SE050 - cardCryptogram don't match
30,232 次查看
ElielderBMelo
I'm working with OpenSSL Engine + SE050 in a Embedded Linux. In SCP Authentication, I cannot initialize the device, when I reach:
// Verify whether the 8 left most byte of cardCryptogramFullLength match cardCryptogram
if (memcmp(cardCryptogramFullLength, cardCryptogram, SCP_GP_IU_CARD_CRYPTOGRAM_LEN) != 0)
status = kStatus_SSS_Fail;
cardCryptogramFullLength and cardCryptogram don´t match and I'm already using:
  • ENC is 35C29245895EA34F6136155F8209D6CD
  • MAC is AF172D5D54F7C0D5C10A05B9F1207F78
  • DEK is A2BC8438BF77015B361A4425F239FA29
They are set in file by the environment variable, by command:
EX_SSS_BOOT_SCP03_PATH=/home/root/plain_scp.txt openssl engine
By the end, I output the DEBUG in console, they presented as following:
scp :DEBUG: Output:cardCryptogramFullLength (Len=16)
B8 78 A9 C7 DB EE 3D 01 5A 5C 72 20 13 9E F2 74
scp :DEBUG: Output:cardCryptogram (Len=8)
27 C3 C1 F6 2D 0A E8 EA
Any solution? Why they don't match. I have attached console output.
Thanks!!!
30,085 次查看
Kan_Li
Hi @ElielderBMelo ,
Thanks for the information! I have just checked with the expert, from the ATR info, looks like SE050F2 is on your board, and it uses different SCP03 keys as the default ones on the dev kits.
Please use the above keys instead and check if they make any difference. Please refer to https://www.nxp.com/docs/en/application-note/AN12436.pdf for more details.
You may also switch on FIPS option to make the MW built for the SE050F IoT Applet which is version 3.6.
of course it is not the root cause, but makes sense. It just slightly modifies the behavior of some examples.
Hope that helps,
Kan
20 回复数
30,214 次查看
Kan_Li
Hi @ElielderBMelo ,
Are you using the development board?
If yes, Did you change the SCP03 keys? Because our default keys are:
Please kindly refer to simw-top/doc/appendix/platfscp.html?highlight=scp03 for more details.
Kan
30,200 次查看
ElielderBMelo
Hi, @Kan_Li
Yes, I'm using the development board.
No, I'm using exactly this keys:
ENC 35C256458958A34F6136155F8209D6CD
MAC AF177D5DBDF7C0D5C10A05B9F1607F78
DEK A1BC8438BF77935B361A4425FE79FA29
Thanks.
30,157 次查看
Kan_Li
Hi @ElielderBMelo ,
Since the dev kit still holds the default keys, so it should work with any demo code with Applet SCP03 Authentication enabled. Did you try it from your side?
To do this, you have to run cmake-gui . to enter the configuration view for cmake, and change the following options.
then configure and generate
and run cmake --build .
if you meet the following issue when running any demo,
please execute se05x_Delete_and_test_provision.exe at first to provision the Authentication Key.
With the default SCP03 keys, you may run any demo starting with an Applet SCP03 authentication like below.
If you run the demo following above steps, it means the dev kit on your hands should be ok, we should focus on the host application instead.
Hope that makes sense,
Kan
30,150 次查看
ElielderBMelo
Hi, Kan Li.
I'm not working in Windows, I'm working in Embedded Linux and I took the .bin in MCU folder in "simw-top/binaries/MCU/" and no one of them worked in my environment.
Attached to this message there is my C-Make configuration file. My environment configuration are shown there.
For your knowledge:
- I'm building a cross compiled library to work with OpenSSL.
- My library are attached to OpenSSL by the "openssl.cnf" file.
- The command that I'm testing is a simple engine operation, only to connect to the device by "openssl engine -t".
- This command above are working with no SCP03 Authentication, but when SCP03 is required it doesn't work well.
- I enabled the SCP03 by following manual and instructions there.
- And I don't what to do for that values of "cardCryptogram" to match between each other
Please, ask if any doubt remains, I need to hurry in trying to fix it, because my project are to be delayed because of that.
Thanks.
Thanks.
30,144 次查看
ElielderBMelo
Hi @Kan_Li
I've found the executable for Linux and I executed se05x_Minimal and se05_GetInfo, and they stopped in the same part. They cannot establish a SCP03 Secure Channel as shown below:
root@am335x-evm:~# ./se05x_Minimal
App :INFO :PlugAndTrust_v03.03.00_20210528
App :INFO :Running ./se05x_Minimal
App :INFO :If you want to over-ride the selection, use ENV=EX_SSS_BOOT_SSS_PORT or pass in command line arguments.
App :DEBUG:Using File: /home/root/plain_scp.txt
App :WARN :Using SCP03 keys from:'/home/root/plain_scp.txt' (FILE=/home/root/plain_scp.txt)
smCom :DEBUG:phPalEse_i2c_open_and_configure Opening port
smCom :DEBUG:I2CInit: opening /dev/i2c-2
smCom :DEBUG:I2C driver: PEC flag cleared
smCom :DEBUG:I2C driver supports plain i2c-level commands.
smCom :DEBUG:I2C driver Initialized :: fd = [12]
smCom :DEBUG:phNxpEseProto7816_Open: First open completed
smCom :DEBUG:phNxpEse_clearReadBuffer Enter ..
smCom :DEBUG:phPalEse_i2c_read Read Requested 260 bytes
smCom :DEBUG:Done with rv = 0d
smCom :DEBUG:TX (axI2CRead): (Len=260)
43 21 01 00 70 99 37 49 00 00 00 00 74 58 EE BE
14 58 EE BE 1C 58 EE BE B3 76 35 49 1C 58 EE BE
D0 9A 37 49 04 00 00 00 78 DE F6 B6 01 00 00 00
00 00 00 00 01 00 00 00 70 99 37 49 00 00 00 00
2C 9B 37 49 2C 9B 37 49 00 00 00 00 01 80 AD FB
20 59 EE BE 20 59 EE BE 20 59 EE BE 20 59 EE BE
FF FF FF FF 1E 5A EE BE 40 A3 38 49 20 D8 F6 B6
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 05 00 00 00 01 00 00 00 04 B1 05 00
10 B0 F6 B6 D0 B4 F6 B6 00 00 00 00 01 00 00 00
00 90 37 49 00 00 00 00 DF B0 35 49 78 DE F6 B6
01 00 00 00 01 00 00 00 00 00 00 00 10 B0 F6 B6
40 A3 38 49 08 59 EE BE 00 B0 05 00 B0 58 EE BE
57 4C 3F 49 88 13 00 00 E8 03 00 00 40 42 0F 00
39 46 41 49 00 00 00 00 40 4B 4C 00 00 B0 05 00
42 5B EE BE 00 00 00 00 F3 D8 03 00 C4 58 EE BE
05 00 00 00
smCom :DEBUG:_i2c_read() error : 13
smCom :DEBUG:TransceiveProcess nextTransceiveState 4
smCom :DEBUG:S-Frame PCB: c0
smCom :DEBUG:phNxpEse_WriteFrame Enter ..
smCom :DEBUG:TX (axI2CWrite) > (Len=5)
5A C0 00 FF FC
smCom :DEBUG:Done with rv = 0c
smCom :DEBUG:RAW Tx> (Len=5)
5A C0 00 FF FC
smCom :DEBUG:phNxpEse_read Enter ..
smCom :DEBUG:phPalEse_i2c_read Read Requested 2 bytes
smCom :DEBUG:TX (axI2CRead): (Len=2)
A5 E0
smCom :DEBUG:phNxpEse_readPacket Read HDR
smCom :DEBUG:phNxpEse_readPacket SOF FOUND
smCom :DEBUG:phPalEse_i2c_read Read Requested 1 bytes
smCom :DEBUG:TX (axI2CRead): (Len=1)
00
smCom :DEBUG:poll_sof_chained_delay value is 0
3F 19
smCom :DEBUG:RAW Rx< (Len=5)
A5 E0 00 3F 19
smCom :DEBUG:phNxpEseProto7816_ProcessResponse p_data ----> 0x60dd8 len ----> 0x5
smCom :DEBUG:Received CRC:0x3f19 Calculated CRC:0x3f19
smCom :DEBUG:Retry Counter = 0
smCom :DEBUG:phNxpEseProto7816_DecodeFrame S-Frame Received
smCom :DEBUG:TransceiveProcess nextTransceiveState 7
smCom :DEBUG:S-Frame PCB: c7
5A C7 00 F7 B1
5A C7 00 F7 B1
A5 E7
23
smCom :DEBUG:phPalEse_i2c_read Read Requested 37 bytes
smCom :DEBUG:TX (axI2CRead): (Len=37)
00 A0 00 00 03 96 04 03 E8 00 FE 02 0B 03 E8 08
01 00 00 00 00 64 00 00 0A 4A 43 4F 50 34 20 41
54 50 4F 2A 8D
smCom :DEBUG:RAW Rx< (Len=40)
A5 E7 23 00 A0 00 00 03 96 04 03 E8 00 FE 02 0B
03 E8 08 01 00 00 00 00 64 00 00 0A 4A 43 4F 50
34 20 41 54 50 4F 2A 8D
smCom :DEBUG:phNxpEseProto7816_ProcessResponse p_data ----> 0x60dd8 len ----> 0x28
smCom :DEBUG:Received CRC:0x2a8d Calculated CRC:0x2a8d
smCom :DEBUG:phNxpEseProto7816_DecodeSFrameData frameoffset=3 value=0x0
smCom :DEBUG:Data[0]=0x0 len=35 Data[34]=0x50 Data[79]=0x23
smCom :DEBUG:Trying to Acquire Lock thread: -1225347056
smCom :DEBUG:LOCK Acquired by thread: -1225347056
smCom :DEBUG:APDU Tx> (Len=22)
00 A4 04 00 10 A0 00 00 03 96 54 53 00 00 00 01
03 00 00 00 00 00
smCom :DEBUG:Enter phNxpEseProto7816_Transceive
smCom :DEBUG:Transceive data ptr 0x0xbeee5438 len:22
smCom :DEBUG:I-Frame Data Len: 22 Seq. no:0
smCom :DEBUG:TransceiveProcess nextTransceiveState 1
smCom :DEBUG:TX (axI2CWrite) > (Len=27)
5A 00 16 00 A4 04 00 10 A0 00 00 03 96 54 53 00
00 00 01 03 00 00 00 00 00 A8 C8
smCom :DEBUG:RAW Tx> (Len=27)
00 00
smCom :DEBUG:_i2c_read() [HDR]errno : 79 ret : FFFFFFFF
smCom :DEBUG:phNxpEse_readPacket Normal Pkt, delay read 1ms
00 00
00 00
00 00
00 00
00 00
00 00
A5 00
09
smCom :DEBUG:phPalEse_i2c_read Read Requested 11 bytes
smCom :DEBUG:TX (axI2CRead): (Len=11)
03 06 00 61 D2 01 0B 90 00 50 AD
smCom :DEBUG:RAW Rx< (Len=14)
A5 00 09 03 06 00 61 D2 01 0B 90 00 50 AD
smCom :DEBUG:phNxpEseProto7816_ProcessResponse p_data ----> 0x60dd8 len ----> 0xe
smCom :DEBUG:Received CRC:0x50ad Calculated CRC:0x50ad
smCom :DEBUG:phNxpEseProto7816_DecodeFrame I-Frame Received
smCom :DEBUG:phNxpEseProto7816_DecodeFrame I-Frame lastRcvdIframeInfo.seqNo:0x0
smCom :DEBUG:Data[0]=0x3 len=9 Data[8]=0x90 Data[0]=0x9
smCom :DEBUG: phNxpEse_Transceive Exit status 0x0
smCom :DEBUG:APDU Rx< (Len=9)
smCom :DEBUG:Trying to Released Lock by thread: -1225347056
smCom :DEBUG:LOCK Released by thread: -1225347056
sss :INFO :atr (Len=35)
54 50 4F
sss :INFO :Newer version of Applet Found
sss :INFO :Compiled for 0x30100. Got newer 0x30600
scp :DEBUG:FN: nxScp03_AuthenticateChannel
scp :DEBUG: Output: hostChallenge (Len=8)
3B 37 1C 2A 1B 02 FE A2
scp :DEBUG:FN: nxScp03_GP_InitializeUpdate
scp :DEBUG:Input:keyVersion 0b
scp :DEBUG: Input: hostChallenge (Len=8)
scp :DEBUG:Sending GP Initialize Update Command !!!
smCom :DEBUG:APDU Tx> (Len=13)
80 50 0B 00 08 3B 37 1C 2A 1B 02 FE A2
smCom :DEBUG:Transceive data ptr 0x0xbeee5164 len:13
smCom :DEBUG:I-Frame Data Len: 13 Seq. no:1
smCom :DEBUG:TX (axI2CWrite) > (Len=18)
5A 40 0D 80 50 0B 00 08 3B 37 1C 2A 1B 02 FE A2
5A 4E
smCom :DEBUG:RAW Tx> (Len=18)
5A 4E
00 00
00 00
A5 40
1F
smCom :DEBUG:phPalEse_i2c_read Read Requested 33 bytes
smCom :DEBUG:TX (axI2CRead): (Len=33)
90 03 12 10 00 00 49 95 55 95 0B 03 00 9E EB B4
D2 0C EA 7D AE 21 0B 23 F0 BD 04 C9 03 90 00 B0
EB
smCom :DEBUG:RAW Rx< (Len=36)
A5 40 1F 90 03 12 10 00 00 49 95 55 95 0B 03 00
9E EB B4 D2 0C EA 7D AE 21 0B 23 F0 BD 04 C9 03
90 00 B0 EB
smCom :DEBUG:phNxpEseProto7816_ProcessResponse p_data ----> 0x60dd8 len ----> 0x24
smCom :DEBUG:Received CRC:0xb0eb Calculated CRC:0xb0eb
smCom :DEBUG:phNxpEseProto7816_DecodeFrame I-Frame lastRcvdIframeInfo.seqNo:0x1
smCom :DEBUG:Data[0]=0x90 len=31 Data[30]=0x90 Data[0]=0x1f
smCom :DEBUG:APDU Rx< (Len=31)
scp :DEBUG: Output: keyDivData (Len=10)
scp :DEBUG: Output: keyInfo (Len=3)
0B 03 00
scp :DEBUG: Output: cardChallenge (Len=8)
scp :DEBUG: Output: cardCryptoGram (Len=8)
scp :DEBUG:FN: nxScp03_HostLocal_CalculateSessionKeys
scp :DEBUG: Input:hostChallenge (Len=8)
scp :DEBUG: Input:cardChallenge (Len=8)
scp :DEBUG:Set the Derviation data to generate Session ENC key
scp :DEBUG:FN: nxScp03_setDerivationData
scp :DEBUG:Input:ddConstant 04
scp :DEBUG:Input:ddL 80
scp :DEBUG:Input:iCounter 01
scp :DEBUG: Input: keyInfo (Len=16)
3B 37 1C 2A 1B 02 FE A2 9E EB B4 D2 0C EA 7D AE
scp :DEBUG:Output: KeyDivData (Len=32)
00 00 00 00 00 00 00 00 00 00 00 04 00 00 80 01
scp :DEBUG:FN: nxScp03_Generate_SessionKey
scp :DEBUG: Input: inData (Len=32)
scp :DEBUG: Output:outSignature (Len=16)
42 E3 9B ED C5 0C 15 80 C7 C5 F4 62 7B 2A 2F 6D
scp :DEBUG: Output:sessionEncKey (Len=16)
scp :DEBUG:Set the Derviation data to generate Session MAC key
scp :DEBUG:Input:ddConstant 06
00 00 00 00 00 00 00 00 00 00 00 06 00 00 80 01
7D 26 00 93 2C 20 90 7F 1F E1 30 37 38 C1 65 21
scp :DEBUG: Output:sessionMacKey (Len=16)
scp :DEBUG:Set the Derviation data to generate Session RMAC key
scp :DEBUG:Input:ddConstant 07
00 00 00 00 00 00 00 00 00 00 00 07 00 00 80 01
14 13 13 F9 D9 1D 98 91 72 4C C4 16 64 CB 31 67
scp :DEBUG: Output:sessionRmacKey (Len=16)
scp :DEBUG:FN: nxScp03_HostLocal_VerifyCardCryptogram
scp :DEBUG:Input:ddConstant 00
scp :DEBUG:Input:ddL 40
00 00 00 00 00 00 00 00 00 00 00 00 00 00 40 01
77 4F 5E 11 CC 39 55 05 2A 15 B5 5A 71 DA 33 C8
scp :DEBUG: Output:cardCryptogram (Len=16)
scp :WARN :nxEnsure:'status == kStatus_SSS_Success' failed. At Line:145 Function:nxScp03_AuthenticateChannel
sss :ERROR:Could not set SCP03 Secure Channel
App :ERROR:sss_session_open failed
App :ERROR:ex_sss_session_open Failed
App :ERROR:!ERROR! ret != 0.
root@am335x-evm:~# ./se05x_GetInfo
App :INFO :Running ./se05x_GetInfo
5B 21 01 00 70 99 37 49 00 00 00 00 74 C8 CE BE
14 C8 CE BE 1C C8 CE BE B3 76 35 49 1C C8 CE BE
D0 9A 37 49 04 00 00 00 78 4E F5 B6 01 00 00 00
20 C9 CE BE 20 C9 CE BE 20 C9 CE BE 20 C9 CE BE
FF FF FF FF 1E CA CE BE 40 A3 38 49 20 48 F5 B6
00 00 00 00 05 00 00 00 01 00 00 00 04 D1 05 00
10 20 F5 B6 D0 24 F5 B6 00 00 00 00 01 00 00 00
00 90 37 49 00 00 00 00 DF B0 35 49 78 4E F5 B6
01 00 00 00 01 00 00 00 00 00 00 00 10 20 F5 B6
40 A3 38 49 08 C9 CE BE 00 D0 05 00 B0 C8 CE BE
39 46 41 49 00 00 00 00 40 4B 4C 00 00 D0 05 00
42 CB CE BE 00 00 00 00 AF EA 03 00 C4 C8 CE BE
05 00 00 00
5A C0 00 FF FC
5A C0 00 FF FC
A5 E0
00
3F 19
A5 E0 00 3F 19
smCom :DEBUG:phNxpEseProto7816_ProcessResponse p_data ----> 0x62dd8 len ----> 0x5
5A C7 00 F7 B1
5A C7 00 F7 B1
A5 E7
23
54 50 4F 2A 8D
smCom :DEBUG:phNxpEseProto7816_ProcessResponse p_data ----> 0x62dd8 len ----> 0x28
smCom :DEBUG:Trying to Acquire Lock thread: -1225449456
smCom :DEBUG:LOCK Acquired by thread: -1225449456
03 00 00 00 00 00
smCom :DEBUG:Transceive data ptr 0x0xbecec438 len:22
00 00
00 00
00 00
00 00
00 00
00 00
00 00
A5 00
09
smCom :DEBUG:phNxpEseProto7816_ProcessResponse p_data ----> 0x62dd8 len ----> 0xe
smCom :DEBUG:Trying to Released Lock by thread: -1225449456
smCom :DEBUG:LOCK Released by thread: -1225449456
54 50 4F
E2 B5 B2 C2 C7 A8 A6 63
80 50 0B 00 08 E2 B5 B2 C2 C7 A8 A6 63
smCom :DEBUG:Transceive data ptr 0x0xbecec164 len:13
5A 40 0D 80 50 0B 00 08 E2 B5 B2 C2 C7 A8 A6 63
61 B7
61 B7
00 00
00 00
A5 40
1F
90 03 12 10 00 00 49 95 55 95 0B 03 00 16 35 AD
77 94 F9 C2 33 D9 23 B6 1F 93 2F 97 4E 90 00 C0
97
16 35 AD 77 94 F9 C2 33 D9 23 B6 1F 93 2F 97 4E
90 00 C0 97
smCom :DEBUG:phNxpEseProto7816_ProcessResponse p_data ----> 0x62dd8 len ----> 0x24
smCom :DEBUG:Received CRC:0xc097 Calculated CRC:0xc097
0B 03 00
E2 B5 B2 C2 C7 A8 A6 63 16 35 AD 77 94 F9 C2 33
F2 F2 CD D3 0C C1 23 64 73 41 DD 04 4B B8 07 1F
6B 55 86 C0 17 65 09 9A EC C0 76 4C 09 B2 3A DA
8E 85 F4 80 FD 9F 08 0F AB 6E C9 4A AE 32 C5 1B
EE 4C A8 23 C7 2E 07 35 32 31 47 4F 32 51 15 B1
Thanks.
30,141 次查看
ElielderBMelo
Hi @Kan_Li
Please, look to this execution of "se05X_GetInfo", this build was built without SCP03 Authentication in C-Make config for libsss_engine.so.
5B 21 01 00 70 99 37 49 00 00 00 00 84 58 B6 BE
24 58 B6 BE 2C 58 B6 BE B3 76 35 49 2C 58 B6 BE
D0 9A 37 49 04 00 00 00 78 2E FF B6 01 00 00 00
30 59 B6 BE 30 59 B6 BE 30 59 B6 BE 30 59 B6 BE
FF FF FF FF 2E 5A B6 BE 40 A3 38 49 20 28 FF B6
10 00 FF B6 D0 04 FF B6 00 00 00 00 01 00 00 00
00 90 37 49 00 00 00 00 DF B0 35 49 78 2E FF B6
01 00 00 00 01 00 00 00 00 00 00 00 10 00 FF B6
40 A3 38 49 18 59 B6 BE 00 D0 05 00 C0 58 B6 BE
52 5B B6 BE 00 00 00 00 FF E6 03 00 D4 58 B6 BE
05 00 00 00
5A C0 00 FF FC
5A C0 00 FF FC
A5 E0
00
3F 19
A5 E0 00 3F 19
smCom :DEBUG:phNxpEseProto7816_ProcessResponse p_data ----> 0x61c88 len ----> 0x5
5A C7 00 F7 B1
5A C7 00 F7 B1
A5 E7
23
54 50 4F 2A 8D
smCom :DEBUG:phNxpEseProto7816_ProcessResponse p_data ----> 0x61c88 len ----> 0x28
54 50 4F
smCom :DEBUG:Trying to Acquire Lock thread: -1224802288
smCom :DEBUG:LOCK Acquired by thread: -1224802288
03 30 00 00 00 00
smCom :DEBUG:Transceive data ptr 0x0xbeb65bac len:22
00 00 01 03 30 00 00 00 00 79 1C
00 00
A5 00
02
smCom :DEBUG:phPalEse_i2c_read Read Requested 4 bytes
smCom :DEBUG:TX (axI2CRead): (Len=4)
6E 00 1A 49
smCom :DEBUG:RAW Rx< (Len=7)
A5 00 02 6E 00 1A 49
smCom :DEBUG:phNxpEseProto7816_ProcessResponse p_data ----> 0x61c88 len ----> 0x7
smCom :DEBUG:Received CRC:0x1a49 Calculated CRC:0x1a49
smCom :DEBUG:Data[0]=0x6e len=2 Data[1]=0x6e Data[0]=0x2
smCom :DEBUG:APDU Rx< (Len=2)
6E 00
smCom :DEBUG:Trying to Released Lock by thread: -1224802288
smCom :DEBUG:LOCK Released by thread: -1224802288
App :WARN :No SemsLite Applet Available.
hostLib:DEBUG:CloseSession command is sent only if valid Session exists!!!
smCom :DEBUG:TransceiveProcess nextTransceiveState 6
smCom :DEBUG:S-Frame PCB: c5
5A C5 00 47 82
5A C5 00 47 82
A5 E5
00
87 67
A5 E5 00 87 67
smCom :DEBUG:Received CRC:0x8767 Calculated CRC:0x8767
smCom :DEBUG:Close i2c device 3.
smCom :DEBUG:phNxpEse_close - ESE Context deinit completed
70 45 73 65 50 72 6F 74 6F 37 38 31 36 5F 4F 70
65 6E 3A 20 46 69 72 73 74 20 6F 70 65 6E 20 63
6F 6D 70 6C 65 74 65 64 00 59 B6 BE 00 00 00 00
A4 B8 04 00 14 5A B6 BE 88 58 B6 BE 00 00 00 00
9B E1 3C 49 00 00 00 00 FF FF FF FF 01 80 AD FB
00 59 B6 BE 00 59 B6 BE 00 59 B6 BE 00 59 B6 BE
24 59 B6 BE FE 59 B6 BE 00 59 B6 BE FE 59 B6 BE
00 00 00 00 05 00 00 00 00 00 00 00 49 03 3D 49
00 00 47 49 00 00 00 00 98 04 00 00 90 E1 05 00
C1 F9 3C 49 70 58 B6 BE FF FF FF FF 00 00 00 00
00 00 00 00 D8 58 B6 BE FF FF FF FF 10 00 FF B6
00 55 00 00 E8 58 B6 BE 75 2F 41 49 90 58 B6 BE
22 5B B6 BE 00 00 00 00 FF E6 03 00 A4 58 B6 BE
05 00 00 00
5A C0 00 FF FC
5A C0 00 FF FC
A5 E0
00
3F 19
A5 E0 00 3F 19
5A C7 00 F7 B1
5A C7 00 F7 B1
A5 E7
23
54 50 4F 2A 8D
03 00 00 00 00 00
smCom :DEBUG:Transceive data ptr 0x0xbeb65418 len:22
00 00
00 00
A5 00
09
smCom :DEBUG:phNxpEseProto7816_ProcessResponse p_data ----> 0x61c88 len ----> 0xe
54 50 4F
sss :WARN :Communication channel is Plain.
sss :WARN :!!!Not recommended for production use.!!!
smCom :DEBUG:APDU Tx> (Len=11)
80 04 00 27 06 41 04 7F FF 02 06
smCom :DEBUG:Transceive data ptr 0x0xbeb64c7c len:11
smCom :DEBUG:I-Frame Data Len: 11 Seq. no:1
smCom :DEBUG:TX (axI2CWrite) > (Len=16)
5A 40 0B 80 04 00 27 06 41 04 7F FF 02 06 A1 C3
smCom :DEBUG:RAW Tx> (Len=16)
00 00
A5 40
02
69 85 00 C1
A5 40 02 69 85 00 C1
smCom :DEBUG:Received CRC:0xc1 Calculated CRC:0xc1
smCom :DEBUG:Data[0]=0x69 len=2 Data[1]=0x69 Data[133]=0x2
69 85
sss :WARN :nxEnsure:'ret == SM_OK' failed. At Line:6291 Function:sss_se05x_TXn
App :ERROR:Failed Se05x_API_CheckObjectExists
App :INFO :Error in Iot_Applet_Identify
smCom :DEBUG:APDU Tx> (Len=5)
00 A4 04 00 00
smCom :DEBUG:Transceive data ptr 0x0xbeb65638 len:5
smCom :DEBUG:I-Frame Data Len: 5 Seq. no:0
smCom :DEBUG:TX (axI2CWrite) > (Len=10)
5A 00 05 00 A4 04 00 00 1E 3C
smCom :DEBUG:RAW Tx> (Len=10)
00 00
00 00
A5 00
14
smCom :DEBUG:phPalEse_i2c_read Read Requested 22 bytes
smCom :DEBUG:TX (axI2CRead): (Len=22)
6F 10 84 08 A0 00 00 01 51 00 00 00 A5 04 9F 65
01 FF 90 00 95 F6
smCom :DEBUG:RAW Rx< (Len=25)
A5 00 14 6F 10 84 08 A0 00 00 01 51 00 00 00 A5
04 9F 65 01 FF 90 00 95 F6
smCom :DEBUG:phNxpEseProto7816_ProcessResponse p_data ----> 0x61c88 len ----> 0x19
smCom :DEBUG:Received CRC:0x95f6 Calculated CRC:0x95f6
smCom :DEBUG:Data[0]=0x6f len=20 Data[19]=0x90 Data[0]=0x14
smCom :DEBUG:APDU Rx< (Len=20)
01 FF 90 00
smCom :DEBUG:APDU Tx> (Len=8)
80 CA 00 FE 02 DF 28 00
smCom :DEBUG:Transceive data ptr 0x0xbeb65bb4 len:8
smCom :DEBUG:I-Frame Data Len: 8 Seq. no:1
smCom :DEBUG:TX (axI2CWrite) > (Len=13)
5A 40 08 80 CA 00 FE 02 DF 28 00 50 06
smCom :DEBUG:RAW Tx> (Len=13)
00 00
00 00
A5 40
49
smCom :DEBUG:phPalEse_i2c_read Read Requested 75 bytes
smCom :DEBUG:TX (axI2CRead): (Len=75)
FE 45 DF 28 42 01 0C 00 01 A7 7E B8 DD 1E EE 56
49 10 76 02 08 00 00 00 00 00 00 00 01 03 18 4A
33 52 33 35 31 30 32 36 34 35 37 31 31 30 30 03
4D 67 74 0B E1 42 19 05 01 01 07 01 00 08 08 2E
5A D8 84 09 C9 BA DB 90 00 57 64
smCom :DEBUG:RAW Rx< (Len=78)
A5 40 49 FE 45 DF 28 42 01 0C 00 01 A7 7E B8 DD
1E EE 56 49 10 76 02 08 00 00 00 00 00 00 00 01
03 18 4A 33 52 33 35 31 30 32 36 34 35 37 31 31
30 30 03 4D 67 74 0B E1 42 19 05 01 01 07 01 00
08 08 2E 5A D8 84 09 C9 BA DB 90 00 57 64
smCom :DEBUG:phNxpEseProto7816_ProcessResponse p_data ----> 0x61c88 len ----> 0x4e
smCom :DEBUG:Received CRC:0x5764 Calculated CRC:0x5764
smCom :DEBUG:Data[0]=0xfe len=73 Data[72]=0x90 Data[0]=0x49
smCom :DEBUG:APDU Rx< (Len=73)
App :WARN :#####################################################
App :INFO :Tag value - proprietary data 0xFE = 0xFE
App :INFO :Length of following data 0x45 = 0x45
App :INFO :Tag card identification data (Len=2)
DF 28
App :INFO :Length of card identification data = 0x42
App :INFO :Tag configuration ID (Must be 0x01) = 0x01
App :DEBUG:Length configuration ID 0x0C = 0x0C
App :INFO :Configuration ID (Len=12)
00 01 A7 7E B8 DD 1E EE 56 49 10 76
App :INFO :OEF ID (Len=2)
A7 7E
App :INFO :Tag patch ID (Must be 0x02) = 0x02
App :DEBUG:Length patch ID 0x08 = 0x08
App :INFO :Patch ID (Len=8)
App :INFO :Tag platform build ID1 (Must be 0x03) = 0x03
App :DEBUG:Length platform build ID 0x18 = 0x18
App :INFO :Platform build ID (Len=24)
4A 33 52 33 35 31 30 32 36 34 35 37 31 31 30 30
App :INFO :JCOP Platform ID = J3R3510264571100
App :INFO :Tag FIPS mode (Must be 0x05) = 0x05
App :DEBUG:Length FIPS mode 0x01 = 0x01
App :INFO :FIPS mode var = 0x01
App :INFO :Tag pre-perso state (Must be 0x07) = 0x07
App :DEBUG:Length pre-perso state 0x01 = 0x01
App :INFO :Bit mask of pre-perso state var = 0x00
App :INFO :Tag ROM ID (Must be 0x08) = 0x08
App :DEBUG:Length ROM ID 0x08 = 0x08
App :INFO :ROM ID (Len=8)
App :INFO :Status Word (SW) (Len=2)
90 00
App :INFO :se05x_GetInfoPlainApplet Example Success !!!...
80 CA 9F 7F 00
smCom :DEBUG:Transceive data ptr 0x0xbeb65bc8 len:5
5A 00 05 80 CA 9F 7F 00 3E 52
00 00
00 00
A5 00
2F
smCom :DEBUG:phPalEse_i2c_read Read Requested 49 bytes
smCom :DEBUG:TX (axI2CRead): (Len=49)
9F 7F 2A 47 90 D3 21 47 00 00 00 00 00 12 10 00
00 49 95 55 95 00 00 00 00 00 00 00 00 01 39 04
30 30 30 34 39 00 00 00 00 00 00 00 00 90 00 91
9F
smCom :DEBUG:RAW Rx< (Len=52)
A5 00 2F 9F 7F 2A 47 90 D3 21 47 00 00 00 00 00
12 10 00 00 49 95 55 95 00 00 00 00 00 00 00 00
01 39 04 30 30 30 34 39 00 00 00 00 00 00 00 00
90 00 91 9F
smCom :DEBUG:phNxpEseProto7816_ProcessResponse p_data ----> 0x61c88 len ----> 0x34
smCom :DEBUG:Received CRC:0x919f Calculated CRC:0x919f
smCom :DEBUG:Data[0]=0x9f len=47 Data[46]=0x90 Data[0]=0x2f
smCom :DEBUG:APDU Rx< (Len=47)
App :INFO :cplc_data.IC_fabricator (Len=2)
47 90
App :INFO :cplc_data.IC_type1 (Len=2)
D3 21
App :INFO :cplc_data.Operating_system_identifier (Len=2)
47 00
App :INFO :cplc_data.Operating_system_release_date (Len=2)
00 00
App :INFO :cplc_data.Operating_system_release_level (Len=2)
00 00
App :INFO :cplc_data.IC_fabrication_date (Len=2)
12 10
App :INFO :cplc_data.IC_Serial_number (Len=4)
00 00 49 95
App :INFO :cplc_data.IC_Batch_identifier (Len=2)
55 95
App :INFO :cplc_data.IC_module_fabricator (Len=2)
00 00
App :INFO :cplc_data.IC_module_packaging_date (Len=2)
00 00
App :INFO :cplc_data.ICC_manufacturer (Len=2)
00 00
App :INFO :cplc_data.IC_embedding_date (Len=2)
00 00
App :INFO :cplc_data.IC_OS_initializer (Len=2)
01 39
App :INFO :cplc_data.IC_OS_initialization_date (Len=2)
04 30
App :INFO :cplc_data.IC_OS_initialization_equipment (Len=4)
30 30 34 39
App :INFO :cplc_data.IC_personalizer (Len=2)
00 00
App :INFO :cplc_data.IC_personalization_date (Len=2)
00 00
App :INFO :cplc_data.IC_personalization_equipment_ID (Len=4)
00 00 00 00
App :INFO :cplc_data.SW (Len=2)
90 00
App :INFO :ex_sss Finished
5A C5 00 47 82
5A C5 00 47 82
A5 E5
00
87 67
A5 E5 00 87 67
Thanks.
30,124 次查看
Kan_Li
Hi @ElielderBMelo ,
Thanks for the information! Looks like you are using platform SCP03 authentication instead of AESKey, so I changed my configuration as yours.
and use external file containing the platform SCP03 keys.
The authentication passed successfully with the following keys.
ENC 35C256458958A34F6136155F8209D6CD # Trailing comment
MAC AF177D5DBDF7C0D5C10A05B9F1607F78 # Optional trailing comment
DEK A1BC8438BF77935B361A4425FE79FA29 # Optional trailing comment
but if I use a different MAC key , for example,
MAC AF177D5DBDF7C0D5C10A05B9F1607F72
The authentication failed as similar as you met.
App :INFO :PlugAndTrust_v04.00.00_20211026
App :INFO :Running C:\se050_middleware\simw-top_build\se_x86\bin\Debug\se05x_Minimal.exe
App :INFO :Using PortName='\\.\COM7' (gszCOMPortDefault)
App :DEBUG:Using File: C:\nxp\SE05X\plain_scp.txt
App :WARN :Using SCP03 keys from:'C:\nxp\SE05X\plain_scp.txt' (FILE=C:\nxp\SE05X\plain_scp.txt)
Opening COM Port '\\.\COM7'
smCom :DEBUG:Get ATR (Len=4)
00 00 00 00
smCom :DEBUG:pAtr (Len=39)
00 00 00 23 00 A0 00 00 03 96 04 03 E8 00 FE 02
0B 03 E8 08 01 00 00 00 00 64 00 00 0A 4A 43 4F
50 34 20 41 54 50 4F
smCom :DEBUG:no lock mode
smCom :DEBUG:H> (Len=4)
01 00 00 16
smCom :DEBUG:Tx> (Len=22)
03 00 00 00 00 00
smCom :DEBUG:<H (Len=4)
01 00 00 09
smCom :DEBUG:<Rx (Len=9)
03 01 00 6F FF 01 0B 90 00
54 50 4F
A7 49 D3 93 CF BC AF 06
01 00 00 0D
smCom :DEBUG:Tx> (Len=13)
80 50 0B 00 08 A7 49 D3 93 CF BC AF 06
01 00 00 1F
smCom :DEBUG:<Rx (Len=31)
90 03 92 84 05 21 70 99 37 34 0B 03 00 14 60 E2
8D 0F 2B 79 61 A0 64 98 04 F1 45 B9 DB 90 00
0B 03 00
14 60 E2 8D 0F 2B 79 61
A7 49 D3 93 CF BC AF 06 14 60 E2 8D 0F 2B 79 61
90 67 9A C3 53 D3 A8 75 47 0C 21 93 56 1D F8 F6
47 04 12 93 3C 60 66 24 3E 7A BD C5 40 C8 18 BD
BA 99 0C 07 4E 1B 98 FD 5A 16 4B FC EB 1A F2 04
E3 13 D6 B5 7C D6 EA 47 DB C2 58 69 BC F7 1F F7
scp :WARN :nxEnsure:'status == kStatus_SSS_Success' failed. At Line:144 Function:nxScp03_AuthenticateChannel
C:\se050_middleware\simw-top_build\se_x86\bin\Debug\se05x_Minimal.exe (process 5656) exited with code 1.
To automatically close the console when debugging stops, enable Tools->Options->Debugging->Automatically close the console when debugging stops.
Press any key to close this window . . .
Please kindly check the keys setting from your side, both the embedded Linux host and the SE050 dev kits. You may run the demo of "Delete and Test Provision" as I mentioned before to inject the default the authentication objects into the dev kits.
Hope that helps,
Kan
30,114 次查看
ElielderBMelo
Hi @Kan_Li
This keys you have provided me are the ones the I am using during the whole process. I ran this the demo of "Delete and Test Provision" and it didn't work, it stopped in the same place.
Attached to this message are a document that I relate all my environment and test I did with "Get Info", also is attached the "cmake_option.txt" file for more information.
Thanks.
30,107 次查看
Kan_Li
Hi @ElielderBMelo ,
Thanks for the information! I checked the cmake option from your side, almost the same, except the host.
I am wondering with which configuration you run the demo of "Delete and Test Provision"?
-DSCP=SCP03_SSS
-DSE05X_Auth=PlatfSCP03
Or
-DSCP=None
-DSE05X_Auth=None
As you mentioned before, the GetInfo demo can run well without SCP03 Authentication, so I think it should be the same the demo of "Delete and Test Provision", right? Please kindly clarify.
Kan
30,097 次查看
ElielderBMelo
Hi @Kan_Li
Thank you for checking my cmake options.
For "Delete and Test Provision" I'm using:
-DSCP=SCP03_SSS
I have shown in the document I have sent you the behavior with SCP03 authentication and without SCP03 auth. For you to help me to see if there is anything strange in the behaviour without SCP03 authentication.
I have one more question @Kan_Li, I noticed that your MW version is different than mine. I'm wondering if I can get an older and a newer version to compile and test here.
My devkit HW are working well and I have 2 of them with my team and those 2 are operating in the same way.
I got this info and I ask you to clarify for me:
      54 50 4F
Thanks.
30,086 次查看
Kan_Li
Hi @ElielderBMelo ,
Hope that helps,
Kan
30,078 次查看
ElielderBMelo
Hi @Kan_Li
Thank you for the reply, it was successful. It worked and I ran the Get Info, Minimal and Delete and Test Provision applications with no more issues.
Now, I will continue the work to bind the library to the OpenSSL Engine.
Thank you a lot.
30,059 次查看
Kan_Li
Hi @ElielderBMelo ,
Great to know! Thanks for the update!
Kan
30,001 次查看
ElielderBMelo
Hi @Kan_Li
I'm having issues with OpenSSL, but first I ask you, please, to check my log files to see if it is correct to the expected from "Get Info" and "Delete and Test Provision" applications.
If they are correct, I will open one more question on the forum for you to provide me help in this issue.
Thanks.
Best Regards.
29,955 次查看
Kan_Li
Hi @ElielderBMelo ,
I have reviewed the logs, and they are correct. I think you have enabled PlatSCP03 authentication correctly.
Kan
30,196 次查看
Kan_Li
Hi @ElielderBMelo ,
Thanks for the info! Did you inject these keys with the demo of SE05X Rotate PlatformSCP Keys Demo? Or the dev kit still holds the default keys? Please kindly clarify.
Kan
30,174 次查看
ElielderBMelo
No, I didn't use the SE05X Rotate PlatformSCP Keys Demo. The kit holds the default keys.
I'm trying to authenticate with SCP03 keys, only. And I've created a file which stores the ENC, MAC and DEK keys, this file are being called by EX_SSS_SCP03_FILE_PATH.
Thanks.
30,219 次查看
ElielderBMelo
I've found a info:
54 50 4F
Is there any problem with this?
30,194 次查看
Kan_Li
Hi @ElielderBMelo ,
What is the version of MW on your hands? I guess it should be 3.03.00, right?
Kan
30,173 次查看
ElielderBMelo
Yes, it is the latest version of Middleware, 03.03.00.
