Unable to Retrieve ECC Curve Details from SE050 using Plug & Trust Nano Package
11,257 次查看
krsuresh
Hi Team,
I am currently using the Plug & Trust Nano package to read the ECC curve details from the SE050.
However, I am consistently receiving zero values for the curve details, even though the function call returns a success status.
I have reviewed the APDU configuration and verified my setup based on the following NXP community discussion, but I did not find any issues:
https://community.nxp.com/t5/Secure-Authentication/Read-ECC-Curvelist-fails-when-SCP03-enabled/m-p/1...
Could you please advise on the possible cause of this issue and how I can correctly retrieve the ECC curve details from the SE050?
Environment details:
SE050 variant: SE050-C and SE050-F
Package: Plug & Trust Nano
SCP03 status: Enabled
Host platform: Raspberry Pi
Code Details:
status = Se05x_API_ReadECCurveList(&se05x_session, curveList, &curveListLen);
printf("curveListLen: %d\n", curveListLen);
if (status == SM_OK) {
printf("Supported ECC Curves:\n");
for (i = 0; i < curveListLen; i++) {
printf(" Curve ID: 0x%02X\n", curveList[i]);
} else {
printf("Failed to read curve list\n");
smStatus_t Se05x_API_ReadECCurveList(pSe05xSession_t session_ctx, uint8_t *data, size_t *pdataLen)
smStatus_t retStatus = SM_NOT_OK;
tlvHeader_t hdr = {{kSE05x_CLA, kSE05x_INS_READ, kSE05x_P1_CURVE, kSE05x_P2_LIST}};
size_t cmdbufLen = 0;
uint8_t *pCmdbuf = NULL;
int tlvRet = 0;
uint8_t *pRspbuf = NULL;
size_t rspbufLen = 0;
ENSURE_OR_GO_CLEANUP(session_ctx != NULL);
memset(session_ctx->apdu_buffer, 0, sizeof(session_ctx->apdu_buffer));
pCmdbuf = &session_ctx->apdu_buffer[0];
pRspbuf = &session_ctx->apdu_buffer[0];
rspbufLen = sizeof(session_ctx->apdu_buffer);
SMLOG_D("APDU - Se05x_API_ReadECCurveList [] \n");
retStatus = DoAPDUTxRx(session_ctx, &hdr, session_ctx->apdu_buffer, cmdbufLen, pRspbuf, &rspbufLen, 1);
if (retStatus == SM_OK) {
size_t rspIndex = 0;
tlvRet = tlvGet_u8buf(pRspbuf, &rspIndex, rspbufLen, kSE05x_TAG_1, data, pdataLen); /* */
if (0 != tlvRet) {
goto cleanup;
if ((rspIndex + 2) == rspbufLen) {
retStatus = (pRspbuf[rspIndex] << 8 | (pRspbuf[rspIndex + 1]));
if (retStatus == SM_ERR_ACCESS_DENIED_BASED_ON_POLICY) {
SMLOG_I("Denied to ReadECCurveList");
cleanup:
return retStatus;
Sureshkumar R
21 回复数
8,265 次查看
javierw
Hi NXP,
Appreciate if you could assist in the above enquiry.
Thanks.
11,000 次查看
krsuresh
Please find the APDU log details.
10,994 次查看
Kan_Li
Hi @krsuresh ,
Thanks for the info! have you tried the plain communication with SE050C? The log should be something like below:
Kan
10,989 次查看
krsuresh
Hi @Kan_Li,
Thank you for your prompt response.
Please find attached the APDU log details captured in open mode. I have observed that the Se05x_API_ReadECCurveList API returns a failure in open mode, whereas it executes successfully in secure mode.
Kindly review the provided details and advise if there are any steps or configurations I might have missed in the flow.
Build steps followed:
$ cmake ..
$ make
$ ./build/src/se05x_app
Sureshkumar R
10,970 次查看
krsuresh
Hi @Kan_Li,
While generating an ECC key pair, the Se05x_API_WriteECKey function returns 0x6985 on the SE050-C board.
The same code was working fine on this board previously, and it is still working correctly on the SE050-F board.
This issue occurred suddenly, and I am unable to determine the cause. Kindly help me to resolve this issue.
SE05x_ECCurve_t curveID = kSE05x_ECCurve_NIST_P256;
    status = Se05x_API_WriteECKey(
        &se05x_session, NULL, 0, keyID, curveID, NULL, 0, NULL, 0, kSE05x_INS_NA, kSE05x_KeyPart_Pair);
    if (status != SM_OK) {
        SMLOG_E("Error in Se05x_API_WriteECKey \n");
        return 1;
Sureshkumar R
10,936 次查看
Kan_Li
Hi @krsuresh ,
Thanks for the info! Have you modified the source code of nano package? Looks like your code is different from the code from the Github repo. Please kindly refer to https://github.com/NXPPlugNTrust/nano-package/blob/737b61c527d4145f6dc96db9b51e22a4067ca09c/lib/apdu... for details.
Kan
10,933 次查看
krsuresh
I have not made any code changes. I am using the older Plug & Trust package version v1.2.1 because, in the latest version, I am facing build issues when building with SCP03 mode (PLUGANDTRUST_SCP03) enabled.
The steps I followed to build in SCP mode are:
mkdir build && cd build
cmake -DPLUGANDTRUST_SCP03=ON ..
make
/usr/bin/ld: build/libse05x_lib.a(se05x_APDU_impl.c.o): in function `Se05x_API_SessionOpen':
se05x_APDU_impl.c:(.text+0x384): undefined reference to `Se05x_API_SCP03_CreateSession'
/usr/bin/ld: build/libse05x_lib.a(se05x_tlv.c.o): in function `DoAPDUTx':
se05x_tlv.c:(.text+0xe90): undefined reference to `Se05x_API_SCP03_Encrypt'
/usr/bin/ld: se05x_tlv.c:(.text+0xf0c): undefined reference to `Se05x_API_SCP03_Decrypt'
/usr/bin/ld: build/libse05x_lib.a(se05x_tlv.c.o): in function `DoAPDUTxRx':
se05x_tlv.c:(.text+0x11d0): undefined reference to `Se05x_API_SCP03_Encrypt'
/usr/bin/ld: se05x_tlv.c:(.text+0x1248): undefined reference to `Se05x_API_SCP03_Decrypt'
collect2: error: ld returned 1 exit status
make[2]: *** [CMakeFiles/ex_se05x_GetInfo.dir/build.make:114: ex_se05x_GetInfo] Error 1
make[1]: *** [CMakeFiles/Makefile2:100: CMakeFiles/ex_se05x_GetInfo.dir/all] Error 2
make: *** [Makefile:91: all] Error 2
The same issue is observed in both the older and the latest code versions, even when operating in open (non-SCP) mode.
./ex_se05x_sign
Se05x Sign Example !
Plug and Trust nano package - version: 1.5.4
I2C driver supports plain i2c-level commands.
Generate ecc key
SE05x Sign Example Failed !
./ex_se05x_sign
Plug and Trust nano package - version: 1.2.1
Generate ecc key
Sureshkumar R
10,929 次查看
krsuresh
Hi @Kan_Li.,
I believe this issue began after executing the kSE05x_ECCurve_NIST_P384/ kSE05x_ECCurve_NIST_P521 sample. Based on the Plug & Trust full package, the se05x_Minimal and se05x_GetInfo examples are functioning correctly; however, the ex_ecc and ex_ecc_rsa examples are failing. Could it be that the secure memory has been locked? I am still able to perform Se05x_API_WriteBinary operations using the Nano package.
Kindly advise if there is any option to perform a complete reset of the SE050 device.
Sureshkumar R
10,784 次查看
Kan_Li
Hi @krsuresh ,
I tried your code in the demo of ex_se05x_sign, and the result is good as expected, I tested it with OM-SE051ARD and raspberry Pi 3B+, Please kindly refer to the following for details.
Is it possible to use the latest version and try again? maybe you can also try to delete all the ECCurves and recreate the one you need before the test.
Kan
10,485 次查看
krsuresh
Hi @Kan_Li,
Thanks for the response.
I have two follow-up questions regarding ECC curve support in SE05x.
1) Curve list retrieval
As per your input, Se05x_API_ReadECCurveList() works fine in the latest code.
Now I am able to read the curve family list(like, NIST-P, Brainpool) correctly.
However, I still need clarification on how to get the exact supported ECC curves such as:
NIST-P192 (0x01)
NIST-P224 (0x02)
NIST-P256 (0x03)
NIST-P384 (0x04)
NIST-P521 (0x05)
Is there any API or recommended method to read the full list of specific curve IDs supported by the SE05x?
2) Key write failures
When I try to create or use curve NIST-P384, I get an error:
Se05x_API_CreateECCurve(&se05x_session, kSE05x_ECCurve_NIST_P384);
After this, all EC key write or key generation operations fail with:
Even if I switch back to kSE05x_ECCurve_NIST_P256, the issue persists.
Currently, I am unable to perform any write operations on both of my boards:
* OM-SE050ARD
* OM-SE050ARD-F
It seems that attempting P-384 has caused all key write operations to fail.
Could you please clarify:
* Does SE05x fully support NIST-P384?
* Why are all write operations failing even after switching back to P-256?
* Is there a way to reset or recover the SE05x to a known working state?
Sureshkumar R
10,390 次查看
krsuresh
Hi @Kan_Li,
As per the latest Nano package code, the se05x_crypto sample works correctly for NIST-P384, but all operations for NIST-P256 fail.
If I change to NIST-P384 (curveID = 4), does this mean the chip will no longer support NIST-P256?
* Is this expected behavior on SE05x when switching from P256 to P384?
* Is there a recommended procedure to recover NIST-P256 operations if NIST-P384 has been used?
Log details for se05x_crypto
Se05x crypto Example !
Establish Secure Channel to SE05x !
Created scp03 Session
Get Version ==>
Applet Version 3.6.0
ex_get_version, PASSED
ex_generate_nist256_key, FAILED
ex_set_get_nist256_key, FAILED
ex_nist256_sign_verify, FAILED
curveID = 4 already exists
ex_generate_nist384_key, PASSED
ex_set_get_nist384_key, PASSED
ex_nist384_sign_verify, PASSED
ex_set_certificate, PASSED
ex_ecdh, FAILED
ex_aes_ECB_NOPAD, PASSED
ex_aes_CBC_NOPAD, PASSED
ex_aes_CTR, PASSED
ex_nist256_sign_policy, FAILED
ex_read_attst_object, FAILED
Close i2c device 3.
SE05x crypto Example Success !
Sureshkumar R
10,385 次查看
Kan_Li
Hi @krsuresh ,
Is it possible to enable the debug log? You may enable this by modifying the prj.conf file with the following configurations:
CONFIG_LOG=y
CONFIG_PLUGANDTRUST_LOG_LEVEL_DBG=y
CONFIG_LOG_MODE_IMMEDIATE=y
Kan
10,375 次查看
krsuresh
Hi  @Kan_Li,
Thanks for the quick response.
I thought prj.conf was only used for Zephyr and not for Linux. For my Linux build, I enabled the debug logs using -DPLUGANDTRUST_DEBUG_LOGS=ON instead. The debug output is attached here for your reference.
Please let me know if there is any additional configuration needed.
Sureshkumar R
10,369 次查看
Kan_Li
Hi @krsuresh ,
Thanks but I could not find the attachment, would you please update your message with the new log?
Kan
10,269 次查看
krsuresh
Hi @Kan_Li
Please find the log details attached. I am unsure why the attachment is not displaying on your end, even though I have already included the log information here.
Log Details:
APDU Tx> :00 a4 04 00 10 a0 00 00 03 96 54 53 00 00 00 01 03 00 00 00 00 00
APDU Rx< :03 01 00 6f ff 01 0b 90 00
hostChallenge ==> :11 22 33 44 55 66 77 88
Sending GP Initialize Update Command !!!
APDU Tx> :80 50 0b 00 08 11 22 33 44 55 66 77 88
APDU Rx< :90 03 92 84 04 50 05 99 37 34 0b 03 00 49 87 9e 91 c8 8e a5 05 4e c7 68 e0 01 db cd fb 90 00
Output: keyDivData :90 03 92 84 04 50 05 99 37 34
Output: keyInfo :0b 03 00
Output: cardChallenge :49 87 9e 91 c8 8e a5 05
Output: cardCryptoGram :4e c7 68 e0 01 db cd fb
Set the Derviation data to generate Session ENC key
Output:scp03_session_enc_Key ==> :3b aa cc 97 b6 9a c8 67 81 1c 43 da 4b c8 50 ac
Set the Derviation data to generate Session MAC key
Output:scp03_session_mac_Key ==> :50 aa 3d e2 bd 41 13 f8 4f 99 4c e1 24 08 65 3d
Set the Derviation data to generate Session RMAC key
Output:scp03_session_rmac_Key ==> :b4 ab 4b 42 1a b5 47 8f 0e e9 47 36 9d 52 a1 8c
Output:cardCryptogram ==> :4e c7 68 e0 01 db cd fb fb 61 21 7c aa 3b c8 fd
cardCryptoGram ==> :4e c7 68 e0 01 db cd fb
CardCryptogram verified successfully...Calculate HostCryptogram
Output:hostCryptogram ==> :0d fd 88 98 2e f2 d9 18 93 36 df 2c 42 76 52 1c
Output: Calculated MAC ==> :35 2e 69 65 bc 68 58 32 22 ce aa fc 6c ef 60 80
Add calculated MAC Value to cmd DataSending GP External Authenticate Command !!!APDU Tx> :84 82 33 00 10 0d fd 88 98 2e f2 d9 18 35 2e 69 65 bc 68 58 32
APDU Rx< :90 00
Authentication Successful!!!
Get Version ==>
APDU - GetVersion []
SCP03: Encrypted Data ==> :84 04 00 20 08 f0 fa c1 18 c7 92 28 ea
APDU Tx> :84 04 00 20 08 f0 fa c1 18 c7 92 28 ea
APDU Rx< :b6 3b eb a7 99 31 df c8 8d 5b e9 5b 8d bd 8d 03 13 08 e8 34 6a c5 b6 0c 90 00
SCP03: RMAC verified successfully...Decrypt Response Data
SCP03: Decrypted Data ==> :41 82 00 07 03 01 00 6f ff 01 0b 90 00
Applet Version 3.1.0
APDU - CheckObjectExists []
APDU :DEBUG:kSE05x_TAG_1["object id"] = 0x7B0001F3
SCP03: Encrypted Data ==> :84 04 00 27 18 ed cb 0e b5 59 73 8e 7c d0 a2 27 f5 a4 93 f9 d0 1f 1f 2b 97 1f 55 b9 bb
APDU Tx> :84 04 00 27 18 ed cb 0e b5 59 73 8e 7c d0 a2 27 f5 a4 93 f9 d0 1f 1f 2b 97 1f 55 b9 bb
APDU Rx< :73 a3 2a 78 0b 78 a0 e3 09 07 f3 9e 25 bb 38 1b 6b 50 49 fa 36 fb f5 38 90 00
SCP03: Decrypted Data ==> :41 01 02 90 00
APDU - Se05x_API_CreateECCurve []
APDU :DEBUG:kSE05x_TAG_1["curve id"] = 0x3
SCP03: Encrypted Data ==> :84 01 0b 04 18 a9 e2 3c 38 29 44 85 c3 74 71 60 4d ed 0a a2 93 30 71 36 d7 0f 96 dd c2
APDU Tx> :84 01 0b 04 18 a9 e2 3c 38 29 44 85 c3 74 71 60 4d ed 0a a2 93 30 71 36 d7 0f 96 dd c2
APDU Rx< :84 2c c7 02 74 30 da dc 90 00
SCP03: Decrypted Data ==> :90 00
APDU - Se05x_API_SetECCurveParam []
APDU :DEBUG:kSE05x_TAG_2["ecCurveParam"] = 0x1
APDU :DEBUG:kSE05x_TAG_3["inputData"] :ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff fe ff ff ff ff 00 00 00 00 00 00 00 00 ff ff ff fc
SCP03: Encrypted Data ==> :84 01 0b 40 48 9d 8b bf 11 43 e1 fb 31 17 34 36 e2 5e 4f d1 bd e5 ee 66 37 98 c5 32 83 e0 cb fb 52 47 37 52 a8 dc 1f a5 08 a5 1d b0 2d 98 b2 17 2f 50 2c 61 1d 4e 87 64 57 80 99 e5 b2 a3 37 70 17 80 ad ae 7f 63 cf 10 85 92 8a 5b 04
APDU Tx> :84 01 0b 40 48 9d 8b bf 11 43 e1 fb 31 17 34 36 e2 5e 4f d1 bd e5 ee 66 37 98 c5 32 83 e0 cb fb 52 47 37 52 a8 dc 1f a5 08 a5 1d b0 2d 98 b2 17 2f 50 2c 61 1d 4e 87 64 57 80 99 e5 b2 a3 37 70 17 80 ad ae 7f 63 cf 10 85 92 8a 5b 04
APDU Rx< :69 85
Error in ex_se05x_create_curve
APDU :DEBUG:kSE05x_TAG_1["object id"] = 0x7B000223
SCP03: Encrypted Data ==> :84 04 00 27 18 fc d1 4c 76 77 1c 23 86 f4 0a e6 6c 74 40 74 f9 ac a8 25 20 16 28 3a 1a
APDU Tx> :84 04 00 27 18 fc d1 4c 76 77 1c 23 86 f4 0a e6 6c 74 40 74 f9 ac a8 25 20 16 28 3a 1a
APDU Rx< :08 5a fe 92 6c 33 d0 be 7b 6e 11 d8 b7 fe b4 d7 a5 53 5c f6 dc ae 3b 69 90 00
APDU - WriteECKey []
APDU :DEBUG:kSE05x_TAG_MAX_ATTEMPTS["maxAttempt"] = 0x0
APDU :DEBUG:kSE05x_TAG_2["curveID"] = 0x3
APDU :DEBUG:kSE05x_TAG_3["privKey"] :e4 ee 5f 99 d9 d8 37 8f 39 c2 c9 fd a9 12 5e a7 3f b8 fd 00 b5 19 e6 94 1e f1 34 75 8d 33 59 8a
APDU :DEBUG:kSE05x_TAG_4["pubKey"] :04 f2 24 bc 5e ea 74 28 a1 20 d3 d2 69 fe 22 f3 59 9c 20 33 a2 e0 cb 81 c2 ce a9 d6 d4 66 c3 68 f8 b6 a8 9c de 08 88 b5 49 cd ed 85 d3 b5 88 72 0a dc 26 32 b0 30 bf b1 67 d0 fd bc 89 e7 2b 9c c1
SCP03: Encrypted Data ==> :84 01 61 00 78 78 06 6e 6b 30 9d 1e 3a 1e 5e 5a 42 54 ef b4 04 17 db ab 49 3e e6 4a 90 29 64 13 73 2a bb 9e ce 27 f0 5d 04 4c 96 8b c6 cb e4 15 74 7a 75 97 35 08 c2 98 c0 3b 8f 6d fa 58 f8 f5 23 f6 f4 ca 96 8e 1b c3 f2 c3 c1 66 33 e9 24 e1 cd 83 ca a1 47 5d d6 e5 fb c0 ec e8 52 d0 c0 7f b6 32 fb e1 75 ab d4 36 38 ba a6 8a 06 15 1b d4 13 a9 e8 f7 6e cf c7 96 75 0a b7 54 82
APDU Tx> :84 01 61 00 78 78 06 6e 6b 30 9d 1e 3a 1e 5e 5a 42 54 ef b4 04 17 db ab 49 3e e6 4a 90 29 64 13 73 2a bb 9e ce 27 f0 5d 04 4c 96 8b c6 cb e4 15 74 7a 75 97 35 08 c2 98 c0 3b 8f 6d fa 58 f8 f5 23 f6 f4 ca 96 8e 1b c3 f2 c3 c1 66 33 e9 24 e1 cd 83 ca a1 47 5d d6 e5 fb c0 ec e8 52 d0 c0 7f b6 32 fb e1 75 ab d4 36 38 ba a6 8a 06 15 1b d4 13 a9 e8 f7 6e cf c7 96 75 0a b7 54 82
APDU Rx< :69 85
APDU :DEBUG:kSE05x_TAG_1["object id"] = 0x7B00025E
SCP03: Encrypted Data ==> :84 04 00 27 18 96 34 9b ee 76 9f 60 d1 08 4f 46 41 e8 df 1c 24 f5 d3 71 f5 b1 be cf 19
APDU Tx> :84 04 00 27 18 96 34 9b ee 76 9f 60 d1 08 4f 46 41 e8 df 1c 24 f5 d3 71 f5 b1 be cf 19
APDU Rx< :d5 3f d5 a4 87 54 fa fe 1e cf e7 14 b9 19 21 ef cd 48 6f f4 c5 d5 0c ff 90 00
SCP03: Encrypted Data ==> :84 81 61 00 18 15 b7 bf a6 af 1a 00 63 b7 37 d1 c7 cb 14 70 31 ae 07 63 b6 01 be cf b1
APDU Tx> :84 81 61 00 18 15 b7 bf a6 af 1a 00 63 b7 37 d1 c7 cb 14 70 31 ae 07 63 b6 01 be cf b1
APDU Rx< :69 85
SCP03: Encrypted Data ==> :84 02 0b 25 08 e3 fc c6 50 cd 1b 88 50
APDU Tx> :84 02 0b 25 08 e3 fc c6 50 cd 1b 88 50
APDU Rx< :55 49 93 04 25 48 e5 02 b4 45 9a 75 98 40 2c a7 bd 22 8c 24 62 23 33 12 f8 a1 52 93 5b c4 34 32 19 f2 3c 1e e5 a8 82 a4 90 00
SCP03: Decrypted Data ==> :41 82 00 11 01 01 02 02 02 01 02 01 01 01 01 01 01 01 01 02 01 90 00
APDU :DEBUG:kSE05x_TAG_1["object id"] = 0x7B0002EF
SCP03: Encrypted Data ==> :84 04 00 27 18 d1 b6 cc 45 d1 7d ac 8d cb 3f c6 cb 45 48 00 6a c1 53 88 d8 a2 86 de 25
APDU Tx> :84 04 00 27 18 d1 b6 cc 45 d1 7d ac 8d cb 3f c6 cb 45 48 00 6a c1 53 88 d8 a2 86 de 25
APDU Rx< :f0 ff 7f 0d 5a ae 24 1d a5 01 6c 8e 22 a6 8a 43 f2 2d 86 29 f2 e8 6c 31 90 00
APDU :DEBUG:kSE05x_TAG_2["curveID"] = 0x4
SCP03: Encrypted Data ==> :84 01 61 00 18 be 74 54 b5 11 5d 57 12 d1 cf 85 61 10 d9 8a 51 61 15 b0 92 7a 91 7c ca
APDU Tx> :84 01 61 00 18 be 74 54 b5 11 5d 57 12 d1 cf 85 61 10 d9 8a 51 61 15 b0 92 7a 91 7c ca
APDU Rx< :be ac eb f1 87 4e e5 93 90 00
APDU - Se05x_API_DeleteSecureObject []
SCP03: Encrypted Data ==> :84 04 00 28 18 9c 5d 90 bf 78 d3 5f 13 d7 fc fa 20 23 9a 7f c1 37 61 f2 7c d3 3a a0 31
APDU Tx> :84 04 00 28 18 9c 5d 90 bf 78 d3 5f 13 d7 fc fa 20 23 9a 7f c1 37 61 f2 7c d3 3a a0 31
APDU Rx< :c3 e9 ab 19 4c 45 95 9e 90 00
APDU :DEBUG:kSE05x_TAG_1["object id"] = 0x7B00032F
SCP03: Encrypted Data ==> :84 04 00 27 18 0b 44 54 e9 70 89 ab 65 c9 bc 29 9b 79 f6 53 21 99 f6 44 e7 40 36 e6 da
APDU Tx> :84 04 00 27 18 0b 44 54 e9 70 89 ab 65 c9 bc 29 9b 79 f6 53 21 99 f6 44 e7 40 36 e6 da
APDU Rx< :81 d5 e6 69 21 05 7e 38 7e 30 90 6c 09 ad 30 ce 8d 36 dc 7c 3d 9f 2d 46 90 00
Sureshkumar R
10,028 次查看
Kan_Li
Hi @krsuresh ,
Thanks for the info! I can see  Se05x_API_SetECCurveParam had a 6985 error, which means the curve has already be set up , but might not set up correctly, so you can not set it up again , neither using it for create key pairs, so please remove this curve at first. and re-run the se05x_crypto demo.
Kan
9,998 次查看
krsuresh
Hi @Kan_Li,
Thank you for the information. I have attempted to remove the curve using Se05x_API_DeleteECCurve, but I am still encountering the same 0x6985 error.
Could you please confirm if this is the correct procedure to delete a curve, or if I am missing any steps? Please find attached the debug log for your reference.
status = Se05x_API_DeleteECCurve(session_ctx, kSE05x_ECCurve_NIST_P256);
SMLOG_E("Error in Se05x_API_DeleteECCurve \n");
return 1;
} else {
SMLOG_I("Curve Deleted Success.... \n");
status = ex_se05x_create_curve(session_ctx, curveID);
SMLOG_I("Error in ex_se05x_create_curve \n");
goto exit;
Log Details:
SCP03: Encrypted Data ==> :84 04 00 27 18 d3 f3 89 46 7d af 66 e8 67 09 59 27 f3 cb f8 35 b2 3f 88 79 c3 50 2d 3f
APDU Tx> :84 04 00 27 18 d3 f3 89 46 7d af 66 e8 67 09 59 27 f3 cb f8 35 b2 3f 88 79 c3 50 2d 3f
APDU Rx< :7b 78 12 39 41 5e 28 e6 ef 8f 93 9c 4b 79 aa 3d 91 a6 7c fe fd 2d 88 15 90 00
APDU - Se05x_API_DeleteECCurve []
SCP03: Encrypted Data ==> :84 04 0b 28 18 4d d7 f6 7c 76 5b c8 d8 70 bb 72 9d 7e f1 7c 59 ea 04 a3 4c c8 37 65 56
APDU Tx> :84 04 0b 28 18 4d d7 f6 7c 76 5b c8 d8 70 bb 72 9d 7e f1 7c 59 ea 04 a3 4c c8 37 65 56
APDU Rx< :17 58 65 57 b6 41 08 ca 90 00
SCP03: Encrypted Data ==> :84 01 0b 04 18 2c 27 d5 77 43 c8 76 d8 29 04 8b d9 66 d4 db 3e f8 a4 85 a1 26 8c 91 d4
APDU Tx> :84 01 0b 04 18 2c 27 d5 77 43 c8 76 d8 29 04 8b d9 66 d4 db 3e f8 a4 85 a1 26 8c 91 d4
APDU Rx< :bf c3 26 f8 16 8a e0 d0 90 00
SCP03: Encrypted Data ==> :84 01 0b 40 48 0b a5 d4 2e 76 eb 95 a5 b0 44 a3 51 ff 9e ec 9d 5f d5 3f c6 98 fc 7c cf 0f 80 e2 59 d6 7b a6 14 07 01 a3 df bb 86 8b 2a 0e d5 f3 4c f3 c9 6b 07 02 1c 77 83 6e 85 e1 f6 dd 9b 9c 4c 6d c8 69 3d a1 df d3 45 e1 dd 6d 7a
APDU Tx> :84 01 0b 40 48 0b a5 d4 2e 76 eb 95 a5 b0 44 a3 51 ff 9e ec 9d 5f d5 3f c6 98 fc 7c cf 0f 80 e2 59 d6 7b a6 14 07 01 a3 df bb 86 8b 2a 0e d5 f3 4c f3 c9 6b 07 02 1c 77 83 6e 85 e1 f6 dd 9b 9c 4c 6d c8 69 3d a1 df d3 45 e1 dd 6d 7a
APDU Rx< :69 85
APDU :DEBUG:kSE05x_TAG_1["object id"] = 0x7B00022C
SCP03: Encrypted Data ==> :84 04 00 27 18 94 09 fd ce 6b 42 04 6a f0 08 94 b7 b8 ff 23 63 08 c3 57 ed 9c 2f 1f 0b
APDU Tx> :84 04 00 27 18 94 09 fd ce 6b 42 04 6a f0 08 94 b7 b8 ff 23 63 08 c3 57 ed 9c 2f 1f 0b
APDU Rx< :be 03 06 02 b6 29 d7 d3 76 1b 10 bc 4a 6b 22 6b 83 8b f2 21 1b 48 67 e1 90 00
SCP03: Encrypted Data ==> :84 01 61 00 78 4b c2 7d c9 fc a3 f5 01 27 7c d2 8d d3 03 01 bd bf 56 c6 04 9f 7e 58 40 fa c3 13 67 b2 9a 0e 1e c6 22 a9 87 06 23 74 6c 46 b0 0b 1f 9a e8 eb f3 78 c8 c9 88 a1 d8 ca 71 20 eb 86 ca d8 86 85 13 51 ba bc 3d ed 99 5d 5e f3 ea 79 5c 64 5b 09 bf 0d e2 6a 8e b3 a7 61 c8 e3 0e b4 bf 18 af 56 13 5a e2 4b dc bf 8e f2 db 9c a5 1e 16 df f7 45 cd a0 21 1a 82 78 b3 9f e2
APDU Tx> :84 01 61 00 78 4b c2 7d c9 fc a3 f5 01 27 7c d2 8d d3 03 01 bd bf 56 c6 04 9f 7e 58 40 fa c3 13 67 b2 9a 0e 1e c6 22 a9 87 06 23 74 6c 46 b0 0b 1f 9a e8 eb f3 78 c8 c9 88 a1 d8 ca 71 20 eb 86 ca d8 86 85 13 51 ba bc 3d ed 99 5d 5e f3 ea 79 5c 64 5b 09 bf 0d e2 6a 8e b3 a7 61 c8 e3 0e b4 bf 18 af 56 13 5a e2 4b dc bf 8e f2 db 9c a5 1e 16 df f7 45 cd a0 21 1a 82 78 b3 9f e2
APDU Rx< :69 85
Sureshkumar R
9,926 次查看
Kan_Li
Hi @krsuresh ,
Looks like you are using the api to generate ECC curve for nist384 to generate ECC curve for nist256, but keep the ECC parameters the same, so lead to this error, you have to use the parameters for nist256 instead.
#define EC_PARAM_prime256v1_prime \
0xFF, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0x01, \
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, \
0x00, 0x00, 0x00, 0x00, 0xFF, 0xFF, 0xFF, 0xFF, \
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF
#define EC_PARAM_prime256v1_a \
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFC
#define EC_PARAM_prime256v1_b \
0x5A, 0xC6, 0x35, 0xD8, 0xAA, 0x3A, 0x93, 0xE7, \
0xB3, 0xEB, 0xBD, 0x55, 0x76, 0x98, 0x86, 0xBC, \
0x65, 0x1D, 0x06, 0xB0, 0xCC, 0x53, 0xB0, 0xF6, \
0x3B, 0xCE, 0x3C, 0x3E, 0x27, 0xD2, 0x60, 0x4B
#define EC_PARAM_prime256v1_x \
0x6B, 0x17, 0xD1, 0xF2, 0xE1, 0x2C, 0x42, 0x47, \
0xF8, 0xBC, 0xE6, 0xE5, 0x63, 0xA4, 0x40, 0xF2, \
0x77, 0x03, 0x7D, 0x81, 0x2D, 0xEB, 0x33, 0xA0, \
0xF4, 0xA1, 0x39, 0x45, 0xD8, 0x98, 0xC2, 0x96
#define EC_PARAM_prime256v1_y \
0x4F, 0xE3, 0x42, 0xE2, 0xFE, 0x1A, 0x7F, 0x9B, \
0x8E, 0xE7, 0xEB, 0x4A, 0x7C, 0x0F, 0x9E, 0x16, \
0x2B, 0xCE, 0x33, 0x57, 0x6B, 0x31, 0x5E, 0xCE, \
0xCB, 0xB6, 0x40, 0x68, 0x37, 0xBF, 0x51, 0xF5
#define EC_PARAM_prime256v1_order \
0xFF, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0x00, \
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, \
0xBC, 0xE6, 0xFA, 0xAD, 0xA7, 0x17, 0x9E, 0x84, \
0xF3, 0xB9, 0xCA, 0xC2, 0xFC, 0x63, 0x25, 0x51
#endif
Hope that helps,
Kan
9,827 次查看
krsuresh
Hi @Kan_Li,
Thank you for the clarification.
After applying the correct parameters, both the NIST256 and NIST384 ECC curves are now functioning as expected. Could you please provide the documentation or reference material related to the SetECCCurveParam procedure that you referred to? Having this information would help me better understand the required parameter settings and the underlying behavior.
Sureshkumar R
9,651 次查看
Kan_Li
Hi @krsuresh ,
Great to know this issue has been solved! I was referring to the full version of MW, and the definition of ECC curve parameters can be found in "C:\SE-PLUG-TRUST-MW_04.07.01\simw-top\hostlib\hostLib\inc\se05x_ecc_curves_values.h".
Hope that helps,
Kan
%3CLINGO-SUB%20id%3D%22lingo-sub-2201735%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A0%E6%B3%95%E4%BD%BF%E7%94%A8%20Plug%20%26amp%3B%20Trust%20Nano%20%E8%BD%AF%E4%BB%B6%E5%8C%85%E4%BB%8E%20SE050%20%E6%A3%80%E7%B4%A2%20ECC%20%E6%9B%B2%E7%BA%BF%E8%AF%A6%E7%BB%86%E4%BF%A1%E6%81%AF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2201735%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E5%9B%A2%E9%98%9F%E3%80%81%3C%2FP%3E%3CP%3E%E6%88%91%E7%9B%AE%E5%89%8D%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20Plug%20%26amp%3B%20Trust%20Nano%20%E4%BB%A3%E7%A0%81%E5%8C%85%E6%9D%A5%E8%AF%BB%E5%8F%96%20SE050%20%E4%B8%AD%E7%9A%84%20ECC%20%E6%9B%B2%E7%BA%BF%E7%BB%86%E8%8A%82%E3%80%82%3CBR%20%2F%3E%E7%84%B6%E8%80%8C%EF%BC%8C%E5%B0%BD%E7%AE%A1%E5%87%BD%E6%95%B0%E8%B0%83%E7%94%A8%E8%BF%94%E5%9B%9E%E4%BA%86%E6%88%90%E5%8A%9F%E7%8A%B6%E6%80%81%EF%BC%8C%E6%88%91%E5%8D%B4%E5%A7%8B%E7%BB%88%E6%94%B6%E5%88%B0%E6%9B%B2%E7%BA%BF%E7%BB%86%E8%8A%82%E7%9A%84%E9%9B%B6%E5%80%BC%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%9F%A5%E7%9C%8B%E4%BA%86%20APDU%20%E9%85%8D%E7%BD%AE%EF%BC%8C%E5%B9%B6%E6%A0%B9%E6%8D%AE%E4%BB%A5%E4%B8%8B%E6%81%A9%E6%99%BA%E6%B5%A6%E7%A4%BE%E5%8C%BA%E8%AE%A8%E8%AE%BA%E9%AA%8C%E8%AF%81%E4%BA%86%E6%88%91%E7%9A%84%E8%AE%BE%E7%BD%AE%EF%BC%8C%E4%BD%86%E6%B2%A1%E6%9C%89%E5%8F%91%E7%8E%B0%E4%BB%BB%E4%BD%95%E9%97%AE%E9%A2%98%EF%BC%9A%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FSecure-Authentication%2FRead-ECC-Curvelist-fails-when-SCP03-enabled%2Fm-p%2F1664562%3Fprofile.language%3Dzh-CN%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FSecure-Authentication%2FRead-ECC-Curvelist-fails-when-SCP03-enabled%2Fm-p%2F1664562%3Fprofile.language%3Dzh-CN%3C%2FA%3E%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%91%8A%E7%9F%A5%E5%87%BA%E7%8E%B0%E6%AD%A4%E9%97%AE%E9%A2%98%E7%9A%84%E5%8F%AF%E8%83%BD%E5%8E%9F%E5%9B%A0%EF%BC%8C%E4%BB%A5%E5%8F%8A%E6%88%91%E5%A6%82%E4%BD%95%E4%BB%8E%20SE050%20%E4%B8%AD%E6%AD%A3%E7%A1%AE%E6%A3%80%E7%B4%A2%20ECC%20%E6%9B%B2%E7%BA%BF%E7%9A%84%E8%AF%A6%E7%BB%86%E4%BF%A1%E6%81%AF%EF%BC%9F%3C%2FP%3E%3CP%3E%3CU%3E%3CSTRONG%3E%E7%8E%AF%E5%A2%83%E8%AF%A6%E6%83%85%EF%BC%9A%3C%2FSTRONG%3E%3C%2FU%3E%3C%2FP%3E%3CP%3ESE050%20%E5%8F%98%E4%BD%93%EF%BC%9ASE050-C%20%E5%92%8C%20SE050-F%20%3CBR%20%2F%3E%20%E4%BB%A3%E7%A0%81%E5%8C%85%EF%BC%9APlug%20%26amp%3B%20Trust%20Nano%20%3CBR%20%2F%3E%20SCP03%20%E7%8A%B6%E6%80%81%EF%BC%9A%E5%B7%B2%E5%90%AF%E7%94%A8%3CBR%20%2F%3E%E4%B8%BB%E6%9C%BA%E5%B9%B3%E5%8F%B0%EF%BC%9A%E6%A0%91%E8%8E%93%E6%B4%BE%3C%2FP%3E%3CP%3E%3CU%3E%3CSTRONG%3E%E4%BB%A3%E7%A0%81%E8%AF%A6%E6%83%85%EF%BC%9A%20%3C%2FSTRONG%3E%3C%2FU%3E%3C%2FP%3E%3CP%3Estatus%20%3D%20Se05x_API_ReadECCurveList(%26amp%3Bse05x_session%2C%20curveList%2C%26amp%3BcurveListLen)%3B%3CBR%20%2F%3Eprintf(%22curveListLen%3A%25d%5Cn%22%2C%20curveListLen)%3B%3CBR%20%2F%3Eif%20(status%20%3D%3D%20SM_OK)%20%7B%3CBR%20%2F%3Eprintf(%22Supported%20ECC%20Curves%EF%BC%9A%5Cn%22)%3B%3CBR%20%2F%3Efor%20(i%20%3D%200%3B%20i%26lt%3B%20curveListLen%3B%20i%2B%2B)%20%7B%3CBR%20%2F%3Eprintf(%22%20Curve%20ID%3A%200x%2502X%5Cn%22%2C%20curveList%5Bi%5D)%3B%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%7D%20else%20%7B%3CBR%20%2F%3Eprintf(%22Failed%20to%20read%20curve%20list%5Cn%22)%3B%3CBR%20%2F%3E%7D%3C%2FP%3E%3CP%3EsmStatus_t%20Se05x_API_ReadECCurveList(pSe05xSession_t%20session_ctx%2C%20uint8_t%20*data%2C%20size_t%20*pdataLen)%3CBR%20%2F%3E%7B%3CBR%20%2F%3EsmStatus_t%20retStatus%20%3D%20SM_NOT_OK%EF%BC%9B%3CBR%20%2F%3EtlvHeader_t%20hdr%20%3D%7B%7BkSE05x_CLA%2C%20kSE05x_INS_READ%2C%20kSE05x_P1_CURVE%2C%20kSE05x_P2_LIST%7D%7D%3B%3CBR%20%2F%3Esize_t%20cmdbufLen%20%3D%200%3B%3CBR%20%2F%3Euint8_t%20*pCmdbuf%20%3D%20NULL%3B%3CBR%20%2F%3Eint%20tlvRet%20%3D%200%3B%3CBR%20%2F%3Euint8_t%20*pRspbuf%20%3D%20NULL%3B%3CBR%20%2F%3Esize_t%20rspbufLen%20%3D%200%EF%BC%9B%3C%2FP%3E%3CP%3EENSURE_OR_GO_CLEANUP(session_ctx%20!%3D%20NULL)%EF%BC%9B%3C%2FP%3E%3CP%3Ememset(session_ctx-%26gt%3Bapdu_buffer%2C%200%2C%20sizeof(session_ctx-%26gt%3Bapdu_buffer))%EF%BC%9B%3C%2FP%3E%3CP%3EpCmdbuf%20%3D%26amp%3Bsession_ctx-%26gt%3Bapdu_buffer%5B0%5D%3B%3CBR%20%2F%3EpRspbuf%20%3D%26amp%3Bsession_ctx-%26gt%3Bapdu_buffer%5B0%5D%3B%3CBR%20%2F%3ErspbufLen%20%3D%20sizeof(session_ctx-%26gt%3Bapdu_buffer)%EF%BC%9B%3C%2FP%3E%3CP%3ESMLOG_D(%22APDU%20-%20Se05x_API_ReadECCurveList%20%5B%5D%20%5Cn%22)%EF%BC%9B%3C%2FP%3E%3CP%3EretStatus%20%3D%20DoAPDUTxRx(session_ctx%2C%26amp%3Bhdr%2C%20session_ctx-%26gt%3Bapdu_buffer%2C%20cmdbufLen%2C%20pRspbuf%2C%26amp%3BrspbufLen%2C%201)%EF%BC%9B%3CBR%20%2F%3E%3CBR%20%2F%3Eif%20(retStatus%20%3D%3D%20SM_OK)%20%7B%3CBR%20%2F%3Esize_t%20rspIndex%20%3D%200%3B%3CBR%20%2F%3EtlvRet%20%3D%20tlvGet_u8buf(pRspbuf%2C%26amp%3BrspIndex%2C%20rspbufLen%2C%20kSE05x_TAG_1%2C%20data%2C%20pdataLen)%3B%20%2F*%20*%2F%3CBR%20%2F%3Eif%20(0%20%EF%BC%81%3D%20tlvRet)%20%7B%3CBR%20%2F%3Egoto%20cleanup%3B%3CBR%20%2F%3E%7D%3CBR%20%2F%3Eif%20((rspIndex%20%2B%202)%20%3D%3D%20rspbufLen)%20%7B%3CBR%20%2F%3EretStatus%20%3D%20(pRspbuf%5BrspIndex%5D%26lt%3B%26lt%3B%208%20%7C%20(pRspbuf%5BrspIndex%20%2B%201%5D))%EF%BC%9B%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%7D%3CBR%20%2F%3Eif%20(retStatus%20%3D%3D%20SM_ERR_ACCESS_DENIED_BASED_ON_POLICY)%20%7B%3CBR%20%2F%3ESMLOG_I(%22Denied%20to%20ReadECCurveList%22)%3B%3CBR%20%2F%3E%7D%3C%2FP%3E%3CP%3E%E6%B8%85%E7%90%86%EF%BC%9A%3CBR%20%2F%3Ereturn%20retStatus%3B%3CBR%20%2F%3E%7D%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3ESureshkumar%20R%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2204972%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Unable%20to%20Retrieve%20ECC%20Curve%20Details%20from%20SE050%20using%20Plug%20%26amp%3B%20Trust%20Nano%20Package%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2204972%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F210184%22%20target%3D%22_blank%22%3E%40krsuresh%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%88%91%E7%94%A8%20OM-SE051ARD%20%E5%92%8C%20raspberry%20Pi%203B%2B%20%E6%B5%8B%E8%AF%95%E4%BA%86%E4%BD%A0%E5%9C%A8%20ex_se05x_sign%20%E6%BC%94%E7%A4%BA%E4%B8%AD%E4%BD%BF%E7%94%A8%E7%9A%84%E4%BB%A3%E7%A0%81%EF%BC%8C%E7%BB%93%E6%9E%9C%E4%B8%8E%E9%A2%84%E6%9C%9F%E7%9A%84%E4%B8%80%E6%A0%B7%E5%A5%BD%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Kan_Li_0-1763104753432.png%22%20style%3D%22width%3A%20689px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1763104753432.png%22%20style%3D%22width%3A%20689px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1763104753432.png%22%20style%3D%22width%3A%20689px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1763104753432.png%22%20style%3D%22width%3A%20689px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1763104753432.png%22%20style%3D%22width%3A%20689px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1763104753432.png%22%20style%3D%22width%3A%20689px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1763104753432.png%22%20style%3D%22width%3A%20689px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1763104753432.png%22%20style%3D%22width%3A%20689px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1763104753432.png%22%20style%3D%22width%3A%20689px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F365655i58978EA158A660D5%2Fimage-dimensions%2F689x455%3Fv%3Dv2%22%20width%3D%22689%22%20height%3D%22455%22%20role%3D%22button%22%20title%3D%22Kan_Li_0-1763104753432.png%22%20alt%3D%22Kan_Li_0-1763104753432.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E6%9C%80%E6%96%B0%E7%89%88%E6%9C%AC%E5%86%8D%E8%AF%95%E4%B8%80%E6%AC%A1%EF%BC%9F%E4%B9%9F%E8%AE%B8%E6%82%A8%E4%B9%9F%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%E5%88%A0%E9%99%A4%E6%89%80%E6%9C%89%20ECCurves%EF%BC%8C%E7%84%B6%E5%90%8E%E5%9C%A8%E6%B5%8B%E8%AF%95%E5%89%8D%E9%87%8D%E6%96%B0%E5%88%9B%E5%BB%BA%E6%82%A8%E9%9C%80%E8%A6%81%E7%9A%84%20ECCurves%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%A5%9D%E6%82%A8%E6%84%89%E5%BF%AB%EF%BC%8C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%3CBR%20%2F%3E-%20%E5%A6%82%E6%9E%9C%E6%9C%AC%E5%B8%96%E5%9B%9E%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%22%E6%A0%87%E8%AE%B0%E6%AD%A3%E7%A1%AE%22%20%E6%8C%89%E9%92%AE%E3%80%82%E8%B0%A2%E8%B0%A2%EF%BC%81%3CBR%20%2F%3E-%20%E6%88%91%E4%BB%AC%E4%BC%9A%E5%9C%A8%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E5%8F%91%E5%B8%96%E5%90%8E%E7%9A%84%207%20%E5%91%A8%E5%86%85%E8%B7%9F%E8%B8%AA%E4%B8%BB%E9%A2%98%EF%BC%8C%E4%B9%8B%E5%90%8E%E7%9A%84%E5%9B%9E%E5%A4%8D%E5%B0%86%E8%A2%AB%E5%BF%BD%E7%95%A5%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BB%A5%E5%90%8E%E6%9C%89%E7%9B%B8%E5%85%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E5%8F%A6%E5%BC%80%E6%96%B0%E4%B8%BB%E9%A2%98%EF%BC%8C%E5%B9%B6%E5%8F%82%E8%80%83%E5%B7%B2%E5%85%B3%E9%97%AD%E7%9A%84%E4%B8%BB%E9%A2%98%E3%80%82%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2203246%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Unable%20to%20Retrieve%20ECC%20Curve%20Details%20from%20SE050%20using%20Plug%20%26amp%3B%20Trust%20Nano%20Package%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2203246%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59276%22%20target%3D%22_blank%22%3E%40Kan_Li%3C%2FA%3E..%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E8%AE%A4%E4%B8%BA%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E6%98%AF%E5%9C%A8%E6%89%A7%E8%A1%8C%3CSTRONG%3EkSE05x_ECCurve_NIST_P384%2F%20kSE05x_ECCurve_NIST_P521%3C%2FSTRONG%3E%E6%A0%B7%E6%9C%AC%E5%90%8E%E5%87%BA%E7%8E%B0%E7%9A%84%E3%80%82%20%E5%9F%BA%E4%BA%8E%20Plug%20%26amp%3B%20Trust%20%E5%AE%8C%E6%95%B4%E4%BB%A3%E7%A0%81%E5%8C%85%EF%BC%8Cse05x_minimal%20%E5%92%8C%20se05x_GetInfo%3CSTRONG%3E%20%E7%A4%BA%E4%BE%8B%E8%BF%90%E8%A1%8C%E6%AD%A3%E5%B8%B8%EF%BC%9B%E4%BD%86%E6%98%AF%EF%BC%8Cex_ecc%3C%2FSTRONG%3E%20%E5%92%8C%3CSTRONG%3E%20ex_ecc_rsa%3C%2FSTRONG%3E%20%E7%A4%BA%E4%BE%8B%E5%A4%B1%E8%B4%A5%E4%BA%86%E3%80%82%E4%BC%9A%E4%B8%8D%E4%BC%9A%E6%98%AF%E5%AE%89%E5%85%A8%E5%AD%98%E5%82%A8%E5%99%A8%E8%A2%AB%E9%94%81%E5%AE%9A%E4%BA%86%EF%BC%9F%E6%88%91%E8%BF%98%E8%83%BD%E4%BD%BF%E7%94%A8%20Nano%20%E4%BB%A3%E7%A0%81%E5%8C%85%E6%89%A7%E8%A1%8C%20%3CSTRONG%3ESe05x_API_WriteBinary%3C%2FSTRONG%3E%20%E6%93%8D%E4%BD%9C%E3%80%82%3CBR%20%2F%3E%E8%AF%B7%E5%91%8A%E7%9F%A5%E6%98%AF%E5%90%A6%E6%9C%89%E4%BB%BB%E4%BD%95%E9%80%89%E9%A1%B9%E5%8F%AF%E4%BB%A5%E5%AF%B9%20SE050%20%E8%AE%BE%E5%A4%87%E8%BF%9B%E8%A1%8C%E5%AE%8C%E5%85%A8%20RESET%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3ESureshkumar%20R%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2203142%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Unable%20to%20Retrieve%20ECC%20Curve%20Details%20from%20SE050%20using%20Plug%20%26amp%3B%20Trust%20Nano%20Package%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2203142%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%E6%88%91%E6%B2%A1%E6%9C%89%E4%BF%AE%E6%94%B9%E4%BB%BB%E4%BD%95%E4%BB%A3%E7%A0%81%E3%80%82%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E8%BE%83%E6%97%A9%E7%9A%84%20Plug%20%26amp%3B%20Trust%20%E4%BB%A3%E7%A0%81%E5%8C%85%E7%89%88%E6%9C%AC%20v1.2.1%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%9C%A8%E6%9C%80%E6%96%B0%E7%89%88%E6%9C%AC%E4%B8%AD%EF%BC%8C%E6%88%91%E5%9C%A8%E5%90%AF%E7%94%A8%20SCP03%20%E6%A8%A1%E5%BC%8F%20(PLUGANDTRUST_SCP03)%20%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E8%BF%9B%E8%A1%8C%E6%9E%84%E5%BB%BA%E6%97%B6%E4%BC%9A%E9%81%87%E5%88%B0%E7%89%88%E6%9C%AC%E9%97%AE%E9%A2%98%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CU%3E%3CSTRONG%3E%E6%88%91%E5%9C%A8%20SCP%20%E6%A8%A1%E5%BC%8F%E4%B8%8B%E7%89%88%E6%9C%AC%E6%97%B6%E9%81%B5%E5%BE%AA%E7%9A%84%E6%AD%A5%E9%AA%A4%E6%98%AF%EF%BC%9A%3C%2FSTRONG%3E%3C%2FU%3E%3C%2FDIV%3E%3CDIV%3Emkdir%20%E7%89%88%E6%9C%AC%20%26amp%3B%26amp%3B%20cd%20%E7%89%88%E6%9C%AC%3C%2FDIV%3E%3CDIV%3Ecmake%20-DPLUGANDTRUST_SCP03%3DON%20.%3C%2FDIV%3E%3CDIV%3Emake%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%2Fusr%2Fbin%2Fld%EF%BC%9A%E7%89%88%E6%9C%AC%2Flibse05x_lib.a%20(se05x_apdu_impl.c.o)%EF%BC%9A%E5%9C%A8%E5%87%BD%E6%95%B0%20%60se05x_api_SessionOpen'%20%E4%B8%AD%EF%BC%9A%3C%2FDIV%3E%3CDIV%3Ese05x_APDU_impl.c%3A(.text%2B0x384)%EF%BC%9A%E5%AF%B9%20%E2%80%9Cse05x_api_scp03_createSession%E2%80%9D%20%E7%9A%84%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%8F%82%E8%80%83%3C%2FDIV%3E%3CDIV%3E%2Fusr%2Fbin%2Fld%EF%BC%9A%E7%89%88%E6%9C%AC%2Flibse05x_lib.a%20(se05x_tlv.c.o)%EF%BC%9A%E5%9C%A8%E5%87%BD%E6%95%B0%20%60doapdUTX'%20%E4%B8%AD%EF%BC%9A%3C%2FDIV%3E%3CDIV%3Ese05x_tlv.c%3A(.text%2B0xe90)%EF%BC%9A%E5%AF%B9%20%E2%80%9Cse05x_api_scp03_encrypt%E2%80%9D%20%E7%9A%84%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%8F%82%E8%80%83%3C%2FDIV%3E%3CDIV%3E%2Fusr%2Fbin%2Fld%3A%20se05x_tlv.c%3A(.text%2B0xf0c)%EF%BC%9A%E5%AF%B9%20%E2%80%9Cse05x_api_scp03_decrypt%E2%80%9D%20%E7%9A%84%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%8F%82%E8%80%83%3C%2FDIV%3E%3CDIV%3E%2Fusr%2Fbin%2Fld%EF%BC%9A%E7%89%88%E6%9C%AC%2Flibse05x_lib.a%20(se05x_tlv.c.o)%EF%BC%9A%E5%9C%A8%E5%87%BD%E6%95%B0%20%60doapdutxRX'%E4%B8%AD%EF%BC%9A%3C%2FDIV%3E%3CDIV%3Ese05x_tlv.c%3A(.text%2B0x11d0)%3A%E5%AF%B9%20%E2%80%9Cse05x_api_scp03_encrypt%E2%80%9D%20%E7%9A%84%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%8F%82%E8%80%83%3C%2FDIV%3E%3CDIV%3E%2Fusr%2Fbin%2Fld%3A%20se05x_tlv.c%3A(.text%2B0x1248)%EF%BC%9A%E5%AF%B9%20%E2%80%9Cse05x_api_scp03_decrypt%E2%80%9D%20%E7%9A%84%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%8F%82%E8%80%83%3C%2FDIV%3E%3CDIV%3Ecollect2%3A%20error%3A%20ld%20returned%201%20exit%20status%3C%2FDIV%3E%3CDIV%3Emake%5B2%5D%3A%20***%20%5BCMakeFiles%2Fex_se05x_GetInfo.dir%2F%E7%89%88%E6%9C%AC.make%3A114%3Aex_se05x_GetInfo%5D%20%E9%94%99%E8%AF%AF%201%3C%2FDIV%3E%3CDIV%3Emake%5B1%5D%EF%BC%9A***%20%5BCMakeFiles%2FMakefile2%3A100%3A%20CMakeFiles%2Fex_se05x_GetInfo.dir%2Fall%5D.%E9%94%99%E8%AF%AF%202%3C%2FDIV%3E%3CDIV%3Emake%EF%BC%9A***%20%5BMakefile%3A91%3A%20all%5D%20%E9%94%99%E8%AF%AF%202%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E5%8D%B3%E4%BD%BF%E5%9C%A8%E5%BC%80%E6%94%BE%EF%BC%88%E9%9D%9E%20SCP%EF%BC%89%E6%A8%A1%E5%BC%8F%E4%B8%8B%E8%BF%90%E8%A1%8C%EF%BC%8C%E6%97%A7%E7%89%88%E6%9C%AC%E5%92%8C%E6%9C%80%E6%96%B0%E7%89%88%E6%9C%AC%E7%9A%84%E4%BB%A3%E7%A0%81%E9%83%BD%E4%BC%9A%E5%87%BA%E7%8E%B0%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E.%2Fex_se05x_sign%20%3C%2FDIV%3E%3CDIV%3ESe05x%20%E4%BF%A1%E5%8F%B7%E7%A4%BA%E4%BE%8B%20%EF%BC%81%3C%2FDIV%3E%3CDIV%3EPlug%20and%20Trust%20nano%20%E4%BB%A3%E7%A0%81%E5%8C%85%20-%3CSTRONG%3E%E7%89%88%E6%9C%AC%EF%BC%9A1.5.4%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%3EI2C%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%94%AF%E6%8C%81%E6%99%AE%E9%80%9A%20i2c%20%E7%BA%A7%E5%91%BD%E4%BB%A4%E3%80%82%3C%2FDIV%3E%3CDIV%3E%E7%94%9F%E6%88%90%20ecc%20%E5%AF%86%E9%92%A5%20%3C%2FDIV%3E%3CDIV%3E%3CSTRONG%3ESe05x_API_WriteECKey%20%E4%B8%AD%E7%9A%84%E9%94%99%E8%AF%AF%20%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%3ESE05x%20%E4%BF%A1%E5%8F%B7%E7%A4%BA%E4%BE%8B%E5%A4%B1%E8%B4%A5%20%EF%BC%81%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E.%2Fex_se05x_sign%20%3C%2FDIV%3E%3CDIV%3ESe05x%20%E4%BF%A1%E5%8F%B7%E7%A4%BA%E4%BE%8B%20%EF%BC%81%3C%2FDIV%3E%3CDIV%3EPlug%20and%20Trust%20nano%20%E4%BB%A3%E7%A0%81%E5%8C%85-%3CSTRONG%3E%E7%89%88%E6%9C%AC%EF%BC%9A1.2.1%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%3EI2C%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%94%AF%E6%8C%81%E6%99%AE%E9%80%9A%20i2c%20%E7%BA%A7%E5%91%BD%E4%BB%A4%E3%80%82%3C%2FDIV%3E%3CDIV%3E%E7%94%9F%E6%88%90%20ecc%20%E5%AF%86%E9%92%A5%20%3C%2FDIV%3E%3CDIV%3E%3CSTRONG%3ESe05x_API_WriteECKey%20%E4%B8%AD%E7%9A%84%E9%94%99%E8%AF%AF%20%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%3ESE05x%20%E4%BF%A1%E5%8F%B7%E7%A4%BA%E4%BE%8B%E5%A4%B1%E8%B4%A5%20%EF%BC%81%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FDIV%3E%3CDIV%3ESureshkumar%20R%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2203084%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Unable%20to%20Retrieve%20ECC%20Curve%20Details%20from%20SE050%20using%20Plug%20%26amp%3B%20Trust%20Nano%20Package%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2203084%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F210184%22%20target%3D%22_blank%22%3E%40krsuresh%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E4%BF%A1%E6%81%AF%EF%BC%81%E4%BD%A0%E4%BF%AE%E6%94%B9%E8%BF%87%E7%BA%B3%E7%B1%B3%E4%BB%A3%E7%A0%81%E5%8C%85%E7%9A%84%E6%BA%90%E4%BB%A3%E7%A0%81%E5%90%97%EF%BC%9F%E7%9C%8B%E6%9D%A5%E4%BD%A0%E7%9A%84%E4%BB%A3%E7%A0%81%E4%B8%8E%20Github%20%E4%BB%93%E5%BA%93%E4%B8%AD%E7%9A%84%E4%BB%A3%E7%A0%81%E4%B8%8D%E5%90%8C%E3%80%82%E8%AF%A6%E6%83%85%E8%AF%B7%E5%8F%82%E9%98%85%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPPlugNTrust%2Fnano-package%2Fblob%2F737b61c527d4145f6dc96db9b51e22a4067ca09c%2Flib%2Fapdu%2Fse05x_APDU_impl.c%23L998%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FNXPPlugNTrust%2Fnano-package%2Fblob%2F737b61c527d4145f6dc96db9b51e22a4067ca09c%2Flib%2Fapdu%2Fse05x_APDU_impl.c%23L998%3C%2FA%3E%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%A5%9D%E6%82%A8%E6%84%89%E5%BF%AB%EF%BC%8C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%3CBR%20%2F%3E-%20%E5%A6%82%E6%9E%9C%E6%9C%AC%E5%B8%96%E5%9B%9E%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%22%E6%A0%87%E8%AE%B0%E6%AD%A3%E7%A1%AE%22%20%E6%8C%89%E9%92%AE%E3%80%82%E8%B0%A2%E8%B0%A2%EF%BC%81%3CBR%20%2F%3E-%20%E6%88%91%E4%BB%AC%E4%BC%9A%E5%9C%A8%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E5%8F%91%E5%B8%96%E5%90%8E%E7%9A%84%207%20%E5%91%A8%E5%86%85%E8%B7%9F%E8%B8%AA%E4%B8%BB%E9%A2%98%EF%BC%8C%E4%B9%8B%E5%90%8E%E7%9A%84%E5%9B%9E%E5%A4%8D%E5%B0%86%E8%A2%AB%E5%BF%BD%E7%95%A5%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BB%A5%E5%90%8E%E6%9C%89%E7%9B%B8%E5%85%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E5%8F%A6%E5%BC%80%E6%96%B0%E4%B8%BB%E9%A2%98%EF%BC%8C%E5%B9%B6%E5%8F%82%E8%80%83%E5%B7%B2%E5%85%B3%E9%97%AD%E7%9A%84%E4%B8%BB%E9%A2%98%E3%80%82%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2202691%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Unable%20to%20Retrieve%20ECC%20Curve%20Details%20from%20SE050%20using%20Plug%20%26amp%3B%20Trust%20Nano%20Package%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2202691%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59276%22%20target%3D%22_blank%22%3E%40Kan_Li%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CDIV%3E%E7%94%9F%E6%88%90%20ECC%20%E5%AF%86%E9%92%A5%E5%AF%B9%E6%97%B6%EF%BC%8CSE05x_API_WriteECKey%20%E5%87%BD%E6%95%B0%E5%9C%A8%20SE050-C%20%E6%9D%BF%E4%B8%8A%E8%BF%94%E5%9B%9E%200x6985%E3%80%82%3C%2FDIV%3E%3CDIV%3E%E4%B9%8B%E5%89%8D%E5%90%8C%E6%A0%B7%E7%9A%84%E4%BB%A3%E7%A0%81%E5%9C%A8%E8%BF%99%E5%9D%97%E6%9D%BF%E4%B8%8A%E8%BF%90%E8%A1%8C%E8%89%AF%E5%A5%BD%EF%BC%8C%E4%BD%86%E5%9C%A8%20SE050-F%20%E6%9D%BF%E4%B8%8A%E4%BB%8D%E7%84%B6%E5%8F%AF%E4%BB%A5%E6%AD%A3%E5%B8%B8%E8%BF%90%E8%A1%8C%E3%80%82%3C%2FDIV%3E%3CDIV%3E%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E6%98%AF%E7%AA%81%E7%84%B6%E5%8F%91%E7%94%9F%E7%9A%84%EF%BC%8C%E6%88%91%E6%97%A0%E6%B3%95%E7%A1%AE%E5%AE%9A%E5%8E%9F%E5%9B%A0%E3%80%82%E8%AF%B7%E5%B8%AE%E6%88%91%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ESE05x_ECCurve_t%20curveID%20%3D%20kSE05x_ECCurve_NIST_P256%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20status%20%3D%20Se05x_API_WriteECKey(%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%26amp%3Bse05x_session%EF%BC%8CNULL%EF%BC%8C0%EF%BC%8CkeyID%EF%BC%8CcurveID%EF%BC%8CNULL%EF%BC%8C0%EF%BC%8CNULL%EF%BC%8C0%EF%BC%8CkSE05x_INS_NA%EF%BC%8CkSE05x_KeyPart_Pair%EF%BC%89%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20if%20(status%20!%3D%20SM_OK)%20%7B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20SMLOG_E(%22Error%20in%20Se05x_API_WriteECKey%20%5Cn%22)%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%E8%BF%94%E5%9B%9E%201%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FDIV%3E%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3ESureshkumar%20R%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2202290%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Unable%20to%20Retrieve%20ECC%20Curve%20Details%20from%20SE050%20using%20Plug%20%26amp%3B%20Trust%20Nano%20Package%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2202290%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59276%22%20target%3D%22_blank%22%3E%40Kan_Li%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%8F%8A%E6%97%B6%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%9C%A8%E9%99%84%E4%BB%B6%E4%B8%AD%E6%89%BE%E5%88%B0%E5%9C%A8%3CSTRONG%3E%E5%BC%80%E6%94%BE%E6%A8%A1%E5%BC%8F%E4%B8%8B%3C%2FSTRONG%3E%E6%8D%95%E8%8E%B7%E7%9A%84%20APDU%20%E6%97%A5%E5%BF%97%E8%AF%A6%E7%BB%86%E4%BF%A1%E6%81%AF%E3%80%82%E6%88%91%E5%8F%91%E7%8E%B0%20Se05x_API_ReadECCurveList%20API%20%E5%9C%A8%E5%BC%80%E6%94%BE%E6%A8%A1%E5%BC%8F%E4%B8%8B%E4%BC%9A%E8%BF%94%E5%9B%9E%E5%A4%B1%E8%B4%A5%EF%BC%8C%E8%80%8C%E5%9C%A8%3CSTRONG%3E%E5%AE%89%E5%85%A8%E6%A8%A1%E5%BC%8F%3C%2FSTRONG%3E%E4%B8%8B%E5%8D%B4%E8%83%BD%E6%88%90%E5%8A%9F%E6%89%A7%E8%A1%8C%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E6%9F%A5%E7%9C%8B%E6%89%80%E6%8F%90%E4%BE%9B%E7%9A%84%E8%AF%A6%E7%BB%86%E4%BF%A1%E6%81%AF%EF%BC%8C%E5%B9%B6%E5%91%8A%E7%9F%A5%E6%88%91%E5%9C%A8%E6%B5%81%E7%A8%8B%E4%B8%AD%E6%98%AF%E5%90%A6%E9%81%97%E6%BC%8F%E4%BA%86%E4%BB%BB%E4%BD%95%E6%AD%A5%E9%AA%A4%E6%88%96%E9%85%8D%E7%BD%AE%E3%80%82%3C%2FP%3E%3CP%3E%3CU%3E%3CSTRONG%3E%E7%89%88%E6%9C%AC%E6%AD%A5%E9%AA%A4%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FSTRONG%3E%3C%2FU%3E%3C%2FP%3E%3CP%3E%24%20cmake..%3CBR%20%2F%3E%3CBR%20%2F%3E%24%20%E8%B5%9A%E9%92%B1%E3%80%82%2Fbuild%2Fsrc%2Fse05x_app%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22krsuresh_0-1762830074736.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22krsuresh_0-1762830074736.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22krsuresh_0-1762830074736.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22krsuresh_0-1762830074736.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22krsuresh_0-1762830074736.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22krsuresh_0-1762830074736.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22krsuresh_0-1762830074736.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22krsuresh_0-1762830074736.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22krsuresh_0-1762830074736.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F364806iB6786A836C804689%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22krsuresh_0-1762830074736.png%22%20alt%3D%22krsuresh_0-1762830074736.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3ESureshkumar%20R%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2202261%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Unable%20to%20Retrieve%20ECC%20Curve%20Details%20from%20SE050%20using%20Plug%20%26amp%3B%20Trust%20Nano%20Package%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2202261%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F210184%22%20target%3D%22_blank%22%3E%40krsuresh%3C%2FA%3E%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E4%BF%A1%E6%81%AF%EF%BC%81%E6%82%A8%E5%B0%9D%E8%AF%95%E8%BF%87%E4%B8%8E%20SE050C%20%E8%BF%9B%E8%A1%8C%E6%99%AE%E9%80%9A%E9%80%9A%E4%BF%A1%E5%90%97%EF%BC%9F%20%E6%97%A5%E5%BF%97%E5%BA%94%E8%AF%A5%E5%A6%82%E4%B8%8B%E6%89%80%E7%A4%BA%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Kan_Li_0-1762828359549.png%22%20style%3D%22width%3A%20666px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1762828359549.png%22%20style%3D%22width%3A%20666px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1762828359549.png%22%20style%3D%22width%3A%20666px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1762828359549.png%22%20style%3D%22width%3A%20666px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1762828359549.png%22%20style%3D%22width%3A%20666px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1762828359549.png%22%20style%3D%22width%3A%20666px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1762828359549.png%22%20style%3D%22width%3A%20666px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1762828359549.png%22%20style%3D%22width%3A%20666px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1762828359549.png%22%20style%3D%22width%3A%20666px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F364799i7D864CAC842FBB90%2Fimage-dimensions%2F666x218%3Fv%3Dv2%22%20width%3D%22666%22%20height%3D%22218%22%20role%3D%22button%22%20title%3D%22Kan_Li_0-1762828359549.png%22%20alt%3D%22Kan_Li_0-1762828359549.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%A5%9D%E6%82%A8%E6%84%89%E5%BF%AB%EF%BC%8C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%3CBR%20%2F%3E-%20%E5%A6%82%E6%9E%9C%E6%9C%AC%E5%B8%96%E5%9B%9E%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%22%E6%A0%87%E8%AE%B0%E6%AD%A3%E7%A1%AE%22%20%E6%8C%89%E9%92%AE%E3%80%82%E8%B0%A2%E8%B0%A2%EF%BC%81%3CBR%20%2F%3E-%20%E6%88%91%E4%BB%AC%E4%BC%9A%E5%9C%A8%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E5%8F%91%E5%B8%96%E5%90%8E%E7%9A%84%207%20%E5%91%A8%E5%86%85%E8%B7%9F%E8%B8%AA%E4%B8%BB%E9%A2%98%EF%BC%8C%E4%B9%8B%E5%90%8E%E7%9A%84%E5%9B%9E%E5%A4%8D%E5%B0%86%E8%A2%AB%E5%BF%BD%E7%95%A5%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BB%A5%E5%90%8E%E6%9C%89%E7%9B%B8%E5%85%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E5%8F%A6%E5%BC%80%E6%96%B0%E4%B8%BB%E9%A2%98%EF%BC%8C%E5%B9%B6%E5%8F%82%E8%80%83%E5%B7%B2%E5%85%B3%E9%97%AD%E7%9A%84%E4%B8%BB%E9%A2%98%E3%80%82%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2202213%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Unable%20to%20Retrieve%20ECC%20Curve%20Details%20from%20SE050%20using%20Plug%20%26amp%3B%20Trust%20Nano%20Package%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2202213%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%AF%B7%E6%9F%A5%E7%9C%8B%20APDU%20%E6%97%A5%E5%BF%97%E8%AF%A6%E6%83%85%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22krsuresh_0-1762823698890.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22krsuresh_0-1762823698890.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22krsuresh_0-1762823698890.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22krsuresh_0-1762823698890.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22krsuresh_0-1762823698890.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22krsuresh_0-1762823698890.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22krsuresh_0-1762823698890.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22krsuresh_0-1762823698890.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22krsuresh_0-1762823698890.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F364779i40ED497EDC93E763%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22krsuresh_0-1762823698890.png%22%20alt%3D%22krsuresh_0-1762823698890.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2248200%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Unable%20to%20Retrieve%20ECC%20Curve%20Details%20from%20SE050%20using%20Plug%20%26amp%3B%20Trust%20Nano%20Package%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2248200%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59276%22%20target%3D%22_blank%22%3E%40Kan_Li%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E4%BF%A1%E6%81%AF%E3%80%82%E6%88%91%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20Se05x_API_DeleteECCurve%20%E5%88%A0%E9%99%A4%E6%9B%B2%E7%BA%BF%EF%BC%8C%E4%BD%86%E4%BB%8D%E9%81%87%E5%88%B0%E7%9B%B8%E5%90%8C%E7%9A%84%200x6985%20%E9%94%99%E8%AF%AF%E3%80%82%3CBR%20%2F%3E%E8%AF%B7%E7%A1%AE%E8%AE%A4%E8%BF%99%E6%98%AF%E5%90%A6%E6%98%AF%E5%88%A0%E9%99%A4%E6%9B%B2%E7%BA%BF%E7%9A%84%E6%AD%A3%E7%A1%AE%E6%AD%A5%E9%AA%A4%EF%BC%8C%E6%88%96%E8%80%85%E6%88%91%E6%98%AF%E5%90%A6%E9%81%97%E6%BC%8F%E4%BA%86%E4%BB%BB%E4%BD%95%E6%AD%A5%E9%AA%A4%EF%BC%9F%E8%AF%B7%E5%9C%A8%E9%99%84%E4%BB%B6%E4%B8%AD%E6%89%BE%E5%88%B0%E8%B0%83%E8%AF%95%E6%97%A5%E5%BF%97%E4%BB%A5%E4%BE%9B%E5%8F%82%E8%80%83%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Estatus%20%3D%20Se05x_API_DeleteECCurve(session_ctx%2C%20kSE05x_ECCurve_NIST_P256)%3B%3CBR%20%2F%3Eif%20(status%20!%3D%20SM_OK)%20%7B%3CBR%20%2F%3ESMLOG_E(%22Error%20in%20Se05x_API_DeleteECCurve%20%5Cn%22)%3B%3CBR%20%2F%3Ereturn%201%3B%3CBR%20%2F%3E%7D%20else%20%7B%3CBR%20%2F%3ESMLOG_I(%22Curve%20Deleted%20Success....%20%5Cn%22)%3B%3CBR%20%2F%3E%7D%3C%2FP%3E%3CP%3Estatus%20%3D%20ex_se05x_create_curve(session_ctx%2C%20curveID)%3B%3CBR%20%2F%3Eif%20(status%20!%3D%20SM_OK)%20%7B%3CBR%20%2F%3ESMLOG_I(%22Error%20in%20ex_se05x_create_curve%20%5Cn%22)%3B%3CBR%20%2F%3Egoto%20exit%3B%3CBR%20%2F%3E%7D%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSTRONG%3E%E6%97%A5%E5%BF%97%E8%AF%A6%E6%83%85%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3Eex_get_version%2C%20PASSED%3CBR%20%2F%3EAPDU%20-%20CheckObjectExists%20%5B%5D%3CBR%20%2F%3EAPDU%20%3ADEBUG%3AkSE05x_TAG_1%5B%22object%20id%22%5D%20%3D%200x7B0001F3%3CBR%20%2F%3ESCP03%3A%20Encrypted%20Data%20%3D%3D%26gt%3B%3A84%2004%2000%2027%2018%20d3%20f3%2089%2046%207d%20af%2066%20e8%2067%2009%2059%2027%20f3%20cb%20f8%2035%20b2%203f%2088%2079%20c3%2050%202d%203f%3CBR%20%2F%3EAPDU%20Tx%26gt%3B%20%EF%BC%9A84%2004%2000%2027%2018%20d3%20f3%2089%2046%207d%20af%2066%20e8%2067%2009%2059%2027%20f3%20cb%20f8%2035%20b2%203f%2088%2079%20c3%2050%202d%203f%3CBR%20%2F%3EAPDU%20Rx%26lt%3B%3A7b%2078%2012%2039%2041%205e%2028%20e6%20ef%208f%2093%209c%204b%2079%20aa%203d%2091%20a6%207c%20fe%20fd%202d%2088%2015%2090%2000%3CBR%20%2F%3ESCP03%3A%20RMAC%20%E6%A0%A1%E9%AA%8C%E6%88%90%E5%8A%9F%E3%80%82..%E8%A7%A3%E5%AF%86%E5%93%8D%E5%BA%94%E6%95%B0%E6%8D%AE%3CBR%20%2F%3ESCP03%3A%20%E8%A7%A3%E5%AF%86%E6%95%B0%E6%8D%AE%20%3D%3D%26gt%3B%3A41%2001%2002%2090%2000%3CBR%20%2F%3E%3CSTRONG%3EAPDU%20-%20Se05x_API_DeleteECCurve%20%5B%5D%3C%2FSTRONG%3E%3CBR%20%2F%3EAPDU%20%3ADEBUG%3AkSE05x_TAG_1%5B%22curve%20id%22%5D%20%3D%200x3%3CBR%20%2F%3ESCP03%3A%20%E5%8A%A0%E5%AF%86%E6%95%B0%E6%8D%AE%20%3D%3D%26gt%3B%20%EF%BC%9A84%2004%200b%2028%2018%204d%20d7%20f6%207c%2076%205b%20c8%20d8%2070%20bb%2072%209d%207e%20f1%207c%2059%20ea%2004%20a3%204c%20c8%2037%2065%2056%3CBR%20%2F%3EAPDU%20Tx%26gt%3B%20%EF%BC%9A84%2004%200b%2028%2018%204d%20d7%20f6%207c%2076%205b%20c8%20d8%2070%20bb%2072%209d%207e%20f1%207c%2059%20ea%2004%20a3%204c%20c8%2037%2065%2056%3CBR%20%2F%3EAPDU%20Rx%26lt%3B%3A17%2058%2065%2057%20b6%2041%2008%20ca%2090%2000%3CBR%20%2F%3ESCP03%3A%20RMAC%20%E6%A0%A1%E9%AA%8C%E6%88%90%E5%8A%9F%E3%80%82..%20Decrypt%20Response%20Data%3CBR%20%2F%3E%20SCP03%3CSTRONG%3E%3A%20Decrypted%20Data%20%3D%3D%26gt%3B%3A90%2000%20%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3ECurve%20Deleted%20Success....%3C%2FSTRONG%3E%3CBR%20%2F%3EAPDU%20-%20Se05x_API_CreateECCurve%20%5B%5D%3CBR%20%2F%3EAPDU%20%3ADEBUG%3AkSE05x_TAG_1%5B%22curve%20id%22%5D%20%3D%200x3%3CBR%20%2F%3ESCP03%3A%20%E5%8A%A0%E5%AF%86%E6%95%B0%E6%8D%AE%20%3D%3D%26gt%3B%3A84%2001%200b%2004%2018%202c%2027%20d5%2077%2043%20c8%2076%20d8%2029%2004%208b%20d9%2066%20d4%20db%203e%20f8%20a4%2085%20a1%2026%208c%2091%20d4%3CBR%20%2F%3EAPDU%20Tx%26gt%3B%20%EF%BC%9A84%2001%200b%2004%2018%202c%2027%20d5%2077%2043%20c8%2076%20d8%2029%2004%208b%20d9%2066%20d4%20db%203e%20f8%20a4%2085%20a1%2026%208c%2091%20d4%3CBR%20%2F%3EAPDU%20Rx%26lt%3B%3Abf%20c3%2026%20f8%2016%208a%20e0%20d0%2090%2000%3CBR%20%2F%3ESCP03%3A%20RMAC%20%E6%A0%A1%E9%AA%8C%E6%88%90%E5%8A%9F%E3%80%82..%E8%A7%A3%E5%AF%86%E5%93%8D%E5%BA%94%E6%95%B0%E6%8D%AE%3CBR%20%2F%3ESCP03%3A%20%E8%A7%A3%E5%AF%86%E6%95%B0%E6%8D%AE%20%3D%3D%26gt%3B%3A90%2000%3CBR%20%2F%3EAPDU%20-%20Se05x_API_SetECCurveParam%20%5B%5D%3CBR%20%2F%3EAPDU%20%3ADEBUG%3AkSE05x_TAG_1%5B%22curve%20id%22%5D%20%3D%200x3%3CBR%20%2F%3EAPDU%20%3ADEBUG%3AkSE05x_TAG_2%5B%22ecCurveParam%22%5D%20%3D%200x1%3CBR%20%2F%3EAPDU%20%EF%BC%9ADEBUG%3AkSE05x_TAG_3%5B%22inputData%22%5D%20%3Aff%20ff%20ff%20ff%20ff%20ff%20ff%20ff%20ff%20ff%20ff%20ff%20ff%20ff%20ff%20ff%20ff%20ff%20ff%20ff%20ff%20ff%20ff%20ff%20ff%20ff%20ff%20ff%20ff%20ff%20ff%20fe%20ff%20ff%20ff%20ff%2000%2000%2000%2000%2000%2000%2000%2000%20ff%20ff%20ff%20fc%3CBR%20%2F%3ESCP03%3A%E5%8A%A0%E5%AF%86%E6%95%B0%E6%8D%AE%20%3D%3D%26gt%3B%20%EF%BC%9A84%2001%200b%2040%2048%200b%20a5%20d4%202e%2076%20eb%2095%20a5%20b0%2044%20a3%2051%20ff%209e%20ec%209d%205f%20d5%203f%20c6%2098%20fc%207c%20cf%200f%2080%20e2%2059%20d6%207b%20a6%2014%2007%2001%20a3DF%20BB%2086%208B%202A%200E%20D5%20F3%204C%20F3%20C9%206B%2007%2002%201C%2077%2083%206E%2085%20E1%20F6%20DD%209B%209C%204C%206D%20C8%2069%203D%20A1%20DF%20D3%2045%20E1%20DD%206D%207A%3CBR%20%2F%3EAPDU%20Tx%26gt%3B%20%EF%BC%9A84%2001%200b%2040%2048%200b%20a5%20d4%202e%2076%20eb%2095%20a5%20b0%2044%20a3%2051%20ff%209e%20ec%209d%205f%20d5%203f%20c6%2098%20fc%207c%20cf%200f%2080%20e2%2059%20d6%207b%20a6%2014%2007%2001%20a3DF%20BB%2086%208B%202A%200E%20D5%20F3%204C%20F3%20C9%206B%2007%2002%201C%2077%2083%206E%2085%20E1%20F6%20DD%209B%209C%204C%206D%20C8%2069%203D%20A1%20DF%20D3%2045%20E1%20DD%206D%207A%3CBR%20%2F%3EAPDU%20Rx%26lt%3B%20%EF%BC%9A69%2085%3CBR%20%2F%3EError%20in%20ex_se05x_create_curve%3CBR%20%2F%3Eex_generate_nist256_key%2C%20FAILED%3CBR%20%2F%3EAPDU%20-%20CheckObjectExists%20%5B%5D%3CBR%20%2F%3EAPDU%20%3ADEBUG%3AkSE05x_TAG_1%5B%22object%20id%22%5D%20%3D%200x7B00022C%3CBR%20%2F%3ESCP03%3A%20Encrypted%E6%95%B0%E6%8D%AE%20%3D%3D%26gt%3B%3A84%2004%2000%2027%2018%2094%2009%20fd%20ce%206b%2042%2004%206a%20f0%2008%2094%20b7%20b8%20ff%2023%2063%2008%20c3%2057%20ed%209c%202f%201f%200b%3CBR%20%2F%3EAPDU%20Tx%26gt%3B%3A84%2004%2000%2027%2018%2094%2009%20fd%20ce%206b%2042%2004%206a%20f0%2008%2094%20b7%20b8%20ff%2023%2063%2008%20c3%2057%20ed%209c%202f%201f%200b%3CBR%20%2F%3EAPDU%20Rx%26lt%3B%20%EF%BC%9Abe%2003%2006%2002%20b6%2029%20d7%20d3%2076%201b%2010%20bc%204a%206b%2022%206b%2083%208b%20f2%2021%201b%2048%2067%20e1%2090%2000%3CBR%20%2F%3ESCP03%3A%20RMAC%20%E6%A0%A1%E9%AA%8C%E6%88%90%E5%8A%9F%E3%80%82..%E8%A7%A3%E5%AF%86%E5%93%8D%E5%BA%94%E6%95%B0%E6%8D%AE%3CBR%20%2F%3ESCP03%3A%20%E8%A7%A3%E5%AF%86%E6%95%B0%E6%8D%AE%20%3D%3D%26gt%3B%3A41%2001%2002%2090%2000%3CBR%20%2F%3EAPDU%20-%20WriteECKey%20%5B%5D%3CBR%20%2F%3EAPDU%20%3ADEBUG%3AkSE05x_TAG_MAX_ATTEMPTS%5B%22maxAttempt%22%5D%20%3D%200x0%3CBR%20%2F%3EAPDU%20%EF%BC%9ADEBUG%3AkSE05x_TAG_1%5B%22object%20id%22%5D%20%3D%200x7B00022C%3CBR%20%2F%3EAPDU%20%3ADEBUG%3AkSE05x_TAG_2%5B%22curveID%22%5D%20%3D%200x3%3CBR%20%2F%3EAPDU%20%3ADEBUG%3AkSE05x_TAG_3%5B%22privKey%22%5D%20%EF%BC%9AE4%20EE%205F%2099%20D9%20D8%2037%208F%2039%20C2%20C9%20FD%20A9%2012%205E%20A7%203F%20B8%20FD%2000%20B5%2019%20E6%2094%201E%20F1%2034%2075%208D%2033%2059%208A%3CBR%20%2F%3EAPDU%20%3ADEBUG%3AkSE05x_TAG_4%5B%22pubKey%22%5D%20%EF%BC%9A04%20f2%2024%20bc%205e%20ea%2074%2028%20a1%2020%20d3%20d2%2069%20fe%2022%20f3%2059%209c%2020%2033%20a2%20e0%20cb%2081%20c2%20ce%20a9%20d6%20d4%2066%20c3%2068%20f8%20b6%20a8%209c%20de%2008%2088%20b5%2049%20cd%20ed%2085%20d3%20b5%2088%2072%200a%20dc%2026%2032%20b0%2030%20bf%20b1%2067%20d0%20fd%20bc%2089%20e7%202b%209c%20c1%3CBR%20%2F%3ESCP03%EF%BC%9A%E5%8A%A0%E5%AF%86%E6%95%B0%E6%8D%AE%20%3D%3D%26gt%3B%20%EF%BC%9A84%2001%2061%2000%2078%204b%20c2%207d%20c9%20fc%20a3%20f5%2001%2027%207c%20d2%208d%20d3%2003%2001%20bd%20bf%2056%20c6%2004%209f%207e%2058%2040%20fa%20c3%2013%2067%20b2%209a%200e%201e%20c6%2022%20a9%2087%2006%2023%2074%206c%2046%20b0%200b%201f%209a%20e8%20eb%20f3%2078%20c8%20c9%2088%20a1%20d8%20ca%2071%2020%20eb%2086ca%20d8%2086%2085%2013%2051%20ba%20bc%203d%20ed%2099%205d%205e%20f3%20ea%2079%205c%2064%205b%2009%20bf%200d%20e2%206a%208e%20b3%20a7%2061%20c8%20e3%200e%20b4%20bf%2018%20af%2056%2013%205a%20e2%204b%20dc%20bf%208e%20f2%20db%209c%20a5%201e%2016%20df%20f7%2045%20cd%20a0%2021%201a%2082%2078%20b3%209f%20e2%3CBR%20%2F%3EAPDU%20Tx%26gt%3B%20%EF%BC%9A84%2001%2061%2000%2078%204b%20C2%207D%20C9%20FC%20A3%20F5%2001%2027%207C%20D2%208D%20D3%2003%2001%20BD%20BF%2056%20C6%2004%209F%207E%2058%2040%20FA%20C3%2013%2067%20B2%209A%200E%201E%20C6%2022%20A9%2087%2006%2023%2074%206C%2046%20B0%200B%201F%209A%20E8%20EB%20F3%2078%20C8%20C9%2088%20A1%20D8%20CA%2071%2020%20EB%2086%20CA%20D8%208685%2013%2051%20ba%20bc%203d%20ed%2099%205d%205e%20f3%20ea%2079%205c%2064%205b%2009%20bf%200d%20e2%206a%208e%20b3%20a7%2061%20c8%20e3%200e%20b4%20bf%2018%20af%2056%2013%205a%20e2%204b%20dc%20bf%208e%20f2%20db%209c%20a5%201e%2016%20df%20f7%2045%20cd%20a0%2021%201a%2082%2078%20b3%209f%20e2%3CBR%20%2F%3EAPDU%20Rx%26lt%3B%20%EF%BC%9A69%2085%3CBR%20%2F%3ESe05x_API_WriteECKey%20%E4%B8%AD%E7%9A%84%E9%94%99%E8%AF%AF%3CBR%20%2F%3Eex_set_get_nist256_key%2C%20FAILED%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3ESureshkumar%20R%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2248088%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Unable%20to%20Retrieve%20ECC%20Curve%20Details%20from%20SE050%20using%20Plug%20%26amp%3B%20Trust%20Nano%20Package%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2248088%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F210184%22%20target%3D%22_blank%22%3E%40krsuresh%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E4%BF%A1%E6%81%AF%EF%BC%81%E6%88%91%E5%8F%AF%E4%BB%A5%E7%9C%8B%E5%87%BA%20%3CSPAN%3Ese05x_api_setecCurveParam%20%E5%87%BA%E7%8E%B0%E4%BA%86%206985%20%E9%94%99%E8%AF%AF%EF%BC%8C%E8%BF%99%E6%84%8F%E5%91%B3%E7%9D%80%E6%9B%B2%E7%BA%BF%E5%B7%B2%E7%BB%8F%E5%AE%89%E8%A3%85%E5%AE%8C%E6%AF%95%EF%BC%8C%E4%BD%86%E5%8F%AF%E8%83%BD%E5%AE%89%E8%A3%85%E4%B8%8D%E6%AD%A3%E7%A1%AE%EF%BC%8C%E5%9B%A0%E6%AD%A4%E4%BD%A0%E6%97%A0%E6%B3%95%E5%86%8D%E6%AC%A1%E8%BF%9B%E8%A1%8C%E5%AE%89%E8%A3%85%EF%BC%8C%E4%B9%9F%E6%97%A0%E6%B3%95%E4%BD%BF%E7%94%A8%E5%AE%83%E6%9D%A5%E5%88%9B%E5%BB%BA%E5%AF%86%E9%92%A5%E5%AF%B9%EF%BC%8C%E6%89%80%E4%BB%A5%E8%AF%B7%3C%2FSPAN%3E%E5%85%88%E7%A7%BB%E9%99%A4%E8%BF%99%E6%9D%A1%E6%9B%B2%E7%BA%BF%E3%80%82%E7%84%B6%E5%90%8E%E9%87%8D%E6%96%B0%E8%BF%90%E8%A1%8C%20se05x_crypto%20%E6%BC%94%E7%A4%BA%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E8%AF%A6%E6%83%85%E8%AF%B7%E5%8F%82%E8%A7%81%E4%B8%8B%E6%96%87%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Kan_Li_0-1764053560292.png%22%20style%3D%22width%3A%20658px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1764053560292.png%22%20style%3D%22width%3A%20658px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1764053560292.png%22%20style%3D%22width%3A%20658px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1764053560292.png%22%20style%3D%22width%3A%20658px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1764053560292.png%22%20style%3D%22width%3A%20658px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1764053560292.png%22%20style%3D%22width%3A%20658px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1764053560292.png%22%20style%3D%22width%3A%20658px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F367094iAC093025C3FA4F42%2Fimage-dimensions%2F658x278%3Fv%3Dv2%22%20width%3D%22658%22%20height%3D%22278%22%20role%3D%22button%22%20title%3D%22Kan_Li_0-1764053560292.png%22%20alt%3D%22Kan_Li_0-1764053560292.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%A5%9D%E6%82%A8%E6%84%89%E5%BF%AB%EF%BC%8C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%3CBR%20%2F%3E-%20%E5%A6%82%E6%9E%9C%E6%9C%AC%E5%B8%96%E5%9B%9E%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%22%E6%A0%87%E8%AE%B0%E6%AD%A3%E7%A1%AE%22%20%E6%8C%89%E9%92%AE%E3%80%82%E8%B0%A2%E8%B0%A2%EF%BC%81%3CBR%20%2F%3E-%20%E6%88%91%E4%BB%AC%E4%BC%9A%E5%9C%A8%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E5%8F%91%E5%B8%96%E5%90%8E%E7%9A%84%207%20%E5%91%A8%E5%86%85%E8%B7%9F%E8%B8%AA%E4%B8%BB%E9%A2%98%EF%BC%8C%E4%B9%8B%E5%90%8E%E7%9A%84%E5%9B%9E%E5%A4%8D%E5%B0%86%E8%A2%AB%E5%BF%BD%E7%95%A5%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BB%A5%E5%90%8E%E6%9C%89%E7%9B%B8%E5%85%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E5%8F%A6%E5%BC%80%E6%96%B0%E4%B8%BB%E9%A2%98%EF%BC%8C%E5%B9%B6%E5%8F%82%E8%80%83%E5%B7%B2%E5%85%B3%E9%97%AD%E7%9A%84%E4%B8%BB%E9%A2%98%E3%80%82%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2249079%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Unable%20to%20Retrieve%20ECC%20Curve%20Details%20from%20SE050%20using%20Plug%20%26amp%3B%20Trust%20Nano%20Package%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2249079%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F210184%22%20target%3D%22_blank%22%3E%40krsuresh%3C%2FA%3E%EF%BC%8C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%9C%8B%E8%B5%B7%E6%9D%A5%E6%82%A8%E4%BD%BF%E7%94%A8%20api%20%E4%B8%BA%20nist384%20%E7%94%9F%E6%88%90%20ECC%20%E6%9B%B2%E7%BA%BF%EF%BC%8C%E4%B8%BA%20nist256%20%E7%94%9F%E6%88%90%20ECC%20%E6%9B%B2%E7%BA%BF%EF%BC%8C%E4%BD%86%20ECC%20%E5%8F%82%E6%95%B0%E4%BF%9D%E6%8C%81%E4%B8%8D%E5%8F%98%EF%BC%8C%E5%9B%A0%E6%AD%A4%E5%AF%BC%E8%87%B4%E6%AD%A4%E9%94%99%E8%AF%AF%EF%BC%8C%E6%82%A8%E5%BF%85%E9%A1%BB%E4%BD%BF%E7%94%A8%20nist256%20%E7%9A%84%E5%8F%82%E6%95%B0%E3%80%82%3C%2FP%3E%0A%3CP%3E%23define%20EC_PARAM_prime256v1_prime%20%5C%3CBR%20%2F%3E0xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200x00%2C%200x00%2C%200x00%2C%200x01%2C%20%5C%3CBR%20%2F%3E0x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E0x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%E3%80%810xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%20%5C%3CBR%20%2F%3E0xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%3CBR%20%2F%3E%23define%20EC_PARAM_prime256v1_a%20%5C%3CBR%20%2F%3E0xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200x00%2C%200x00%2C%200x00%2C%200x01%2C%20%5C%3CBR%20%2F%3E0x00%2C%200x00%E3%80%810x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%20%5C%3CBR%20%2F%3E0x00%2C%200x00%2C%200x00%2C%200x00%2C%200xFF%2C%200xFF%2C%200xFF%2C%20%5C%3CBR%20%2F%3E0xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFC%3CBR%20%2F%3E%23define%20EC_PARAM_prime256v1_b%20%5C%3CBR%20%2F%3E0x5A%E3%80%810xC6%2C%200x35%2C%200xD8%2C%200xAA%2C%200x3A%2C%200x93%2C%200xE7%2C%20%5C%3CBR%20%2F%3E0xB3%2C%200xEB%2C%200xBD%2C%200x55%2C%200x76%2C%200x98%2C%200x86%2C%200xBC%2C%20%5C%3CBR%20%2F%3E0x65%2C%200x1D%2C%200x06%2C%200xB0%2C%200xCC%2C%200x53%2C%200xB0%2C%200xF6%2C%20%5C%3CBR%20%2F%3E0x3B%2C%200xCE%E3%80%810x3C%2C%200x3E%2C%200x27%2C%200xD2%2C%200x60%2C%200x4B%3CBR%20%2F%3E%23define%20EC_PARAM_prime256v1_x%20%5C%3CBR%20%2F%3E0x6B%2C%200x17%2C%200xD1%2C%200xF2%2C%200xE1%2C%200x2C%2C%200x42%2C%200x47%2C%3CBR%20%2F%3E0xF8%2C%200xBC%2C%200xE6%2C%200xE5%2C%200x63%2C%200xA4%2C%200x40%2C%200xF2%E3%80%81%5C%3CBR%20%2F%3E0x77%2C%200x03%2C%200x7D%2C%200x81%2C%200x2D%2C%200xEB%2C%200x33%2C%200xA0%2C%3CBR%20%2F%3E0xF4%2C%200xA1%2C%200x39%2C%200x45%2C%200xD8%2C%200x98%2C%200xC2%2C%200x96%3CBR%20%2F%3E%23define%20EC_PARAM_prime256v1_y%20%5C%3CBR%20%2F%3E0x4F%2C%200xE3%2C%200x42%2C%200xE2%2C%200xFE%E3%80%810x1A%2C%200x7F%2C%200x9B%2C%20%5C%3CBR%20%2F%3E0x8E%2C%200xE7%2C%200xEB%2C%200x4A%2C%200x7C%2C%200x0F%2C%200x9E%2C%200x16%2C%20%5C%3CBR%20%2F%3E0x2B%2C%200xCE%2C%200x33%2C%200x57%2C%200x6B%2C%200x31%2C%200x5E%2C%200xCE%2C%20%5C%3CBR%20%2F%3E0xCB%2C%200xB6%2C%200x40%2C%200x68%2C%200x37%2C%200xBF%2C%200x51%E3%80%810xF5%3CBR%20%2F%3E%23define%20EC_PARAM_prime256v1_order%5C%3CBR%20%2F%3E0xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200x00%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E0xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%3CBR%20%2F%3E0xBC%2C%200xE6%2C%200xFA%2C%200xAD%E3%80%81%200xA7%2C%200x17%2C%200x9E%2C%200x84%2C%20%5C%3CBR%20%2F%3E0xF3%2C%200xB9%2C%200xCA%2C%200xC2%2C%200xFC%2C%200x63%2C%200x25%2C%200x51%3CBR%20%2F%3E%23endif%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%B8%8C%E6%9C%9B%E5%AF%B9%E4%BD%A0%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%A5%9D%E6%82%A8%E6%84%89%E5%BF%AB%EF%BC%8C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%3CBR%20%2F%3E-%20%E5%A6%82%E6%9E%9C%E6%9C%AC%E5%B8%96%E5%9B%9E%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%22%E6%A0%87%E8%AE%B0%E6%AD%A3%E7%A1%AE%22%20%E6%8C%89%E9%92%AE%E3%80%82%E8%B0%A2%E8%B0%A2%EF%BC%81%3CBR%20%2F%3E-%20%E6%88%91%E4%BB%AC%E4%BC%9A%E5%9C%A8%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E5%8F%91%E5%B8%96%E5%90%8E%E7%9A%84%207%20%E5%91%A8%E5%86%85%E8%B7%9F%E8%B8%AA%E4%B8%BB%E9%A2%98%EF%BC%8C%E4%B9%8B%E5%90%8E%E7%9A%84%E5%9B%9E%E5%A4%8D%E5%B0%86%E8%A2%AB%E5%BF%BD%E7%95%A5%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BB%A5%E5%90%8E%E6%9C%89%E7%9B%B8%E5%85%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E5%8F%A6%E5%BC%80%E6%96%B0%E4%B8%BB%E9%A2%98%EF%BC%8C%E5%B9%B6%E5%8F%82%E8%80%83%E5%B7%B2%E5%85%B3%E9%97%AD%E7%9A%84%E4%B8%BB%E9%A2%98%E3%80%82%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2249899%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Unable%20to%20Retrieve%20ECC%20Curve%20Details%20from%20SE050%20using%20Plug%20%26amp%3B%20Trust%20Nano%20Package%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2249899%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59276%22%20target%3D%22_blank%22%3E%40Kan_Li%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E4%BD%A0%E7%9A%84%E6%BE%84%E6%B8%85%E3%80%82%3C%2FP%3E%3CP%3E%E5%BA%94%E7%94%A8%E6%AD%A3%E7%A1%AE%E7%9A%84%E5%8F%82%E6%95%B0%E5%90%8E%EF%BC%8C%3CSTRONG%3ENIST256%3C%2FSTRONG%3E%E5%92%8C%3CSTRONG%3ENIST384%3C%2FSTRONG%3EECC%20%E6%9B%B2%E7%BA%BF%E7%8E%B0%E5%9C%A8%E9%83%BD%E8%83%BD%E6%8C%89%E9%A2%84%E6%9C%9F%E8%BF%90%E8%A1%8C%E3%80%82%E4%BD%A0%E8%83%BD%E5%90%A6%E6%8F%90%E4%BE%9B%E4%B8%8E%E4%BD%A0%E6%8F%90%E5%88%B0%E7%9A%84%20%3CSTRONG%3ESetECCCurveParam%20%E7%A8%8B%E5%BA%8F%E7%9B%B8%E5%85%B3%E7%9A%84%E6%96%87%E6%A1%A3%E6%88%96%E5%BC%95%E7%94%A8%E6%9D%90%E6%96%99%3C%2FSTRONG%3E%EF%BC%9F%E6%8E%8C%E6%8F%A1%E8%BF%99%E4%BA%9B%E4%BF%A1%E6%81%AF%E6%9C%89%E5%8A%A9%E4%BA%8E%E6%88%91%E6%9B%B4%E5%A5%BD%E5%9C%B0%E7%90%86%E8%A7%A3%E6%89%80%E9%9C%80%E7%9A%84%E5%8F%82%E6%95%B0%E8%AE%BE%E7%BD%AE%E5%92%8C%E5%9F%BA%E6%9C%AC%E8%A1%8C%E4%B8%BA%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3ESureshkumar%20R%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2250758%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Unable%20to%20Retrieve%20ECC%20Curve%20Details%20from%20SE050%20using%20Plug%20%26amp%3B%20Trust%20Nano%20Package%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2250758%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F210184%22%20target%3D%22_blank%22%3E%40krsuresh%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%BE%88%E9%AB%98%E5%85%B4%E7%9F%A5%E9%81%93%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E5%B7%B2%E7%BB%8F%E8%A7%A3%E5%86%B3%E4%BA%86%EF%BC%81%E6%88%91%E6%8C%87%E7%9A%84%E6%98%AF%E5%AE%8C%E6%95%B4%E7%89%88%E7%9A%84%20MW%EF%BC%8CECC%20%E6%9B%B2%E7%BA%BF%E5%8F%82%E6%95%B0%E7%9A%84%E5%AE%9A%E4%B9%89%E5%8F%AF%E4%BB%A5%E5%9C%A8%22C%3A%5CSE-PLUG-TRUST-MW_04.07.01%5Csimw-top%5Chostlib%5ChostLib%5Cinc%5Cse05x_ecc_curves_values.h%22%20%E4%B8%AD%E6%89%BE%E5%88%B0%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%B8%8C%E6%9C%9B%E5%AF%B9%E4%BD%A0%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%A5%9D%E6%82%A8%E6%84%89%E5%BF%AB%EF%BC%8C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%3CBR%20%2F%3E-%20%E5%A6%82%E6%9E%9C%E6%9C%AC%E5%B8%96%E5%9B%9E%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%22%E6%A0%87%E8%AE%B0%E6%AD%A3%E7%A1%AE%22%20%E6%8C%89%E9%92%AE%E3%80%82%E8%B0%A2%E8%B0%A2%EF%BC%81%3CBR%20%2F%3E-%20%E6%88%91%E4%BB%AC%E4%BC%9A%E5%9C%A8%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E5%8F%91%E5%B8%96%E5%90%8E%E7%9A%84%207%20%E5%91%A8%E5%86%85%E8%B7%9F%E8%B8%AA%E4%B8%BB%E9%A2%98%EF%BC%8C%E4%B9%8B%E5%90%8E%E7%9A%84%E5%9B%9E%E5%A4%8D%E5%B0%86%E8%A2%AB%E5%BF%BD%E7%95%A5%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BB%A5%E5%90%8E%E6%9C%89%E7%9B%B8%E5%85%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E5%8F%A6%E5%BC%80%E6%96%B0%E4%B8%BB%E9%A2%98%EF%BC%8C%E5%B9%B6%E5%8F%82%E8%80%83%E5%B7%B2%E5%85%B3%E9%97%AD%E7%9A%84%E4%B8%BB%E9%A2%98%E3%80%82%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2252752%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Unable%20to%20Retrieve%20ECC%20Curve%20Details%20from%20SE050%20using%20Plug%20%26amp%3B%20Trust%20Nano%20Package%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2252752%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59276%22%20target%3D%22_blank%22%3E%40Kan_Li%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E4%BF%A1%E6%81%AF%E3%80%82%20%3C%2FP%3E%3CDIV%3E%E5%9C%A8%20OM-SE050ARD%20%E6%9D%BF%E4%B8%8A%E7%94%9F%E6%88%90%E5%92%8C%E8%AF%BB%E5%8F%96%20NIST-P521%20%E5%85%AC%E9%92%A5%E6%97%B6%EF%BC%8C%E6%88%91%E9%81%87%E5%88%B0%E4%BA%86%E6%80%BB%E7%BA%BF%E9%94%99%E8%AF%AF%E3%80%82%E4%BD%86%E6%98%AF%EF%BC%8C%E5%9C%A8%20OM-SE050ARD-F%20%E6%9D%BF%E4%B8%8A%EF%BC%8C%E6%88%91%E6%B2%A1%E6%9C%89%E6%94%B6%E5%88%B0%E6%80%BB%E7%BA%BF%E9%94%99%E8%AF%AF%EF%BC%8C%E4%BD%86%E6%98%AF%E7%94%9F%E6%88%90%E7%9A%84%E5%85%AC%E9%92%A5%E4%BC%BC%E4%B9%8E%E6%97%A0%E6%95%88%E3%80%82%E5%A6%82%E8%83%BD%E6%8F%90%E4%BE%9B%E4%BB%BB%E4%BD%95%E6%8C%87%E5%AF%BC%E6%88%96%E8%B0%83%E8%AF%95%E6%AD%A5%E9%AA%A4%EF%BC%8C%E5%B0%86%E4%B8%8D%E8%83%9C%E6%84%9F%E6%BF%80%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CU%3E%3CSTRONG%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%E8%A7%A6%E5%8F%91%E4%BF%A1%E5%8F%B7%E7%9A%84%20P-521%20%E5%85%AC%E9%92%A5%EF%BC%88133%20%E5%AD%97%E8%8A%82%EF%BC%89%EF%BC%9A%3C%2FSTRONG%3E%3C%2FU%3E%3C%2FDIV%3E%3CDIV%3E0x04%E3%80%810x00%E3%80%810xf0%E3%80%810x6f%E3%80%810x02%E3%80%810x09%E3%80%810x86%E3%80%810xd8%E3%80%810x11%E3%80%810x6a%E3%80%810x1c%E3%80%810x52%E3%80%810x2b%E3%80%810x25%E3%80%810x1f%E3%80%810x51%E3%80%81%20%3C%2FDIV%3E%3CDIV%3E0x92%E3%80%810x94%E3%80%810xa5%E3%80%810x1a%E3%80%810x67%E3%80%810x02%E3%80%810xe0%E3%80%810x4f%E3%80%810x45%E3%80%810x86%E3%80%810x43%E3%80%810x9e%E3%80%810x6b%E3%80%810x17%E3%80%810x83%E3%80%810x3b%E3%80%81%20%3C%2FDIV%3E%3CDIV%3E0xbd%E3%80%810xcf%E3%80%810x36%E3%80%810xaf%E3%80%810xa7%E3%80%810x35%E3%80%810x28%E3%80%810xf7%E3%80%810x10%E3%80%810x02%E3%80%810x32%E3%80%810x60%E3%80%810xdb%E3%80%810x72%E3%80%810x38%E3%80%810xbb%E3%80%81%20%3C%2FDIV%3E%3CDIV%3E0x43%E3%80%810x32%E3%80%810x5c%E3%80%810x48%E3%80%810x86%E3%80%810x32%E3%80%810x53%E3%80%810x95%E3%80%810x6e%E3%80%810x4f%E3%80%810x18%E3%80%810x59%E3%80%810xc8%E3%80%810xde%E3%80%810x81%E3%80%810xb4%E3%80%81%20%3C%2FDIV%3E%3CDIV%3E0x1b%E3%80%810x30%E3%80%810xd7%E3%80%810x00%E3%80%810x16%E3%80%810x17%E3%80%810x93%E3%80%810x83%E3%80%810x0a%E3%80%810x4c%E3%80%810x0d%E3%80%810x90%E3%80%810x80%E3%80%810x2d%E3%80%810x1b%E3%80%810xf2%E3%80%81%20%3C%2FDIV%3E%3CDIV%3E0xfc%E3%80%810x75%E3%80%810x7d%E3%80%810xc2%E3%80%810xdb%E3%80%810x2f%E3%80%810x3a%E3%80%810x68%E3%80%810xda%E3%80%810xbc%E3%80%810xce%E3%80%810xd5%E3%80%810xfd%E3%80%810x35%E3%80%810x48%E3%80%810x15%E3%80%81%20%3C%2FDIV%3E%3CDIV%3E0x6c%E3%80%810xe8%E3%80%810x19%E3%80%810xde%E3%80%810xef%E3%80%810x25%E3%80%810x3b%E3%80%810x0b%E3%80%810xf4%E3%80%810xe1%E3%80%810x17%E3%80%810xad%E3%80%810xa2%E3%80%810x0d%E3%80%810x86%E3%80%810xc2%E3%80%81%20%3C%2FDIV%3E%3CDIV%3E0x20%E3%80%810x61%E3%80%810xca%E3%80%810x4c%E3%80%810x8a%E3%80%810x05%E3%80%810x5c%E3%80%810x0c%E3%80%810x5a%E3%80%810x16%E3%80%810xa6%E3%80%810xe5%E3%80%810x09%E3%80%810x74%E3%80%810xc0%E3%80%810x9d%E3%80%81%20%3C%2FDIV%3E%3CDIV%3E0xc1%E3%80%810xd5%E3%80%810x37%E3%80%810x36%E3%80%810xeb%E3%80%81%20%3C%2FDIV%3E%3CDIV%3E%E6%80%BB%E7%BA%BF%E9%94%99%E8%AF%AF%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CU%3E%3CSTRONG%3E%E6%9D%A5%E8%87%AA%20OM-SE050ARD-F%20%E6%9D%BF%E7%9A%84%E5%AF%86%E9%92%A5%E6%98%AF%EF%BC%9A%3C%2FSTRONG%3E%3C%2FU%3E%3C%2FDIV%3E%3CDIV%3E0x04%E3%80%810x00%E3%80%810xe5%E3%80%810x6a%E3%80%810x9c%E3%80%810x58%E3%80%810x0b%E3%80%810xa0%E3%80%810x2b%E3%80%810x97%E3%80%810xf6%E3%80%810xc7%E3%80%810x05%E3%80%810x70%E3%80%810x09%E3%80%810xb5%E3%80%81%20%3C%2FDIV%3E%3CDIV%3E0x12%E3%80%810xa6%E3%80%810x89%E3%80%810x45%E3%80%810xf0%E3%80%810x28%E3%80%810xb5%E3%80%810x05%E3%80%810xf4%E3%80%810x4c%E3%80%810x5c%E3%80%810x63%E3%80%810x7e%E3%80%810xf0%E3%80%810x7c%E3%80%810x2c%E3%80%81%20%3C%2FDIV%3E%3CDIV%3E0x79%E3%80%810x2a%E3%80%810x59%E3%80%810x88%E3%80%810x7b%E3%80%810xa0%E3%80%810x8e%E3%80%810x38%E3%80%810x78%E3%80%810x59%E3%80%810xc2%E3%80%810xa6%E3%80%810x9a%E3%80%810xe5%E3%80%810xa0%E3%80%810x47%E3%80%81%20%3C%2FDIV%3E%3CDIV%3E0x67%E3%80%810xd1%E3%80%810xf5%E3%80%810x1f%E3%80%810x45%E3%80%810x55%E3%80%810x55%E3%80%810x84%E3%80%810xfe%E3%80%810x33%E3%80%810xaa%E3%80%810xe0%E3%80%810x97%E3%80%810xd1%E3%80%810xeb%E3%80%810x5b%E3%80%81%20%3C%2FDIV%3E%3CDIV%3E0xd3%E3%80%810x3a%E3%80%810x31%E3%80%810x01%E3%80%810x4e%E3%80%810xdb%E3%80%810xd2%E3%80%810x5a%E3%80%810x93%E3%80%810xde%E3%80%810x3a%E3%80%810x86%E3%80%810x8b%E3%80%810x20%E3%80%810xd5%E3%80%810xff%E3%80%81%20%3C%2FDIV%3E%3CDIV%3E0x2c%E3%80%810x96%E3%80%810x45%E3%80%810x51%E3%80%810x55%E3%80%810x3f%E3%80%810x5b%E3%80%810x47%E3%80%810x58%E3%80%810x5f%E3%80%810x42%E3%80%810xb9%E3%80%810x4d%E3%80%810xe1%E3%80%810xda%E3%80%810x4b%E3%80%81%20%3C%2FDIV%3E%3CDIV%3E0xf0%E3%80%810x49%E3%80%810xb7%E3%80%810xc9%E3%80%810x8e%E3%80%810xf3%E3%80%810x12%E3%80%810xf1%E3%80%810xae%E3%80%810x35%E3%80%810x02%E3%80%810xb9%E3%80%810x88%E3%80%810x5b%E3%80%810x3d%E3%80%810x6c%E3%80%81%20%3C%2FDIV%3E%3CDIV%3E0x04%E3%80%810x91%E3%80%810x6f%E3%80%810x49%E3%80%810xd3%E3%80%810x7b%E3%80%810xa0%E3%80%810xe9%E3%80%810x87%E3%80%810x09%E3%80%810x49%E3%80%810xd8%E3%80%810x54%E3%80%810xd1%E3%80%810x5f%E3%80%810xae%E3%80%81%20%3C%2FDIV%3E%3CDIV%3E0xa8%E3%80%810x54%E3%80%810xac%E3%80%810x88%E3%80%810x02%E3%80%81%20%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CU%3E%3CSTRONG%3E%E4%BB%A3%E7%A0%81%E8%AF%A6%E6%83%85%EF%BC%9A%20%3C%2FSTRONG%3E%3C%2FU%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%2F*%20secp521r1%20%3A%20521%20%E4%BD%8D%E7%B4%A0%E6%95%B0%E5%9F%9F%E4%B8%8A%E7%9A%84%20NIST%2FSECG%20%E6%9B%B2%E7%BA%BF%20*%2F%3C%2FDIV%3E%3CDIV%3E%23define%20EC_PARAM_secp521r1_prime%20%5C%5C%3C%2FDIV%3E%3CDIV%3E%20%20%20%200x01%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%3C%2FDIV%3E%3CDIV%3E%20%20%20%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%3C%2FDIV%3E%3CDIV%3E%20%20%20%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%3C%2FDIV%3E%3CDIV%3E%20%20%20%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%3C%2FDIV%3E%3CDIV%3E%20%20%20%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%3C%2FDIV%3E%3CDIV%3E%20%20%20%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%3C%2FDIV%3E%3CDIV%3E%20%20%20%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%3C%2FDIV%3E%3CDIV%3E%20%20%20%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%3C%2FDIV%3E%3CDIV%3E%20%20%20%200xFF%2C%200xFF%3C%2FDIV%3E%3CDIV%3E%23define%20EC_PARAM_secp521r1_a%20%5C%3C%2FDIV%3E%3CDIV%3E%20%20%20%200x01%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%3C%2FDIV%3E%3CDIV%3E%20%20%20%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%3C%2FDIV%3E%3CDIV%3E%20%20%20%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%3C%2FDIV%3E%3CDIV%3E%20%20%20%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%3C%2FDIV%3E%3CDIV%3E%20%20%20%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%3C%2FDIV%3E%3CDIV%3E%20%20%20%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%3C%2FDIV%3E%3CDIV%3E%20%20%20%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%3C%2FDIV%3E%3CDIV%3E%20%20%20%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%3C%2FDIV%3E%3CDIV%3E%20%20%20%200xFF%E3%80%810xFC%3C%2FDIV%3E%3CDIV%3E%23define%20EC_PARAM_secp521r1_b%20%5C%3C%2FDIV%3E%3CDIV%3E%20%20%20%200x00%2C0x51%2C0x95%2C0x3E%2C0xB9%2C0x61%2C0x8E%2C0x1C%2C%EF%BC%88...%3C%2FDIV%3E%3CDIV%3E%20%20%20%200x9A%E3%80%810x1F%E3%80%810x92%E3%80%810x9A%E3%80%810x21%E3%80%810xA0%E3%80%810xB6%E3%80%810x85%E3%80%81%EF%BC%88%20%EF%BC%89%E3%80%82%3C%2FDIV%3E%3CDIV%3E%20%20%20%200x40%2C0xEE%2C0xA2%2C0xDA%2C0x72%2C0x5B%2C0x99%2C0xB3%2C%EF%BC%88%20%EF%BC%89%E3%80%82%3C%2FDIV%3E%3CDIV%3E%20%20%20%200x15%2C0xF3%2C0xB8%2C0xB4%2C0x89%2C0x91%2C0x8E%2C0xF1%2C%EF%BC%88%20%EF%BC%89%E3%80%82%3C%2FDIV%3E%3CDIV%3E%20%20%20%200x09%2C%200xE1%2C%200x56%2C%200x19%2C%200x39%2C%200x51%2C%200xEC%2C%200x7E%2C%5C%3C%2FDIV%3E%3CDIV%3E%20%20%20%200x93%2C0x7B%2C0x16%2C0x52%2C0xC0%2C0xBD%2C0x3B%2C0xB1%2C%EF%BC%88...%3C%2FDIV%3E%3CDIV%3E%20%20%20%200xBF%E3%80%810x07%E3%80%810x35%E3%80%810x73%E3%80%810xDF%E3%80%810x88%E3%80%810x3D%E3%80%810x2C%3C%2FDIV%3E%3CDIV%3E%20%20%20%200x34%2C%200xF1%2C%200xEF%2C%200x45%2C%200x1F%2C%200xD4%2C%200x6B%2C%200x50%2C%5C%3C%2FDIV%3E%3CDIV%3E%20%20%20%200x3F%EF%BC%8C0x00%3C%2FDIV%3E%3CDIV%3E%23define%20EC_PARAM_secp521r1_x%20%5C%3C%2FDIV%3E%3CDIV%3E%20%20%20%200x00%2C%200xC6%2C%200x85%2C%200x8E%2C%200x06%2C%200xB7%2C%200x04%2C%200x04%2C%20%5C%3C%2FDIV%3E%3CDIV%3E%20%20%20%200xE9%2C%200xCD%2C%200x9E%2C%200x3E%2C%200xCB%2C%200x66%2C%200x23%2C%200x95%2C%5C%3C%2FDIV%3E%3CDIV%3E%20%20%20%200xB4%E3%80%810x42%E3%80%810x9C%E3%80%810x64%E3%80%810x81%E3%80%810x39%E3%80%810x05%E3%80%810x3F%E3%80%81%EF%BC%88%20%EF%BC%89%E3%80%82%3C%2FDIV%3E%3CDIV%3E%20%20%20%200xB5%2C%200x21%2C%200xF8%2C%200x28%2C%200xAF%2C%200x60%2C%200x6B%2C%200x4D%2C%5C%3C%2FDIV%3E%3CDIV%3E%20%20%20%200x3D%E3%80%810xBA%E3%80%810xA1%E3%80%810x4B%E3%80%810x5E%E3%80%810x77%E3%80%810xEF%E3%80%810xE7%3C%2FDIV%3E%3CDIV%3E%20%20%20%200x59%2C%200x28%2C%200xFE%2C%200x1D%2C%200xC1%2C%200x27%2C%200xA2%2C%200xFF%2C%5C%3C%2FDIV%3E%3CDIV%3E%20%20%20%200xA8%E3%80%810xDE%E3%80%810x33%E3%80%810x48%E3%80%810xB3%E3%80%810xC1%E3%80%810x85%E3%80%810x6A%E3%80%81%EF%BC%88%20%EF%BC%89%E3%80%82%3C%2FDIV%3E%3CDIV%3E%20%20%20%200x42%2C%200x9B%2C%200xF9%2C%200x7E%2C%200x7E%2C%200x31%2C%200xC2%2C%200xE5%2C%5C%3C%2FDIV%3E%3CDIV%3E%20%20%20%200xBD%E3%80%810x66%3C%2FDIV%3E%3CDIV%3E%23define%20EC_PARAM_secp521r1_y%20%5C%3C%2FDIV%3E%3CDIV%3E%20%20%20%200x01%2C%200x18%2C%200x39%2C%200x29%2C%200x6A%2C%200x78%2C%200x9A%2C%200x3B%2C%5C%3C%2FDIV%3E%3CDIV%3E%20%20%20%200xC0%2C%200x04%2C%200x5C%2C%200x8A%2C%200x5F%2C%200xB4%2C%200x2C%2C%200x7D%2C%5C%3C%2FDIV%3E%3CDIV%3E%20%20%20%200x1B%2C%200xD9%2C%200x98%2C%200xF5%2C%200x44%2C%200x49%2C%200x57%2C%200x9B%2C%5C%3C%2FDIV%3E%3CDIV%3E%20%20%20%200x44%2C%200x68%2C%200x17%2C%200xAF%2C%200xBD%2C%200x17%2C%200x27%2C%200x3E%2C%5C%3C%2FDIV%3E%3CDIV%3E%20%20%20%200x66%2C%200x2C%2C%200x97%2C%200xEE%2C%200x72%2C%200x99%2C%200x5E%2C%200xF4%2C%5C%3C%2FDIV%3E%3CDIV%3E%20%20%20%200x26%2C%200x40%2C%200xC5%2C%200x50%2C%200xB9%2C%200x01%2C%200x3F%2C%200xAD%2C%5C%3C%2FDIV%3E%3CDIV%3E%20%20%20%200x07%2C%200x61%2C%200x35%2C%200x3C%2C%200x70%2C%200x86%2C%200xA2%2C%200x72%2C%5C%3C%2FDIV%3E%3CDIV%3E%20%20%20%200xC2%E3%80%810x40%E3%80%810x88%E3%80%810xBE%E3%80%810x94%E3%80%810x76%E3%80%810x9F%E3%80%810xD1%E3%80%810xD1%3C%2FDIV%3E%3CDIV%3E%20%20%20%200x66%2C%200x50%3C%2FDIV%3E%3CDIV%3E%23define%20EC_PARAM_secp521r1_order%20%5C%3C%2FDIV%3E%3CDIV%3E%20%20%20%200x01%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%3C%2FDIV%3E%3CDIV%3E%20%20%20%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%3C%2FDIV%3E%3CDIV%3E%20%20%20%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%3C%2FDIV%3E%3CDIV%3E%20%20%20%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%2C%200xFF%3C%2FDIV%3E%3CDIV%3E%20%20%20%200xFF%2C%200xFA%2C%200x51%2C%200x86%2C%200x87%2C%200x83%2C%200xBF%2C%200x2F%2C%5C%3C%2FDIV%3E%3CDIV%3E%20%20%20%200x96%2C0x6B%2C0x7F%2C0xCC%2C0x01%2C0x48%2C0xF7%2C0x09%2C%EF%BC%88%20%EF%BC%89%E3%80%82%3C%2FDIV%3E%3CDIV%3E%20%20%20%200xA5%2C%200xD0%2C%200x3B%2C%200xB5%2C%200xC9%2C%200xB8%2C%200x89%2C%200x9C%2C%5C%3C%2FDIV%3E%3CDIV%3E%20%20%20%200x47%2C%200xAE%2C%200xBB%2C%200x6F%2C%200xB7%2C%200x1E%2C%200x91%2C%200x38%2C%5C%3C%2FDIV%3E%3CDIV%3E%20%20%20%200x64%EF%BC%8C0x09%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EcurveID%20%3D%20kSE05x_ECCurve_NIST_P521%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%20%20%20%20status%20%3D%20Se05x_API_ReadECCurveList(%26amp%3Bse05x_session%EF%BC%8CcurveList%EF%BC%8C%26amp%3BcurveListLen)%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20if%20(status%20!%3D%20SM_OK)%20%7B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20SMLOG_E(%22Error%20in%20Se05x_API_ReadECCurveList%20%5Cn%22)%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%E5%90%A6%E5%88%99%20%7B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%E5%A6%82%E6%9E%9C%20(curveList%5BcurveID%20-%201%5D%20%3D%3D%20kSE05x_SetIndicator_SET)%20%7B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%20%20%20%20SMLOG_I(%22curveID%20%3D%250x%20already%20exists%20%5Cn%22%2C%20curveID)%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%E5%90%A6%E5%88%99%20%7B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%20%20%20%20status%20%3D%20ex_se05x_create_curve_p521(%26amp%3Bse05x_session%EF%BC%8CcurveID)%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%20%20%20%20if%20(status%20!%3D%20SM_OK)%20%7B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20SMLOG_I(%22Error%20in%20ex_se05x_create_curve%20%5Cn%22)%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Estatus%20%3D%20Se05x_API_CheckObjectExists(%26amp%3Bse05x_session%EF%BC%8CkeyID%EF%BC%8C%26amp%3Bresult)%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%20%20%20%20if%20(status%20!%3D%20SM_OK)%20%7B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20SMLOG_E(%22%5BSE050%5D%20Error%20in%20Se05x_API_CheckObjectExists%20%5Cn%22)%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%E8%BF%94%E5%9B%9E%20SE050_FAILURE%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%E5%A6%82%E6%9E%9C%20(result%20%3D%3D%20kSE05x_Result_SUCCESS)%20%7B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20curveID%20%3D%20kSE05x_ECCurve_NA%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20status%20%3D%20Se05x_API_WriteECKey(%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%26amp%3Bse05x_session%EF%BC%8CNULL%EF%BC%8C0%EF%BC%8CkeyID%EF%BC%8CcurveID%EF%BC%8CNULL%EF%BC%8C0%EF%BC%8CNULL%EF%BC%8C0%EF%BC%8CkSE05x_INS_NA%EF%BC%8CkSE05x_KeyPart_Pair%EF%BC%89%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20if%20(status%20!%3D%20SM_OK)%20%7B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20SMLOG_E(%22%5BSE050%5D%20Error%20in%20Se05x_API_WriteECKey%20%5Cn%22)%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20Se05x_Delete_Session(keyID)%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%E8%BF%94%E5%9B%9E%20SE050_FAILURE%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Euint8_t%20key_buf%5B256%5D%20%3D%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%200%2C%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%7D%3B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20size_t%20key_buflen%20%3D%20sizeof(key_buf)%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Estatus%20%3D%20Se05x_API_ReadObject(%26amp%3Bse05x_session%EF%BC%8CkeyID%EF%BC%8C0%EF%BC%8C0%EF%BC%8Ckey_buf%EF%BC%8C%26amp%3Bkey_buflen)%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%20%20%20%20if%20(status%20!%3D%20SM_OK)%20%7B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20SMLOG_E(%22Error%20in%20Se05x_API_ReadObject%20%5Cn%22)%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%E8%BF%94%E5%9B%9E%20SE050_FAILURE%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FDIV%3E%3CDIV%3ESureshkumar%20R%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2259680%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Unable%20to%20Retrieve%20ECC%20Curve%20Details%20from%20SE050%20using%20Plug%20%26amp%3B%20Trust%20Nano%20Package%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2259680%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%81%A9%E6%99%BA%E6%B5%A6%E3%80%81%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E8%83%BD%E5%B0%B1%E4%B8%8A%E8%BF%B0%E8%AF%A2%E9%97%AE%E6%8F%90%E4%BE%9B%E5%B8%AE%E5%8A%A9%EF%BC%8C%E5%B0%86%E4%B8%8D%E8%83%9C%E6%84%9F%E6%BF%80%E3%80%82%20%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
