD%2078%20C9%20ED%2069%2098%2030%201A%20BF%20DA%2000%2068%20F3%20nx_mw%20%3ADEBUG%3Arv%20%3D%200c%20%E3%81%A7%E5%AE%8C%E4%BA%86%20nx_mw%20%3ADEBUG%3ARAW%20Tx%26gt%3B%20(Len%3D78)%2021%2000%2000%2048%2090%2046%2000%2000%2042%2000%2001%200C%2004%2000%2030%2000%2000%2000%2000%20A2%20B1%2030%206A%20AE%20CF%2030%2047%20D5%2096%20D7%20EB%2069%20EF%20DB%20A3%2066%208D%20F0%20B1%200F%20FD%203D%20FE%2042%2098%20DF%2073%2071%20EA%207D%2082%2098%20B6%2031%209E%20CE%20F0%20FF%208C%20D6%2014%2053%20D5%2022%2003%20CD%2078%20C9%20ED%2069%2098%2030%201A%20BF%20DA%2000%2068%20F3%20nx_mw%20%3ADEBUG%3AphNxpEse_read%20%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99..%20nx_mw%20%3ADEBUG%3AphPalEse_i2c_read%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E8%A6%81%E6%B1%82%202%20%E3%83%90%E3%82%A4%E3%83%88%20nx_mw%20%3ADEBUG%3Arv%20%3D%200d%20%E3%81%A7%E5%AE%8C%E4%BA%86%20nx_mw%20%3ADEBUG%3ARX%20(axI2CRead)%3A%20(Len%3D2)%2000%2000%20nx_mw%20%3ADEBUG%3A_i2c_read()%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%2013%20nx_mw%20%3ADEBUG%3A_i2c_read()%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%86%8D%E8%A9%A6%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%3A1!nx_mw%3ADEBUG%3Arv%20%3D%200d%20%E3%81%A7%E5%AE%8C%E4%BA%86%20nx_mw%3ADEBUG%3ARX%20(axI2CRead)%3A%20(Len%3D2)%2000%2000%20nx_mw%3ADEBUG%3A_i2c_read()%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%2013%20nx_mw%3ADEBUG%3A_i2c_read()%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%86%8D%E8%A9%A6%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%3A2!nx_mw%3ADEBUG%3Arv%20%3D%200d%20%E3%81%A7%E5%AE%8C%E4%BA%86%20nx_mw%3ADEBUG%3ARX%20(axI2CRead)%3A%20(Len%3D2)%2000%2000%20nx_mw%3ADEBUG%3A_i2c_read()%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%2013%20nx_mw%3ADEBUG%3A_i2c_read()%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%86%8D%E8%A9%A6%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%3A3%20!nx_mw%3ADEBUG%3Arv%20%3D%200d%20%E3%81%A7%E5%AE%8C%E4%BA%86%20nx_mw%3ADEBUG%3ARX%20(axI2CRead)%3A%20(Len%3D2)%2000%2000%20nx_mw%3ADEBUG%3A_i2c_read()%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%2013%20nx_mw%3ADEBUG%3A_i2c_read()%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%86%8D%E8%A9%A6%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%3A4%20!nx_mw%3ADEBUG%3Arv%20%3D%200d%20%E3%81%A7%E5%AE%8C%E4%BA%86%20nx_mw%3ADEBUG%3ARX%20(axI2CRead)%3A%20(Len%3D2)%2000%2000%20nx_mw%3ADEBUG%3A_i2c_read()%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%2013%20nx_mw%3ADEBUG%3A_i2c_read()%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%86%8D%E8%A9%A6%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%3A5%20!nx_mw%3ADEBUG%3Arv%20%3D%200d%20%E3%81%A7%E5%AE%8C%E4%BA%86%20nx_mw%3ADEBUG%3ARX%20(axI2CRead)%3A%20(Len%3D2)%2000%2000%20nx_mw%3ADEBUG%3A_i2c_read()%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%2013%20nx_mw%3ADEBUG%3A_i2c_read()%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%86%8D%E8%A9%A6%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%3A6!nx_mw%20%3ADEBUG%3Arv%20%3D%200c%20%E3%81%A7%E5%AE%8C%E4%BA%86%20nx_mw%20%3ADEBUG%3ARX%20(axI2CRead)%3A%20(Len%3D2)%2012%2000%20nx_mw%20%3ADEBUG%3AphNxpEse_readPacket%20HDR%20%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%20nx_mw%20%3ADEBUG%3AphNxpEse_readPacket%20SOF%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%20nx_mw%20%3ADEBUG%3AphPalEse_i2c_read%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E8%A6%81%E6%B1%82%202%20%E3%83%90%E3%82%A4%E3%83%88%20nx_mw%20%3ADEBUG%3Arv%20%3D%200c%20%E3%81%A7%E5%AE%8C%E4%BA%86%20nx_mw%20%3ADEBUG%3ARX%20(axI2CRead)%3A%20(Len%3D2)%2000%200A%20nx_mw%20%3ADEBUG%3Apoll_sof_chained_delay%20%E3%81%AE%E5%80%A4%E3%81%AF%200%20%E3%81%A7%E3%81%99%20nx_mw%20%3ADEBUG%3AphPalEse_i2c_read%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E8%A6%81%E6%B1%82%2012%20%E3%83%90%E3%82%A4%E3%83%88%20nx_mw%20%3ADEBUG%3Arv%20%3D%200c%20%E3%81%A7%E5%AE%8C%E4%BA%86%20nx_mw%20%3ADEBUG%3ARX%20(axI2CRead)%3A%20(Len%3D12)%207F%208B%2020%2025%20EA%2016%2035%20E6%2091%2000%2086%20F6%20nx_mw%20%3ADEBUG%3ARAW%20Rx%26lt%3B%20(Len%3D16)%2012%2000%2000%200A%207F%208B%2020%2025%20EA%2016%2035%20E6%2091%2000%2086%20F6%20nx_mw%20%3ADEBUG%3AphNxpEseProto7816_ProcessResponse%20p_data%20----%26gt%3B%200x55562b33cab0%20len%20----%26gt%3B%200x10%20nx_mw%20%3ADEBUG%3A%E5%8F%97%E4%BF%A1CRC%3A0x86f6%20%E8%A8%88%E7%AE%97%E3%81%95%E3%82%8C%E3%81%9FCRC%3A0x86f6%20nx_mw%20%3ADEBUG%3A%E5%86%8D%E8%A9%A6%E8%A1%8C%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%20%3D%200%20nx_mw%20%3ADEBUG%3AphNxpEseProto7816_DecodeFrame%20I%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E5%8F%97%E4%BF%A1%20nx_mw%20%3ADEBUG%3AphNxpEseProto7816_DecodeFrame%20I%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%20lastRcvdIframeInfo.seqNo%3A0x0nx_mw%20%3ADEBUG%3AData%5B0%5D%3D0x7f%20len%3D10%20Data%5B9%5D%3D0x91%20Data%5B10%5D%3D0x0%20nx_mw%20%3ADEBUG%3A%20phNxpEse_Transceive%20%E7%B5%82%E4%BA%86%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%200x0%20nx_mw%20%3ADEBUG%3AAPDU%20Rx%26lt%3B%20(Len%3D10)%207F%208B%2020%2025%20EA%2016%2035%20E6%2091%2000%20nx_mw%20%3ADEBUG%3AFN%3A%20nx_DeCrypt%20nx_mw%20%3ADEBUG%3A%20Input%3ArspBuf%20(Len%3D10)%207F%208B%2020%2025%20EA%2016%2035%20E6%2091%2000%20nx_mw%20%3ADEBUG%3AMac%20%E6%A4%9C%E8%A8%BC%E6%B8%88%E3%81%BF%3A%20(Len%3D16)%2028%207F%2086%208B%20E1%2020%206F%2025%20BE%20EA%20C1%2016%201B%2035%20B5%20E6%20nx_mw%20%3ADEBUG%3A%E5%BF%9C%E7%AD%94%E3%82%92%E5%BE%A9%E5%8F%B7%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20(Len%3D2)%2091%2000%20APDU%20%3ADEBUG%3AGetConfiguration%20%5B%E8%A8%BC%E6%98%8E%E6%9B%B8%E3%83%9E%E3%83%8D%E3%82%B8%E3%83%A1%E3%83%B3%E3%83%88%5D%20APDU%20%3ADEBUG%3A%20%5B%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%5D%20%3D%200x13%20nx_mw%20%3ADEBUG%3A%E5%85%A5%E5%8A%9B%3A%E3%83%8D%E3%82%A4%E3%83%86%E3%82%A3%E3%83%96%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%B3%E3%83%BC%E3%83%89%20(Len%3D1)%2065%20nx_mw%20%3ADEBUG%3A%E5%85%A5%E5%8A%9B%3A%E3%83%8D%E3%82%A4%E3%83%86%E3%82%A3%E3%83%96%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%20(Len%3D1)%2013%20nx_mw%20%3ADEBUG%3AFN%3A%20nx_AES_EV2_MAC_CommandAPDU%20nx_mw%20%3ADEBUG%3A%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%20%3D%205%20nx_mw%20%3ADEBUG%3AAPDU%20Tx%26gt%3B%20(Len%3D15)%2090%2065%2000%2000%2009%2013%20A2%2019%2025%209F%2028%20A9%2067%20A0%2000%20nx_mw%20%3ADEBUG%3A%20phNxpEseProto7816_Transceive%20nx_mw%20%E3%82%92%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3ADEBUG%3A%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B7%E3%83%BC%E3%83%96%20%E3%83%87%E3%83%BC%E3%82%BF%20ptr%200x0x7ffff91ea0c0%20len%3A15%20nx_mw%20%3ADEBUG%3A%20I%20%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%20%E3%83%87%E3%83%BC%E3%82%BF%20Len%3A%2015%20Seq.no%3A1%20nx_mw%20%3ADEBUG%3ATransceiveProcess%20nextTransceiveState%201%20nx_mw%20%3ADEBUG%3AphNxpEse_WriteFrame%20%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82nx_mw%20%3ADEBUG%3ATX%20(axI2CWrite)%20%26gt%3B%20(Len%3D21)%2021%2040%2000%200F%2090%2065%2000%2000%2009%2013%20A2%2019%2025%209F%2028%20A9%2067%20A0%2000%207A%207F%20nx_mw%20%3ADEBUG%3Arv%20%3D%200c%20%E3%81%A7%E5%AE%8C%E4%BA%86%20nx_mw%20%3ADEBUG%3ARAW%20Tx%26gt%3B%20(Len%3D21)%2021%2040%2000%200F%2090%2065%2000%2000%2009%2013%20A2%2019%2025%209F%2028%20A9%2067%20A0%2000%207A%207F%20nx_mw%3ADEBUG%3AphNxpEse_read%20%E3%82%92%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82nx_mw%3ADEBUG%3AphPalEse_i2c_read%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E8%A6%81%E6%B1%82%E3%81%AF%202%20%E3%83%90%E3%82%A4%E3%83%88%E3%81%A7%E3%81%99%E3%80%82nx_mw%3ADEBUG%3Arv%20%3D%200d%20%E3%81%A7%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82nx_mw%3ADEBUG%3ARX%20(axI2CRead)%3A%20(Len%3D2)%2000%2000%20nx_mw%3ADEBUG%3A_i2c_read()%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%2013%20nx_mw%3ADEBUG%3A_i2c_read()%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%86%8D%E8%A9%A6%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%3A1!nx_mw%20%3ADEBUG%3Arv%20%3D%200c%20%E3%81%A7%E5%AE%8C%E4%BA%86%20nx_mw%20%3ADEBUG%3ARX%20(axI2CRead)%3A%20(Len%3D2)%2012%2040%20nx_mw%20%3ADEBUG%3AphNxpEse_readPacket%20HDR%20%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%20nx_mw%20%3ADEBUG%3AphNxpEse_readPacket%20SOF%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%20nx_mw%20%3ADEBUG%3AphPalEse_i2c_read%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E8%A6%81%E6%B1%82%202%20%E3%83%90%E3%82%A4%E3%83%88%20nx_mw%20%3ADEBUG%3Arv%20%3D%200c%20%E3%81%A7%E5%AE%8C%E4%BA%86%20nx_mw%20%3ADEBUG%3ARX%20(axI2CRead)%3A%20(Len%3D2)%2000%201A%20nx_mw%20%3ADEBUG%3Apoll_sof_chained_delay%20%E3%81%AE%E5%80%A4%E3%81%AF%200%20%E3%81%A7%E3%81%99%20nx_mw%20%3ADEBUG%3AphPalEse_i2c_read%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E8%A6%81%E6%B1%82%2028%20%E3%83%90%E3%82%A4%E3%83%88%20nx_mw%20%3ADEBUG%3ADone%20with%20rv%20%3D%200c%20nx_mw%20%3ADEBUG%3ARX%20(axI2CRead)%3A%20(Len%3D28)%202E%207F%20BE%2071%2008%203B%202B%20FF%2046%20F0%202B%20E5%2066%2016%20DA%2032%20F7%2034%2039%20B6%204D%20EA%20C7%20D7%2091%2000%20BB%20AF%20nx_mw%20%3ADEBUG%3ARAW%20Rx%26lt%3B%20(Len%3D32)%2012%2040%2000%201A%202E%207F%20BE%2071%2008%203B%202B%20FF%2046%20F0%202B%20E5%2066%2016%20DA%2032%20F7%2034%2039%20B6%204D%20EA%20C7%20D7%2091%2000%20BB%20AF%20nx_mw%20%3ADEBUG%3AphNxpEseProto7816_ProcessResponse%20p_data%20----%26gt%3B%200x55562b33cab0%20len%20----%26gt%3B%200x20%20nx_mw%20%3ADEBUG%3ACRC%E5%8F%97%E4%BF%A1%3A0xbbaf%20%E8%A8%88%E7%AE%97%E3%81%95%E3%82%8C%E3%81%9FCRC%3A0xbbaf%20nx_mw%20%3ADEBUG%3A%E5%86%8D%E8%A9%A6%E8%A1%8C%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%20%3D%200%20nx_mw%20%3ADEBUG%3AphNxpEseProto7816_DecodeFrame%20I%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E5%8F%97%E4%BF%A1%20nx_mw%20%3ADEBUG%3AphNxpEseProto7816_DecodeFrame%20I%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%20lastRcvdIframeInfo.seqNo%3A0x1nx_mw%20%3ADEBUG%3AData%5B0%5D%3D0x2e%20len%3D26%20Data%5B25%5D%3D0x91%20Data%5B26%5D%3D0x0%20nx_mw%20%3ADEBUG%3A%20phNxpEse_Transceive%20%E7%B5%82%E4%BA%86%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%200x0%20nx_mw%20%3ADEBUG%3AAPDU%20Rx%26lt%3B%20(Len%3D26)%202E%207F%20BE%2071%2008%203B%202B%20FF%2046%20F0%202B%20E5%2066%2016%20DA%2032%20F7%2034%2039%20B6%204D%20EA%20C7%20D7%2091%2000%20nx_mw%20%3ADEBUG%3AFN%3A%20nx_DeCrypt%20nx_mw%20%3ADEBUG%3A%20%E5%85%A5%E5%8A%9B%3ArspBuf%20(Len%3D26)%202E%207F%20BE%2071%2008%203B%202B%20FF%2046%20F0%202B%20E5%2066%2016%20DA%2032%20F7%2034%2039%20B6%204D%20EA%20C7%20D7%2091%2000%20nx_mw%20%3ADEBUG%3AMac%20%E3%81%8C%E6%A4%9C%E8%A8%BC%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%20(Len%3D16)%2098%20F7%2045%2034%205C%2039%2081%20B6%20E5%204D%205F%20EA%2056%20C7%20C2%20D7%20nx_mw%20%3ADEBUG%3A%E5%BF%9C%E7%AD%94%E3%82%92%E5%BE%A9%E5%8F%B7%E5%8C%96%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20(Len%3D6)%2005%2004%2008%2010%2091%2000%20APDU%20%3ADEBUG%3AManageCertRepo%20%5BCreateCertRepo%5D%20APDU%20%3ADEBUG%3A%20%5Baction%5D%20%3D%200x0%20APDU%20%3ADEBUG%3A%20%5BrepoID%5D%20%3D%200x0%20APDU%20%3ADEBUG%3A%20%5Bcert%20private%20keyID%5D%20%3D%200x0%20APDU%20%3ADEBUG%3A%20%5BrepoSize(LSB)%5D%20%3D%200xC00%20APDU%20%3ADEBUG%3A%20%5BwriteAccess%5D%20%3D%200x30%20APDU%20%3ADEBUG%3A%20%5BreadAccess%5D%20%3D%200x30%20nx_mw%20%3ADEBUG%3A%20%E5%85%A5%E5%8A%9B%3A%E3%83%8D%E3%82%A4%E3%83%86%E3%82%A3%E3%83%96%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%B3%E3%83%BC%E3%83%89%20(Len%3D1)%2049%20nx_mw%20%3ADEBUG%3A%20%E5%85%A5%E5%8A%9B%3A%E3%83%8D%E3%82%A4%E3%83%86%E3%82%A3%E3%83%96%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%20(Len%3D7)%2000%2000%2000%2000%200C%2030%2030%20nx_mw%20%3ADEBUG%3AFN%3A%20nx_AES_EV2_MAC_CommandAPDU%20nx_mw%20%3ADEBUG%3A%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%20%3D%206%20nx_mw%20%3ADEBUG%3AAPDU%20Tx%26gt%3B%20(Len%3D21)%2090%2049%2000%2000%200F%2000%2000%2000%2000%200C%2030%2030%2021%2050%2044%201A%2000%20AA%2084%20A7%2000%20nx_mw%20%3ADEBUG%3AEnter%20phNxpEseProto7816_Transceive%20nx_mw%20%3ADEBUG%3A%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B7%E3%83%BC%E3%83%96%20%E3%83%87%E3%83%BC%E3%82%BF%20ptr%200x0x7ffff91eaf20%20len%3A21%20nx_mw%20%3ADEBUG%3AI%20%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%20%E3%83%87%E3%83%BC%E3%82%BF%20Len%3A%2021%20Seq.no%3A0%20nx_mw%20%3ADEBUG%3ATransceiveProcess%20nextTransceiveState%201%20nx_mw%20%3ADEBUG%3AphNxpEse_WriteFrame%20%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82nx_mw%20%3ADEBUG%3ATX%20(axI2CWrite)%20%26gt%3B%20(Len%3D27)%2021%2000%2000%2015%2090%2049%2000%2000%200F%2000%2000%2000%2000%200C%2030%2030%2021%2050%2044%201A%2000%20AA%2084%20A7%2000%20FA%2077%20nx_mw%20%3ADEBUG%3Arv%20%3D%200c%20%E3%81%A7%E5%AE%8C%E4%BA%86%20nx_mw%20%3ADEBUG%3ARAW%20Tx%26gt%3B%20(Len%3D27)%2021%2000%2000%2015%2090%2049%2000%2000%200F%2000%2000%2000%2000%200C%2030%2030%2021%2050%2044%201A%2000%20AA%2084%20A7%2000%20FA%2077%20nx_mw%20%3ADEBUG%3AphNxpEse_read%20Enter%20..%20nx_mw%20%3ADEBUG%3AphPalEse_i2c_read%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E8%A6%81%E6%B1%82%202%20%E3%83%90%E3%82%A4%E3%83%88%20nx_mw%20%3ADEBUG%3ADone%20with%20rv%20%3D%200c%20nx_mw%20%3ADEBUG%3ARX%20(axI2CRead)%3A%20(Len%3D2)%2012%2000%20nx_mw%20%3ADEBUG%3AphNxpEse_readPacket%20HDR%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%20nx_mw%20%3ADEBUG%3AphNxpEse_readPacket%20SOF%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%20nx_mw%20%3ADEBUG%3AphPalEse_i2c_read%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E8%A6%81%E6%B1%82%202%20%E3%83%90%E3%82%A4%E3%83%88%20nx_mw%20%3ADEBUG%3ADone%20with%20rv%20%3D%200c%20nx_mw%20%3ADEBUG%3ARX%20(axI2CRead)%3A%20(Len%3D2)%2000%2002%20nx_mw%20%3ADEBUG%3Apoll_sof_chained_delay%20%E5%80%A4%E3%81%AF%200%20%E3%81%A7%E3%81%99%20nx_mw%20%3ADEBUG%3AphPalEse_i2c_read%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E8%A6%81%E6%B1%82%204%20%E3%83%90%E3%82%A4%E3%83%88%20nx_mw%20%3ADEBUG%3Arv%20%3D%200c%20%E3%81%A7%E5%AE%8C%E4%BA%86%20nx_mw%20%3ADEBUG%3ARX%20(axI2CRead)%3A%20(Len%3D4)%2091%20DE%2037%20A7%20nx_mw%20%3ADEBUG%3ARAW%20Rx%26lt%3B%20(Len%3D8)%2012%2000%2000%2002%2091%20DE%2037%20A7%20nx_mw%20%3ADEBUG%3AphNxpEseProto7816_ProcessResponse%20p_data%20----%26gt%3B%200x55562b33cab0%20len%20----%26gt%3B%200x8%20nx_mw%20%3ADEBUG%3AReceived%20CRC%3A0x37a7%20%E8%A8%88%E7%AE%97%E3%81%95%E3%82%8C%E3%81%9FCRC%3A0x37a7%20nx_mw%20%3ADEBUG%3A%E5%86%8D%E8%A9%A6%E8%A1%8C%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%20%3D%200%20nx_mw%20%3ADEBUG%3AphNxpEseProto7816_DecodeFrame%20I%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20nx_mw%20%3ADEBUG%3AphNxpEseProto7816_DecodeFrame%20I%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%20lastRcvdIframeInfo.seqNo%3A0x0nx_mw%20%3ADEBUG%3AData%5B0%5D%3D0x91%20len%3D2%20Data%5B1%5D%3D0x91%20Data%5B2%5D%3D0xde%20nx_mw%20%3ADEBUG%3A%20phNxpEse_Transceive%20%E7%B5%82%E4%BA%86%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%200x0%20nx_mw%20%3ADEBUG%3AAPDU%20Rx%26lt%3B%20(Len%3D2)%2091%20DE%20nx_mw%20%3ADEBUG%3AFN%3A%20nx_DeCrypt%20nx_mw%20%3ADEBUG%3A%20Input%3ArspBuf%20(Len%3D2)%2091%20DE%20nx_mw%20%3AWARN%20%3AnxEnsure%3A'(ret%20%3D%3D%20SM_OK)%20%7C%7C%20(ret%20%3D%3D%20SM_OK_ALT)'%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E8%A1%8C%3A%203713%20%E9%96%A2%E6%95%B0%3A%20sss_nx_TXn_AES_EV2%20nx_mw%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20nx_ManageCertRepo_CreateCertRepo%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20nx_mw%3A%20%E8%AD%A6%E5%91%8A%3A%20nxEnsure%3A%20'status%20%3D%3D%20kStatus_SSS_Success'%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E8%A1%8C%3A812%20%E9%96%A2%E6%95%B0%3Anx_load_se_leaf_keypair_and_cert%20nx_mw%3A%E8%AD%A6%E5%91%8A%3AnxEnsure%3A'status%20%3D%3D%20kStatus_SSS_Success'%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E8%A1%8C%3A980%20%E9%96%A2%E6%95%B0%3Aex_sss_entry%20nx_mw%3AERROR%3Anx_Personalization%20%E3%81%AE%E4%BE%8B%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F!!!...%20nx_mw%3AINFO%3Aex_sss%20%E3%81%8C%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20nx_mw%3AERROR%3Aex_sss_entry%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20nx_mw%3ADEBUG%3Ai2c%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%203%20%E3%82%92%E9%96%89%E3%81%98%E3%81%BE%E3%81%99%E3%80%82%20nx_mw%3ADEBUG%3AphNxpEse_close%20-%20ESE%20%E3%82%B3%E3%83%B3%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20nx_mw%3AERROR%3A!ERROR!ret%20!%3D%200%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2047168%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Using%20correct%20ENV%20Variable%20with%20nx_personalization%20demo%20for%20A30%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2047168%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F241789%22%20target%3D%22_blank%22%3E%40Jansch%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%94%E8%AA%AC%E6%98%8E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%E6%AC%A1%E3%81%AE%20cmake%20%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%80%81%E3%82%88%E3%82%8A%E8%A9%B3%E7%B4%B0%E3%81%AA%E3%83%AD%E3%82%B0%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E-DNXMW_Log%3D%E8%A9%B3%E7%B4%B0%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%99%E3%81%A6%E3%81%8D%E3%81%AA%E4%B8%80%E6%97%A5%E3%82%92%E3%80%81%3CBR%20%2F%3E%E3%82%AB%E3%83%B3%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E---------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%E8%A8%98%EF%BC%9A%3CBR%20%2F%3E%20-%20%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%8C%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%B8%E3%81%AE%E5%9B%9E%E7%AD%94%E3%81%A7%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%80%8C%E6%AD%A3%E8%A7%A3%E3%81%A8%E3%81%97%E3%81%A6%E3%83%9E%E3%83%BC%E3%82%AF%E3%80%8D%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%EF%BC%81%3CBR%20%2F%3E%20-%20Thread%E3%81%AF%E6%9C%80%E5%BE%8C%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%8B%E3%82%897%E9%80%B1%E9%96%93%E3%83%95%E3%82%A9%E3%83%AD%E3%83%BC%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E4%BB%A5%E9%99%8D%E3%81%AE%E8%BF%94%E4%BF%A1%E3%81%AF%E7%84%A1%E8%A6%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E5%BE%8C%E3%81%BB%E3%81%A9%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%96%B0%E3%81%97%E3%81%84Thread%E3%82%92%E9%96%8B%E3%81%84%E3%81%A6%E3%80%81%E9%96%89%E3%81%98%E3%81%9FThread%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E---------------------------------------------------------------------------------%3C%2FP%3E%0A%3CDIV%20id%3D%22tinyMceEditorKan_Li_0%22%20class%3D%22mceNonEditable%20lia-copypaste-placeholder%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2047045%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Using%20correct%20ENV%20Variable%20with%20nx_personalization%20demo%20for%20A30%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2047045%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59276%22%20target%3D%22_blank%22%3E%40Kan_Li%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%AF%E3%81%84%E3%80%81%E3%81%9D%E3%81%AE%E9%80%9A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%E4%BB%96%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%87%E3%83%A2%E3%81%AF%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%80%81%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E6%96%B9%E6%B3%95%E3%82%92%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9F%E3%81%A0%E3%80%81SIGMA-I%20%E8%AA%8D%E8%A8%BC%E3%82%92%E6%A9%9F%E8%83%BD%E3%81%95%E3%81%9B%E3%82%8B%E3%81%AE%E3%81%AB%E8%8B%A6%E5%8A%B4%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ENX_AUTH_CERT_DIR%20%E3%81%AF%E3%80%81%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%204.1.1%20%E3%81%A7%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%83%BC%E3%82%92%E5%8F%82%E7%85%A7%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%80%8C%E3%83%8F%E3%83%BC%E3%83%89%E3%82%B3%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%9F%E8%A8%BC%E6%98%8E%E6%9B%B8%E3%81%AF%3C%2FP%3E%3CP%3Enx-mw-top%2F%E3%83%87%E3%83%A2%2Fnx%2Fnx_Personalization%2Fnx_Personalization.h%22%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E7%A7%81%E3%81%AE%E5%AE%9F%E9%9A%9B%E3%81%AE%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%AF%E6%AC%A1%E3%81%AE%E5%A0%B4%E6%89%80%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3A%3C%2FP%3E%3CP%3E~%2Fa30mw%2Fnxmw_main%2F%E3%83%87%E3%83%A2%2Fnx%2Fnx_Personalization%2Fnx_Personalization.h%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E7%A7%81%E3%81%AE%20NX_AUTH_CERT_DIR%20%E3%81%AE%E5%86%85%E5%AE%B9%E3%81%A7%E3%82%82%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%AE%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%82%92%E8%AA%BF%E3%81%B9%E3%81%A6%E3%81%BF%E3%82%8B%E3%81%A8%E3%80%81%E3%81%95%E3%81%BE%E3%81%96%E3%81%BE%E3%81%AA%E8%A8%BC%E6%98%8E%E6%9B%B8%E3%81%8C%E3%83%97%E3%83%AC%E3%83%BC%E3%83%B3%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%E3%81%A7%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E6%AD%A3%E5%B8%B8%E3%81%AE%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%94%E6%8C%A8%E6%8B%B6%3C%2FP%3E%3CP%3EJan%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2046864%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Using%20correct%20ENV%20Variable%20with%20nx_personalization%20demo%20for%20A30%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2046864%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F241789%22%20target%3D%22_blank%22%3E%40Jansch%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3Enxmw.pdf%20%E3%81%AE%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%202.5.3%20%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E6%AC%A1%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%A7%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%99%E3%81%AD%3F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Kan_Li_0-1739935828335.png%22%20style%3D%22width%3A%20655px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1739935828335.png%22%20style%3D%22width%3A%20655px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F324660iF7FC4F528A1DBE4D%2Fimage-dimensions%2F655x94%3Fv%3Dv2%22%20width%3D%22655%22%20height%3D%2294%22%20role%3D%22button%22%20title%3D%22Kan_Li_0-1739935828335.png%22%20alt%3D%22Kan_Li_0-1739935828335.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EKan_Li_0-1739935828335.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%204.1.1%20%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%80%81%E7%8B%AC%E8%87%AA%E3%81%AB%E5%AE%9A%E7%BE%A9%E3%81%97%E3%81%9F%20ENV%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%20Nx%20%E3%83%91%E3%83%BC%E3%82%BD%E3%83%8A%E3%83%A9%E3%82%A4%E3%82%BC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E4%BE%8B%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%E3%81%93%E3%81%AECASE%E3%81%AENX_AUTH_CERT_DIR%20%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F%E8%A9%B3%E3%81%97%E3%81%8F%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E4%BD%95%E3%81%8B%E8%AA%A4%E8%A7%A3%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%82%89%E3%80%81%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%99%E3%81%A6%E3%81%8D%E3%81%AA%E4%B8%80%E6%97%A5%E3%82%92%E3%80%81%3CBR%20%2F%3E%E3%82%AB%E3%83%B3%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E---------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%E8%A8%98%EF%BC%9A%3CBR%20%2F%3E%20-%20%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%8C%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%B8%E3%81%AE%E5%9B%9E%E7%AD%94%E3%81%A7%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%80%8C%E6%AD%A3%E8%A7%A3%E3%81%A8%E3%81%97%E3%81%A6%E3%83%9E%E3%83%BC%E3%82%AF%E3%80%8D%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%EF%BC%81%3CBR%20%2F%3E%20-%20Thread%E3%81%AF%E6%9C%80%E5%BE%8C%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%8B%E3%82%897%E9%80%B1%E9%96%93%E3%83%95%E3%82%A9%E3%83%AD%E3%83%BC%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E4%BB%A5%E9%99%8D%E3%81%AE%E8%BF%94%E4%BF%A1%E3%81%AF%E7%84%A1%E8%A6%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E5%BE%8C%E3%81%BB%E3%81%A9%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%96%B0%E3%81%97%E3%81%84Thread%E3%82%92%E9%96%8B%E3%81%84%E3%81%A6%E3%80%81%E9%96%89%E3%81%98%E3%81%9FThread%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E---------------------------------------------------------------------------------%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2046225%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Using%20correct%20ENV%20Variable%20with%20nx_personalization%20demo%20for%20A30%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2046225%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59276%22%20target%3D%22_blank%22%3E%40Kan_Li%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%3CBR%20%2F%3E%3CBR%20%2F%3E%E7%A7%81%E3%81%AFraspbian%E3%81%A7%E3%81%93%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81.bat%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%82%3CBR%20%2F%3E%E7%A7%81%E3%81%AF%20nxmw.pdf%20%E3%81%AE%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%202.5%20%E3%81%AB%E5%BE%93%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9D%E3%81%93%E3%81%A7%E3%81%AF%20nx_Personalization%20%E3%81%AE%E4%BE%8B%E3%81%8C%E5%8F%82%E7%85%A7%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3EENV%20%E5%A4%89%E6%95%B0%E3%82%92%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E6%AD%A3%E3%81%97%E3%81%8F%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%87%BA%E5%8A%9B%E3%81%AB%E3%82%82%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%BE%E3%81%A0%E3%81%A9%E3%81%93%E3%81%8B%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%BB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E6%AD%A3%E3%81%97%E3%81%8F%E9%96%8B%E3%81%84%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E6%AD%A3%E3%81%97%E3%81%84%E5%AF%BE%E7%A7%B0%E3%82%AD%E3%83%BC%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8F%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AB%20Linux%20%E3%81%A7%E7%95%B0%E3%81%AA%E3%82%8B%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%80%82%E3%82%88%E3%81%8F%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3Enx_mw%3AINFO%3A********************************%20%E6%B3%A8%E6%84%8F********************************************%20nx_mw%3AINFO%3A%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E6%9C%80%E4%B8%8A%E4%BD%8D%E8%A8%BC%E6%98%8E%E6%9B%B8%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%3A%20%2Ftmp%2Fconfiguration%2Fa30_hostcert_depth2_x509_rev3_nistp%2F%20nx_mw%3AINFO%3A%E3%81%93%E3%81%AE%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%20%E3%83%91%E3%82%B9%E3%82%92%E4%B8%8A%E6%9B%B8%E3%81%8D%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E7%92%B0%E5%A2%83%E5%A4%89%E6%95%B0%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3A%20nx_mw%3AINFO%3ANX_AUTH_CERT_DIR%3D..%5Cnx-mw-top%5Cbinaries%5Cconfiguration%5Ccert_depth3_PKCS7_rev1%20nx_mw%3AINFO%3A********************************************************************************%20nx_mw%3AINFO%3A%E8%A8%BC%E6%98%8E%E6%9B%B8%2F%E3%82%AD%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99from%3A'%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fpi%2Fa30mw%2Fnxmw-main%2Fbinaries%2Fconfiguration%2Fcert_depth3_PKCS7_rev1'%20(ENV%3DNX_AUTH_CERT_DIR)%20nx_mw%3AINFO%3A%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fpi%2Fa30mw%2Fnxmw-main%2Fbinaries%2Fconfiguration%2Fcert_depth3_PKCS7_rev1%2Fcert_and_key%2Fnist_p%2Fhost_root_certificate.der%E3%81%8B%E3%82%89%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82nx_mw%3AINFO%3A%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fpi%2Fa30mw%2Fnxmw-main%2Fbinaries%2Fconfiguration%2Fcert_depth3_PKCS7_rev1%2Fcert_and_key%2Fnist_p%2Fdevice_leaf_certificate.der%E3%81%8B%E3%82%89%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82nx_mw%3AINFO%3A%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fpi%2Fa30mw%2Fnxmw-main%2Fbinaries%2Fconfiguration%2Fcert_depth3_PKCS7_rev1%2Fcert_and_key%2Fnist_p%2Fdevice_leaf_keypair.der%20nx_mw%20%3AWARN%20%3AnxEnsure%3A'(ret%20%3D%3D%20SM_OK)%20%7C%7C%20(ret%20%3D%3D%20SM_OK_ALT)'%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E8%A1%8C%3A%203713%20%E9%96%A2%E6%95%B0%3A%20sss_nx_TXn_AES_EV2%20nx_mw%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20nx_ManageCertRepo_CreateCertRepo%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20nx_mw%3A%20%E8%AD%A6%E5%91%8A%3A%20nxEnsure%3A%20'status%20%3D%3D%20kStatus_SSS_Success'%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E8%A1%8C%3A812%20%E9%96%A2%E6%95%B0%3Anx_load_se_leaf_keypair_and_cert%20nx_mw%3A%E8%AD%A6%E5%91%8A%3AnxEnsure%3A'status%20%3D%3D%20kStatus_SSS_Success'%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E8%A1%8C%3A980%20%E9%96%A2%E6%95%B0%3Aex_sss_entry%20nx_mw%3AERROR%3Anx_Personalization%20%E3%81%AE%E4%BE%8B%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F!!!...%20nx_mw%3AINFO%3Aex_sss%20%E3%81%8C%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20nx_mw%3AERROR%3Aex_sss_entry%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20nx_mw%3AERROR%3A!ERROR!ret%20!%3D%200%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2046075%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Using%20correct%20ENV%20Variable%20with%20nx_personalization%20demo%20for%20A30%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2046075%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F241789%22%20target%3D%22_blank%22%3E%40Jansch%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%AF%E3%81%84%E3%80%81nx-mw-top%5Cbinaries%5Cconfiguration%5Ca30_hostcert_depth2_x509_rev3_nistp%20%E3%81%AE%E8%A8%BC%E6%98%8E%E6%9B%B8%E3%81%A8%E3%82%AD%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%20%3CSPAN%20data-teams%3D%22true%22%3EA30%20%E3%81%AE%E8%A8%BC%E6%98%8E%E6%9B%B8%E3%82%92%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%9E%E3%82%A4%E3%82%BA%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3CSPAN%3E%E3%81%9D%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E3%81%AF%E3%80%81bat%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20nxclitool_prov_host_root_cert%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%80%82%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81NXMW.pdf%20%E3%81%AE%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%202.1%E3%80%8CA30%2FNTAG_X_DNA%20%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%80%8D%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FSPAN%3E%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%99%E3%81%A6%E3%81%8D%E3%81%AA%E4%B8%80%E6%97%A5%E3%82%92%E3%80%81%3CBR%20%2F%3E%E3%82%AB%E3%83%B3%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E---------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%E8%A8%98%EF%BC%9A%3CBR%20%2F%3E%20-%20%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%8C%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%B8%E3%81%AE%E5%9B%9E%E7%AD%94%E3%81%A7%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%80%8C%E6%AD%A3%E8%A7%A3%E3%81%A8%E3%81%97%E3%81%A6%E3%83%9E%E3%83%BC%E3%82%AF%E3%80%8D%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%EF%BC%81%3CBR%20%2F%3E%20-%20Thread%E3%81%AF%E6%9C%80%E5%BE%8C%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%8B%E3%82%897%E9%80%B1%E9%96%93%E3%83%95%E3%82%A9%E3%83%AD%E3%83%BC%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E4%BB%A5%E9%99%8D%E3%81%AE%E8%BF%94%E4%BF%A1%E3%81%AF%E7%84%A1%E8%A6%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E5%BE%8C%E3%81%BB%E3%81%A9%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%96%B0%E3%81%97%E3%81%84Thread%E3%82%92%E9%96%8B%E3%81%84%E3%81%A6%E3%80%81%E9%96%89%E3%81%98%E3%81%9FThread%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E---------------------------------------------------------------------------------%3C%2FP%3E%0A%3CP%3E%3CLI-WRAPPER%3E%3C%2FLI-WRAPPER%3E%3C%2FP%3E%0A%3CP%3E%3CLI-WRAPPER%3E%3C%2FLI-WRAPPER%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
