SE050 AEAD Decryption
Changhawn
Dear
In S32K314 Platform, developing TLS1.3 with using SE050E.
During the TLS1.3 handshake, need the AEAD(AES GCM) description(message authentication).
When AEADOneShot command (AES GCM calculation) Se05x_API_AeadOneShot() is executed.
I2C Access is failed in SE050.  I don't know the reason.
I2C was working fine in another case.
Could you check what's problem?
Thank you.
Chang
< LOG >
$ app info
[INF][cli] Open Session to SE05x
[INF][cli] Plug and Trust nano package - version: 1.5.4
[INF][cli] Applet Major = 7
[INF][cli] Applet Minor = 2
[INF][cli] Applet patch = 0
[INF][cli] AppletConfig = 3F9F
[INF][cli] With    ECDSA_ECDH_ECDHE
[INF][cli]
[INF][cli] With    EDDSA
[INF][cli]
[INF][cli] With    DH_MONT
[INF][cli]
[INF][cli] With    HMAC
[INF][cli]
[INF][cli] WithOut RSA_PLAIN
[INF][cli]
[INF][cli] WithOut RSA_CRT
[INF][cli]
[INF][cli] With    AES
[INF][cli]
[INF][cli] With    DES
[INF][cli]
[INF][cli] With    PBKDF
[INF][cli]
[INF][cli] With    TLS
[INF][cli]
[INF][cli] With    MIFARE
[INF][cli]
[INF][cli] With    I2CM
[INF][cli]
$ app info aead
[SE_APDU] Write SymmKey keyid(0xef0002de)
[23007 ms] APDU TX len=zu:
                          80 03 11 37 00 00 48
  41 04 EF 00 02 DE
  42 01 B0
  43 10 48 45 4C 4C 4F 48 45 4C 4C 4F 48 45 4C 4C 4F 31
  44 19 45 78 74 72 61 20 61 75 74 68 65 6E 74 69 63 61 74 69 6F 6E 20 64 61 74 61
  45 10 00 00 00 00 00 00 00 00 FD 15 71 99 32 D3 56 90
  00 00
           [23063 ms] Transceive data ptr 0x0x20412c6c len:81
[23071 ms] phNxpEseProto7816_SendIframe len:86
[23079 ms] phNxpEseProto7816_SendRawFrame len:86
[23087 ms] phNxpEse_WriteFrame len:86
[23093 ms] phPalEse_i2c_write len:86
[23412 ms] phNxpEseProto7816_sendRframe len:5
[23418 ms] phNxpEseProto7816_SendRawFrame len:5
[23426 ms] phNxpEse_WriteFrame len:5
[23432 ms] phPalEse_i2c_write len:5
axI2CWrite Failed(0x9)
[23645 ms] Se05x_API_AeadOneShot failed 0
< Code >
void ex_sss_aead_decrypt(void)
    sss_status_t status = kStatus_SSS_Success;
    sss_algorithm_t algorithm;
    sss_mode_t mode;
    /* clang-format off */
    uint8_t aead_srcData[16] = { 0x48 ,0x45 ,0x4c ,0x4c ,0x4f ,0x48 ,0x45 ,0x4c ,0x4c ,0x4f ,0x48 ,0x45 ,0x4c ,0x4c ,0x4f ,0x31 }; /*HELLOHELLOHELLO1*/
    uint8_t aead_keystring[KEY_BIT_LEN / 8] = { 0x48 ,0x45 ,0x4c ,0x4c ,0x4f ,0x48 ,0x45 ,0x4c ,0x4c ,0x4f ,0x48 ,0x45 ,0x4c ,0x4c ,0x4f ,0x31 }; /*HELLOHELLOHELLO1*/
    uint8_t destData[16] = {0,};
    size_t destDataLen = sizeof(destData);
    uint8_t aead_iv[16] = {0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xfd, 0x15, 0x71, 0x99, 0x32, 0xd3, 0x56, 0x90};
    size_t ivlen = 16;
    uint32_t keyId = MAKE_TEST_ID(__LINE__);
    sss_key_part_t keyPart;
    sss_cipher_type_t cipherType;
    size_t keyByteLenMax = KEY_BIT_LEN/8;
    sss_object_t key = { 0 };
    sss_se05x_aead_t ctx_aead_encrypt = { 0 };
    size_t TAG_SIZE = 16;
    uint8_t tag[TAG_SIZE];
    uint8_t  *aad =(uint8_t*)"Extra authentication data";
    size_t aadSize = strlen((char*)aad);
    pSe05xSession_t p_session_ctx = &se05x_session;
    SE05x_CipherMode_t cipherMode = kSE05x_CipherMode_AES_GCM;
    SE05x_Cipher_Oper_OneShot_t OperType = kSE05x_Cipher_Oper_OneShot_Encrypt; // : kSE05x_Cipher_Oper_OneShot_Decrypt;
    algorithm =  kAlgorithm_SSS_AES_GCM;
    keyPart    = kSSS_KeyPart_Default;
    cipherType = kSSS_CipherType_AES;
    mode       = kMode_SSS_Encrypt;
    p_session_ctx = se05x_get_session();
    key.session = p_session_ctx;
    if (key.session == NULL)
        __printf("SESSION open failed\r\n");
        return;
     status = sss_key_object_allocate_handle(&key, keyId, keyPart, cipherType, keyByteLenMax, kKeyObject_Mode_Persistent);
    if (status != true)
        __printf("sss_key_object_allocate_handle failed %x\r\n", status);
        return;
     status = sss_se05x_key_store_set_key(&key, aead_keystring, sizeof(aead_keystring), sizeof(aead_keystring) * 8);
    if (status != kStatus_SSS_Success)
        __printf("sss_se05x_key_store_set_key failed 0x%x\r\n", status);
        return;
    //status = sss_aead_context_init(&ctx_aead_encrypt, &pCtx->session, &key, algorithm, mode);
    ctx_aead_encrypt.keyObject = &key;
    ctx_aead_encrypt.algorithm = algorithm;
    ctx_aead_encrypt.mode = mode;
    aeadoneshotlog = true;
    status = Se05x_API_AeadOneShot(p_session_ctx, keyId, cipherMode, aead_srcData,
            destDataLen, aad, aadSize, aead_iv, ivlen, tag, &TAG_SIZE, destData, &destDataLen, OperType);
    aeadoneshotlog = false;
        sm_dbg_printf("Se05x_API_AeadOneShot failed %x\r\n", status);
        return;
    __printf("Encryption successful !!!");
cleanup:
    return;
Kan_Li
Hi @Changhawn ,
per APDU spec for AEADOneShot command:
When the AEADMode equals AES_GCM, the length of AAD + length of data should
be limited to 888 bytes - the total C-APDU buffer length. Did you meet this requirement?
Kan
jesssaid
I need to develop the A1006 chip. If you have done it before, please contact me. Thank you very much!
Kan_Li
Hi @Changhawn ,
Is it possible to turn on the debug log printing? Are you building the application based on zephyr? If yes, please set the following configurations in prj.conf file.
CONFIG_LOG=y
CONFIG_PLUGANDTRUST_LOG_LEVEL_DBG=y
CONFIG_LOG_MODE_IMMEDIATE=y
Kan
Changhawn
Dear Kan_Li
My paltform is NXP S32K314.
Log print has a lot of delay, which prevents i2c access from working properly in the first place.
I used the Plug-and-Trust Nano version, so it doesn't have a prj.conf file.
I don't know if i2c access fails in AEAD Deription.
Could you please tell me some other debugging points?
Thank you.
Chang
Kan_Li
Hi @Changhawn ,
The AEAD operation takes longer than AES CCM, but the I2C would keep polling the SE until there is a response. you may build the application with -DPLUGANDTRUST_DEBUG_LOGS=ON to have more debug info.
Kan
Changhawn
Dear Kan_Li
The i2c issue was somewhat resolved by fixing the i2c access issue. However, the AEAD Decryption still has issues. Please check the code and logs to determine what the issue is.
#define KEY_BIT_LEN 256
smStatus_t Se05x_API_AeadOneShot(pSe05xSession_t session_ctx,
uint32_t objectID,
SE05x_CipherMode_t cipherMode,
const uint8_t *pInputData,
size_t inputDataLen,
const uint8_t *pAad,
size_t aadLen,
uint8_t *pIV,
size_t IVLen,
uint8_t *pTagData,
size_t *pTagDataLen,
uint8_t *pOutputData,
size_t *pOutputDataLen,
const SE05x_Cipher_Oper_OneShot_t operation)
smStatus_t retStatus = SM_NOT_OK;
tlvHeader_t hdr = {{kSE05x_CLA, kSE05x_INS_CRYPTO, kSE05x_P1_AEAD, operation}};
size_t cmdbufLen = 0;
uint8_t *pCmdbuf = NULL;
int tlvRet = 0;
uint8_t *pRspbuf = NULL;
size_t rspbufLen = MAX_APDU_BUFFER;
SE05x_Result_t result;
uint16_t ivlen16 = 0;
size_t ivlen32 = IVLen;
size_t rspIndex = 0;
pCmdbuf = &session_ctx->apdu_buffer[0];
pRspbuf = &session_ctx->apdu_buffer[0];
if (IVLen > UINT16_MAX) {
goto cleanup;
ivlen16 = (uint16_t)IVLen;
tlvRet = TLVSET_U32("objectID", &pCmdbuf, &cmdbufLen, kSE05x_TAG_1, objectID);
if (0 != tlvRet) {
goto cleanup;
tlvRet = TLVSET_CipherMode("cipherMode",
&pCmdbuf,
&cmdbufLen,
kSE05x_TAG_2,
((cipherMode == kSE05x_CipherMode_AES_GCM_INT_IV) ? kSE05x_CipherMode_AES_GCM : cipherMode));
if (0 != tlvRet) {
goto cleanup;
tlvRet = TLVSET_u8bufOptional("inputData", &pCmdbuf, &cmdbufLen, kSE05x_TAG_3, pInputData, inputDataLen);
if (0 != tlvRet) {
goto cleanup;
tlvRet = TLVSET_u8bufOptional("AdditionalData", &pCmdbuf, &cmdbufLen, kSE05x_TAG_4, pAad, aadLen);
if (0 != tlvRet) {
goto cleanup;
if ((cipherMode == kSE05x_CipherMode_AES_GCM) ||
((cipherMode == kSE05x_CipherMode_AES_GCM_INT_IV) && (operation == kSE05x_Cipher_Oper_OneShot_Decrypt))) {
tlvRet = TLVSET_u8bufOptional("IV", &pCmdbuf, &cmdbufLen, kSE05x_TAG_5, pIV, IVLen);
if (0 != tlvRet) {
goto cleanup;
else {
tlvRet = TLVSET_U16("IVLen", &pCmdbuf, &cmdbufLen, kSE05x_TAG_5, ivlen16);
if (0 != tlvRet) {
goto cleanup;
if (operation == kSE05x_Cipher_Oper_OneShot_Decrypt) {
if (pTagDataLen != NULL) {
//__printf("%s tgaDataLen is selected\r\n", __func__);
//if (pTagDataLen > 0 ) {
tlvRet = TLVSET_u8bufOptional("tag", &pCmdbuf, &cmdbufLen, kSE05x_TAG_6, pTagData, *pTagDataLen);
if (0 != tlvRet) {
goto cleanup;
#if 0
uint8_t *temp = session_ctx->apdu_buffer;
__printf("APDU TX len=%zu:\n", cmdbufLen);
for (size_t i=0;i<cmdbufLen;i++) __printf("%02X ", temp[i]);
__printf("\n");
#endif
//retStatus = DoAPDUTxRx_s_Case4_ext(session_ctx, &hdr, session_ctx->apdu_buffer, cmdbufLen, pRspbuf, &rspbufLen);
retStatus = DoAPDUTxRx(session_ctx, &hdr, session_ctx->apdu_buffer, cmdbufLen, session_ctx->apdu_buffer, &rspbufLen, 1);
if (retStatus == SM_OK) {
__printf("%s SE050 AEAD Decrypt Ok...\r\n", __func__);
__printf("APDU RSP len=%d:\n", rspbufLen);
for (size_t i=0 ; i < rspbufLen ; i++) __printf("%02X ", pRspbuf[i]);
__printf("\n");
if (inputDataLen != 0) {
tlvRet = tlvGet_u8buf(pRspbuf, &rspIndex, rspbufLen, kSE05x_TAG_1, pOutputData, pOutputDataLen);
__printf("AEAD Decrypt RSP tag1=%d:\n", tlvRet);
if (0 != tlvRet) {
goto cleanup;
if (operation == kSE05x_Cipher_Oper_OneShot_Encrypt) {
tlvRet = tlvGet_u8buf(pRspbuf, &rspIndex, rspbufLen, kSE05x_TAG_2, pTagData, pTagDataLen);
__printf("AEAD Decrypt RSP tag2=%d:\n", tlvRet);
if (0 != tlvRet) {
goto cleanup;
tlvRet = tlvGet_Result(pRspbuf, &rspIndex, rspbufLen, kSE05x_TAG_2, &result);
if (0 != tlvRet) {
__printf("AEAD Decrypt RSP tlvRet=%d:\n", tlvRet);
goto cleanup;
if (result != kSE05x_Result_SUCCESS) {
__printf("APDU Decrypt RSP result=%d:\n", result);
goto cleanup;
if ((operation == kSE05x_Cipher_Oper_OneShot_Encrypt) && (cipherMode == kSE05x_CipherMode_AES_GCM_INT_IV)) {
tlvRet = tlvGet_u8buf(pRspbuf, &rspIndex, rspbufLen, kSE05x_TAG_3, pIV, &ivlen32);
if (0 != tlvRet) {
goto cleanup;
if ((rspIndex + 2) == rspbufLen) {
retStatus = (smStatus_t)((pRspbuf[rspIndex] << | (pRspbuf[rspIndex + 1]));
cleanup:
return retStatus;
sss_mode_t mode;
#ifdef ADED_DECRYPT_TEST
uint8_t aead_srcData[16] = { 0x8f, 0xd9, 0x64, 0xc, 0xa9, 0x95, 0xf1, 0x98, 0x86, 0xcf, 0xd6, 0xe9, 0xde, 0xd0, 0x37, 0x1f };
uint8_t aead_keystring[KEY_BIT_LEN / 8] = { 0xad, 0x4f , 0x6f , 0xaa , 0x5c , 0x67 , 0xf8 , 0x94 , 0xdc , 0x50 , 0xdd , 0x3e ,
0xf2 , 0x82 , 0xe3 , 0xf9 , 0x65 , 0x34 , 0xf8 , 0x0f , 0xdc , 0x46 , 0x65 , 0x1b , 0xb5 , 0x9a , 0x01 , 0x69 , 0xce , 0xfb , 0xa8 , 0xec};
#else
#endif
uint8_t aead_iv[12] = {0x55, 0x6a , 0xe5 , 0xa9 , 0x17 , 0xce , 0xa , 0xd , 0x27 , 0x3f , 0x9f , 0xaa};
size_t ivlen = 12;
#else
size_t ivlen = 16;
#endif
uint8_t tag[16] = {0x99 , 0xc5 , 0x3 , 0xaa , 0x7c , 0x6d ,
0x37 , 0x52 , 0x64 , 0x6e , 0x62 , 0x47 , 0xe0 , 0x3a , 0x80 , 0xc8};
uint8_t aad[5] = {0x17, 0x3, 0x3, 0x0, 0x20};
//uint8_t *aad =(uint8_t*)"Extra authentication data";
#else
#endif
//uint8_t *aad = NULL;
//size_t aadSize = 0;
SE05x_Cipher_Oper_OneShot_t OperType = kSE05x_Cipher_Oper_OneShot_Decrypt;
#else
#endif
mode = kMode_SSS_Decrypt;
#else
#endif
/* doc:start ex_sss_symmetric-allocate-key */
/* Pre-requisite for encryption Part*/
//status = Se05x_API_SessionOpen(p_session_ctx);
return;
//status = sss_key_object_allocate_handle(&key, keyId, keyPart, cipherType, keyByteLenMax, kKeyObject_Mode_Persistent);
if (status != true)
return;
//status = sss_key_store_set_key(&pCtx->ks, &key, keystring, sizeof(keystring), sizeof(keystring) * 8, NULL, 0);
return;
/*Do Encryption*/
#if 1
//aeadoneshotlog = false;
if (status != SM_OK)
return;
/* doc:end ex_sss_aead-encrypt */
__printf("AEAD En/Decryption successful !!!");
#else /* AEAD Multistep */
status = se05x_gcm_encrypt_multistep(p_session_ctx,
keyId, aead_srcData, destDataLen,
aad, aadSize, aead_iv, ivlen, destData, &destDataLen,
tag, &TAG_SIZE, OperType);
sm_dbg_printf("se05x_gcm_encrypt_multistep failed %x\r\n", status);
return;
#endif
cleanup:
return;
< LOG >
[SE_APDU] Update SymmKey keyid(0xef0003d1)
Se05x_API_AeadOneShot SE050 AEAD Decrypt Ok...
APDU RSP len=7:
42 82 00 01 02 90 00
AEAD Decrypt RSP tag1=1:
[409452 ms] Se05x_API_AeadOneShot failed ffff
Kan_Li
Hi @Changhawn ,
It should be due to the authentication tag, please kindly refer to the following for details.
Kan
Changhawn
Dear Kan_Li.
AEAD Oneshot Decryption has been somewhat resolved.
However, for the second AEAD Decrypt cipher frame, with a size of 2256, memory issues prevent oneshot decryption.
Attempting to use a multi-step (init, update, final) approach results in excessive performance degradation.
Do you have any other solution? or recommandation?
Thank you.
< log >
mbedtls_cipher_aead_decrypt Cipher ctx(20427300) Mode 6, tag_len 16, ilen(16)
[INF][devtask] Cipher Aead OneGo Start:0x20427320 size:16 Cipher Mode:0xb0, OP Type:0x38
[INF][devtask] Key ID: 0xef00050e
[INF][devtask] aadLen: 5:
17 3 3 0 20
[INF][devtask] nonceLen: 12:
44 2 e5 9e 14 f8 bc d2 8f b6 7 b4
[INF][devtask] tagLen: 16:
32 ac 13 ca 2e 31 2a 1c 91 bf ea 79 16 bb b8 b0
[INF][devtask] srcData(ciphertext): 16:
[INF][devtask] dstData(plaintext): 16:
APDU RSP len=27:
41 82 00 10 08 00 00 02 00 00 16 00 00 00 00 00 00 00 00 00 42 82 00 01 01 90 00
AEAD Decrypt RSP tag1=0:
[INF][devtask] 0x9000
../mbedtls/mbedtls/library/ssl_msg.c:1520: => decrypt buf
mbedtls_ssl_decrypt_buf data_len(2256) TAG used(16)::
83 e6 fb 9c 7b 9 d7 6 92 c c5 83 91 a3 81 20
mbedtls_cipher_aead_decrypt Cipher ctx(20427300) Mode 6, tag_len 16, ilen(2256)
[INF][devtask] Cipher Aead OneGo Start:0x20427320 size:2256 Cipher Mode:0xb0, OP Type:0x38
17 3 3 8 e0
44 2 e5 9e 14 f8 bc d2 8f b6 7 b5
[INF][devtask] srcData(ciphertext): 2256:
[INF][devtask] dstData(plaintext): 2256:
[31678 ms] se05x_gcm_decrypt_multistep keyId 0xef00050e, cipherMode 0xb0 cryptoObjectId 26, tagLen 541177908
[49212 ms] se05x_gcm_decrypt_multistep AEAD Update offset(400) (2256)
[65947 ms] se05x_gcm_decrypt_multistep AEAD Update offset(800) (2256)
[82784 ms] se05x_gcm_decrypt_multistep AEAD Update offset(1200) (2256)
[99558 ms] se05x_gcm_decrypt_multistep AEAD Update offset(1600) (2256)
[116379 ms] se05x_gcm_decrypt_multistep AEAD Update offset(2000) (2256)
[127157 ms] se05x_gcm_decrypt_multistep AEAD Update offset(2256) (2256)
[ERR][devtask] Not enough buffer
Changhawn
Dear Kan_Li.
If  increase the APDU unit size as 2400 and test with Oneshot instead of Multistep AEAD Decrypt, as before, the SE050 chip responds with the following log:
SM_ERR_WRONG_LENGTH (0x6700)
Could you please also check this.
Thank you.
Chang
< 로그 >
mbedtls_ssl_decrypt_buf data_len(16) TAG used(16)::
14 b0 cf 4b 29 2c c2 a0 1c 83 d9 e9 92 47 65 f1
mbedtls_cipher_aead_decrypt Cipher ctx(20428900) Mode 6, tag_len 16, ilen(16)
[INF][devtask] Cipher Aead OneGo Start:0x20428920 size:16 Cipher Mode:0xb0, OP Type:0x38
 17 3 3 0 20
 a2 3c 82 54 67 a9 29 d2 aa 69 99 ef
[26093 ms] APDU TX len=75 :
[26099 ms] Transceive data ptr 0x0x204133cc len:75
APDU RSP len=27:
../mbedtls/mbedtls/library/ssl_msg.c:2139: <= decrypt buf
../mbedtls/mbedtls/library/ssl_msg.c:4289: <= read record
../mbedtls/mbedtls/library/ssl_tls13_client.c:2306: <= parse encrypted extensions
../mbedtls/mbedtls/library/ssl_msg.c:2333: in_left: 5, nb_want: 2277
40 62 d7 27 8 70 88 f6 83 3b a5 93 44 bc 59 71
mbedtls_cipher_aead_decrypt Cipher ctx(20428900) Mode 6, tag_len 16, ilen(2256)
[INF][devtask] Cipher Aead OneGo Start:0x20428920 size:2256 Cipher Mode:0xb0, OP Type:0x38
 17 3 3 8 e0
 a2 3c 82 54 67 a9 29 d2 aa 69 99 ee
[28667 ms] APDU TX len=2317 :
[28676 ms] Transceive data ptr 0x0x204133cc len:2317
Se05x_API_AeadOneShot SE050 AEAD Decrypt Failed(0x6700)
[INF][devtask]  0x6700
Kan_Li
Hi @Changhawn ,
Kan
Changhawn
Dear Kan_Li.
By below SE050 specification, Oneshot input length is limited 256.
So I have developed with Multistep(AEADInit, AEADUpdate, AEADFinal). But still have problem.
That's low performance. It takes 95 secs. Could you recommand about this low performance.
Thank you.
Chang.
e8 c0 f9 3 a1 a6 87 9d e9 e3 91 fe 59 7a 45 62
17 3 3 8 e0
7b 5e 1b 41 9d 19 b2 b8 94 62 c2 2e
[27711 ms] APDU TX len=4 :
[27749 ms] se05x_gcm_decrypt_multistep keyId 0xef00050e, cipherMode 0xb0 cryptoObjectId 26, ctLen 2256, tagLen 16
[27814 ms] se05x_gcm_decrypt_multistep aadLen 5
[27852 ms] se05x_gcm_decrypt_multistep offset 0, ctLen 2256
[27864 ms] APDU TX len=497 :
[48615 ms] se05x_gcm_decrypt_multistep AEAD Update offset(480) (2256)
[48630 ms] APDU TX len=497 :
[68749 ms] se05x_gcm_decrypt_multistep AEAD Update offset(960) (2256)
[68764 ms] APDU TX len=497 :
[88833 ms] se05x_gcm_decrypt_multistep AEAD Update offset(1440) (2256)
[88848 ms] APDU TX len=497 :
[108979 ms] se05x_gcm_decrypt_multistep AEAD Update offset(1920) (2256)
[108994 ms] APDU TX len=353 :
[123113 ms] se05x_gcm_decrypt_multistep AEAD Update offset(2256) (2256)
[123128 ms] APDU TX len=31 :
Changhawn
AEAD Oneshot is debugging multistep with tag2 max length problem.
%3CLINGO-SUB%20id%3D%22lingo-sub-2228917%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ESE050%20AEAD%20Decryption%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2228917%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3EDear%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EIn%20S32K314%20Platform%2C%20developing%20TLS1.3%20with%20using%20SE050E.%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EDuring%20the%20TLS1.3%20handshake%2C%20need%20the%20AEAD(AES%20GCM)%20description(message%20authentication).%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EWhen%20AEADOneShot%20command%20(AES%20GCM%20calculation)%20Se05x_API_AeadOneShot()%20is%20executed.%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EI2C%20Access%20is%20failed%20in%20SE050.%26nbsp%3B%20I%20don't%20know%20the%20reason.%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EI2C%20was%20working%20fine%20in%20another%20case.%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3ECould%20you%20check%20what's%20problem%3F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EThank%20you.%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EChang%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26lt%3B%20LOG%20%26gt%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%24%20app%20info%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%20Open%20Session%20to%20SE05x%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%20Plug%20and%20Trust%20nano%20package%20-%20version%3A%201.5.4%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%20Applet%20Major%20%3D%207%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%20Applet%20Minor%20%3D%202%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%20Applet%20patch%20%3D%200%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%20AppletConfig%20%3D%203F9F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%20With%26nbsp%3B%20%26nbsp%3B%20ECDSA_ECDH_ECDHE%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%20With%26nbsp%3B%20%26nbsp%3B%20EDDSA%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%20With%26nbsp%3B%20%26nbsp%3B%20DH_MONT%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%20With%26nbsp%3B%20%26nbsp%3B%20HMAC%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%20WithOut%20RSA_PLAIN%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%20WithOut%20RSA_CRT%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%20With%26nbsp%3B%20%26nbsp%3B%20AES%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%20With%26nbsp%3B%20%26nbsp%3B%20DES%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%20With%26nbsp%3B%20%26nbsp%3B%20PBKDF%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%20With%26nbsp%3B%20%26nbsp%3B%20TLS%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%20With%26nbsp%3B%20%26nbsp%3B%20MIFARE%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%20With%26nbsp%3B%20%26nbsp%3B%20I2CM%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%24%3C%2FDIV%3E%3CDIV%3E%24%3C%2FDIV%3E%3CDIV%3E%24%20app%20info%20aead%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%20Open%20Session%20to%20SE05x%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%20Plug%20and%20Trust%20nano%20package%20-%20version%3A%201.5.4%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%5BSE_APDU%5D%20Write%20SymmKey%20keyid(0xef0002de)%3C%2FDIV%3E%3CDIV%3E%5B23007%20ms%5D%20APDU%20TX%20len%3Dzu%3A%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%2080%2003%2011%2037%2000%2000%2048%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%2041%2004%20EF%2000%2002%20DE%26nbsp%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%2042%2001%20B0%26nbsp%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%2043%2010%2048%2045%204C%204C%204F%2048%2045%204C%204C%204F%2048%2045%204C%204C%204F%2031%26nbsp%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%2044%2019%2045%2078%2074%2072%2061%2020%2061%2075%2074%2068%2065%206E%2074%2069%2063%2061%2074%2069%206F%206E%2020%2064%2061%2074%2061%26nbsp%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%2045%2010%2000%2000%2000%2000%2000%2000%2000%2000%20FD%2015%2071%2099%2032%20D3%2056%2090%26nbsp%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%2000%2000%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%5B23063%20ms%5D%20Transceive%20data%20ptr%200x0x20412c6c%20len%3A81%3C%2FDIV%3E%3CDIV%3E%5B23071%20ms%5D%20phNxpEseProto7816_SendIframe%20len%3A86%3C%2FDIV%3E%3CDIV%3E%5B23079%20ms%5D%20phNxpEseProto7816_SendRawFrame%20len%3A86%3C%2FDIV%3E%3CDIV%3E%5B23087%20ms%5D%20phNxpEse_WriteFrame%20len%3A86%3C%2FDIV%3E%3CDIV%3E%5B23093%20ms%5D%20phPalEse_i2c_write%20len%3A86%3C%2FDIV%3E%3CDIV%3E%5B23412%20ms%5D%20phNxpEseProto7816_sendRframe%20len%3A5%3C%2FDIV%3E%3CDIV%3E%5B23418%20ms%5D%20phNxpEseProto7816_SendRawFrame%20len%3A5%3C%2FDIV%3E%3CDIV%3E%5B23426%20ms%5D%20phNxpEse_WriteFrame%20len%3A5%3C%2FDIV%3E%3CDIV%3E%3CSTRONG%3E%5B23432%20ms%5D%20phPalEse_i2c_write%20len%3A5%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%3E%3CSTRONG%3EaxI2CWrite%20Failed(0x9)%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%3E%5B23645%20ms%5D%20Se05x_API_AeadOneShot%20failed%200%3C%2FDIV%3E%3CDIV%3E%24%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26lt%3B%20Code%20%26gt%3B%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Evoid%20ex_sss_aead_decrypt(void)%3C%2FDIV%3E%3CDIV%3E%7B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20sss_status_t%20status%20%3D%20kStatus_SSS_Success%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20sss_algorithm_t%20algorithm%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20sss_mode_t%20mode%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%2F*%20clang-format%20off%20*%2F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20uint8_t%20aead_srcData%5B16%5D%20%3D%20%7B%200x48%20%2C0x45%20%2C0x4c%20%2C0x4c%20%2C0x4f%20%2C0x48%20%2C0x45%20%2C0x4c%20%2C0x4c%20%2C0x4f%20%2C0x48%20%2C0x45%20%2C0x4c%20%2C0x4c%20%2C0x4f%20%2C0x31%20%7D%3B%20%2F*HELLOHELLOHELLO1*%2F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20uint8_t%20aead_keystring%5BKEY_BIT_LEN%20%2F%208%5D%20%3D%20%7B%200x48%20%2C0x45%20%2C0x4c%20%2C0x4c%20%2C0x4f%20%2C0x48%20%2C0x45%20%2C0x4c%20%2C0x4c%20%2C0x4f%20%2C0x48%20%2C0x45%20%2C0x4c%20%2C0x4c%20%2C0x4f%20%2C0x31%20%7D%3B%20%2F*HELLOHELLOHELLO1*%2F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20uint8_t%20destData%5B16%5D%20%3D%20%7B0%2C%7D%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20size_t%20destDataLen%20%3D%20sizeof(destData)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20uint8_t%20aead_iv%5B16%5D%20%3D%20%7B0x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200xfd%2C%200x15%2C%200x71%2C%200x99%2C%200x32%2C%200xd3%2C%200x56%2C%200x90%7D%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20size_t%20ivlen%20%3D%2016%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20uint32_t%20keyId%20%3D%20MAKE_TEST_ID(__LINE__)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20sss_key_part_t%20keyPart%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20sss_cipher_type_t%20cipherType%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20size_t%20keyByteLenMax%20%3D%20KEY_BIT_LEN%2F8%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20sss_object_t%20key%20%3D%20%7B%200%20%7D%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20sss_se05x_aead_t%20ctx_aead_encrypt%20%3D%20%7B%200%20%7D%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20size_t%20TAG_SIZE%20%3D%2016%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20uint8_t%20tag%5BTAG_SIZE%5D%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20uint8_t%26nbsp%3B%20*aad%20%3D(uint8_t*)%22Extra%20authentication%20data%22%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20size_t%20aadSize%20%3D%20strlen((char*)aad)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20pSe05xSession_t%20p_session_ctx%20%3D%20%26amp%3Bse05x_session%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20SE05x_CipherMode_t%20cipherMode%20%3D%20kSE05x_CipherMode_AES_GCM%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20SE05x_Cipher_Oper_OneShot_t%20OperType%20%3D%20kSE05x_Cipher_Oper_OneShot_Encrypt%3B%20%2F%2F%20%3A%20kSE05x_Cipher_Oper_OneShot_Decrypt%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20algorithm%20%3D%26nbsp%3B%20kAlgorithm_SSS_AES_GCM%3B%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20keyPart%26nbsp%3B%20%26nbsp%3B%20%3D%20kSSS_KeyPart_Default%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20cipherType%20%3D%20kSSS_CipherType_AES%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20mode%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%3D%20kMode_SSS_Encrypt%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20p_session_ctx%20%3D%20se05x_get_session()%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20key.session%20%3D%20p_session_ctx%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20if%20(key.session%20%3D%3D%20NULL)%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%7B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20__printf(%22SESSION%20open%20failed%5Cr%5Cn%22)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20return%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bstatus%20%3D%20sss_key_object_allocate_handle(%26amp%3Bkey%2C%20keyId%2C%20keyPart%2C%20cipherType%2C%20keyByteLenMax%2C%20kKeyObject_Mode_Persistent)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20if%20(status%20!%3D%20true)%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%7B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20__printf(%22sss_key_object_allocate_handle%20failed%20%25x%5Cr%5Cn%22%2C%20status)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20return%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bstatus%20%3D%20sss_se05x_key_store_set_key(%26amp%3Bkey%2C%20aead_keystring%2C%20sizeof(aead_keystring)%2C%20sizeof(aead_keystring)%20*%208)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20if%20(status%20!%3D%20kStatus_SSS_Success)%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%7B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20__printf(%22sss_se05x_key_store_set_key%20failed%200x%25x%5Cr%5Cn%22%2C%20status)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20return%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%2F%2Fstatus%20%3D%20sss_aead_context_init(%26amp%3Bctx_aead_encrypt%2C%20%26amp%3BpCtx-%26gt%3Bsession%2C%20%26amp%3Bkey%2C%20algorithm%2C%20mode)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20ctx_aead_encrypt.keyObject%20%3D%20%26amp%3Bkey%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20ctx_aead_encrypt.algorithm%20%3D%20algorithm%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20ctx_aead_encrypt.mode%20%3D%20mode%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20aeadoneshotlog%20%3D%20true%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20status%20%3D%20Se05x_API_AeadOneShot(p_session_ctx%2C%20keyId%2C%20cipherMode%2C%20aead_srcData%2C%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20destDataLen%2C%20aad%2C%20aadSize%2C%20aead_iv%2C%20ivlen%2C%20tag%2C%20%26amp%3BTAG_SIZE%2C%20destData%2C%20%26amp%3BdestDataLen%2C%20OperType)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20aeadoneshotlog%20%3D%20false%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20if%20(status%20!%3D%20kStatus_SSS_Success)%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%7B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20sm_dbg_printf(%22Se05x_API_AeadOneShot%20failed%20%25x%5Cr%5Cn%22%2C%20status)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20return%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20__printf(%22Encryption%20successful%20!!!%22)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Ecleanup%3A%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20return%3B%3C%2FDIV%3E%3CDIV%3E%7D%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2246661%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050%20AEAD%20Decryption%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2246661%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F232520%22%20target%3D%22_blank%22%3E%40Changhawn%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EThe%20AEAD%20operation%20takes%20longer%20than%20AES%20CCM%2C%20but%20the%20I2C%20would%20keep%20polling%20the%20SE%20until%20there%20is%20a%20response.%20you%20may%20build%20the%20application%20with%26nbsp%3B%3CSPAN%20data-teams%3D%22true%22%3E-DPLUGANDTRUST_DEBUG_LOGS%3DON%20to%20have%20more%20debug%20info.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EHave%20a%20great%20day%2C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3ENote%3A%3CBR%20%2F%3E-%20If%20this%20post%20answers%20your%20question%2C%20please%20click%20the%20%22Mark%20Correct%22%20button.%20Thank%20you!%3CBR%20%2F%3E-%20We%20are%20following%20threads%20for%207%20weeks%20after%20the%20last%20post%2C%20later%20replies%20are%20ignored%3CBR%20%2F%3EPlease%20open%20a%20new%20thread%20and%20refer%20to%20the%20closed%20one%2C%20if%20you%20have%20a%20related%20question%20at%20a%20later%20point%20in%20time.%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2246260%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050%20AEAD%20Decryption%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2246260%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDear%20Kan_Li%3C%2FP%3E%3CP%3EMy%20paltform%20is%20NXP%20S32K314.%26nbsp%3B%3C%2FP%3E%3CP%3ELog%20print%20has%20a%20lot%20of%20delay%2C%20which%20prevents%20i2c%20access%20from%20working%20properly%20in%20the%20first%20place.%3C%2FP%3E%3CP%3EI%20used%20the%20Plug-and-Trust%20Nano%20version%2C%20so%20it%20doesn't%20have%20a%20prj.conf%20file.%3C%2FP%3E%3CP%3EI%20don't%20know%20if%20i2c%20access%20fails%20in%20AEAD%20Deription.%3C%2FP%3E%3CP%3ECould%20you%20please%20tell%20me%20some%20other%20debugging%20points%3F%3C%2FP%3E%3CP%3EThank%20you.%26nbsp%3B%3C%2FP%3E%3CP%3EChang%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2232153%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050%20AEAD%20Decryption%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2232153%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F232520%22%20target%3D%22_blank%22%3E%40Changhawn%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EIs%20it%20possible%20to%20turn%20on%20the%20debug%20log%20printing%3F%20Are%20you%20building%20the%20application%20based%20on%20zephyr%3F%20If%20yes%2C%20please%20set%20the%20following%20configurations%20in%20prj.conf%20file.%3C%2FP%3E%0A%3CP%3ECONFIG_LOG%3Dy%3CBR%20%2F%3ECONFIG_PLUGANDTRUST_LOG_LEVEL_DBG%3Dy%3CBR%20%2F%3ECONFIG_LOG_MODE_IMMEDIATE%3Dy%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EHave%20a%20great%20day%2C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3ENote%3A%3CBR%20%2F%3E-%20If%20this%20post%20answers%20your%20question%2C%20please%20click%20the%20%22Mark%20Correct%22%20button.%20Thank%20you!%3CBR%20%2F%3E-%20We%20are%20following%20threads%20for%207%20weeks%20after%20the%20last%20post%2C%20later%20replies%20are%20ignored%3CBR%20%2F%3EPlease%20open%20a%20new%20thread%20and%20refer%20to%20the%20closed%20one%2C%20if%20you%20have%20a%20related%20question%20at%20a%20later%20point%20in%20time.%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2249857%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050%20AEAD%20Decryption%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2249857%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDear%20Kan_Li%3C%2FP%3E%3CP%3EThe%20i2c%20issue%20was%20somewhat%20resolved%20by%20fixing%20the%20i2c%20access%20issue.%20However%2C%20the%20AEAD%20Decryption%20still%20has%20issues.%20Please%20check%20the%20code%20and%20logs%20to%20determine%20what%20the%20issue%20is.%3C%2FP%3E%3CP%3E%23define%20KEY_BIT_LEN%20256%3C%2FP%3E%3CP%3EsmStatus_t%20Se05x_API_AeadOneShot(pSe05xSession_t%20session_ctx%2C%3CBR%20%2F%3Euint32_t%20objectID%2C%3CBR%20%2F%3ESE05x_CipherMode_t%20cipherMode%2C%3CBR%20%2F%3Econst%20uint8_t%20*pInputData%2C%3CBR%20%2F%3Esize_t%20inputDataLen%2C%3CBR%20%2F%3Econst%20uint8_t%20*pAad%2C%3CBR%20%2F%3Esize_t%20aadLen%2C%3CBR%20%2F%3Euint8_t%20*pIV%2C%3CBR%20%2F%3Esize_t%20IVLen%2C%3CBR%20%2F%3Euint8_t%20*pTagData%2C%3CBR%20%2F%3Esize_t%20*pTagDataLen%2C%3CBR%20%2F%3Euint8_t%20*pOutputData%2C%3CBR%20%2F%3Esize_t%20*pOutputDataLen%2C%3CBR%20%2F%3Econst%20SE05x_Cipher_Oper_OneShot_t%20operation)%3CBR%20%2F%3E%7B%3CBR%20%2F%3EsmStatus_t%20retStatus%20%3D%20SM_NOT_OK%3B%3CBR%20%2F%3EtlvHeader_t%20hdr%20%3D%20%7B%7BkSE05x_CLA%2C%20kSE05x_INS_CRYPTO%2C%20kSE05x_P1_AEAD%2C%20operation%7D%7D%3B%3CBR%20%2F%3Esize_t%20cmdbufLen%20%3D%200%3B%3CBR%20%2F%3Euint8_t%20*pCmdbuf%20%3D%20NULL%3B%3CBR%20%2F%3Eint%20tlvRet%20%3D%200%3B%3CBR%20%2F%3Euint8_t%20*pRspbuf%20%3D%20NULL%3B%3CBR%20%2F%3Esize_t%20rspbufLen%20%3D%20MAX_APDU_BUFFER%3B%3CBR%20%2F%3ESE05x_Result_t%20result%3B%3CBR%20%2F%3Euint16_t%20ivlen16%20%3D%200%3B%3CBR%20%2F%3Esize_t%20ivlen32%20%3D%20IVLen%3B%3CBR%20%2F%3Esize_t%20rspIndex%20%3D%200%3B%3C%2FP%3E%3CP%3EpCmdbuf%20%3D%20%26amp%3Bsession_ctx-%26gt%3Bapdu_buffer%5B0%5D%3B%3CBR%20%2F%3EpRspbuf%20%3D%20%26amp%3Bsession_ctx-%26gt%3Bapdu_buffer%5B0%5D%3B%3C%2FP%3E%3CP%3Eif%20(IVLen%20%26gt%3B%20UINT16_MAX)%20%7B%3CBR%20%2F%3Egoto%20cleanup%3B%3CBR%20%2F%3E%7D%3CBR%20%2F%3Eivlen16%20%3D%20(uint16_t)IVLen%3B%3CBR%20%2F%3EtlvRet%20%3D%20TLVSET_U32(%22objectID%22%2C%20%26amp%3BpCmdbuf%2C%20%26amp%3BcmdbufLen%2C%20kSE05x_TAG_1%2C%20objectID)%3B%3CBR%20%2F%3Eif%20(0%20!%3D%20tlvRet)%20%7B%3CBR%20%2F%3Egoto%20cleanup%3B%3CBR%20%2F%3E%7D%3C%2FP%3E%3CP%3EtlvRet%20%3D%20TLVSET_CipherMode(%22cipherMode%22%2C%3CBR%20%2F%3E%26amp%3BpCmdbuf%2C%3CBR%20%2F%3E%26amp%3BcmdbufLen%2C%3CBR%20%2F%3EkSE05x_TAG_2%2C%3CBR%20%2F%3E((cipherMode%20%3D%3D%20kSE05x_CipherMode_AES_GCM_INT_IV)%20%3F%20kSE05x_CipherMode_AES_GCM%20%3A%20cipherMode))%3B%3C%2FP%3E%3CP%3Eif%20(0%20!%3D%20tlvRet)%20%7B%3CBR%20%2F%3Egoto%20cleanup%3B%3CBR%20%2F%3E%7D%3CBR%20%2F%3EtlvRet%20%3D%20TLVSET_u8bufOptional(%22inputData%22%2C%20%26amp%3BpCmdbuf%2C%20%26amp%3BcmdbufLen%2C%20kSE05x_TAG_3%2C%20pInputData%2C%20inputDataLen)%3B%3CBR%20%2F%3Eif%20(0%20!%3D%20tlvRet)%20%7B%3CBR%20%2F%3Egoto%20cleanup%3B%3CBR%20%2F%3E%7D%3CBR%20%2F%3EtlvRet%20%3D%20TLVSET_u8bufOptional(%22AdditionalData%22%2C%20%26amp%3BpCmdbuf%2C%20%26amp%3BcmdbufLen%2C%20kSE05x_TAG_4%2C%20pAad%2C%20aadLen)%3B%3CBR%20%2F%3Eif%20(0%20!%3D%20tlvRet)%20%7B%3CBR%20%2F%3Egoto%20cleanup%3B%3CBR%20%2F%3E%7D%3C%2FP%3E%3CP%3Eif%20((cipherMode%20%3D%3D%20kSE05x_CipherMode_AES_GCM)%20%7C%7C%3CBR%20%2F%3E((cipherMode%20%3D%3D%20kSE05x_CipherMode_AES_GCM_INT_IV)%20%26amp%3B%26amp%3B%20(operation%20%3D%3D%20kSE05x_Cipher_Oper_OneShot_Decrypt)))%20%7B%3CBR%20%2F%3EtlvRet%20%3D%20TLVSET_u8bufOptional(%22IV%22%2C%20%26amp%3BpCmdbuf%2C%20%26amp%3BcmdbufLen%2C%20kSE05x_TAG_5%2C%20pIV%2C%20IVLen)%3B%3CBR%20%2F%3Eif%20(0%20!%3D%20tlvRet)%20%7B%3CBR%20%2F%3Egoto%20cleanup%3B%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%7D%3CBR%20%2F%3Eelse%20%7B%3CBR%20%2F%3EtlvRet%20%3D%20TLVSET_U16(%22IVLen%22%2C%20%26amp%3BpCmdbuf%2C%20%26amp%3BcmdbufLen%2C%20kSE05x_TAG_5%2C%20ivlen16)%3B%3CBR%20%2F%3Eif%20(0%20!%3D%20tlvRet)%20%7B%3CBR%20%2F%3Egoto%20cleanup%3B%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%7D%3CBR%20%2F%3Eif%20(operation%20%3D%3D%20kSE05x_Cipher_Oper_OneShot_Decrypt)%20%7B%3CBR%20%2F%3Eif%20(pTagDataLen%20!%3D%20NULL)%20%7B%3CBR%20%2F%3E%2F%2F__printf(%22%25s%20tgaDataLen%20is%20selected%5Cr%5Cn%22%2C%20__func__)%3B%3CBR%20%2F%3E%2F%2Fif%20(pTagDataLen%20%26gt%3B%200%20)%20%7B%3CBR%20%2F%3EtlvRet%20%3D%20TLVSET_u8bufOptional(%22tag%22%2C%20%26amp%3BpCmdbuf%2C%20%26amp%3BcmdbufLen%2C%20kSE05x_TAG_6%2C%20pTagData%2C%20*pTagDataLen)%3B%3CBR%20%2F%3Eif%20(0%20!%3D%20tlvRet)%20%7B%3CBR%20%2F%3Egoto%20cleanup%3B%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%7D%3C%2FP%3E%3CP%3E%23if%200%3CBR%20%2F%3E%7B%3CBR%20%2F%3Euint8_t%20*temp%20%3D%20session_ctx-%26gt%3Bapdu_buffer%3B%3CBR%20%2F%3E__printf(%22APDU%20TX%20len%3D%25zu%3A%5Cn%22%2C%20cmdbufLen)%3B%3CBR%20%2F%3Efor%20(size_t%20i%3D0%3Bi%3CCMDBUFLEN%3E%3C%2FCMDBUFLEN%3E__printf(%22%5Cn%22)%3B%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%23endif%3CBR%20%2F%3E%2F%2FretStatus%20%3D%20DoAPDUTxRx_s_Case4_ext(session_ctx%2C%20%26amp%3Bhdr%2C%20session_ctx-%26gt%3Bapdu_buffer%2C%20cmdbufLen%2C%20pRspbuf%2C%20%26amp%3BrspbufLen)%3B%3CBR%20%2F%3EretStatus%20%3D%20DoAPDUTxRx(session_ctx%2C%20%26amp%3Bhdr%2C%20session_ctx-%26gt%3Bapdu_buffer%2C%20cmdbufLen%2C%20session_ctx-%26gt%3Bapdu_buffer%2C%20%26amp%3BrspbufLen%2C%201)%3B%3CBR%20%2F%3Eif%20(retStatus%20%3D%3D%20SM_OK)%20%7B%3CBR%20%2F%3E__printf(%22%25s%20SE050%20AEAD%20Decrypt%20Ok...%5Cr%5Cn%22%2C%20__func__)%3B%3CBR%20%2F%3E%7B%3CBR%20%2F%3E__printf(%22APDU%20RSP%20len%3D%25d%3A%5Cn%22%2C%20rspbufLen)%3B%3CBR%20%2F%3Efor%20(size_t%20i%3D0%20%3B%20i%20%26lt%3B%20rspbufLen%20%3B%20i%2B%2B)%20__printf(%22%2502X%20%22%2C%20pRspbuf%5Bi%5D)%3B%3CBR%20%2F%3E__printf(%22%5Cn%22)%3B%3CBR%20%2F%3E%7D%3CBR%20%2F%3EretStatus%20%3D%20SM_NOT_OK%3B%3CBR%20%2F%3Eif%20(inputDataLen%20!%3D%200)%20%7B%3CBR%20%2F%3EtlvRet%20%3D%20tlvGet_u8buf(pRspbuf%2C%20%26amp%3BrspIndex%2C%20rspbufLen%2C%20kSE05x_TAG_1%2C%20pOutputData%2C%20pOutputDataLen)%3B%3CBR%20%2F%3E__printf(%22AEAD%20Decrypt%20RSP%20tag1%3D%25d%3A%5Cn%22%2C%20tlvRet)%3B%3CBR%20%2F%3Eif%20(0%20!%3D%20tlvRet)%20%7B%3CBR%20%2F%3Egoto%20cleanup%3B%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%7D%3CBR%20%2F%3Eif%20(operation%20%3D%3D%20kSE05x_Cipher_Oper_OneShot_Encrypt)%20%7B%3CBR%20%2F%3EtlvRet%20%3D%20tlvGet_u8buf(pRspbuf%2C%20%26amp%3BrspIndex%2C%20rspbufLen%2C%20kSE05x_TAG_2%2C%20pTagData%2C%20pTagDataLen)%3B%3CBR%20%2F%3E__printf(%22AEAD%20Decrypt%20RSP%20tag2%3D%25d%3A%5Cn%22%2C%20tlvRet)%3B%3CBR%20%2F%3Eif%20(0%20!%3D%20tlvRet)%20%7B%3CBR%20%2F%3Egoto%20cleanup%3B%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%7D%3CBR%20%2F%3Eif%20(operation%20%3D%3D%20kSE05x_Cipher_Oper_OneShot_Decrypt)%20%7B%3CBR%20%2F%3EtlvRet%20%3D%20tlvGet_Result(pRspbuf%2C%20%26amp%3BrspIndex%2C%20rspbufLen%2C%20kSE05x_TAG_2%2C%20%26amp%3Bresult)%3B%3CBR%20%2F%3Eif%20(0%20!%3D%20tlvRet)%20%7B%3CBR%20%2F%3E__printf(%22AEAD%20Decrypt%20RSP%20tlvRet%3D%25d%3A%5Cn%22%2C%20tlvRet)%3B%3CBR%20%2F%3Egoto%20cleanup%3B%3CBR%20%2F%3E%7D%3CBR%20%2F%3Eif%20(result%20!%3D%20kSE05x_Result_SUCCESS)%20%7B%3CBR%20%2F%3E__printf(%22APDU%20Decrypt%20RSP%20result%3D%25d%3A%5Cn%22%2C%20result)%3B%3CBR%20%2F%3Egoto%20cleanup%3B%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%7D%3CBR%20%2F%3Eif%20((operation%20%3D%3D%20kSE05x_Cipher_Oper_OneShot_Encrypt)%20%26amp%3B%26amp%3B%20(cipherMode%20%3D%3D%20kSE05x_CipherMode_AES_GCM_INT_IV))%20%7B%3CBR%20%2F%3EtlvRet%20%3D%20tlvGet_u8buf(pRspbuf%2C%20%26amp%3BrspIndex%2C%20rspbufLen%2C%20kSE05x_TAG_3%2C%20pIV%2C%20%26amp%3Bivlen32)%3B%3CBR%20%2F%3Eif%20(0%20!%3D%20tlvRet)%20%7B%3CBR%20%2F%3Egoto%20cleanup%3B%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%7D%3CBR%20%2F%3Eif%20((rspIndex%20%2B%202)%20%3D%3D%20rspbufLen)%20%7B%3CBR%20%2F%3EretStatus%20%3D%20(smStatus_t)((pRspbuf%5BrspIndex%5D%20%26lt%3B%26lt%3B%20%3CLI-EMOJI%20id%3D%22lia_smiling-face-with-sunglasses%22%20title%3D%22%3Asmiling_face_with_sunglasses%3A%22%3E%3C%2FLI-EMOJI%3E%20%7C%20(pRspbuf%5BrspIndex%20%2B%201%5D))%3B%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%7D%3CBR%20%2F%3Ecleanup%3A%3CBR%20%2F%3Ereturn%20retStatus%3B%3CBR%20%2F%3E%7D%3C%2FP%3E%3CP%3Evoid%20ex_sss_aead_decrypt(void)%3CBR%20%2F%3E%7B%3CBR%20%2F%3Esss_status_t%20status%20%3D%20kStatus_SSS_Success%3B%3CBR%20%2F%3Esss_algorithm_t%20algorithm%3B%3CBR%20%2F%3Esss_mode_t%20mode%3B%3CBR%20%2F%3E%2F*%20clang-format%20off%20*%2F%3CBR%20%2F%3E%23ifdef%20ADED_DECRYPT_TEST%3CBR%20%2F%3Euint8_t%20aead_srcData%5B16%5D%20%3D%20%7B%200x8f%2C%200xd9%2C%200x64%2C%200xc%2C%200xa9%2C%200x95%2C%200xf1%2C%200x98%2C%200x86%2C%200xcf%2C%200xd6%2C%200xe9%2C%200xde%2C%200xd0%2C%200x37%2C%200x1f%20%7D%3B%3C%2FP%3E%3CP%3Euint8_t%20aead_keystring%5BKEY_BIT_LEN%20%2F%208%5D%20%3D%20%7B%200xad%2C%200x4f%20%2C%200x6f%20%2C%200xaa%20%2C%200x5c%20%2C%200x67%20%2C%200xf8%20%2C%200x94%20%2C%200xdc%20%2C%200x50%20%2C%200xdd%20%2C%200x3e%20%2C%3CBR%20%2F%3E0xf2%20%2C%200x82%20%2C%200xe3%20%2C%200xf9%20%2C%200x65%20%2C%200x34%20%2C%200xf8%20%2C%200x0f%20%2C%200xdc%20%2C%200x46%20%2C%200x65%20%2C%200x1b%20%2C%200xb5%20%2C%200x9a%20%2C%200x01%20%2C%200x69%20%2C%200xce%20%2C%200xfb%20%2C%200xa8%20%2C%200xec%7D%3B%3C%2FP%3E%3CP%3E%23else%3CBR%20%2F%3Euint8_t%20aead_srcData%5B16%5D%20%3D%20%7B%200x48%20%2C0x45%20%2C0x4c%20%2C0x4c%20%2C0x4f%20%2C0x48%20%2C0x45%20%2C0x4c%20%2C0x4c%20%2C0x4f%20%2C0x48%20%2C0x45%20%2C0x4c%20%2C0x4c%20%2C0x4f%20%2C0x31%20%7D%3B%20%2F*HELLOHELLOHELLO1*%2F%3CBR%20%2F%3Euint8_t%20aead_keystring%5BKEY_BIT_LEN%20%2F%208%5D%20%3D%20%7B%200x48%20%2C0x45%20%2C0x4c%20%2C0x4c%20%2C0x4f%20%2C0x48%20%2C0x45%20%2C0x4c%20%2C0x4c%20%2C0x4f%20%2C0x48%20%2C0x45%20%2C0x4c%20%2C0x4c%20%2C0x4f%20%2C0x31%20%7D%3B%20%2F*HELLOHELLOHELLO1*%2F%3CBR%20%2F%3E%23endif%3CBR%20%2F%3Euint8_t%20destData%5B16%5D%20%3D%20%7B0%2C%7D%3B%3CBR%20%2F%3Esize_t%20destDataLen%20%3D%20sizeof(destData)%3B%3C%2FP%3E%3CP%3E%23ifdef%20ADED_DECRYPT_TEST%3CBR%20%2F%3Euint8_t%20aead_iv%5B12%5D%20%3D%20%7B0x55%2C%200x6a%20%2C%200xe5%20%2C%200xa9%20%2C%200x17%20%2C%200xce%20%2C%200xa%20%2C%200xd%20%2C%200x27%20%2C%200x3f%20%2C%200x9f%20%2C%200xaa%7D%3B%3CBR%20%2F%3Esize_t%20ivlen%20%3D%2012%3B%3CBR%20%2F%3E%23else%3CBR%20%2F%3Euint8_t%20aead_iv%5B16%5D%20%3D%20%7B0x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200xfd%2C%200x15%2C%200x71%2C%200x99%2C%200x32%2C%200xd3%2C%200x56%2C%200x90%7D%3B%3C%2FP%3E%3CP%3Esize_t%20ivlen%20%3D%2016%3B%3CBR%20%2F%3E%23endif%3CBR%20%2F%3Euint32_t%20keyId%20%3D%20MAKE_TEST_ID(__LINE__)%3B%3CBR%20%2F%3Esss_key_part_t%20keyPart%3B%3CBR%20%2F%3Esss_cipher_type_t%20cipherType%3B%3CBR%20%2F%3Esize_t%20keyByteLenMax%20%3D%20KEY_BIT_LEN%2F8%3B%3CBR%20%2F%3Esss_object_t%20key%20%3D%20%7B%200%20%7D%3B%3CBR%20%2F%3Esss_se05x_aead_t%20ctx_aead_encrypt%20%3D%20%7B%200%20%7D%3B%3C%2FP%3E%3CP%3E%23ifdef%20ADED_DECRYPT_TEST%3CBR%20%2F%3Esize_t%20TAG_SIZE%20%3D%2016%3B%3CBR%20%2F%3Euint8_t%20tag%5B16%5D%20%3D%20%7B0x99%20%2C%200xc5%20%2C%200x3%20%2C%200xaa%20%2C%200x7c%20%2C%200x6d%20%2C%3CBR%20%2F%3E0x37%20%2C%200x52%20%2C%200x64%20%2C%200x6e%20%2C%200x62%20%2C%200x47%20%2C%200xe0%20%2C%200x3a%20%2C%200x80%20%2C%200xc8%7D%3B%3CBR%20%2F%3Euint8_t%20aad%5B5%5D%20%3D%20%7B0x17%2C%200x3%2C%200x3%2C%200x0%2C%200x20%7D%3B%3CBR%20%2F%3E%2F%2Fuint8_t%20*aad%20%3D(uint8_t*)%22Extra%20authentication%20data%22%3B%3CBR%20%2F%3E%23else%3CBR%20%2F%3Esize_t%20TAG_SIZE%20%3D%2016%3B%3CBR%20%2F%3Euint8_t%20tag%5BTAG_SIZE%5D%3B%3CBR%20%2F%3Euint8_t%20*aad%20%3D(uint8_t*)%22Extra%20authentication%20data%22%3B%3CBR%20%2F%3E%23endif%3CBR%20%2F%3Esize_t%20aadSize%20%3D%20strlen((char*)aad)%3B%3CBR%20%2F%3E%2F%2Fuint8_t%20*aad%20%3D%20NULL%3B%3CBR%20%2F%3E%2F%2Fsize_t%20aadSize%20%3D%200%3B%3C%2FP%3E%3CP%3EpSe05xSession_t%20p_session_ctx%20%3D%20%26amp%3Bse05x_session%3B%3CBR%20%2F%3ESE05x_CipherMode_t%20cipherMode%20%3D%20kSE05x_CipherMode_AES_GCM%3B%3CBR%20%2F%3E%23ifdef%20ADED_DECRYPT_TEST%3CBR%20%2F%3ESE05x_Cipher_Oper_OneShot_t%20OperType%20%3D%20kSE05x_Cipher_Oper_OneShot_Decrypt%3B%3CBR%20%2F%3E%23else%3CBR%20%2F%3ESE05x_Cipher_Oper_OneShot_t%20OperType%20%3D%20kSE05x_Cipher_Oper_OneShot_Encrypt%3B%20%2F%2F%20%3A%20kSE05x_Cipher_Oper_OneShot_Decrypt%3B%3CBR%20%2F%3E%23endif%3CBR%20%2F%3Ealgorithm%20%3D%20kAlgorithm_SSS_AES_GCM%3B%3CBR%20%2F%3EkeyPart%20%3D%20kSSS_KeyPart_Default%3B%3CBR%20%2F%3EcipherType%20%3D%20kSSS_CipherType_AES%3B%3CBR%20%2F%3E%23ifdef%20ADED_DECRYPT_TEST%3CBR%20%2F%3Emode%20%3D%20kMode_SSS_Decrypt%3B%3CBR%20%2F%3E%23else%3CBR%20%2F%3Emode%20%3D%20kMode_SSS_Encrypt%3B%3CBR%20%2F%3E%23endif%3CBR%20%2F%3E%2F*%20doc%3Astart%20ex_sss_symmetric-allocate-key%20*%2F%3CBR%20%2F%3E%2F*%20Pre-requisite%20for%20encryption%20Part*%2F%3C%2FP%3E%3CP%3E%2F%2Fstatus%20%3D%20Se05x_API_SessionOpen(p_session_ctx)%3B%3C%2FP%3E%3CP%3Ep_session_ctx%20%3D%20se05x_get_session()%3B%3CBR%20%2F%3Ekey.session%20%3D%20p_session_ctx%3B%3C%2FP%3E%3CP%3Eif%20(key.session%20%3D%3D%20NULL)%3CBR%20%2F%3E%7B%3CBR%20%2F%3E__printf(%22SESSION%20open%20failed%5Cr%5Cn%22)%3B%3CBR%20%2F%3Ereturn%3B%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%2F%2Fstatus%20%3D%20sss_key_object_allocate_handle(%26amp%3Bkey%2C%20keyId%2C%20keyPart%2C%20cipherType%2C%20keyByteLenMax%2C%20kKeyObject_Mode_Persistent)%3B%3CBR%20%2F%3Estatus%20%3D%20sss_key_object_allocate_handle(%26amp%3Bkey%2C%20keyId%2C%20keyPart%2C%20cipherType%2C%20keyByteLenMax%2C%20kKeyObject_Mode_Persistent)%3B%3CBR%20%2F%3Eif%20(status%20!%3D%20true)%3CBR%20%2F%3E%7B%3CBR%20%2F%3E__printf(%22sss_key_object_allocate_handle%20failed%20%25x%5Cr%5Cn%22%2C%20status)%3B%3CBR%20%2F%3Ereturn%3B%3CBR%20%2F%3E%7D%3C%2FP%3E%3CP%3E%2F%2Fstatus%20%3D%20sss_key_store_set_key(%26amp%3BpCtx-%26gt%3Bks%2C%20%26amp%3Bkey%2C%20keystring%2C%20sizeof(keystring)%2C%20sizeof(keystring)%20*%208%2C%20NULL%2C%200)%3B%3CBR%20%2F%3Estatus%20%3D%20sss_se05x_key_store_set_key(%26amp%3Bkey%2C%20aead_keystring%2C%20sizeof(aead_keystring)%2C%20sizeof(aead_keystring)%20*%208)%3B%3CBR%20%2F%3Eif%20(status%20!%3D%20kStatus_SSS_Success)%3CBR%20%2F%3E%7B%3CBR%20%2F%3E__printf(%22sss_se05x_key_store_set_key%20failed%200x%25x%5Cr%5Cn%22%2C%20status)%3B%3CBR%20%2F%3Ereturn%3B%3CBR%20%2F%3E%7D%3C%2FP%3E%3CP%3E%2F*Do%20Encryption*%2F%3C%2FP%3E%3CP%3E%23if%201%3CBR%20%2F%3Estatus%20%3D%20Se05x_API_AeadOneShot(p_session_ctx%2C%20keyId%2C%20cipherMode%2C%20aead_srcData%2C%3CBR%20%2F%3EdestDataLen%2C%20aad%2C%20aadSize%2C%20aead_iv%2C%20ivlen%2C%20tag%2C%20%26amp%3BTAG_SIZE%2C%20destData%2C%20%26amp%3BdestDataLen%2C%20OperType)%3B%3CBR%20%2F%3E%2F%2Faeadoneshotlog%20%3D%20false%3B%3CBR%20%2F%3Eif%20(status%20!%3D%20SM_OK)%3CBR%20%2F%3E%7B%3CBR%20%2F%3Esm_dbg_printf(%22Se05x_API_AeadOneShot%20failed%20%25x%5Cr%5Cn%22%2C%20status)%3B%3CBR%20%2F%3Ereturn%3B%3CBR%20%2F%3E%7D%3C%2FP%3E%3CP%3E%2F*%20doc%3Aend%20ex_sss_aead-encrypt%20*%2F%3C%2FP%3E%3CP%3E__printf(%22AEAD%20En%2FDecryption%20successful%20!!!%22)%3B%3CBR%20%2F%3E%23else%20%2F*%20AEAD%20Multistep%20*%2F%3CBR%20%2F%3Estatus%20%3D%20se05x_gcm_encrypt_multistep(p_session_ctx%2C%3CBR%20%2F%3EkeyId%2C%20aead_srcData%2C%20destDataLen%2C%3CBR%20%2F%3Eaad%2C%20aadSize%2C%20aead_iv%2C%20ivlen%2C%20destData%2C%20%26amp%3BdestDataLen%2C%3CBR%20%2F%3Etag%2C%20%26amp%3BTAG_SIZE%2C%20OperType)%3B%3C%2FP%3E%3CP%3Eaeadoneshotlog%20%3D%20false%3B%3CBR%20%2F%3Eif%20(status%20!%3D%20SM_OK)%3CBR%20%2F%3E%7B%3CBR%20%2F%3Esm_dbg_printf(%22se05x_gcm_encrypt_multistep%20failed%20%25x%5Cr%5Cn%22%2C%20status)%3B%3CBR%20%2F%3Ereturn%3B%3CBR%20%2F%3E%7D%3C%2FP%3E%3CP%3E%2F*%20doc%3Aend%20ex_sss_aead-encrypt%20*%2F%3C%2FP%3E%3CP%3E__printf(%22Encryption%20successful%20!!!%22)%3B%3C%2FP%3E%3CP%3E%23endif%3C%2FP%3E%3CP%3Ecleanup%3A%3CBR%20%2F%3E%3CBR%20%2F%3Ereturn%3B%3CBR%20%2F%3E%7D%3C%2FP%3E%3CP%3E%26lt%3B%20LOG%20%26gt%3B%3CBR%20%2F%3E%5BINF%5D%5Bcli%5D%20Open%20Session%20to%20SE05x%3C%2FP%3E%3CP%3E%5BINF%5D%5Bcli%5D%20Plug%20and%20Trust%20nano%20package%20-%20version%3A%201.5.4%3C%2FP%3E%3CP%3E%5BSE_APDU%5D%20Update%20SymmKey%20keyid(0xef0003d1)%3CBR%20%2F%3ESe05x_API_AeadOneShot%20SE050%20AEAD%20Decrypt%20Ok...%3CBR%20%2F%3EAPDU%20RSP%20len%3D7%3A%3CBR%20%2F%3E%3CSTRONG%3E42%2082%2000%2001%2002%2090%2000%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3EAEAD%20Decrypt%20RSP%20tag1%3D1%3A%3C%2FSTRONG%3E%3CBR%20%2F%3E%5B409452%20ms%5D%20Se05x_API_AeadOneShot%20failed%20ffff%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2250798%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050%20AEAD%20Decryption%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2250798%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F232520%22%20target%3D%22_blank%22%3E%40Changhawn%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EIt%20should%20be%20due%20to%20the%20authentication%20tag%2C%20please%20kindly%20refer%20to%20the%20following%20for%20details.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Kan_Li_0-1764306364604.png%22%20style%3D%22width%3A%20652px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1764306364604.png%22%20style%3D%22width%3A%20652px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1764306364604.png%22%20style%3D%22width%3A%20652px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1764306364604.png%22%20style%3D%22width%3A%20652px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1764306364604.png%22%20style%3D%22width%3A%20652px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1764306364604.png%22%20style%3D%22width%3A%20652px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1764306364604.png%22%20style%3D%22width%3A%20652px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F367698i66BFBEB7A08DB2A9%2Fimage-dimensions%2F652x327%3Fv%3Dv2%22%20width%3D%22652%22%20height%3D%22327%22%20role%3D%22button%22%20title%3D%22Kan_Li_0-1764306364604.png%22%20alt%3D%22Kan_Li_0-1764306364604.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EKan_Li_0-1764306364604.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EHave%20a%20great%20day%2C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3ENote%3A%3CBR%20%2F%3E-%20If%20this%20post%20answers%20your%20question%2C%20please%20click%20the%20%22Mark%20Correct%22%20button.%20Thank%20you!%3CBR%20%2F%3E-%20We%20are%20following%20threads%20for%207%20weeks%20after%20the%20last%20post%2C%20later%20replies%20are%20ignored%3CBR%20%2F%3EPlease%20open%20a%20new%20thread%20and%20refer%20to%20the%20closed%20one%2C%20if%20you%20have%20a%20related%20question%20at%20a%20later%20point%20in%20time.%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2252720%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050%20AEAD%20Decryption%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2252720%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDear%20Kan_Li.%3C%2FP%3E%3CP%3EIf%26nbsp%3B%20increase%20the%20APDU%20unit%20size%20as%202400%20and%20test%20with%20Oneshot%20instead%20of%20Multistep%20AEAD%20Decrypt%2C%20as%20before%2C%20the%20SE050%20chip%20responds%20with%20the%20following%20log%3A%3C%2FP%3E%3CP%3ESM_ERR_WRONG_LENGTH%20(0x6700)%3C%2FP%3E%3CP%3ECould%20you%20please%20also%20check%20this.%3C%2FP%3E%3CP%3EThank%20you.%3C%2FP%3E%3CP%3EChang%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%26lt%3B%20%EB%A1%9C%EA%B7%B8%20%26gt%3B%3C%2FP%3E%3CP%3E..%2Fmbedtls%2Fmbedtls%2Flibrary%2Fssl_msg.c%3A1520%3A%26nbsp%3B%3D%26gt%3B%26nbsp%3Bdecrypt%26nbsp%3Bbuf%3CBR%20%2F%3Embedtls_ssl_decrypt_buf%26nbsp%3Bdata_len(16)%26nbsp%3BTAG%26nbsp%3Bused(16)%3A%3A%3CBR%20%2F%3E14%26nbsp%3Bb0%26nbsp%3Bcf%26nbsp%3B4b%26nbsp%3B29%26nbsp%3B2c%26nbsp%3Bc2%26nbsp%3Ba0%26nbsp%3B1c%26nbsp%3B83%26nbsp%3Bd9%26nbsp%3Be9%26nbsp%3B92%26nbsp%3B47%26nbsp%3B65%26nbsp%3Bf1%3CBR%20%2F%3Embedtls_cipher_aead_decrypt%26nbsp%3BCipher%26nbsp%3Bctx(20428900)%26nbsp%3BMode%26nbsp%3B6%2C%26nbsp%3Btag_len%26nbsp%3B16%2C%26nbsp%3Bilen(16)%3CBR%20%2F%3E%5BINF%5D%5Bdevtask%5D%26nbsp%3BCipher%26nbsp%3BAead%26nbsp%3BOneGo%26nbsp%3BStart%3A0x20428920%26nbsp%3Bsize%3A16%26nbsp%3BCipher%26nbsp%3BMode%3A0xb0%2C%26nbsp%3BOP%26nbsp%3BType%3A0x38%3CBR%20%2F%3E%5BINF%5D%5Bdevtask%5D%26nbsp%3B%26nbsp%3B%26nbsp%3BKey%26nbsp%3BID%3A%26nbsp%3B0xef00050e%3CBR%20%2F%3E%3CBR%20%2F%3E%5BINF%5D%5Bdevtask%5D%26nbsp%3B%26nbsp%3B%26nbsp%3BaadLen%3A%26nbsp%3B5%3A%3CBR%20%2F%3E%26nbsp%3B17%26nbsp%3B3%26nbsp%3B3%26nbsp%3B0%26nbsp%3B20%3CBR%20%2F%3E%5BINF%5D%5Bdevtask%5D%26nbsp%3B%26nbsp%3B%26nbsp%3BnonceLen%3A%26nbsp%3B12%3A%3CBR%20%2F%3E%26nbsp%3Ba2%26nbsp%3B3c%26nbsp%3B82%26nbsp%3B54%26nbsp%3B67%26nbsp%3Ba9%26nbsp%3B29%26nbsp%3Bd2%26nbsp%3Baa%26nbsp%3B69%26nbsp%3B99%26nbsp%3Bef%3CBR%20%2F%3E%5BINF%5D%5Bdevtask%5D%26nbsp%3B%26nbsp%3B%26nbsp%3BtagLen%3A%26nbsp%3B16%3A%3CBR%20%2F%3E%26nbsp%3B14%26nbsp%3Bb0%26nbsp%3Bcf%26nbsp%3B4b%26nbsp%3B29%26nbsp%3B2c%26nbsp%3Bc2%26nbsp%3Ba0%26nbsp%3B1c%26nbsp%3B83%26nbsp%3Bd9%26nbsp%3Be9%26nbsp%3B92%26nbsp%3B47%26nbsp%3B65%26nbsp%3Bf1%3CBR%20%2F%3E%5BINF%5D%5Bdevtask%5D%26nbsp%3B%26nbsp%3B%26nbsp%3BsrcData(ciphertext)%3A%26nbsp%3B16%3A%3CBR%20%2F%3E%5BINF%5D%5Bdevtask%5D%26nbsp%3B%26nbsp%3B%26nbsp%3BdstData(plaintext)%3A%26nbsp%3B16%3A%3CBR%20%2F%3E%5B26093%26nbsp%3Bms%5D%26nbsp%3BAPDU%26nbsp%3BTX%26nbsp%3Blen%3D75%26nbsp%3B%3A%3CBR%20%2F%3E%5B26099%26nbsp%3Bms%5D%26nbsp%3BTransceive%26nbsp%3Bdata%26nbsp%3Bptr%26nbsp%3B0x0x204133cc%26nbsp%3Blen%3A75%3CBR%20%2F%3ESe05x_API_AeadOneShot%26nbsp%3BSE050%26nbsp%3BAEAD%26nbsp%3BDecrypt%26nbsp%3BOk...%3CBR%20%2F%3EAPDU%26nbsp%3BRSP%26nbsp%3Blen%3D27%3A%3CBR%20%2F%3E41%26nbsp%3B82%26nbsp%3B00%26nbsp%3B10%26nbsp%3B08%26nbsp%3B00%26nbsp%3B00%26nbsp%3B02%26nbsp%3B00%26nbsp%3B00%26nbsp%3B16%26nbsp%3B00%26nbsp%3B00%26nbsp%3B00%26nbsp%3B00%26nbsp%3B00%26nbsp%3B00%26nbsp%3B00%26nbsp%3B00%26nbsp%3B00%26nbsp%3B42%26nbsp%3B82%26nbsp%3B00%26nbsp%3B01%26nbsp%3B01%26nbsp%3B90%26nbsp%3B00%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3BAEAD%26nbsp%3BDecrypt%26nbsp%3BRSP%26nbsp%3Btag1%3D0%3A%3CBR%20%2F%3E%5BINF%5D%5Bdevtask%5D%26nbsp%3B%26nbsp%3B0x9000%3CBR%20%2F%3E%3CBR%20%2F%3E..%2Fmbedtls%2Fmbedtls%2Flibrary%2Fssl_msg.c%3A2139%3A%26nbsp%3B%26lt%3B%3D%26nbsp%3Bdecrypt%26nbsp%3Bbuf%3CBR%20%2F%3E..%2Fmbedtls%2Fmbedtls%2Flibrary%2Fssl_msg.c%3A4289%3A%26nbsp%3B%26lt%3B%3D%26nbsp%3Bread%26nbsp%3Brecord%3CBR%20%2F%3E..%2Fmbedtls%2Fmbedtls%2Flibrary%2Fssl_tls13_client.c%3A2306%3A%26nbsp%3B%26lt%3B%3D%26nbsp%3Bparse%26nbsp%3Bencrypted%26nbsp%3Bextensions%3CBR%20%2F%3E..%2Fmbedtls%2Fmbedtls%2Flibrary%2Fssl_msg.c%3A2333%3A%26nbsp%3Bin_left%3A%26nbsp%3B5%2C%26nbsp%3Bnb_want%3A%26nbsp%3B2277%3CBR%20%2F%3E..%2Fmbedtls%2Fmbedtls%2Flibrary%2Fssl_msg.c%3A1520%3A%26nbsp%3B%3D%26gt%3B%26nbsp%3Bdecrypt%26nbsp%3Bbuf%3CBR%20%2F%3Embedtls_ssl_decrypt_buf%26nbsp%3Bdata_len(2256)%26nbsp%3BTAG%26nbsp%3Bused(16)%3A%3A%3CBR%20%2F%3E40%26nbsp%3B62%26nbsp%3Bd7%26nbsp%3B27%26nbsp%3B8%26nbsp%3B70%26nbsp%3B88%26nbsp%3Bf6%26nbsp%3B83%26nbsp%3B3b%26nbsp%3Ba5%26nbsp%3B93%26nbsp%3B44%26nbsp%3Bbc%26nbsp%3B59%26nbsp%3B71%3CBR%20%2F%3Embedtls_cipher_aead_decrypt%26nbsp%3BCipher%26nbsp%3Bctx(20428900)%26nbsp%3BMode%26nbsp%3B6%2C%26nbsp%3Btag_len%26nbsp%3B16%2C%26nbsp%3Bilen(2256)%3CBR%20%2F%3E%5BINF%5D%5Bdevtask%5D%26nbsp%3BCipher%26nbsp%3BAead%26nbsp%3BOneGo%26nbsp%3BStart%3A0x20428920%26nbsp%3Bsize%3A2256%26nbsp%3BCipher%26nbsp%3BMode%3A0xb0%2C%26nbsp%3BOP%26nbsp%3BType%3A0x38%3CBR%20%2F%3E%5BINF%5D%5Bdevtask%5D%26nbsp%3B%26nbsp%3B%26nbsp%3BKey%26nbsp%3BID%3A%26nbsp%3B0xef00050e%3CBR%20%2F%3E%3CBR%20%2F%3E%5BINF%5D%5Bdevtask%5D%26nbsp%3B%26nbsp%3B%26nbsp%3BaadLen%3A%26nbsp%3B5%3A%3CBR%20%2F%3E%26nbsp%3B17%26nbsp%3B3%26nbsp%3B3%26nbsp%3B8%26nbsp%3Be0%3CBR%20%2F%3E%5BINF%5D%5Bdevtask%5D%26nbsp%3B%26nbsp%3B%26nbsp%3BnonceLen%3A%26nbsp%3B12%3A%3CBR%20%2F%3E%26nbsp%3Ba2%26nbsp%3B3c%26nbsp%3B82%26nbsp%3B54%26nbsp%3B67%26nbsp%3Ba9%26nbsp%3B29%26nbsp%3Bd2%26nbsp%3Baa%26nbsp%3B69%26nbsp%3B99%26nbsp%3Bee%3CBR%20%2F%3E%5BINF%5D%5Bdevtask%5D%26nbsp%3B%26nbsp%3B%26nbsp%3BtagLen%3A%26nbsp%3B16%3A%3CBR%20%2F%3E%26nbsp%3B40%26nbsp%3B62%26nbsp%3Bd7%26nbsp%3B27%26nbsp%3B8%26nbsp%3B70%26nbsp%3B88%26nbsp%3Bf6%26nbsp%3B83%26nbsp%3B3b%26nbsp%3Ba5%26nbsp%3B93%26nbsp%3B44%26nbsp%3Bbc%26nbsp%3B59%26nbsp%3B71%3CBR%20%2F%3E%5BINF%5D%5Bdevtask%5D%26nbsp%3B%26nbsp%3B%26nbsp%3BsrcData(ciphertext)%3A%26nbsp%3B2256%3A%3CBR%20%2F%3E%5BINF%5D%5Bdevtask%5D%26nbsp%3B%26nbsp%3B%26nbsp%3BdstData(plaintext)%3A%26nbsp%3B2256%3A%3CBR%20%2F%3E%5B28667%26nbsp%3Bms%5D%26nbsp%3BAPDU%26nbsp%3BTX%26nbsp%3Blen%3D2317%26nbsp%3B%3A%3CBR%20%2F%3E%5B28676%26nbsp%3Bms%5D%26nbsp%3BTransceive%26nbsp%3Bdata%26nbsp%3Bptr%26nbsp%3B0x0x204133cc%26nbsp%3Blen%3A2317%3CBR%20%2F%3E%3CSTRONG%3ESe05x_API_AeadOneShot%26nbsp%3BSE050%26nbsp%3BAEAD%26nbsp%3BDecrypt%26nbsp%3BFailed(0x6700)%3CBR%20%2F%3E%5BINF%5D%5Bdevtask%5D%26nbsp%3B%26nbsp%3B0x6700%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2252195%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050%20AEAD%20Decryption%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2252195%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDear%20Kan_Li.%3C%2FP%3E%3CP%3EAEAD%20Oneshot%20Decryption%20has%20been%20somewhat%20resolved.%3C%2FP%3E%3CP%3EHowever%2C%20for%20the%20second%20AEAD%20Decrypt%20cipher%20frame%2C%20with%20a%20size%20of%202256%2C%20memory%20issues%20prevent%20oneshot%20decryption.%3CBR%20%2F%3EAttempting%20to%20use%20a%20multi-step%20(init%2C%20update%2C%20final)%20approach%20results%20in%20excessive%20performance%20degradation.%3C%2FP%3E%3CP%3EDo%20you%20have%20any%20other%20solution%3F%20or%20recommandation%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThank%20you.%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%26lt%3B%20log%20%26gt%3B%3C%2FP%3E%3CP%3Embedtls_cipher_aead_decrypt%20Cipher%20ctx(20427300)%20Mode%206%2C%20tag_len%2016%2C%20ilen(16)%3CBR%20%2F%3E%5BINF%5D%5Bdevtask%5D%20Cipher%20Aead%20OneGo%20Start%3A0x20427320%20size%3A16%20Cipher%20Mode%3A0xb0%2C%20OP%20Type%3A0x38%3CBR%20%2F%3E%5BINF%5D%5Bdevtask%5D%20Key%20ID%3A%200xef00050e%3C%2FP%3E%3CP%3E%5BINF%5D%5Bdevtask%5D%20aadLen%3A%205%3A%3CBR%20%2F%3E17%203%203%200%2020%3CBR%20%2F%3E%5BINF%5D%5Bdevtask%5D%20nonceLen%3A%2012%3A%3CBR%20%2F%3E44%202%20e5%209e%2014%20f8%20bc%20d2%208f%20b6%207%20b4%3CBR%20%2F%3E%5BINF%5D%5Bdevtask%5D%20tagLen%3A%2016%3A%3CBR%20%2F%3E32%20ac%2013%20ca%202e%2031%202a%201c%2091%20bf%20ea%2079%2016%20bb%20b8%20b0%3CBR%20%2F%3E%5BINF%5D%5Bdevtask%5D%20srcData(ciphertext)%3A%2016%3A%3CBR%20%2F%3E%5BINF%5D%5Bdevtask%5D%20dstData(plaintext)%3A%2016%3A%3CBR%20%2F%3ESe05x_API_AeadOneShot%20SE050%20AEAD%20Decrypt%20Ok...%3CBR%20%2F%3EAPDU%20RSP%20len%3D27%3A%3CBR%20%2F%3E41%2082%2000%2010%2008%2000%2000%2002%2000%2000%2016%2000%2000%2000%2000%2000%2000%2000%2000%2000%2042%2082%2000%2001%2001%2090%2000%3CBR%20%2F%3EAEAD%20Decrypt%20RSP%20tag1%3D0%3A%3CBR%20%2F%3E%5BINF%5D%5Bdevtask%5D%200x9000%3C%2FP%3E%3CP%3E..%2Fmbedtls%2Fmbedtls%2Flibrary%2Fssl_msg.c%3A1520%3A%20%3D%26gt%3B%20decrypt%20buf%3CBR%20%2F%3Embedtls_ssl_decrypt_buf%20data_len(2256)%20TAG%20used(16)%3A%3A%3CBR%20%2F%3E83%20e6%20fb%209c%207b%209%20d7%206%2092%20c%20c5%2083%2091%20a3%2081%2020%3CBR%20%2F%3Embedtls_cipher_aead_decrypt%20Cipher%20ctx(20427300)%20Mode%206%2C%20tag_len%2016%2C%20ilen(2256)%3CBR%20%2F%3E%5BINF%5D%5Bdevtask%5D%20Cipher%20Aead%20OneGo%20Start%3A0x20427320%20size%3A2256%20Cipher%20Mode%3A0xb0%2C%20OP%20Type%3A0x38%3CBR%20%2F%3E%5BINF%5D%5Bdevtask%5D%20Key%20ID%3A%200xef00050e%3C%2FP%3E%3CP%3E%5BINF%5D%5Bdevtask%5D%20aadLen%3A%205%3A%3CBR%20%2F%3E17%203%203%208%20e0%3CBR%20%2F%3E%5BINF%5D%5Bdevtask%5D%20nonceLen%3A%2012%3A%3CBR%20%2F%3E44%202%20e5%209e%2014%20f8%20bc%20d2%208f%20b6%207%20b5%3CBR%20%2F%3E%5BINF%5D%5Bdevtask%5D%20tagLen%3A%2016%3A%3CBR%20%2F%3E83%20e6%20fb%209c%207b%209%20d7%206%2092%20c%20c5%2083%2091%20a3%2081%2020%3CBR%20%2F%3E%5BINF%5D%5Bdevtask%5D%20srcData(ciphertext)%3A%202256%3A%3CBR%20%2F%3E%5BINF%5D%5Bdevtask%5D%20dstData(plaintext)%3A%202256%3A%3CBR%20%2F%3E%5B31678%20ms%5D%20se05x_gcm_decrypt_multistep%20keyId%200xef00050e%2C%20cipherMode%200xb0%20cryptoObjectId%2026%2C%20tagLen%20541177908%3CBR%20%2F%3E%5B49212%20ms%5D%20se05x_gcm_decrypt_multistep%20AEAD%20Update%20offset(400)%20(2256)%3CBR%20%2F%3E%5B65947%20ms%5D%20se05x_gcm_decrypt_multistep%20AEAD%20Update%20offset(800)%20(2256)%3CBR%20%2F%3E%5B82784%20ms%5D%20se05x_gcm_decrypt_multistep%20AEAD%20Update%20offset(1200)%20(2256)%3CBR%20%2F%3E%5B99558%20ms%5D%20se05x_gcm_decrypt_multistep%20AEAD%20Update%20offset(1600)%20(2256)%3CBR%20%2F%3E%5B116379%20ms%5D%20se05x_gcm_decrypt_multistep%20AEAD%20Update%20offset(2000)%20(2256)%3CBR%20%2F%3E%5B127157%20ms%5D%20se05x_gcm_decrypt_multistep%20AEAD%20Update%20offset(2256)%20(2256)%3CBR%20%2F%3E%5BERR%5D%5Bdevtask%5D%20Not%20enough%20buffer%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2252827%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050%20AEAD%20Decryption%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2252827%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F232520%22%20target%3D%22_blank%22%3E%40Changhawn%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CP%3Eper%20APDU%20spec%20for%26nbsp%3BAEADOneShot%20command%3A%3C%2FP%3E%0A%3CP%3EWhen%20the%20AEADMode%20equals%20AES_GCM%2C%20the%20length%20of%20AAD%20%2B%20length%20of%20data%20should%3CBR%20%2F%3Ebe%20limited%20to%20888%20bytes%20-%20the%20total%20C-APDU%20buffer%20length.%20Did%20you%20meet%20this%20requirement%3F%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%0A%3CP%3EHave%20a%20great%20day%2C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3ENote%3A%3CBR%20%2F%3E-%20If%20this%20post%20answers%20your%20question%2C%20please%20click%20the%20%22Mark%20Correct%22%20button.%20Thank%20you!%3CBR%20%2F%3E-%20We%20are%20following%20threads%20for%207%20weeks%20after%20the%20last%20post%2C%20later%20replies%20are%20ignored%3CBR%20%2F%3EPlease%20open%20a%20new%20thread%20and%20refer%20to%20the%20closed%20one%2C%20if%20you%20have%20a%20related%20question%20at%20a%20later%20point%20in%20time.%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2252907%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050%20AEAD%20Decryption%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2252907%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDear%20Kan_Li.%3C%2FP%3E%3CP%3EBy%20below%20SE050%20specification%2C%20Oneshot%20input%20length%20is%20limited%20256.%3C%2FP%3E%3CP%3ESo%20I%20have%20developed%20with%20Multistep(AEADInit%2C%20AEADUpdate%2C%20AEADFinal).%20But%20still%20have%20problem.%3C%2FP%3E%3CP%3EThat's%20low%20performance.%20It%20takes%2095%20secs.%20Could%20you%20recommand%20about%20this%20low%20performance.%3C%2FP%3E%3CP%3EThank%20you.%26nbsp%3B%3C%2FP%3E%3CP%3EChang.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Changhawn_0-1764661314832.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Changhawn_0-1764661314832.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Changhawn_0-1764661314832.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F368169iD6AEF8E5C60147B8%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Changhawn_0-1764661314832.png%22%20alt%3D%22Changhawn_0-1764661314832.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EChanghawn_0-1764661314832.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E..%2Fmbedtls%2Fmbedtls%2Flibrary%2Fssl_msg.c%3A1520%3A%20%3D%26gt%3B%20decrypt%20buf%3CBR%20%2F%3Embedtls_ssl_decrypt_buf%20data_len(2256)%20TAG%20used(16)%3A%3A%3CBR%20%2F%3Ee8%20c0%20f9%203%20a1%20a6%2087%209d%20e9%20e3%2091%20fe%2059%207a%2045%2062%3CBR%20%2F%3Embedtls_cipher_aead_decrypt%20Cipher%20ctx(20427300)%20Mode%206%2C%20tag_len%2016%2C%20ilen(2256)%3CBR%20%2F%3E%5BINF%5D%5Bdevtask%5D%20Cipher%20Aead%20OneGo%20Start%3A0x20427320%20size%3A2256%20Cipher%20Mode%3A0xb0%2C%20OP%20Type%3A0x38%3CBR%20%2F%3E%5BINF%5D%5Bdevtask%5D%20Key%20ID%3A%200xef00050e%3C%2FP%3E%3CP%3E%5BINF%5D%5Bdevtask%5D%20aadLen%3A%205%3A%3CBR%20%2F%3E17%203%203%208%20e0%3CBR%20%2F%3E%5BINF%5D%5Bdevtask%5D%20nonceLen%3A%2012%3A%3CBR%20%2F%3E7b%205e%201b%2041%209d%2019%20b2%20b8%2094%2062%20c2%202e%3CBR%20%2F%3E%5BINF%5D%5Bdevtask%5D%20tagLen%3A%2016%3A%3CBR%20%2F%3Ee8%20c0%20f9%203%20a1%20a6%2087%209d%20e9%20e3%2091%20fe%2059%207a%2045%2062%3CBR%20%2F%3E%5BINF%5D%5Bdevtask%5D%20srcData(ciphertext)%3A%202256%3A%3CBR%20%2F%3E%5BINF%5D%5Bdevtask%5D%20dstData(plaintext)%3A%202256%3A%3CBR%20%2F%3E%5B27711%20ms%5D%20APDU%20TX%20len%3D4%20%3A%3CBR%20%2F%3E%5B27749%20ms%5D%20se05x_gcm_decrypt_multistep%20keyId%200xef00050e%2C%20cipherMode%200xb0%20cryptoObjectId%2026%2C%20ctLen%202256%2C%20tagLen%2016%3CBR%20%2F%3E%5B27814%20ms%5D%20se05x_gcm_decrypt_multistep%20aadLen%205%3CBR%20%2F%3E%5B27852%20ms%5D%20se05x_gcm_decrypt_multistep%20offset%200%2C%20ctLen%202256%3CBR%20%2F%3E%5B27864%20ms%5D%20APDU%20TX%20len%3D497%20%3A%3CBR%20%2F%3E%5B48615%20ms%5D%20se05x_gcm_decrypt_multistep%20AEAD%20Update%20offset(480)%20(2256)%3CBR%20%2F%3E%5B48630%20ms%5D%20APDU%20TX%20len%3D497%20%3A%3CBR%20%2F%3E%5B68749%20ms%5D%20se05x_gcm_decrypt_multistep%20AEAD%20Update%20offset(960)%20(2256)%3CBR%20%2F%3E%5B68764%20ms%5D%20APDU%20TX%20len%3D497%20%3A%3CBR%20%2F%3E%5B88833%20ms%5D%20se05x_gcm_decrypt_multistep%20AEAD%20Update%20offset(1440)%20(2256)%3CBR%20%2F%3E%5B88848%20ms%5D%20APDU%20TX%20len%3D497%20%3A%3CBR%20%2F%3E%5B108979%20ms%5D%20se05x_gcm_decrypt_multistep%20AEAD%20Update%20offset(1920)%20(2256)%3CBR%20%2F%3E%5B108994%20ms%5D%20APDU%20TX%20len%3D353%20%3A%3CBR%20%2F%3E%5B123113%20ms%5D%20se05x_gcm_decrypt_multistep%20AEAD%20Update%20offset(2256)%20(2256)%3CBR%20%2F%3E%5B123128%20ms%5D%20APDU%20TX%20len%3D31%20%3A%3CBR%20%2F%3E%5BINF%5D%5Bdevtask%5D%200x9000%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2270398%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050%20AEAD%20Decryption%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2270398%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20need%20to%20develop%20the%20A1006%20chip.%20If%20you%20have%20done%20it%20before%2C%20please%20contact%20me.%20Thank%20you%20very%20much!%3C%2FP%3E%3C%2FLINGO-BODY%3E
