SE050C2HQ1 middle ware integration issue
4,449 次查看
daisuke2
I am trying to integrate middle ware for SE050C2HQ1 on imx8mp custom board.
I used 'SE-PLUG-TRUST-MW_04.07.01.zip' from nxp portal site and build with cmake flag as bellow
-DCMAKE_BUILD_TYPE=Debug \
-DPTMW_Host=iMXLinux -DPTMW_HostCrypto=OPENSSL -DPTMW_SMCOM=T1oI2C \
-DPTMW_SE05X_Auth=PlatfSCP03 -DPTMW_SCP=SCP03_SSS -DPTMW_Applet=SE05X_A \
-DPTMW_SE05X_Ver=07_02
when i trying to run 'ex_ecc', i am keep getting error like bellow
----log----------------------
App :INFO :Running ex_ecc
App :INFO :Using PortName='/dev/i2c-2' (CLI)
App :INFO :PlugAndTrust_v04.07.01_20250519
App :WARN :Using SCP03 keys from:'/etc/se05x/scp03_keys.bin' (ENV=EX_SSS_BOOT_SCP03_PATH)
App :ERROR:Unknown key type «Í«Í«Í«Í«Í«Í«Í[m
sss :INFO :atr (Len=35)
01 A0 00 00 03 96 04 03 E8 00 FE 02 0B 03 E8 00
01 00 00 00 00 64 13 88 0A 00 65 53 45 30 35 31
00 00 00
sss :INFO :Newer version of Applet Found
sss :INFO :Compiled for 0x70200. Got newer 0x70216
scp :WARN :nxEnsure:'status == kStatus_SSS_Success' failed. At Line:148 Function:nxScp03_AuthenticateChannel
sss :ERROR:Could not set SCP03 Secure Channel
App :ERROR:sss_session_open failed
App :ERROR:ex_sss_session_open Failed
App :ERROR:!ERROR! ret != 0.
I thought that my scp3-key 'scp03_keys.bin'  might be problem, so i tried 'se05x_MandatePlatformSCP' and 'se05x_Delete_and_test_provision'.
But  keep getting "unknown key type" error and fails.
It seems that Applet in SE050C2H is new than "SE-PLUG-TRUST-MW_04.07.01.zip".
Is there any newer "SE-PLUG-TRUST-MW_04.07.xx.zip" available?
Or it could be different issue other than Applet version mismatch ?
Best Regards
daisuke
7 回复数
4,438 次查看
daisuke2
One correction. I was wrong. Secure IC is SE052F2HN2 not SE050C2HQ1 .
4,431 次查看
Kan_Li
Hi @daisuke2 ,
Please kindly refer to table 3 in https://www.nxp.com/docs/en/application-note/AN14028.pdf for details regarding the Cmake-settings for SE052F.
Hope that helps,
Kan
4,389 次查看
daisuke2
Hi Kan,
I fixed the cmake flag  SE05X_C   and define SSS_PFSCP_ENABLE_SE052_B501=1 in header file.
But it still can't establish secure channel.
-----log----------
oot@harmonia-mvp1-dvt-machine:~# se05x_GetInfo /dev/i2c-2
App :INFO :Running se05x_GetInfo
App :INFO :Using default PlatfSCP03 keys. You can use keys from file using ENV=EX_SSS_BOOT_SCP03_PATH
00 00 00
I tried "DPTMW_SE05X_Auth=None". This did not work before, but
Is it possible to control SE052F2HN2  without scp3 secure channel?
Does this applet version mismatch mater at all?
daisuke
4,351 次查看
Kan_Li
Hi @daisuke2 ,
How did you change the default platformSCP keys for SE052F? It is not in the head file, it is in the fsl_sss_ftr.h.in file including options to select one of the predefined default
Platform SCP keys. This file is located in: simw-top/sss/inc.
Alternatively, you may set up a file to contain the default platformSCP keys for SE052F. Please refer to SE-PLUG-TRUST-MW_04.07.01/simw-top/doc/appendix/platfscp.html for more details.
PlatformSCP is mandatory for SE052F2 as required by FIPS certification.
Does this applet version mismatch mater at all? - I didn't find any mismatch info from the log. what are you referring to?
Kan
4,345 次查看
daisuke2
Hi Kan,
Ok, let me check the SCP3 key in embedded.
Applet version mismatch thing is like
---log-------
00 00 00
daisuke
4,311 次查看
Kan_Li
Hi @daisuke2 ,
The following is the default platformSCP keys for SE052F, was it the same as yours? please kindly refer to https://www.nxp.com/docs/en/application-note/AN14277.pdf for more details.
Applet version mismatch info like  "sss :INFO :Compiled for 0x70200. Got newer 0x70216" doesn't matter at all.
Kan
4,342 次查看
daisuke2
Hi Kan,
Tried 10.11 Using own Platform SCP03 Keys.
Looks does not work either. somehow keep getting 'Unknown key type' error when i setup local key file.
---log----
root@harmonia-mvp1-dvt-machine:~# export EX_SSS_BOOT_SCP03_PATH=/etc/se05x/plain_scp.txt
root@harmonia-mvp1-dvt-machine:~# ex_ecc /dev/i2c-2
App :WARN :Using SCP03 keys from:'/etc/se05x/plain_scp.txt' (ENV=EX_SSS_BOOT_SCP03_PATH)
00 00 00
daisuke
%3CLINGO-SUB%20id%3D%22lingo-sub-2197745%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ESE050C2HQ1%20%E4%B8%AD%E9%97%B4%E4%BB%B6%E9%9B%86%E6%88%90%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2197745%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%20%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E5%9C%A8%20imx8mp%20%E8%87%AA%E5%AE%9A%E4%B9%89%E6%9D%BF%E4%B8%8A%E9%9B%86%E6%88%90%20SE050C2HQ1%20%E7%9A%84%E4%B8%AD%E9%97%B4%E4%BB%B6%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E4%BA%86%E6%81%A9%E6%99%BA%E6%B5%A6%E9%97%A8%E6%88%B7%E7%BD%91%E7%AB%99%E4%B8%AD%E7%9A%84%20%E2%80%9CSE-plug-trust-mw_04.07.01.zip%E2%80%9D%20%E5%B9%B6%E4%BD%BF%E7%94%A8%20cmake%20%E6%A0%87%E5%BF%97%E8%BF%9B%E8%A1%8C%E7%89%88%E6%9C%AC%EF%BC%8C%E5%A6%82%E4%B8%8B%E6%89%80%E7%A4%BA%3C%2FP%3E%3CP%3E---------------------------%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E-DPTMW_Host%3DiMXLinux%20-DPTMW_HostCrypto%3DOPENSSL%20-DPTMW_SMCOM%3DT1oI2C%20%5C%3CBR%20%2F%3E-DPTMW_SE05X_Auth%3DPlatfSCP03%20-DPTMW_SCP%3DSCP03_SSS%20-DPTMW_Applet%3DSE05X_A%20%5C%3CBR%20%2F%3E-DPTMW_SE05X_Ver%3D07_02%20%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%BD%93%E6%88%91%E5%B0%9D%E8%AF%95%E8%BF%90%E8%A1%8C%20%22ex_ecc%20%22%E6%97%B6%EF%BC%8C%E4%B8%80%E7%9B%B4%E5%87%BA%E7%8E%B0%E7%B1%BB%E4%BC%BC%E4%B8%8B%E9%9D%A2%E7%9A%84%E9%94%99%E8%AF%AF%3C%2FP%3E%3CP%3E----log----------------------%3C%2FP%3E%3CP%3EApp%20%3AINFO%20%3ARunning%20ex_ecc%3CBR%20%2F%3EApp%20%3AINFO%20%3AUsing%20PortName%3D'%2Fdev%2Fi2c-2'%20(CLI)%3CBR%20%2F%3EApp%20%3AINFO%20%3APlugAndTrust_v04.07.01_20250519%3CBR%20%2F%3E%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%20%3AWARN%20%3A%E4%BD%BF%E7%94%A8%E6%9D%A5%E8%87%AA%3A'%2Fetc%2Fse05x%2Fscp03_keys.bin'%E7%9A%84%20SCP03%20%E5%AF%86%E9%92%A5(ENV%3DEX_SSS_BOOT_SCP03_PATH)%3CBR%20%2F%3EApp%20%3AERROR%3AUnknown%20key%20type%20%22%C3%8D%20%22%C3%8D%20%22%C3%8D%20%22%C3%8D%20%22%C3%8D%20%22%C3%8D%5Bm%3CBR%20%2F%3Esss%20%3AINFO%20%EF%BC%9Aatr%20(Len%3D35)%3CBR%20%2F%3E01%20A0%2000%2000%2003%2096%2004%2003%20E8%2000%20FE%2002%200B%2003%20E8%2000%3CBR%20%2F%3E01%2000%2000%2000%2064%2013%2088%200A%2000%2065%2053%2045%2030%2035%2031%3CBR%20%2F%3E00%2000%3CBR%20%2F%3Esss%20%3AINFO%20%3ANewer%20version%20of%20Applet%20Found%3CBR%20%2F%3Esss%20%3AINFO%20%3ACompiled%20for%200x70200.%E5%BE%97%E5%88%B0%E6%9B%B4%E6%96%B0%E7%9A%84%200x70216%3CBR%20%2F%3Escp%20%3AWARN%20%3AnxEnsure%3A'status%20%3D%3D%20kStatus_SSS_Success'%E5%A4%B1%E8%B4%A5%E3%80%82At%20Line%3A148%20Function%3AnxScp03_AuthenticateChannel%3CBR%20%2F%3Esss%20%3AERROR%3ACould%20not%20set%20SCP03%20Secure%20Channel%3CBR%20%2F%3EApp%20%3AERROR%3Asss_session_open%20failed%3CBR%20%2F%3EApp%20%3AERROR%3Aex_sss_session_open%20Failed%3CBR%20%2F%3EApp%20%3AERROR%3A!ERROR%EF%BC%81ret%20!%3D%200%E3%80%82%3C%2FP%3E%3CP%3E------------------------------------%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%A5%E4%B8%BA%E6%88%91%E7%9A%84%20scp3%20%E5%AF%86%E9%92%A5%20%22scp03_keys.bin%20%E5%8F%AF%E8%83%BD%E6%9C%89%E9%97%AE%E9%A2%98%EF%BC%8C%E6%89%80%E4%BB%A5%E6%88%91%E5%B0%9D%E8%AF%95%E4%BA%86%20%22se05x_MandatePlatformSCP%20%22%E5%92%8C%20%22se05x_Delete_and_test_provision%22%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%86%E4%B8%80%E7%9B%B4%E6%94%B6%E5%88%B0%22unknown%20key%20type%22%20%E9%94%99%E8%AF%AF%E5%B9%B6%E5%AF%BC%E8%87%B4%E5%A4%B1%E8%B4%A5%E3%80%82%3C%2FP%3E%3CP%3ESE050C2H%20%E4%B8%AD%E7%9A%84%20Applet%20%E4%BC%BC%E4%B9%8E%E6%AF%94%22SE-PLUG-TRUST-MW_04.07.01.zip%22%20%E6%96%B0%E3%80%82%3C%2FP%3E%3CP%3E%E6%98%AF%E5%90%A6%E6%9C%89%E6%9B%B4%E6%96%B0%E7%9A%84%22SE-PLUG-TRUST-MW_04.07.xx.zip%22%20%EF%BC%9F%3C%2FP%3E%3CP%3E%E9%99%A4%E4%BA%86%20Applet%20%E7%89%88%E6%9C%AC%E4%B8%8D%E5%8C%B9%E9%85%8D%E4%B9%8B%E5%A4%96%EF%BC%8C%E8%BF%98%E5%8F%AF%E8%83%BD%E6%9C%89%E5%85%B6%E4%BB%96%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3E%E5%A4%A7%E8%BE%85%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2197745%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ESE050%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2199852%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050C2HQ1%20%20middle%20ware%20integration%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2199852%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F200599%22%20target%3D%22_blank%22%3E%40daisuke2%3C%2FA%3E%EF%BC%8C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%20SE052F%20%E7%9A%84%E9%BB%98%E8%AE%A4%20platformSCP%20%E5%AF%86%E9%92%A5%EF%BC%8C%E6%98%AF%E5%90%A6%E4%B8%8E%E6%82%A8%E7%9A%84%E7%9B%B8%E5%90%8C%EF%BC%9F%E8%AF%A6%E6%83%85%E8%AF%B7%E5%8F%82%E9%98%85%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN14277.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN14277.pdf%3C%2FA%3E%E3%80%82%20%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Kan_Li_0-1762414176073.png%22%20style%3D%22width%3A%20645px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1762414176073.png%22%20style%3D%22width%3A%20645px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F364243iF5246D5B23AA22BE%2Fimage-dimensions%2F645x128%3Fv%3Dv2%22%20width%3D%22645%22%20height%3D%22128%22%20role%3D%22button%22%20title%3D%22Kan_Li_0-1762414176073.png%22%20alt%3D%22Kan_Li_0-1762414176073.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EApplet%20%E7%89%88%E6%9C%AC%E4%B8%8D%E5%8C%B9%E9%85%8D%E4%BF%A1%E6%81%AF%EF%BC%8C%E5%A6%82%22%20sss%3CSPAN%3E%3AINFO%20%3ACompiled%20for%200x70200.%E5%BE%97%E5%88%B0%E4%BA%86%E6%9B%B4%E6%96%B0%E7%9A%84%200x70216%3C%2FSPAN%3E%22%20%E5%AE%8C%E5%85%A8%E6%B2%A1%E6%9C%89%E5%85%B3%E7%B3%BB%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%A5%9D%E6%82%A8%E6%84%89%E5%BF%AB%EF%BC%8C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%3CBR%20%2F%3E-%20%E5%A6%82%E6%9E%9C%E6%9C%AC%E5%B8%96%E5%9B%9E%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%22%E6%A0%87%E8%AE%B0%E6%AD%A3%E7%A1%AE%22%20%E6%8C%89%E9%92%AE%E3%80%82%E8%B0%A2%E8%B0%A2%EF%BC%81%3CBR%20%2F%3E-%20%E6%88%91%E4%BB%AC%E4%BC%9A%E5%9C%A8%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E5%8F%91%E5%B8%96%E5%90%8E%E7%9A%84%207%20%E5%91%A8%E5%86%85%E8%B7%9F%E8%B8%AA%E4%B8%BB%E9%A2%98%EF%BC%8C%E4%B9%8B%E5%90%8E%E7%9A%84%E5%9B%9E%E5%A4%8D%E5%B0%86%E8%A2%AB%E5%BF%BD%E7%95%A5%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BB%A5%E5%90%8E%E6%9C%89%E7%9B%B8%E5%85%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E5%8F%A6%E5%BC%80%E6%96%B0%E4%B8%BB%E9%A2%98%EF%BC%8C%E5%B9%B6%E5%8F%82%E8%80%83%E5%B7%B2%E5%85%B3%E9%97%AD%E7%9A%84%E4%B8%BB%E9%A2%98%E3%80%82%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2199036%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050C2HQ1%20%20middle%20ware%20integration%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2199036%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8CKan%E3%80%81%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%E8%87%AA%E5%B7%B1%E5%B9%B3%E5%8F%B0%E7%9A%84%20SCP03%20%E5%AF%86%E9%92%A5%E8%AF%95%E7%94%A8%E4%BA%86%2010.11%20%E7%89%88%E3%80%82%3C%2FP%3E%3CP%3E%E5%A4%96%E8%A7%82%E4%B9%9F%E4%B8%8D%E8%A1%8C%E3%80%82%E4%B8%8D%E7%9F%A5%E4%BD%95%E6%95%85%EF%BC%8C%E5%BD%93%E6%88%91%E8%AE%BE%E7%BD%AE%E6%9C%AC%E5%9C%B0%E5%AF%86%E9%92%A5%E6%96%87%E4%BB%B6%E6%97%B6%EF%BC%8C%E6%80%BB%E6%98%AF%E5%87%BA%E7%8E%B0%20%22%E6%9C%AA%E7%9F%A5%E5%AF%86%E9%92%A5%E7%B1%BB%E5%9E%8B%20%22%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E---log----%3C%2FP%3E%3CP%3Eroot%40harmonia-mvp1-dvt-machine%3A~%23%20export%20EX_SSS_BOOT_SCP03_PATH%3D%2Fetc%2Fse05x%2Fplain_scp.txt%3CBR%20%2F%3Eroot%40harmonia-mvp1-dvt-machine%3A~%23%20ex_ecc%20%2Fdev%2Fi2c-2%3CBR%20%2F%3EApp%20%3AINFO%20%3ARunning%20ex_ecc%3CBR%20%2F%3EApp%20%3AINFO%20%3AUsing%20PortName%3D'%2Fdev%2Fi2c-2'%20(CLI)%3CBR%20%2F%3EApp%20%3AINFO%20%3APlugAndTrust_v04.07.01_20250519%3CBR%20%2F%3E%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%20%3AWARN%20%3A%E4%BD%BF%E7%94%A8%E6%9D%A5%E8%87%AA%3A'%2Fetc%2Fse05x%2Fplain_scp.txt'%E7%9A%84%20SCP03%20%E5%AF%86%E9%92%A5(ENV%3DEX_SSS_BOOT_SCP03_PATH)%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3EApp%20%3AERROR%3AUnknown%20key%20type%3C%2FFONT%3E%3CBR%20%2F%3Esss%20%3AINFO%20%3Aatr%20(Len%3D35)%3CBR%20%2F%3E01%20A0%2000%2000%2003%2096%2004%2003%20E8%2000%20FE%2002%200B%2003%20E8%2000%3CBR%20%2F%3E01%2000%2000%2000%2064%2013%2088%200A%2000%2065%2053%2045%2030%2035%2031%3CBR%20%2F%3E00%2000%3CBR%20%2F%3E%20sss%20%3AINFO%20%3A%3CFONT%20color%3D%22%23FF0000%22%3ENewer%20version%20of%20Applet%20Found%3C%2FFONT%3E%3CBR%20%2F%3Esss%20%3AINFO%20%3ACompiled%20for%200x70200.%E5%BE%97%E5%88%B0%E6%9B%B4%E6%96%B0%E7%9A%84%200x70216%3CBR%20%2F%3Escp%20%3AWARN%20%3AnxEnsure%3A'status%20%3D%3D%20kStatus_SSS_Success'%E5%A4%B1%E8%B4%A5%E3%80%82At%20Line%3A148%20Function%3AnxScp03_AuthenticateChannel%3CBR%20%2F%3Esss%20%3AERROR%3ACould%20not%20set%20SCP03%20Secure%20Channel%3CBR%20%2F%3EApp%20%3AERROR%3Asss_session_open%20failed%3CBR%20%2F%3EApp%20%3AERROR%3Aex_sss_session_open%20Failed%3CBR%20%2F%3EApp%20%3AERROR%3A!ERROR%EF%BC%81ret%20!%3D%200%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBR%3C%2FP%3E%3CP%3E%E5%A4%A7%E8%BE%85%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2198989%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050C2HQ1%20%20middle%20ware%20integration%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2198989%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8CKan%E3%80%81%3C%2FP%3E%3CP%3E%E5%A5%BD%E7%9A%84%EF%BC%8C%E8%AE%A9%E6%88%91%E6%A3%80%E6%9F%A5%E4%B8%80%E4%B8%8B%E5%B5%8C%E5%85%A5%E5%BC%8F%20SCP3%20%E5%AF%86%E9%92%A5%E3%80%82%3C%2FP%3E%3CP%3E%E5%B0%8F%E7%A8%8B%E5%BA%8F%E7%89%88%E6%9C%AC%E4%B8%8D%E5%8C%B9%E9%85%8D%E7%9A%84%E4%BA%8B%E6%83%85%E5%B0%B1%E5%83%8F%3C%2FP%3E%3CP%3E---log-------%3C%2FP%3E%3CP%3EApp%20%3AINFO%20%3ARunning%20ex_ecc%3CBR%20%2F%3EApp%20%3AINFO%20%3AUsing%20PortName%3D'%2Fdev%2Fi2c-2'%20(CLI)%3CBR%20%2F%3EApp%20%3AINFO%20%3APlugAndTrust_v04.07.01_20250519%3CBR%20%2F%3E%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%20%3AINFO%20%3A%E4%BD%BF%E7%94%A8%E9%BB%98%E8%AE%A4%E7%9A%84%20PlatfSCP03%20%E9%94%AE%E3%80%82%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20ENV%3DEX_SSS_BOOT_SCP03_PATH%20%E6%96%87%E4%BB%B6%E4%B8%AD%E7%9A%84%E9%94%AE%3CBR%20%2F%3Esss%20%3AINFO%20%3Aatr%20(Len%3D35)%3CBR%20%2F%3E01%20A0%2000%2000%2003%2096%2004%2003%20E8%2000%20FE%2002%200B%2003%20E8%2000%3CBR%20%2F%3E01%2000%2000%2000%2064%2013%2088%200A%2000%2065%2053%2045%2030%2035%2031%3CBR%20%2F%3E00%2000%3CBR%20%2F%3Esss%20%3AINFO%20%3A%E5%8F%91%E7%8E%B0%E6%9B%B4%E6%96%B0%E7%89%88%E6%9C%AC%E7%9A%84%20Applet%3CBR%20%2F%3E%20sss%20%3AINFO%20%3A%3CFONT%20color%3D%22%23FF0000%22%3E%E7%BC%96%E8%AF%91%E4%B8%BA%200x70200%E3%80%82%E5%BE%97%E5%88%B0%E6%9B%B4%E6%96%B0%E7%9A%84%200x70216%3C%2FFONT%3E%3CBR%20%2F%3Escp%20%3AWARN%20%3AnxEnsure%3A'status%20%3D%3D%20kStatus_SSS_Success'%E5%A4%B1%E8%B4%A5%E3%80%82At%20Line%3A148%20Function%3AnxScp03_AuthenticateChannel%3CBR%20%2F%3Esss%20%3AERROR%3ACould%20not%20set%20SCP03%20Secure%20Channel%3CBR%20%2F%3EApp%20%3AERROR%3Asss_session_open%20failed%3CBR%20%2F%3EApp%20%3AERROR%3Aex_sss_session_open%20Failed%3CBR%20%2F%3EApp%20%3AERROR%3A!ERROR%EF%BC%81ret%20!%3D%200%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBR%3C%2FP%3E%3CP%3E%E5%A4%A7%E8%BE%85%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2198804%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050C2HQ1%20%20middle%20ware%20integration%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2198804%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F200599%22%20target%3D%22_blank%22%3E%40daisuke2%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%82%A8%E6%98%AF%E5%A6%82%E4%BD%95%E6%9B%B4%E6%94%B9%20SE052F%20%E7%9A%84%E9%BB%98%E8%AE%A4%20platformSCP%20%E5%AF%86%E9%92%A5%E7%9A%84%EF%BC%9F%E5%AE%83%E4%B8%8D%E5%9C%A8%E5%A4%B4%E9%83%A8%E6%96%87%E4%BB%B6%E4%B8%AD%EF%BC%8C%E8%80%8C%E6%98%AF%E5%9C%A8fsl_sss_ftr.h.in%E6%96%87%E4%BB%B6%E4%B8%AD%EF%BC%8C%E5%8C%85%E6%8B%AC%E9%80%89%E6%8B%A9%E9%A2%84%E5%AE%9A%E4%B9%89%E9%BB%98%E8%AE%A4%3CBR%20%2F%3EPlatform%20SCP%E5%AF%86%E9%92%A5%E4%B9%8B%E4%B8%80%E7%9A%84%E9%80%89%E9%A1%B9%E3%80%82%E8%AF%A5%E6%96%87%E4%BB%B6%E4%BD%8D%E4%BA%8E%EF%BC%9A%20simw-top%2Fsss%2Finc%E3%80%82%3CBR%20%2F%3E%E6%88%96%E8%80%85%EF%BC%8C%E4%BD%A0%E5%8F%AF%E4%BB%A5%E8%AE%BE%E7%BD%AE%E4%B8%80%E4%B8%AA%E6%96%87%E4%BB%B6%E6%9D%A5%E5%8C%85%E5%90%AB%20SE052F%20%E7%9A%84%E9%BB%98%E8%AE%A4%20PlatformSCP%20%E5%AF%86%E9%92%A5%E3%80%82%E8%AF%A6%E6%83%85%E8%AF%B7%E5%8F%82%E9%98%85%20SE-PLUG-TRUST-MW_04.07.01%2Fsimw-top%2Fdoc%2Fappendix%2Fplatfscp.html%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%A0%B9%E6%8D%AE%20FIPS%20%E8%AE%A4%E8%AF%81%E8%A6%81%E6%B1%82%EF%BC%8CSE052F2%20%E5%BF%85%E9%A1%BB%E4%BD%BF%E7%94%A8%20PlatformSCP%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E8%BF%99%E4%B8%AA%E5%B0%8F%E7%A8%8B%E5%BA%8F%E7%89%88%E6%9C%AC%E6%98%AF%E5%90%A6%E4%B8%8E%E6%AF%8D%E4%BD%93%E5%AE%8C%E5%85%A8%E4%B8%8D%E5%8C%B9%E9%85%8D%EF%BC%9F-%20%E6%88%91%E6%B2%A1%E6%9C%89%E4%BB%8E%E6%97%A5%E5%BF%97%E4%B8%AD%E6%89%BE%E5%88%B0%E4%BB%BB%E4%BD%95%E4%B8%8D%E5%8C%B9%E9%85%8D%E4%BF%A1%E6%81%AF%E3%80%82%E4%BD%A0%E6%8C%87%E7%9A%84%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%A5%9D%E6%82%A8%E6%84%89%E5%BF%AB%EF%BC%8C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%3CBR%20%2F%3E-%20%E5%A6%82%E6%9E%9C%E6%9C%AC%E5%B8%96%E5%9B%9E%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%22%E6%A0%87%E8%AE%B0%E6%AD%A3%E7%A1%AE%22%20%E6%8C%89%E9%92%AE%E3%80%82%E8%B0%A2%E8%B0%A2%EF%BC%81%3CBR%20%2F%3E-%20%E6%88%91%E4%BB%AC%E4%BC%9A%E5%9C%A8%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E5%8F%91%E5%B8%96%E5%90%8E%E7%9A%84%207%20%E5%91%A8%E5%86%85%E8%B7%9F%E8%B8%AA%E4%B8%BB%E9%A2%98%EF%BC%8C%E4%B9%8B%E5%90%8E%E7%9A%84%E5%9B%9E%E5%A4%8D%E5%B0%86%E8%A2%AB%E5%BF%BD%E7%95%A5%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BB%A5%E5%90%8E%E6%9C%89%E7%9B%B8%E5%85%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E5%8F%A6%E5%BC%80%E6%96%B0%E4%B8%BB%E9%A2%98%EF%BC%8C%E5%B9%B6%E5%8F%82%E8%80%83%E5%B7%B2%E5%85%B3%E9%97%AD%E7%9A%84%E4%B8%BB%E9%A2%98%E3%80%82%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2198400%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050C2HQ1%20%20middle%20ware%20integration%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2198400%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8CKan%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E4%BF%AE%E6%AD%A3%E4%BA%86%20cmake%20%E6%A0%87%E5%BF%97%20SE05X_C%EF%BC%8C%E5%B9%B6%E5%9C%A8%E5%A4%B4%E6%96%87%E4%BB%B6%E4%B8%AD%E5%AE%9A%E4%B9%89%E4%BA%86%20SSS_PFSCP_ENABLE_SE052_B501%3D1%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%86%E5%AE%83%E4%BB%8D%E7%84%B6%E6%97%A0%E6%B3%95%E5%BB%BA%E7%AB%8B%E5%AE%89%E5%85%A8%E9%80%9A%E9%81%93%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E-----log----------%3C%2FP%3E%3CP%3Eoot%40harmonia-mvp1-dvt-machine%3A~%23%20se05x_GetInfo%20%2Fdev%2Fi2c-2%3CBR%20%2F%3EApp%20%3AINFO%20%3ARunning%20se05x_GetInfo%3CBR%20%2F%3EApp%20%3AINFO%20%3AUsing%20PortName%3D'%2Fdev%2Fi2c-2'%20(CLI)%3CBR%20%2F%3EApp%20%3AINFO%20%3APlugAndTrust_v04.07.01_20250519%3CBR%20%2F%3E%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%20%3AINFO%20%3A%E4%BD%BF%E7%94%A8%E9%BB%98%E8%AE%A4%E7%9A%84%20PlatfSCP03%20%E9%94%AE%E3%80%82%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20ENV%3DEX_SSS_BOOT_SCP03_PATH%3CBR%20%2F%3Esss%20%3AINFO%20%3Aatr%20(Len%3D35)%3CBR%20%2F%3E01%20A0%2000%2000%2003%2096%2004%2003%20E8%2000%20FE%2002%200B%2003%20E8%2000%3CBR%20%2F%3E01%2000%2000%2000%2064%2013%2088%200A%2000%2065%2053%2045%2030%2035%2031%3CBR%20%2F%3E00%2000%3CBR%20%2F%3Escp%20%3AWARN%20%3AnxEnsure%3A'status%20%3D%3D%20kStatus_SSS_Success'%20%E5%A4%B1%E8%B4%A5%E3%80%82At%20Line%3A148%20Function%3AnxScp03_AuthenticateChannel%3CBR%20%2F%3Esss%20%3AERROR%3ACould%20not%20set%20SCP03%20Secure%20Channel%3CBR%20%2F%3EApp%20%3AERROR%3Asss_session_open%20failed%3CBR%20%2F%3EApp%20%3AERROR%3Aex_sss_session_open%20Failed%3CBR%20%2F%3EApp%20%3AERROR%3A!ERROR%EF%BC%81ret%20!%3D%200%E3%80%82%3C%2FP%3E%3CP%3E--------------------------------%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%9D%E8%AF%95%E4%BA%86%22DPTMW_SE05X_Auth%3DNone%22%20%E3%80%82%E8%BF%99%E5%9C%A8%E4%BB%A5%E5%89%8D%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%EF%BC%8C%E4%BD%86%3C%2FP%3E%3CP%3E%E5%8F%AF%E4%BB%A5%E5%9C%A8%E6%B2%A1%E6%9C%89%20scp3%20%E5%AE%89%E5%85%A8%E9%80%9A%E9%81%93%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E6%8E%A7%E5%88%B6%20SE052F2HN2%20%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%BF%99%E4%B8%AA%E5%B0%8F%E7%A8%8B%E5%BA%8F%E7%89%88%E6%9C%AC%E6%98%AF%E5%90%A6%E4%B8%8E%E6%AF%8D%E4%BD%93%E5%AE%8C%E5%85%A8%E4%B8%8D%E5%8C%B9%E9%85%8D%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBR%3C%2FP%3E%3CP%3E%E5%A4%A7%E8%BE%85%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2197846%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050C2HQ1%20%20middle%20ware%20integration%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2197846%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F200599%22%20target%3D%22_blank%22%3E%40daisuke2%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%9C%89%E5%85%B3%20SE052F%20%E7%9A%84%20Cmake%20%E8%AE%BE%E7%BD%AE%E8%AF%A6%E6%83%85%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN14028.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN14028.pdf%3C%2FA%3E%E4%B8%AD%E7%9A%84%E8%A1%A8%203%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%B8%8C%E6%9C%9B%E5%AF%B9%E4%BD%A0%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%A5%9D%E6%82%A8%E6%84%89%E5%BF%AB%EF%BC%8C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%3CBR%20%2F%3E-%20%E5%A6%82%E6%9E%9C%E6%9C%AC%E5%B8%96%E5%9B%9E%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%22%E6%A0%87%E8%AE%B0%E6%AD%A3%E7%A1%AE%22%20%E6%8C%89%E9%92%AE%E3%80%82%E8%B0%A2%E8%B0%A2%EF%BC%81%3CBR%20%2F%3E-%20%E6%88%91%E4%BB%AC%E4%BC%9A%E5%9C%A8%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E5%8F%91%E5%B8%96%E5%90%8E%E7%9A%84%207%20%E5%91%A8%E5%86%85%E8%B7%9F%E8%B8%AA%E4%B8%BB%E9%A2%98%EF%BC%8C%E4%B9%8B%E5%90%8E%E7%9A%84%E5%9B%9E%E5%A4%8D%E5%B0%86%E8%A2%AB%E5%BF%BD%E7%95%A5%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BB%A5%E5%90%8E%E6%9C%89%E7%9B%B8%E5%85%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E5%8F%A6%E5%BC%80%E6%96%B0%E4%B8%BB%E9%A2%98%EF%BC%8C%E5%B9%B6%E5%8F%82%E8%80%83%E5%B7%B2%E5%85%B3%E9%97%AD%E7%9A%84%E4%B8%BB%E9%A2%98%E3%80%82%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2197776%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050C2HQ1%20%20middle%20ware%20integration%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2197776%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%20%3C%2FP%3E%3CP%3E%E4%B8%80%E4%B8%AA%E6%9B%B4%E6%AD%A3%E3%80%82%E6%88%91%E9%94%99%E4%BA%86%E3%80%82%E5%AE%89%E5%85%A8%E9%9B%86%E6%88%90%E7%94%B5%E8%B7%AF%E6%98%AF%20SE052F2HN2%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%20SE050C2HQ1%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
