Request for Reference Documentation for SE052 Security IC with Raspberry Pi CM5
968件の閲覧回数
urvisha
Dear NXP Support Team,
We are currently developing a custom PCB for our project, in which we are using the NXP SE052 Security IC for secure communication and secure storage of certificates.
Our host platform is the Raspberry Pi Compute Module 5 (CM5). We would like to understand the proper integration method and software support required to interface the SE052 security IC with the CM5 platform.
Could you please provide the following:
  1. Reference documentation or application notes for integrating the SE052 Security IC with Raspberry Pi platforms (especially CM5).
  2. Any available reference design, hardware schematics, or recommended interface configuration (I2C / T=1 over I2C).
  3. Software support details such as middleware, drivers, or examples compatible with Linux running on Raspberry Pi.
  4. Any guidance or best practices for implementing secure certificate storage and secure communication using SE052 with embedded Linux systems.
Your guidance and relevant documentation will help us correctly implement the SE052 in our custom hardware design.
Thank you for your support.
Urvisha Andani
849件の閲覧回数
Kan_Li
Hi @urvisha ,
Please kindly refer to the following for details:
Get started with EdgeLock SE05x support package
EdgeLock SE05x Quick start guide with Raspberry Pi
OM-SE052ARD: Development Board for EdgeLock SE052F Secure Element | NXP Semiconductors
https://www.nxp.com/webapp/Download?colCode=UM11225
We have plug&trust MWs available :
Full version:
PKCS#11 support:
GitHub - NXPPlugNTrust/se05x-pkcs11: This is the pkcs11 Plugin Interface for Se05x using the mini-pk...
1. securely storing certs inside the SE: Refer to demos from the MW:se05x_GetCertificate ,se05x_InjectCertificate
2. Always enable platformSCP to secure communication between the host and SE.
Refer to chapter 5 of https://www.nxp.com/docs/en/application-note/AN12570.pdffordetails. SE052F has platformSCP enabled by default, so you just need to rotate the default keys to your own defined keys for the mass production.
Refer to the  rotation of Platform SCP03 keys demo from MW for details.
3. Use Development Boards + Adapter for Early Bring-Up
Hope that helps,
Kan
%3CLINGO-SUB%20id%3D%22lingo-sub-2327667%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERaspberry%20Pi%20CM5%20%E6%90%AD%E8%BC%89%20SE052%20%E3%82%BB%E3%82%AD%E3%83%A5%E3%83%AA%E3%83%86%E3%82%A3%20IC%20%E3%81%AE%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AE%E3%83%AA%E3%82%AF%E3%82%A8%E3%82%B9%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2327667%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20class%3D%22%22%3E%3CSPAN%3ENXP%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%83%81%E3%83%BC%E3%83%A0%E6%A7%98%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AF%E7%8F%BE%E5%9C%A8%E3%80%81%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E7%94%A8%E3%81%AB%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20PCB%20%E3%82%92%E9%96%8B%E7%99%BA%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E5%AE%89%E5%85%A8%E3%81%AA%E9%80%9A%E4%BF%A1%E3%81%A8%E8%A8%BC%E6%98%8E%E6%9B%B8%E3%81%AE%E5%AE%89%E5%85%A8%E3%81%AA%E4%BF%9D%E7%AE%A1%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%20NXP%20SE052%20%E3%82%BB%E3%82%AD%E3%83%A5%E3%83%AA%E3%83%86%E3%82%A3%20IC%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E3%83%9B%E3%82%B9%E3%83%88%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%AF%E3%80%81Raspberry%20Pi%20Compute%20Module%205%20(CM5)%20%E3%81%A7%E3%81%99%E3%80%82SE052%20%E3%82%BB%E3%82%AD%E3%83%A5%E3%83%AA%E3%83%86%E3%82%A3%20IC%20%E3%82%92%20CM5%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%A8%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E9%81%A9%E5%88%87%E3%81%AA%E7%B5%B1%E5%90%88%E6%96%B9%E6%B3%95%E3%81%A8%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E7%90%86%E8%A7%A3%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E6%83%85%E5%A0%B1%E3%82%92%E3%81%94%E6%8F%90%E4%BE%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3COL%3E%3CLI%3E%3CP%20class%3D%22%22%3E%3CSPAN%3ESE052%20%E3%82%BB%E3%82%AD%E3%83%A5%E3%83%AA%E3%83%86%E3%82%A3%20IC%20%E3%82%92%20Raspberry%20Pi%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20(%E7%89%B9%E3%81%AB%20CM5)%20%E3%81%AB%E7%B5%B1%E5%90%88%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E5%8F%82%E7%85%A7%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20%E3%83%8E%E3%83%BC%E3%83%88%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%BB%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%80%81%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E5%9B%9E%E8%B7%AF%E5%9B%B3%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E6%8E%A8%E5%A5%A8%E3%81%95%E3%82%8C%E3%82%8B%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E6%A7%8B%E6%88%90%20(I2C%20%2F%20T%3D1%20over%20I2C)%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%3E%3CSPAN%3ERaspberry%20Pi%20%E4%B8%8A%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%82%8B%20Linux%20%E3%81%A8%E4%BA%92%E6%8F%9B%E6%80%A7%E3%81%AE%E3%81%82%E3%82%8B%E3%83%9F%E3%83%89%E3%83%AB%E3%82%A6%E3%82%A7%E3%82%A2%E3%80%81%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%80%81%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%81%AA%E3%81%A9%E3%81%AE%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BF%20Linux%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A7%20SE052%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E5%AE%89%E5%85%A8%E3%81%AA%E8%A8%BC%E6%98%8E%E6%9B%B8%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%E3%81%A8%E5%AE%89%E5%85%A8%E3%81%AA%E9%80%9A%E4%BF%A1%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%82%AC%E3%82%A4%E3%83%80%E3%83%B3%E3%82%B9%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%99%E3%82%B9%E3%83%88%20%E3%83%97%E3%83%A9%E3%82%AF%E3%83%86%E3%82%A3%E3%82%B9%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E6%8C%87%E5%B0%8E%E3%81%A8%E9%96%A2%E9%80%A3%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AF%E3%80%81%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%20%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%81%AB%20SE052%20%E3%82%92%E6%AD%A3%E3%81%97%E3%81%8F%E5%AE%9F%E8%A3%85%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E5%86%8D%E9%96%8B%E3%81%BE%E3%81%A7%E4%BB%8A%E3%81%97%E3%81%B0%E3%82%89%E3%81%8F%E3%81%8A%E5%BE%85%E3%81%A1%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%82%A6%E3%83%AB%E3%83%B4%E3%82%A3%E3%82%B7%E3%83%A3%E3%83%BB%E3%82%A2%E3%83%B3%E3%83%80%E3%83%8B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2328632%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Request%20for%20Reference%20Documentation%20for%20SE052%20Security%20IC%20with%20Raspberry%20Pi%20CM5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2328632%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F260478%22%20target%3D%22_blank%22%3E%40urvisha%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CDIV%3E%3CSPAN%3E%E8%A9%B3%E7%B4%B0%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%82%92%E3%81%94%E5%8F%82%E7%85%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3CBR%20clear%3D%22none%22%20%2F%3E%3CBR%20clear%3D%22none%22%20%2F%3E%20%3CSPAN%3ESE052%20%E3%82%BB%E3%82%AD%E3%83%A5%E3%83%AA%E3%83%86%E3%82%A3%20IC%20%E3%82%92%20Raspberry%20Pi%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20(%E7%89%B9%E3%81%AB%20CM5)%20%E3%81%AB%E7%B5%B1%E5%90%88%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E5%8F%82%E7%85%A7%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20%E3%83%8E%E3%83%BC%E3%83%88%E3%80%82%3C%2FSPAN%3E%3CBR%20clear%3D%22none%22%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.jp%2Fdocs%2Fen%2Fapplication-note%2FAN13013.pdf%22%20shape%3D%22rect%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EEdgeLock%20SE05x%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E4%BD%BF%E3%81%84%E5%A7%8B%E3%82%81%E3%82%8B%3C%2FA%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN12570.pdf%22%20shape%3D%22rect%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EEdgeLock%20SE05x%20%E3%82%AF%E3%82%A4%E3%83%83%E3%82%AF%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%E3%82%AC%E3%82%A4%E3%83%89%EF%BC%88Raspberry%20Pi%20%E7%94%A8%EF%BC%89%3C%2FA%3E%3CBR%20clear%3D%22none%22%20%2F%3E%3CSPAN%3E%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%BB%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%80%81%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E5%9B%9E%E8%B7%AF%E5%9B%B3%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E6%8E%A8%E5%A5%A8%E3%81%95%E3%82%8C%E3%82%8B%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E6%A7%8B%E6%88%90%20(I2C%20%2F%20T%3D1%20over%20I2C)%E3%80%82%3C%2FSPAN%3E%3CBR%20clear%3D%22none%22%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fdevelopment-boards-and-designs%2FOM-SE052ARD%22%20shape%3D%22rect%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EOM-SE052ARD%3A%20EdgeLock%20SE052F%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%82%A8%E3%83%AC%E3%83%A1%E3%83%B3%E3%83%88%E7%94%A8%E9%96%8B%E7%99%BA%E3%83%9C%E3%83%BC%E3%83%89%20%7C%20NXP%20Semiconductors%3C%2FA%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DAN14262%22%20shape%3D%22rect%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DAN14262%3C%2FA%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com.cn%2Fdocs%2Fen%2Fapplication-note%2FAN14028.pdf%22%20shape%3D%22rect%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EEdgeLock%20SE050F%E3%81%8B%E3%82%89EdgeLock%20SE052F%E3%81%B8%E3%81%AE%E7%A7%BB%E8%A1%8C%3C%2FA%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DUM11225%22%20shape%3D%22rect%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DUM11225%3C%2FA%3E%3CBR%20clear%3D%22none%22%20%2F%3E%20%3CSPAN%3ERaspberry%20Pi%20%E4%B8%8A%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%82%8B%20Linux%20%E3%81%A8%E4%BA%92%E6%8F%9B%E6%80%A7%E3%81%AE%E3%81%82%E3%82%8B%E3%83%9F%E3%83%89%E3%83%AB%E3%82%A6%E3%82%A7%E3%82%A2%E3%80%81%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%80%81%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%81%AA%E3%81%A9%E3%81%AE%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3E%E3%83%97%E3%83%A9%E3%82%B0%EF%BC%86%E3%83%88%E3%83%A9%E3%82%B9%E3%83%88MW%E3%82%92%E3%81%94%E7%94%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%81%BE%E3%81%99%3A%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3E%E3%83%95%E3%83%AB%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DSE05x-PLUG-TRUST-MW%26amp%3BappType%3Dlicense%22%20shape%3D%22rect%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DSE05x-PLUG-TRUST-MW%26amp%3BappType%3Dlicense%3C%2FA%3E%3CBR%20clear%3D%22none%22%20%2F%3E%E3%83%9F%E3%83%8B%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%3CBR%20clear%3D%22none%22%20%2F%3E%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXP%2Fplug-and-trust%22%20shape%3D%22rect%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EGitHub%20-%20NXP%2Fplug-and-trust%3A%20%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%82%A8%E3%83%AC%E3%83%A1%E3%83%B3%E3%83%88%20SE050%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%20Plug%20%26amp%3B%20Trust%20%E3%83%9F%E3%83%89%E3%83%AB%E3%82%A6%E3%82%A7%E3%82%A2%20%C2%B7%20GitHub%3C%2FA%3E%3CBR%20clear%3D%22none%22%20%2F%3E%E3%83%8A%E3%83%8E%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%3C%2FDIV%3E%0A%3CDIV%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPPlugNTrust%2Fnano-package%22%20shape%3D%22rect%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EGitHub%20-%20NXPPlugNTrust%2Fnano-package%20%C2%B7%20GitHub%3C%2FA%3E%3C%2FDIV%3E%0A%3CDIV%3EPKCS%2311%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3A%3CBR%20clear%3D%22none%22%20%2F%3E%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPPlugNTrust%2Fse05x-pkcs11%22%20shape%3D%22rect%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EGitHub%20-%20NXPPlugNTrust%2Fse05x-pkcs11%3A%20%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81mini-pkg%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%20Se05x%20%E7%94%A8%E3%81%AE%20pkcs11%20%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%A7%E3%81%99%E3%80%82%20%C2%B7%20GitHub%3C%2FA%3E%3CBR%20clear%3D%22none%22%20%2F%3E%3CSPAN%3E%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BF%20Linux%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A7%20SE052%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E5%AE%89%E5%85%A8%E3%81%AA%E8%A8%BC%E6%98%8E%E6%9B%B8%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%E3%81%A8%E5%AE%89%E5%85%A8%E3%81%AA%E9%80%9A%E4%BF%A1%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%82%AC%E3%82%A4%E3%83%80%E3%83%B3%E3%82%B9%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%99%E3%82%B9%E3%83%88%20%E3%83%97%E3%83%A9%E3%82%AF%E3%83%86%E3%82%A3%E3%82%B9%E3%80%82%3C%2FSPAN%3E%3CBR%20clear%3D%22none%22%20%2F%3E1.%20SE%20%E5%86%85%E3%81%AB%E8%A8%BC%E6%98%8E%E6%9B%B8%E3%82%92%E5%AE%89%E5%85%A8%E3%81%AB%E4%BF%9D%E5%AD%98%E3%81%99%E3%82%8B%3A%20MW%20%E3%81%AE%E3%83%87%E3%83%A2%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3A%20%3CSPAN%3Ese05x_GetCertificate%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%80%81%20%3CSPAN%3Ese05x_InjectCertificate%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E2.%20%E3%83%9B%E3%82%B9%E3%83%88%E3%81%A8%20SE%20%E9%96%93%E3%81%AE%E9%80%9A%E4%BF%A1%E3%82%92%E4%BF%9D%E8%AD%B7%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81platformSCP%20%E3%82%92%E5%B8%B8%E3%81%AB%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%0A%3CDIV%3E%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%20%3CSTRONG%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN12570.pdf%22%20shape%3D%22rect%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN12570.pdf%3C%2FA%3E%3C%2FSTRONG%3E%E3%81%AE%E7%AC%AC%205%20%E7%AB%A0%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82SE052F%20%E3%81%A7%E3%81%AF%E3%80%81platformSCP%20%E3%81%8C%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%A7%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E5%A4%A7%E9%87%8F%E7%94%9F%E7%94%A3%E6%99%82%E3%81%AB%E3%81%AF%E3%80%81%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E3%82%AD%E3%83%BC%E3%82%92%E7%8B%AC%E8%87%AA%E3%81%AB%E5%AE%9A%E7%BE%A9%E3%81%97%E3%81%9F%E3%82%AD%E3%83%BC%E3%81%AB%E3%83%AD%E3%83%BC%E3%83%86%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E6%B8%88%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%0A%3CDIV%3E%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E3%82%AD%E3%83%BC%E3%81%AF%E6%AC%A1%E3%81%AE%E5%A0%B4%E6%89%80%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN14277.pdf%22%20shape%3D%22rect%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN14277.pdf%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FDIV%3E%0A%3CDIV%3E%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81MW%20%E3%81%AE%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20SCP03%20%E3%82%AD%E3%83%BC%E3%81%AE%E3%83%AD%E3%83%BC%E3%83%86%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20%E3%83%87%E3%83%A2%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FDIV%3E%0A%3CDIV%3E3.%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%E6%97%A9%E6%9C%9F%E7%AB%8B%E3%81%A1%E4%B8%8A%E3%81%92%E3%81%AB%E3%81%AF%E9%96%8B%E7%99%BA%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A8%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fdevelopment-boards-and-designs%2FOM-SE052ARD%22%20shape%3D%22rect%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EOM-SE052ARD%3A%20EdgeLock%20SE052F%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%82%A8%E3%83%AC%E3%83%A1%E3%83%B3%E3%83%88%E7%94%A8%E9%96%8B%E7%99%BA%E3%83%9C%E3%83%BC%E3%83%89%20%7C%20NXP%20Semiconductors%3C%2FA%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fpart%2FOM-SE050RPI%22%20shape%3D%22rect%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EOM-SE050RPI%20%E8%A3%BD%E5%93%81%E6%83%85%E5%A0%B1%20%7C%20NXP%E3%82%BB%E3%83%9F%E3%82%B3%E3%83%B3%E3%83%80%E3%82%AF%E3%82%BF%E3%83%BC%E3%82%BA%3C%2FA%3E%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%0A%3CP%3E%E3%81%99%E3%81%A6%E3%81%8D%E3%81%AA%E4%B8%80%E6%97%A5%E3%82%92%E3%80%81%3CBR%20%2F%3E%E3%82%AB%E3%83%B3%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E---------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%E8%A8%98%EF%BC%9A%3CBR%20%2F%3E%20-%20%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%8C%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%B8%E3%81%AE%E5%9B%9E%E7%AD%94%E3%81%A7%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%80%8C%E6%AD%A3%E8%A7%A3%E3%81%A8%E3%81%97%E3%81%A6%E3%83%9E%E3%83%BC%E3%82%AF%E3%80%8D%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%EF%BC%81%3CBR%20%2F%3E%20-%20%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%81%AF%E6%9C%80%E5%BE%8C%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%8B%E3%82%897%E9%80%B1%E9%96%93%E3%83%95%E3%82%A9%E3%83%AD%E3%83%BC%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E4%BB%A5%E9%99%8D%E3%81%AE%E8%BF%94%E4%BF%A1%E3%81%AF%E7%84%A1%E8%A6%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E5%BE%8C%E3%81%BB%E3%81%A9%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%82%92%E9%96%8B%E3%81%84%E3%81%A6%E3%80%81%E9%96%89%E3%81%98%E3%81%9F%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E---------------------------------------------------------------------------------%3C%2FP%3E%0A%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
