MbedTLS Server connection with client using SE052
1,896 次查看
MohitGediya
Hardware setup:
Board SoC: ESP32C3devkitm board and IC is SE052F2HN2Z019HJ.
Now i use nano plug and trust module's "se05x_mbedtls_alt_test" example.
Flash in board. But i face issue to verify "plugandtrust: Error in mbedtls_pk_verify. ret = -19968".
I change both key as per document of SE052. In my code.
Here is full sample application. Please verify it and suggest me the change that i need to fix.
Also give valid informative document about this so, i can explore more features of it.
And also,
I want to create TCP zephyr server based sample application. for that what informations i can store inside SE052 IC(this ic)? Which is use for cryptographic operation.
Which api and steps i need to follow to send encrypted data to client and client will decrypt the data.(client is other same setup board).
Which type of algorithm should i use for mbedTLS.
@Kan @Kan_Li @tseco
uint8_t scp03_enc_key[16] = {0x3a, 0xe4, 0x41, 0xc7, 0x47, 0xe3, 0x2e, 0xbc, 0x16, 0xb3, 0xbb, 0x2d, 0x84, 0x3c, 0x6d, 0xd8};
uint8_t scp03_mac_key[16] = {0x6c, 0x18, 0xf3, 0xd0, 0x8f, 0xee, 0x1c, 0xb9, 0x6a, 0x3c, 0x8d, 0xe5, 0xd3, 0x53, 0x8a, 0xaa};
标记 (1)
7 回复数
1,788 次查看
MohitGediya
1,788 次查看
MohitGediya
@carlos_o
Please give reply
1,814 次查看
Kan_Li
Hi @MohitGediya ,
Is it possible to have the APDU log out of the test when you run "se05x_mbedtls_alt_test" example?
Kan
1,809 次查看
MohitGediya
Here is logs.
@Kan_Li
1,786 次查看
Kan_Li
Hi @MohitGediya ,
Thanks for the info! I have shared with the SW team for review, and will let you know when I have any feedback from there.
Thanks for your patience!
Kan
1,681 次查看
MohitGediya
How software team will connects for this with me
1,605 次查看
Kan_Li
Hi @MohitGediya ,
I will be the contact window and let you know when there is any progress on this issue.
Kan
%3CLINGO-SUB%20id%3D%22lingo-sub-2370197%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BD%BF%E7%94%A8%20SE052%20%E8%BF%9E%E6%8E%A5%20MbedTLS%20%E6%9C%8D%E5%8A%A1%E5%99%A8%E4%B8%8E%E5%AE%A2%E6%88%B7%E7%AB%AF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2370197%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%A1%AC%E4%BB%B6%E8%AE%BE%E7%BD%AE%EF%BC%9A%3CBR%20%2F%3E%E4%B8%BB%E6%9D%BF%20SoC%EF%BC%9AESP32c3DevkitM%20%E4%B8%BB%E6%9D%BF%E5%92%8C%20IC%20%E6%98%AF%20SE052F2HN2Z019HJ%E3%80%82%3C%2FP%3E%3CP%3E%E7%8E%B0%E5%9C%A8%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%20nano%20%E6%8F%92%E4%BB%B6%E5%92%8C%E4%BF%A1%E4%BB%BB%E6%A8%A1%E5%9D%97%E7%9A%84%3CSTRONG%3E%22%3CU%3Ese05x_mbedtls_alt_test%3C%2FU%3E%22%20%3C%2FSTRONG%3E%E7%A4%BA%E4%BE%8B%E3%80%82%3CBR%20%2F%3E%E9%97%AA%E5%85%89%E7%81%AF%E5%9C%A8%E6%9D%BF%E3%80%82%E4%BD%86%E6%88%91%20%3CU%3E%3CSTRONG%3E%E9%9D%A2%E4%B8%B4%E7%9A%84%E9%97%AE%E9%A2%98%3C%2FSTRONG%3E%3C%2FU%3E%E9%AA%8C%E8%AF%81%20%3CSTRONG%3E%22%3C%2FSTRONG%3E%3CSTRONG%3E%3CU%3Eplugandtrust%EF%BC%9AError%20in%20mbedtls_pk_verify.%20ret%20%3D%20-19968%3C%2FU%3E%22.%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%8C%89%E7%85%A7%20SE052%20%E7%9A%84%E6%96%87%E4%BB%B6%E6%9B%B4%E6%94%B9%E4%BA%86%E4%B8%A4%E4%B8%AA%E5%AF%86%E9%92%A5%E3%80%82%E5%9C%A8%E6%88%91%E7%9A%84%E4%BB%A3%E7%A0%81%E4%B8%AD%3C%2FP%3E%3CP%3E%E4%B8%8B%E9%9D%A2%E6%98%AF%E5%AE%8C%E6%95%B4%E7%9A%84%E7%94%B3%E8%AF%B7%E7%A4%BA%E4%BE%8B%E3%80%82%E8%AF%B7%E9%AA%8C%E8%AF%81%E5%B9%B6%E5%BB%BA%E8%AE%AE%E6%88%91%E9%9C%80%E8%A6%81%E4%BF%AE%E6%94%B9%E7%9A%84%E5%9C%B0%E6%96%B9%E3%80%82%3CBR%20%2F%3E%E8%BF%98%E8%AF%B7%E6%8F%90%E4%BE%9B%E7%9B%B8%E5%85%B3%E7%9A%84%E6%9C%89%E6%95%88%E4%BF%A1%E6%81%AF%E6%96%87%E4%BB%B6%EF%BC%8C%E4%BB%A5%E4%BE%BF%E6%88%91%E5%8F%AF%E4%BB%A5%E6%8E%A2%E7%B4%A2%E5%AE%83%E7%9A%84%E6%9B%B4%E5%A4%9A%E5%8A%9F%E8%83%BD%E3%80%82%3CBR%20%2F%3E%E6%AD%A4%E5%A4%96%EF%BC%8C%3CBR%20%2F%3E%EF%BC%8C%E6%88%91%E6%83%B3%E5%88%9B%E5%BB%BA%E5%9F%BA%E4%BA%8E%20TCP%20zephyr%20%E6%9C%8D%E5%8A%A1%E5%99%A8%E7%9A%84%E7%A4%BA%E4%BE%8B%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E3%80%82%E4%B8%BA%E6%AD%A4%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E5%9C%A8%20SE052%20IC%EF%BC%88%E6%AD%A4%20IC%EF%BC%89%E4%B8%AD%E5%AD%98%E5%82%A8%E5%93%AA%E4%BA%9B%E4%BF%A1%E6%81%AF%EF%BC%9F%E5%AE%83%E7%94%A8%E4%BA%8E%E5%8A%A0%E5%AF%86%E6%93%8D%E4%BD%9C%E3%80%82%3CBR%20%2F%3E%E6%88%91%E9%9C%80%E8%A6%81%E9%81%B5%E5%BE%AA%E5%93%AA%E4%B8%AA%20API%20%E5%92%8C%E6%AD%A5%E9%AA%A4%E6%89%8D%E8%83%BD%E5%B0%86%E5%8A%A0%E5%AF%86%E6%95%B0%E6%8D%AE%E5%8F%91%E9%80%81%E7%BB%99%E5%AE%A2%E6%88%B7%E7%AB%AF%E5%92%8C%E5%AE%A2%E6%88%B7%E7%AB%AF%EF%BC%8C%E8%BF%99%E5%B0%86%E8%A7%A3%E5%AF%86%E6%95%B0%E6%8D%AE%E3%80%82%EF%BC%88%E5%AE%A2%E6%88%B7%E6%9C%BA%E6%98%AF%E5%8F%A6%E4%B8%80%E4%B8%AA%E7%9B%B8%E5%90%8C%E7%9A%84%E8%AE%BE%E7%BD%AE%E6%9D%BF%EF%BC%89%E3%80%82%3CBR%20%2F%3E%E6%88%91%E5%BA%94%E8%AF%A5%E4%B8%BA%20mbedTLS%20%E4%BD%BF%E7%94%A8%E5%93%AA%E7%A7%8D%E7%AE%97%E6%B3%95%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F38145%22%20target%3D%22_blank%22%3E%40Kan%3C%2FA%3E%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59276%22%20target%3D%22_blank%22%3E%40Kan_Li%3C%2FA%3E%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F46854%22%20target%3D%22_blank%22%3E%40tseco%3C%2FA%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Euint8_t%3C%2FSPAN%3E%20%3CSPAN%3Escp03_enc_key%3C%2FSPAN%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E16%3C%2FSPAN%3E%3CSPAN%3E%5D%20%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E%7B%3C%2FSPAN%3E%3CSPAN%3E0x3a%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E0xe4%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E0x41%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E0xc7%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E0x47%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E0xc7%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E0x2e%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E0xbc%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E0x16%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E0xb3%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E0xbb%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E0x2d%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E0x84%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E0x3c%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E0x6d%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E0xd8%3C%2FSPAN%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Euint8_t%3C%2FSPAN%3E%20%3CSPAN%3Escp03_mac_key%3C%2FSPAN%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E16%3C%2FSPAN%3E%3CSPAN%3E%5D%20%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E%7B%3C%2FSPAN%3E%3CSPAN%3E0x6c%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E0x18%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E0xf3%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E0xd0%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E0x8f%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E0xee%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E0x1c%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E0xb9%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E0x6a%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E0x3c%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E0x8d%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E0xe5%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E0xd3%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E0x53%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E0x8a%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E0xaa%3C%2FSPAN%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2371750%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MbedTLS%20Server%20connection%20with%20client%20using%20SE052%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2371750%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F262552%22%20target%3D%22_blank%22%3E%EF%BC%8C%40MohitGediya%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E4%BF%A1%E6%81%AF%EF%BC%81%E6%88%91%E5%B7%B2%E4%B8%8E%20SW%20%E5%9B%A2%E9%98%9F%E5%88%86%E4%BA%AB%E4%BA%86%E8%BF%99%E4%B8%80%E4%BF%A1%E6%81%AF%E4%BB%A5%E4%BE%9B%E5%AE%A1%E6%9F%A5%EF%BC%8C%E4%B8%80%E6%97%A6%E6%94%B6%E5%88%B0%E4%BB%96%E4%BB%AC%E7%9A%84%E5%8F%8D%E9%A6%88%EF%BC%8C%E6%88%91%E5%B0%86%E5%8F%8A%E6%97%B6%E9%80%9A%E7%9F%A5%E6%82%A8%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E8%80%90%E5%BF%83%E7%AD%89%E5%BE%85%EF%BC%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E5%9D%8E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2371739%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MbedTLS%20Server%20connection%20with%20client%20using%20SE052%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2371739%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F241501%22%20target%3D%22_blank%22%3E%40carlos_o%3C%2FA%3E%3C%2FP%3E%3CP%3E%E8%AF%B7%E7%BB%99%E4%BA%88%E7%AD%94%E5%A4%8D%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2371737%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MbedTLS%20Server%20connection%20with%20client%20using%20SE052%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2371737%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%AF%B7%E5%9B%9E%E5%A4%8D%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59276%22%20target%3D%22_blank%22%3E%40Kan_Li%3C%2FA%3E%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FSmart-Cards-and-Secure-Element%2FRequest-for-AES-GCM-Example-with-SE052F%2Fm-p%2F2197350%23U2197350%22%20class%3D%22lia-mention-container-editor-message%20lia-img-icon-forum-thread%20lia-fa-icon%20lia-fa-forum%20lia-fa-thread%20lia-fa%22%20target%3D%22_blank%22%3E%E8%AF%B7%E6%B1%82%E6%8F%90%E4%BE%9B%E4%BD%BF%E7%94%A8%20SE052F%20%E7%9A%84%20AES-GCM%20%E7%A4%BA%E4%BE%8B%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2371248%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MbedTLS%20Server%20connection%20with%20client%20using%20SE052%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2371248%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%BF%99%E6%98%AF%E6%97%A5%E5%BF%97%E3%80%82%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59276%22%20target%3D%22_blank%22%3E%40Kan_Li%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2371153%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MbedTLS%20Server%20connection%20with%20client%20using%20SE052%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2371153%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F262552%22%20target%3D%22_blank%22%3E%EF%BC%8C%40MohitGediya%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%98%AF%E5%90%A6%E6%9C%89%E5%8F%AF%E8%83%BD%E5%9C%A8%E8%BF%90%E8%A1%8C%3CSTRONG%3E%22%3CU%3Ese05x_mbedtls_alt_test%3C%2FU%3E%22%20%3C%2FSTRONG%3E%3CSPAN%3E%E7%A4%BA%E4%BE%8B%20%3C%2FSPAN%3E%E6%97%B6%E8%AE%A9%20APDU%20%E9%80%80%E5%87%BA%E6%B5%8B%E8%AF%95%EF%BC%9F%20%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%A5%9D%E6%82%A8%E6%84%89%E5%BF%AB%EF%BC%8C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%3CBR%20%2F%3E-%20%E5%A6%82%E6%9E%9C%E6%9C%AC%E5%B8%96%E5%9B%9E%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%22%E6%A0%87%E8%AE%B0%E6%AD%A3%E7%A1%AE%22%20%E6%8C%89%E9%92%AE%E3%80%82%E8%B0%A2%E8%B0%A2%EF%BC%81%3CBR%20%2F%3E-%20%E6%88%91%E4%BB%AC%E4%BC%9A%E5%9C%A8%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E5%8F%91%E5%B8%96%E5%90%8E%E7%9A%84%207%20%E5%91%A8%E5%86%85%E8%B7%9F%E8%B8%AA%E4%B8%BB%E9%A2%98%EF%BC%8C%E4%B9%8B%E5%90%8E%E7%9A%84%E5%9B%9E%E5%A4%8D%E5%B0%86%E8%A2%AB%E5%BF%BD%E7%95%A5%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BB%A5%E5%90%8E%E6%9C%89%E7%9B%B8%E5%85%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E5%8F%A6%E5%BC%80%E6%96%B0%E4%B8%BB%E9%A2%98%EF%BC%8C%E5%B9%B6%E5%8F%82%E8%80%83%E5%B7%B2%E5%85%B3%E9%97%AD%E7%9A%84%E4%B8%BB%E9%A2%98%E3%80%82%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2374168%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MbedTLS%20Server%20connection%20with%20client%20using%20SE052%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2374168%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%BD%AF%E4%BB%B6%E5%9B%A2%E9%98%9F%E5%B0%86%E5%A6%82%E4%BD%95%E4%B8%8E%E6%88%91%E8%81%94%E7%B3%BB%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2374673%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MbedTLS%20Server%20connection%20with%20client%20using%20SE052%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2374673%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F262552%22%20target%3D%22_blank%22%3E%EF%BC%8C%40MohitGediya%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%88%91%E5%B0%86%E4%BD%9C%E4%B8%BA%E8%81%94%E7%B3%BB%E7%AA%97%E5%8F%A3%EF%BC%8C%E4%B8%80%E6%97%A6%E5%9C%A8%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E4%B8%8A%E6%9C%89%E4%BB%BB%E4%BD%95%E8%BF%9B%E5%B1%95%EF%BC%8C%E5%B0%B1%E4%BC%9A%E9%80%9A%E7%9F%A5%E4%BD%A0%E4%BB%AC%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E5%9D%8E%3C%2FP%3E%3C%2FLINGO-BODY%3E
