SE050E detection issue in custom imx8mp board
757 次查看
pratham_malaviya
Hi there,
I am trying to validate the SE050E chip interfaced in our custom IMX8MP based board using the middleware example se05x_GetInfo. I have built and deployed the middleware using the application note AN13027.pdf . Since the SE is interfaced with the i2c-4 so i have modified the
static char* default_axSmDevice_name = "/dev/i2c-1";
to static char* default_axSmDevice_name = "/dev/i2c-3";
in simw top/hostlib/hostLib/platform/linux/i2c_a7.c file.
Still I am facing the error:
root@imx8mp-lpddr4-evk:~# se05x_GetInfo
App :INFO :PlugAndTrust_v04.05.00_20231201
App :INFO :Running se05x_GetInfo
App :INFO :If you want to over-ride the selection, use ENV=EX_SSS_BOOT_SSS_PORT or pass in command line arguments.
smCom :ERROR:Failed writing data (nrWritten=-1).
smCom :ERROR: - Error in I2C Write.....
smCom :ERROR:phNxpEseProto7816_SendRawFrame Error phNxpEse_WriteFrame
smCom :ERROR:TransceiveProcess Transceive send failed, going to recovery!
smCom :ERROR:phNxpEseProto7816_Open failed
smCom :ERROR: Failed to Open session
sss :ERROR:SM_I2CConnect Failed. Status 7012
App :ERROR:sss_session_open failed
App :ERROR:ex_sss_session_open Failed
App :ERROR:!ERROR! ret != 0.
I have also attached the cmake-conf.txt for cmake configuration.
Can anyone suggest if any other changes are required in the source?
691 次查看
Kan_Li
Hi @pratham_malaviya ,
Did you try the i2cdetect command like below to probe the SE device on /dev/i2c-3?
i2cdetect -y -a -q 3
and you don't need to change the source code at all, just use the following command before running any demo out of MW.
export EX_SSS_BOOT_SSS_PORT=/dev/i2c-3
Hope that helps,
Kan
681 次查看
pratham_malaviya
Hi @Kan_Li ,
I have tried with the given command and I am getting the output as below
root@imx8mp-lpddr4-evk:~# i2cdetect -y -a -q 3
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00: 00 -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
10: 10 -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- 21 -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- 55 -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 7f
 and by testing with Getinfo utility same error is there,
root@imx8mp-lpddr4-evk:~/simw-top_build/imx_native_se050_t1oi2c/bin# ./se05x_GetInfo
App   :INFO :Running ./se05x_GetInfo
App   :INFO :Using PortName='/dev/i2c-3' (ENV: EX_SSS_BOOT_SSS_PORT=/dev/i2c-3)
Can you please guide me to validate it?
Pratham
639 次查看
Kan_Li
The default I2C address for SE050E is 0x48, so from your test, there is no such device on /dev/i2c-3, is there any connection issue between the host and SE050E on your board? Is it ok to have the schematics for a review?
Kan
%3CLINGO-SUB%20id%3D%22lingo-sub-2179856%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E8%87%AA%E5%AE%9A%E4%B9%89%20imx8mp%20%E6%9D%BF%E4%B8%AD%E7%9A%84%20SE050E%20%E6%A3%80%E6%B5%8B%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2179856%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CEM%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%E4%B8%AD%E9%97%B4%E4%BB%B6%E7%A4%BA%E4%BE%8B%20se05x_GetInfo%20%E6%9D%A5%E9%AA%8C%E8%AF%81%E6%88%91%E4%BB%AC%E5%9F%BA%E4%BA%8E%20IMX8MP%20%E7%9A%84%E5%AE%9A%E5%88%B6%E6%9D%BF%E4%B8%AD%E6%8E%A5%E5%8F%A3%E7%9A%84%20SE050E%20%E8%8A%AF%E7%89%87%E3%80%82%3C%2FEM%3E%3C%2FSTRONG%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E4%BD%BF%E7%94%A8%E5%BA%94%E7%94%A8%E7%AC%94%E8%AE%B0%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN13027.pdf%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EAN13027.pdf%3C%2FA%3E%20%E6%9E%84%E5%BB%BA%E5%92%8C%E9%83%A8%E7%BD%B2%E4%BA%86%E4%B8%AD%E9%97%B4%E4%BB%B6%E3%80%82%E7%94%B1%E4%BA%8E%20SE%20%E4%B8%8E%3CSTRONG%3Ei2c-4%3C%2FSTRONG%3E%E7%9B%B8%E8%BF%9E%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%88%91%E4%BF%AE%E6%94%B9%E4%BA%86%3CBR%20%2F%3E%3CEM%3Estatic%20char*%20default_axSmDevice_name%20%3D%22%2Fdev%2Fi2c-1%22%3B%20%3CBR%20%2F%3E%E4%B8%BA%20static%20char*%20default_axSmDevice_name%20%3D%22%3C%2FEM%3E%2Fdev%2Fi2c-3%22%3B%20%E5%9C%A8%20simw%20top%2Fhostlib%2FhostLib%2Fplatform%2Flinux%2Fi2c_a7.c%E4%B8%AD%20%E9%94%89%E5%88%80%3C%2FP%3E%3CP%3E%E6%88%91%E8%BF%98%E6%98%AF%E9%81%87%E5%88%B0%E4%BA%86%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FP%3E%3CP%3Eroot%40imx8mp-lpddr4-evk%3A~%23%20se05x_GetInfo%3CBR%20%2F%3EApp%20%3AINFO%20%3APlugAndTrust_v04.05.00_20231201%3CBR%20%2F%3EApp%20%3AINFO%20%3ARunning%20se05x_GetInfo%3CBR%20%2F%3EApp%20%3AINFO%20%3A%E5%A6%82%E6%9E%9C%E8%A6%81%E8%A6%86%E7%9B%96%E9%80%89%E6%8B%A9%EF%BC%8C%E8%AF%B7%E4%BD%BF%E7%94%A8%20ENV%3DEX_SSS_BOOT_SSS_PORT%20%E6%88%96%E4%BC%A0%E9%80%92%E5%91%BD%E4%BB%A4%E8%A1%8C%E5%8F%82%E6%95%B0%E3%80%82%3CBR%20%2F%3EsmCom%20%3AERROR%3AFailed%20writing%20data%20(nrWritten%3D-1).%3C%2FP%3E%3CP%3EsmCom%20%3AERROR%3A%20-%20Error%20in%20I2C%20Write.....%3CBR%20%2F%3EsmCom%20%3AERROR%3AphNxpEseProto7816_SendRawFrame%20Error%20phNxpEse_WriteFrame%3CBR%20%2F%3EsmCom%20%3AERROR%3ATransceiveProcess%20Transceive%20send%20failed%2C%20going%20to%20recovery!%3CBR%20%2F%3EsmCom%20%3AERROR%3AphNxpEseProto7816_Open%20failed%3CBR%20%2F%3EsmCom%20%3AERROR%EF%BC%9AFailed%20to%20Open%20session%3CBR%20%2F%3Esss%20%3AERROR%3ASM_I2CConnect%20Failed.Status%207012%3CBR%20%2F%3EApp%20%3AERROR%3Asss_session_open%20failed%3CBR%20%2F%3EApp%20%3AERROR%3Aex_sss_session_open%20Failed%3CBR%20%2F%3EApp%20%3AERROR%3A!ERROR%EF%BC%81ret%20!%3D%200%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E8%BF%98%E9%99%84%E4%B8%8A%E4%BA%86%20cmake%20%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%20cmake-conf.txt%E3%80%82%3C%2FP%3E%3CP%3E%E6%9C%89%E4%BA%BA%E5%BB%BA%E8%AE%AE%E6%98%AF%E5%90%A6%E9%9C%80%E8%A6%81%E5%AF%B9%E6%BA%90%E4%BB%A3%E7%A0%81%E8%BF%9B%E8%A1%8C%E5%85%B6%E4%BB%96%E4%BF%AE%E6%94%B9%E5%90%97%EF%BC%9F%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2184580%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050E%20detection%20issue%20in%20custom%20imx8mp%20board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2184580%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F235882%22%20target%3D%22_blank%22%3E%40pratham_malaviya%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ESE050E%20%E7%9A%84%E9%BB%98%E8%AE%A4%20I2C%20%E5%9C%B0%E5%9D%80%E6%98%AF%200x48%EF%BC%8C%E6%89%80%E4%BB%A5%E6%A0%B9%E6%8D%AE%E4%BD%A0%E7%9A%84%E6%B5%8B%E8%AF%95%EF%BC%8C%2Fdev%2Fi2c-3%20%E4%B8%8A%E6%B2%A1%E6%9C%89%E8%BF%99%E6%A0%B7%E7%9A%84%E8%AE%BE%E5%A4%87%EF%BC%8C%E4%B8%BB%E6%9C%BA%E4%B8%8E%E4%BD%A0%E7%9A%84%E4%B8%BB%E6%9D%BF%E4%B8%8A%E7%9A%84%20SE050E%20%E4%B9%8B%E9%97%B4%E6%9C%89%E4%BB%BB%E4%BD%95%E8%BF%9E%E6%8E%A5%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%E5%B0%86%E7%A4%BA%E6%84%8F%E5%9B%BE%E7%94%A8%E4%BA%8E%E5%AE%A1%E6%9F%A5%EF%BC%9F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%A5%9D%E6%82%A8%E6%84%89%E5%BF%AB%EF%BC%8C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%3CBR%20%2F%3E-%20%E5%A6%82%E6%9E%9C%E6%9C%AC%E5%B8%96%E5%9B%9E%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%22%E6%A0%87%E8%AE%B0%E6%AD%A3%E7%A1%AE%22%20%E6%8C%89%E9%92%AE%E3%80%82%E8%B0%A2%E8%B0%A2%EF%BC%81%3CBR%20%2F%3E-%20%E6%88%91%E4%BB%AC%E4%BC%9A%E5%9C%A8%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E5%8F%91%E5%B8%96%E5%90%8E%E7%9A%84%207%20%E5%91%A8%E5%86%85%E8%B7%9F%E8%B8%AA%E4%B8%BB%E9%A2%98%EF%BC%8C%E4%B9%8B%E5%90%8E%E7%9A%84%E5%9B%9E%E5%A4%8D%E5%B0%86%E8%A2%AB%E5%BF%BD%E7%95%A5%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BB%A5%E5%90%8E%E6%9C%89%E7%9B%B8%E5%85%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E5%8F%A6%E5%BC%80%E6%96%B0%E4%B8%BB%E9%A2%98%EF%BC%8C%E5%B9%B6%E5%8F%82%E8%80%83%E5%B7%B2%E5%85%B3%E9%97%AD%E7%9A%84%E4%B8%BB%E9%A2%98%E3%80%82%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2183767%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050E%20detection%20issue%20in%20custom%20imx8mp%20board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2183767%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59276%22%20target%3D%22_blank%22%3E%40Kan_Li%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E6%88%91%E8%AF%95%E7%9D%80%E4%BD%BF%E7%94%A8%E7%BB%99%E5%87%BA%E7%9A%84%E5%91%BD%E4%BB%A4%EF%BC%8C%E5%BE%97%E5%88%B0%E7%9A%84%E8%BE%93%E5%87%BA%E7%BB%93%E6%9E%9C%E5%A6%82%E4%B8%8B%20%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Eroot%40imx8mp-lpddr4-evk%3A~%23%20i2cdetect%20-y%20-a%20-q%203%0A%20%20%20%20%200%20%201%20%202%20%203%20%204%20%205%20%206%20%207%20%208%20%209%20%20a%20%20b%20%20c%20%20d%20%20e%20%20f%0A00%3A%2000%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20%0A10%3A%2010%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20%0A20%3A%20--%2021%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20%0A30%3A%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20%0A40%3A%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20%0A50%3A%20--%20--%20--%20--%20--%2055%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20%0A60%3A%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20%0A70%3A%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%207f%20%0Aroot%40imx8mp-lpddr4-evk%3A~%23%20%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%E4%BD%BF%E7%94%A8%20Getinfo%20%E5%B7%A5%E5%85%B7%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%E6%97%B6%EF%BC%8C%E4%B9%9F%E5%87%BA%E7%8E%B0%E4%BA%86%E5%90%8C%E6%A0%B7%E7%9A%84%E9%94%99%E8%AF%AF%E3%80%81%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Eroot%40imx8mp-lpddr4-evk%3A~%2Fsimw-top_build%2Fimx_native_se050_t1oi2c%2Fbin%23%20.%2Fse05x_GetInfo%20%0AApp%20%20%20%3AINFO%20%3APlugAndTrust_v04.05.00_20231201%0AApp%20%20%20%3AINFO%20%3ARunning%20.%2Fse05x_GetInfo%0AApp%20%20%20%3AINFO%20%3AUsing%20PortName%3D'%2Fdev%2Fi2c-3'%20(ENV%3A%20EX_SSS_BOOT_SSS_PORT%3D%2Fdev%2Fi2c-3)%0AsmCom%20%3AERROR%3AFailed%20writing%20data%20(nrWritten%3D-1).%0A%0AsmCom%20%3AERROR%3A%20-%20Error%20in%20I2C%20Write.....%0AsmCom%20%3AERROR%3AphNxpEseProto7816_SendRawFrame%20Error%20phNxpEse_WriteFrame%20%0AsmCom%20%3AERROR%3ATransceiveProcess%20Transceive%20send%20failed%2C%20going%20to%20recovery!%20%0AsmCom%20%3AERROR%3AphNxpEseProto7816_Open%20failed%20%0AsmCom%20%3AERROR%3A%20Failed%20to%20Open%20session%20%0Asss%20%20%20%3AERROR%3ASM_I2CConnect%20Failed.%20Status%207012%0AApp%20%20%20%3AERROR%3Asss_session_open%20failed%0AApp%20%20%20%3AERROR%3Aex_sss_session_open%20Failed%0AApp%20%20%20%3AERROR%3A!ERROR!%20ret%20!%3D%200.%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%E8%83%BD%E5%90%A6%E8%AF%B7%E6%82%A8%E6%8C%87%E5%AF%BC%E6%88%91%E8%BF%9B%E8%A1%8C%E9%AA%8C%E8%AF%81%EF%BC%9F%20%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3E%E6%99%AE%E6%8B%89%E5%A1%94%E5%A7%86%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2183616%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050E%20detection%20issue%20in%20custom%20imx8mp%20board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2183616%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F235882%22%20target%3D%22_blank%22%3E%40pratham_malaviya%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E4%BD%A0%E6%9C%89%E6%B2%A1%E6%9C%89%E8%AF%95%E8%BF%87%E5%83%8F%E4%B8%8B%E9%9D%A2%E8%BF%99%E6%A0%B7%E7%9A%84%20i2cdetect%20%E5%91%BD%E4%BB%A4%E6%9D%A5%E6%8E%A2%E6%B5%8B%20%2Fdev%2Fi2c-3%20%E4%B8%8A%E7%9A%84%20SE%20%E8%AE%BE%E5%A4%87%EF%BC%9F%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Ei2cdetect%20-y%20-a%20-q%203%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%E8%80%8C%E4%B8%94%E4%BD%A0%E6%A0%B9%E6%9C%AC%E4%B8%8D%E9%9C%80%E8%A6%81%E4%BF%AE%E6%94%B9%E6%BA%90%E4%BB%A3%E7%A0%81%EF%BC%8C%E5%8F%AA%E9%9C%80%E5%9C%A8%E8%BF%90%E8%A1%8C%E4%BB%BB%E4%BD%95%20MW%20%E6%BC%94%E7%A4%BA%E4%B9%8B%E5%89%8D%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%E5%8D%B3%E5%8F%AF%E3%80%82%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Eexport%20EX_SSS_BOOT_SSS_PORT%3D%2Fdev%2Fi2c-3%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%B8%8C%E6%9C%9B%E5%AF%B9%E4%BD%A0%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%A5%9D%E6%82%A8%E6%84%89%E5%BF%AB%EF%BC%8C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%3CBR%20%2F%3E-%20%E5%A6%82%E6%9E%9C%E6%9C%AC%E5%B8%96%E5%9B%9E%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%22%E6%A0%87%E8%AE%B0%E6%AD%A3%E7%A1%AE%22%20%E6%8C%89%E9%92%AE%E3%80%82%E8%B0%A2%E8%B0%A2%EF%BC%81%3CBR%20%2F%3E-%20%E6%88%91%E4%BB%AC%E4%BC%9A%E5%9C%A8%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E5%8F%91%E5%B8%96%E5%90%8E%E7%9A%84%207%20%E5%91%A8%E5%86%85%E8%B7%9F%E8%B8%AA%E4%B8%BB%E9%A2%98%EF%BC%8C%E4%B9%8B%E5%90%8E%E7%9A%84%E5%9B%9E%E5%A4%8D%E5%B0%86%E8%A2%AB%E5%BF%BD%E7%95%A5%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BB%A5%E5%90%8E%E6%9C%89%E7%9B%B8%E5%85%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E5%8F%A6%E5%BC%80%E6%96%B0%E4%B8%BB%E9%A2%98%EF%BC%8C%E5%B9%B6%E5%8F%82%E8%80%83%E5%B7%B2%E5%85%B3%E9%97%AD%E7%9A%84%E4%B8%BB%E9%A2%98%E3%80%82%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E
