How to enable Platform SCP when using SE050
961 次查看
yang_lee
Hello everyone,
I'm using SE050E and having trouble using Platform SCP. I followed the instructions in AN12542 (https://www.nxp.jp/docs/en/application-note/AN12542.pdf#4#4) and defined SSS_HAVE_SE05X_AUTH_PLATFSCP03 1, but when I open a session by calling the ex_sss_boot_open function, the result is kStatus_SSS_Fail. Did I do something wrong? Everything worked fine when I use plain communication. Please let me know if I need to configure anything else.
标记 (2)
926 次查看
Kan_Li
Hi @yang_lee ,
The example provided in the chapter 6 is just for SE050E, but at first please make sure which build system you are using.
1. For MCUXpresso SDK based, please follow the steps within 6.2 and 6.3
2. For Cmake based, please follow the steps within 6.4 and 6.5
Hope that helps,
Kan
912 次查看
yang_lee
Hi @Kan_Li ,
I followed the instructions in sections 6.2 and 6.3 and tried running the se05x_MandatePlatformSCP example in SE-PLUG-TRUST-MW_04.07.01, but the sss_key_object_init(eraseAuthCtx.auth.ctx.idobj.pObj, &pCtx->host_ks) function returned kStatus_SSS_InvalidArgument. Do I need to call the ex_sss_boot_open, ex_sss_key_store_and_object_init, and ex_sss_boot_open_host_session functions as in the ex_sss_main_inc.h file before calling the sss_key_object_init function? The code is below:
/* clang-format off */
#define MandateSCP_UserID_VALUE                 \
        'N', 'E', 'E', 'D', 'S', 'C', 'P'            \
/* clang-format ON */
sss_status_t se050_platformSCP03(void)
sss_status_t status = kStatus_SSS_Fail;
    sss_object_t keyObject;
    ex_sss_boot_ctx_t gex_sss_mandate_scp_boot_ctx;
SE_Connect_Ctx_t eraseAuthCtx = { 0 };
sss_se05x_session_t *pSession = (sss_se05x_session_t *)&gex_sss_mandate_scp_boot_ctx.session;
    smStatus_t sw_status;
    Se05xSession_t *pSe05xSession;
    SE_Connect_Ctx_t* pOpenCtx;
    sss_object_t ex_id = { 0 };
    const uint8_t host_userid_value[] = MandateSCP_UserID_VALUE;
    const uint8_t userid_value_factoryreset[] = MandateSCP_UserID_VALUE;
    eraseAuthCtx.auth.ctx.idobj.pObj = &ex_id;
const char *portName = NULL;
    memset(&gex_sss_mandate_scp_boot_ctx, 0, sizeof(gex_sss_mandate_scp_boot_ctx));
//    /* initialize session to connect to the SE050 */
//    status = ex_sss_boot_open(&gex_sss_mandate_scp_boot_ctx, portName);
//    if (kStatus_SSS_Success != status)
//        ex_sss_session_close(&gex_sss_mandate_scp_boot_ctx);
//        return status; /* return error if can't initialize session with SE050 */
//    /* setup KeyStore */
//    status = ex_sss_key_store_and_object_init(&gex_sss_mandate_scp_boot_ctx);
//        return status; /* close sesion and return error if can't initialize fail */
//    ex_sss_boot_open_host_session(&gex_sss_mandate_scp_boot_ctx);
    /* Prepare host */
    status = sss_key_object_init(eraseAuthCtx.auth.ctx.idobj.pObj, &gex_sss_mandate_scp_boot_ctx.host_ks);
    if (kStatus_SSS_Success != status) {
        LOG_E("Failed sss_key_object_init");
        goto cleanup;
    status = sss_key_object_allocate_handle(eraseAuthCtx.auth.ctx.idobj.pObj,
                                            MAKE_TEST_ID(__LINE__),
                                            kSSS_KeyPart_Default,
                                            kSSS_CipherType_UserID,
                                            sizeof(host_userid_value),
                                            kKeyObject_Mode_Transient);
        LOG_E("Failed sss_key_object_allocate_handle");
        goto cleanup;
    status = sss_key_store_set_key(&gex_sss_mandate_scp_boot_ctx.host_ks,
                                   host_userid_value,
                                   sizeof(host_userid_value) * 8,
                                   NULL,
                                   0);
        LOG_E("Failed sss_key_store_set_key");
        goto cleanup;
    pSe05xSession = &pSession->s_ctx;
    sw_status = Se05x_API_WriteUserID(pSe05xSession,
        NULL,
        SE05x_MaxAttemps_NA,
        kSE05x_AppletResID_PLATFORM_SCP,
        userid_value_factoryreset,
        sizeof(userid_value_factoryreset),
        kSE05x_AttestationType_AUTH);
    pOpenCtx = &gex_sss_mandate_scp_boot_ctx.se05x_open_ctx;
    eraseAuthCtx.tunnelCtx = pOpenCtx->tunnelCtx;
    eraseAuthCtx.connType = pOpenCtx->connType;
    eraseAuthCtx.portName = pOpenCtx->portName;
    eraseAuthCtx.auth.authType = kSSS_AuthType_ID;
    sss_session_close(&gex_sss_mandate_scp_boot_ctx.session);
    status = sss_session_open(&gex_sss_mandate_scp_boot_ctx.session, kType_SSS_SE_SE05x,
                               kSSS_ConnectionType_Password, &eraseAuthCtx);
        LOG_E("Failed sss_session_open");
        goto cleanup;
    /* Call SE05X API to Mandate Platform SCP. */
    sw_status = Se05x_API_SetPlatformSCPRequest(&pSession->s_ctx, kSE05x_PlatformSCPRequest_REQUIRED);
    if(SM_OK != sw_status) {
        LOG_E("Se05x_API_SetPlatformSCPRequest Failed");
        goto cleanup;
    else {
        LOG_I("Se05x_API_SetPlatformSCPRequest Successful");
        LOG_W("Further communication must be encrypted");
cleanup:
    if (kStatus_SSS_Success == status) {
        LOG_I("se05x_MandatePlatformSCP Example Success !!!...");
    else {
        LOG_E("se05x_MandatePlatformSCP Example Failed !!!...");
    return status;
Duong
标记 (2)
%3CLINGO-SUB%20id%3D%22lingo-sub-2372103%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BD%BF%E7%94%A8%20SE050%20%E6%97%B6%E5%A6%82%E4%BD%95%E5%90%AF%E7%94%A8%E5%B9%B3%E5%8F%B0%20SCP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2372103%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%3C%2FP%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20SE050E%EF%BC%8C%E5%9C%A8%E4%BD%BF%E7%94%A8%20Platform%20SCP%20%E6%97%B6%E9%81%87%E5%88%B0%E4%BA%86%E9%BA%BB%E7%83%A6%E3%80%82%E6%88%91%E6%8C%89%E7%85%A7%20AN12542%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.jp%2Fdocs%2Fen%2Fapplication-note%2FAN12542.pdf%234%234%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E(https%3A%2F%2Fwww.nxp.jp%2Fdocs%2Fen%2Fapplication-note%2FAN12542.pdf%234%234)%3C%2FA%3E%20%E4%B8%AD%E7%9A%84%E8%AF%B4%E6%98%8E%E5%AE%9A%E4%B9%89%E4%BA%86%20SSS_HAVE_SE05X_AUTH_PLATFSCP03%201%EF%BC%8C%E4%BD%86%E5%BD%93%E6%88%91%E8%B0%83%E7%94%A8%20ex_sss_boot_open%20%E5%87%BD%E6%95%B0%E6%89%93%E5%BC%80%E4%BC%9A%E8%AF%9D%E6%97%B6%EF%BC%8C%E7%BB%93%E6%9E%9C%E5%8D%B4%E6%98%AF%20kStatus_SSS_Fail%E3%80%82%E6%88%91%E5%81%9A%E9%94%99%E4%BB%80%E4%B9%88%E4%BA%86%E5%90%97%EF%BC%9F%E4%BD%BF%E7%94%A8%E6%99%AE%E9%80%9A%E9%80%9A%E4%BF%A1%E6%97%B6%EF%BC%8C%E4%B8%80%E5%88%87%E6%AD%A3%E5%B8%B8%E3%80%82%E5%A6%82%E6%9E%9C%E8%BF%98%E9%9C%80%E8%A6%81%E5%85%B6%E4%BB%96%E9%85%8D%E7%BD%AE%EF%BC%8C%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2372103%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ESE050%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2372709%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20enable%20Platform%20SCP%20when%20using%20SE050%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2372709%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59276%22%20target%3D%22_blank%22%3E%40Kan_Li%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E6%88%91%E6%8C%89%E7%85%A7%E7%AC%AC%206.2%20%E5%92%8C%206.3%20%E8%8A%82%E4%B8%AD%E7%9A%84%E8%AF%B4%E6%98%8E%EF%BC%8C%E5%B0%9D%E8%AF%95%E8%BF%90%E8%A1%8C%3CSTRONG%3E%20SE-PLUG-TRUST-MW_04.07.01%3C%2FSTRONG%3E%20%E4%B8%AD%E7%9A%84%3CEM%3E%20se05x_MandatePlatformSCP%3C%2FEM%3E%20%E7%A4%BA%E4%BE%8B%EF%BC%8C%E4%BD%86%3CEM%3E%20%3C%2FEM%3Esss_key_object_init(eraseAuthCtx.auth.ctx.idobj.pObj%E3%80%81%26amp%3BpCtx-%26gt%3Bhost_ks)%20%E5%87%BD%E6%95%B0%E8%BF%94%E5%9B%9E%20kStatus_SSS_InvalidArgument%E3%80%82%E6%88%91%E9%9C%80%E8%A6%81%E8%B0%83%E7%94%A8%20ex%3CEM%3E_%3C%2FEM%3Esss_boot_open%E3%80%81%3CEM%3Eex_sss_key_store_and_object_init%3C%2FEM%3E%20%E5%92%8C%3CEM%3Eex_sss_boot_open_host_session%3C%2FEM%3E%E5%87%BD%E6%95%B0%E5%90%97%EF%BC%9F%E8%B0%83%E7%94%A8%3CEM%3Esss_key_object_init%3C%2FEM%3E%E5%87%BD%E6%95%B0%E4%B9%8B%E5%89%8D%E5%85%88%E8%B0%83%E7%94%A8sss_key_object_init%E6%96%87%E4%BB%B6%E5%90%97%EF%BC%9F%E4%BB%A3%E7%A0%81%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FP%3E%3CBR%20%2F%3E%3CDIV%3E%2F*%20%E5%85%B3%E9%97%AD%20clang-format%20*%2F%3C%2FDIV%3E%3CDIV%3E%23define%20MandateSCP_UserID_VALUE%20%5C%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%7B%20%5C%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20n'%E3%80%81'e'%E3%80%81'e'%E3%80%81'd'%E3%80%81's'%E3%80%81'c'%E3%80%81'p%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%2F*%20clang-format%20ON%20*%2F%3C%2FDIV%3E%3CDIV%3Esss_status_t%20se050_platformSCP03(void)%3C%2FDIV%3E%3CDIV%3E%7B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Esss_status_t%20status%20%3D%20kStatus_SSS_Fail%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%20%20%20%20sss_object_t%20keyObject%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20ex_sss_boot_ctx_t%20gex_sss_mandate_scp_boot_ctx%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ESE_Connect_Ctx_t%20eraseAuthCtx%20%3D%20%7B%200%20%7D%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Esss_se05x_session_t%20*pSession%20%3D%20(sss_se05x_session_t%20*)%26amp%3Bgex_sss_mandate_scp_boot_ctx.session%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%20%20%20%20smStatus_t%20sw_status%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20Se05xSession_t%20*pSe05xSession%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20SE_Connect_Ctx_t*%20pOpenCtx%EF%BC%9B%3C%2FDIV%3E%3CDIV%3Esss_object_t%20ex_id%20%3D%7B%200%20%7D%20%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20const%20uint8_t%20host_userid_value%5B%5D%20%3D%20MandateSCP_UserID_VALUE%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20const%20uint8_t%20userid_value_factoryreset%5B%5D%20%3D%20MandateSCP_UserID_VALUE%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20eraseAuthCtx.auth.ctx.idobj.pObj%20%3D%26amp%3Bex_id%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Econst%20char%20*portName%20%3D%20NULL%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20memset(%26amp%3Bgex_sss_mandate_scp_boot_ctx%2C%200%2C%20sizeof(gex_sss_mandate_scp_boot_ctx))%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%2F%2F*%20%E5%88%9D%E5%A7%8B%E5%8C%96%E4%BC%9A%E8%AF%9D%E4%BB%A5%E8%BF%9E%E6%8E%A5%20SE050%20*%2F%3C%2FDIV%3E%3CDIV%3E%2F%2F%20status%20%3D%20ex_sss_boot_open(%26amp%3Bgex_sss_mandate_scp_boot_ctx%2C%20portName)%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%2F%2F%20%E5%A6%82%E6%9E%9C%20(kStatus_SSS_Success%20!%3D%20status)%3C%2FDIV%3E%3CDIV%3E%2F%2F%20%7B%3C%2FDIV%3E%3CDIV%3E%2F%2F%20ex_sss_session_close(%26amp%3Bgex_sss_mandate_scp_boot_ctx)%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%2F%2F%20return%20status%3B%20%2F*%20return%20error%20if%20can't%20initialize%20session%20with%20SE050%20*%2F%3C%2FDIV%3E%3CDIV%3E%2F%2F%20%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%2F%2F%20**%20%E8%AE%BE%E7%BD%AE%E5%AF%86%E9%92%A5%E5%AD%98%E5%82%A8%20*%2F%3C%2FDIV%3E%3CDIV%3E%2F%2F%20status%20%3D%20ex_sss_key_store_and_object_init(%26amp%3Bgex_sss_mandate_scp_boot_ctx)%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%2F%2F%20%E5%A6%82%E6%9E%9C%20(kStatus_SSS_Success%20!%3D%20status)%3C%2FDIV%3E%3CDIV%3E%2F%2F%20%7B%3C%2FDIV%3E%3CDIV%3E%2F%2F%20ex_sss_session_close(%26amp%3Bgex_sss_mandate_scp_boot_ctx)%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%2F%2F%20return%20status%3B%20%2F*%20close%20sesion%20and%20return%20error%20if%20can't%20initialize%20fail%20*%2F%3C%2FDIV%3E%3CDIV%3E%2F%2F%20%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%2F%2F%20ex_sss_boot_open_host_session(%26amp%3Bgex_sss_mandate_scp_boot_ctx)%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%2F*%20%E5%87%86%E5%A4%87%E4%B8%BB%E6%9C%BA%20*%2F%20%20%3C%2FDIV%3E%3CDIV%3E%20%20%20%20status%20%3D%20sss_key_object_init(eraseAuthCtx.auth.ctx.idobj.pObj.php)%E3%80%81%26amp%3Bgex_sss_mandate_scp_boot_ctx.host_ks%EF%BC%89%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%E5%A6%82%E6%9E%9C%20(kStatus_SSS_Success%20!%3D%20status)%20%7B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20LOG_E(%22%E5%A4%B1%E8%B4%A5%E7%9A%84%20sss_key_object_init%22)%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%E5%8E%BB%E6%B8%85%E7%90%86%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%20%20%20%20status%20%3D%20sss_key_object_allocate_handle(eraseAuthCtx.auth.ctx.idobj.pObj.php)%E3%80%81%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20make_test_id(__LINE__)%E3%80%81%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20kSSS_KeyPart_Default%E3%80%81%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20kSSS_CipherType_UserID%E3%80%81%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20sizeof(host_userid_value)%E3%80%81%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20kKeyObject_Mode_Transient%EF%BC%89%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%E5%A6%82%E6%9E%9C%20(kStatus_SSS_Success%20!%3D%20status)%20%7B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20LOG_E(%22%E5%A4%B1%E8%B4%A5%E7%9A%84%20sss_key_object_allocate_handle%22)%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%E5%8E%BB%E6%B8%85%E7%90%86%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%20%20%20%20status%20%3D%20sss_key_store_set_key(%26amp%3Bgex_sss_mandate_scp_boot_ctx.host_ks%E3%80%81%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20eraseAuthCtx.auth.ctx.idobj.pObj%E3%80%81%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20host_userid_value%E3%80%81%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20sizeof(host_userid_value)%E3%80%81%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20sizeof(host_userid_value)%20*%208%E3%80%81%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20NULL%E3%80%81%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%200)%3B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%E5%A6%82%E6%9E%9C%20(kStatus_SSS_Success%20!%3D%20status)%20%7B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20LOG_E(%22%E5%A4%B1%E8%B4%A5%E7%9A%84%20sss_key_store_set_key%22)%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%E5%8E%BB%E6%B8%85%E7%90%86%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20pSe05xSession%20%3D%26amp%3BpSession-%26gt%3Bs_ctx%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20sw_status%20%3D%20Se05x_API_WriteUserID%EF%BC%88pSe05xSession%E3%80%81%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20NULL%E3%80%81%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20SE05x_MaxAttemps_NA%E3%80%81%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20kSE05x_AppletResID_PLATFORM_SCP%E3%80%81%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20userid_value_factoryreset%E3%80%81%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20sizeof(userid_value_factoryreset)%E3%80%81%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20kSE05x_AttestationType_AUTH%EF%BC%89%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20pOpenCtx%20%3D%26amp%3Bgex_sss_mandate_scp_boot_ctx.se05x_open_ctx%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20eraseAuthCtx.tunnelCtx%20%3D%20pOpenCtx-%26gt%3BtunnelCtx%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20eraseAuthCtx.connType%20%3D%20pOpenCtx-%26gt%3BconnType%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20eraseAuthCtx.portName%20%3D%20pOpenCtx-%26gt%3BportName%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20eraseAuthCtx.auth.authType%20%3D%20kSSS_AuthType_ID%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20sss_session_close(%26amp%3Bgex_sss_mandate_scp_boot_ctx.session)%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20pSe05xSession%20%3D%26amp%3BpSession-%26gt%3Bs_ctx%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20status%20%3D%20sss_session_open(%26amp%3Bgex_sss_mandate_scp_boot_ctx.session%E3%80%81kType_SSS_SE_SE05x%E3%80%81%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20kSE05x_AppletResID_PLATFORM_SCP%E3%80%81%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20kSSS_ConnectionType_Password%2C%26amp%3BeraseAuthCtx)%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%E5%A6%82%E6%9E%9C%20(kStatus_SSS_Success%20!%3D%20status)%20%7B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20LOG_E(%22%E5%A4%B1%E8%B4%A5%E7%9A%84%20sss_session_open%22)%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%E5%8E%BB%E6%B8%85%E7%90%86%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%2F*%20%E8%B0%83%E7%94%A8%20SE05X%20API%20%E6%8E%88%E6%9D%83%E5%B9%B3%E5%8F%B0%20SCP%E3%80%82*%2F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20sw_status%20%3D%20Se05x_API_SetPlatformSCPRequest(%26amp%3BpSession-%26gt%3Bs_ctx%2C%20kSE05x_PlatformSCPRequest_REQUIRED)%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20if(SM_OK%20!%3D%20sw_status)%20%7B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20LOG_E(%22Se05x_API_SetPlatformSCPRequest%20%E5%A4%B1%E8%B4%A5%22)%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%E5%8E%BB%E6%B8%85%E7%90%86%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%E5%90%A6%E5%88%99%20%7B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20LOG_I(%22Se05x_API_SetPlatformSCPRequest%20Successful%22)%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20LOG_W(%22%E8%BF%9B%E4%B8%80%E6%AD%A5%E9%80%9A%E4%BF%A1%E5%BF%85%E9%A1%BB%E5%8A%A0%E5%AF%86%22)%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E6%B8%85%E7%90%86%EF%BC%9A%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%E5%A6%82%E6%9E%9C%20(kStatus_SSS_Success%20%3D%3D%20status)%20%7B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20LOG_I(%22se05x_MandatePlatformSCP%20Example%20Success%20!!!...%22)%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%E5%90%A6%E5%88%99%20%7B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20LOG_E(%22se05x_MandatePlatformSCP%20Example%20Failed%20!!!...%22)%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%E8%BF%94%E5%9B%9E%E7%8A%B6%E6%80%81%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3EDuong%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2372675%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20enable%20Platform%20SCP%20when%20using%20SE050%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2372675%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F252826%22%20target%3D%22_blank%22%3E%40yang_lee%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%AC%AC%206%20%E7%AB%A0%E4%B8%AD%E6%8F%90%E4%BE%9B%E7%9A%84%E7%A4%BA%E4%BE%8B%E4%BB%85%E9%80%82%E7%94%A8%E4%BA%8E%20SE050E%EF%BC%8C%E4%BD%86%E9%A6%96%E5%85%88%E8%AF%B7%E7%A1%AE%E5%AE%9A%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E5%93%AA%E4%B8%AA%E7%BC%96%E8%AF%91%E7%B3%BB%E7%BB%9F%E3%80%82%3C%2FP%3E%0A%3CP%3E1.%E5%A6%82%E6%9E%9C%E4%BD%BF%E7%94%A8%20MCUXpresso%20SDK%EF%BC%8C%E8%AF%B7%E6%8C%89%E7%85%A7%206.2%20%E5%92%8C%206.3%20%E4%B8%AD%E7%9A%84%E6%AD%A5%E9%AA%A4%E6%93%8D%E4%BD%9C%3C%2FP%3E%0A%3CP%3E2.%E5%A6%82%E6%9E%9C%E4%BD%BF%E7%94%A8%20Cmake%EF%BC%8C%E8%AF%B7%E6%8C%89%E7%85%A7%206.4%20%E5%92%8C%206.5%20%E4%B8%AD%E7%9A%84%E6%AD%A5%E9%AA%A4%E6%93%8D%E4%BD%9C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%B8%8C%E6%9C%9B%E5%AF%B9%E4%BD%A0%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%A5%9D%E6%82%A8%E6%84%89%E5%BF%AB%EF%BC%8C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%3CBR%20%2F%3E-%20%E5%A6%82%E6%9E%9C%E6%9C%AC%E5%B8%96%E5%9B%9E%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%22%E6%A0%87%E8%AE%B0%E6%AD%A3%E7%A1%AE%22%20%E6%8C%89%E9%92%AE%E3%80%82%E8%B0%A2%E8%B0%A2%EF%BC%81%3CBR%20%2F%3E-%20%E6%88%91%E4%BB%AC%E4%BC%9A%E5%9C%A8%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E5%8F%91%E5%B8%96%E5%90%8E%E7%9A%84%207%20%E5%91%A8%E5%86%85%E8%B7%9F%E8%B8%AA%E4%B8%BB%E9%A2%98%EF%BC%8C%E4%B9%8B%E5%90%8E%E7%9A%84%E5%9B%9E%E5%A4%8D%E5%B0%86%E8%A2%AB%E5%BF%BD%E7%95%A5%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BB%A5%E5%90%8E%E6%9C%89%E7%9B%B8%E5%85%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E5%8F%A6%E5%BC%80%E6%96%B0%E4%B8%BB%E9%A2%98%EF%BC%8C%E5%B9%B6%E5%8F%82%E8%80%83%E5%B7%B2%E5%85%B3%E9%97%AD%E7%9A%84%E4%B8%BB%E9%A2%98%E3%80%82%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E
