SE050 Working
SE050 Working
5,606 次查看
Changhawn
Dear
With SE050 Evb,  TLS 1.3 Handshaking is tested. And I have some question about SE050 working.
1. Memory-related issues
When executing the key writing API (Se05x_API_WriteECKey_Ver()) during the TLS handshake, it returns 0x6a84.
SM_ERR_FILE_FULL = 0x6A84, // Not enough memory space available (either transient or persistent memory)
The same issue persists even after powering off and on again.
What are the causes and solutions for this memory space issue?
2. When trying to check free memory with Se05x_API_GetFreeMemory() to confirm issue #1 above,
SE050 returns incorrect data (0x6a80), as shown below. Can I use this API? Please help.
[ERR][cli] Se05x_API_GetFreeMemory Failed(0x6a80)
[INF][cli] Persistent Memory 0x0000
[INF][cli] Transient Memory 0x0000
3. When SE050 doesn't work (no SE050 I2C response), even after a main board power reset, it still doesn't work.
Sometimes, after several attempts, it starts working again for no reason.
Are there any specific booting or working conditions required for SE050 to function properly?
Thank in advance.
11 回复数
5,588 次查看
Kan_Li
Hi @Changhawn ,
Is it possible to provide more details regarding the platform as well as the SE050 board? are you using OM-SE050ARD-E? Is your plarform a MCU based platform? Which variant of SE050 is used in your test? Please kindly clarify.
Kan
5,583 次查看
Changhawn
Dear Kan_Li
Yes. Platform is like this(S32K314(FreeRTOS+LWIP+MbedTLS+HSE) + SE050),  and use OM-SE050ARD-E.
With MCU based platform, I do testing TLS1.3. (Handshake is sometimes ok. )
SE050 : ECC, ECDH, ECDSA, HKDF & Key mgmt
S32K314 HSE  : AES, CMAC, HMAC, AES GCM(AEAD) & Key mgmt
about Issues,
1. memory related issue :   issue is happened in Key generation.(ECDHE)
2. Se05x_API_GetFreeMemory() : for debugging about issue number 1.
3. Sometimes, after MCU Reset, SE050 is returned as failed(I2C Arbitration lost)
Thank you.
Chang.
5,574 次查看
Kan_Li
Hi @Changhawn ,
Thanks for the info! Can the getinfo demo work with this part on your platform? It looks like platformSCP03 was set mandatory while the controller still communicated with the SE in plain channel.
Kan
5,550 次查看
Changhawn
Dear Kan_Li.
For debugging, more information.
When I use Se05x_API_DeleteAll_Iterative() for deleting all object, error is returned in Se05x_API_ReadIDList() like below.
ReadIDList Failed=0x6985
// SM_ERR_CONDITIONS_OF_USE_NOT_SATISFIED = 0x6985,
smStatus_t Se05x_API_DeleteAll_Iterative(pSe05xSession_t session_ctx)
    uint8_t pmore = kSE05x_MoreIndicator_NA;
    uint8_t list[1024];
    size_t listlen = sizeof(list);
    size_t i;
    smStatus_t retStatus  = SM_NOT_OK;
    uint16_t outputOffset = 0;
    do {
        retStatus = Se05x_API_ReadIDList(session_ctx, outputOffset, 0xFF, &pmore, list, &listlen);
        if (retStatus != SM_OK) {
            SMLOG_I("ReadIDList Failed=0x%04x", retStatus);
            goto exit;
        outputOffset = (uint16_t)listlen;
        for (i = 0; i < listlen; i += 4) {
            uint32_t id = 0 | (list[i + 0] << (3 * 8)) | (list[i + 1] << (2 * 8)) | (list[i + 2] << (1 * 8)) |
                          (list[i + 3] << (0 * 8));
            if (SE05X_OBJID_SE05X_APPLET_RES_START == SE05X_OBJID_SE05X_APPLET_RES_MASK(id)) {
                SMLOG_I("Not erasing ObjId=0x%08X (Reserved)", id);
                /* In Reserved space */
            else if (EX_SSS_OBJID_DEMO_AUTH_START == EX_SSS_OBJID_DEMO_AUTH_MASK(id)) {
                SMLOG_I("Not erasing ObjId=0x%08X (Demo Auth)", id);
                /* Not reasing default authentication object */
            else if (EX_SSS_OBJID_IOT_HUB_A_START == EX_SSS_OBJID_IOT_HUB_A_MASK(id)) {
                SMLOG_I("Not erasing ObjId=0x%08X (IoT Hub)", id);
                /* Not reasing IoT Hub object */
            else if (!SE05X_OBJID_TP_MASK(id) && id) {
                SMLOG_I("Not erasing Trust Provisioned objects");
            else {
                retStatus = Se05x_API_DeleteSecureObject(session_ctx, id);
                    SMLOG_I("Error in erasing ObjId=0x%08X (Others)", id);
    } while (pmore == kSE05x_MoreIndicator_MORE);
exit:
    return retStatus;
5,570 次查看
Changhawn
Dear Kan_Li.
Thank you for your guide.
Getinfo demo(GetVersion) work well in our platform.
scp03 key and auth key was set like below API(GetInfo).
Is it(plain channel or secure channel) related to Issue 1, 2 ?
Thank you.
Chang.
int ex_se05x_GetInfo()
    smStatus_t status             = SM_NOT_OK;
    pSe05xSession_t p_session_ctx = &se05x_session;
    int ret                       = 1;
    uint32_t mem = 0;
    ex_set_scp03_keys(p_session_ctx);
    ex_set_ec_auth_keys(p_session_ctx);
    p_session_ctx = se05x_get_session();
    if (p_session_ctx == NULL) {
        SMLOG_E("Error in Se05x_API_SessionOpen \r\n");
        return 1;
        /* Get applet version and config details */
        ret = Iot_Applet_Identify(p_session_ctx, 1);
        if (ret != 0) {
            SMLOG_I("Error in Iot_Applet_Identify \n");
    //   #define SE05X_VERSION_HEX_07_02
    p_session_ctx->applet_version = 0x07020000;
    status = Se05x_API_GetFreeMemory(p_session_ctx, kSE05x_MemoryType_PERSISTENT, &mem);
    if (status != SM_OK) {
        SMLOG_E("Se05x_API_GetFreeMemory Failed(0x%x)", status);
        status = kStatus_SSS_Fail;
    if ((mem >= 0x7FFF) && (p_session_ctx->applet_version <= SE05X_VERSION_HEX_07_02)) {
        SMLOG_I("If 32768 bytes or more bytes are available, 32767 bytes free is reported.");
    SMLOG_I("Persistent Memory 0x%04x", mem);
    status = Se05x_API_GetFreeMemory(p_session_ctx, kSE05x_MemoryType_TRANSIENT_RESET, &mem);
    SMLOG_I("Transient Memory 0x%04x", mem);
    status = Se05x_API_SessionClose(p_session_ctx);
        SMLOG_I("Error in Se05x_API_SessionClose \n");
        return 1;
    return 0;
5,575 次查看
Changhawn
Dear Kan_Li.
Issue 3 is cleared. so debugging on Issue 1, 2.
Below log is applet version and config details.
Thank you.
Chang.
< Log >
[INF][cli] Open Session to SE05x
[INF][cli] Plug and Trust nano package - version: 1.5.4
[INF][cli] Applet Major = 7
[INF][cli] Applet Minor = 2
[INF][cli] Applet patch = 0
[INF][cli] AppletConfig = 3F9F
[INF][cli] With ECDSA_ECDH_ECDHE
[INF][cli]
[INF][cli] With EDDSA
[INF][cli]
[INF][cli] With DH_MONT
[INF][cli]
[INF][cli] With HMAC
[INF][cli]
[INF][cli] WithOut RSA_PLAIN
[INF][cli]
[INF][cli] WithOut RSA_CRT
[INF][cli]
[INF][cli] With AES
[INF][cli]
[INF][cli] With DES
[INF][cli]
[INF][cli] With PBKDF
[INF][cli]
[INF][cli] With TLS
[INF][cli]
[INF][cli] With MIFARE
[INF][cli]
[INF][cli] With I2CM
[INF][cli]
5,526 次查看
Kan_Li
Hi @Changhawn ,
Thanks for the info! Is it possible to provide the APDU command log as well? Seems you are using the nano package, so you may build the package with SMLOG_DEBUG_MESSAGES definition to enable the debug log info.
Kan
5,522 次查看
Changhawn
Dear Kan_Li.
Yes , used some API of Nano version. also used Full version.
I have no SMLOG_DEBUG_MESSAGES definition.
I can not enable any log feature, I2C has problem by log message.
If you need apdu of som API, please tell me the API. I can give you APDU of that API.
Thank you.
Chang.
5,517 次查看
Kan_Li
Hi @Changhawn ,
Looks like the secure objects created in your SE consumed all the memory, so that you had such issue with readidlist, which needs extend APDU format to have a longer size for receiving the secure object list , Please kindly refer to https://community.nxp.com/t5/Secure-Authentication/SE050E-question-for-Se05x-API-GetFreeMemory-and-e... for more details regarding how to enable the extend APDU format in the nano package.
Hope that helps,
Kan
5,475 次查看
Changhawn
Dear Kan_Li.
Thank you for your support.
One more question about my issue.
With "WITH_PLATFORM_SCP03" and correct enc_key and mac_key,
I can confirm the memory status and deleting object.
Is it(below log 2) normal? ,
But when run the TLS 1.3 Handshake(writing key) , "SM_ERR_SECURITY_STATUS" is returned like log 1.  Could you give what's problem?
Thank you
Chang.
< log 1 >
[INF][devtask] ECDH compute shared secret with SE050
[SE_APDU] Se05x_API_GetECCurveId is ok keyid(0xef0000ec) retObjectType(49) curveid(5) transientType(2)
[SE_APDU] sss_se05x_key_store_set_ecc_public_key KeyId(0xef000371) keybitlen(521), keyLen(133) ciphertype(40)
[SE_APDU] sss_se05x_key_store_set_ecc_public_key curve_id 5, key_part 32
[SE_APDU] WriteECKey_Ver Failed(0x6982)
SM_ERR_SECURITY_STATUS = 0x6982, // Security status not satisfied
< log 2 >
/* Memory status of SE050 */
show mem...
[INF][cli] Establish Secure Channel to SE05x !
[INF][cli] Created scp03 Session
[INF][cli] If 32768 bytes or more bytes are available, 32767 bytes free is reported.
[INF][cli] Persistent Memory 0x7fff
[INF][cli] Transient Memory 0x02bc
/* Run the Se05x_API_DeleteAll_Iterative API */
Delete Object...
[INF][cli] Not erasing ObjId=0xF0000103 (IoT Hub)
[INF][cli] Not erasing ObjId=0xF0000101 (IoT Hub)
[INF][cli] Not erasing ObjId=0xF0000102 (IoT Hub)
[INF][cli] Not erasing ObjId=0xF0000100 (IoT Hub)
[INF][cli] Not erasing ObjId=0xF0000003 (IoT Hub)
[INF][cli] Not erasing ObjId=0xF0000001 (IoT Hub)
[INF][cli] Not erasing ObjId=0xF0000002 (IoT Hub)
[INF][cli] Not erasing ObjId=0xF0000000 (IoT Hub)
[INF][cli] Not erasing ObjId=0xF0000013 (IoT Hub)
[INF][cli] Not erasing ObjId=0xF0000012 (IoT Hub)
[INF][cli] Not erasing ObjId=0xF0000020 (IoT Hub)
[INF][cli] Not erasing ObjId=0xF0003394 (IoT Hub)
[INF][cli] Not erasing ObjId=0x7FFF020B (Reserved)
[INF][cli] Not erasing ObjId=0x7FFF0204 (Reserved)
[INF][cli] Not erasing ObjId=0x7FFF0202 (Reserved)
[INF][cli] Not erasing ObjId=0x7FFF0201 (Reserved)
[INF][cli] Not erasing ObjId=0x7FFF0206 (Reserved)
SE050 Reset Success !!!
5,444 次查看
Kan_Li
Hi @Changhawn ,
If you have successful result only when "WITH_PLATFORM_SCP03" and correct enc_key and mac_key, it means you have enabled platformSCP03 mandatory.
from log1, I can not comment as no APDU log available, is it possible to open the debug info printing?
Thanks for your patience!
Kan
%3CLINGO-SUB%20id%3D%22lingo-sub-2262131%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ESE050%20%E5%B7%A5%E4%BD%9C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2262131%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%B0%8A%E6%95%AC%E7%9A%84%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%20SE050%20Evb%20%E6%B5%8B%E8%AF%95%E4%BA%86%20TLS%201.3%20%E6%8F%A1%E6%89%8B%E3%80%82%E6%88%91%E8%BF%98%E6%9C%89%E4%B8%80%E4%BA%9B%E5%85%B3%E4%BA%8E%20SE050%20%E5%B7%A5%E4%BD%9C%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E1.%E5%86%85%E5%AD%98%E7%9B%B8%E5%85%B3%E9%97%AE%E9%A2%98%3CBR%20%2F%3E%E5%9C%A8%20TLS%20%E6%8F%A1%E6%89%8B%E8%BF%87%E7%A8%8B%E4%B8%AD%E6%89%A7%E8%A1%8C%E5%AF%86%E9%92%A5%E5%86%99%E5%85%A5%20API%EF%BC%88Se05x_API_WriteECKey_Ver()%EF%BC%89%E6%97%B6%EF%BC%8C%E8%BF%94%E5%9B%9E%200x6a84%E3%80%82%3CBR%20%2F%3ESM_ERR_FILE_FULL%20%3D%200x6A84%2C%20%2F%2F%20%E6%B2%A1%E6%9C%89%E8%B6%B3%E5%A4%9F%E7%9A%84%E5%8F%AF%E7%94%A8%E5%86%85%E5%AD%98%E7%A9%BA%E9%97%B4%EF%BC%88%E7%9E%AC%E6%97%B6%E5%86%85%E5%AD%98%E6%88%96%E6%8C%81%E4%B9%85%E5%86%85%E5%AD%98%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E5%8D%B3%E4%BD%BF%E5%85%B3%E6%9C%BA%E5%90%8E%E5%86%8D%E6%AC%A1%E5%BC%80%E6%9C%BA%EF%BC%8C%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%E4%BE%9D%E7%84%B6%E5%AD%98%E5%9C%A8%E3%80%82%3C%2FP%3E%3CP%3E%E5%86%85%E5%AD%98%E7%A9%BA%E9%97%B4%E9%97%AE%E9%A2%98%E7%9A%84%E5%8E%9F%E5%9B%A0%E5%92%8C%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E2.%E5%BD%93%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20Se05x_API_GetFreeMemory()%E6%A3%80%E6%9F%A5%E5%8F%AF%E7%94%A8%E5%86%85%E5%AD%98%E4%BB%A5%E7%A1%AE%E8%AE%A4%E4%B8%8A%E8%BF%B0%E9%97%AE%E9%A2%98%20%231%20%E6%97%B6%E3%80%81%3C%2FP%3E%3CP%3ESE050%20%E8%BF%94%E5%9B%9E%E9%94%99%E8%AF%AF%E6%95%B0%E6%8D%AE%20(0x6a80)%EF%BC%8C%E5%A6%82%E4%B8%8B%E6%89%80%E7%A4%BA%E3%80%82%E6%88%91%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E8%AF%A5%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E6%8E%A5%E5%8F%A3%E5%90%97%EF%BC%9F%E8%AF%B7%E5%B8%AE%E5%B8%AE%E6%88%91%E3%80%82%3C%2FP%3E%3CP%3E%5BERR%5D%5Bcli%5D%20Se05x_API_GetFreeMemory%20Failed(0x6a80)%3CBR%20%2F%3E%5BINF%5D%5Bcli%5D%20Persistent%20Memory%200x0000%3CBR%20%2F%3E%5BERR%5D%5Bcli%5D%20Se05x_API_GetFreeMemory%20Failed(0x6a80)%3CBR%20%2F%3E%5BINF%5D%5Bcli%5D%20Transient%20Memory%200x0000%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E3.%E5%BD%93%20SE050%20%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E6%97%B6%EF%BC%88%E6%B2%A1%E6%9C%89%20SE050%20I2C%20%E5%93%8D%E5%BA%94%EF%BC%89%EF%BC%8C%E5%8D%B3%E4%BD%BF%E5%9C%A8%E4%B8%BB%E6%9D%BF%E7%94%B5%E6%BA%90%20RESET%20%E4%B9%8B%E5%90%8E%EF%BC%8C%E5%AE%83%E4%BB%8D%E7%84%B6%E6%97%A0%E6%B3%95%E5%B7%A5%E4%BD%9C%E3%80%82%3C%2FP%3E%3CP%3E%E6%9C%89%E6%97%B6%EF%BC%8C%E5%B0%9D%E8%AF%95%E5%87%A0%E6%AC%A1%E5%90%8E%EF%BC%8C%E5%AE%83%E5%8F%88%E4%BC%9A%E6%97%A0%E7%BC%98%E6%97%A0%E6%95%85%E5%9C%B0%E5%BC%80%E5%A7%8B%E5%B7%A5%E4%BD%9C%E3%80%82%3C%2FP%3E%3CP%3ESE050%20%E6%98%AF%E5%90%A6%E9%9C%80%E8%A6%81%E4%BB%BB%E4%BD%95%E7%89%B9%E5%AE%9A%E7%9A%84%E5%90%AF%E5%8A%A8%E6%88%96%E5%B7%A5%E4%BD%9C%E6%9D%A1%E4%BB%B6%E6%89%8D%E8%83%BD%E6%AD%A3%E5%B8%B8%E8%BF%90%E8%A1%8C%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E9%A2%84%E5%85%88%E8%87%B4%E8%B0%A2%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2263227%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050%20Working%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2263227%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F232520%22%20target%3D%22_blank%22%3E%40Changhawn%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%9C%8B%E6%9D%A5%E4%BD%A0%E7%9A%84%20SE%20%E4%B8%AD%E5%88%9B%E5%BB%BA%E7%9A%84%E5%AE%89%E5%85%A8%E5%AF%B9%E8%B1%A1%E6%B6%88%E8%80%97%E4%BA%86%E6%89%80%E6%9C%89%E5%86%85%E5%AD%98%EF%BC%8C%E6%89%80%E4%BB%A5%E4%BD%A0%E5%9C%A8%E4%BD%BF%E7%94%A8%20readidlist%20%E6%97%B6%E9%81%87%E5%88%B0%E4%BA%86%E8%BF%99%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E5%AE%83%E9%9C%80%E8%A6%81%E6%89%A9%E5%B1%95%20APDU%20%E6%A0%BC%E5%BC%8F%E4%BB%A5%E6%9B%B4%E9%95%BF%E7%9A%84%E5%A4%A7%E5%B0%8F%E6%9D%A5%E6%8E%A5%E6%94%B6%E5%AE%89%E5%85%A8%E5%AF%B9%E8%B1%A1%E5%88%97%E8%A1%A8%E3%80%82%E6%9C%89%E5%85%B3%E5%A6%82%E4%BD%95%E5%9C%A8%20nano%20%E8%BD%AF%E4%BB%B6%E5%8C%85%E4%B8%AD%E5%90%AF%E7%94%A8%E6%89%A9%E5%B1%95%20APDU%20%E6%A0%BC%E5%BC%8F%E7%9A%84%E6%9B%B4%E5%A4%9A%E8%AF%A6%E7%BB%86%E4%BF%A1%E6%81%AF%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FSecure-Authentication%2FSE050E-question-for-Se05x-API-GetFreeMemory-and-ex-se05x%2Fm-p%2F2107498%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FSecure-Authentication%2FSE050E-question-for-Se05x-API-GetFreeMemory-and-ex-se05x%2Fm-p%2F2107498%3C%2FA%3E%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%B8%8C%E6%9C%9B%E5%AF%B9%E4%BD%A0%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%A5%9D%E6%82%A8%E6%84%89%E5%BF%AB%EF%BC%8C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%3CBR%20%2F%3E-%20%E5%A6%82%E6%9E%9C%E6%9C%AC%E5%B8%96%E5%9B%9E%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%22%E6%A0%87%E8%AE%B0%E6%AD%A3%E7%A1%AE%22%20%E6%8C%89%E9%92%AE%E3%80%82%E8%B0%A2%E8%B0%A2%EF%BC%81%3CBR%20%2F%3E-%20%E6%88%91%E4%BB%AC%E4%BC%9A%E5%9C%A8%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E5%8F%91%E5%B8%96%E5%90%8E%E7%9A%84%207%20%E5%91%A8%E5%86%85%E8%B7%9F%E8%B8%AA%E4%B8%BB%E9%A2%98%EF%BC%8C%E4%B9%8B%E5%90%8E%E7%9A%84%E5%9B%9E%E5%A4%8D%E5%B0%86%E8%A2%AB%E5%BF%BD%E7%95%A5%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BB%A5%E5%90%8E%E6%9C%89%E7%9B%B8%E5%85%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E6%89%93%E5%BC%80%E4%B8%80%E4%B8%AA%E6%96%B0%E4%B8%BB%E9%A2%98%E5%B9%B6%E5%8F%82%E8%80%83%E5%B7%B2%E5%85%B3%E9%97%AD%E7%9A%84%E4%B8%BB%E9%A2%98%E3%80%82%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2263225%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050%20Working%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2263225%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BA%B2%E7%88%B1%E7%9A%84%20Kan_Li%3C%2FP%3E%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E4%BD%BF%E7%94%A8%E4%BA%86%E7%BA%B3%E7%B1%B3%E7%89%88%E6%9C%AC%E7%9A%84%E4%B8%80%E4%BA%9B%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E6%8E%A5%E5%8F%A3%E3%80%82%E4%B9%9F%E4%BD%BF%E7%94%A8%E4%BA%86%E5%AE%8C%E6%95%B4%E7%89%88%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%B2%A1%E6%9C%89%3CSPAN%3ESMLOG_DEBUG_MESSAGES%20%E7%9A%84%E5%AE%9A%E4%B9%89%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%97%A0%E6%B3%95%E5%90%AF%E7%94%A8%E4%BB%BB%E4%BD%95%E6%97%A5%E5%BF%97%E5%8A%9F%E8%83%BD%EF%BC%8CI2C%20%E7%9A%84%E6%97%A5%E5%BF%97%E4%BF%A1%E6%81%AF%E6%9C%89%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E9%9C%80%E8%A6%81%E6%9F%90%E4%B8%AA%20API%20%E7%9A%84%20apdu%EF%BC%8C%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E6%98%AF%E5%93%AA%E4%B8%AA%20API%E3%80%82%E6%88%91%E5%8F%AF%E4%BB%A5%E4%B8%BA%E6%82%A8%E6%8F%90%E4%BE%9B%E8%AF%A5%20API%20%E7%9A%84%20APDU%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%E5%BC%A0%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2263185%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050%20Working%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2263185%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F232520%22%20target%3D%22_blank%22%3E%40Changhawn%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E4%BF%A1%E6%81%AF%EF%BC%81%E8%83%BD%E5%90%A6%E5%90%8C%E6%97%B6%E6%8F%90%E4%BE%9B%20APDU%20%E5%91%BD%E4%BB%A4%E6%97%A5%E5%BF%97%EF%BC%9F%E7%9C%8B%E6%9D%A5%E4%BD%A0%E5%9C%A8%E4%BD%BF%E7%94%A8%E7%BA%B3%E7%B1%B3%E8%BD%AF%E4%BB%B6%E5%8C%85%EF%BC%8C%E6%89%80%E4%BB%A5%E4%BD%A0%E5%8F%AF%E4%BB%A5%E7%94%A8%20SMLOG_DEBUG%20%3CSPAN%3E_MESSAGES%20%E5%AE%9A%E4%B9%89%E6%9D%A5%E7%89%88%E6%9C%AC%E8%BF%99%E4%B8%AA%E8%BD%AF%E4%BB%B6%E5%8C%85%E6%9D%A5%E5%90%AF%E7%94%A8%E8%B0%83%E8%AF%95%E6%97%A5%E5%BF%97%E4%BF%A1%E6%81%AF%3C%2FSPAN%3E%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%A5%9D%E6%82%A8%E6%84%89%E5%BF%AB%EF%BC%8C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%3CBR%20%2F%3E-%20%E5%A6%82%E6%9E%9C%E6%9C%AC%E5%B8%96%E5%9B%9E%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%22%E6%A0%87%E8%AE%B0%E6%AD%A3%E7%A1%AE%22%20%E6%8C%89%E9%92%AE%E3%80%82%E8%B0%A2%E8%B0%A2%EF%BC%81%3CBR%20%2F%3E-%20%E6%88%91%E4%BB%AC%E4%BC%9A%E5%9C%A8%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E5%8F%91%E5%B8%96%E5%90%8E%E7%9A%84%207%20%E5%91%A8%E5%86%85%E8%B7%9F%E8%B8%AA%E4%B8%BB%E9%A2%98%EF%BC%8C%E4%B9%8B%E5%90%8E%E7%9A%84%E5%9B%9E%E5%A4%8D%E5%B0%86%E8%A2%AB%E5%BF%BD%E7%95%A5%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BB%A5%E5%90%8E%E6%9C%89%E7%9B%B8%E5%85%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E6%89%93%E5%BC%80%E4%B8%80%E4%B8%AA%E6%96%B0%E4%B8%BB%E9%A2%98%E5%B9%B6%E5%8F%82%E8%80%83%E5%B7%B2%E5%85%B3%E9%97%AD%E7%9A%84%E4%B8%BB%E9%A2%98%E3%80%82%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2263144%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050%20Working%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2263144%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BA%B2%E7%88%B1%E7%9A%84%20Kan_Li%3C%2FP%3E%3CP%3E%E6%9C%89%E5%85%B3%E8%B0%83%E8%AF%95%E7%9A%84%E6%9B%B4%E5%A4%9A%E4%BF%A1%E6%81%AF%E3%80%82%3C%2FP%3E%3CP%3E%E5%BD%93%E6%88%91%E4%BD%BF%E7%94%A8%3CSPAN%3ESe05x_API_DeleteAll_Iterative()%E5%88%A0%E9%99%A4%E6%89%80%E6%9C%89%E5%AF%B9%E8%B1%A1%E6%97%B6%EF%BC%8C%3CSPAN%3ESe05x_API_ReadIDList()%3C%2FSPAN%3E%E8%BF%94%E5%9B%9E%E7%9A%84%E9%94%99%E8%AF%AF%E4%BF%A1%E6%81%AF%E5%A6%82%E4%B8%8B%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E8%AF%BB%E5%8F%96%20IDList%20%E5%A4%B1%E8%B4%A5%3D0x6985%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%2F%2F%20%3C%2FSPAN%3E%3CSPAN%3Esm_err_conditions_of_use_not_satisfied%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E0x6985%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3EsmStatus_t%3C%2FSPAN%3E%20%3CSPAN%3ESe05x_API_DeleteAll_Iterative%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3EpSe05xSession_t%3C%2FSPAN%3E%20%3CSPAN%3Esession_ctx%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3Euint8_t%3C%2FSPAN%3E%20%3CSPAN%3Epmore%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3EkSE05x_MoreIndicator_NA%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3Euint8_t%3C%2FSPAN%3E%20%3CSPAN%3Elist%3C%2FSPAN%3E%3CSPAN%3E%5B1024%5D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3Esize_t%3C%2FSPAN%3E%20%3CSPAN%3Elistlen%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3Esizeof(list)%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3Esize_t%3C%2FSPAN%3E%20%3CSPAN%3Ei%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3EsmStatus_t%3C%2FSPAN%3E%20%3CSPAN%3EretStatus%3C%2FSPAN%3E%3CSPAN%3E%20%20%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3ESM_NOT_OK%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3Euint16_t%3C%2FSPAN%3E%20%3CSPAN%3E%E8%BE%93%E5%87%BA%E5%81%8F%E7%A7%BB%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E5%81%9A%3C%2FSPAN%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E7%8A%B6%E6%80%81%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3ESe05x_API_ReadIDList%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%E4%BC%9A%E8%AF%9D_ctx%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E%E8%BE%93%E5%87%BA%E5%81%8F%E7%A7%BB%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E0xFF%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%3Epmore%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3Elist%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%3Elistlen%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3EretStatus%3C%2FSPAN%3E%20%3CSPAN%3E!%3D%3C%2FSPAN%3E%20%3CSPAN%3ESM_OK%3C%2FSPAN%3E%3CSPAN%3E)%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3ESMLOG_I%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%22%E8%AF%BB%E5%8F%96%20IDList%20%E5%A4%B1%E8%B4%A5%3D0x%3C%2FSPAN%3E%3CSPAN%3E%2504x%3C%2FSPAN%3E%3CSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3EretStatus%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E8%B7%B3%E8%BD%AC%3C%2FSPAN%3E%20%3CSPAN%3E%E9%80%80%E5%87%BA%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E8%BE%93%E5%87%BA%E5%81%8F%E7%A7%BB%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Euint16_t%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3CSPAN%3Elistlen%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E4%B8%BA%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Ei%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3B%20%3C%2FSPAN%3E%3CSPAN%3Ei%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3Elistlen%3C%2FSPAN%3E%3CSPAN%3E%3B%20%3C%2FSPAN%3E%3CSPAN%3Ei%3C%2FSPAN%3E%20%3CSPAN%3E%2B%3D%3C%2FSPAN%3E%20%3CSPAN%3E4%3C%2FSPAN%3E%3CSPAN%3E)%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3Euint32_t%3C%2FSPAN%3E%20%3CSPAN%3Eid%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Elist%3C%2FSPAN%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3Ei%3C%2FSPAN%3E%20%3CSPAN%3E%2B%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%5D%20%3C%2FSPAN%3E%3CSPAN%3E%26lt%3B%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E3%3C%2FSPAN%3E%20%3CSPAN%3E*%3C%2FSPAN%3E%20%3CSPAN%3E8%3C%2FSPAN%3E%3CSPAN%3E))%20%3C%2FSPAN%3E%3CSPAN%3E%7C%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%E5%88%97%E8%A1%A8%3C%2FSPAN%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3Ei%3C%2FSPAN%3E%20%3CSPAN%3E%2B%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%5D%20%3C%2FSPAN%3E%3CSPAN%3E%26lt%3B%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E2%3C%2FSPAN%3E%20%3CSPAN%3E*%3C%2FSPAN%3E%20%3CSPAN%3E8%3C%2FSPAN%3E%3CSPAN%3E))%20%3C%2FSPAN%3E%3CSPAN%3E%7C%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%E5%88%97%E8%A1%A8%3C%2FSPAN%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3Ei%3C%2FSPAN%3E%20%3CSPAN%3E%2B%3C%2FSPAN%3E%20%3CSPAN%3E2%3C%2FSPAN%3E%3CSPAN%3E%5D%20%3C%2FSPAN%3E%3CSPAN%3E%26lt%3B%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%20%3CSPAN%3E*%3C%2FSPAN%3E%20%3CSPAN%3E8%3C%2FSPAN%3E%3CSPAN%3E))%20%3C%2FSPAN%3E%3CSPAN%3E%7C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20(%3C%2FSPAN%3E%3CSPAN%3E%E5%88%97%E8%A1%A8%3C%2FSPAN%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3Ei%3C%2FSPAN%3E%20%3CSPAN%3E%2B%3C%2FSPAN%3E%20%3CSPAN%3E3%3C%2FSPAN%3E%3CSPAN%3E%5D%20%3C%2FSPAN%3E%3CSPAN%3E%26lt%3B%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E*%3C%2FSPAN%3E%20%3CSPAN%3E8%3C%2FSPAN%3E%3CSPAN%3E))%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Ese05x_objid_se05x_applet_res_start%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3D%3C%2FSPAN%3E%20%3CSPAN%3Ese05x_objid_se05x_applet_res_mask%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Eid%3C%2FSPAN%3E%3CSPAN%3E))%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3ESMLOG_I%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%22%E6%9C%AA%E6%93%A6%E9%99%A4%20ObjId%3D0x%3C%2FSPAN%3E%3CSPAN%3E%2508X%3C%2FSPAN%3E%3CSPAN%3E(%E4%BF%9D%E7%95%99)%22%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3Eid%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F*%20%E4%BF%9D%E7%95%99%E7%A9%BA%E9%97%B4%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E5%90%A6%E5%88%99%3C%2FSPAN%3E%20%3CSPAN%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Eex_sss_objid_demo_auth_start%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3D%3C%2FSPAN%3E%20%3CSPAN%3Eex_sss_objid_demo_auth_mask%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Eid%3C%2FSPAN%3E%3CSPAN%3E))%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3ESMLOG_I%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%22%E6%9C%AA%E6%93%A6%E9%99%A4%20ObjId%3D0x%3C%2FSPAN%3E%3CSPAN%3E%2508X%3C%2FSPAN%3E%3CSPAN%3E(%E6%BC%94%E7%A4%BA%E9%AA%8C%E8%AF%81)%22%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3Eid%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F*%20%E4%B8%8D%E6%9B%B4%E6%96%B0%E9%BB%98%E8%AE%A4%E8%BA%AB%E4%BB%BD%E9%AA%8C%E8%AF%81%E5%AF%B9%E8%B1%A1%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E5%90%A6%E5%88%99%3C%2FSPAN%3E%20%3CSPAN%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Eex_sss_objid_iot_hub_a_start%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3D%3C%2FSPAN%3E%20%3CSPAN%3Eex_sss_objid_iot_hub_a_mask%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Eid%3C%2FSPAN%3E%3CSPAN%3E))%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3ESMLOG_I%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%22%E6%9C%AA%E6%93%A6%E9%99%A4%20ObjId%3D0x%3C%2FSPAN%3E%3CSPAN%3E%2508X%3C%2FSPAN%3E%3CSPAN%3E(%E7%89%A9%E8%81%94%E7%BD%91%E4%B8%AD%E6%9E%A2%EF%BC%89%22%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3Eid%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F*%20%E4%B8%8D%E6%9B%B4%E6%96%B0%E7%89%A9%E8%81%94%E7%BD%91%E6%9E%A2%E7%BA%BD%E5%AF%B9%E8%B1%A1%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E5%90%A6%E5%88%99%3C%2FSPAN%3E%20%3CSPAN%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E!%3C%2FSPAN%3E%3CSPAN%3Ese05x_objid_tp_mask%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Eid%3C%2FSPAN%3E%3CSPAN%3E)%20%3C%2FSPAN%3E%3CSPAN%3E%26amp%3B%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%3Eid%3C%2FSPAN%3E%3CSPAN%3E)%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%3ESMLOG_I(%3C%2FSPAN%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%3E%22%20%E4%B8%8D%E6%93%A6%E9%99%A4%E4%BF%A1%E4%BB%BB%E9%85%8D%E7%BD%AE%20%E5%AF%B9%E8%B1%A1%3C%2FSPAN%3E%3CSPAN%3E%20%22)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E5%85%B6%E4%BB%96%3C%2FSPAN%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E7%8A%B6%E6%80%81%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3ESe05x_API_DeleteSecureObject%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%E4%BC%9A%E8%AF%9D_ctx%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3Eid%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3EretStatus%3C%2FSPAN%3E%20%3CSPAN%3E!%3D%3C%2FSPAN%3E%20%3CSPAN%3ESM_OK%3C%2FSPAN%3E%3CSPAN%3E)%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3ESMLOG_I%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%22%E6%93%A6%E9%99%A4%20ObjId%3D0x%20%E6%97%B6%E5%87%BA%E9%94%99%3C%2FSPAN%3E%3CSPAN%3E%2508X%3C%2FSPAN%3E%3CSPAN%3E%E5%85%B6%E4%BB%96%22%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3Eid%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%7D%20%3C%2FSPAN%3E%3CSPAN%3E%E8%80%8C%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Epmore%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3D%3C%2FSPAN%3E%20%3CSPAN%3EkSE05x_MoreIndicator_MORE%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%E9%80%80%E5%87%BA%3C%2FSPAN%3E%3CSPAN%3E%3A%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3E%20%3CSPAN%3EretStatus%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2262497%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050%20Working%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2262497%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BA%B2%E7%88%B1%E7%9A%84%20Kan_Li%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E6%8C%87%E5%AF%BC%E3%80%82%3C%2FP%3E%3CP%3EGetinfo%20demo(GetVersion)%20%E5%9C%A8%E6%88%91%E4%BB%AC%E7%9A%84%E5%B9%B3%E5%8F%B0%E4%B8%8A%E8%BF%90%E8%A1%8C%E8%89%AF%E5%A5%BD%E3%80%82%3C%2FP%3E%3CP%3Escp03%20%E5%AF%86%E9%92%A5%E5%92%8C%20auth%20%E5%AF%86%E9%92%A5%E7%9A%84%E8%AE%BE%E7%BD%AE%E5%A6%82%E4%B8%8B%E6%89%80%E7%A4%BA%EF%BC%8CAPI(GetInfo)%E3%80%82%3C%2FP%3E%3CP%3E%E5%AE%83%EF%BC%88%E6%99%AE%E9%80%9A%E4%BF%A1%E9%81%93%E6%88%96%E5%AE%89%E5%85%A8%E4%BF%A1%E9%81%93%EF%BC%89%E4%B8%8E%E9%97%AE%E9%A2%98%201%E3%80%812%20%E6%9C%89%E5%85%B3%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E3%80%82%20%3C%2FP%3E%3CP%3E%E5%BC%A0%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3Eint%3C%2FSPAN%3E%20%3CSPAN%3Eex_se05x_GetInfo%3C%2FSPAN%3E%3CSPAN%3E()%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3EsmStatus_t%3C%2FSPAN%3E%20%3CSPAN%3E%E7%8A%B6%E6%80%81%3C%2FSPAN%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3ESM_NOT_OK%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3EpSe05xSession_t%3C%2FSPAN%3E%20%3CSPAN%3Ep_session_ctx%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%3Ese05x_session%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3Eint%3C%2FSPAN%3E%20%3CSPAN%3Eret%3C%2FSPAN%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3Euint32_t%3C%2FSPAN%3E%20%3CSPAN%3Emem%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSTRONG%3E%20%20%20%20ex_set_scp03_keys(p_session_ctx)%EF%BC%9B%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%3E%3CSTRONG%3E%20%20%20%20ex_set_ec_auth_keys(p_session_ctx)%EF%BC%9B%3C%2FSTRONG%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3Ep_session_ctx%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3Ese05x_get_session%3C%2FSPAN%3E%3CSPAN%3E()%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Ep_session_ctx%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3D%3C%2FSPAN%3E%20%3CSPAN%3ENULL%3C%2FSPAN%3E%3CSPAN%3E)%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3ESMLOG_E%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%22%E5%9C%A8%20Se05x_API_SessionOpen%20%E4%B8%AD%E5%87%BA%E9%94%99%20%3C%2FSPAN%3E%3CSPAN%3E%5C%E9%94%99%E8%AF%AF%3C%2FSPAN%3E%3CSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%2F*%20%E8%8E%B7%E5%8F%96%E5%B0%8F%E7%A8%8B%E5%BA%8F%E7%89%88%E6%9C%AC%E5%92%8C%E9%85%8D%E7%BD%AE%E8%AF%A6%E6%83%85%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E4%BF%9D%E7%95%99%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3EIot_Applet_Identify%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Ep_session_ctx%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Eret%3C%2FSPAN%3E%20%3CSPAN%3E!%3D%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E)%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3ESMLOG_I%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%22%E5%9C%A8%20Iot_Applet_Identify%20%E4%B8%AD%E5%87%BA%E9%94%99%20%3C%2FSPAN%3E%3CSPAN%3E%5Cn%3C%2FSPAN%3E%3CSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%20%23define%20SE05X_VERSION_HEX_07_02%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3Ep_session_ctx%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3Eapplet_version%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E0x07020000%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E7%8A%B6%E6%80%81%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3ESe05x_API_GetFreeMemory%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Ep_session_ctx%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3EkSE05x_MemoryType_PERSISTENT%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%3E%E5%86%85%E5%AD%98%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Estatus%3C%2FSPAN%3E%20%3CSPAN%3E!%3D%3C%2FSPAN%3E%20%3CSPAN%3ESM_OK%3C%2FSPAN%3E%3CSPAN%3E)%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3ESMLOG_E%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%22Se05x_API_GetFreeMemory%20Failed(0x%3C%2FSPAN%3E%3CSPAN%3E%25x%3C%2FSPAN%3E%3CSPAN%3E)%22%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E%E7%8A%B6%E6%80%81%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E7%8A%B6%E6%80%81%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3EkStatus_SSS_Fail%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%3CSPAN%3E((%3C%2FSPAN%3E%3CSPAN%3Emem%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3D%3C%2FSPAN%3E%20%3CSPAN%3E0x7FFF%3C%2FSPAN%3E%3CSPAN%3E)%20%3C%2FSPAN%3E%3CSPAN%3E%26amp%3B%26amp%3B%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Ep_session_ctx%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E5%B0%8F%E7%A8%8B%E5%BA%8F%E7%89%88%E6%9C%AC%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3D%3C%2FSPAN%3E%20%3CSPAN%3ESE05X_VERSION_HEX_07_02%3C%2FSPAN%3E%3CSPAN%3E))%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%3ESMLOG_I%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%22%20%E5%A6%82%E6%9E%9C%E6%9C%89%2032768%20%E5%AD%97%E8%8A%82%E6%88%96%E6%9B%B4%E5%A4%9A%E5%AD%97%E8%8A%82%E5%8F%AF%E7%94%A8%EF%BC%8C%E5%88%99%E4%BC%9A%E6%8A%A5%E5%91%8A%2032767%20%E5%AD%97%E8%8A%82%E7%9A%84%E7%A9%BA%E9%97%B2%E5%AD%97%E8%8A%82%E3%80%82%3C%2FSPAN%3E%22%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3ESMLOG_I%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%22%E6%8C%81%E4%B9%85%E5%86%85%E5%AD%98%200x%3C%2FSPAN%3E%3CSPAN%3E%2504x%3C%2FSPAN%3E%3CSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E%E5%86%85%E5%AD%98%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E7%8A%B6%E6%80%81%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3ESe05x_API_GetFreeMemory%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Ep_session_ctx%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3EkSE05x_MemoryType_TRANSIENT_RESET%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%3E%E5%86%85%E5%AD%98%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Estatus%3C%2FSPAN%3E%20%3CSPAN%3E!%3D%3C%2FSPAN%3E%20%3CSPAN%3ESM_OK%3C%2FSPAN%3E%3CSPAN%3E)%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3ESMLOG_E%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%22Se05x_API_GetFreeMemory%20Failed(0x%3C%2FSPAN%3E%3CSPAN%3E%25x%3C%2FSPAN%3E%3CSPAN%3E)%22%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E%E7%8A%B6%E6%80%81%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E7%8A%B6%E6%80%81%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3EkStatus_SSS_Fail%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%3CSPAN%3E((%3C%2FSPAN%3E%3CSPAN%3Emem%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3D%3C%2FSPAN%3E%20%3CSPAN%3E0x7FFF%3C%2FSPAN%3E%3CSPAN%3E)%20%3C%2FSPAN%3E%3CSPAN%3E%26amp%3B%26amp%3B%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Ep_session_ctx%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E5%B0%8F%E7%A8%8B%E5%BA%8F%E7%89%88%E6%9C%AC%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3D%3C%2FSPAN%3E%20%3CSPAN%3ESE05X_VERSION_HEX_07_02%3C%2FSPAN%3E%3CSPAN%3E))%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%3ESMLOG_I%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%22%20%E5%A6%82%E6%9E%9C%E6%9C%89%2032768%20%E5%AD%97%E8%8A%82%E6%88%96%E6%9B%B4%E5%A4%9A%E5%AD%97%E8%8A%82%E5%8F%AF%E7%94%A8%EF%BC%8C%E5%88%99%E4%BC%9A%E6%8A%A5%E5%91%8A%2032767%20%E5%AD%97%E8%8A%82%E7%9A%84%E7%A9%BA%E9%97%B2%E5%AD%97%E8%8A%82%E3%80%82%3C%2FSPAN%3E%22%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3ESMLOG_I%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%22%E6%9A%82%E5%AD%98%E5%99%A8%200x%3C%2FSPAN%3E%3CSPAN%3E%2504x%3C%2FSPAN%3E%3CSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E%E5%86%85%E5%AD%98%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E7%8A%B6%E6%80%81%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3ESe05x_API_SessionClose%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Ep_session_ctx%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Estatus%3C%2FSPAN%3E%20%3CSPAN%3E!%3D%3C%2FSPAN%3E%20%3CSPAN%3ESM_OK%3C%2FSPAN%3E%3CSPAN%3E)%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3ESMLOG_I%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%22%E5%9C%A8%20Se05x_API_SessionClose%20%E4%B8%AD%E5%87%BA%E9%94%99%20%3C%2FSPAN%3E%3CSPAN%3E%5Cn%3C%2FSPAN%3E%3CSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2262488%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050%20Working%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2262488%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F232520%22%20target%3D%22_blank%22%3E%40Changhawn%3C%2FA%3E%EF%BC%8C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E4%BF%A1%E6%81%AF%EF%BC%81%E5%9C%A8%E6%82%A8%E7%9A%84%E5%B9%B3%E5%8F%B0%E4%B8%8A%EF%BC%8Cgetinfo%20%E6%BC%94%E7%A4%BA%E8%83%BD%E5%90%A6%E4%BD%BF%E7%94%A8%E8%AF%A5%E9%83%A8%E4%BB%B6%EF%BC%9F%E7%9C%8B%E8%B5%B7%E6%9D%A5%20platformSCP03%20%E5%B7%B2%E8%A2%AB%E5%BC%BA%E5%88%B6%E8%AE%BE%E7%BD%AE%EF%BC%8C%E8%80%8C%E6%8E%A7%E5%88%B6%E5%99%A8%E4%BB%8D%E4%BB%A5%E6%99%AE%E9%80%9A%E4%BF%A1%E9%81%93%E4%B8%8E%20SE%20%E9%80%9A%E4%BF%A1%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%A5%9D%E6%82%A8%E6%84%89%E5%BF%AB%EF%BC%8C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%3CBR%20%2F%3E-%20%E5%A6%82%E6%9E%9C%E6%9C%AC%E5%B8%96%E5%9B%9E%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%22%E6%A0%87%E8%AE%B0%E6%AD%A3%E7%A1%AE%22%20%E6%8C%89%E9%92%AE%E3%80%82%E8%B0%A2%E8%B0%A2%EF%BC%81%3CBR%20%2F%3E-%20%E6%88%91%E4%BB%AC%E4%BC%9A%E5%9C%A8%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E5%8F%91%E5%B8%96%E5%90%8E%E7%9A%84%207%20%E5%91%A8%E5%86%85%E8%B7%9F%E8%B8%AA%E4%B8%BB%E9%A2%98%EF%BC%8C%E4%B9%8B%E5%90%8E%E7%9A%84%E5%9B%9E%E5%A4%8D%E5%B0%86%E8%A2%AB%E5%BF%BD%E7%95%A5%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BB%A5%E5%90%8E%E6%9C%89%E7%9B%B8%E5%85%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E6%89%93%E5%BC%80%E4%B8%80%E4%B8%AA%E6%96%B0%E4%B8%BB%E9%A2%98%E5%B9%B6%E5%8F%82%E8%80%83%E5%B7%B2%E5%85%B3%E9%97%AD%E7%9A%84%E4%B8%BB%E9%A2%98%E3%80%82%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2262480%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050%20Working%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2262480%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BA%B2%E7%88%B1%E7%9A%84%20Kan_Li%3C%2FP%3E%3CP%3E%E9%97%AE%E9%A2%98%203%20%E5%B7%B2%E6%B8%85%E9%99%A4%E3%80%82%E5%9B%A0%E6%AD%A4%E8%B0%83%E8%AF%95%E9%97%AE%E9%A2%98%201%E3%80%812%E3%80%82%3C%2FP%3E%3CP%3E%E4%B8%8B%E9%9D%A2%E7%9A%84%E6%97%A5%E5%BF%97%E6%98%AF%E5%B0%8F%E7%A8%8B%E5%BA%8F%E7%89%88%E6%9C%AC%E5%92%8C%E9%85%8D%E7%BD%AE%E8%AF%A6%E6%83%85%E3%80%82%20%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%E5%BC%A0%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%26lt%3B%20Log%20%26gt%3B%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%5BINF%5D%5Bcli%5D%E6%89%93%E5%BC%80%E4%BC%9A%E8%AF%9D%E8%87%B3%20SE05x%3C%2FP%3E%3CP%3E%5BINF%5D%20%5Bcli%5D%20Plug%20and%20Trust%20nano%20%E8%BD%AF%E4%BB%B6%E5%8C%85-%E7%89%88%E6%9C%AC%EF%BC%9A1.5.4%3C%2FP%3E%3CP%3E%5BINF%5D%5Bcli%5D%20Applet%20Major%20%3D%207%3C%2FP%3E%3CP%3E%5BINF%5D%5Bcli%5D%20Applet%20Minor%20%3D%202%3C%2FP%3E%3CP%3E%5BINF%5D%5Bcli%5D%E5%B0%8F%E7%A8%8B%E5%BA%8F%E8%A1%A5%E4%B8%81%20%3D%200%3C%2FP%3E%3CP%3E%5BINF%5D%5Bcli%5D%20AppletConfig%20%3D%203F9F%3C%2FP%3E%3CP%3E%5BINF%5D%5Bcli%5D%20%E4%BD%BF%E7%94%A8%20ECDSA_ECDH_ECDHE%3CBR%20%2F%3E%5BINF%5D%5Bcli%5D%3C%2FP%3E%3CP%3E%5BINF%5D%5Bcli%5D%20%E4%BD%BF%E7%94%A8%20EDDSA%3CBR%20%2F%3E%5BINF%5D%5Bcli%5D%3C%2FP%3E%3CP%3E%5BINF%5D%5Bcli%5D%20%E4%BD%BF%E7%94%A8%20DH_MONT%3CBR%20%2F%3E%5BINF%5D%5Bcli%5D%3C%2FP%3E%3CP%3E%5BINF%5D%5Bcli%5D%20%E4%BD%BF%E7%94%A8%20HMAC%3CBR%20%2F%3E%5BINF%5D%5Bcli%5D%3C%2FP%3E%3CP%3E%5BINF%5D%5Bcli%5D%20WithOut%20RSA_PLAIN%3CBR%20%2F%3E%5BINF%5D%5Bcli%5D%3C%2FP%3E%3CP%3E%5BINF%5D%5Bcli%5D%20WithOut%20RSA_CRT%3CBR%20%2F%3E%5BINF%5D%5Bcli%5D%3C%2FP%3E%3CP%3E%5BINF%5D%5Bcli%5D%20%E4%BD%BF%E7%94%A8%20AES%3CBR%20%2F%3E%5BINF%5D%5Bcli%5D%3C%2FP%3E%3CP%3E%5BINF%5D%5Bcli%5D%E4%BD%BF%E7%94%A8%20DES%3CBR%20%2F%3E%5BINF%5D%5Bcli%5D%3C%2FP%3E%3CP%3E%5BINF%5D%5Bcli%5D%20%E4%BD%BF%E7%94%A8%20PBKDF%3CBR%20%2F%3E%5BINF%5D%5Bcli%5D%3C%2FP%3E%3CP%3E%5BINF%5D%5Bcli%5D%20%E4%BD%BF%E7%94%A8%20TLS%3CBR%20%2F%3E%5BINF%5D%5Bcli%5D%3C%2FP%3E%3CP%3E%5BINF%5D%5Bcli%5D%20%E4%BD%BF%E7%94%A8%20MIFARE%3CBR%20%2F%3E%5BINF%5D%5Bcli%5D%3C%2FP%3E%3CP%3E%5BINF%5D%5Bcli%5D%E4%BD%BF%E7%94%A8%20I2CM%3CBR%20%2F%3E%5BINF%5D%5Bcli%5D%3C%2FP%3E%3CP%3E%5BERR%5D%5Bcli%5D%20Se05x_API_GetFreeMemory%20Failed(0x6a80)%3CBR%20%2F%3E%5BINF%5D%5Bcli%5D%20Persistent%20Memory%200x0000%3CBR%20%2F%3E%5BERR%5D%5Bcli%5D%20Se05x_API_GetFreeMemory%20Failed(0x6a80)%3CBR%20%2F%3E%5BINF%5D%5Bcli%5D%20Transient%20Memory%200x0000%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2262252%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050%20Working%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2262252%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BA%B2%E7%88%B1%E7%9A%84%20Kan_Li%3C%2FP%3E%3CP%3E%E6%98%AF%E7%9A%84%E3%80%82%E5%B9%B3%E5%8F%B0%E6%98%AF%E8%BF%99%E6%A0%B7%E7%9A%84%EF%BC%88S32K314(FreeRTOS%2BLWIP%2BMbedTLS%2BHSE)%20%2B%20SE050%EF%BC%89%EF%BC%8C%E4%BD%BF%E7%94%A8%20OM-SE050ARD-E%E3%80%82%20%3C%2FP%3E%3CP%3E%E5%9C%A8%E5%9F%BA%E4%BA%8E%20MCU%20%E7%9A%84%E5%B9%B3%E5%8F%B0%E4%B8%8A%EF%BC%8C%E6%88%91%E6%AD%A3%E5%9C%A8%E6%B5%8B%E8%AF%95%20TLS1.3%E3%80%82(%E6%8F%A1%E6%89%8B%E6%9C%89%E6%97%B6%E4%B9%9F%E5%8F%AF%E4%BB%A5%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3ESE050%EF%BC%9AECC%E3%80%81ECDH%E3%80%81ECDSA%E3%80%81HKDF%26amp%3B%20%E5%AF%86%E9%92%A5%E7%AE%A1%E7%90%86%20%3C%2FSPAN%3E%3C!--%20%20%20notionvc%3A%20a06778dc-39c0-403f-bbd1-7a85249b1c6f%20%20%20--%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3ES32K314%20HSE%EF%BC%9AAES%E3%80%81CMAC%E3%80%81HMAC%E3%80%81AES%20GCM(AEAD)%26amp%3B%20%E5%AF%86%E9%92%A5%E7%AE%A1%E7%90%86%3C%2FSPAN%3E%3C!--%20%20%20notionvc%3A%20aa0039cb-e664-406d-8dc6-b33d8a6029e7%20%20%20--%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%E5%85%B3%E4%BA%8E%E9%97%AE%E9%A2%98%E3%80%81%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E1.%20%E5%86%85%E5%AD%98%E7%9B%B8%E5%85%B3%E9%97%AE%E9%A2%98%EF%BC%9A%E9%97%AE%E9%A2%98%E5%8F%91%E7%94%9F%E5%9C%A8%E5%AF%86%E9%92%A5%E7%94%9F%E6%88%90%E8%BF%87%E7%A8%8B%E4%B8%AD%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E2.Se05x_API_GetFreeMemory()%20%3A%20%E7%94%A8%E4%BA%8E%E8%B0%83%E8%AF%95%E9%97%AE%E9%A2%98%201%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E3.%E6%9C%89%E6%97%B6%EF%BC%8C%E5%9C%A8%20MCU%20RESET%20%E5%90%8E%EF%BC%8CSE050%20%E4%BC%9A%E4%BD%9C%E4%B8%BA%E5%A4%B1%E8%B4%A5%E8%BF%94%E5%9B%9E%EF%BC%88I2C%20%E4%BB%B2%E8%A3%81%E4%B8%A2%E5%A4%B1%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%E5%BC%A0%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2262226%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050%20Working%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2262226%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F232520%22%20target%3D%22_blank%22%3E%40Changhawn%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%E6%8F%90%E4%BE%9B%E6%9C%89%E5%85%B3%E8%AF%A5%E5%B9%B3%E5%8F%B0%E5%92%8C%20SE050%20%E6%9D%BF%E7%9A%84%E6%9B%B4%E5%A4%9A%E8%AF%A6%E7%BB%86%E4%BF%A1%E6%81%AF%EF%BC%9F%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20OM-SE050ARD-E%EF%BC%9F%E6%82%A8%E7%9A%84%20plarform%20%E6%98%AF%E5%9F%BA%E4%BA%8E%20MCU%20%E7%9A%84%E5%B9%B3%E5%8F%B0%E5%90%97%EF%BC%9F%E6%82%A8%E7%9A%84%E6%B5%8B%E8%AF%95%E4%B8%AD%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E5%93%AA%E4%B8%80%E7%A7%8D%20SE050%20%E5%8F%98%E4%BD%93%EF%BC%9F%E8%AF%B7%E4%BA%88%E4%BB%A5%E6%BE%84%E6%B8%85%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%A5%9D%E6%82%A8%E6%84%89%E5%BF%AB%EF%BC%8C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%3CBR%20%2F%3E-%20%E5%A6%82%E6%9E%9C%E6%9C%AC%E5%B8%96%E5%9B%9E%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%22%E6%A0%87%E8%AE%B0%E6%AD%A3%E7%A1%AE%22%20%E6%8C%89%E9%92%AE%E3%80%82%E8%B0%A2%E8%B0%A2%EF%BC%81%3CBR%20%2F%3E-%20%E6%88%91%E4%BB%AC%E4%BC%9A%E5%9C%A8%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E5%8F%91%E5%B8%96%E5%90%8E%E7%9A%84%207%20%E5%91%A8%E5%86%85%E8%B7%9F%E8%B8%AA%E4%B8%BB%E9%A2%98%EF%BC%8C%E4%B9%8B%E5%90%8E%E7%9A%84%E5%9B%9E%E5%A4%8D%E5%B0%86%E8%A2%AB%E5%BF%BD%E7%95%A5%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BB%A5%E5%90%8E%E6%9C%89%E7%9B%B8%E5%85%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E6%89%93%E5%BC%80%E4%B8%80%E4%B8%AA%E6%96%B0%E4%B8%BB%E9%A2%98%E5%B9%B6%E5%8F%82%E8%80%83%E5%B7%B2%E5%85%B3%E9%97%AD%E7%9A%84%E4%B8%BB%E9%A2%98%E3%80%82%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2264350%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050%20Working%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2264350%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F232520%22%20target%3D%22_blank%22%3E%40Changhawn%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E5%8F%AA%E6%9C%89%E5%9C%A8%22%3CSPAN%3EWITH_PLATFORM_SCP03%22%20%E4%B8%94%20enc_key%20%E5%92%8C%20mac_key%20%E6%AD%A3%E7%A1%AE%E7%9A%84%E6%83%85%E5%86%B5%20%3C%2FSPAN%3E%E4%B8%8B%E6%89%8D%E6%9C%89%E6%88%90%E5%8A%9F%E7%BB%93%E6%9E%9C%EF%BC%8C%E5%88%99%E8%A1%A8%E7%A4%BA%E5%B7%B2%E5%BC%BA%E5%88%B6%E5%90%AF%E7%94%A8%20platformSCP03%20%E3%80%82%20%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3E%E7%94%B1%E4%BA%8E%E6%B2%A1%E6%9C%89%20APDU%20%E6%97%A5%E5%BF%97%EF%BC%8C%E6%88%91%E6%97%A0%E6%B3%95%E5%AF%B9%20log1%20%E8%BF%9B%E8%A1%8C%E6%B3%A8%E9%87%8A%EF%BC%8C%E6%9C%89%E5%8F%AF%E8%83%BD%E6%89%93%E5%BC%80%E8%B0%83%E8%AF%95%E4%BF%A1%E6%81%AF%E6%89%93%E5%8D%B0%E5%90%97%EF%BC%9F%20%20%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E8%80%90%E5%BF%83%E7%AD%89%E5%BE%85%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%A5%9D%E6%82%A8%E6%84%89%E5%BF%AB%EF%BC%8C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%3CBR%20%2F%3E-%20%E5%A6%82%E6%9E%9C%E6%9C%AC%E5%B8%96%E5%9B%9E%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%22%E6%A0%87%E8%AE%B0%E6%AD%A3%E7%A1%AE%22%20%E6%8C%89%E9%92%AE%E3%80%82%E8%B0%A2%E8%B0%A2%EF%BC%81%3CBR%20%2F%3E-%20%E6%88%91%E4%BB%AC%E4%BC%9A%E5%9C%A8%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E5%8F%91%E5%B8%96%E5%90%8E%E7%9A%84%207%20%E5%91%A8%E5%86%85%E8%B7%9F%E8%B8%AA%E4%B8%BB%E9%A2%98%EF%BC%8C%E4%B9%8B%E5%90%8E%E7%9A%84%E5%9B%9E%E5%A4%8D%E5%B0%86%E8%A2%AB%E5%BF%BD%E7%95%A5%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BB%A5%E5%90%8E%E6%9C%89%E7%9B%B8%E5%85%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E6%89%93%E5%BC%80%E4%B8%80%E4%B8%AA%E6%96%B0%E4%B8%BB%E9%A2%98%E5%B9%B6%E5%8F%82%E8%80%83%E5%B7%B2%E5%85%B3%E9%97%AD%E7%9A%84%E4%B8%BB%E9%A2%98%E3%80%82%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2264276%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050%20Working%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2264276%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BA%B2%E7%88%B1%E7%9A%84%20Kan_Li%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E6%94%AF%E6%8C%81%E3%80%82%3C%2FP%3E%3CP%3E%E5%85%B3%E4%BA%8E%E6%88%91%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%BF%98%E6%9C%89%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%22%3CSPAN%3EWITH_PLATFORM_SCP03%22%20%E5%92%8C%E6%AD%A3%E7%A1%AE%E7%9A%84%20enc_key%20%E5%92%8C%20mac_key%20%3C%2FSPAN%3E%E3%80%81%20%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%88%91%E5%8F%AF%E4%BB%A5%E7%A1%AE%E8%AE%A4%E5%86%85%E5%AD%98%E7%8A%B6%E6%80%81%E5%92%8C%E5%88%A0%E9%99%A4%E5%AF%B9%E8%B1%A1%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%AE%83%EF%BC%88%E4%BD%8E%E4%BA%8E%E5%AF%B9%E6%95%B0%202%EF%BC%89%E6%AD%A3%E5%B8%B8%E5%90%97%EF%BC%9F%2C%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E5%BD%93%E8%BF%90%E8%A1%8C%20TLS%201.3%20Handshake%EF%BC%88%E5%86%99%E5%AF%86%E9%92%A5%EF%BC%89%E6%97%B6%EF%BC%8C%22SM_ERR_SECURITY_STATUS%22%20%E8%BF%94%E5%9B%9E%EF%BC%8C%E5%A6%82%E6%97%A5%E5%BF%97%201%E3%80%82%20%20%E8%AF%B7%E9%97%AE%E9%97%AE%E9%A2%98%E5%87%BA%E5%9C%A8%E5%93%AA%E9%87%8C%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%B0%A2%E8%B0%A2%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%BC%A0%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSTRONG%3E%3CSPAN%3E%26lt%3B%20log%201%20%26gt%3B%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%5BINF%5D%5Bdevtask%5D%20ECDH%20%E4%BD%BF%E7%94%A8%20SE050%20%E8%AE%A1%E7%AE%97%E5%85%B1%E4%BA%AB%E5%AF%86%E6%96%87%3CBR%20%2F%3E%5BSE_APDU%5D%20Se05x_API_GetECCurveId%20is%20ok%20keyid(0xef0000ec)%20retObjectType(49)%20curveid(5)%20transientType(2)%3CBR%20%2F%3E%5BSE_APDU%5D%20sss_se05x_key_store_set_ecc_public_key%20KeyId(0xef000371)%20keybitlen(521)%E3%80%81keyLen(133)%20ciphertype(40)%3CBR%20%2F%3E%5BSE_APDU%5D%20sss_se05x_key_store_set_ecc_public_key%20curve_id%205%2C%20key_part%2032%3CBR%20%2F%3E%5BSE_APDU%5D%3CSTRONG%3EWriteECKey_Ver%20Failed(0x6982)%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3ESM_ERR_SECURITY_STATUS%20%3D%200x6982%2C%2F%2F%E7%BD%91%E7%BB%9C%E5%AE%89%E5%85%A8%E7%8A%B6%E6%80%81%E4%B8%8D%E6%BB%A1%E6%84%8F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSTRONG%3E%26lt%3B%20log%202%20%26gt%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%2F*%20SE050%20%E7%9A%84%E5%86%85%E5%AD%98%E7%8A%B6%E6%80%81%20*%2F%3CBR%20%2F%3Eshow%20mem...%3CBR%20%2F%3E%5BINF%5D%5Bcli%5D%20%E6%89%93%E5%BC%80%E4%BC%9A%E8%AF%9D%E8%87%B3%20SE05x%3C%2FP%3E%3CP%3E%5BINF%5D%20%5Bcli%5D%20Plug%20and%20Trust%20nano%20%E8%BD%AF%E4%BB%B6%E5%8C%85-%E7%89%88%E6%9C%AC%EF%BC%9A1.5.4%3C%2FP%3E%3CP%3E%5BINF%5D%5Bcli%5D%E5%BB%BA%E7%AB%8B%E5%88%B0%20SE05x%20%E7%9A%84%E5%AE%89%E5%85%A8%E9%80%9A%E9%81%93%EF%BC%81%3C%2FP%3E%3CP%3E%5BINF%5D%5Bcli%5D%E5%88%9B%E5%BB%BA%E4%BA%86%20scp03%20%E4%BC%9A%E8%AF%9D%3C%2FP%3E%3CP%3E%5BINF%5D%20%5Bcli%5D%20%E5%A6%82%E6%9E%9C%E6%9C%89%2032768%20%E5%AD%97%E8%8A%82%E6%88%96%E6%9B%B4%E5%A4%9A%E5%AD%97%E8%8A%82%E5%8F%AF%E7%94%A8%EF%BC%8C%E5%88%99%E4%BC%9A%E6%8A%A5%E5%91%8A%2032767%20%E5%AD%97%E8%8A%82%E7%9A%84%E7%A9%BA%E9%97%B2%E5%AD%97%E8%8A%82%E3%80%82%3CBR%20%2F%3E%5BINF%5D%5Bcli%5D%20Persistent%20Memory%200x7fff%3CBR%20%2F%3E%5BINF%5D%5Bcli%5D%20Transient%20Memory%200x02bc%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%2F*%20%E8%BF%90%E8%A1%8C%20Se05x_API_DeleteAll_Iterative%20API%20*%2F%3CBR%20%2F%3EDelete%20Object...%3CBR%20%2F%3E%5BINF%5D%5Bcli%5D%20Open%20Session%20to%20SE05x%3C%2FP%3E%3CP%3E%5BINF%5D%20%5Bcli%5D%20Plug%20and%20Trust%20nano%20%E8%BD%AF%E4%BB%B6%E5%8C%85-%E7%89%88%E6%9C%AC%EF%BC%9A1.5.4%3C%2FP%3E%3CP%3E%5BINF%5D%5Bcli%5D%E5%BB%BA%E7%AB%8B%E5%88%B0%20SE05x%20%E7%9A%84%E5%AE%89%E5%85%A8%E9%80%9A%E9%81%93%EF%BC%81%3C%2FP%3E%3CP%3E%5BINF%5D%5Bcli%5D%E5%88%9B%E5%BB%BA%E4%BA%86%20scp03%20%E4%BC%9A%E8%AF%9D%3C%2FP%3E%3CP%3E%5BINF%5D%20%5Bcli%5D%20%E4%B8%8D%E6%93%A6%E9%99%A4%20objid%3D0xf0000103%EF%BC%88%E7%89%A9%E8%81%94%E7%BD%91%E4%B8%AD%E5%BF%83%EF%BC%89%5BINF%5D%20%5Bcli%5D%20%E4%B8%8D%E6%93%A6%E9%99%A4%20objid%3D0xf0000101%EF%BC%88%E7%89%A9%E8%81%94%E7%BD%91%E4%B8%AD%E5%BF%83%EF%BC%89%3CBR%20%2F%3E%5BINF%5D%20%5Bcli%5D%20%E4%B8%8D%E6%93%A6%E9%99%A4%20objid%3D0xf0000102%EF%BC%88%E7%89%A9%E8%81%94%E7%BD%91%E4%B8%AD%E5%BF%83%EF%BC%89%5BINF%5D%20%5Bcli%5D%20%E4%B8%8D%E6%93%A6%E9%99%A4%20objid%3D0xf0000100%EF%BC%88%E7%89%A9%E8%81%94%E7%BD%91%E4%B8%AD%E5%BF%83%EF%BC%89%3CBR%20%2F%3E%5BINF%5D%20%5Bcli%5D%20%E6%B2%A1%E6%9C%89%E6%93%A6%E9%99%A4%20objid%3D0xf0000003%EF%BC%88%E7%89%A9%E8%81%94%E7%BD%91%E4%B8%AD%E5%BF%83%EF%BC%89%5BINF%5D%20%5Bcli%5D%20%E4%B8%8D%E6%93%A6%E9%99%A4%20objid%3D0xf000000001%EF%BC%88%E7%89%A9%E8%81%94%E7%BD%91%E4%B8%AD%E5%BF%83%EF%BC%89%3CBR%20%2F%3E%5BINF%5D%20%5Bcli%5D%20%E4%B8%8D%E6%93%A6%E9%99%A4%20objid%3D0xf0000002%EF%BC%88%E7%89%A9%E8%81%94%E7%BD%91%E4%B8%AD%E5%BF%83%EF%BC%89%5BINF%5D%20%5Bcli%5D%20%E4%B8%8D%E6%93%A6%E9%99%A4%20objid%3D0xf0000000%EF%BC%88%E7%89%A9%E8%81%94%E7%BD%91%E4%B8%AD%E5%BF%83%EF%BC%89%3CBR%20%2F%3E%5BINF%5D%20%5Bcli%5D%20%E4%B8%8D%E6%93%A6%E9%99%A4%20objid%3D0xf0000000%EF%BC%88%E7%89%A9%E8%81%94%E7%BD%91%E4%B8%AD%E5%BF%83%EF%BC%89%5BINF%5D%20%5Bcli%5D%20%E4%B8%8D%E6%93%A6%E9%99%A4%20objid%3D0xf0000000%EF%BC%88%E7%89%A9%E8%81%94%E7%BD%91%E4%B8%AD%E5%BF%83%EF%BC%89%3CBR%20%2F%3E%5BINF%5D%20%5Bcli%5D%20%E4%B8%8D%E6%93%A6%E9%99%A4%20objid%3D0xf0000000%EF%BC%88%E7%89%A9%E8%81%94%E7%BD%91%E4%B8%AD%E5%BF%83%EF%BC%89%5B%3D0xf0000013%EF%BC%88%E7%89%A9%E8%81%94%E7%BD%91%E4%B8%AD%E5%BF%83%EF%BC%89%5BINF%5D%20%5Bcli%5D%20%E4%B8%8D%E6%93%A6%E9%99%A4%20objid%3D0xf0000012%EF%BC%88%E7%89%A9%E8%81%94%E7%BD%91%E4%B8%AD%E5%BF%83%EF%BC%89%3CBR%20%2F%3E%5BINF%5D%20%5Bcli%5D%20%E4%B8%8D%E6%98%AF%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%E6%93%A6%E9%99%A4%20objid%3D0xf0000020%EF%BC%88%E7%89%A9%E8%81%94%E7%BD%91%E4%B8%AD%E5%BF%83%EF%BC%89%3CBR%20%2F%3E%5BINF%5D%20%5Bcli%5D%20%E4%B8%8D%E6%93%A6%E9%99%A4%20objid%3D0xf0003394%EF%BC%88%E7%89%A9%E8%81%94%E7%BD%91%E4%B8%AD%E5%BF%83%EF%BC%89%5BINF%5D%20%5Bcli%5D%20%E4%B8%8D%E6%93%A6%E9%99%A4%20objid%3D0x7ff020B%EF%BC%88%E4%BF%9D%E7%95%99%EF%BC%89%5BINF%5D%20%5Bcli%5D%20%E4%B8%8D%E6%93%A6%E9%99%A4%20objid%3D0x7ff0204%EF%BC%88%E4%BF%9D%E7%95%99%EF%BC%89%3CBR%20%2F%3E%5BINF%5D%20%5Bcli%5D%20%E6%9C%AA%E6%93%A6%E9%99%A4%20objid%3D0x7ff0202%EF%BC%88%E5%B7%B2%E4%BF%9D%E7%95%99%EF%BC%89%5BINF%5D%20%5Bcli%5D%20%E4%B8%8D%E6%93%A6%E9%99%A4%20objid%3D0x7ff0201%EF%BC%88%E5%B7%B2%E4%BF%9D%E7%95%99%EF%BC%89%3CBR%20%2F%3E%5BINF%5D%20%5Bcli%5D%20%E6%9C%AA%E6%93%A6%E9%99%A4%20objid%3D0x7fff0206%EF%BC%88%E5%B7%B2%E4%BF%9D%E7%95%99%EF%BC%89SE050%20%E9%87%8D%E7%BD%AE%E6%88%90%E5%8A%9F%EF%BC%81%EF%BC%81%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%24%3C%2FP%3E%3C%2FLINGO-BODY%3E
