POLICY_OBJ_ALLOW_DELETE and Reset
3,801 次查看
psvz
If I attached POLICY_OBJ_ALLOW_DELETE = False to a key object - would it help to preserve it over ssscli se05x reset?
3,790 次查看
psvz
Hi Kan
I am trying to achieve the opposite effect. I want a key that I have provisioned to stay in secure element forever and couldn't be deleted - same way as NXP keys and certificates. Is it possible?
5 回复数
3,744 次查看
psvz
Se05x_API_DeleteAll() fails if I open session with kSSS_AuthType_None. Do you know if session with kSSS_AuthType_SCP03 would work? any working demo using Se05x_API_DeleteAll()?
3,741 次查看
Kan_Li
Hi @psvz ,
Actually this command can only be used in the session authenticated using the
credential with index RESERVED_ID_FACTORY_RESET, and this Auth ID might be not available in your device, but you may provision it with the help of ssscli tool.
Please kindly refer to https://www.nxp.com/webapp/Download?colCode=AN12543 for more details.
Kan
3,794 次查看
Kan_Li
Hi @psvz ,
Yes, you can do that, and usually we set up POLICY_OBJ_ALLOW_DELETE = True for some Auth ID to a key object so that you may still perform the deletion in some cases.
Hope that makes sense,
Kan
3,791 次查看
psvz
Hi Kan
3,754 次查看
Kan_Li
Hi @psvz ,
No , I don't think it is possible, you know, the DeleteAll command may delete all secure objects which are not trust provisioned by NXP.
Kan
