Is it recommended to use one AES key for both message authentication and message encryption?
1,505件の閲覧回数
jordijofrenxp
Generally, it is a good design to use different keys for different purposes. Typically, one master key is used to derive the other individual keys using defined constants. This scheme prevents the same keys being used for different uses cases and increases robustness.
タグ(1)
0 返答(返信)
