SE050 AEAD Decryption
7,975件の閲覧回数
Changhawn
Dear
In S32K314 Platform, developing TLS1.3 with using SE050E.
During the TLS1.3 handshake, need the AEAD(AES GCM) description(message authentication).
When AEADOneShot command (AES GCM calculation) Se05x_API_AeadOneShot() is executed.
I2C Access is failed in SE050.  I don't know the reason.
I2C was working fine in another case.
Could you check what's problem?
Thank you.
Chang
< LOG >
$ app info
[INF][cli] Open Session to SE05x
[INF][cli] Plug and Trust nano package - version: 1.5.4
[INF][cli] Applet Major = 7
[INF][cli] Applet Minor = 2
[INF][cli] Applet patch = 0
[INF][cli] AppletConfig = 3F9F
[INF][cli] With    ECDSA_ECDH_ECDHE
[INF][cli]
[INF][cli] With    EDDSA
[INF][cli]
[INF][cli] With    DH_MONT
[INF][cli]
[INF][cli] With    HMAC
[INF][cli]
[INF][cli] WithOut RSA_PLAIN
[INF][cli]
[INF][cli] WithOut RSA_CRT
[INF][cli]
[INF][cli] With    AES
[INF][cli]
[INF][cli] With    DES
[INF][cli]
[INF][cli] With    PBKDF
[INF][cli]
[INF][cli] With    TLS
[INF][cli]
[INF][cli] With    MIFARE
[INF][cli]
[INF][cli] With    I2CM
[INF][cli]
$ app info aead
[SE_APDU] Write SymmKey keyid(0xef0002de)
[23007 ms] APDU TX len=zu:
                          80 03 11 37 00 00 48
  41 04 EF 00 02 DE
  42 01 B0
  43 10 48 45 4C 4C 4F 48 45 4C 4C 4F 48 45 4C 4C 4F 31
  44 19 45 78 74 72 61 20 61 75 74 68 65 6E 74 69 63 61 74 69 6F 6E 20 64 61 74 61
  45 10 00 00 00 00 00 00 00 00 FD 15 71 99 32 D3 56 90
  00 00
           [23063 ms] Transceive data ptr 0x0x20412c6c len:81
[23071 ms] phNxpEseProto7816_SendIframe len:86
[23079 ms] phNxpEseProto7816_SendRawFrame len:86
[23087 ms] phNxpEse_WriteFrame len:86
[23093 ms] phPalEse_i2c_write len:86
[23412 ms] phNxpEseProto7816_sendRframe len:5
[23418 ms] phNxpEseProto7816_SendRawFrame len:5
[23426 ms] phNxpEse_WriteFrame len:5
[23432 ms] phPalEse_i2c_write len:5
axI2CWrite Failed(0x9)
[23645 ms] Se05x_API_AeadOneShot failed 0
< Code >
void ex_sss_aead_decrypt(void)
    sss_status_t status = kStatus_SSS_Success;
    sss_algorithm_t algorithm;
    sss_mode_t mode;
    /* clang-format off */
    uint8_t aead_srcData[16] = { 0x48 ,0x45 ,0x4c ,0x4c ,0x4f ,0x48 ,0x45 ,0x4c ,0x4c ,0x4f ,0x48 ,0x45 ,0x4c ,0x4c ,0x4f ,0x31 }; /*HELLOHELLOHELLO1*/
    uint8_t aead_keystring[KEY_BIT_LEN / 8] = { 0x48 ,0x45 ,0x4c ,0x4c ,0x4f ,0x48 ,0x45 ,0x4c ,0x4c ,0x4f ,0x48 ,0x45 ,0x4c ,0x4c ,0x4f ,0x31 }; /*HELLOHELLOHELLO1*/
    uint8_t destData[16] = {0,};
    size_t destDataLen = sizeof(destData);
    uint8_t aead_iv[16] = {0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xfd, 0x15, 0x71, 0x99, 0x32, 0xd3, 0x56, 0x90};
    size_t ivlen = 16;
    uint32_t keyId = MAKE_TEST_ID(__LINE__);
    sss_key_part_t keyPart;
    sss_cipher_type_t cipherType;
    size_t keyByteLenMax = KEY_BIT_LEN/8;
    sss_object_t key = { 0 };
    sss_se05x_aead_t ctx_aead_encrypt = { 0 };
    size_t TAG_SIZE = 16;
    uint8_t tag[TAG_SIZE];
    uint8_t  *aad =(uint8_t*)"Extra authentication data";
    size_t aadSize = strlen((char*)aad);
    pSe05xSession_t p_session_ctx = &se05x_session;
    SE05x_CipherMode_t cipherMode = kSE05x_CipherMode_AES_GCM;
    SE05x_Cipher_Oper_OneShot_t OperType = kSE05x_Cipher_Oper_OneShot_Encrypt; // : kSE05x_Cipher_Oper_OneShot_Decrypt;
    algorithm =  kAlgorithm_SSS_AES_GCM;
    keyPart    = kSSS_KeyPart_Default;
    cipherType = kSSS_CipherType_AES;
    mode       = kMode_SSS_Encrypt;
    p_session_ctx = se05x_get_session();
    key.session = p_session_ctx;
    if (key.session == NULL)
        __printf("SESSION open failed\r\n");
        return;
     status = sss_key_object_allocate_handle(&key, keyId, keyPart, cipherType, keyByteLenMax, kKeyObject_Mode_Persistent);
    if (status != true)
        __printf("sss_key_object_allocate_handle failed %x\r\n", status);
        return;
     status = sss_se05x_key_store_set_key(&key, aead_keystring, sizeof(aead_keystring), sizeof(aead_keystring) * 8);
    if (status != kStatus_SSS_Success)
        __printf("sss_se05x_key_store_set_key failed 0x%x\r\n", status);
        return;
    //status = sss_aead_context_init(&ctx_aead_encrypt, &pCtx->session, &key, algorithm, mode);
    ctx_aead_encrypt.keyObject = &key;
    ctx_aead_encrypt.algorithm = algorithm;
    ctx_aead_encrypt.mode = mode;
    aeadoneshotlog = true;
    status = Se05x_API_AeadOneShot(p_session_ctx, keyId, cipherMode, aead_srcData,
            destDataLen, aad, aadSize, aead_iv, ivlen, tag, &TAG_SIZE, destData, &destDataLen, OperType);
    aeadoneshotlog = false;
        sm_dbg_printf("Se05x_API_AeadOneShot failed %x\r\n", status);
        return;
    __printf("Encryption successful !!!");
cleanup:
    return;
7,616件の閲覧回数
Kan_Li
Hi @Changhawn ,
per APDU spec for AEADOneShot command:
When the AEADMode equals AES_GCM, the length of AAD + length of data should
be limited to 888 bytes - the total C-APDU buffer length. Did you meet this requirement?
Kan
11 返答(返信)
5,827件の閲覧回数
jesssaid
I need to develop the A1006 chip. If you have done it before, please contact me. Thank you very much!
タグ(1)
7,953件の閲覧回数
Kan_Li
Hi @Changhawn ,
Is it possible to turn on the debug log printing? Are you building the application based on zephyr? If yes, please set the following configurations in prj.conf file.
CONFIG_LOG=y
CONFIG_PLUGANDTRUST_LOG_LEVEL_DBG=y
CONFIG_LOG_MODE_IMMEDIATE=y
Kan
7,921件の閲覧回数
Changhawn
Dear Kan_Li
My paltform is NXP S32K314.
Log print has a lot of delay, which prevents i2c access from working properly in the first place.
I used the Plug-and-Trust Nano version, so it doesn't have a prj.conf file.
I don't know if i2c access fails in AEAD Deription.
Could you please tell me some other debugging points?
Thank you.
Chang
7,874件の閲覧回数
Kan_Li
Hi @Changhawn ,
The AEAD operation takes longer than AES CCM, but the I2C would keep polling the SE until there is a response. you may build the application with -DPLUGANDTRUST_DEBUG_LOGS=ON to have more debug info.
Kan
7,799件の閲覧回数
Changhawn
Dear Kan_Li
The i2c issue was somewhat resolved by fixing the i2c access issue. However, the AEAD Decryption still has issues. Please check the code and logs to determine what the issue is.
#define KEY_BIT_LEN 256
smStatus_t Se05x_API_AeadOneShot(pSe05xSession_t session_ctx,
uint32_t objectID,
SE05x_CipherMode_t cipherMode,
const uint8_t *pInputData,
size_t inputDataLen,
const uint8_t *pAad,
size_t aadLen,
uint8_t *pIV,
size_t IVLen,
uint8_t *pTagData,
size_t *pTagDataLen,
uint8_t *pOutputData,
size_t *pOutputDataLen,
const SE05x_Cipher_Oper_OneShot_t operation)
smStatus_t retStatus = SM_NOT_OK;
tlvHeader_t hdr = {{kSE05x_CLA, kSE05x_INS_CRYPTO, kSE05x_P1_AEAD, operation}};
size_t cmdbufLen = 0;
uint8_t *pCmdbuf = NULL;
int tlvRet = 0;
uint8_t *pRspbuf = NULL;
size_t rspbufLen = MAX_APDU_BUFFER;
SE05x_Result_t result;
uint16_t ivlen16 = 0;
size_t ivlen32 = IVLen;
size_t rspIndex = 0;
pCmdbuf = &session_ctx->apdu_buffer[0];
pRspbuf = &session_ctx->apdu_buffer[0];
if (IVLen > UINT16_MAX) {
goto cleanup;
ivlen16 = (uint16_t)IVLen;
tlvRet = TLVSET_U32("objectID", &pCmdbuf, &cmdbufLen, kSE05x_TAG_1, objectID);
if (0 != tlvRet) {
goto cleanup;
tlvRet = TLVSET_CipherMode("cipherMode",
&pCmdbuf,
&cmdbufLen,
kSE05x_TAG_2,
((cipherMode == kSE05x_CipherMode_AES_GCM_INT_IV) ? kSE05x_CipherMode_AES_GCM : cipherMode));
if (0 != tlvRet) {
goto cleanup;
tlvRet = TLVSET_u8bufOptional("inputData", &pCmdbuf, &cmdbufLen, kSE05x_TAG_3, pInputData, inputDataLen);
if (0 != tlvRet) {
goto cleanup;
tlvRet = TLVSET_u8bufOptional("AdditionalData", &pCmdbuf, &cmdbufLen, kSE05x_TAG_4, pAad, aadLen);
if (0 != tlvRet) {
goto cleanup;
if ((cipherMode == kSE05x_CipherMode_AES_GCM) ||
((cipherMode == kSE05x_CipherMode_AES_GCM_INT_IV) && (operation == kSE05x_Cipher_Oper_OneShot_Decrypt))) {
tlvRet = TLVSET_u8bufOptional("IV", &pCmdbuf, &cmdbufLen, kSE05x_TAG_5, pIV, IVLen);
if (0 != tlvRet) {
goto cleanup;
else {
tlvRet = TLVSET_U16("IVLen", &pCmdbuf, &cmdbufLen, kSE05x_TAG_5, ivlen16);
if (0 != tlvRet) {
goto cleanup;
if (operation == kSE05x_Cipher_Oper_OneShot_Decrypt) {
if (pTagDataLen != NULL) {
//__printf("%s tgaDataLen is selected\r\n", __func__);
//if (pTagDataLen > 0 ) {
tlvRet = TLVSET_u8bufOptional("tag", &pCmdbuf, &cmdbufLen, kSE05x_TAG_6, pTagData, *pTagDataLen);
if (0 != tlvRet) {
goto cleanup;
#if 0
uint8_t *temp = session_ctx->apdu_buffer;
__printf("APDU TX len=%zu:\n", cmdbufLen);
for (size_t i=0;i<cmdbufLen;i++) __printf("%02X ", temp[i]);
__printf("\n");
#endif
//retStatus = DoAPDUTxRx_s_Case4_ext(session_ctx, &hdr, session_ctx->apdu_buffer, cmdbufLen, pRspbuf, &rspbufLen);
retStatus = DoAPDUTxRx(session_ctx, &hdr, session_ctx->apdu_buffer, cmdbufLen, session_ctx->apdu_buffer, &rspbufLen, 1);
if (retStatus == SM_OK) {
__printf("%s SE050 AEAD Decrypt Ok...\r\n", __func__);
__printf("APDU RSP len=%d:\n", rspbufLen);
for (size_t i=0 ; i < rspbufLen ; i++) __printf("%02X ", pRspbuf[i]);
__printf("\n");
if (inputDataLen != 0) {
tlvRet = tlvGet_u8buf(pRspbuf, &rspIndex, rspbufLen, kSE05x_TAG_1, pOutputData, pOutputDataLen);
__printf("AEAD Decrypt RSP tag1=%d:\n", tlvRet);
if (0 != tlvRet) {
goto cleanup;
if (operation == kSE05x_Cipher_Oper_OneShot_Encrypt) {
tlvRet = tlvGet_u8buf(pRspbuf, &rspIndex, rspbufLen, kSE05x_TAG_2, pTagData, pTagDataLen);
__printf("AEAD Decrypt RSP tag2=%d:\n", tlvRet);
if (0 != tlvRet) {
goto cleanup;
tlvRet = tlvGet_Result(pRspbuf, &rspIndex, rspbufLen, kSE05x_TAG_2, &result);
if (0 != tlvRet) {
__printf("AEAD Decrypt RSP tlvRet=%d:\n", tlvRet);
goto cleanup;
if (result != kSE05x_Result_SUCCESS) {
__printf("APDU Decrypt RSP result=%d:\n", result);
goto cleanup;
if ((operation == kSE05x_Cipher_Oper_OneShot_Encrypt) && (cipherMode == kSE05x_CipherMode_AES_GCM_INT_IV)) {
tlvRet = tlvGet_u8buf(pRspbuf, &rspIndex, rspbufLen, kSE05x_TAG_3, pIV, &ivlen32);
if (0 != tlvRet) {
goto cleanup;
if ((rspIndex + 2) == rspbufLen) {
retStatus = (smStatus_t)((pRspbuf[rspIndex] << | (pRspbuf[rspIndex + 1]));
cleanup:
return retStatus;
sss_mode_t mode;
#ifdef ADED_DECRYPT_TEST
uint8_t aead_srcData[16] = { 0x8f, 0xd9, 0x64, 0xc, 0xa9, 0x95, 0xf1, 0x98, 0x86, 0xcf, 0xd6, 0xe9, 0xde, 0xd0, 0x37, 0x1f };
uint8_t aead_keystring[KEY_BIT_LEN / 8] = { 0xad, 0x4f , 0x6f , 0xaa , 0x5c , 0x67 , 0xf8 , 0x94 , 0xdc , 0x50 , 0xdd , 0x3e ,
0xf2 , 0x82 , 0xe3 , 0xf9 , 0x65 , 0x34 , 0xf8 , 0x0f , 0xdc , 0x46 , 0x65 , 0x1b , 0xb5 , 0x9a , 0x01 , 0x69 , 0xce , 0xfb , 0xa8 , 0xec};
#else
#endif
uint8_t aead_iv[12] = {0x55, 0x6a , 0xe5 , 0xa9 , 0x17 , 0xce , 0xa , 0xd , 0x27 , 0x3f , 0x9f , 0xaa};
size_t ivlen = 12;
#else
size_t ivlen = 16;
#endif
uint8_t tag[16] = {0x99 , 0xc5 , 0x3 , 0xaa , 0x7c , 0x6d ,
0x37 , 0x52 , 0x64 , 0x6e , 0x62 , 0x47 , 0xe0 , 0x3a , 0x80 , 0xc8};
uint8_t aad[5] = {0x17, 0x3, 0x3, 0x0, 0x20};
//uint8_t *aad =(uint8_t*)"Extra authentication data";
#else
#endif
//uint8_t *aad = NULL;
//size_t aadSize = 0;
SE05x_Cipher_Oper_OneShot_t OperType = kSE05x_Cipher_Oper_OneShot_Decrypt;
#else
#endif
mode = kMode_SSS_Decrypt;
#else
#endif
/* doc:start ex_sss_symmetric-allocate-key */
/* Pre-requisite for encryption Part*/
//status = Se05x_API_SessionOpen(p_session_ctx);
return;
//status = sss_key_object_allocate_handle(&key, keyId, keyPart, cipherType, keyByteLenMax, kKeyObject_Mode_Persistent);
if (status != true)
return;
//status = sss_key_store_set_key(&pCtx->ks, &key, keystring, sizeof(keystring), sizeof(keystring) * 8, NULL, 0);
return;
/*Do Encryption*/
#if 1
//aeadoneshotlog = false;
if (status != SM_OK)
return;
/* doc:end ex_sss_aead-encrypt */
__printf("AEAD En/Decryption successful !!!");
#else /* AEAD Multistep */
status = se05x_gcm_encrypt_multistep(p_session_ctx,
keyId, aead_srcData, destDataLen,
aad, aadSize, aead_iv, ivlen, destData, &destDataLen,
tag, &TAG_SIZE, OperType);
sm_dbg_printf("se05x_gcm_encrypt_multistep failed %x\r\n", status);
return;
#endif
cleanup:
return;
< LOG >
[SE_APDU] Update SymmKey keyid(0xef0003d1)
Se05x_API_AeadOneShot SE050 AEAD Decrypt Ok...
APDU RSP len=7:
42 82 00 01 02 90 00
AEAD Decrypt RSP tag1=1:
[409452 ms] Se05x_API_AeadOneShot failed ffff
7,715件の閲覧回数
Kan_Li
Hi @Changhawn ,
It should be due to the authentication tag, please kindly refer to the following for details.
Kan
7,651件の閲覧回数
Changhawn
Dear Kan_Li.
AEAD Oneshot Decryption has been somewhat resolved.
However, for the second AEAD Decrypt cipher frame, with a size of 2256, memory issues prevent oneshot decryption.
Attempting to use a multi-step (init, update, final) approach results in excessive performance degradation.
Do you have any other solution? or recommandation?
Thank you.
< log >
mbedtls_cipher_aead_decrypt Cipher ctx(20427300) Mode 6, tag_len 16, ilen(16)
[INF][devtask] Cipher Aead OneGo Start:0x20427320 size:16 Cipher Mode:0xb0, OP Type:0x38
[INF][devtask] Key ID: 0xef00050e
[INF][devtask] aadLen: 5:
17 3 3 0 20
[INF][devtask] nonceLen: 12:
44 2 e5 9e 14 f8 bc d2 8f b6 7 b4
[INF][devtask] tagLen: 16:
32 ac 13 ca 2e 31 2a 1c 91 bf ea 79 16 bb b8 b0
[INF][devtask] srcData(ciphertext): 16:
[INF][devtask] dstData(plaintext): 16:
APDU RSP len=27:
41 82 00 10 08 00 00 02 00 00 16 00 00 00 00 00 00 00 00 00 42 82 00 01 01 90 00
AEAD Decrypt RSP tag1=0:
[INF][devtask] 0x9000
../mbedtls/mbedtls/library/ssl_msg.c:1520: => decrypt buf
mbedtls_ssl_decrypt_buf data_len(2256) TAG used(16)::
83 e6 fb 9c 7b 9 d7 6 92 c c5 83 91 a3 81 20
mbedtls_cipher_aead_decrypt Cipher ctx(20427300) Mode 6, tag_len 16, ilen(2256)
[INF][devtask] Cipher Aead OneGo Start:0x20427320 size:2256 Cipher Mode:0xb0, OP Type:0x38
17 3 3 8 e0
44 2 e5 9e 14 f8 bc d2 8f b6 7 b5
[INF][devtask] srcData(ciphertext): 2256:
[INF][devtask] dstData(plaintext): 2256:
[31678 ms] se05x_gcm_decrypt_multistep keyId 0xef00050e, cipherMode 0xb0 cryptoObjectId 26, tagLen 541177908
[49212 ms] se05x_gcm_decrypt_multistep AEAD Update offset(400) (2256)
[65947 ms] se05x_gcm_decrypt_multistep AEAD Update offset(800) (2256)
[82784 ms] se05x_gcm_decrypt_multistep AEAD Update offset(1200) (2256)
[99558 ms] se05x_gcm_decrypt_multistep AEAD Update offset(1600) (2256)
[116379 ms] se05x_gcm_decrypt_multistep AEAD Update offset(2000) (2256)
[127157 ms] se05x_gcm_decrypt_multistep AEAD Update offset(2256) (2256)
[ERR][devtask] Not enough buffer
7,631件の閲覧回数
Changhawn
Dear Kan_Li.
If  increase the APDU unit size as 2400 and test with Oneshot instead of Multistep AEAD Decrypt, as before, the SE050 chip responds with the following log:
SM_ERR_WRONG_LENGTH (0x6700)
Could you please also check this.
Thank you.
Chang
< 로그 >
mbedtls_ssl_decrypt_buf data_len(16) TAG used(16)::
14 b0 cf 4b 29 2c c2 a0 1c 83 d9 e9 92 47 65 f1
mbedtls_cipher_aead_decrypt Cipher ctx(20428900) Mode 6, tag_len 16, ilen(16)
[INF][devtask] Cipher Aead OneGo Start:0x20428920 size:16 Cipher Mode:0xb0, OP Type:0x38
 17 3 3 0 20
 a2 3c 82 54 67 a9 29 d2 aa 69 99 ef
[26093 ms] APDU TX len=75 :
[26099 ms] Transceive data ptr 0x0x204133cc len:75
APDU RSP len=27:
../mbedtls/mbedtls/library/ssl_msg.c:2139: <= decrypt buf
../mbedtls/mbedtls/library/ssl_msg.c:4289: <= read record
../mbedtls/mbedtls/library/ssl_tls13_client.c:2306: <= parse encrypted extensions
../mbedtls/mbedtls/library/ssl_msg.c:2333: in_left: 5, nb_want: 2277
40 62 d7 27 8 70 88 f6 83 3b a5 93 44 bc 59 71
mbedtls_cipher_aead_decrypt Cipher ctx(20428900) Mode 6, tag_len 16, ilen(2256)
[INF][devtask] Cipher Aead OneGo Start:0x20428920 size:2256 Cipher Mode:0xb0, OP Type:0x38
 17 3 3 8 e0
 a2 3c 82 54 67 a9 29 d2 aa 69 99 ee
[28667 ms] APDU TX len=2317 :
[28676 ms] Transceive data ptr 0x0x204133cc len:2317
Se05x_API_AeadOneShot SE050 AEAD Decrypt Failed(0x6700)
[INF][devtask]  0x6700
7,617件の閲覧回数
Kan_Li
Hi @Changhawn ,
Kan
7,613件の閲覧回数
Changhawn
Dear Kan_Li.
By below SE050 specification, Oneshot input length is limited 256.
So I have developed with Multistep(AEADInit, AEADUpdate, AEADFinal). But still have problem.
That's low performance. It takes 95 secs. Could you recommand about this low performance.
Thank you.
Chang.
e8 c0 f9 3 a1 a6 87 9d e9 e3 91 fe 59 7a 45 62
17 3 3 8 e0
7b 5e 1b 41 9d 19 b2 b8 94 62 c2 2e
[27711 ms] APDU TX len=4 :
[27749 ms] se05x_gcm_decrypt_multistep keyId 0xef00050e, cipherMode 0xb0 cryptoObjectId 26, ctLen 2256, tagLen 16
[27814 ms] se05x_gcm_decrypt_multistep aadLen 5
[27852 ms] se05x_gcm_decrypt_multistep offset 0, ctLen 2256
[27864 ms] APDU TX len=497 :
[48615 ms] se05x_gcm_decrypt_multistep AEAD Update offset(480) (2256)
[48630 ms] APDU TX len=497 :
[68749 ms] se05x_gcm_decrypt_multistep AEAD Update offset(960) (2256)
[68764 ms] APDU TX len=497 :
[88833 ms] se05x_gcm_decrypt_multistep AEAD Update offset(1440) (2256)
[88848 ms] APDU TX len=497 :
[108979 ms] se05x_gcm_decrypt_multistep AEAD Update offset(1920) (2256)
[108994 ms] APDU TX len=353 :
[123113 ms] se05x_gcm_decrypt_multistep AEAD Update offset(2256) (2256)
[123128 ms] APDU TX len=31 :
7,620件の閲覧回数
Changhawn
AEAD Oneshot is debugging multistep with tag2 max length problem.
%3CLINGO-SUB%20id%3D%22lingo-sub-2228917%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ESE050%20AEAD%E5%BE%A9%E5%8F%B7%E5%8C%96%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2228917%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%E6%A7%98%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3ES32K314%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%A7%E3%80%81SE050E%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20TLS1.3%20%E3%82%92%E9%96%8B%E7%99%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3ETLS1.3%E3%83%8F%E3%83%B3%E3%83%89%E3%82%B7%E3%82%A7%E3%82%A4%E3%82%AF%E6%99%82%E3%81%AB%E3%81%AFAEAD(AES%20GCM)%E8%A8%98%E8%BF%B0(%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E8%AA%8D%E8%A8%BC)%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EAEADOneShot%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%EF%BC%88AES%20GCM%E8%A8%88%E7%AE%97%EF%BC%89Se05x_API_AeadOneShot()%E3%81%8C%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%9F%E3%81%A8%E3%81%8D%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3ESE050%E3%81%A7I2C%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%90%86%E7%94%B1%E3%81%AF%E5%88%86%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E5%88%A5%E3%81%AECASE%E3%81%A7%E3%81%AF%E3%80%81I2C%20%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E4%BD%95%E3%81%8C%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%AE%E3%81%8B%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E3%83%81%E3%83%A3%E3%83%B3%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26lt%3B%20LOG%20%26gt%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%24%20%E3%82%A2%E3%83%97%E3%83%AA%E6%83%85%E5%A0%B1%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%20SE05x%E3%81%B8%E3%81%AE%E3%82%BB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E9%96%8B%E3%81%8F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%20%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A2%E3%83%B3%E3%83%89%E3%83%88%E3%83%A9%E3%82%B9%E3%83%88%20%E3%83%8A%E3%83%8E%20%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%20-%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%201.5.4%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%20%E3%82%A2%E3%83%97%E3%83%AC%E3%83%83%E3%83%88%E3%83%A1%E3%82%B8%E3%83%A3%E3%83%BC%20%3D%207%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%20%E3%82%A2%E3%83%97%E3%83%AC%E3%83%83%E3%83%88%E3%83%9E%E3%82%A4%E3%83%8A%E3%83%BC%20%3D%202%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%20%E3%82%A2%E3%83%97%E3%83%AC%E3%83%83%E3%83%88%20%E3%83%91%E3%83%83%E3%83%81%20%3D%200%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%20%E3%82%A2%E3%83%97%E3%83%AC%E3%83%83%E3%83%88%E8%A8%AD%E5%AE%9A%20%3D%203F9F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%20ECDSA_ECDH_ECDHE%20%E4%BB%98%E3%81%8D%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%20EDDSA%E4%BB%98%E3%81%8D%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%20DH_MONT%20%E3%81%82%E3%82%8A%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%20HMAC%20%E4%BB%98%E3%81%8D%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%20RSA_PLAIN%E3%81%AA%E3%81%97%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%20RSA_CRT%E3%81%AA%E3%81%97%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%20AES%20%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%20DES%20%E3%81%AE%E5%A0%B4%E5%90%88%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%20PBKDF%20%E4%BB%98%E3%81%8D%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%20TLS%20%E3%81%82%E3%82%8A%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%20MIFARE%20%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%20I2CM%20%E3%81%82%E3%82%8A%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%24%3C%2FDIV%3E%3CDIV%3E%24%3C%2FDIV%3E%3CDIV%3E%24%20%E3%82%A2%E3%83%97%E3%83%AA%E6%83%85%E5%A0%B1%20aead%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%20SE05x%E3%81%B8%E3%81%AE%E3%82%BB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E9%96%8B%E3%81%8F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%5BINF%5D%5Bcli%5D%20%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A2%E3%83%B3%E3%83%89%E3%83%88%E3%83%A9%E3%82%B9%E3%83%88%20%E3%83%8A%E3%83%8E%20%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%20-%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%201.5.4%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%5BSE_APDU%5D%20%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%20SymmKey%20keyid(0xef0002de)%3C%2FDIV%3E%3CDIV%3E%5B23007%20ms%5D%20APDU%20TX%20%E9%95%B7%E3%81%95%3Dzu%3A%3C%2FDIV%3E%3CDIV%3E80%2003%2011%2037%2000%2000%2048%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E41%2004%20EF%2000%2002%20DE%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E42%2001%20B0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E43%2010%2048%2045%204C%204C%204F%2048%2045%204C%204C%204F%2048%2045%204C%204C%204F%2031%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E44%2019%2045%2078%2074%2072%2061%2020%2061%2075%2074%2068%2065%206E%2074%2069%2063%2061%2074%2069%206F%206E%2020%2064%2061%2074%2061%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E45%2010%2000%2000%2000%2000%2000%2000%2000%2000%20FD%2015%2071%2099%2032%20D3%2056%2090%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E00%2000%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%5B23063%20ms%5D%20%E9%80%81%E5%8F%97%E4%BF%A1%E3%83%87%E3%83%BC%E3%82%BF%E3%83%9D%E3%82%A4%E3%83%B3%E3%82%BF%200x0x20412c6c%20%E9%95%B7%E3%81%95%3A81%3C%2FDIV%3E%3CDIV%3E%5B23071%20%E3%83%9F%E3%83%AA%E7%A7%92%5D%20phNxpEseProto7816_SendIframe%20%E9%95%B7%E3%81%95%3A86%3C%2FDIV%3E%3CDIV%3E%5B23079%20%E3%83%9F%E3%83%AA%E7%A7%92%5D%20phNxpEseProto7816_SendRawFrame%20len%3A86%3C%2FDIV%3E%3CDIV%3E%5B23087%20%E3%83%9F%E3%83%AA%E7%A7%92%5D%20phNxpEse_WriteFrame%20%E9%95%B7%E3%81%95%3A86%3C%2FDIV%3E%3CDIV%3E%5B23093%20%E3%83%9F%E3%83%AA%E7%A7%92%5D%20phPalEse_i2c_write%20%E9%95%B7%E3%81%95%3A86%3C%2FDIV%3E%3CDIV%3E%5B23412%20%E3%83%9F%E3%83%AA%E7%A7%92%5D%20phNxpEseProto7816_sendRframe%20%E9%95%B7%E3%81%95%3A5%3C%2FDIV%3E%3CDIV%3E%5B23418%20%E3%83%9F%E3%83%AA%E7%A7%92%5D%20phNxpEseProto7816_SendRawFrame%20%E9%95%B7%E3%81%95%3A5%3C%2FDIV%3E%3CDIV%3E%5B23426%20%E3%83%9F%E3%83%AA%E7%A7%92%5D%20phNxpEse_WriteFrame%20%E9%95%B7%E3%81%95%3A5%3C%2FDIV%3E%3CDIV%3E%3CSTRONG%3E%5B23432%20%E3%83%9F%E3%83%AA%E7%A7%92%5D%20phPalEse_i2c_write%20%E9%95%B7%E3%81%95%3A5%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%3E%3CSTRONG%3EaxI2C%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E5%A4%B1%E6%95%97(0x9)%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%3E%5B23645%20%E3%83%9F%E3%83%AA%E7%A7%92%5D%20Se05x_API_AeadOneShot%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%200%3C%2FDIV%3E%3CDIV%3E%24%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26lt%3B%20Code%20%26gt%3B%3C%2FDIV%3E%3CDIV%3Evoid%20ex_sss_aead_decrypt(void)%3C%2FDIV%3E%3CDIV%3E%7B%3C%2FDIV%3E%3CDIV%3Esss_status_t%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20kStatus_SSS_Success%3B%3C%2FDIV%3E%3CDIV%3Esss_algorithm_t%20%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%3B%3C%2FDIV%3E%3CDIV%3Esss_mode_t%20%E3%83%A2%E3%83%BC%E3%83%89%3B%3C%2FDIV%3E%3CDIV%3E%2F*%20clang-format%20%E3%82%AA%E3%83%95%20*%2F%3C%2FDIV%3E%3CDIV%3Euint8_t%20aead_srcData%5B16%5D%20%3D%20%7B%200x48%20%2C0x45%20%2C0x4c%20%2C0x4c%20%2C0x4f%20%2C0x48%20%2C0x45%20%2C0x4c%20%2C0x4c%20%2C0x4f%20%2C0x48%20%2C0x45%20%2C0x4c%20%2C0x4c%20%2C0x4f%20%2C0x31%20%7D%3B%20%2F*HELLOHELLOHELLO1*%2F%3C%2FDIV%3E%3CDIV%3Euint8_t%20aead_keystring%5BKEY_BIT_LEN%20%2F%208%5D%20%3D%20%7B%200x48%20%2C0x45%20%2C0x4c%20%2C0x4c%20%2C0x4f%20%2C0x48%20%2C0x45%20%2C0x4c%20%2C0x4c%20%2C0x4f%20%2C0x48%20%2C0x45%20%2C0x4c%20%2C0x4c%20%2C0x4f%20%2C0x31%20%7D%3B%20%2F*HELLOHELLOHELLO1*%2F%3C%2FDIV%3E%3CDIV%3Euint8_t%20%E5%AE%9B%E5%85%88%E3%83%87%E3%83%BC%E3%82%BF%5B16%5D%20%3D%20%7B0%2C%7D%3B%3C%2FDIV%3E%3CDIV%3Esize_t%20destDataLen%20%3D%20sizeof(destData)%3B%3C%2FDIV%3E%3CDIV%3Euint8_t%20aead_iv%5B16%5D%20%3D%20%7B0x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200xfd%2C%200x15%2C%200x71%2C%200x99%2C%200x32%2C%200xd3%2C%200x56%2C%200x90%7D%3B%3C%2FDIV%3E%3CDIV%3Esize_t%20ivlen%20%3D%2016%3B%3C%2FDIV%3E%3CDIV%3Euint32_t%20keyId%20%3D%20MAKE_TEST_ID(%20__LINE__%20)%3B%3C%2FDIV%3E%3CDIV%3Esss_key_part_t%20%E3%82%AD%E3%83%BC%E3%83%91%E3%83%BC%E3%83%88%3B%3C%2FDIV%3E%3CDIV%3Esss_cipher_type_t%20%E6%9A%97%E5%8F%B7%E3%82%BF%E3%82%A4%E3%83%97%3B%3C%2FDIV%3E%3CDIV%3Esize_t%20keyByteLenMax%20%3D%20KEY_BIT_LEN%2F8%3B%3C%2FDIV%3E%3CDIV%3Esss_object_t%20%E3%82%AD%E3%83%BC%20%3D%20%7B%200%20%7D%3B%3C%2FDIV%3E%3CDIV%3Esss_se05x_aead_t%20ctx_aead_encrypt%20%3D%20%7B%200%20%7D%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Esize_t%20TAG_SIZE%20%3D%2016%3B%3C%2FDIV%3E%3CDIV%3Euint8_t%20%E3%82%BF%E3%82%B0%5BTAG_SIZE%5D%3B%3C%2FDIV%3E%3CDIV%3Euint8_t%20*aad%20%3D(uint8_t*)%22%E8%BF%BD%E5%8A%A0%E3%81%AE%E8%AA%8D%E8%A8%BC%E3%83%87%E3%83%BC%E3%82%BF%22%3B%3C%2FDIV%3E%3CDIV%3Esize_t%20aadSize%20%3D%20strlen((char*)aad)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EpSe05xSession_t%20p_session_ctx%20%3D%20%26amp%3Bse05x_session%3B%3C%2FDIV%3E%3CDIV%3ESE05x_CipherMode_t%20%E6%9A%97%E5%8F%B7%E3%83%A2%E3%83%BC%E3%83%89%20%3D%20kSE05x_CipherMode_AES_GCM%3B%3C%2FDIV%3E%3CDIV%3ESE05x_Cipher_Oper_OneShot_t%20OperType%20%3D%20kSE05x_Cipher_Oper_OneShot_Encrypt%3B%20%2F%2F%20%3A%20kSE05x_Cipher_Oper_OneShot_Decrypt%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%20%3D%20kAlgorithm_SSS_AES_GCM%3B%3C%2FDIV%3E%3CDIV%3E%E3%82%AD%E3%83%BC%E3%83%91%E3%83%BC%E3%83%88%20%3D%20kSSS_KeyPart_Default%3B%3C%2FDIV%3E%3CDIV%3E%E6%9A%97%E5%8F%B7%E3%82%BF%E3%82%A4%E3%83%97%20%3D%20kSSS_CipherType_AES%3B%3C%2FDIV%3E%3CDIV%3E%E3%83%A2%E3%83%BC%E3%83%89%20%3D%20kMode_SSS_Encrypt%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Ep_session_ctx%20%3D%20se05x_get_session()%3B%3C%2FDIV%3E%3CDIV%3E%E3%82%AD%E3%83%BC.%E3%82%BB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%20%3D%20p_session_ctx%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E(key.session%20%3D%3D%20NULL)%E3%81%AE%E5%A0%B4%E5%90%88%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%7B%3C%2FDIV%3E%3CDIV%3E__printf(%22%E3%82%BB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%5Cr%5Cn%22)%3B%3C%2FDIV%3E%3CDIV%3E%E6%88%BB%E3%82%8B%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20sss_key_object_allocate_handle(%26amp%3Bkey%2C%20keyId%2C%20keyPart%2C%20cipherType%2C%20keyByteLenMax%2C%20kKeyObject_Mode_Persistent)%3B%3C%2FDIV%3E%3CDIV%3Eif%20(%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20!%3D%20true)%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%7B%3C%2FDIV%3E%3CDIV%3E__printf(%22sss_key_object_allocate_handle%20%E3%81%8C%20%25x%5Cr%5Cn%20%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%22%2C%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9)%3B%3C%2FDIV%3E%3CDIV%3E%E6%88%BB%E3%82%8B%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20sss_se05x_key_store_set_key(%26amp%3Bkey%2C%20aead_keystring%2C%20sizeof(aead_keystring)%2C%20sizeof(aead_keystring)%20*%208)%3B%3C%2FDIV%3E%3CDIV%3Eif%20(%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20!%3D%20kStatus_SSS_Success)%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%7B%3C%2FDIV%3E%3CDIV%3E__printf(%22sss_se05x_key_store_set_key%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%200x%25x%5Cr%5Cn%22%2C%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9)%3B%3C%2FDIV%3E%3CDIV%3E%E6%88%BB%E3%82%8B%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%2F%2F%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20sss_aead_context_init(%26amp%3Bctx_aead_encrypt%2C%20%26amp%3BpCtx-%26gt%3Bsession%2C%20%26amp%3Bkey%2C%20algorithm%2C%20mode)%3B%3C%2FDIV%3E%3CDIV%3Ectx_aead_encrypt.keyObject%20%3D%20%26amp%3Bkey%3B%3C%2FDIV%3E%3CDIV%3Ectx_aead_encrypt.algorithm%20%3D%20%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%3B%3C%2FDIV%3E%3CDIV%3Ectx_aead_encrypt.mode%20%3D%20%E3%83%A2%E3%83%BC%E3%83%89%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eaeadoneshotlog%20%3D%20true%3B%3C%2FDIV%3E%3CDIV%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20Se05x_API_AeadOneShot(p_session_ctx%2C%20keyId%2C%20cipherMode%2C%20aead_srcData%2C%3C%2FDIV%3E%3CDIV%3EdestDataLen%E3%80%81aad%E3%80%81aadSize%E3%80%81aead_iv%E3%80%81ivlen%E3%80%81tag%E3%80%81%26amp%3BTAG_SIZE%E3%80%81destData%E3%80%81%26amp%3BdestDataLen%E3%80%81OperType)%3B%3C%2FDIV%3E%3CDIV%3Eaeadoneshotlog%20%3D%20false%3B%3C%2FDIV%3E%3CDIV%3Eif%20(%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20!%3D%20kStatus_SSS_Success)%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%7B%3C%2FDIV%3E%3CDIV%3Esm_dbg_printf(%22Se05x_API_AeadOneShot%20%E3%81%8C%20%25x%5Cr%5Cn%20%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%22%2C%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9)%3B%3C%2FDIV%3E%3CDIV%3E%E6%88%BB%E3%82%8B%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E__printf(%22%E6%9A%97%E5%8F%B7%E5%8C%96%E3%81%AB%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F!!!%22)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E6%8E%83%E9%99%A4%EF%BC%9A%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E6%88%BB%E3%82%8B%3B%3C%2FDIV%3E%3CDIV%3E%7D%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2246661%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050%20AEAD%20Decryption%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2246661%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F232520%22%20target%3D%22_blank%22%3E%40Changhawn%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EAEAD%20%E6%93%8D%E4%BD%9C%E3%81%AF%20AES%20CCM%20%E3%82%88%E3%82%8A%E3%82%82%E6%99%82%E9%96%93%E3%81%8C%E3%81%8B%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81I2C%20%E3%81%AF%E5%BF%9C%E7%AD%94%E3%81%8C%E3%81%82%E3%82%8B%E3%81%BE%E3%81%A7%20SE%20%E3%82%92%E3%83%9D%E3%83%BC%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%97%E7%B6%9A%E3%81%91%E3%81%BE%E3%81%99%E3%80%82%3CSPAN%20data-teams%3D%22true%22%3E%E3%82%88%E3%82%8A%E5%A4%9A%E3%81%8F%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E6%83%85%E5%A0%B1%E3%82%92%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81-DPLUGANDTRUST_DEBUG_LOGS%3DON%20%E3%81%A7%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%99%E3%81%A6%E3%81%8D%E3%81%AA%E4%B8%80%E6%97%A5%E3%82%92%E3%80%81%3CBR%20%2F%3E%E3%82%AB%E3%83%B3%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E---------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%E8%A8%98%EF%BC%9A%3CBR%20%2F%3E%20-%20%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%8C%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%B8%E3%81%AE%E5%9B%9E%E7%AD%94%E3%81%A7%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%80%8C%E6%AD%A3%E8%A7%A3%E3%81%A8%E3%81%97%E3%81%A6%E3%83%9E%E3%83%BC%E3%82%AF%E3%80%8D%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%EF%BC%81%3CBR%20%2F%3E%20-%20Thread%E3%81%AF%E6%9C%80%E5%BE%8C%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%8B%E3%82%897%E9%80%B1%E9%96%93%E3%83%95%E3%82%A9%E3%83%AD%E3%83%BC%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E4%BB%A5%E9%99%8D%E3%81%AE%E8%BF%94%E4%BF%A1%E3%81%AF%E7%84%A1%E8%A6%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E5%BE%8C%E3%81%BB%E3%81%A9%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%96%B0%E3%81%97%E3%81%84Thread%E3%82%92%E9%96%8B%E3%81%84%E3%81%A6%E3%80%81%E9%96%89%E3%81%98%E3%81%9FThread%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E---------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2246260%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050%20AEAD%20Decryption%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2246260%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EKan_Li%E6%A7%98%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%AFNXP%20S32K314%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%AD%E3%82%B0%E5%8D%B0%E5%88%B7%E3%81%AB%E3%81%AF%E5%A4%9A%E3%81%8F%E3%81%AE%E9%81%85%E5%BB%B6%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E3%81%9D%E3%82%82%E3%81%9D%E3%82%82%20i2c%20%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%8C%E9%81%A9%E5%88%87%E3%81%AB%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%20Plug-and-Trust%20Nano%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%80%81SO%20prj.conf%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3EAEAD%20Deription%20%E3%81%A7%20i2c%20%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%99%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%AF%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%81%E3%83%A3%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2232153%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050%20AEAD%20Decryption%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2232153%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F232520%22%20target%3D%22_blank%22%3E%40Changhawn%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%AD%E3%82%B0%E3%81%AE%E5%8D%B0%E5%88%B7%E3%82%92%E3%82%AA%E3%83%B3%E3%81%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%81%8B%3FZephyr%20%E3%82%92%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AB%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%AF%E3%81%84%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81prj.conf%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E6%AC%A1%E3%81%AE%E6%A7%8B%E6%88%90%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3ECONFIG_LOG%3Dy%3CBR%20%2F%3E%20CONFIG_PLUGANDTRUST_LOG_LEVEL_DBG%3Dy%3CBR%20%2F%3E%20CONFIG_LOG_MODE_IMMEDIATE%3Dy%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%99%E3%81%A6%E3%81%8D%E3%81%AA%E4%B8%80%E6%97%A5%E3%82%92%E3%80%81%3CBR%20%2F%3E%E3%82%AB%E3%83%B3%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E---------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%E8%A8%98%EF%BC%9A%3CBR%20%2F%3E%20-%20%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%8C%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%B8%E3%81%AE%E5%9B%9E%E7%AD%94%E3%81%A7%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%80%8C%E6%AD%A3%E8%A7%A3%E3%81%A8%E3%81%97%E3%81%A6%E3%83%9E%E3%83%BC%E3%82%AF%E3%80%8D%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%EF%BC%81%3CBR%20%2F%3E%20-%20Thread%E3%81%AF%E6%9C%80%E5%BE%8C%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%8B%E3%82%897%E9%80%B1%E9%96%93%E3%83%95%E3%82%A9%E3%83%AD%E3%83%BC%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E4%BB%A5%E9%99%8D%E3%81%AE%E8%BF%94%E4%BF%A1%E3%81%AF%E7%84%A1%E8%A6%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E5%BE%8C%E3%81%BB%E3%81%A9%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%96%B0%E3%81%97%E3%81%84Thread%E3%82%92%E9%96%8B%E3%81%84%E3%81%A6%E3%80%81%E9%96%89%E3%81%98%E3%81%9FThread%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E---------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2249857%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050%20AEAD%20Decryption%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2249857%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EKan_Li%E6%A7%98%3C%2FP%3E%3CP%3Ei2c%20%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%80%81i2c%20%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E3%81%82%E3%82%8B%E7%A8%8B%E5%BA%A6%E8%A7%A3%E6%B1%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81AEAD%20%E5%BE%A9%E5%8F%B7%E5%8C%96%E3%81%AB%E3%81%AF%E3%81%BE%E3%81%A0%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E5%95%8F%E9%A1%8C%E3%81%8C%E4%BD%95%E3%81%A7%E3%81%82%E3%82%8B%E3%81%8B%E3%82%92%E5%88%A4%E6%96%AD%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A8%E3%83%AD%E3%82%B0%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%23KEY_BIT_LEN%20256%20%E3%82%92%E5%AE%9A%E7%BE%A9%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3EsmStatus_t%20Se05x_API_AeadOneShot(pSe05xSession_t%20session_ctx%2C%3CBR%20%2F%3E%20uint32_t%20%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88ID%E3%80%81%3CBR%20%2F%3E%20SE05x_CipherMode_t%20%E6%9A%97%E5%8F%B7%E3%83%A2%E3%83%BC%E3%83%89%E3%80%81%3CBR%20%2F%3E%20const%20uint8_t%20*pInputData%E3%80%81%3CBR%20%2F%3E%20size_t%20%E5%85%A5%E5%8A%9B%E3%83%87%E3%83%BC%E3%82%BF%E9%95%B7%E3%80%81%3CBR%20%2F%3E%20const%20uint8_t%20*pAad%E3%80%81%3CBR%20%2F%3E%20size_t%20aadLen%E3%80%81%3CBR%20%2F%3E%20uint8_t%20*pIV%2C%3CBR%20%2F%3E%20size_t%20IVLen%E3%80%81%3CBR%20%2F%3E%20uint8_t%20*p%E3%82%BF%E3%82%B0%E3%83%87%E3%83%BC%E3%82%BF%E3%80%81%3CBR%20%2F%3E%20size_t%20*p%E3%82%BF%E3%82%B0%E3%83%87%E3%83%BC%E3%82%BF%E9%95%B7%E3%81%95%E3%80%81%3CBR%20%2F%3E%20uint8_t%20*p%E5%87%BA%E5%8A%9B%E3%83%87%E3%83%BC%E3%82%BF%E3%80%81%3CBR%20%2F%3E%20size_t%20*p%E5%87%BA%E5%8A%9B%E3%83%87%E3%83%BC%E3%82%BF%E9%95%B7%E3%80%81%3CBR%20%2F%3E%20const%20SE05x_Cipher_Oper_OneShot_t%20%E6%93%8D%E4%BD%9C)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20smStatus_t%20retStatus%20%3D%20SM_NOT_OK%3B%3CBR%20%2F%3E%20tlvHeader_t%20hdr%20%3D%20%7B%7BkSE05x_CLA%2C%20kSE05x_INS_CRYPTO%2C%20kSE05x_P1_AEAD%2C%20operation%7D%7D%20%3B%3CBR%20%2F%3E%20size_t%20cmdbufLen%20%3D%200%3B%3CBR%20%2F%3E%20uint8_t%20*pCmdbuf%20%3D%20NULL%3B%3CBR%20%2F%3E%20int%20tlvRet%20%3D%200%3B%3CBR%20%2F%3E%20uint8_t%20*pRspbuf%20%3D%20NULL%3B%3CBR%20%2F%3E%20size_t%20rspbufLen%20%3D%20MAX_APDU_BUFFER%3B%3CBR%20%2F%3E%20SE05x_Result_t%20%E7%B5%90%E6%9E%9C%3B%3CBR%20%2F%3E%20uint16_t%20ivlen16%20%3D%200%3B%3CBR%20%2F%3E%20size_t%20ivlen32%20%3D%20IVLen%3B%3CBR%20%2F%3E%20size_t%20rspIndex%20%3D%200%3B%3C%2FP%3E%3CP%3EpCmdbuf%20%3D%20%26amp%3Bsession_ctx-%26gt%3Bapdu_buffer%5B0%5D%3B%3CBR%20%2F%3E%20pRspbuf%20%3D%20%26amp%3Bsession_ctx-%26gt%3Bapdu_buffer%5B0%5D%3B%3C%2FP%3E%3CP%3E%EF%BC%88IVLen%20%26gt%3B%20UINT16_MAX%EF%BC%89%E3%81%AE%E5%A0%B4%E5%90%88%20%7B%3CBR%20%2F%3E%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%A2%E3%83%83%E3%83%97%E3%81%B8%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20ivlen16%20%3D%20(uint16_t)IVLen%3B%3CBR%20%2F%3E%20tlvRet%20%3D%20TLVSET_U32(%22%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88ID%22%2C%20%26amp%3BpCmdbuf%2C%20%26amp%3BcmdbufLen%2C%20kSE05x_TAG_1%2C%20%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88ID)%3B%3CBR%20%2F%3E%200%20!%3D%20tlvRet%20%E3%81%AE%E5%A0%B4%E5%90%88%20%7B%3CBR%20%2F%3E%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%A2%E3%83%83%E3%83%97%E3%81%B8%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%7D%3C%2FP%3E%3CP%3EtlvRet%20%3D%20TLVSET_CipherMode(%22cipherMode%22%2C%3CBR%20%2F%3E%20%26amp%3Bp%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%2C%3CBR%20%2F%3E%20%26amp%3BcmdbufLen%2C%3CBR%20%2F%3E%20kSE05x_TAG_2%E3%80%81%3CBR%20%2F%3E%20((%E6%9A%97%E5%8F%B7%E3%83%A2%E3%83%BC%E3%83%89%20%3D%3D%20kSE05x_CipherMode_AES_GCM_INT_IV)%20%3FkSE05x_CipherMode_AES_GCM%20%3A%20%E6%9A%97%E5%8F%B7%E3%83%A2%E3%83%BC%E3%83%89))%3B%3C%2FP%3E%3CP%3E0%20!%3D%20tlvRet%20%E3%81%AE%E5%A0%B4%E5%90%88%20%7B%3CBR%20%2F%3E%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%A2%E3%83%83%E3%83%97%E3%81%B8%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20tlvRet%20%3D%20TLVSET_u8bufOptional(%22inputData%22%2C%20%26amp%3BpCmdbuf%2C%20%26amp%3BcmdbufLen%2C%20kSE05x_TAG_3%2C%20pInputData%2C%20inputDataLen)%3B%3CBR%20%2F%3E%200%20!%3D%20tlvRet%20%E3%81%AE%E5%A0%B4%E5%90%88%20%7B%3CBR%20%2F%3E%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%A2%E3%83%83%E3%83%97%E3%81%B8%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20tlvRet%20%3D%20TLVSET_u8bufOptional(%22AdditionalData%22%2C%20%26amp%3BpCmdbuf%2C%20%26amp%3BcmdbufLen%2C%20kSE05x_TAG_4%2C%20pAad%2C%20aadLen)%3B%3CBR%20%2F%3E%200%20!%3D%20tlvRet%20%E3%81%AE%E5%A0%B4%E5%90%88%20%7B%3CBR%20%2F%3E%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%A2%E3%83%83%E3%83%97%E3%81%B8%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%7D%3C%2FP%3E%3CP%3E%E6%9A%97%E5%8F%B7%E3%83%A2%E3%83%BC%E3%83%89%20%3D%3D%20kSE05x_CipherMode_AES_GCM%20%E3%81%AE%E5%A0%B4%E5%90%88%20%7C%7C%3CBR%20%2F%3E%20((%E6%9A%97%E5%8F%B7%E3%83%A2%E3%83%BC%E3%83%89%20%3D%3D%20kSE05x_CipherMode_AES_GCM_INT_IV)%20%26amp%3B%26amp%3B%20(%E6%93%8D%E4%BD%9C%20%3D%3D%20kSE05x_Cipher_Oper_OneShot_Decrypt)))%20%7B%3CBR%20%2F%3E%20tlvRet%20%3D%20TLVSET_u8bufOptional(%22IV%22%2C%20%26amp%3BpCmdbuf%2C%20%26amp%3BcmdbufLen%2C%20kSE05x_TAG_5%2C%20pIV%2C%20IVLen)%3B%3CBR%20%2F%3E%200%20!%3D%20tlvRet%20%E3%81%AE%E5%A0%B4%E5%90%88%20%7B%3CBR%20%2F%3E%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%A2%E3%83%83%E3%83%97%E3%81%B8%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%E3%81%9D%E3%82%8C%E4%BB%A5%E5%A4%96%20%7B%3CBR%20%2F%3E%20tlvRet%20%3D%20TLVSET_U16(%22IVLen%22%2C%20%26amp%3BpCmdbuf%2C%20%26amp%3BcmdbufLen%2C%20kSE05x_TAG_5%2C%20ivlen16)%3B%3CBR%20%2F%3E%200%20!%3D%20tlvRet%20%E3%81%AE%E5%A0%B4%E5%90%88%20%7B%3CBR%20%2F%3E%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%A2%E3%83%83%E3%83%97%E3%81%B8%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20if%20(%E6%93%8D%E4%BD%9C%20%3D%3D%20kSE05x_Cipher_Oper_OneShot_Decrypt)%20%7B%3CBR%20%2F%3E%20pTagDataLen%20!%3D%20NULL%20%E3%81%AE%E5%A0%B4%E5%90%88%20%7B%3CBR%20%2F%3E%20%2F%2F%20__printf(%22%25s%20tgaDataLen%20is%20selected%5Cr%5Cn%22%2C%20__%E9%96%A2%E6%95%B0__)%3B%3CBR%20%2F%3E%20%2F%2Fif%20(pTagDataLen%20%26gt%3B%200%20)%20%7B%3CBR%20%2F%3E%20tlvRet%20%3D%20TLVSET_u8bufOptional(%22%E3%82%BF%E3%82%B0%22%2C%20%26amp%3BpCmdbuf%2C%20%26amp%3BcmdbufLen%2C%20kSE05x_TAG_6%2C%20pTagData%2C%20*pTagDataLen)%3B%3CBR%20%2F%3E%200%20!%3D%20tlvRet%20%E3%81%AE%E5%A0%B4%E5%90%88%20%7B%3CBR%20%2F%3E%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%A2%E3%83%83%E3%83%97%E3%81%B8%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20%7D%3C%2FP%3E%3CP%3E%230%E3%81%AE%E5%A0%B4%E5%90%88%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%20uint8_t%20*temp%20%3D%20session_ctx-%26gt%3Bapdu_buffer%3B%3CBR%20%2F%3E%20__printf(%22APDU%20TX%20len%3D%25zu%3A%5Cn%22%2C%20cmdbufLen)%3B%3CBR%20%2F%3E%20(size_t%20i%3D0%3Bi%3CCMDBUFLEN%3E%3C%2FCMDBUFLEN%3E__%E5%A0%B4%E5%90%88%20printf(%22%5Cn%22)%3B%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20%23endif%3CBR%20%2F%3E%20%2F%2FretStatus%20%3D%20DoAPDUTxRx_s_Case4_ext(session_ctx%2C%20%26amp%3Bhdr%2C%20session_ctx-%26gt%3Bapdu_buffer%2C%20cmdbufLen%2C%20pRspbuf%2C%20%26amp%3BrspbufLen)%3B%3CBR%20%2F%3E%20retStatus%20%3D%20DoAPDUTxRx(session_ctx%2C%20%26amp%3Bhdr%2C%20session_ctx-%26gt%3Bapdu_buffer%2C%20cmdbufLen%2C%20session_ctx-%26gt%3Bapdu_buffer%2C%20%26amp%3BrspbufLen%2C%201)%3B%3CBR%20%2F%3E%20if%20(retStatus%20%3D%3D%20SM_OK)%20%7B%3CBR%20%2F%3E%20__printf(%22%25s%20SE050%20AEAD%20Decrypt%20Ok...%5Cr%5Cn%22%2C%20__%20func%20__)%3B%3CBR%20%2F%3E%7B%3CBR%20%2F%3E__%20printf(%22APDU%20RSP%20len%3D%25d%3A%5Cn%22%2C%20rspbufLen)%3B%3CBR%20%2F%3E%20for%20(size_t%20i%3D0%3B%20i%20%26lt%3B%20rspbufLen%3B%20i%2B%2B)%20__printf(%22%2502X%20%22%2C%20pRspbuf%5Bi%5D)%3B%3CBR%20%2F%3E__%20printf(%22%5Cn%22)%3B%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20retStatus%20%3D%20SM_NOT_OK%3B%3CBR%20%2F%3E%E5%85%A5%E5%8A%9B%E3%83%87%E3%83%BC%E3%82%BF%E9%95%B7%E3%81%8C%200%20%E3%81%AE%E5%A0%B4%E5%90%88%20%7B%3CBR%20%2F%3E%20tlvRet%20%3D%20tlvGet_u8buf(pRspbuf%E3%80%81%26amp%3BrspIndex%E3%80%81rspbufLen%E3%80%81kSE05x_TAG_1%E3%80%81pOutputData%E3%80%81pOutputDataLen)%3B%3CBR%20%2F%3E%20__printf(%22AEAD%20%E5%BE%A9%E5%8F%B7%E5%8C%96%20RSP%20%E3%82%BF%E3%82%B01%3D%25d%3A%5Cn%22%2C%20tlvRet)%3B%3CBR%20%2F%3E%200%20!%3D%20tlvRet%20%E3%81%AE%E5%A0%B4%E5%90%88%20%7B%3CBR%20%2F%3E%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%A2%E3%83%83%E3%83%97%E3%81%B8%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20if%20(%E6%93%8D%E4%BD%9C%20%3D%3D%20kSE05x_Cipher_Oper_OneShot_Encrypt)%20%7B%3CBR%20%2F%3E%20tlvRet%20%3D%20tlvGet_u8buf(pRspbuf%E3%80%81%26amp%3BrspIndex%E3%80%81rspbufLen%E3%80%81kSE05x_TAG_2%E3%80%81pTagData%E3%80%81pTagDataLen)%3B%3CBR%20%2F%3E%20__printf(%22AEAD%20%E5%BE%A9%E5%8F%B7%E5%8C%96%20RSP%20%E3%82%BF%E3%82%B02%3D%25d%3A%5Cn%22%2C%20tlvRet)%3B%3CBR%20%2F%3E%200%20!%3D%20tlvRet%20%E3%81%AE%E5%A0%B4%E5%90%88%20%7B%3CBR%20%2F%3E%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%A2%E3%83%83%E3%83%97%E3%81%B8%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20if%20(%E6%93%8D%E4%BD%9C%20%3D%3D%20kSE05x_Cipher_Oper_OneShot_Decrypt)%20%7B%3CBR%20%2F%3E%20tlvRet%20%3D%20tlvGet_Result(pRspbuf%E3%80%81%26amp%3BrspIndex%E3%80%81rspbufLen%E3%80%81kSE05x_TAG_2%E3%80%81%26amp%3Bresult)%3B%3CBR%20%2F%3E%200%20!%3D%20tlvRet%20%E3%81%AE%E5%A0%B4%E5%90%88%20%7B%3CBR%20%2F%3E%20__printf(%22AEAD%20%E5%BE%A9%E5%8F%B7%E5%8C%96%20RSP%20tlvRet%3D%25d%3A%5Cn%22%2C%20tlvRet)%3B%3CBR%20%2F%3E%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%A2%E3%83%83%E3%83%97%E3%81%B8%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20if%20(%E7%B5%90%E6%9E%9C%20!%3D%20kSE05x_Result_SUCCESS)%20%7B%3CBR%20%2F%3E%20__printf(%22APDU%20%E5%BE%A9%E5%8F%B7%E5%8C%96%20RSP%20%E7%B5%90%E6%9E%9C%20%3D%20%25d%3A%5Cn%22%2C%20%E7%B5%90%E6%9E%9C)%3B%3CBR%20%2F%3E%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%A2%E3%83%83%E3%83%97%E3%81%B8%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20if%20((%E6%93%8D%E4%BD%9C%20%3D%3D%20kSE05x_Cipher_Oper_OneShot_Encrypt)%20%26amp%3B%26amp%3B%20(%E6%9A%97%E5%8F%B7%E3%83%A2%E3%83%BC%E3%83%89%20%3D%3D%20kSE05x_CipherMode_AES_GCM_INT_IV))%20%7B%3CBR%20%2F%3E%20tlvRet%20%3D%20tlvGet_u8buf(pRspbuf%2C%20%26amp%3BrspIndex%2C%20rspbufLen%2C%20kSE05x_TAG_3%2C%20pIV%2C%20%26amp%3Bivlen32)%3B%3CBR%20%2F%3E%200%20!%3D%20tlvRet%20%E3%81%AE%E5%A0%B4%E5%90%88%20%7B%3CBR%20%2F%3E%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%A2%E3%83%83%E3%83%97%E3%81%B8%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20if%20((rspIndex%20%2B%202)%20%3D%3D%20rspbufLen)%20%7B%3CBR%20%2F%3E%20retStatus%20%3D%20(smStatus_t)((pRspbuf%5BrspIndex%5D%20%26lt%3B%26lt%3B%20%3CLI-EMOJI%20id%3D%22lia_smiling-face-with-sunglasses%22%20title%3D%22%3Asmiling_face_with_sunglasses%3A%22%3E%3C%2FLI-EMOJI%3E%20%7C%20(pRspbuf%5BrspIndex%20%2B%201%5D))%3B%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%E6%8E%83%E9%99%A4%EF%BC%9A%3CBR%20%2F%3E%20retStatus%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%7D%3C%2FP%3E%3CP%3Evoid%20ex_sss_aead_decrypt(void)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20sss_status_t%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20kStatus_SSS_Success%3B%3CBR%20%2F%3E%20sss_algorithm_t%20%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%3B%3CBR%20%2F%3E%20sss_mode_t%20%E3%83%A2%E3%83%BC%E3%83%89%3B%3CBR%20%2F%3E%20%2F*%20clang-format%20%E3%82%AA%E3%83%95%20*%2F%3CBR%20%2F%3E%20%23ifdef%20ADED_DECRYPT_TEST%3CBR%20%2F%3E%20uint8_t%20aead_srcData%5B16%5D%20%3D%20%7B%200x8f%2C%200xd9%2C%200x64%2C%200xc%2C%200xa9%2C%200x95%2C%200xf1%2C%200x98%2C%200x86%2C%200xcf%2C%200xd6%2C%200xe9%2C%200xde%2C%200xd0%2C%200x37%2C%200x1f%20%7D%3B%3C%2FP%3E%3CP%3Euint8_t%20aead_keystring%5BKEY_BIT_LEN%20%2F%208%5D%20%3D%20%7B%200xad%2C%200x4f%2C%200x6f%2C%200xaa%2C%200x5c%2C%200x67%2C%200xf8%2C%200x94%2C%200xdc%2C%200x50%2C%200xdd%2C%200x3e%2C%3CBR%20%2F%3E%200xf2%E3%80%810x82%E3%80%810xe3%E3%80%810xf9%E3%80%810x65%E3%80%810x34%E3%80%810xf8%E3%80%810x0f%E3%80%810xdc%E3%80%810x46%E3%80%810x65%E3%80%810x1b%E3%80%810xb5%E3%80%810x9a%E3%80%810x01%E3%80%810x69%E3%80%810xce%E3%80%810xfb%E3%80%810xa8%E3%80%810xec%7D%3B%3C%2FP%3E%3CP%3E%EF%BC%83%E3%81%9D%E3%82%8C%E4%BB%A5%E5%A4%96%3CBR%20%2F%3Euint8_t%20aead_srcData%5B16%5D%20%3D%20%7B%200x48%20%2C0x45%20%2C0x4c%20%2C0x4c%20%2C0x4f%20%2C0x48%20%2C0x45%20%2C0x4c%20%2C0x4c%20%2C0x4f%20%2C0x48%20%2C0x45%20%2C0x4c%20%2C0x4c%20%2C0x4f%20%2C0x31%20%7D%3B%20%2F*HELLOHELLOHELLO1*%2F%3CBR%20%2F%3E%20uint8_t%20aead_keystring%5BKEY_BIT_LEN%20%2F%208%5D%20%3D%20%7B%200x48%20%2C0x45%20%2C0x4c%20%2C0x4c%20%2C0x4f%20%2C0x48%20%2C0x45%20%2C0x4c%20%2C0x4c%20%2C0x4f%20%2C0x48%20%2C0x45%20%2C0x4c%20%2C0x4c%20%2C0x4f%20%2C0x31%20%7D%3B%20%2F*HELLOHELLOHELLO1*%2F%3CBR%20%2F%3E%20%23endif%3CBR%20%2F%3E%20uint8_t%20%E5%AE%9B%E5%85%88%E3%83%87%E3%83%BC%E3%82%BF%5B16%5D%20%3D%20%7B0%2C%7D%3B%3CBR%20%2F%3E%20size_t%20destDataLen%20%3D%20sizeof(destData)%3B%3C%2FP%3E%3CP%3E%23ifdef%20ADED_DECRYPT_TEST%3CBR%20%2F%3E%20uint8_t%20aead_iv%5B12%5D%20%3D%20%7B0x55%2C%200x6a%2C%200xe5%2C%200xa9%2C%200x17%2C%200xce%2C%200xa%2C%200xd%2C%200x27%2C%200x3f%2C%200x9f%2C%200xaa%7D%3B%3CBR%20%2F%3E%20size_t%20ivlen%20%3D%2012%3B%3CBR%20%2F%3E%20%EF%BC%83%E3%81%9D%E3%82%8C%E4%BB%A5%E5%A4%96%3CBR%20%2F%3Euint8_t%20aead_iv%5B16%5D%20%3D%20%7B0x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200xfd%2C%200x15%2C%200x71%2C%200x99%2C%200x32%2C%200xd3%2C%200x56%2C%200x90%7D%3B%3C%2FP%3E%3CP%3Esize_t%20ivlen%20%3D%2016%3B%3CBR%20%2F%3E%20%23endif%3CBR%20%2F%3E%20uint32_t%20keyId%20%3D%20MAKE_TEST_ID(%20__LINE__%20)%3B%3CBR%20%2F%3E%20sss_key_part_t%20%E3%82%AD%E3%83%BC%E3%83%91%E3%83%BC%E3%83%88%3B%3CBR%20%2F%3E%20sss_cipher_type_t%20%E6%9A%97%E5%8F%B7%E3%82%BF%E3%82%A4%E3%83%97%3B%3CBR%20%2F%3E%20size_t%20keyByteLenMax%20%3D%20KEY_BIT_LEN%2F8%3B%3CBR%20%2F%3E%20sss_object_t%20%E3%82%AD%E3%83%BC%20%3D%20%7B%200%20%7D%3B%3CBR%20%2F%3E%20sss_se05x_aead_t%20ctx_aead_encrypt%20%3D%20%7B%200%20%7D%3B%3C%2FP%3E%3CP%3E%23ifdef%20ADED_DECRYPT_TEST%3CBR%20%2F%3E%20size_t%20TAG_SIZE%20%3D%2016%3B%3CBR%20%2F%3E%20uint8_t%20%E3%82%BF%E3%82%B0%5B16%5D%20%3D%20%7B0x99%2C%200xc5%2C%200x3%2C%200xaa%2C%200x7c%2C%200x6d%2C%3CBR%20%2F%3E%200x37%E3%80%810x52%E3%80%810x64%E3%80%810x6e%E3%80%810x62%E3%80%810x47%E3%80%810xe0%E3%80%810x3a%E3%80%810x80%E3%80%810xc8%7D%3B%3CBR%20%2F%3E%20uint8_t%20aad%5B5%5D%20%3D%20%7B0x17%2C%200x3%2C%200x3%2C%200x0%2C%200x20%7D%3B%3CBR%20%2F%3E%20%2F%2Fuint8_t%20*aad%20%3D(uint8_t*)%22%E8%BF%BD%E5%8A%A0%E3%81%AE%E8%AA%8D%E8%A8%BC%E3%83%87%E3%83%BC%E3%82%BF%22%3B%3CBR%20%2F%3E%20%EF%BC%83%E3%81%9D%E3%82%8C%E4%BB%A5%E5%A4%96%3CBR%20%2F%3Esize_t%20TAG_SIZE%20%3D%2016%3B%3CBR%20%2F%3E%20uint8_t%20%E3%82%BF%E3%82%B0%5BTAG_SIZE%5D%3B%3CBR%20%2F%3E%20uint8_t%20*aad%20%3D(uint8_t*)%22%E8%BF%BD%E5%8A%A0%E3%81%AE%E8%AA%8D%E8%A8%BC%E3%83%87%E3%83%BC%E3%82%BF%22%3B%3CBR%20%2F%3E%20%23endif%3CBR%20%2F%3E%20size_t%20aadSize%20%3D%20strlen((char*)aad)%3B%3CBR%20%2F%3E%20%2F%2Fuint8_t%20*aad%20%3D%20NULL%3B%3CBR%20%2F%3E%20%2F%2Fsize_t%20aadSize%20%3D%200%3B%3C%2FP%3E%3CP%3EpSe05xSession_t%20p_session_ctx%20%3D%20%26amp%3Bse05x_session%3B%3CBR%20%2F%3E%20SE05x_CipherMode_t%20%E6%9A%97%E5%8F%B7%E3%83%A2%E3%83%BC%E3%83%89%20%3D%20kSE05x_CipherMode_AES_GCM%3B%3CBR%20%2F%3E%20%23ifdef%20ADED_DECRYPT_TEST%3CBR%20%2F%3E%20SE05x_Cipher_Oper_OneShot_t%20%E3%82%AA%E3%83%9A%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%BF%E3%82%A4%E3%83%97%20%3D%20kSE05x_Cipher_Oper_OneShot_Decrypt%3B%3CBR%20%2F%3E%20%EF%BC%83%E3%81%9D%E3%82%8C%E4%BB%A5%E5%A4%96%3CBR%20%2F%3ESE05x_Cipher_Oper_OneShot_t%20OperType%20%3D%20kSE05x_Cipher_Oper_OneShot_Encrypt%3B%20%2F%2F%20%3A%20kSE05x_Cipher_Oper_OneShot_Decrypt%3B%3CBR%20%2F%3E%20%23endif%3CBR%20%2F%3E%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%20%3D%20kAlgorithm_SSS_AES_GCM%3B%3CBR%20%2F%3E%E3%82%AD%E3%83%BC%E3%83%91%E3%83%BC%E3%83%88%20%3D%20kSSS_KeyPart_Default%3B%3CBR%20%2F%3E%E6%9A%97%E5%8F%B7%E3%82%BF%E3%82%A4%E3%83%97%20%3D%20kSSS_CipherType_AES%3B%3CBR%20%2F%3E%20%23ifdef%20ADED_DECRYPT_TEST%3CBR%20%2F%3E%E3%83%A2%E3%83%BC%E3%83%89%20%3D%20kMode_SSS_Decrypt%3B%3CBR%20%2F%3E%20%EF%BC%83%E3%81%9D%E3%82%8C%E4%BB%A5%E5%A4%96%3CBR%20%2F%3E%E3%83%A2%E3%83%BC%E3%83%89%20%3D%20kMode_SSS_Encrypt%3B%3CBR%20%2F%3E%20%23endif%3CBR%20%2F%3E%20%2F*%20doc%3Aex_sss_symmetric-allocate-key%20%E3%81%AE%E9%96%8B%E5%A7%8B%20*%2F%3CBR%20%2F%3E%20%2F*%20%E6%9A%97%E5%8F%B7%E5%8C%96%E3%81%AE%E5%89%8D%E6%8F%90%E6%9D%A1%E4%BB%B6%20*%2F%3C%2FP%3E%3CP%3E%2F%2F%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20Se05x_API_SessionOpen(p_session_ctx)%3B%3C%2FP%3E%3CP%3Ep_session_ctx%20%3D%20se05x_get_session()%3B%3CBR%20%2F%3E%E3%82%AD%E3%83%BC.%E3%82%BB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%20%3D%20p_session_ctx%3B%3C%2FP%3E%3CP%3E(key.session%20%3D%3D%20NULL)%E3%81%AE%E5%A0%B4%E5%90%88%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%20__printf(%22%E3%82%BB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%5Cr%5Cn%22)%3B%3CBR%20%2F%3E%E6%88%BB%E3%82%8B%3B%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20%2F%2F%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20sss_key_object_allocate_handle(%26amp%3Bkey%2C%20keyId%2C%20keyPart%2C%20cipherType%2C%20keyByteLenMax%2C%20kKeyObject_Mode_Persistent)%3B%3CBR%20%2F%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20sss_key_object_allocate_handle(%26amp%3Bkey%2C%20keyId%2C%20keyPart%2C%20cipherType%2C%20keyByteLenMax%2C%20kKeyObject_Mode_Persistent)%3B%3CBR%20%2F%3E%20if%20(%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20!%3D%20true)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20__printf(%22sss_key_object_allocate_handle%20%E3%81%8C%20%25x%5Cr%5Cn%20%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%22%2C%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9)%3B%3CBR%20%2F%3E%E6%88%BB%E3%82%8B%3B%3CBR%20%2F%3E%20%7D%3C%2FP%3E%3CP%3E%2F%2F%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20sss_key_store_set_key(%26amp%3BpCtx-%26gt%3Bks%2C%20%26amp%3Bkey%2C%20keystring%2C%20sizeof(keystring)%2C%20sizeof(keystring)%20*%208%2C%20NULL%2C%200)%3B%3CBR%20%2F%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20sss_se05x_key_store_set_key(%26amp%3Bkey%2C%20aead_keystring%2C%20sizeof(aead_keystring)%2C%20sizeof(aead_keystring)%20*%208)%3B%3CBR%20%2F%3E%20if%20(%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20!%3D%20kStatus_SSS_Success)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20__printf(%22sss_se05x_key_store_set_key%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%200x%25x%5Cr%5Cn%22%2C%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9)%3B%3CBR%20%2F%3E%E6%88%BB%E3%82%8B%3B%3CBR%20%2F%3E%20%7D%3C%2FP%3E%3CP%3E%2F*%E6%9A%97%E5%8F%B7%E5%8C%96%E3%82%92%E8%A1%8C%E3%81%86*%2F%3C%2FP%3E%3CP%3E%231%E3%81%AE%E5%A0%B4%E5%90%88%3CBR%20%2F%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20Se05x_API_AeadOneShot(p_session_ctx%2C%20keyId%2C%20cipherMode%2C%20aead_srcData%2C%3CBR%20%2F%3E%20destDataLen%E3%80%81aad%E3%80%81aadSize%E3%80%81aead_iv%E3%80%81ivlen%E3%80%81tag%E3%80%81%26amp%3BTAG_SIZE%E3%80%81destData%E3%80%81%26amp%3BdestDataLen%E3%80%81OperType)%3B%3CBR%20%2F%3E%20%2F%2Faeadoneshotlog%20%3D%20false%3B%3CBR%20%2F%3E%20if%20(%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20!%3D%20SM_OK)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20sm_dbg_printf(%22Se05x_API_AeadOneShot%20%E3%81%8C%20%25x%5Cr%5Cn%20%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%22%2C%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9)%3B%3CBR%20%2F%3E%E6%88%BB%E3%82%8B%3B%3CBR%20%2F%3E%20%7D%3C%2FP%3E%3CP%3E%2F*%20doc%3Aex_sss_aead-encrypt%20%E3%81%AE%E7%B5%82%E4%BA%86%20*%2F%3C%2FP%3E%3CP%3E__printf(%22AEAD%20%E6%9A%97%E5%8F%B7%E5%8C%96%2F%E5%BE%A9%E5%8F%B7%E5%8C%96%E3%81%AB%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F!!!%22)%3B%3CBR%20%2F%3E%20%23else%20%2F*%20AEAD%20%E3%83%9E%E3%83%AB%E3%83%81%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%20*%2F%3CBR%20%2F%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20se05x_gcm_encrypt_multistep(p_session_ctx%2C%3CBR%20%2F%3E%20keyId%E3%80%81aead_srcData%E3%80%81destDataLen%E3%80%81%3CBR%20%2F%3E%20aad%E3%80%81aadSize%E3%80%81aead_iv%E3%80%81ivlen%E3%80%81destData%E3%80%81%26amp%3BdestDataLen%E3%80%81%3CBR%20%2F%3E%E3%82%BF%E3%82%B0%E3%80%81%26amp%3BTAG_SIZE%E3%80%81OperType)%3B%3C%2FP%3E%3CP%3Eaeadoneshotlog%20%3D%20false%3B%3CBR%20%2F%3E%20if%20(%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20!%3D%20SM_OK)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20sm_dbg_printf(%22se05x_gcm_encrypt_multistep%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20%25x%5Cr%5Cn%22%2C%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9)%3B%3CBR%20%2F%3E%E6%88%BB%E3%82%8B%3B%3CBR%20%2F%3E%20%7D%3C%2FP%3E%3CP%3E%2F*%20doc%3Aex_sss_aead-encrypt%20%E3%81%AE%E7%B5%82%E4%BA%86%20*%2F%3C%2FP%3E%3CP%3E__printf(%22%E6%9A%97%E5%8F%B7%E5%8C%96%E3%81%AB%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F!!!%22)%3B%3C%2FP%3E%3CP%3E%23endif%3C%2FP%3E%3CP%3E%E6%8E%83%E9%99%A4%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%88%BB%E3%82%8B%3B%3CBR%20%2F%3E%20%7D%3C%2FP%3E%3CP%3E%26lt%3B%20LOG%20%26gt%3B%3CBR%20%2F%3E%5BINF%5D%5Bcli%5D%20SE05x%E3%81%B8%E3%81%AE%E3%82%BB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E9%96%8B%E3%81%8F%3C%2FP%3E%3CP%3E%5BINF%5D%5Bcli%5D%20%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A2%E3%83%B3%E3%83%89%E3%83%88%E3%83%A9%E3%82%B9%E3%83%88%20%E3%83%8A%E3%83%8E%20%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%20-%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%201.5.4%3C%2FP%3E%3CP%3E%5BSE_APDU%5D%20SymmKey%20keyid(0xef0003d1)%20%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3ESe05x_API_AeadOneShot%20SE050%20AEAD%20%E5%BE%A9%E5%8F%B7%E5%8C%96%E6%88%90%E5%8A%9F...%3CBR%20%2F%3E%20APDU%20RSP%20%E9%95%B7%E3%81%95%3D7%3A%3CBR%20%2F%3E%20%3CSTRONG%3E42%2082%2000%2001%2002%2090%2000%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3EAEAD%20%E5%BE%A9%E5%8F%B7%E5%8C%96%20RSP%20%E3%82%BF%E3%82%B01%3D1%3A%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%5B409452%20%E3%83%9F%E3%83%AA%E7%A7%92%5D%20Se05x_API_AeadOneShot%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20ffff%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2250798%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050%20AEAD%20Decryption%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2250798%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F232520%22%20target%3D%22_blank%22%3E%40Changhawn%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%AA%8D%E8%A8%BC%E3%82%BF%E3%82%B0%E3%81%AB%E3%82%88%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A8%E6%80%9D%E3%82%8F%E3%82%8C%E3%81%BE%E3%81%99%E3%81%AE%E3%81%A7%E3%80%81%E8%A9%B3%E7%B4%B0%E3%81%AF%E4%B8%8B%E8%A8%98%E3%82%92%E3%81%94%E5%8F%82%E7%85%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Kan_Li_0-1764306364604.png%22%20style%3D%22width%3A%20652px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1764306364604.png%22%20style%3D%22width%3A%20652px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1764306364604.png%22%20style%3D%22width%3A%20652px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1764306364604.png%22%20style%3D%22width%3A%20652px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1764306364604.png%22%20style%3D%22width%3A%20652px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1764306364604.png%22%20style%3D%22width%3A%20652px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1764306364604.png%22%20style%3D%22width%3A%20652px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F367698i66BFBEB7A08DB2A9%2Fimage-dimensions%2F652x327%3Fv%3Dv2%22%20width%3D%22652%22%20height%3D%22327%22%20role%3D%22button%22%20title%3D%22Kan_Li_0-1764306364604.png%22%20alt%3D%22Kan_Li_0-1764306364604.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EKan_Li_0-1764306364604.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%99%E3%81%A6%E3%81%8D%E3%81%AA%E4%B8%80%E6%97%A5%E3%82%92%E3%80%81%3CBR%20%2F%3E%E3%82%AB%E3%83%B3%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E---------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%E8%A8%98%EF%BC%9A%3CBR%20%2F%3E%20-%20%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%8C%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%B8%E3%81%AE%E5%9B%9E%E7%AD%94%E3%81%A7%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%80%8C%E6%AD%A3%E8%A7%A3%E3%81%A8%E3%81%97%E3%81%A6%E3%83%9E%E3%83%BC%E3%82%AF%E3%80%8D%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%EF%BC%81%3CBR%20%2F%3E%20-%20Thread%E3%81%AF%E6%9C%80%E5%BE%8C%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%8B%E3%82%897%E9%80%B1%E9%96%93%E3%83%95%E3%82%A9%E3%83%AD%E3%83%BC%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E4%BB%A5%E9%99%8D%E3%81%AE%E8%BF%94%E4%BF%A1%E3%81%AF%E7%84%A1%E8%A6%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E5%BE%8C%E3%81%BB%E3%81%A9%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%96%B0%E3%81%97%E3%81%84Thread%E3%82%92%E9%96%8B%E3%81%84%E3%81%A6%E3%80%81%E9%96%89%E3%81%98%E3%81%9FThread%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E---------------------------------------------------------------------------------%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2252720%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050%20AEAD%20Decryption%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2252720%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%A6%AA%E6%84%9B%E3%81%AA%E3%82%8BKan_Li%E6%A7%98%E3%80%82%3C%2FP%3E%3CP%3EAPDU%20%E3%83%A6%E3%83%8B%E3%83%83%E3%83%88%20%E3%82%B5%E3%82%A4%E3%82%BA%E3%82%92%202400%20%E3%81%AB%E5%A2%97%E3%82%84%E3%81%97%E3%80%81%E4%BB%A5%E5%89%8D%E3%81%A8%E5%90%8C%E6%A7%98%E3%81%AB%E3%80%81Multistep%20AEAD%20Decrypt%20%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%20Oneshot%20%E3%81%A7%E3%83%86%E3%82%B9%E3%83%88%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81SE050%20%E3%83%81%E3%83%83%E3%83%97%E3%81%AF%E6%AC%A1%E3%81%AE%E3%83%AD%E3%82%B0%E3%81%A7%E5%BF%9C%E7%AD%94%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ESM_ERR_WRONG_LENGTH%20(0x6700)%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%A1%E3%82%89%E3%82%82%E3%81%94%E7%A2%BA%E8%AA%8D%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%81%E3%83%A3%E3%83%B3%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%26lt%3B%20%EB%A1%9C%EA%B7%B8%20%26gt%3B%3C%2FP%3E%3CP%3E..%2Fmbedtls%2Fmbedtls%2Flibrary%2Fssl_msg.c%3A1520%3A%20%3D%26gt%3B%20%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%92%E5%BE%A9%E5%8F%B7%E5%8C%96%3CBR%20%2F%3Embedtls_ssl_decrypt_buf%20data_len(16)%20%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%9F%E3%82%BF%E3%82%B0(16)%3A%3A%3CBR%20%2F%3E%2014%20b0%20cf%204b%2029%202c%20c2%20a0%201c%2083%20d9%20e9%2092%2047%2065%20f1%3CBR%20%2F%3E%20mbedtls_cipher_aead_decrypt%20%E6%9A%97%E5%8F%B7%20ctx(20428900)%20%E3%83%A2%E3%83%BC%E3%83%89%206%E3%80%81tag_len%2016%E3%80%81ilen(16)%3CBR%20%2F%3E%20%5BINF%5D%5Bdevtask%5D%20%E6%9A%97%E5%8F%B7%20Aead%20OneGo%20%E9%96%8B%E5%A7%8B%3A0x20428920%20%E3%82%B5%E3%82%A4%E3%82%BA%3A16%20%E6%9A%97%E5%8F%B7%E3%83%A2%E3%83%BC%E3%83%89%3A0xb0%E3%80%81OP%20%E3%82%BF%E3%82%A4%E3%83%97%3A0x38%3CBR%20%2F%3E%20%5BINF%5D%5Bdevtask%5D%20%E3%82%AD%E3%83%BCID%3A%200xef00050e%3CBR%20%2F%3E%3CBR%20%2F%3E%20%5BINF%5D%5Bdevtask%5D%20aadLen%3A%205%3A%3CBR%20%2F%3E%2017%203%203%200%2020%3CBR%20%2F%3E%20%5BINF%5D%5Bdevtask%5D%20nonceLen%3A%2012%3A%3CBR%20%2F%3E%20a2%203c%2082%2054%2067%20a9%2029%20d2%20aa%2069%2099%20ef%3CBR%20%2F%3E%20%5BINF%5D%5Bdevtask%5D%20%E3%82%BF%E3%82%B0%E9%95%B7%3A%2016%3A%3CBR%20%2F%3E%2014%20b0%20cf%204b%2029%202c%20c2%20a0%201c%2083%20d9%20e9%2092%2047%2065%20f1%3CBR%20%2F%3E%20%5BINF%5D%5Bdevtask%5D%20srcData(%E6%9A%97%E5%8F%B7%E6%96%87)%3A%2016%3A%3CBR%20%2F%3E%20%5BINF%5D%5Bdevtask%5D%20dstData(%E3%83%97%E3%83%AC%E3%83%BC%E3%83%B3%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88)%3A%2016%3A%3CBR%20%2F%3E%20%5B26093%20%E3%83%9F%E3%83%AA%E7%A7%92%5D%20APDU%20TX%20%E9%95%B7%E3%81%95%3D75%3A%3CBR%20%2F%3E%20%5B26099%20ms%5D%20%E9%80%81%E5%8F%97%E4%BF%A1%E3%83%87%E3%83%BC%E3%82%BF%E3%83%9D%E3%82%A4%E3%83%B3%E3%82%BF%200x0x204133cc%20%E9%95%B7%E3%81%95%3A75%3CBR%20%2F%3E%20Se05x_API_AeadOneShot%20SE050%20AEAD%20%E5%BE%A9%E5%8F%B7%E5%8C%96%E6%88%90%E5%8A%9F...%3CBR%20%2F%3E%20APDU%20RSP%20%E9%95%B7%E3%81%95%3D27%3A%3CBR%20%2F%3E%2041%2082%2000%2010%2008%2000%2000%2002%2000%2000%2016%2000%2000%2000%2000%2000%2000%2000%2000%2000%2042%2082%2000%2001%2001%2090%2000%3CBR%20%2F%3E%20AEAD%20%E5%BE%A9%E5%8F%B7%E5%8C%96%20RSP%20%E3%82%BF%E3%82%B01%3D0%3A%3CBR%20%2F%3E%20%5BINF%5D%5B%E9%96%8B%E7%99%BA%E3%82%BF%E3%82%B9%E3%82%AF%5D%200x9000%3CBR%20%2F%3E%3CBR%20%2F%3E%20..%2Fmbedtls%2Fmbedtls%2Flibrary%2Fssl_msg.c%3A2139%3A%20%26lt%3B%3D%20%E5%BE%A9%E5%8F%B7%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%3CBR%20%2F%3E..%2Fmbedtls%2Fmbedtls%2Flibrary%2Fssl_msg.c%3A4289%3A%20%26lt%3B%3D%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%3CBR%20%2F%3E..%2Fmbedtls%2Fmbedtls%2Flibrary%2Fssl_tls13_client.c%3A2306%3A%20%26lt%3B%3D%20%E6%9A%97%E5%8F%B7%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%E6%8B%A1%E5%BC%B5%E6%A9%9F%E8%83%BD%E3%82%92%E8%A7%A3%E6%9E%90%E3%81%99%E3%82%8B%3CBR%20%2F%3E..%2Fmbedtls%2Fmbedtls%2Flibrary%2Fssl_msg.c%3A2333%3A%20in_left%3A%205%2C%20nb_want%3A%202277%3CBR%20%2F%3E%20..%2Fmbedtls%2Fmbedtls%2Flibrary%2Fssl_msg.c%3A1520%3A%20%3D%26gt%3B%20%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%92%E5%BE%A9%E5%8F%B7%E5%8C%96%3CBR%20%2F%3Embedtls_ssl_decrypt_buf%20data_len(2256)%20%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%9F%E3%82%BF%E3%82%B0(16)%3A%3A%3CBR%20%2F%3E%2040%2062%20d7%2027%208%2070%2088%20f6%2083%203b%20a5%2093%2044%20bc%2059%2071%3CBR%20%2F%3E%20mbedtls_cipher_aead_decrypt%20%E6%9A%97%E5%8F%B7%20ctx(20428900)%20%E3%83%A2%E3%83%BC%E3%83%89%206%E3%80%81tag_len%2016%E3%80%81ilen(2256)%3CBR%20%2F%3E%20%5BINF%5D%5Bdevtask%5D%20%E6%9A%97%E5%8F%B7%20Aead%20OneGo%20%E9%96%8B%E5%A7%8B%3A0x20428920%20%E3%82%B5%E3%82%A4%E3%82%BA%3A2256%20%E6%9A%97%E5%8F%B7%E3%83%A2%E3%83%BC%E3%83%89%3A0xb0%E3%80%81OP%20%E3%82%BF%E3%82%A4%E3%83%97%3A0x38%3CBR%20%2F%3E%20%5BINF%5D%5Bdevtask%5D%20%E3%82%AD%E3%83%BCID%3A%200xef00050e%3CBR%20%2F%3E%3CBR%20%2F%3E%20%5BINF%5D%5Bdevtask%5D%20aadLen%3A%205%3A%3CBR%20%2F%3E%2017%203%203%208%20e0%3CBR%20%2F%3E%20%5BINF%5D%5Bdevtask%5D%20nonceLen%3A%2012%3A%3CBR%20%2F%3E%20a2%203c%2082%2054%2067%20a9%2029%20d2%20aa%2069%2099%20ee%3CBR%20%2F%3E%20%5BINF%5D%5Bdevtask%5D%20%E3%82%BF%E3%82%B0%E9%95%B7%3A%2016%3A%3CBR%20%2F%3E%2040%2062%20d7%2027%208%2070%2088%20f6%2083%203b%20a5%2093%2044%20bc%2059%2071%3CBR%20%2F%3E%20%5BINF%5D%5Bdevtask%5D%20srcData(%E6%9A%97%E5%8F%B7%E6%96%87)%3A%202256%3A%3CBR%20%2F%3E%20%5BINF%5D%5Bdevtask%5D%20dstData(%E3%83%97%E3%83%AC%E3%83%BC%E3%83%B3%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88)%3A%202256%3A%3CBR%20%2F%3E%20%5B28667%20%E3%83%9F%E3%83%AA%E7%A7%92%5D%20APDU%20TX%20%E9%95%B7%E3%81%95%3D2317%3A%3CBR%20%2F%3E%20%5B28676%20ms%5D%20%E9%80%81%E5%8F%97%E4%BF%A1%E3%83%87%E3%83%BC%E3%82%BF%E3%83%9D%E3%82%A4%E3%83%B3%E3%82%BF%200x0x204133cc%20%E9%95%B7%E3%81%95%3A2317%3CBR%20%2F%3E%20%3CSTRONG%3ESe05x_API_AeadOneShot%20SE050%20AEAD%20%E5%BE%A9%E5%8F%B7%E5%8C%96%E5%A4%B1%E6%95%97(0x6700)%3CBR%20%2F%3E%20%5BINF%5D%5B%E9%96%8B%E7%99%BA%E3%82%BF%E3%82%B9%E3%82%AF%5D%200x6700%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2252195%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050%20AEAD%20Decryption%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2252195%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%A6%AA%E6%84%9B%E3%81%AA%E3%82%8BKan_Li%E6%A7%98%E3%80%82%3C%2FP%3E%3CP%3EAEAD%20%E3%83%AF%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88%E5%BE%A9%E5%8F%B7%E5%8C%96%E3%81%AF%E3%81%82%E3%82%8B%E7%A8%8B%E5%BA%A6%E8%A7%A3%E6%B1%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%8C%202256%20%E3%81%AE%202%20%E7%95%AA%E7%9B%AE%E3%81%AE%20AEAD%20Decrypt%20%E6%9A%97%E5%8F%B7%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%81%A7%E3%81%AF%E3%80%81%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%83%AF%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88%E5%BE%A9%E5%8F%B7%E5%8C%96%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%E8%A4%87%E6%95%B0%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%20(init%E3%80%81update%E3%80%81final)%20%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AD%E3%83%BC%E3%83%81%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E3%81%8C%E8%91%97%E3%81%97%E3%81%8F%E4%BD%8E%E4%B8%8B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%96%E3%81%AB%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E6%8E%A8%E8%96%A6%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%26lt%3B%20log%20%26gt%3B%3C%2FP%3E%3CP%3Embedtls_cipher_aead_decrypt%20%E6%9A%97%E5%8F%B7%20ctx(20427300)%20%E3%83%A2%E3%83%BC%E3%83%89%206%E3%80%81tag_len%2016%E3%80%81ilen(16)%3CBR%20%2F%3E%20%5BINF%5D%5Bdevtask%5D%20%E6%9A%97%E5%8F%B7%20Aead%20OneGo%20%E9%96%8B%E5%A7%8B%3A0x20427320%20%E3%82%B5%E3%82%A4%E3%82%BA%3A16%20%E6%9A%97%E5%8F%B7%E3%83%A2%E3%83%BC%E3%83%89%3A0xb0%E3%80%81OP%20%E3%82%BF%E3%82%A4%E3%83%97%3A0x38%3CBR%20%2F%3E%20%5BINF%5D%5Bdevtask%5D%20%E3%82%AD%E3%83%BCID%3A%200xef00050e%3C%2FP%3E%3CP%3E%5BINF%5D%5Bdevtask%5D%20aadLen%3A%205%3A%3CBR%20%2F%3E%2017%203%203%200%2020%3CBR%20%2F%3E%20%5BINF%5D%5Bdevtask%5D%20nonceLen%3A%2012%3A%3CBR%20%2F%3E%2044%202%20e5%209e%2014%20f8%20bc%20d2%208f%20b6%207%20b4%3CBR%20%2F%3E%20%5BINF%5D%5Bdevtask%5D%20%E3%82%BF%E3%82%B0%E9%95%B7%3A%2016%3A%3CBR%20%2F%3E%2032%20ac%2013%20ca%202e%2031%202a%201c%2091%20bf%20ea%2079%2016%20bb%20b8%20b0%3CBR%20%2F%3E%20%5BINF%5D%5Bdevtask%5D%20srcData(%E6%9A%97%E5%8F%B7%E6%96%87)%3A%2016%3A%3CBR%20%2F%3E%20%5BINF%5D%5Bdevtask%5D%20dstData(%E3%83%97%E3%83%AC%E3%83%BC%E3%83%B3%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88)%3A%2016%3A%3CBR%20%2F%3E%20Se05x_API_AeadOneShot%20SE050%20AEAD%20%E5%BE%A9%E5%8F%B7%E5%8C%96%E6%88%90%E5%8A%9F...%3CBR%20%2F%3E%20APDU%20RSP%20%E9%95%B7%E3%81%95%3D27%3A%3CBR%20%2F%3E%2041%2082%2000%2010%2008%2000%2000%2002%2000%2000%2016%2000%2000%2000%2000%2000%2000%2000%2000%2000%2042%2082%2000%2001%2001%2090%2000%3CBR%20%2F%3E%20AEAD%20%E5%BE%A9%E5%8F%B7%E5%8C%96%20RSP%20%E3%82%BF%E3%82%B01%3D0%3A%3CBR%20%2F%3E%20%5BINF%5D%5B%E9%96%8B%E7%99%BA%E3%82%BF%E3%82%B9%E3%82%AF%5D%200x9000%3C%2FP%3E%3CP%3E..%2Fmbedtls%2Fmbedtls%2Flibrary%2Fssl_msg.c%3A1520%3A%20%3D%26gt%3B%20%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%92%E5%BE%A9%E5%8F%B7%E5%8C%96%3CBR%20%2F%3Embedtls_ssl_decrypt_buf%20data_len(2256)%20%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%9F%E3%82%BF%E3%82%B0(16)%3A%3A%3CBR%20%2F%3E%2083%20e6%20fb%209c%207b%209%20d7%206%2092%20c%20c5%2083%2091%20a3%2081%2020%3CBR%20%2F%3E%20mbedtls_cipher_aead_decrypt%20%E6%9A%97%E5%8F%B7%20ctx(20427300)%20%E3%83%A2%E3%83%BC%E3%83%89%206%E3%80%81tag_len%2016%E3%80%81ilen(2256)%3CBR%20%2F%3E%20%5BINF%5D%5Bdevtask%5D%20%E6%9A%97%E5%8F%B7%20Aead%20OneGo%20%E9%96%8B%E5%A7%8B%3A0x20427320%20%E3%82%B5%E3%82%A4%E3%82%BA%3A2256%20%E6%9A%97%E5%8F%B7%E3%83%A2%E3%83%BC%E3%83%89%3A0xb0%E3%80%81OP%20%E3%82%BF%E3%82%A4%E3%83%97%3A0x38%3CBR%20%2F%3E%20%5BINF%5D%5Bdevtask%5D%20%E3%82%AD%E3%83%BCID%3A%200xef00050e%3C%2FP%3E%3CP%3E%5BINF%5D%5Bdevtask%5D%20aadLen%3A%205%3A%3CBR%20%2F%3E%2017%203%203%208%20e0%3CBR%20%2F%3E%20%5BINF%5D%5Bdevtask%5D%20nonceLen%3A%2012%3A%3CBR%20%2F%3E%2044%202%20e5%209e%2014%20f8%20bc%20d2%208f%20b6%207%20b5%3CBR%20%2F%3E%20%5BINF%5D%5Bdevtask%5D%20%E3%82%BF%E3%82%B0%E9%95%B7%3A%2016%3A%3CBR%20%2F%3E%2083%20e6%20fb%209c%207b%209%20d7%206%2092%20c%20c5%2083%2091%20a3%2081%2020%3CBR%20%2F%3E%20%5BINF%5D%5Bdevtask%5D%20srcData(%E6%9A%97%E5%8F%B7%E6%96%87)%3A%202256%3A%3CBR%20%2F%3E%20%5BINF%5D%5Bdevtask%5D%20dstData(%E3%83%97%E3%83%AC%E3%83%BC%E3%83%B3%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88)%3A%202256%3A%3CBR%20%2F%3E%20%5B31678%20%E3%83%9F%E3%83%AA%E7%A7%92%5D%20se05x_gcm_decrypt_multistep%20keyId%200xef00050e%E3%80%81cipherMode%200xb0%20cryptoObjectId%2026%E3%80%81tagLen%20541177908%3CBR%20%2F%3E%20%5B49212%20%E3%83%9F%E3%83%AA%E7%A7%92%5D%20se05x_gcm_decrypt_multistep%20AEAD%20%E6%9B%B4%E6%96%B0%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88(400)%20(2256)%3CBR%20%2F%3E%20%5B65947%20ms%5D%20se05x_gcm_decrypt_multistep%20AEAD%20%E6%9B%B4%E6%96%B0%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88(800)%20(2256)%3CBR%20%2F%3E%20%5B82784%20ms%5D%20se05x_gcm_decrypt_multistep%20AEAD%20%E6%9B%B4%E6%96%B0%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88(1200)%20(2256)%3CBR%20%2F%3E%20%5B99558%20ms%5D%20se05x_gcm_decrypt_multistep%20AEAD%20%E6%9B%B4%E6%96%B0%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88(1600)%20(2256)%3CBR%20%2F%3E%20%5B116379%20ms%5D%20se05x_gcm_decrypt_multistep%20AEAD%20%E6%9B%B4%E6%96%B0%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88(2000)%20(2256)%3CBR%20%2F%3E%20%5B127157%20ms%5D%20se05x_gcm_decrypt_multistep%20AEAD%20%E6%9B%B4%E6%96%B0%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88(2256)%20(2256)%3CBR%20%2F%3E%20%5BERR%5D%5Bdevtask%5D%20%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%8C%E8%B6%B3%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2252827%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050%20AEAD%20Decryption%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2252827%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F232520%22%20target%3D%22_blank%22%3E%40Changhawn%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%0A%3CP%3EAEADOneShot%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AE%20APDU%20%E4%BB%95%E6%A7%98%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%3A%3C%2FP%3E%0A%3CP%3EAEADMode%E3%81%8CAES_GCM%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81AAD%E3%81%AE%E9%95%B7%E3%81%95%2B%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E9%95%B7%E3%81%95%E3%81%AF%3CBR%20%2F%3EC-APDU%20%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%AE%E5%90%88%E8%A8%88%E9%95%B7%E3%81%A7%E3%81%82%E3%82%8B%20888%20%E3%83%90%E3%82%A4%E3%83%88%E3%81%AB%E5%88%B6%E9%99%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E8%A6%81%E4%BB%B6%E3%82%92%E6%BA%80%E3%81%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%0A%3CP%3E%E3%81%99%E3%81%A6%E3%81%8D%E3%81%AA%E4%B8%80%E6%97%A5%E3%82%92%E3%80%81%3CBR%20%2F%3E%E3%82%AB%E3%83%B3%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E---------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%E8%A8%98%EF%BC%9A%3CBR%20%2F%3E%20-%20%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%8C%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%B8%E3%81%AE%E5%9B%9E%E7%AD%94%E3%81%A7%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%80%8C%E6%AD%A3%E8%A7%A3%E3%81%A8%E3%81%97%E3%81%A6%E3%83%9E%E3%83%BC%E3%82%AF%E3%80%8D%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%EF%BC%81%3CBR%20%2F%3E%20-%20Thread%E3%81%AF%E6%9C%80%E5%BE%8C%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%8B%E3%82%897%E9%80%B1%E9%96%93%E3%83%95%E3%82%A9%E3%83%AD%E3%83%BC%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E4%BB%A5%E9%99%8D%E3%81%AE%E8%BF%94%E4%BF%A1%E3%81%AF%E7%84%A1%E8%A6%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E5%BE%8C%E3%81%BB%E3%81%A9%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%96%B0%E3%81%97%E3%81%84Thread%E3%82%92%E9%96%8B%E3%81%84%E3%81%A6%E3%80%81%E9%96%89%E3%81%98%E3%81%9FThread%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E---------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2252907%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050%20AEAD%20Decryption%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2252907%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%A6%AA%E6%84%9B%E3%81%AA%E3%82%8BKan_Li%E6%A7%98%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%20SE050%20%E4%BB%95%E6%A7%98%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E3%83%AF%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88%E5%85%A5%E5%8A%9B%E3%81%AE%E9%95%B7%E3%81%95%E3%81%AF%20256%20%E3%81%AB%E5%88%B6%E9%99%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ESO%E7%A7%81%E3%81%AFMultistep(AEADInit%E3%80%81AEADUpdate%E3%80%81AEADFinal)%E3%81%A7%E9%96%8B%E7%99%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%81%BE%E3%81%A0%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%81%AF%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E3%81%8C%E4%BD%8E%E3%81%84%E3%81%A7%E3%81%99%E3%80%8295%E7%A7%92%E3%81%8B%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E4%BD%8E%E3%81%84%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%81%E3%83%A3%E3%83%B3%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Changhawn_0-1764661314832.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Changhawn_0-1764661314832.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Changhawn_0-1764661314832.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F368169iD6AEF8E5C60147B8%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Changhawn_0-1764661314832.png%22%20alt%3D%22Changhawn_0-1764661314832.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EChanghawn_0-1764661314832.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E..%2Fmbedtls%2Fmbedtls%2Flibrary%2Fssl_msg.c%3A1520%3A%20%3D%26gt%3B%20%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%92%E5%BE%A9%E5%8F%B7%E5%8C%96%3CBR%20%2F%3Embedtls_ssl_decrypt_buf%20data_len(2256)%20%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%9F%E3%82%BF%E3%82%B0(16)%3A%3A%3CBR%20%2F%3E%20e8%20c0%20f9%203%20a1%20a6%2087%209d%20e9%20e3%2091%20fe%2059%207a%2045%2062%3CBR%20%2F%3E%20mbedtls_cipher_aead_decrypt%20%E6%9A%97%E5%8F%B7%20ctx(20427300)%20%E3%83%A2%E3%83%BC%E3%83%89%206%E3%80%81tag_len%2016%E3%80%81ilen(2256)%3CBR%20%2F%3E%20%5BINF%5D%5Bdevtask%5D%20%E6%9A%97%E5%8F%B7%20Aead%20OneGo%20%E9%96%8B%E5%A7%8B%3A0x20427320%20%E3%82%B5%E3%82%A4%E3%82%BA%3A2256%20%E6%9A%97%E5%8F%B7%E3%83%A2%E3%83%BC%E3%83%89%3A0xb0%E3%80%81OP%20%E3%82%BF%E3%82%A4%E3%83%97%3A0x38%3CBR%20%2F%3E%20%5BINF%5D%5Bdevtask%5D%20%E3%82%AD%E3%83%BCID%3A%200xef00050e%3C%2FP%3E%3CP%3E%5BINF%5D%5Bdevtask%5D%20aadLen%3A%205%3A%3CBR%20%2F%3E%2017%203%203%208%20e0%3CBR%20%2F%3E%20%5BINF%5D%5Bdevtask%5D%20nonceLen%3A%2012%3A%3CBR%20%2F%3E%207b%205e%201b%2041%209d%2019%20b2%20b8%2094%2062%20c2%202e%3CBR%20%2F%3E%20%5BINF%5D%5Bdevtask%5D%20%E3%82%BF%E3%82%B0%E9%95%B7%3A%2016%3A%3CBR%20%2F%3E%20e8%20c0%20f9%203%20a1%20a6%2087%209d%20e9%20e3%2091%20fe%2059%207a%2045%2062%3CBR%20%2F%3E%20%5BINF%5D%5Bdevtask%5D%20srcData(%E6%9A%97%E5%8F%B7%E6%96%87)%3A%202256%3A%3CBR%20%2F%3E%20%5BINF%5D%5Bdevtask%5D%20dstData(%E3%83%97%E3%83%AC%E3%83%BC%E3%83%B3%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88)%3A%202256%3A%3CBR%20%2F%3E%20%5B27711%20%E3%83%9F%E3%83%AA%E7%A7%92%5D%20APDU%20TX%20%E9%95%B7%E3%81%95%3D4%20%3A%3CBR%20%2F%3E%20%5B27749%20%E3%83%9F%E3%83%AA%E7%A7%92%5D%20se05x_gcm_decrypt_multistep%20keyId%200xef00050e%E3%80%81cipherMode%200xb0%20cryptoObjectId%2026%E3%80%81ctLen%202256%E3%80%81tagLen%2016%3CBR%20%2F%3E%20%5B27814%20%E3%83%9F%E3%83%AA%E7%A7%92%5D%20se05x_gcm_decrypt_multistep%20aadLen%205%3CBR%20%2F%3E%20%5B27852%20%E3%83%9F%E3%83%AA%E7%A7%92%5D%20se05x_gcm_decrypt_multistep%20%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%200%E3%80%81ctLen%202256%3CBR%20%2F%3E%20%5B27864%20%E3%83%9F%E3%83%AA%E7%A7%92%5D%20APDU%20TX%20%E9%95%B7%E3%81%95%3D497%20%3A%3CBR%20%2F%3E%20%5B48615%20ms%5D%20se05x_gcm_decrypt_multistep%20AEAD%20%E6%9B%B4%E6%96%B0%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88(480)%20(2256)%3CBR%20%2F%3E%20%5B48630%20%E3%83%9F%E3%83%AA%E7%A7%92%5D%20APDU%20TX%20%E9%95%B7%E3%81%95%3D497%20%3A%3CBR%20%2F%3E%20%5B68749%20ms%5D%20se05x_gcm_decrypt_multistep%20AEAD%20%E6%9B%B4%E6%96%B0%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88(960)%20(2256)%3CBR%20%2F%3E%20%5B68764%20%E3%83%9F%E3%83%AA%E7%A7%92%5D%20APDU%20TX%20%E9%95%B7%E3%81%95%3D497%3A%3CBR%20%2F%3E%20%5B88833%20ms%5D%20se05x_gcm_decrypt_multistep%20AEAD%20%E6%9B%B4%E6%96%B0%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88(1440)%20(2256)%3CBR%20%2F%3E%20%5B88848%20%E3%83%9F%E3%83%AA%E7%A7%92%5D%20APDU%20TX%20%E9%95%B7%E3%81%95%3D497%20%3A%3CBR%20%2F%3E%20%5B108979%20ms%5D%20se05x_gcm_decrypt_multistep%20AEAD%20%E6%9B%B4%E6%96%B0%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88(1920)%20(2256)%3CBR%20%2F%3E%20%5B108994%20%E3%83%9F%E3%83%AA%E7%A7%92%5D%20APDU%20TX%20%E9%95%B7%E3%81%95%3D353%3A%3CBR%20%2F%3E%20%5B123113%20ms%5D%20se05x_gcm_decrypt_multistep%20AEAD%20%E6%9B%B4%E6%96%B0%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88(2256)%20(2256)%3CBR%20%2F%3E%20%5B123128%20%E3%83%9F%E3%83%AA%E7%A7%92%5D%20APDU%20TX%20%E9%95%B7%E3%81%95%3D31%3A%3CBR%20%2F%3E%20%5BINF%5D%5B%E9%96%8B%E7%99%BA%E3%82%BF%E3%82%B9%E3%82%AF%5D%200x9000%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2270398%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050%20AEAD%20Decryption%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2270398%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EA1006%20%E3%83%81%E3%83%83%E3%83%97%E3%82%92%E9%96%8B%E7%99%BA%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E4%BB%A5%E5%89%8D%E3%81%AB%E3%82%84%E3%81%A3%E3%81%9F%E3%81%93%E3%81%A8%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%81%8A%E5%95%8F%E3%81%84%E5%90%88%E3%82%8F%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%A9%E3%81%86%E3%82%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E
