Se05x_API_PBKDF2 Failed in WiFiKDF_derive example
3,349 次查看
Tlabs
Hi all,
i tried the ex_se05x-WiFiKDF_derive example which allways fails on my SE051. Using this example with default ECKeys and an ECKey Session based on the rapsberry pi examples. I will attach the debug output.
I tried to call Se05x_API_PBKDF2 in the ex_se05_WiFiKDF_example on the raspberry pi.
App :INFO :Deriving PBKDF2 for wifi_ssid='some-wifi-ssid', WIFI_COUNT='10000'
it allways fails with:
sss :WARN :nxEnsure:'ret == SM_OK' failed. At Line:6992 Function:sss_se05x_TXn
App :ERROR:Se05x_API_PBKDF2 Failed
App :INFO :Done
App :INFO :ex_sss Finished
App :ERROR:ex_sss_entry Failed
APDU :DEBUG:PBKDF2 []
APDU :DEBUG:kSE05x_TAG_1 [4-byte password identifier (object type must be HMACKey)] = 0x7D51F001
APDU :DEBUG:kSE05x_TAG_2 [salt] (Len=14)
73 6F 6D 65 2D 77 69 66 69 2D 73 73 69 64
APDU :DEBUG:kSE05x_TAG_3 [count] = 0x2710
APDU :DEBUG:kSE05x_TAG_4 [requestedLen] = 0x20
scp :DEBUG:FN: nxSCP03_Encrypt_CommandAPDU
scp :DEBUG: Input:cmdBuf (Len=30)
41 04 7D 51 F0 01 42 0E 73 6F 6D 65 2D 77 69 66
69 2D 73 73 69 64 43 02 27 10 44 02 00 20
scp :DEBUG:FN: nxSCP03_PadCommandAPDU
scp :DEBUG:Input: cmdBuf (Len=30)
scp :DEBUG:Ouput: cmdBuf (Len=32)
69 2D 73 73 69 64 43 02 27 10 44 02 00 20 80 00
scp :DEBUG:FN: nxSCP03_Calculate_CommandICV
scp :DEBUG: Output: (Len=8)
C8 1E 96 37 77 FC AE 12
scp :DEBUG:Encrypt CommandAPDU
scp :DEBUG:cmdBuf (Len=32)
10 3C 38 8F 36 62 2A A8 9A C4 B8 AD 38 48 11 FE
4F 28 36 48 C7 DB 82 53 CC B3 18 7A 2B 70 D4 FC
scp :DEBUG:Output: EncryptedcmdBuf (Len=32)
scp :DEBUG:FN: nxpSCP03_CalculateMac_CommandAPDU
scp :DEBUG:Input: cmdBuf (Len=37)
84 03 00 2E 28 10 3C 38 8F 36 62 2A A8 9A C4 B8
AD 38 48 11 FE 4F 28 36 48 C7 DB 82 53 CC B3 18
7A 2B 70 D4 FC
scp :DEBUG:Output: mac (Len=8)
3A 69 CE 15 98 FB 0B FD
smCom :DEBUG:APDU Tx> (Len=62)
80 05 00 00 39 10 08 01 9F 0A DD A0 37 6E 9E 41
2D 84 03 00 2E 28 10 3C 38 8F 36 62 2A A8 9A C4
B8 AD 38 48 11 FE 4F 28 36 48 C7 DB 82 53 CC B3
18 7A 2B 70 D4 FC 3A 69 CE 15 98 FB 0B FD
smCom :DEBUG:Enter phNxpEseProto7816_Transceive
smCom :DEBUG:Transceive data ptr 0x0xbee9e000 len:62
smCom :DEBUG:I-Frame Data Len: 62 Seq. no:1
smCom :DEBUG:TransceiveProcess nextTransceiveState 1
smCom :DEBUG:phNxpEse_WriteFrame Enter ..
smCom :DEBUG:RAW Tx> (Len=67)
5A 40 3E 80 05 00 00 39 10 08 01 9F 0A DD A0 37
6E 9E 41 2D 84 03 00 2E 28 10 3C 38 8F 36 62 2A
A8 9A C4 B8 AD 38 48 11 FE 4F 28 36 48 C7 DB 82
53 CC B3 18 7A 2B 70 D4 FC 3A 69 CE 15 98 FB 0B
FD 8F 46
smCom :DEBUG:phNxpEse_read Enter ..
smCom :DEBUG:phPalEse_i2c_read Read Requested 2 bytes
smCom :DEBUG:_i2c_read() error : 13
smCom :DEBUG:_i2c_read() [HDR]errno : 79 ret : FFFFFFFF
smCom :DEBUG:phNxpEse_readPacket Normal Pkt, delay read 1ms
smCom :DEBUG:phNxpEse_readPacket Read HDR
smCom :DEBUG:phNxpEse_readPacket SOF FOUND
smCom :DEBUG:phPalEse_i2c_read Read Requested 1 bytes
smCom :DEBUG:poll_sof_chained_delay value is 0
smCom :DEBUG:phPalEse_i2c_read Read Requested 4 bytes
smCom :DEBUG:RAW Rx< (Len=7)
A5 40 02 69 86 9B F3
smCom :DEBUG:phNxpEseProto7816_ProcessResponse p_data ----> 0x186b3b0 len ----> 0x7
smCom :DEBUG:Received CRC:0x9bf3 Calculated CRC:0x9bf3
smCom :DEBUG:Retry Counter = 0
smCom :DEBUG:phNxpEseProto7816_DecodeFrame I-Frame Received
smCom :DEBUG:phNxpEseProto7816_DecodeFrame I-Frame lastRcvdIframeInfo.seqNo:0x1
smCom :DEBUG:Data[0]=0x69 len=2 Data[1]=0x69 Data[2]=0x86
smCom :DEBUG: phNxpEse_Transceive Exit status 0x0
smCom :DEBUG:APDU Rx< (Len=2)
69 86
scp :DEBUG:Inc_CommandCounter value (Len=16)
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03
App :INFO :Done
APDU :DEBUG:CloseSession []
scp :DEBUG: Input:cmdBuf (Len=0)
scp :DEBUG:Input: cmdBuf (Len=5)
84 04 00 1C 08
36 7D F2 32 70 06 6B FB
smCom :DEBUG:APDU Tx> (Len=30)
80 05 00 00 19 10 08 01 9F 0A DD A0 37 6E 9E 41
0D 84 04 00 1C 08 36 7D F2 32 70 06 6B FB
smCom :DEBUG:Transceive data ptr 0x0xbee9e0a8 len:30
smCom :DEBUG:I-Frame Data Len: 30 Seq. no:0
smCom :DEBUG:RAW Tx> (Len=35)
5A 00 1E 80 05 00 00 19 10 08 01 9F 0A DD A0 37
6E 9E 41 0D 84 04 00 1C 08 36 7D F2 32 70 06 6B
FB 9F F2
smCom :DEBUG:phPalEse_i2c_read Read Requested 12 bytes
smCom :DEBUG:RAW Rx< (Len=15)
A5 00 0A 1E 15 ED DD 2A A3 2C E7 90 00 06 C1
smCom :DEBUG:phNxpEseProto7816_ProcessResponse p_data ----> 0x186b3b0 len ----> 0xf
smCom :DEBUG:Received CRC:0x6c1 Calculated CRC:0x6c1
smCom :DEBUG:phNxpEseProto7816_DecodeFrame I-Frame lastRcvdIframeInfo.seqNo:0x0
smCom :DEBUG:Data[0]=0x1e len=10 Data[9]=0x90 Data[10]=0x0
smCom :DEBUG:APDU Rx< (Len=10)
scp :DEBUG:FN: nxpSCP03_Decrypt_ResponseAPDU
scp :DEBUG: Input:rspBuf (Len=10)
scp :DEBUG: Calculated RMAC : (Len=16)
1E 15 ED DD 2A A3 2C E7 1C 63 E8 5E BB F1 81 62
scp :DEBUG:Verify MAC
scp :DEBUG:RMAC verified successfully...Decrypt Response Data
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04
smCom :DEBUG:TransceiveProcess nextTransceiveState 6
smCom :DEBUG:S-Frame PCB: c5
smCom :DEBUG:RAW Tx> (Len=5)
5A C5 00 47 82
smCom :DEBUG:RAW Rx< (Len=5)
A5 E5 00 87 67
smCom :DEBUG:phNxpEseProto7816_ProcessResponse p_data ----> 0x186b3b0 len ----> 0x5
smCom :DEBUG:Received CRC:0x8767 Calculated CRC:0x8767
smCom :DEBUG:phNxpEseProto7816_DecodeFrame S-Frame Received
smCom :DEBUG:phNxpEse_close - ESE Context deinit completed
App :INFO :Closing Host Session
App :ERROR:!ERROR! ret != 0.
6 回复数
3,316 次查看
Tlabs
Now its working but if i set the Count to 10.000 is not working with:
App :INFO :ex_sss_entry started
smCom :ERROR:phNxpEseProto7816_DecodeFrame Interface Reset to eSE wtx count reached!!!
App :INFO :Done
scp :ERROR: RESPONSE MAC DID NOT VERIFY 7042
Does anybody know the reason?
3,279 次查看
Kan_Li
Hi @Tlabs ,
Do you mean it works with count of 4096 but failed with count of 10000? Please kindly clarify.
Kan
3,273 次查看
Tlabs
Hi Kan,
Yes 4096 is working but 10.000 not.
Any idea?
Thx.
Torsten
3,185 次查看
Kan_Li
Hi @Tlabs ,
I just got the solution from the expert team, and they suggested increasing PH_PROTO_WTX_DEFAULT_COUNT in simw-top\hostlib\hostLib\libCommon\smCom\T1oI2C\phNxpEseProto7816_3.h and this solution has been verified on my side. please kindly refer to the following for details.
In my test, PH_PROTO_WTX_DEFAULT_COUNT was updated to 1000, you may try it as well on your side.
Please kindly let me if the problem is still there.
Kan
3,259 次查看
Kan_Li
Hi @Tlabs ,
Thanks for the clarification! but why do you use 10k iterations of PBKDF2? The Wifi spec uses only 4096 as far as I know. I will check if it is possible to run with 10k count.
Kan
3,320 次查看
Kan_Li
Hi @Tlabs ,
There is some issue with the policy of the symmetric key injected by ex_se05x_WiFiKDF_inject, so that it leads to the failure in WiFiKDF_derive example. Please apply the attached patch and try again.
Apply patch as
cd simw-top\demos
git apply ex_se05x_WiFiKDF.patch
Hope that helps,
Kan
