Request for Reference Documentation for SE052 Security IC with Raspberry Pi CM5
urvisha
Dear NXP Support Team,
We are currently developing a custom PCB for our project, in which we are using the NXP SE052 Security IC for secure communication and secure storage of certificates.
Our host platform is the Raspberry Pi Compute Module 5 (CM5). We would like to understand the proper integration method and software support required to interface the SE052 security IC with the CM5 platform.
Could you please provide the following:
  1. Reference documentation or application notes for integrating the SE052 Security IC with Raspberry Pi platforms (especially CM5).
  2. Any available reference design, hardware schematics, or recommended interface configuration (I2C / T=1 over I2C).
  3. Software support details such as middleware, drivers, or examples compatible with Linux running on Raspberry Pi.
  4. Any guidance or best practices for implementing secure certificate storage and secure communication using SE052 with embedded Linux systems.
Your guidance and relevant documentation will help us correctly implement the SE052 in our custom hardware design.
Thank you for your support.
Urvisha Andani
Kan_Li
Hi @urvisha ,
Please kindly refer to the following for details:
Get started with EdgeLock SE05x support package
EdgeLock SE05x Quick start guide with Raspberry Pi
OM-SE052ARD: Development Board for EdgeLock SE052F Secure Element | NXP Semiconductors
https://www.nxp.com/webapp/Download?colCode=UM11225
We have plug&trust MWs available :
Full version:
PKCS#11 support:
GitHub - NXPPlugNTrust/se05x-pkcs11: This is the pkcs11 Plugin Interface for Se05x using the mini-pk...
1. securely storing certs inside the SE: Refer to demos from the MW:se05x_GetCertificate ,se05x_InjectCertificate
2. Always enable platformSCP to secure communication between the host and SE.
Refer to chapter 5 of https://www.nxp.com/docs/en/application-note/AN12570.pdffordetails. SE052F has platformSCP enabled by default, so you just need to rotate the default keys to your own defined keys for the mass production.
Refer to the  rotation of Platform SCP03 keys demo from MW for details.
3. Use Development Boards + Adapter for Early Bring-Up
Hope that helps,
Kan
%3CLINGO-SUB%20id%3D%22lingo-sub-2327667%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERequest%20for%20Reference%20Documentation%20for%20SE052%20Security%20IC%20with%20Raspberry%20Pi%20CM5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2327667%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20class%3D%22%22%3E%3CSPAN%3EDear%20NXP%20Support%20Team%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3EWe%20are%20currently%20developing%20a%20custom%20PCB%20for%20our%20project%2C%20in%20which%20we%20are%20using%20the%20NXP%20SE052%20Security%20IC%20for%20secure%20communication%20and%20secure%20storage%20of%20certificates.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3EOur%20host%20platform%20is%20the%20Raspberry%20Pi%20Compute%20Module%205%20(CM5).%20We%20would%20like%20to%20understand%20the%20proper%20integration%20method%20and%20software%20support%20required%20to%20interface%20the%20SE052%20security%20IC%20with%20the%20CM5%20platform.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3ECould%20you%20please%20provide%20the%20following%3A%3C%2FSPAN%3E%3C%2FP%3E%3COL%3E%3CLI%3E%3CP%20class%3D%22%22%3E%3CSPAN%3EReference%20documentation%20or%20application%20notes%20for%20integrating%20the%20SE052%20Security%20IC%20with%20Raspberry%20Pi%20platforms%20(especially%20CM5).%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%3E%3CSPAN%3EAny%20available%20reference%20design%2C%20hardware%20schematics%2C%20or%20recommended%20interface%20configuration%20(I2C%20%2F%20T%3D1%20over%20I2C).%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%3E%3CSPAN%3ESoftware%20support%20details%20such%20as%20middleware%2C%20drivers%2C%20or%20examples%20compatible%20with%20Linux%20running%20on%20Raspberry%20Pi.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%3E%3CSPAN%3EAny%20guidance%20or%20best%20practices%20for%20implementing%20secure%20certificate%20storage%20and%20secure%20communication%20using%20SE052%20with%20embedded%20Linux%20systems.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%20class%3D%22%22%3E%3CSPAN%3EYour%20guidance%20and%20relevant%20documentation%20will%20help%20us%20correctly%20implement%20the%20SE052%20in%20our%20custom%20hardware%20design.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3EThank%20you%20for%20your%20support.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EBest%20regards%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EUrvisha%20Andani%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2328632%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Request%20for%20Reference%20Documentation%20for%20SE052%20Security%20IC%20with%20Raspberry%20Pi%20CM5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2328632%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F260478%22%20target%3D%22_blank%22%3E%40urvisha%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CDIV%3E%3CSPAN%3EPlease%20kindly%20refer%20to%20the%20following%20for%20details%3A%3C%2FSPAN%3E%3CBR%20clear%3D%22none%22%20%2F%3E%3CBR%20clear%3D%22none%22%20%2F%3E%3CSPAN%3EReference%20documentation%20or%20application%20notes%20for%20integrating%20the%20SE052%20Security%20IC%20with%20Raspberry%20Pi%20platforms%20(especially%20CM5).%3C%2FSPAN%3E%3CBR%20clear%3D%22none%22%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.jp%2Fdocs%2Fen%2Fapplication-note%2FAN13013.pdf%22%20shape%3D%22rect%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EGet%20started%20with%20EdgeLock%20SE05x%20support%20package%3C%2FA%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN12570.pdf%22%20shape%3D%22rect%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EEdgeLock%20SE05x%20Quick%20start%20guide%20with%20Raspberry%20Pi%3C%2FA%3E%26nbsp%3B%3CBR%20clear%3D%22none%22%20%2F%3E%3CSPAN%3EAny%20available%20reference%20design%2C%20hardware%20schematics%2C%20or%20recommended%20interface%20configuration%20(I2C%20%2F%20T%3D1%20over%20I2C).%3C%2FSPAN%3E%3CBR%20clear%3D%22none%22%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fdevelopment-boards-and-designs%2FOM-SE052ARD%22%20shape%3D%22rect%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EOM-SE052ARD%3A%20Development%20Board%20for%20EdgeLock%20SE052F%20Secure%20Element%20%7C%20NXP%20Semiconductors%3C%2FA%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DAN14262%22%20shape%3D%22rect%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DAN14262%3C%2FA%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com.cn%2Fdocs%2Fen%2Fapplication-note%2FAN14028.pdf%22%20shape%3D%22rect%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EMoving%20from%20EdgeLock%20SE050F%20to%20EdgeLock%20SE052F%3C%2FA%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DUM11225%22%20shape%3D%22rect%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DUM11225%3C%2FA%3E%3CBR%20clear%3D%22none%22%20%2F%3E%3CSPAN%3ESoftware%20support%20details%20such%20as%20middleware%2C%20drivers%2C%20or%20examples%20compatible%20with%20Linux%20running%20on%20Raspberry%20Pi.%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3EWe%20have%20plug%26amp%3Btrust%20MWs%20available%20%3A%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3EFull%20version%3A%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DSE05x-PLUG-TRUST-MW%26amp%3BappType%3Dlicense%22%20shape%3D%22rect%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DSE05x-PLUG-TRUST-MW%26amp%3BappType%3Dlicense%3C%2FA%3E%3CBR%20clear%3D%22none%22%20%2F%3Emini%20version%3A%3CBR%20clear%3D%22none%22%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXP%2Fplug-and-trust%22%20shape%3D%22rect%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EGitHub%20-%20NXP%2Fplug-and-trust%3A%20Plug%20%26amp%3B%20Trust%20middleware%20to%20use%20secure%20element%20SE050%20%C2%B7%20GitHub%3C%2FA%3E%26nbsp%3B%3CBR%20clear%3D%22none%22%20%2F%3Enano%20version%3A%3C%2FDIV%3E%0A%3CDIV%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPPlugNTrust%2Fnano-package%22%20shape%3D%22rect%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EGitHub%20-%20NXPPlugNTrust%2Fnano-package%20%C2%B7%20GitHub%3C%2FA%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3EPKCS%2311%20support%3A%3CBR%20clear%3D%22none%22%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPPlugNTrust%2Fse05x-pkcs11%22%20shape%3D%22rect%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EGitHub%20-%20NXPPlugNTrust%2Fse05x-pkcs11%3A%20This%20is%20the%20pkcs11%20Plugin%20Interface%20for%20Se05x%20using%20the%20mini-pkg.%20%C2%B7%20GitHub%3C%2FA%3E%26nbsp%3B%3CBR%20clear%3D%22none%22%20%2F%3E%3CSPAN%3EAny%20guidance%20or%20best%20practices%20for%20implementing%20secure%20certificate%20storage%20and%20secure%20communication%20using%20SE052%20with%20embedded%20Linux%20systems.%3C%2FSPAN%3E%26nbsp%3B%3CBR%20clear%3D%22none%22%20%2F%3E1.%20securely%20storing%20certs%20inside%20the%20SE%3A%20Refer%20to%20demos%20from%20the%20MW%3A%3CSPAN%3Ese05x_GetCertificate%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%2C%3CSPAN%3Ese05x_InjectCertificate%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E2.%20Always%20enable%20platformSCP%20to%20secure%20communication%20between%20the%20host%20and%20SE.%3C%2FDIV%3E%0A%3CDIV%3ERefer%20to%20chapter%205%20of%26nbsp%3B%3CSTRONG%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN12570.pdf%22%20shape%3D%22rect%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN12570.pdf%3C%2FA%3E%3C%2FSTRONG%3Efordetails.%20SE052F%20has%20platformSCP%20enabled%20by%20default%2C%20so%20you%20just%20need%20to%20rotate%20the%20default%20keys%20to%20your%20own%20defined%20keys%20for%20the%20mass%20production.%3C%2FDIV%3E%0A%3CDIV%3EThe%20default%20keys%20can%20be%20found%20in%3CSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN14277.pdf%22%20shape%3D%22rect%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN14277.pdf%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FDIV%3E%0A%3CDIV%3ERefer%20to%20the%20%26nbsp%3Brotation%20of%20Platform%20SCP03%20keys%20demo%20from%20MW%20for%20details.%3C%2FDIV%3E%0A%3CDIV%3E3.%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3EUse%20Development%20Boards%20%2B%20Adapter%20for%20Early%20Bring-Up%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fdevelopment-boards-and-designs%2FOM-SE052ARD%22%20shape%3D%22rect%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EOM-SE052ARD%3A%20Development%20Board%20for%20EdgeLock%20SE052F%20Secure%20Element%20%7C%20NXP%20Semiconductors%3C%2FA%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fpart%2FOM-SE050RPI%22%20shape%3D%22rect%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EOM-SE050RPI%20Product%20Information%20%7C%20NXP%20Semiconductors%3C%2FA%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3EHope%20that%20helps%2C%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%0A%3CP%3EHave%20a%20great%20day%2C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3ENote%3A%3CBR%20%2F%3E-%20If%20this%20post%20answers%20your%20question%2C%20please%20click%20the%20%22Mark%20Correct%22%20button.%20Thank%20you!%3CBR%20%2F%3E-%20We%20are%20following%20threads%20for%207%20weeks%20after%20the%20last%20post%2C%20later%20replies%20are%20ignored%3CBR%20%2F%3EPlease%20open%20a%20new%20thread%20and%20refer%20to%20the%20closed%20one%2C%20if%20you%20have%20a%20related%20question%20at%20a%20later%20point%20in%20time.%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%0A%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
