SE050C2HQ1 middle ware integration issue
4,530件の閲覧回数
daisuke2
I am trying to integrate middle ware for SE050C2HQ1 on imx8mp custom board.
I used 'SE-PLUG-TRUST-MW_04.07.01.zip' from nxp portal site and build with cmake flag as bellow
-DCMAKE_BUILD_TYPE=Debug \
-DPTMW_Host=iMXLinux -DPTMW_HostCrypto=OPENSSL -DPTMW_SMCOM=T1oI2C \
-DPTMW_SE05X_Auth=PlatfSCP03 -DPTMW_SCP=SCP03_SSS -DPTMW_Applet=SE05X_A \
-DPTMW_SE05X_Ver=07_02
when i trying to run 'ex_ecc', i am keep getting error like bellow
----log----------------------
App :INFO :Running ex_ecc
App :INFO :Using PortName='/dev/i2c-2' (CLI)
App :INFO :PlugAndTrust_v04.07.01_20250519
App :WARN :Using SCP03 keys from:'/etc/se05x/scp03_keys.bin' (ENV=EX_SSS_BOOT_SCP03_PATH)
App :ERROR:Unknown key type «Í«Í«Í«Í«Í«Í«Í[m
sss :INFO :atr (Len=35)
01 A0 00 00 03 96 04 03 E8 00 FE 02 0B 03 E8 00
01 00 00 00 00 64 13 88 0A 00 65 53 45 30 35 31
00 00 00
sss :INFO :Newer version of Applet Found
sss :INFO :Compiled for 0x70200. Got newer 0x70216
scp :WARN :nxEnsure:'status == kStatus_SSS_Success' failed. At Line:148 Function:nxScp03_AuthenticateChannel
sss :ERROR:Could not set SCP03 Secure Channel
App :ERROR:sss_session_open failed
App :ERROR:ex_sss_session_open Failed
App :ERROR:!ERROR! ret != 0.
I thought that my scp3-key 'scp03_keys.bin'  might be problem, so i tried 'se05x_MandatePlatformSCP' and 'se05x_Delete_and_test_provision'.
But  keep getting "unknown key type" error and fails.
It seems that Applet in SE050C2H is new than "SE-PLUG-TRUST-MW_04.07.01.zip".
Is there any newer "SE-PLUG-TRUST-MW_04.07.xx.zip" available?
Or it could be different issue other than Applet version mismatch ?
Best Regards
daisuke
7 返答(返信)
4,519件の閲覧回数
daisuke2
One correction. I was wrong. Secure IC is SE052F2HN2 not SE050C2HQ1 .
4,512件の閲覧回数
Kan_Li
Hi @daisuke2 ,
Please kindly refer to table 3 in https://www.nxp.com/docs/en/application-note/AN14028.pdf for details regarding the Cmake-settings for SE052F.
Hope that helps,
Kan
4,470件の閲覧回数
daisuke2
Hi Kan,
I fixed the cmake flag  SE05X_C   and define SSS_PFSCP_ENABLE_SE052_B501=1 in header file.
But it still can't establish secure channel.
-----log----------
oot@harmonia-mvp1-dvt-machine:~# se05x_GetInfo /dev/i2c-2
App :INFO :Running se05x_GetInfo
App :INFO :Using default PlatfSCP03 keys. You can use keys from file using ENV=EX_SSS_BOOT_SCP03_PATH
00 00 00
I tried "DPTMW_SE05X_Auth=None". This did not work before, but
Is it possible to control SE052F2HN2  without scp3 secure channel?
Does this applet version mismatch mater at all?
daisuke
4,432件の閲覧回数
Kan_Li
Hi @daisuke2 ,
How did you change the default platformSCP keys for SE052F? It is not in the head file, it is in the fsl_sss_ftr.h.in file including options to select one of the predefined default
Platform SCP keys. This file is located in: simw-top/sss/inc.
Alternatively, you may set up a file to contain the default platformSCP keys for SE052F. Please refer to SE-PLUG-TRUST-MW_04.07.01/simw-top/doc/appendix/platfscp.html for more details.
PlatformSCP is mandatory for SE052F2 as required by FIPS certification.
Does this applet version mismatch mater at all? - I didn't find any mismatch info from the log. what are you referring to?
Kan
4,426件の閲覧回数
daisuke2
Hi Kan,
Ok, let me check the SCP3 key in embedded.
Applet version mismatch thing is like
---log-------
00 00 00
daisuke
4,392件の閲覧回数
Kan_Li
Hi @daisuke2 ,
The following is the default platformSCP keys for SE052F, was it the same as yours? please kindly refer to https://www.nxp.com/docs/en/application-note/AN14277.pdf for more details.
Applet version mismatch info like  "sss :INFO :Compiled for 0x70200. Got newer 0x70216" doesn't matter at all.
Kan
4,423件の閲覧回数
daisuke2
Hi Kan,
Tried 10.11 Using own Platform SCP03 Keys.
Looks does not work either. somehow keep getting 'Unknown key type' error when i setup local key file.
---log----
root@harmonia-mvp1-dvt-machine:~# export EX_SSS_BOOT_SCP03_PATH=/etc/se05x/plain_scp.txt
root@harmonia-mvp1-dvt-machine:~# ex_ecc /dev/i2c-2
App :WARN :Using SCP03 keys from:'/etc/se05x/plain_scp.txt' (ENV=EX_SSS_BOOT_SCP03_PATH)
00 00 00
daisuke
%3CLINGO-SUB%20id%3D%22lingo-sub-2197745%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ESE050C2HQ1%20%E3%83%9F%E3%83%89%E3%83%AB%E3%82%A6%E3%82%A7%E3%82%A2%E7%B5%B1%E5%90%88%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2197745%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3C%2FP%3E%3CP%3Eimx8mp%20%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%20SE050C2HQ1%20%E7%94%A8%E3%81%AE%E3%83%9F%E3%83%89%E3%83%AB%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E7%B5%B1%E5%90%88%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFnxp%E3%83%9D%E3%83%BC%E3%82%BF%E3%83%AB%E3%82%B5%E3%82%A4%E3%83%88%E3%81%8B%E3%82%89%E3%80%8CSE-PLUG-TRUST-MW_04.07.01.zip%E3%80%8D%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%88%E3%81%86%E3%81%ABcmake%E3%83%95%E3%83%A9%E3%82%B0%E3%81%A7%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E---------------------------%3C%2FP%3E%3CP%3E-DCMAKE_BUILD_TYPE%3D%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%5C%3CBR%20%2F%3E%20-DPTMW_Host%3DiMXLinux%20-DPTMW_HostCrypto%3DOPENSSL%20-DPTMW_SMCOM%3DT1oI2C%20%5C%3CBR%20%2F%3E%20-DPTMW_SE05X_Auth%3DPlatfSCP03%20-DPTMW_SCP%3DSCP03_SSS%20-DPTMW_Applet%3DSE05X_A%20%5C%3CBR%20%2F%3E%20-DPTMW_SE05X_Ver%3D07_02%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E'ex_ecc'%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%B9%B0%E3%82%8A%E8%BF%94%E3%81%97%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E-%20%20-%20%E3%83%AD%E3%82%B0%20-%20%20-%20%20-%20%20-%20%20-%20%20-%20%20-%20%20-%20%20-%20%20-%20%20-%20%3C%2FP%3E%3CP%3E%E3%82%A2%E3%83%97%E3%83%AA%3AINFO%3Aex_ecc%20%E3%82%92%E5%AE%9F%E8%A1%8C%E4%B8%AD%3CBR%20%2F%3E%E3%82%A2%E3%83%97%E3%83%AA%3AINFO%3APortName%3D'%2Fdev%2Fi2c-2'%20%E3%82%92%E4%BD%BF%E7%94%A8%20(CLI)%3CBR%20%2F%3E%E3%82%A2%E3%83%97%E3%83%AA%3A%E6%83%85%E5%A0%B1%3APlugAndTrust_v04.07.01_20250519%3CBR%20%2F%3E%E3%82%A2%E3%83%97%E3%83%AA%3A%E8%AD%A6%E5%91%8A%3A'%2Fetc%2Fse05x%2Fscp03_keys.bin'%20%E3%81%8B%E3%82%89%E3%81%AE%20SCP03%20%E3%82%AD%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99(ENV%3DEX_SSS_BOOT_SCP03_PATH)%3CBR%20%2F%3E%E3%82%A2%E3%83%97%E3%83%AA%20%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%E4%B8%8D%E6%98%8E%E3%81%AA%E3%82%AD%E3%83%BC%20%E3%82%BF%E3%82%A4%E3%83%97%20%C2%AB%C3%8D%C2%AB%C3%8D%C2%AB%C3%8D%C2%AB%C3%8D%C2%AB%C3%8D%C2%AB%C3%8D%C2%AB%C3%8D%5Bm%3CBR%20%2F%3E%20sss%20%3AINFO%20%3Aatr%20(%E9%95%B7%E3%81%95%3D35)%3CBR%20%2F%3E%2001%20A0%2000%2000%2003%2096%2004%2003%20E8%2000%20FE%2002%200B%2003%20E8%2000%3CBR%20%2F%3E%2001%2000%2000%2000%2000%2064%2013%2088%200A%2000%2065%2053%2045%2030%2035%2031%3CBR%20%2F%3E%2000%2000%2000%3CBR%20%2F%3E%20sss%20%3AINFO%20%3A%E3%82%A2%E3%83%97%E3%83%AC%E3%83%83%E3%83%88%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Esss%20%3AINFO%20%3A0x70200%20%E7%94%A8%E3%81%AB%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%96%B0%E3%81%97%E3%81%840x70216%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Escp%3AWARN%3AnxEnsure%3A'status%20%3D%3D%20kStatus_SSS_Success'%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E8%A1%8C%3A148%20%E9%96%A2%E6%95%B0%3AnxScp03_AuthenticateChannel%3CBR%20%2F%3E%20sss%20%3A%E3%82%A8%E3%83%A9%E3%83%BC%3ASCP03%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E3%82%A2%E3%83%97%E3%83%AA%3A%E3%82%A8%E3%83%A9%E3%83%BC%3Asss_session_open%20%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E3%82%A2%E3%83%97%E3%83%AA%3A%E3%82%A8%E3%83%A9%E3%83%BC%3Aex_sss_session_open%20%E5%A4%B1%E6%95%97%3CBR%20%2F%3E%E3%82%A2%E3%83%97%E3%83%AA%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A!%E3%82%A8%E3%83%A9%E3%83%BC!ret%20!%3D%200%E3%80%82%3C%2FP%3E%3CP%3E------------------------------------%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFscp3%E3%82%AD%E3%83%BC%E3%80%8Cscp03_keys.bin%E3%80%8D%E3%81%8C%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%AA%E3%81%84%E3%80%81SO%E3%80%8Cse05x_MandatePlatformSCP%E3%80%8D%E3%81%A8%E3%80%8Cse05x_Delete_and_test_provision%E3%80%8D%E3%82%92%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%80%8C%E4%B8%8D%E6%98%8E%E3%81%AA%E3%82%AD%E3%83%BC%20%E3%82%BF%E3%82%A4%E3%83%97%E3%80%8D%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E7%B6%9A%E3%81%91%E3%80%81%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ESE050C2H%20%E5%86%85%E3%81%AE%20Applet%20%E3%81%AF%E3%80%81%E3%80%8CSE-PLUG-TRUST-MW_04.07.01.zip%E3%80%8D%E3%82%88%E3%82%8A%E3%82%82%E6%96%B0%E3%81%97%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8A%E6%96%B0%E3%81%97%E3%81%84%E3%80%8CSE-PLUG-TRUST-MW_04.07.xx.zip%E3%80%8D%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%81%AF%E3%80%81%E3%82%A2%E3%83%97%E3%83%AC%E3%83%83%E3%83%88%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE%E4%B8%8D%E4%B8%80%E8%87%B4%E4%BB%A5%E5%A4%96%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%A7%E3%81%82%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E5%A4%A7%E8%BC%94%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2197745%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ESE050%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2199852%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050C2HQ1%20%20middle%20ware%20integration%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2199852%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F200599%22%20target%3D%22_blank%22%3E%40daisuke2%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AF%20SE052F%20%E3%81%AE%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20SCP%20%E3%82%AD%E3%83%BC%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%82%82%E3%81%AE%E3%81%A8%E5%90%8C%E3%81%98%E3%81%A7%E3%81%97%E3%81%9F%E3%81%8B%3F%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN14277.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN14277.pdf%3C%2FA%3E%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Kan_Li_0-1762414176073.png%22%20style%3D%22width%3A%20645px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1762414176073.png%22%20style%3D%22width%3A%20645px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F364243iF5246D5B23AA22BE%2Fimage-dimensions%2F645x128%3Fv%3Dv2%22%20width%3D%22645%22%20height%3D%22128%22%20role%3D%22button%22%20title%3D%22Kan_Li_0-1762414176073.png%22%20alt%3D%22Kan_Li_0-1762414176073.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%80%8C%20%3CSPAN%3Esss%20%3AINFO%20%3A0x70200%20%E7%94%A8%E3%81%AB%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%96%B0%E3%81%97%E3%81%84%200x70216%20%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%E3%80%8D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%A2%E3%83%97%E3%83%AC%E3%83%83%E3%83%88%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE%E4%B8%8D%E4%B8%80%E8%87%B4%E6%83%85%E5%A0%B1%E3%81%AF%E3%81%BE%E3%81%A3%E3%81%9F%E3%81%8F%E3%83%9E%E3%82%BF%E3%83%BC%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%99%E3%81%A6%E3%81%8D%E3%81%AA%E4%B8%80%E6%97%A5%E3%82%92%E3%80%81%3CBR%20%2F%3E%E3%82%AB%E3%83%B3%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E---------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%E8%A8%98%EF%BC%9A%3CBR%20%2F%3E%20-%20%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%8C%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%B8%E3%81%AE%E5%9B%9E%E7%AD%94%E3%81%A7%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%80%8C%E6%AD%A3%E8%A7%A3%E3%81%A8%E3%81%97%E3%81%A6%E3%83%9E%E3%83%BC%E3%82%AF%E3%80%8D%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%EF%BC%81%3CBR%20%2F%3E%20-%20Thread%E3%81%AF%E6%9C%80%E5%BE%8C%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%8B%E3%82%897%E9%80%B1%E9%96%93%E3%83%95%E3%82%A9%E3%83%AD%E3%83%BC%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E4%BB%A5%E9%99%8D%E3%81%AE%E8%BF%94%E4%BF%A1%E3%81%AF%E7%84%A1%E8%A6%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E5%BE%8C%E3%81%BB%E3%81%A9%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%96%B0%E3%81%97%E3%81%84Thread%E3%82%92%E9%96%8B%E3%81%84%E3%81%A6%E3%80%81%E9%96%89%E3%81%98%E3%81%9FThread%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E---------------------------------------------------------------------------------%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2199036%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050C2HQ1%20%20middle%20ware%20integration%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2199036%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%82%AB%E3%83%B3%E3%81%95%E3%82%93%3C%2FP%3E%3CP%3E%E7%8B%AC%E8%87%AA%E3%81%AE%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20SCP03%20%E3%82%AD%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%2010.11%20%E3%82%92%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E8%A6%8B%E3%81%9F%E7%9B%AE%E3%82%82%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%20%E3%82%AD%E3%83%BC%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E4%BD%95%E3%82%89%E3%81%8B%E3%81%AE%E7%90%86%E7%94%B1%E3%81%A7%E3%80%8C%E4%B8%8D%E6%98%8E%E3%81%AA%E3%82%AD%E3%83%BC%20%E3%82%BF%E3%82%A4%E3%83%97%E3%80%8D%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E7%B6%9A%E3%81%91%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E-%20-%E3%83%AD%E3%82%B0%20-%20%20-%20%3C%2FP%3E%3CP%3Eroot%40harmonia-mvp1-dvt-machine%3A~%23%20EX_SSS_BOOT_SCP03_PATH%3D%2Fetc%2Fse05x%2Fplain_scp.txt%20%E3%82%92%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3Eroot%40harmonia-mvp1-dvt-machine%3A~%23%20ex_ecc%20%2Fdev%2Fi2c-2%3CBR%20%2F%3E%E3%82%A2%E3%83%97%E3%83%AA%3AINFO%3Aex_ecc%20%E3%82%92%E5%AE%9F%E8%A1%8C%E4%B8%AD%3CBR%20%2F%3E%E3%82%A2%E3%83%97%E3%83%AA%3AINFO%3APortName%3D'%2Fdev%2Fi2c-2'%20%E3%82%92%E4%BD%BF%E7%94%A8%20(CLI)%3CBR%20%2F%3E%E3%82%A2%E3%83%97%E3%83%AA%3A%E6%83%85%E5%A0%B1%3APlugAndTrust_v04.07.01_20250519%3CBR%20%2F%3E%E3%82%A2%E3%83%97%E3%83%AA%3A%E8%AD%A6%E5%91%8A%3A'%2Fetc%2Fse05x%2Fplain_scp.txt'%20%E3%81%8B%E3%82%89%E3%81%AE%20SCP03%20%E3%82%AD%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99(ENV%3DEX_SSS_BOOT_SCP03_PATH)%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3E%E3%82%A2%E3%83%97%E3%83%AA%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%E4%B8%8D%E6%98%8E%E3%81%AA%E3%82%AD%E3%83%BC%E3%82%BF%E3%82%A4%E3%83%97%3C%2FFONT%3E%3CBR%20%2F%3Esss%20%3AINFO%20%3Aatr%20(%E9%95%B7%E3%81%95%3D35)%3CBR%20%2F%3E%2001%20A0%2000%2000%2003%2096%2004%2003%20E8%2000%20FE%2002%200B%2003%20E8%2000%3CBR%20%2F%3E%2001%2000%2000%2000%2000%2064%2013%2088%200A%2000%2065%2053%2045%2030%2035%2031%3CBR%20%2F%3E%2000%2000%2000%3CBR%20%2F%3E%20%3CFONT%20color%3D%22%23FF0000%22%3Esss%20%3AINFO%20%3A%E3%82%A2%E3%83%97%E3%83%AC%E3%83%83%E3%83%88%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FFONT%3E%3CBR%20%2F%3Esss%20%3AINFO%20%3A0x70200%20%E7%94%A8%E3%81%AB%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%96%B0%E3%81%97%E3%81%840x70216%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Escp%3AWARN%3AnxEnsure%3A'status%20%3D%3D%20kStatus_SSS_Success'%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E8%A1%8C%3A148%20%E9%96%A2%E6%95%B0%3AnxScp03_AuthenticateChannel%3CBR%20%2F%3E%20sss%20%3A%E3%82%A8%E3%83%A9%E3%83%BC%3ASCP03%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E3%82%A2%E3%83%97%E3%83%AA%3A%E3%82%A8%E3%83%A9%E3%83%BC%3Asss_session_open%20%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E3%82%A2%E3%83%97%E3%83%AA%3A%E3%82%A8%E3%83%A9%E3%83%BC%3Aex_sss_session_open%20%E5%A4%B1%E6%95%97%3CBR%20%2F%3E%E3%82%A2%E3%83%97%E3%83%AA%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A!%E3%82%A8%E3%83%A9%E3%83%BC!ret%20!%3D%200%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBR%3C%2FP%3E%3CP%3E%E5%A4%A7%E8%BC%94%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2198989%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050C2HQ1%20%20middle%20ware%20integration%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2198989%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%82%AB%E3%83%B3%E3%81%95%E3%82%93%3C%2FP%3E%3CP%3E%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%9F%8B%E3%82%81%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%9F%20SCP3%20%E3%82%AD%E3%83%BC%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%95%E3%81%9B%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%A2%E3%83%97%E3%83%AC%E3%83%83%E3%83%88%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E4%B8%8D%E4%B8%80%E8%87%B4%E3%81%A8%E3%81%84%E3%81%86%E3%81%AE%E3%81%AF%3C%2FP%3E%3CP%3E-%20-%E3%83%AD%E3%82%B0%20-%20%20-%20%20-%20-%3C%2FP%3E%3CP%3E%E3%82%A2%E3%83%97%E3%83%AA%3AINFO%3Aex_ecc%20%E3%82%92%E5%AE%9F%E8%A1%8C%E4%B8%AD%3CBR%20%2F%3E%E3%82%A2%E3%83%97%E3%83%AA%3AINFO%3APortName%3D'%2Fdev%2Fi2c-2'%20%E3%82%92%E4%BD%BF%E7%94%A8%20(CLI)%3CBR%20%2F%3E%E3%82%A2%E3%83%97%E3%83%AA%3A%E6%83%85%E5%A0%B1%3APlugAndTrust_v04.07.01_20250519%3CBR%20%2F%3E%E3%82%A2%E3%83%97%E3%83%AA%3AINFO%3A%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%20PlatfSCP03%20%E3%82%AD%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82ENV%3DEX_SSS_BOOT_SCP03_PATH%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8B%E3%82%89%E3%82%AD%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%20CAN%E3%80%82%3CBR%20%2F%3E%20sss%20%3AINFO%20%3Aatr%20(%E9%95%B7%E3%81%95%3D35)%3CBR%20%2F%3E%2001%20A0%2000%2000%2003%2096%2004%2003%20E8%2000%20FE%2002%200B%2003%20E8%2000%3CBR%20%2F%3E%2001%2000%2000%2000%2000%2064%2013%2088%200A%2000%2065%2053%2045%2030%2035%2031%3CBR%20%2F%3E%2000%2000%2000%3CBR%20%2F%3E%20sss%20%3AINFO%20%3A%E3%82%A2%E3%83%97%E3%83%AC%E3%83%83%E3%83%88%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3Esss%20%3AINFO%20%3A0x70200%20%E7%94%A8%E3%81%AB%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%96%B0%E3%81%97%E3%81%84%200x70216%20%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FFONT%3E%3CBR%20%2F%3Escp%3AWARN%3AnxEnsure%3A'status%20%3D%3D%20kStatus_SSS_Success'%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E8%A1%8C%3A148%20%E9%96%A2%E6%95%B0%3AnxScp03_AuthenticateChannel%3CBR%20%2F%3E%20sss%20%3A%E3%82%A8%E3%83%A9%E3%83%BC%3ASCP03%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E3%82%A2%E3%83%97%E3%83%AA%3A%E3%82%A8%E3%83%A9%E3%83%BC%3Asss_session_open%20%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E3%82%A2%E3%83%97%E3%83%AA%3A%E3%82%A8%E3%83%A9%E3%83%BC%3Aex_sss_session_open%20%E5%A4%B1%E6%95%97%3CBR%20%2F%3E%E3%82%A2%E3%83%97%E3%83%AA%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A!%E3%82%A8%E3%83%A9%E3%83%BC!ret%20!%3D%200%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBR%3C%2FP%3E%3CP%3E%E5%A4%A7%E8%BC%94%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2198804%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050C2HQ1%20%20middle%20ware%20integration%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2198804%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F200599%22%20target%3D%22_blank%22%3E%40daisuke2%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ESE052F%20%E3%81%AE%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20SCP%20%E3%82%AD%E3%83%BC%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%E3%81%93%E3%82%8C%E3%81%AF%E3%83%98%E3%83%83%E3%83%89%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E5%AE%9A%E7%BE%A9%E6%B8%88%E3%81%BF%E3%81%AE%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E3%81%84%E3%81%9A%E3%82%8C%E3%81%8B%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%99%E3%82%8B%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%90%AB%E3%82%80fsl_sss_ftr.h.in%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20SCP%20%E3%82%AD%E3%83%BC%E3%80%82%E3%81%93%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E3%80%81simw-top%2Fsss%2Finc%20%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%82%E3%82%8B%E3%81%84%E3%81%AF%E3%80%81SE052F%20%E3%81%AE%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%20platformSCP%20%E3%82%AD%E3%83%BC%E3%82%92%E5%90%AB%E3%82%80%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81SE-PLUG-TRUST-MW_04.07.01%2Fsimw-top%2Fdoc%2Fappendix%2Fplatfscp.html%20%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EFIPS%20%E8%AA%8D%E8%A8%BC%E3%81%AE%E8%A6%81%E4%BB%B6%E3%81%AB%E5%BE%93%E3%81%84%E3%80%81PlatformSCP%20%E3%81%AF%20SE052F2%20%E3%81%AB%E5%BF%85%E9%A0%88%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%81%93%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AC%E3%83%83%E3%83%88%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE%E4%B8%8D%E4%B8%80%E8%87%B4%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%20-%20%E3%83%AD%E3%82%B0%E3%81%8B%E3%82%89%E4%B8%8D%E4%B8%80%E8%87%B4%E3%81%AE%E6%83%85%E5%A0%B1%E3%81%AF%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E4%BD%95%E3%81%AE%E3%81%93%E3%81%A8%E3%82%92%E8%A8%80%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%99%E3%81%A6%E3%81%8D%E3%81%AA%E4%B8%80%E6%97%A5%E3%82%92%E3%80%81%3CBR%20%2F%3E%E3%82%AB%E3%83%B3%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E---------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%E8%A8%98%EF%BC%9A%3CBR%20%2F%3E%20-%20%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%8C%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%B8%E3%81%AE%E5%9B%9E%E7%AD%94%E3%81%A7%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%80%8C%E6%AD%A3%E8%A7%A3%E3%81%A8%E3%81%97%E3%81%A6%E3%83%9E%E3%83%BC%E3%82%AF%E3%80%8D%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%EF%BC%81%3CBR%20%2F%3E%20-%20Thread%E3%81%AF%E6%9C%80%E5%BE%8C%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%8B%E3%82%897%E9%80%B1%E9%96%93%E3%83%95%E3%82%A9%E3%83%AD%E3%83%BC%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E4%BB%A5%E9%99%8D%E3%81%AE%E8%BF%94%E4%BF%A1%E3%81%AF%E7%84%A1%E8%A6%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E5%BE%8C%E3%81%BB%E3%81%A9%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%96%B0%E3%81%97%E3%81%84Thread%E3%82%92%E9%96%8B%E3%81%84%E3%81%A6%E3%80%81%E9%96%89%E3%81%98%E3%81%9FThread%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E---------------------------------------------------------------------------------%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2198400%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050C2HQ1%20%20middle%20ware%20integration%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2198400%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%82%AB%E3%83%B3%E3%81%95%E3%82%93%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Ecmake%20%E3%83%95%E3%83%A9%E3%82%B0%20SE05X_C%20%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%80%81%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%20SSS_PFSCP_ENABLE_SE052_B501%3D1%20%E3%82%92%E5%AE%9A%E7%BE%A9%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%81%BE%E3%81%A0%E5%AE%89%E5%85%A8%E3%81%AA%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%82%92%E7%A2%BA%E7%AB%8B%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AFCAN%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E-%20%20-%20-%E3%83%AD%E3%82%B0%20-%20%20-%20%20-%20%20-%20%20-%20%3C%2FP%3E%3CP%3Eoot%40harmonia-mvp1-dvt-machine%3A~%23%20se05x_GetInfo%20%2Fdev%2Fi2c-2%3CBR%20%2F%3E%E3%82%A2%E3%83%97%E3%83%AA%3AINFO%3Ase05x_GetInfo%20%E3%82%92%E5%AE%9F%E8%A1%8C%E4%B8%AD%3CBR%20%2F%3E%E3%82%A2%E3%83%97%E3%83%AA%3AINFO%3APortName%3D'%2Fdev%2Fi2c-2'%20%E3%82%92%E4%BD%BF%E7%94%A8%20(CLI)%3CBR%20%2F%3E%E3%82%A2%E3%83%97%E3%83%AA%3A%E6%83%85%E5%A0%B1%3APlugAndTrust_v04.07.01_20250519%3CBR%20%2F%3E%E3%82%A2%E3%83%97%E3%83%AA%3AINFO%3A%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%20PlatfSCP03%20%E3%82%AD%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82ENV%3DEX_SSS_BOOT_SCP03_PATH%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8B%E3%82%89%E3%82%AD%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%20CAN%20%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20sss%20%3AINFO%20%3Aatr%20(%E9%95%B7%E3%81%95%3D35)%3CBR%20%2F%3E%2001%20A0%2000%2000%2003%2096%2004%2003%20E8%2000%20FE%2002%200B%2003%20E8%2000%3CBR%20%2F%3E%2001%2000%2000%2000%2000%2064%2013%2088%200A%2000%2065%2053%2045%2030%2035%2031%3CBR%20%2F%3E%2000%2000%2000%3CBR%20%2F%3E%20scp%3AWARN%3AnxEnsure%3A'status%20%3D%3D%20kStatus_SSS_Success'%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E8%A1%8C%3A148%20%E9%96%A2%E6%95%B0%3AnxScp03_AuthenticateChannel%3CBR%20%2F%3E%20sss%20%3A%E3%82%A8%E3%83%A9%E3%83%BC%3ASCP03%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E3%82%A2%E3%83%97%E3%83%AA%3A%E3%82%A8%E3%83%A9%E3%83%BC%3Asss_session_open%20%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E3%82%A2%E3%83%97%E3%83%AA%3A%E3%82%A8%E3%83%A9%E3%83%BC%3Aex_sss_session_open%20%E5%A4%B1%E6%95%97%3CBR%20%2F%3E%E3%82%A2%E3%83%97%E3%83%AA%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A!%E3%82%A8%E3%83%A9%E3%83%BC!ret%20!%3D%200%E3%80%82%3C%2FP%3E%3CP%3E--------------------------------%3C%2FP%3E%3CP%3E%E3%80%8CDPTMW_SE05X_Auth%3DNone%E3%80%8D%E3%82%92%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E4%BB%A5%E5%89%8D%E3%81%AF%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8B%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%8C%E3%80%81%3C%2FP%3E%3CP%3Escp3%20%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%20%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%AA%E3%81%97%E3%81%A7%20SE052F2HN2%20%E3%82%92%E5%88%B6%E5%BE%A1%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AC%E3%83%83%E3%83%88%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE%E4%B8%8D%E4%B8%80%E8%87%B4%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBR%3C%2FP%3E%3CP%3E%E5%A4%A7%E8%BC%94%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2197846%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050C2HQ1%20%20middle%20ware%20integration%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2197846%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F200599%22%20target%3D%22_blank%22%3E%40daisuke2%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ESE052F%20%E3%81%AE%20Cmake%20%E8%A8%AD%E5%AE%9A%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN14028.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN14028.pdf%3C%2FA%3E%E3%81%AE%E8%A1%A8%203%20%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%99%E3%81%A6%E3%81%8D%E3%81%AA%E4%B8%80%E6%97%A5%E3%82%92%E3%80%81%3CBR%20%2F%3E%E3%82%AB%E3%83%B3%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E---------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%E8%A8%98%EF%BC%9A%3CBR%20%2F%3E%20-%20%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%8C%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%B8%E3%81%AE%E5%9B%9E%E7%AD%94%E3%81%A7%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%80%8C%E6%AD%A3%E8%A7%A3%E3%81%A8%E3%81%97%E3%81%A6%E3%83%9E%E3%83%BC%E3%82%AF%E3%80%8D%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%EF%BC%81%3CBR%20%2F%3E%20-%20Thread%E3%81%AF%E6%9C%80%E5%BE%8C%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%8B%E3%82%897%E9%80%B1%E9%96%93%E3%83%95%E3%82%A9%E3%83%AD%E3%83%BC%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E4%BB%A5%E9%99%8D%E3%81%AE%E8%BF%94%E4%BF%A1%E3%81%AF%E7%84%A1%E8%A6%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E5%BE%8C%E3%81%BB%E3%81%A9%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%96%B0%E3%81%97%E3%81%84Thread%E3%82%92%E9%96%8B%E3%81%84%E3%81%A6%E3%80%81%E9%96%89%E3%81%98%E3%81%9FThread%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E---------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2197776%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050C2HQ1%20%20middle%20ware%20integration%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2197776%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3C%2FP%3E%3CP%3E%E8%A8%82%E6%AD%A3%E3%81%8C1%E3%81%A4%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AF%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%81%9F%E3%80%82%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%20IC%20%E3%81%AF%20SE050C2HQ1%20%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%20SE052F2HN2%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
