Setting AES-GCM Authentication Tag Length to 12 Bytes for DLMS with SE050E2
5,738件の閲覧回数
Faizy98
I am currently using the SE050E2 secure element for AES-GCM encryption and decryption operations. The encryption and decryption APIs work well, specifically the following function:
sss_status_t sss_aead_one_go( sss_aead_t *context, const uint8_t *srcData, uint8_t *destData, size_t size, uint8_t *nonce, size_t nonceLen, const uint8_t *aad, size_t aadLen, uint8_t *tag, size_t *tagLen);
This API functions perfectly when the authentication tag length is 16 bytes. However, I am working with DLMS protocol payloads that require the authentication tag to be only 12 bytes in length.
When I use this API to encrypt DLMS plain data, it generates an authentication tag of 16 bytes, but the DLMS standard expects a 12-byte tag. Similarly, for decryption, when the encrypted DLMS payload arrives with a 12-byte authentication tag, passing this 12-byte tag to the API results in a decryption failure, because the API expects the tag to be 16 bytes.
My question is:
Is there any way to configure or set the authentication tag length in the SE050E2 or its middleware so it can use a 12-byte tag as required by the DLMS standard?
Currently, the API always returns a 16-byte tag after encryption, and requires a 16-byte tag for decryption. I want to ensure compatibility with DLMS devices that use 12-byte tags without causing decryption errors.
Any guidance on configuring AES-GCM tag length for SE050E2, or recommended approaches for handling this DLMS tag size mismatch, would be highly appreciated.
Thanks in advance!
BR,
Faizy
5,680件の閲覧回数
Kan_Li
Hi @Faizy98 ,
This is defined when you create the key for AEAD operation. please kindly refer to the following for details.
Kan
2 返答(返信)
5,681件の閲覧回数
Kan_Li
Hi @Faizy98 ,
Kan
5,661件の閲覧回数
Faizy98
Thank you for your support.
BR,
Faizy
%3CLINGO-SUB%20id%3D%22lingo-sub-2150265%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ESE050E2%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%20DLMS%20%E3%81%AE%20AES-GCM%20%E8%AA%8D%E8%A8%BC%E3%82%BF%E3%82%B0%E3%81%AE%E9%95%B7%E3%81%95%E3%82%92%2012%20%E3%83%90%E3%82%A4%E3%83%88%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2150265%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20class%3D%22%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%20class%3D%22%22%3E%E7%8F%BE%E5%9C%A8%E3%80%81AES-GCM%20%E6%9A%97%E5%8F%B7%E5%8C%96%E3%81%8A%E3%82%88%E3%81%B3%E5%BE%A9%E5%8F%B7%E5%8C%96%E6%93%8D%E4%BD%9C%E3%81%AB%20SE050E2%20%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%20%E3%82%A8%E3%83%AC%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E6%9A%97%E5%8F%B7%E5%8C%96%E3%81%8A%E3%82%88%E3%81%B3%E5%BE%A9%E5%8F%B7%E5%8C%96%20API%20%E3%81%AF%E3%80%81%E7%89%B9%E3%81%AB%E6%AC%A1%E3%81%AE%E9%96%A2%E6%95%B0%E3%81%A7%E9%81%A9%E5%88%87%E3%81%AB%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3E%3CSTRONG%3Esss_status_t%20sss_aead_one_go(%20sss_aead_t%20*context%E3%80%81const%20uint8_t%20*srcData%E3%80%81uint8_t%20*destData%E3%80%81size_t%20size%E3%80%81uint8_t%20*nonce%E3%80%81size_t%20nonceLen%E3%80%81const%20uint8_t%20*aad%E3%80%81size_t%20aadLen%E3%80%81uint8_t%20*tag%E3%80%81size_t%20*tagLen)%3B%3CBR%20%2F%3E%3C%2FSTRONG%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3E%E3%81%93%E3%81%AE%20API%20%E3%81%AF%E3%80%81%E8%AA%8D%E8%A8%BC%E3%82%BF%E3%82%B0%E3%81%AE%E9%95%B7%E3%81%95%E3%81%8C%2016%20%E3%83%90%E3%82%A4%E3%83%88%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AB%E5%AE%8C%E5%85%A8%E3%81%AB%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E8%AA%8D%E8%A8%BC%E3%82%BF%E3%82%B0%E3%81%AE%E9%95%B7%E3%81%95%E3%81%8C%2012%20%E3%83%90%E3%82%A4%E3%83%88%E3%81%AE%E3%81%BF%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E8%A6%81%E6%B1%82%E3%81%99%E3%82%8B%20DLMS%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%9A%E3%82%A4%E3%83%AD%E3%83%BC%E3%83%89%E3%82%92%E6%89%B1%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%20class%3D%22%22%3E%E3%81%93%E3%81%AE%20API%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20DLMS%20%E3%83%97%E3%83%AC%E3%83%BC%E3%83%B3%20%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E6%9A%97%E5%8F%B7%E5%8C%96%E3%81%99%E3%82%8B%E3%81%A8%E3%80%8116%20%E3%83%90%E3%82%A4%E3%83%88%E3%81%AE%E8%AA%8D%E8%A8%BC%E3%82%BF%E3%82%B0%E3%81%8C%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81DLMS%20%E6%A8%99%E6%BA%96%E3%81%A7%E3%81%AF%2012%20%E3%83%90%E3%82%A4%E3%83%88%E3%81%AE%E3%82%BF%E3%82%B0%E3%81%8C%E6%83%B3%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E5%90%8C%E6%A7%98%E3%81%AB%E3%80%81%E5%BE%A9%E5%8F%B7%E5%8C%96%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E6%9A%97%E5%8F%B7%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%20DLMS%20%E3%83%9A%E3%82%A4%E3%83%AD%E3%83%BC%E3%83%89%E3%81%8C%2012%20%E3%83%90%E3%82%A4%E3%83%88%E3%81%AE%E8%AA%8D%E8%A8%BC%E3%82%BF%E3%82%B0%E3%81%A8%E3%81%A8%E3%82%82%E3%81%AB%E5%88%B0%E7%9D%80%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81API%20%E3%81%AF%E3%82%BF%E3%82%B0%E3%81%8C%2016%20%E3%83%90%E3%82%A4%E3%83%88%E3%81%A7%E3%81%82%E3%82%8B%E3%81%A8%E6%83%B3%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%81%93%E3%81%AE%2012%20%E3%83%90%E3%82%A4%E3%83%88%E3%81%AE%E3%82%BF%E3%82%B0%E3%82%92%20API%20%E3%81%AB%E6%B8%A1%E3%81%99%E3%81%A8%E5%BE%A9%E5%8F%B7%E5%8C%96%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20class%3D%22%22%3E%E7%A7%81%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%3A%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSTRONG%3EDLMS%20%E6%A8%99%E6%BA%96%E3%81%A7%E8%A6%81%E6%B1%82%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%2012%20%E3%83%90%E3%82%A4%E3%83%88%E3%81%AE%E3%82%BF%E3%82%B0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81SE050E2%20%E3%81%BE%E3%81%9F%E3%81%AF%E3%81%9D%E3%81%AE%E3%83%9F%E3%83%89%E3%83%AB%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A7%E8%AA%8D%E8%A8%BC%E3%82%BF%E3%82%B0%E3%81%AE%E9%95%B7%E3%81%95%E3%82%92%E6%A7%8B%E6%88%90%E3%81%BE%E3%81%9F%E3%81%AF%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%E7%8F%BE%E5%9C%A8%E3%80%81API%20%E3%81%AF%E6%9A%97%E5%8F%B7%E5%8C%96%E5%BE%8C%E3%81%AB%E5%B8%B8%E3%81%AB%2016%20%E3%83%90%E3%82%A4%E3%83%88%E3%81%AE%E3%82%BF%E3%82%B0%E3%82%92%E8%BF%94%E3%81%97%E3%80%81%E5%BE%A9%E5%8F%B7%E5%8C%96%E3%81%AB%E3%81%AF%2016%20%E3%83%90%E3%82%A4%E3%83%88%E3%81%AE%E3%82%BF%E3%82%B0%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%E5%BE%A9%E5%8F%B7%E5%8C%96%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E7%99%BA%E7%94%9F%E3%81%95%E3%81%9B%E3%81%9A%E3%81%AB%E3%80%8112%20%E3%83%90%E3%82%A4%E3%83%88%E3%81%AE%E3%82%BF%E3%82%B0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%20DLMS%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A8%E3%81%AE%E4%BA%92%E6%8F%9B%E6%80%A7%E3%82%92%E7%A2%BA%E4%BF%9D%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20class%3D%22%22%3ESE050E2%20%E3%81%AE%20AES-GCM%20%E3%82%BF%E3%82%B0%E3%81%AE%E9%95%B7%E3%81%95%E3%82%92%E6%A7%8B%E6%88%90%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%82%AC%E3%82%A4%E3%83%80%E3%83%B3%E3%82%B9%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E3%81%93%E3%81%AE%20DLMS%20%E3%82%BF%E3%82%B0%20%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AE%E4%B8%8D%E4%B8%80%E8%87%B4%E3%82%92%E5%87%A6%E7%90%86%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E6%8E%A8%E5%A5%A8%E3%82%A2%E3%83%97%E3%83%AD%E3%83%BC%E3%83%81%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81%E3%81%9C%E3%81%B2%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%20class%3D%22%22%3E%E5%89%8D%E3%82%82%E3%81%A3%E3%81%A6%E6%84%9F%E8%AC%9D%E3%81%97%E3%81%BE%E3%81%99%EF%BC%81%3CBR%20%2F%3E%3CBR%20%2F%3E%20BR%E3%80%81%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%82%B8%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2152408%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Setting%20AES-GCM%20Authentication%20Tag%20Length%20to%2012%20Bytes%20for%20DLMS%20with%20SE050E2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2152408%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%86%8D%E9%96%8B%E3%81%BE%E3%81%A7%E4%BB%8A%E3%81%97%E3%81%B0%E3%82%89%E3%81%8F%E3%81%8A%E5%BE%85%E3%81%A1%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3EBR%E3%80%81%3C%2FP%3E%3CP%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%82%B8%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2152249%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Setting%20AES-GCM%20Authentication%20Tag%20Length%20to%2012%20Bytes%20for%20DLMS%20with%20SE050E2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2152249%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F253702%22%20target%3D%22_blank%22%3E%40Faizy98%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81AEAD%20%E6%93%8D%E4%BD%9C%E3%81%AE%E3%82%AD%E3%83%BC%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AB%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E8%A9%B3%E7%B4%B0%E3%81%AF%E4%B8%8B%E8%A8%98%E3%82%92%E3%81%94%E5%8F%82%E7%85%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Kan_Li_1-1755162576795.png%22%20style%3D%22width%3A%20569px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_1-1755162576795.png%22%20style%3D%22width%3A%20569px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F352423iF3080388BF9D9892%2Fimage-dimensions%2F569x498%3Fv%3Dv2%22%20width%3D%22569%22%20height%3D%22498%22%20role%3D%22button%22%20title%3D%22Kan_Li_1-1755162576795.png%22%20alt%3D%22Kan_Li_1-1755162576795.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EKan_Li_1-1755162576795.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%81%99%E3%81%A6%E3%81%8D%E3%81%AA%E4%B8%80%E6%97%A5%E3%82%92%E3%80%81%3CBR%20%2F%3E%E3%82%AB%E3%83%B3%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E---------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%E8%A8%98%EF%BC%9A%3CBR%20%2F%3E%20-%20%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%8C%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%B8%E3%81%AE%E5%9B%9E%E7%AD%94%E3%81%A7%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%80%8C%E6%AD%A3%E8%A7%A3%E3%81%A8%E3%81%97%E3%81%A6%E3%83%9E%E3%83%BC%E3%82%AF%E3%80%8D%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%EF%BC%81%3CBR%20%2F%3E%20-%20Thread%E3%81%AF%E6%9C%80%E5%BE%8C%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%8B%E3%82%897%E9%80%B1%E9%96%93%E3%83%95%E3%82%A9%E3%83%AD%E3%83%BC%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E4%BB%A5%E9%99%8D%E3%81%AE%E8%BF%94%E4%BF%A1%E3%81%AF%E7%84%A1%E8%A6%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E5%BE%8C%E3%81%BB%E3%81%A9%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%96%B0%E3%81%97%E3%81%84Thread%E3%82%92%E9%96%8B%E3%81%84%E3%81%A6%E3%80%81%E9%96%89%E3%81%98%E3%81%9FThread%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E---------------------------------------------------------------------------------%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
