SE051C2: all Secure Object operations return 0x6985 while GetRandom works over the same authenticate
397件の閲覧回数
winetime
## The problem in one line
On an **SE051C2**, every command that touches the applet's object store returns
**0x6985 (CONDITIONS NOT SATISFIED)** — while `GetRandom` succeeds on the *same*
session, including over the armed Platform SCP03 channel.
## Our questions
**Q1. Is this part in a "mandate platform SCP" / RESTRICTED / transport state?**
Both of our samples are as-delivered, and one is factory-fresh. If SE051C2 ships with
the object store locked until the Platform SCP03 keys are rotated off the NXP
defaults, that would explain every observation below exactly. If so, what is the
documented procedure to leave that state?
**Q2. Do object operations require customer-key (rotated) Platform SCP03, rather than
the default platform keys?** Our channel authenticates with the defaults and
demonstrably carries traffic — but every object command over it is refused.
**Q3. If Q1/Q2 are yes: how do we read UNIQUE_ID first?**
This is a chicken-and-egg that blocks us completely. Our platform-key derivation takes
the chip UID as its input, but `ReadObject(UNIQUE_ID)` is itself one of the refused
commands. What is the intended order of operations on a fresh part?
**Q4. Is there a GET DATA / GET STATUS we can issue that reports the applet's
lifecycle / VC state?** Stateless commands *do* work for us, so if such a query exists
we can confirm the part's state ourselves instead of guessing.
**Q5. What makes THIS part refuse ordinary object creation, when it evidently works
for others?** In the DeleteAll/0x6985 thread (m-p/1648349), step 1 was
`Se05x_API_WriteUserID(... FACTORY_RESET ...)` returning **0x9000** — a
WriteSecureObject succeeding on the default session with only platform SCP03. That is
precisely the class of command that fails for us. So object writes are *not* inherently
session-gated. Is the difference the variant/configuration (SE051C2 vs SE050), or the
platform keys still being NXP defaults?
**Q6. Is m-p/1716555 the same root cause?** There, another user reports
`Se05x_API_WriteUserID` returning `SM_ERR_CONDITIONS_OF_USE_NOT_SATISFIED` — our exact
symptom — and that question appears to have gone unanswered.
**Q7. Does `kSE05x_ECCurve_NIST_P256` require an explicit `Se05x_API_CreateECCurve` on
SE051C2, or is it built in?** (Minor — but we tried it, and even the CreateECCurve is
refused.)
## What we measured
| Check | Result | Meaning |
| `Se05x_API_SELECT` applet | **0x9000** | IoT applet selected |
| `Se05x_API_GetRandom` (plain) | real entropy | session + transport work |
| Platform SCP03 authenticate | **succeeds** | default key set matched |
| **GetRandom OVER the SCP03 channel** | **succeeds, real entropy** | encrypt + C-MAC + decrypt verified |
| Second wrapped command back-to-back | **succeeds** | command counter stays in sync |
| `WriteECKey` NIST P-256 (generate) | **0x6985** | |
| `WriteECKey` secp256k1 (import) | **0x6985** | `CreateCurve_secp256k1` IS called first |
| `WriteECKey` Ed25519 (import) | **0x6985** | built-in curve, no CreateCurve needed |
| `ReadObject(UNIQUE_ID)` | **0x6985** | no policy argument involved |
| `WriteBinary_Ver` (with file policy) | **0x6985** | file objects fail too |
| `CreateECCurve(NIST_P256)` | **0x6985** | even creating a curve is refused |
| `CheckObjectExists` | **0x6985** | cannot even test for an object |
**`GetRandom` is the only command that works.** Every object-store operation returns
0x6985 — on both samples, plain or SCP03-wrapped.
## Already ruled out by experiment
1. **Not the part.** A second, factory-fresh SE051C2 behaves identically.
2. **Not the transport or session.** SELECT returns 0x9000; GetRandom returns real
entropy on the same session.
3. **Not a broken or missing Platform SCP03 channel.** Authenticate succeeds against
the default key set and — decisively — a `GetRandom` issued **over the armed
channel** returns real entropy, as does a second back-to-back (command counter in
sync). Encrypt + C-MAC + response decrypt all verified. The failing object commands
are carried by a channel we have proven functional.
4. **Not a missing key policy.** We passed a real `Se05xPolicy_t`
(`ALLOW_SIGN|VERIFY|KA|READ|WRITE|GEN`, authID 0) to every `WriteECKey`. No change.
(It could not explain the UNIQUE_ID read anyway — `ReadObject` takes no policy.)
5. **Not a missing curve.** `CreateCurve_secp256k1` is called before the secp256k1
import, Ed25519 is built in, and `Se05x_API_CreateECCurve(NIST_P256)` **also**
returns 0x6985.
6. **Not command ordering.** Same 0x6985 whether issued on the plain session or on the
authenticated SCP03 channel.
7. **Not the middleware auth build configuration.** Rebuilt with
`SSS_HAVE_SE05X_AUTH_PLATFSCP03=1`, `SSS_HAVE_SE05X_AUTH_NONE=0` and
`SSSFTR_SE05X_AuthSession=1` (they had been NONE / 0). No change.
## Environment
* Part: **SE051C2** — two samples, one factory-fresh, identical behaviour
* Host: STM32L562, bare-metal, TrustZone secure world, I2C1 @ 100 kHz, T=1
* Middleware: vendored NXP Plug & Trust `Se05x_API_*` over a custom
`smCom_TransceiveRaw` transport (our own T=1 framing — SELECT and GetRandom prove
it works). Full middleware, **not** nano-package.
* Platform SCP03: NXP default keys; authenticate succeeds and carries traffic
タグ(1)
349件の閲覧回数
winetime
Hi @Kan_Li  — closing this out. **It was our side, and the diagnosis was wrong from the
start.** Posting the resolution in case it helps someone else.
The part is fine. Once I instrumented a whole-boot APDU trace instead of reading
individual results, a clean power-up gave 83 APDUs with 80 of them 0x9000 — object
creation, secp256k1 key generation, `ReadObject` and ECDSA signing all working. The only
non-0x9000 responses were benign and already handled by our own code:
80 01 0B 04 CreateECCurve(secp256k1) -> 6985 curve already exists
80 01 61 00 WriteECKey -> 6A80 object exists, wrong type
80 04 00 27 CheckObjectExists -> 9000
80 04 00 28 DeleteSecureObject -> 9000
80 01 61 00 WriteECKey -> 9000 succeeds after the delete
**What I was actually looking at.** The SE was already in a wedged state when each of my
test boots started, left there by an earlier session. Once wedged, *every* APDU returns
0x6985 — `GetRandom`, `GetVersion`, `GetFreeMemory` included — and the state survives an
MCU reset, a T=1 interface reset, and a re-`SELECT` that itself returns 0x9000. Only
removing power clears it. So every measurement I reported was of the wedge, not of a
blocked feature, and my "GetRandom is the only command that works" and "GetVersion is
refused" claims were both artifacts of that. Apologies for the noise.
For the record, on a healthy boot this part reports:
* `GetVersion` → `07 02 00 3F FF FF FF` — applet **7.2.0**, AppletConfig `0x3FFF`
* `GetFreeMemory(PERSISTENT)` → `0x3E0C` = **15,884 bytes** free
* Platform SCP03 authenticates on the default key set for **OEF 0005A8FA (SE051C)**
**One thing that may still be worth your comment**, since it is the part I do not
understand and it has shipping implications for us:
While wedged, GP security-domain commands keep working — `80 50 00 00` INITIALIZE
UPDATE and `84 82 33 00` EXTERNAL AUTHENTICATE both return 0x9000 — while the IoT
applet refuses everything. Is there a documented applet error state with that shape,
and is there any way to detect or clear it **without cutting power**? A deployed device
cannot power-cycle its secure element independently, so if a host can drive the applet
into this state we need to know how to get back out.
Thanks for the quick response earlier.
350件の閲覧回数
winetime
377件の閲覧回数
Kan_Li
Hi @winetime ,
Did you try the same process without platformSCP enabled? SE051C doesn't require a mandate platform SCP by default. If you may share the APDU command log for this issue, we may check it further.
Kan
%3CLINGO-SUB%20id%3D%22lingo-sub-2399763%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ESE051C2%3A%20%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E6%93%8D%E4%BD%9C%E3%81%8C%200x6985%20%E3%82%92%E8%BF%94%E3%81%99%E4%B8%80%E6%96%B9%E3%80%81GetRandom%20%E3%81%AF%E5%90%8C%E3%81%98%E8%AA%8D%E8%A8%BC%E6%83%85%E5%A0%B1%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2399763%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%23%23%20%E5%95%8F%E9%A1%8C%E7%82%B9%E3%82%92%E4%B8%80%E8%A1%8C%E3%81%A7%E8%A1%A8%E3%81%99%E3%81%A8%E3%81%93%E3%81%86%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E**SE051C2%E3%81%A7%E3%81%AF%E3%80%81%E3%82%A2%E3%83%97%E3%83%AC%E3%83%83%E3%83%88%E3%81%AE%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%B9%E3%83%88%E3%82%A2%E3%81%AB%E8%A7%A6%E3%82%8C%E3%82%8B%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E8%BF%94%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%3CBR%20%2F%3E**0x6985(%E6%9D%A1%E4%BB%B6%E3%81%8C%E6%BA%80%E3%81%9F%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93)**%20%E2%80%94%20%E4%B8%80%E6%96%B9%E3%81%A7%E3%80%8CGetRandom%E3%80%8D%E3%81%AF*%E5%90%8C%E3%81%98*%E3%81%A7%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E4%BC%9A%E8%AD%B0%E3%80%81%E6%AD%A6%E8%A3%85%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0SCP03%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%82%92%E9%80%9A%E3%81%98%E3%81%A6%E3%82%82%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%23%23%20%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AE%E8%B3%AA%E5%95%8F%3C%2FP%3E%3CP%3E**Q1.%E3%81%93%E3%81%AE%E9%83%A8%E5%88%86%E3%81%AF%E3%80%8C%E5%BC%B7%E5%88%B6%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0SCP%E3%80%8D%2F%E5%88%B6%E9%99%90%E4%BB%98%E3%81%8D%2F%E8%BC%B8%E9%80%81%E7%8A%B6%E6%85%8B%E3%81%A7%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%E3%81%A9%E3%81%A1%E3%82%89%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%82%E7%B4%8D%E5%93%81%E6%99%82%E3%81%AE%E7%8A%B6%E6%85%8B%E3%81%AE%E3%81%BE%E3%81%BE%E3%81%A7%E3%80%81%E7%89%87%E6%96%B9%E3%81%AF%E5%B7%A5%E5%A0%B4%E3%81%8B%E3%82%89%E5%87%BA%E8%8D%B7%E3%81%95%E3%82%8C%E3%81%9F%E3%81%B0%E3%81%8B%E3%82%8A%E3%81%AE%E6%96%B0%E5%93%81%E3%81%A7%E3%81%99%E3%80%82%E3%82%82%E3%81%97SE051C2%E3%81%8C%3CBR%20%2F%3E%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%B9%E3%83%88%E3%82%A2%E3%81%AF%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0SCP03%E3%82%AD%E3%83%BC%E3%81%8CNXP%E3%81%8B%E3%82%89%E3%83%AD%E3%83%BC%E3%83%86%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%95%E3%82%8C%E3%82%8B%E3%81%BE%E3%81%A7%E3%83%AD%E3%83%83%E3%82%AF%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%A7%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AA%E3%82%89%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E8%A6%B3%E5%AF%9F%E3%82%92%E6%AD%A3%E7%A2%BA%E3%81%AB%E8%AA%AC%E6%98%8E%E3%81%A7%E3%81%8D%E3%82%8B%E3%80%82%E3%82%82%E3%81%97%E3%81%9D%E3%81%86%E3%81%AA%E3%82%89%E3%80%81%3CBR%20%2F%3E%E3%81%9D%E3%81%AE%E5%B7%9E%E3%82%92%E9%9B%A2%E3%82%8C%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E6%96%87%E6%9B%B8%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%E6%89%8B%E7%B6%9A%E3%81%8D%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E**Q2.%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E6%93%8D%E4%BD%9C%E3%81%AF%E9%A1%A7%E5%AE%A2%E3%82%AD%E3%83%BC(%E5%9B%9E%E8%BB%A2)%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0SCP03%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%82%AD%E3%83%BC%E3%81%AF%3F**%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AE%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%AF%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%A7%E8%AA%8D%E8%A8%BC%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E6%98%8E%E3%82%89%E3%81%8B%E3%81%AB%E3%83%88%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%82%92%E9%81%8B%E3%81%B6%E3%81%8C%E3%80%81%E3%81%9D%E3%81%AE%E4%B8%8A%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E6%8C%87%E4%BB%A4%E3%81%AF%E6%8B%92%E5%90%A6%E3%81%95%E3%82%8C%E3%82%8B%E3%80%82%3C%2FP%3E%3CP%3E**Q3.%E3%82%82%E3%81%97Q1%2FQ2%E3%81%8C%E3%82%A4%E3%82%A8%E3%82%B9%E3%81%AA%E3%82%89%E3%80%81%E3%81%BE%E3%81%9A%E3%81%A9%E3%81%86%E3%82%84%E3%81%A3%E3%81%A6UNIQUE_ID%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F**%3CBR%20%2F%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%81%BE%E3%81%95%E3%81%AB%E9%B6%8F%E3%81%A8%E5%8D%B5%E3%81%AE%E9%96%A2%E4%BF%82%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E6%88%91%E3%80%85%E3%81%AE%E8%A1%8C%E3%81%8F%E6%89%8B%E3%82%92%E9%98%BB%E3%82%80%E3%82%82%E3%81%AE%E3%81%A0%E3%80%82%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AE%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E9%8D%B5%E5%B0%8E%E5%87%BA%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%83%81%E3%83%83%E3%83%97%E3%81%AF%E5%85%A5%E5%8A%9B%E3%81%A8%E3%81%97%E3%81%A6UID%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%80%8CReadObject(UNIQUE_ID)%E3%80%8D%E8%87%AA%E4%BD%93%E3%81%AF%E6%8B%92%E5%90%A6%E3%81%95%E3%82%8C%E3%81%9F%E3%82%82%E3%81%AE%E3%81%AE%E4%B8%80%E3%81%A4%E3%81%A7%E3%81%99%3CBR%20%2F%3E%E5%91%BD%E4%BB%A4%E3%80%82%E6%96%B0%E5%93%81%E9%83%A8%E5%93%81%E3%81%AB%E5%AF%BE%E3%81%99%E3%82%8B%E4%BD%9C%E6%A5%AD%E6%89%8B%E9%A0%86%E3%81%AE%E9%A0%86%E5%BA%8F%E3%81%AF%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E**Q4.%E3%82%A2%E3%83%97%E3%83%AC%E3%83%83%E3%83%88%E3%82%92%E5%A0%B1%E5%91%8A%E3%81%A7%E3%81%8D%E3%82%8BGET%20DATA%20%2F%20GET%20STATUS%E3%81%AE%E9%80%9A%E7%9F%A5%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%E3%83%A9%E3%82%A4%E3%83%95%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%2FVC%E3%81%AE%E7%8A%B6%E6%85%8B%E3%81%AF%3F**%E3%82%B9%E3%83%86%E3%83%BC%E3%83%88%E3%83%AC%E3%82%B9%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AF%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AB%E3%81%A8%E3%81%A3%E3%81%A6%E3%81%AF*%E7%A2%BA%E3%81%8B%E3%81%AB*%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%81SO%E3%82%82%E3%81%97%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%AF%E3%82%A8%E3%83%AA%E3%81%8C%E5%AD%98%E5%9C%A8%E3%81%99%E3%82%8B%E3%81%AA%E3%82%89%3CBR%20%2F%3E%E6%8E%A8%E6%B8%AC%E3%81%99%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E8%87%AA%E5%88%86%E3%81%9F%E3%81%A1%E3%81%A7%E3%83%91%E3%83%BC%E3%83%84%E3%81%AE%E7%8A%B6%E6%85%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E**Q5.%E3%81%93%E3%81%AE%E9%83%A8%E5%88%86%E3%81%8C%E9%80%9A%E5%B8%B8%E3%81%AE%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E4%BD%9C%E6%88%90%E3%82%92%E6%8B%92%E5%90%A6%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AF%E3%81%AA%E3%81%9C%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%E6%98%8E%E3%82%89%E3%81%8B%E3%81%AB%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%AB%E3%80%82%3CBR%20%2F%3E%E4%BB%96%E3%81%AE%E4%BA%BA%E3%81%AB%E3%81%A8%E3%81%A3%E3%81%A6%E3%81%AF%E3%81%A9%E3%81%86%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9FDeleteAll%2F0x6985Thread(m-p%2F1648349)%E3%81%A7%E3%81%AF%E3%80%81%E3%82%B9%E3%83%86%E3%83%83%E3%83%971%E3%81%AF%3CBR%20%2F%3E%60Se05x_API_WriteUserID(...FACTORY_RESET...)%60%E3%81%8C**0x9000**%E3%82%92%E8%BF%94%E3%81%97%20%E2%80%94%20%3CBR%20%2F%3EWriteSecureObject%E3%81%8C%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0SCP03%E3%81%AE%E3%81%BF%E3%81%A7%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%82%BB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E6%88%90%E5%8A%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E3%81%AF%3CBR%20%2F%3E%E3%81%BE%E3%81%95%E3%81%AB%E3%80%81%E6%88%91%E3%80%85%E3%81%AB%E3%81%A8%E3%81%A3%E3%81%A6%E5%A4%B1%E6%95%97%E3%81%AB%E7%B5%82%E3%82%8F%E3%82%8B%E7%A8%AE%E9%A1%9E%E3%81%AE%E6%8C%87%E6%8F%AE%E7%B3%BB%E7%B5%B1%E3%81%A0%E3%80%82%E3%81%A4%E3%81%BE%E3%82%8A%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%AF%E6%9C%AC%E8%B3%AA%E7%9A%84%E3%81%AB%E3%81%9D%E3%81%86%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%E3%82%BB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%B2%E3%83%BC%E3%83%88%E3%80%82%E9%81%95%E3%81%84%E3%81%AF%E3%83%90%E3%83%AA%E3%82%A8%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%84%E6%A7%8B%E6%88%90(SE051C2%E3%81%A8SE050%E3%81%AE%E9%81%95%E3%81%84)%E3%81%AA%E3%81%AE%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%82%AD%E3%83%BC%E3%81%AF%E3%81%BE%E3%81%A0NXP%E3%81%AE%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E**Q6.m-p%2F1716555%20%E3%81%AF%E5%90%8C%E3%81%98%E6%A0%B9%E6%9C%AC%E5%8E%9F%E5%9B%A0%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%E3%81%9D%E3%81%93%E3%81%A7%E5%88%A5%E3%81%AE%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%8C%E5%A0%B1%E5%91%8A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%80%8CSe05x_API_WriteUserID%E3%80%8D%E3%81%8C%E8%BF%94%E3%81%99%E3%80%8CSM_ERR_CONDITIONS_OF_USE_NOT_SATISFIED%E3%80%8D%E2%80%95%E2%80%95%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%A8%E3%81%BE%E3%81%A3%E3%81%9F%E3%81%8F%E5%90%8C%E3%81%98%3CBR%20%2F%3E%E7%97%87%E7%8A%B6%E2%80%95%E2%80%95%E3%81%9D%E3%81%97%E3%81%A6%E3%81%9D%E3%81%AE%E7%96%91%E5%95%8F%E3%81%AF%E7%AD%94%E3%81%88%E3%81%8C%E5%87%BA%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E**Q7.%60kSE05x_ECCurve_NIST_P256%60%20%E3%81%AF%E6%98%8E%E7%A4%BA%E7%9A%84%E3%81%AA%20%60Se05x_API_CreateECCurve%60%20%E3%82%92%E5%BF%85%E8%A6%81%E3%81%A8%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3CBR%20%2F%3E%20SE051C2%20%E3%81%A7%E3%81%99%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E5%86%85%E8%94%B5%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F**%20(%E4%BA%9B%E7%B4%B0%E3%81%AA%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81CreateECCurve%20%E3%81%A7%E3%81%95%E3%81%88%E3%82%82%3CBR%20%2F%3E%E6%8B%92%E5%90%A6%E3%81%97%E3%81%9F%E3%80%82%EF%BC%89%3C%2FP%3E%3CP%3E%23%23%20%E6%B8%AC%E5%AE%9A%E5%AF%BE%E8%B1%A1%3C%2FP%3E%3CP%3E%7C%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%7C%E7%B5%90%E6%9E%9C%7C%E6%84%8F%E5%91%B3%20%7C%3CBR%20%2F%3E%7C---%7C---%7C---%7C%3CBR%20%2F%3E%7C%E3%80%8CSe05x_API_SELECT%E3%80%8D%E3%82%A2%E3%83%97%E3%83%AC%E3%83%83%E3%83%88%20%7C**0x9000**%20%7CIoT%20applet%20selected%20%7C%3CBR%20%2F%3E%7C%E3%80%8ESe05x_API_GetRandom%E3%80%8F(%E5%8D%98%E7%B4%94)%20%7C%E5%AE%9F%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AD%E3%83%94%E3%83%BC%20%7C%E3%82%BB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%2B%E8%BC%B8%E9%80%81%E4%BD%9C%E6%A5%AD%7C%3CBR%20%2F%3E%7C%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0SCP03%E8%AA%8D%E8%A8%BC%20%7C**%E6%88%90%E5%8A%9F**%20%7C%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E3%82%AD%E3%83%BC%E3%82%BB%E3%83%83%E3%83%88%E3%81%8C%E4%B8%80%E8%87%B4%20%7C%3CBR%20%2F%3E%7C**%E3%83%A9%E3%83%B3%E3%83%80%E3%83%A0%E3%81%AB%E8%A9%B1%E3%81%9B%E3%80%81SCP03%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E8%B6%8A%E3%81%97**%20%7C**%E6%88%90%E5%8A%9F%E3%80%81%E6%9C%AC%E7%89%A9%E3%81%AE%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AD%E3%83%94%E3%83%BC**%20%7C%E6%9A%97%E5%8F%B7%E5%8C%96%20%2B%20C-MAC%20%2B%20%E5%BE%A9%E5%8F%B7%E6%A4%9C%E8%A8%BC%E6%B8%88%E3%81%BF%20%7C%3CBR%20%2F%3E%7C%E9%80%A3%E7%B6%9A%E3%81%97%E3%81%A62%E5%9B%9E%E7%9B%AE%E3%81%AE%E3%83%A9%E3%83%83%E3%83%97%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%20%7C**%E6%88%90%E5%8A%9F**%20%7C%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%E3%81%8C%E5%90%8C%E6%9C%9F%E3%82%92%E4%BF%9D%E3%81%A4%20%7C%3CBR%20%2F%3E%7C%E3%80%8CWriteECKey%E3%80%8DNIST%20P-256(%E7%94%9F%E6%88%90)%20%7C**0x6985**%20%7C%3CBR%20%2F%3E%7C'WriteECKey'%20secp256k1%20(import)%20%7C**0x6985**%20%7C%E3%80%8CCreateCurve_secp256k1%E3%80%8D%E3%81%AF%E6%9C%80%E5%88%9D%E3%81%AB%E5%91%BC%E3%81%B0%E3%82%8C%E3%81%BE%E3%81%99%20%7C%3CBR%20%2F%3E%7C%E3%80%8EWriteECKey%E3%80%8F%20Ed25519(%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88)%20%7C**0x6985**%20%7C%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BF%E3%81%AE%E6%9B%B2%E7%B7%9A%E3%80%81CreateCurve%E3%81%AF%E4%B8%8D%E8%A6%81%20%7C%3CBR%20%2F%3E%7C%E3%80%8EReadObject(UNIQUE_ID)%E3%80%8F%20%7C**0x6985**%20%7C%E6%94%BF%E7%AD%96%E8%AB%96%E4%BA%89%E3%81%AF%E9%96%A2%E4%BF%82%E3%81%AA%E3%81%84%20%7C%3CBR%20%2F%3E%7C%E3%80%8CWriteBinary_Ver%E3%80%8D(%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%83%9D%E3%83%AA%E3%82%B7%E3%83%BC%E4%BB%98%E3%81%8D)%20%7C**0x6985**%20%7C%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%82%E5%A4%B1%E6%95%97%E3%81%99%E3%82%8B%20%7C%3CBR%20%2F%3E%7C%E3%80%8ECreateECCurve(NIST_P256)%E3%80%8F%20%7C**0x6985**%20%7C%E6%9B%B2%E7%B7%9A%E3%82%92%E4%BD%9C%E3%82%8B%E3%81%93%E3%81%A8%E3%81%95%E3%81%88%E6%8B%92%E5%90%A6%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%20%7C%3CBR%20%2F%3E%7C%E3%80%8CCheckObjectExists%E3%80%8D%20%7C**0x6985**%20%7C%E5%AF%BE%E8%B1%A1%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E3%81%99%E3%82%89%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%20%7C%3C%2FP%3E%3CP%3E**%E3%80%8CGetRandom%E3%80%8D%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%A0%E3%81%91%E3%81%8C%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82**%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%B9%E3%83%88%E3%82%A2%E6%93%8D%E4%BD%9C%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E0x6985%20%E2%80%94%20%E9%80%9A%E5%B8%B8%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%81%A8%20SCP03%20%E3%81%A7%E5%8C%85%E8%A3%85%E3%81%95%E3%82%8C%E3%81%9F%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%A7%E7%99%BA%E7%94%9F%E3%80%82%3C%2FP%3E%3CP%3E%23%23%20%E5%AE%9F%E9%A8%93%E3%81%AB%E3%82%88%E3%82%8A%E6%97%A2%E3%81%AB%E5%90%A6%E5%AE%9A%E6%B8%88%E3%81%BF%3C%2FP%3E%3CP%3E1.%20**%E3%81%9D%E3%81%AE%E9%83%A8%E5%88%86%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82**%E6%96%B0%E5%93%81%E3%81%AESE051C2%E3%82%82%E5%85%A8%E3%81%8F%E5%90%8C%E3%81%98%E3%82%88%E3%81%86%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%80%82%3CBR%20%2F%3E2.%20**%E4%BA%A4%E9%80%9A%E8%B2%BB%E3%82%84%E3%82%BB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E8%B2%BB%E7%94%A8%E3%81%AF%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82**SELECT%20%E3%81%AF%200x9000%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%E3%80%82GetRandom%20%E3%81%AF%E5%AE%9F%E6%95%B0%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E5%90%8C%E4%B8%80%E3%82%BB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8B%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AD%E3%83%94%E3%83%BC%E3%80%82%3CBR%20%2F%3E3.%20**%E5%A3%8A%E3%82%8C%E3%81%9F%E3%82%8A%E6%AC%A0%E8%90%BD%E3%81%97%E3%81%9F%E3%82%8A%E3%81%97%E3%81%9F%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0SCP03%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%AF%E3%81%AA%E3%81%84%E3%80%82**%E8%AA%8D%E8%A8%BC%E3%81%AF%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%20%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E3%82%AD%E3%83%BC%E3%82%BB%E3%83%83%E3%83%88%E3%81%A8%E3%80%81%E6%B1%BA%E5%AE%9A%E7%9A%84%E3%81%AB%E3%80%8CGetRandom%E3%80%8D%E3%81%8C%E7%99%BA%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%9F**%E6%AD%A6%E8%A3%85%E3%81%95%E3%82%8C%E3%81%9F%3CBR%20%2F%3E%20%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB**%E3%81%AF%E5%AE%9F%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AD%E3%83%94%E3%83%BC%E3%82%92%E8%BF%94%E3%81%97%E3%80%812%E5%9B%9E%E7%9B%AE%E3%81%AE%E9%80%A3%E7%B6%9A(%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC)%E3%82%82%E5%90%8C%E6%A7%98%E3%81%A7%E3%81%99%E3%80%82%E5%90%8C%E6%9C%9F)%E3%82%92%E7%B5%84%E3%81%BF%E5%90%88%E3%82%8F%E3%81%9B%E3%82%8B%E3%80%82%3CBR%20%2F%3E%E6%9A%97%E5%8F%B7%E5%8C%96%EF%BC%8BC-MAC%EF%BC%8B%E5%BF%9C%E7%AD%94%E5%BE%A9%E5%8F%B7%E5%8C%96%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%8C%E6%A4%9C%E8%A8%BC%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%A4%B1%E6%95%97%E3%81%99%E3%82%8B%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3CBR%20%2F%3E%E6%A9%9F%E8%83%BD%E3%81%8C%E8%A8%BC%E6%98%8E%E3%81%95%E3%82%8C%E3%81%9F%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%A7%E9%81%8B%E3%81%B0%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E4.%20**%E6%AC%A0%E6%90%8D%E3%82%AD%E3%83%BC%E3%83%9D%E3%83%AA%E3%82%B7%E3%83%BC%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82**%E5%AE%9F%E9%9A%9B%E3%81%AE%20%60Se05xPolicy_t%60%20%E3%82%92%E6%B8%A1%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%20%60WriteECKey%60%20%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%E3%80%81(%60ALLOW_SIGN%7CVERIFY%7CKA%7CREAD%7CWRITE%7CGEN%60%E3%80%81authID%200)%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%A4%89%E6%9B%B4%E3%81%AA%E3%81%97%E3%80%82%3CBR%20%2F%3E(%E3%81%9D%E3%82%82%E3%81%9D%E3%82%82%E8%AA%AD%E3%81%BFUNIQUE_ID%E7%90%86%E7%94%B1%E3%81%AF%E8%AA%AC%E6%98%8E%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%20%E2%80%94%20%E3%80%8CReadObject%E3%80%8D%E3%81%AF%E3%83%9D%E3%83%AA%E3%82%B7%E3%83%BC%E3%82%92%E5%8F%96%E3%82%89%E3%81%AA%E3%81%84%E3%81%8B%E3%82%89%E3%81%A7%E3%81%99%E3%80%82)%3CBR%20%2F%3E5.%20**%E6%9B%B2%E7%B7%9A%E3%81%8C%E6%AC%A0%E8%90%BD%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%8F%E3%81%91%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82**%60CreateCurve_secp256k1%60%E3%81%AFsecp256k1%E3%81%AE%E5%89%8D%E3%81%AB%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%80%81Ed25519%E3%81%AF%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BF%E3%80%81%60Se05x_API_CreateECCurve(NIST_P256)%60%E3%82%82**%3CBR%20%2F%3E%200x6985%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E6.%20**%E5%91%BD%E4%BB%A4%E3%81%AE%E3%81%94%E6%B3%A8%E6%96%87%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%80%82**%E3%83%97%E3%83%AC%E3%83%BC%E3%83%B3%E3%82%BB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%82%82%E3%80%810x6985%3CBR%20%2F%3E%E8%AA%8D%E8%A8%BC%E6%B8%88%E3%81%BF%E3%81%AESCP03%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%80%82%3CBR%20%2F%3E7.%20**%E3%83%9F%E3%83%89%E3%83%AB%E3%82%A6%E3%82%A7%E3%82%A2%E8%AA%8D%E8%A8%BC%E3%83%93%E3%83%AB%E3%83%89%E6%A7%8B%E6%88%90%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82**%E5%86%8D%E6%A7%8B%E7%AF%89%3CBR%20%2F%3E%60SSS_HAVE_SE05X_AUTH_PLATFSCP03%3D1%60%E3%80%81%60SSS_HAVE_SE05X_AUTH_NONE%3D0%60%E3%81%8A%E3%82%88%E3%81%B3%3CBR%20%2F%3E%60SSSFTR_SE05X_AuthSession%3D1%60%EF%BC%88%E4%BB%A5%E5%89%8D%E3%81%AFNONE%2F0%E3%81%A7%E3%81%97%E3%81%9F%EF%BC%89%E3%80%82%E5%A4%89%E6%9B%B4%E3%81%AA%E3%81%97%E3%80%82%3C%2FP%3E%3CP%3E%EF%BC%83%EF%BC%83%20%E7%92%B0%E5%A2%83%3C%2FP%3E%3CP%3E*%20%E9%83%A8%E5%93%81%E7%95%AA%E5%8F%B7%3A%20**SE051C2**%20%E2%80%94%20%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB2%E5%80%8B%E3%80%81%E3%81%86%E3%81%A11%E5%80%8B%E3%81%AF%E5%B7%A5%E5%A0%B4%E5%87%BA%E8%8D%B7%E6%99%82%E3%81%AE%E6%96%B0%E5%93%81%E3%80%81%E5%8B%95%E4%BD%9C%E3%81%AF%E5%90%8C%E4%B8%80%3CBR%20%2F%3E*%20%E3%83%9B%E3%82%B9%E3%83%88%3A%20STM32L562%E3%80%81%E3%83%99%E3%82%A2%E3%83%A1%E3%82%BF%E3%83%AB%E3%80%81TrustZone%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%E3%80%81I2C1%20%40%20100%20kHz%E3%80%81T%3D1%3CBR%20%2F%3E%20*%20%E3%83%9F%E3%83%89%E3%83%AB%E3%82%A6%E3%82%A7%E3%82%A2%3A%20%E3%83%99%E3%83%B3%E3%83%80%E3%83%BC%E6%8F%90%E4%BE%9B%E3%81%AE%20NXP%20Plug%20%26amp%3B%20Trust%20%60Se05x_API_*%60%20%E3%82%92%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20%E4%B8%8A%E3%81%A7%E4%BD%BF%E7%94%A8%3CBR%20%2F%3E%60smCom_TransceiveRaw%60%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%EF%BC%88%E7%8B%AC%E8%87%AA%E3%81%AET%3D1%E3%83%95%E3%83%AC%E3%83%BC%E3%83%9F%E3%83%B3%E3%82%B0%20-%20SELECT%E3%81%A8GetRandom%E3%81%8C%E8%A8%BC%E6%98%8E%EF%BC%89%3CBR%20%2F%3E%E3%81%9D%E3%82%8C%E3%81%AF%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%EF%BC%89%E3%80%82%E3%83%95%E3%83%AB%E3%83%9F%E3%83%89%E3%83%AB%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A7%E3%80%81**%E3%83%8A%E3%83%8E%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93**%E3%80%82%3CBR%20%2F%3E*%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0SCP03%3ANXP%E3%81%AE%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%82%AD%E3%83%BC%3B%E8%AA%8D%E8%A8%BC%E3%81%AF%E6%88%90%E5%8A%9F%E3%81%97%E3%80%81%E3%83%88%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%82%92%E9%81%8B%E3%81%B3%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2399763%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ESE050%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2399956%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE051C2%3A%20all%20Secure%20Object%20operations%20return%200x6985%20while%20GetRandom%20works%20over%20the%20same%20authenti%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2399956%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F265110%22%20target%3D%22_blank%22%3E%40winetime%20%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EplatformSCP%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%9B%E3%81%9A%E3%81%AB%E5%90%8C%E3%81%98%E6%89%8B%E9%A0%86%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%EF%BC%9FSE051C%E3%81%AF%20%3CSPAN%3E%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%A7%E5%BF%85%E9%A0%88%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0SCP%E3%82%92%E5%BF%85%E8%A6%81%E3%81%A8%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8BAPDU%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%AD%E3%82%B0%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8C%E3%81%B0%E3%80%81%E3%81%95%E3%82%89%E3%81%AB%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%99%E3%81%A6%E3%81%8D%E3%81%AA%E4%B8%80%E6%97%A5%E3%82%92%E3%80%81%3CBR%20%2F%3E%E3%82%AB%E3%83%B3%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%E8%A8%98%EF%BC%9A%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%8C%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%B8%E3%81%AE%E5%9B%9E%E7%AD%94%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%80%8C%E6%AD%A3%E8%A7%A3%E3%81%A8%E3%81%97%E3%81%A6%E3%83%9E%E3%83%BC%E3%82%AF%E3%80%8D%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99!%3CBR%20%2F%3E-%20%E5%89%8D%E5%9B%9E%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%8B%E3%82%897%E9%80%B1%E9%96%93Thread%E3%82%92%E3%83%95%E3%82%A9%E3%83%AD%E3%83%BC%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%81%9D%E3%81%AE%E5%BE%8C%E3%81%AE%E8%BF%94%E4%BF%A1%E3%81%AF%E7%84%A1%E8%A6%96%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%82%82%E3%81%97%E5%BE%8C%E3%81%A7%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81%E6%96%B0%E3%81%97%E3%81%84Thread%E3%82%92%E9%96%8B%E3%81%8D%E3%80%81%E9%96%89%E3%81%98%E3%81%9FThread%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2400067%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE051C2%3A%20all%20Secure%20Object%20operations%20return%200x6985%20while%20GetRandom%20works%20over%20the%20same%20authenti%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2400067%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%82%AB%E3%83%B3%E3%80%81%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%81%AE%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E7%B4%A0%E6%97%A9%E3%81%84%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E8%BF%94%E4%BA%8B%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%81%AF%E3%81%84%20%E2%80%94%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0SCP%E3%81%AA%E3%81%97%E3%81%A7%E3%83%86%E3%82%B9%E3%83%88%E3%81%95%E3%82%8C%E3%81%9F%E3%82%82%E3%81%AE%E3%81%A7%E3%80%81%E3%81%9D%E3%82%8C%E3%81%8C%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AE%E9%80%9A%E5%B8%B8%E3%81%AECASE%E3%81%A7%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AE%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E6%93%8D%E4%BD%9C%E3%81%AF%E5%AE%9F%E8%A1%8C%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CEM%3Ebefore%3C%2FEM%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Ese051_scp03_open()%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%81%8C%E5%91%BC%E3%81%B0%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%81%99%E3%81%A7%E3%81%AB%E3%83%97%E3%83%AC%E3%83%BC%E3%83%B3%E3%82%BB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E4%B8%8A%E3%81%AB%E3%81%82%E3%82%8A%E3%80%81%E3%81%9D%E3%81%93%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81SCP03%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%82%82%E4%BD%95%E3%81%AE%E6%84%8F%E5%91%B3%E3%82%82%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%20%E2%80%94%20%E5%90%8C%E3%81%98%E3%82%88%E3%81%86%E3%81%AB0x6985%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%81%A9%E3%81%A1%E3%82%89%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%82%84%E3%82%8A%E6%96%B9%E3%82%82%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AFAPDU%E3%83%AD%E3%82%B0%E3%81%A7%E3%81%99%E3%80%82%E9%80%9A%E5%B8%B8%E3%81%AE%E3%82%BB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E3%80%81SCP03%E3%81%AA%E3%81%97%EF%BC%88CLA%3D0x80%E3%80%81%E3%81%AA%E3%81%97%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E0x04%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%83%B3%E3%82%B0%E3%83%93%E3%83%83%E3%83%88%E3%80%82%E5%BF%9C%E7%AD%94%E3%81%AF%E5%8D%98%E7%B4%94%E3%81%AA%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E7%8A%B6%E6%85%8B%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E8%A8%80%E8%91%89%E3%80%81%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%81%AA%E3%81%84%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%EF%BC%88%E5%8C%85%E8%A3%85%E6%B8%88%E3%81%BF%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3ETX%20(11)%3A%2080%2004%2000%2027%2006%2041%2004%2020%2000%20F0%2030%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ERX%EF%BC%882%EF%BC%89%EF%BC%9A69%2085%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%81%AF%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3ECheckObjectExists%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E(INS%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E04%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3EMGMT%E3%80%81P2%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E27%E3%80%81TAG_1%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88ID%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E0x2000F030)%20%E2%80%94%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E5%B0%82%E7%94%A8%E5%AD%98%E5%9C%A8%E3%83%86%E3%82%B9%E3%83%88%20%E2%80%94%20CONDITIONS%20%E3%81%AB%E3%82%88%E3%82%8A%E6%8B%92%E5%90%A6%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%81%AA%E3%81%84%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E6%BA%80%E8%B6%B3%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%B9%E3%83%88%E3%82%A2%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E8%A9%A6%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%9F%E3%81%B3%E3%81%AB%E3%80%81%E3%81%A9%E3%81%AE%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88ID%E3%81%A7%E3%82%82%E3%80%81%E5%90%8C%E3%81%980x6985%E3%81%8C%E8%BF%94%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3ECheckObjectExists%E3%80%81%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3EWriteBinary_Ver%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%EF%BC%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%83%9D%E3%83%AA%E3%82%B7%E3%83%BC%E4%BB%98%E3%81%8D%EF%BC%89%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3EWriteECKey%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%EF%BC%88%E7%94%9F%E6%88%90%E3%81%8A%E3%82%88%E3%81%B3%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%3B%20P-256%E3%80%81secp256k1%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3ECreateCurve_secp256k1%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%81%BE%E3%81%9A%E3%80%81%E3%81%9D%E3%81%97%E3%81%A6Ed25519%EF%BC%89%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3ECreateECCurve(NIST_P256)%E3%80%81%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3EReadObject(UNIQUE_ID)%20%3CSPAN%20class%3D%22%22%3E%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%90%8C%E3%81%98%E5%B9%B3%E9%87%8E%E4%BC%9A%E3%81%A7%E3%80%81%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E4%BB%95%E4%BA%8B%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%A4%A7%E4%B8%88%E5%A4%AB%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E9%81%B8%E6%8A%9E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3EIoT%E3%82%A2%E3%83%97%E3%83%AC%E3%83%83%E3%83%88%E3%81%AE%E2%86%92%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E0x9000%3C%2FLI%3E%3CLI%3E%E3%83%A9%E3%83%B3%E3%83%80%E3%83%A0%E3%82%92%E5%8F%96%E5%BE%97%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E2%86%92%20%E5%AE%9F%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AD%E3%83%94%E3%83%BC%3C%2FLI%3E%3C%2FUL%3E%3CP%3ESO%E3%80%81%E8%BC%B8%E9%80%81%E6%89%8B%E6%AE%B5%E3%81%A8%E3%82%A2%E3%83%97%E3%83%AC%E3%83%83%E3%83%88%E3%81%AE%E9%81%B8%E6%8A%9E%E3%81%AF%E8%89%AF%E5%A5%BD%E3%81%A7%E3%81%99%E3%80%82object-store%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ecommands%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eare%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Erefused%E3%81%AE%E3%81%BF%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E8%B3%AA%E5%95%8F%EF%BC%9A%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E5%B7%A5%E5%A0%B4%E5%87%BA%E8%8D%B7%E6%99%82%E3%81%AESE051C2%E3%81%8C%E6%8B%92%E5%90%A6%E3%81%99%E3%82%8B%E5%8E%9F%E5%9B%A0%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3ECheckObjectExists%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E9%80%9A%E5%B8%B8%E3%81%AE%E3%82%BB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%EF%BC%9F%E6%88%91%E3%80%85%E3%81%AF%E5%85%A8%E3%81%8F%E5%90%8C%E3%81%98%E8%A1%8C%E5%8B%95%E3%82%92%E7%9B%AE%E3%81%AB%E3%81%99%E3%82%8B%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%81%AE%E4%B8%8A%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E4%BA%8C%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%80%81%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E1%E3%81%A4%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%96%E3%83%A9%E3%83%B3%E3%83%89%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E6%96%B0%E3%81%97%E3%81%84%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%81%9D%E3%81%97%E3%81%A6%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E4%B8%80%E5%BA%A6%E3%82%82%E3%81%AA%E3%81%84%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E6%9B%B8%E3%81%8B%E3%82%8C%E3%81%9F%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%81%AB%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%82%A2%E3%83%97%E3%83%AC%E3%83%83%E3%83%88%E3%81%AE%E3%83%A9%E3%82%A4%E3%83%95%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%EF%BC%8F%E6%A7%8B%E6%88%90%E7%8A%B6%E6%85%8B%E3%82%92%E5%A0%B1%E5%91%8A%E3%81%99%E3%82%8BGET%20DATA%EF%BC%88%E3%81%BE%E3%81%9F%E3%81%AF%E3%81%9D%E3%82%8C%E3%81%AB%E9%A1%9E%E3%81%99%E3%82%8B%EF%BC%89%E3%82%AF%E3%82%A8%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E7%84%A1%E7%8A%B6%E6%85%8B%E3%81%AE%E5%91%BD%E4%BB%A4%E3%81%AF%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E6%A9%9F%E8%83%BD%E3%81%97%E3%80%81%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3ESO%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AF%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3ECAN%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E8%B5%B0%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E9%80%83%E3%81%92%E3%81%A6%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%A0%B1%E5%91%8A%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E6%88%BB%E3%81%9B%E3%81%AA%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%3ASE051C2%E3%80%81STM32L562%E3%83%99%E3%82%A2%E3%83%A1%E3%82%BF%E3%83%AB%E3%83%9B%E3%82%B9%E3%83%88%E3%80%81I2C%20100kHz%E3%80%81%E8%87%AA%E7%A4%BE%E3%81%AET%3D1%E3%83%95%E3%83%AC%E3%83%BC%E3%83%9F%E3%83%B3%E3%82%B0(SELECT%E3%81%A8GetRandom%E3%81%8C%E8%A8%BC%E6%98%8E)%E3%80%81%E3%83%95%E3%83%ABPlug%20%26amp%3B%20Trust%E3%83%9F%E3%83%89%E3%83%AB%E3%82%A6%E3%82%A7%E3%82%A2%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20Se05x_API_*%2C%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3CSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Enot%3CSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20nano%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2400661%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE051C2%3A%20all%20Secure%20Object%20operations%20return%200x6985%20while%20GetRandom%20works%20over%20the%20same%20authenti%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2400661%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%3CSPAN%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59276%22%20target%3D%22_blank%22%3E%40Kan_Li%20%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%82%E3%81%93%E3%81%AE%E4%BB%B6%E3%81%AF%E3%81%93%E3%82%8C%E3%81%A7%E3%82%AF%E3%83%AD%E3%83%BC%E3%82%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82**%E3%81%9D%E3%82%8C%E3%81%AF%E6%88%91%E3%80%85%E3%81%AE%E5%81%B4%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E8%A8%BA%E6%96%AD%E3%81%AF%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%A7%8B%E3%82%81%E3%82%8B%E3%80%82**%E8%AA%B0%E3%81%8B%E3%81%AE%E5%8A%A9%E3%81%91%E3%81%AB%E3%81%AA%E3%82%8C%E3%81%B0%E3%81%A8%E6%80%9D%E3%81%84%E3%80%81%E8%A7%A3%E6%B1%BA%E6%A1%88%E3%82%92%E6%8A%95%E7%A8%BF%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E9%83%A8%E5%93%81%E8%87%AA%E4%BD%93%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%96%E3%83%BC%E3%83%88APDU%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E5%85%A8%E4%BD%93%E3%82%92%E8%A8%88%E6%B8%AC%E3%81%97%E3%81%9F%E9%9A%9B%E3%80%81%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%80%8B%E3%80%85%E3%81%AE%E7%B5%90%E6%9E%9C%E3%81%A7%E3%81%AF%E3%80%81%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%81%AA%E9%9B%BB%E6%BA%90%E6%8A%95%E5%85%A5%E3%81%AB%E3%82%88%E3%82%8A%2083%20%E5%80%8B%E3%81%AE%20APDU%20%E3%81%8C%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%80%81%E3%81%9D%E3%81%AE%E3%81%86%E3%81%A1%2080%20%E5%80%8B%E3%81%8C%200x9000%20%E2%80%94%20%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E4%BD%9C%E6%88%90%E3%80%81secp256k1%E3%82%AD%E3%83%BC%E7%94%9F%E6%88%90%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3E%60%3C%2FSPAN%3E%20%3CSPAN%3EReadObject%60%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EECDSA%E7%BD%B2%E5%90%8D%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0x9000%E4%BB%A5%E5%A4%96%E3%81%AE%E5%BF%9C%E7%AD%94%E3%81%AF%E7%84%A1%E5%AE%B3%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E6%97%A2%E3%81%AB%E5%BC%8A%E7%A4%BE%E7%8B%AC%E8%87%AA%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E5%87%A6%E7%90%86%E6%B8%88%E3%81%BF%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E80%2001%200B%2004%20CreateECCurve(secp256k1)%20-%26gt%3B%206985%20%E6%9B%B2%E7%B7%9A%E3%81%AF%E6%97%A2%E3%81%AB%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E80%2001%2061%2000%20WriteECKey%20-%26gt%3B%206A80%20%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%8C%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%BF%E3%82%A4%E3%83%97%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E80%2004%2000%2027%20CheckObjectExists%20-%26gt%3B%209000%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E80%2004%2000%2028%20DeleteSecureObject%20-%26gt%3B%209000%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E80%2001%2061%2000%20WriteECKey%20-%26gt%3B%209000%20%E3%81%AF%E5%89%8A%E9%99%A4%E5%BE%8C%E3%81%AB%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E**%3C%2FSPAN%3E%3CSPAN%3E%E7%A7%81%E3%81%8C%E5%AE%9F%E9%9A%9B%E3%81%AB%E8%A6%8B%E3%81%A6%E3%81%84%E3%81%9F%E3%82%82%E3%81%AE%E3%80%82%3C%2FSPAN%3E%20%3CSPAN%3E**%3C%2FSPAN%3E%20%3CSPAN%3ESE%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%E3%82%A6%E3%82%A7%E3%83%83%E3%82%B8%E7%8A%B6%E6%85%8B%E3%81%AB%E3%81%82%E3%82%8A%E3%80%81%E7%A7%81%E3%81%AE%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%E3%83%86%E3%82%B9%E3%83%88%E3%83%96%E3%83%BC%E3%83%88%E3%81%8C%E9%96%8B%E5%A7%8B%E3%81%95%E3%82%8C%E3%80%81%3CSPAN%3E%E4%BB%A5%E5%89%8D%3C%2FSPAN%3E%3CSPAN%3E%E3%81%AE%3C%2FSPAN%3E%3CSPAN%3E%E3%82%BB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%81%9D%E3%81%93%E3%81%AB%E6%AE%8B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%3C%2FSPAN%3E%3CSPAN%3E%E3%81%9F%3C%2FSPAN%3E%3CSPAN%3E%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0x6985%20%E2%80%94%3C%2FSPAN%3E%20%3CSPAN%3E%60%3C%2FSPAN%3E%20%3CSPAN%3EGetRandom%60%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3E%60%3C%2FSPAN%3E%20%3CSPAN%3EGetVersion%60%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3E%60%3C%2FSPAN%3E%20%3CSPAN%3EGetFreeMemory%60%3C%2FSPAN%3E%3CSPAN%3E%E3%82%92%3C%2FSPAN%3E%E5%90%AB%E3%82%80%3CSPAN%3E%E2%80%94%3C%2FSPAN%3E%3CSPAN%3E%E3%81%9D%E3%81%97%E3%81%A6%E7%8A%B6%E6%85%8B%3C%2FSPAN%3E%3CSPAN%3E%E3%81%AF%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMCU%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%80%81T%3D1%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%80%81%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%E3%81%9D%E3%81%97%E3%81%A6%E8%87%AA%E8%BA%AB%E3%81%8C0x9000%E3%82%92%E8%BF%94%E3%81%99%E5%86%8D%3CSPAN%3E%E3%80%8CSELECT%E3%80%8D%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%E3%81%A7%E3%81%99%3CSPAN%3E%E3%80%82%E3%81%9F%E3%81%A0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E9%9B%BB%E6%BA%90%E3%82%92%E5%88%87%E3%82%8B%E3%81%A8%E8%A7%A3%E6%B6%88%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81%E7%A7%81%E3%81%8C%E5%A0%B1%E5%91%8A%E3%81%97%E3%81%9F%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E6%B8%AC%E5%AE%9A%E5%80%A4%E3%81%AF%E3%82%A6%E3%82%A7%E3%83%83%E3%82%B8%E3%81%AE%E3%82%82%E3%81%AE%E3%81%A7%E3%81%82%E3%81%A3%E3%81%A6%E3%80%81%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%95%E3%82%8C%E3%81%9F%E6%A9%9F%E8%83%BD%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E7%A7%81%E3%81%AE%E3%80%8CGetRandom%E3%80%8D%E3%81%AF%E5%94%AF%E4%B8%80%E6%A9%9F%E8%83%BD%E3%81%99%E3%82%8B%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E3%80%8CGetVersion%E3%80%8D%E3%81%AF%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%80%8C%E6%8B%92%E5%90%A6%E3%81%95%E3%82%8C%E3%81%9F%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E4%B8%BB%E5%BC%B5%E3%81%AF%E3%81%A9%E3%81%A1%E3%82%89%E3%82%82%E3%80%81%E3%81%9D%E3%81%AE%E3%81%93%E3%81%A8%E3%81%AE%E7%94%A3%E7%89%A9%E3%81%A0%E3%81%A3%E3%81%9F%E3%80%82%E9%A8%92%E9%9F%B3%E3%81%A7%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%BF%B5%E3%81%AE%E3%81%9F%E3%82%81%E7%94%B3%E3%81%97%E6%B7%BB%E3%81%88%E3%81%A6%E3%81%8A%E3%81%8F%E3%81%A8%E3%80%81%E6%AD%A3%E5%B8%B8%E3%81%AA%E3%83%96%E3%83%BC%E3%83%84%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%81%93%E3%81%AE%E9%83%A8%E5%88%86%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%A0%B1%E5%91%8A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E*%3C%2FSPAN%3E%20%3CSPAN%3E%60%3C%2FSPAN%3E%20%3CSPAN%3EGetVersion%60%3C%2FSPAN%3E%20%3CSPAN%3E%E2%86%92%3C%2FSPAN%3E%20%3CSPAN%3E%60%3C%2FSPAN%3E%2007%20%3CSPAN%3E02%3C%2FSPAN%3E%20%3CSPAN%3E00%203F%20FF%20FF%20FF%60%3C%2FSPAN%3E%20%3CSPAN%3E%E2%80%94%3C%2FSPAN%3E%3CSPAN%3E%E3%82%A2%E3%83%97%E3%83%AC%E3%83%83%E3%83%88%3C%2FSPAN%3E%3CSPAN%3E**%3C%2FSPAN%3E%20%3CSPAN%3E7.2.0%3C%2FSPAN%3E%20%3CSPAN%3E**%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EAppletConfig%3C%2FSPAN%3E%20%3CSPAN%3E%60%3C%2FSPAN%3E%20%3CSPAN%3E0x3FFF%60%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E*%3C%2FSPAN%3E%20%3CSPAN%3E%60%3C%2FSPAN%3E%20%3CSPAN%3EGetFreeMemory(PERSISTENT)%3C%2FSPAN%3E%20%3CSPAN%3E%60%3C%2FSPAN%3E%20%3CSPAN%3E%E2%86%92%3C%2FSPAN%3E%20%3CSPAN%3E%60%3C%2FSPAN%3E%20%3CSPAN%3E0x3E0C%60%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E**%3C%2FSPAN%3E%20%3CSPAN%3E15%2C884%3C%2FSPAN%3E%3CSPAN%3E%E3%83%90%E3%82%A4%E3%83%88%3C%2FSPAN%3E%3CSPAN%3E**%3C%2FSPAN%3E%3CSPAN%3E%E7%A9%BA%E3%81%8D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E*%3C%2FSPAN%3E%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0SCP03%E3%81%AF%3CSPAN%3E**%3C%2FSPAN%3E%3CSPAN%3EOEF%200005A8FA%20(SE051C)%3C%2FSPAN%3E%3CSPAN%3E**%3C%2FSPAN%3E%3CSPAN%3E%E3%81%AE%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%82%AD%E3%83%BC%E3%82%BB%E3%83%83%E3%83%88%E3%81%A7%E8%AA%8D%E8%A8%BC%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E**%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E**%3C%2FSPAN%3E%3CSPAN%3E%E3%81%9D%E3%82%8C%E3%81%A7%E3%82%82%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%81%99%E3%82%8B%E4%BE%A1%E5%80%A4%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%AA%E3%81%84%E7%82%B9%E3%81%8C1%E3%81%A4%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CSPAN%3E**%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%82%E3%81%9D%E3%82%8C%E3%81%AF%E7%A7%81%E3%81%8C%E7%90%86%E8%A7%A3%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E9%83%A8%E5%88%86%E3%81%A0%E3%81%8B%E3%82%89%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E7%90%86%E8%A7%A3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AB%E3%81%A8%E3%81%A3%E3%81%A6%E9%85%8D%E9%80%81%E4%B8%8A%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%A8%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%A6%E3%82%A7%E3%83%83%E3%82%B8%E7%8A%B6%E6%85%8B%E3%81%A7%E3%82%82GP%E3%81%AE%E3%82%BB%E3%82%AD%E3%83%A5%E3%83%AA%E3%83%86%E3%82%A3%E3%83%89%E3%83%A1%E3%82%A4%E3%83%B3%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AF%E5%8B%95%E4%BD%9C%E3%81%97%E7%B6%9A%E3%81%91%E3%81%BE%E3%81%99%20%E2%80%94%20%3C%2FSPAN%3E%3CSPAN%3E%E3%80%8C%3C%2FSPAN%3E%3CSPAN%3E80%2050%2000%2000%3C%2FSPAN%3E%3CSPAN%3E%E3%80%8D%3C%2FSPAN%3E%3CSPAN%3E%20INITIALIZE%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EUPDATE%E3%81%A8%3C%2FSPAN%3E%3CSPAN%3E%60%3C%2FSPAN%3E%20%3CSPAN%3E84%2082%2033%2000%60%3C%2FSPAN%3E%20%3CSPAN%3EEXTERNAL%3C%2FSPAN%3E%20%3CSPAN%3EAUTHENTICATE%E3%81%AF%E3%81%A9%E3%81%A1%E3%82%89%E3%82%820x9000%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81IoT%E3%81%AF%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%A2%E3%83%97%E3%83%AC%E3%83%83%E3%83%88%E3%81%8C%E5%85%A8%E3%81%A6%E3%82%92%E6%8B%92%E5%90%A6%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%AE%E5%BD%A2%E7%8A%B6%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AC%E3%83%83%E3%83%88%E3%82%A8%E3%83%A9%E3%83%BC%E7%8A%B6%E6%85%8B%E3%81%AF%E6%96%87%E6%9B%B8%E5%8C%96%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E9%9B%BB%E6%BA%90%3C%2FSPAN%3E%3CSPAN%3E%E3%82%92%E5%88%87%E3%82%89%E3%81%9A%E3%81%AB%3C%2FSPAN%3E%3CSPAN%3E%E3%81%9D%E3%82%8C%3C%2FSPAN%3E%3CSPAN%3E%E3%82%92%E6%A4%9C%E5%87%BA%E3%81%BE%E3%81%9F%E3%81%AF%E6%B6%88%E5%8E%BB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3C%2FSPAN%3E%3CSPAN%3E%EF%BC%9F%20%E5%B1%95%E9%96%8B%E6%B8%88%E3%81%BF%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E7%B4%A0%E5%AD%90%E3%82%92%E7%8B%AC%E7%AB%8B%E3%81%97%E3%81%A6%E9%9B%BB%E6%BA%90%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E3%83%9B%E3%82%B9%E3%83%88%E3%81%8C%E3%82%A2%E3%83%97%E3%83%AC%E3%83%83%E3%83%88%E3%82%92%E9%A7%86%E5%8B%95%E3%81%A7%E3%81%8D%E3%82%8B%E5%A0%B4%E5%90%88%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%81%93%E3%81%AE%E7%8A%B6%E6%85%8B%E3%81%AB%E9%99%A5%E3%81%A3%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E3%81%9D%E3%81%93%E3%81%8B%E3%82%89%E6%8A%9C%E3%81%91%E5%87%BA%E3%81%99%E6%96%B9%E6%B3%95%E3%82%92%E7%9F%A5%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%85%88%E3%81%BB%E3%81%A9%E3%81%AF%E8%BF%85%E9%80%9F%E3%81%AA%E3%81%94%E5%AF%BE%E5%BF%9C%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
