How to batch modify SCP03 KEY of SE05E?
Nancy_LAN
Dear Kan,
  The customer wants to know how to batch modify the SCP03 KEY of SE050E. Have they encountered such cases in previous users? Do you have any good suggestions?
For example, do users need to design the board themselves and modify it using the touch points and software methods on it? Is this feasible?
Looking forward to your reply!
Best Wishes!
Kan_Li
Hi @Nancy_LAN ,
To modify the SCP03 keys on SE050E , we recommend implementing it in the application code which holds the default SCP03 keys as well as the new keys, so the device may rotate the default keys with the new ones on the first power up. We provide rotating demo in the MW, and they may use it as a reference.
Hope that helps,
Kan
Kan_Li
Hi @Nancy_LAN ,
Hope that helps,
Kan
%3CLINGO-SUB%20id%3D%22lingo-sub-2248789%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHow%20to%20batch%20modify%20SCP03%20KEY%20of%20SE05E%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2248789%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDear%20Kan%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%20The%20customer%20wants%20to%20know%20how%20to%20batch%20modify%20the%20SCP03%20KEY%20of%20SE050E.%20Have%20they%20encountered%20such%20cases%20in%20previous%20users%3F%20Do%20you%20have%20any%20good%20suggestions%3F%3C%2FP%3E%3CP%3EFor%20example%2C%20do%20users%20need%20to%20design%20the%20board%20themselves%20and%20modify%20it%20using%20the%20touch%20points%20and%20software%20methods%20on%20it%3F%20Is%20this%20feasible%EF%BC%9F%3C%2FP%3E%3CP%3ELooking%20forward%20to%20your%20reply%EF%BC%81%3C%2FP%3E%3CP%3EBest%20Wishes%EF%BC%81%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2248873%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20batch%20modify%20SCP03%20KEY%20of%20SE05E%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2248873%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F241117%22%20target%3D%22_blank%22%3E%40Nancy_LAN%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ETo%20modify%20the%20SCP03%20keys%20on%20SE050E%20%2C%20we%20recommend%20implementing%20it%20in%20the%20application%20code%20which%20holds%20the%20default%20SCP03%20keys%20as%20well%20as%20the%20new%20keys%2C%20so%20the%20device%20may%20rotate%20the%20default%20keys%20with%20the%20new%20ones%20on%20the%20first%20power%20up.%20We%20provide%20rotating%20demo%20in%20the%20MW%2C%20and%20they%20may%20use%20it%20as%20a%20reference.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EHope%20that%20helps%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EHave%20a%20great%20day%2C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3ENote%3A%3CBR%20%2F%3E-%20If%20this%20post%20answers%20your%20question%2C%20please%20click%20the%20%22Mark%20Correct%22%20button.%20Thank%20you!%3CBR%20%2F%3E-%20We%20are%20following%20threads%20for%207%20weeks%20after%20the%20last%20post%2C%20later%20replies%20are%20ignored%3CBR%20%2F%3EPlease%20open%20a%20new%20thread%20and%20refer%20to%20the%20closed%20one%2C%20if%20you%20have%20a%20related%20question%20at%20a%20later%20point%20in%20time.%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E
