Restricted areas after Configuration Lock for S32K312 MCU
jeongwoo
Hello
Our company is working on a project using S32K312 MCU.
I have a question about Configuration Lock among cyber security items.
I know that there are areas in the HSE area that are restricted after activating Configuration Lock. Except for the Secure Area (ex. 0x005D4000 -- 0x005FFFFF) that is basically restricted among the HSE areas, is there an area where the read/write area is not restricted before activating Configuration Lock, but is it restricted after activating Configuration Lock?
I will wait for your answer. Thank you.
lukaszadrapa
Hi @jeongwoo
Please take a look at Table 197, Table 199 and Table 200 in S32K3 reference manual:
https://www.nxp.com/webapp/Download?colCode=S32K3XXRM
Table 197 - memory map when HSE feature flag is disabled (not programmed)
Table 199 - memory map when HSE feature flag is enabled (programmed) - this is also memory map when FULL_MEM version of HSE firmware is installed
Table 200 - memory map when AB_SWAP version of HSE firmware is installed.
Lukas
PS. If you have questions about S32K devices, please ask them in this community space:
https://community.nxp.com/t5/S32K/bd-p/S32K
