Generate Private RSA key Inside SE052
1,051件の閲覧回数
MohitGediya
I use SE052 Secuere element IC.
I create zephyr based sample application which is generates RSA private key inside SE052.
But face the issue to generate new private RSA key, check this logs and fix it.
I want to Generate RSA key inside SE052 which can be use for TLS handshake process.
board is ESP32c3devkitm.
Zephyr RTOS version is 3.7.0 and TLS handshake v.1.2 is use.
I attach also sample application and logs with you. Please suggest how to generate RSA key.
@Kan_Li
Logs are in .c file key_generation_failed.c file
ラベル(2)
タグ(2)
3 返答(返信)
1,050件の閲覧回数
MohitGediya
Function defination of called function is in last and it's comment for your reference.
Is there any issue about associated keyID?
Or APDU command header.
Can i generate only private key or key_pair in any format. There is no issue about type.
I just want any type of private RSA key inside SE052.
1,006件の閲覧回数
MohitGediya
996件の閲覧回数
Kan_Li
Hi @MohitGediya ,
Please use Se05x_API_WriteRSAKey() to generate the RSA key, the sample code can be something like below:
status = Se05x_API_WriteRSAKey(pSe05xSession,
(Se05xPolicy_t *)&policy_for_auth_obj,
RSA_ATTESTATION_KEY_ID,
2048,
SE05X_RSA_NO_p,
SE05X_RSA_NO_q,
SE05X_RSA_NO_dp,
SE05X_RSA_NO_dq,
SE05X_RSA_NO_qInv,
SE05X_RSA_NO_pubExp,
SE05X_RSA_NO_priv,
SE05X_RSA_NO_pubMod,
kSE05x_INS_NA,
kSE05x_KeyPart_Pair,
kSE05x_RSAKeyFormat_CRT);
Please assign proper policy to the key pair, especially no disabling the deletion, otherwise the key can not be removed any more.
Kan
%3CLINGO-SUB%20id%3D%22lingo-sub-2382586%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ESE052%E5%86%85%E3%81%A7RSA%E7%A7%98%E5%AF%86%E9%8D%B5%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2382586%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%A7%81%E3%81%AFSE052%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%82%A8%E3%83%AC%E3%83%A1%E3%83%B3%E3%83%88IC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E7%A7%81%E3%81%AFZephyr%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81SE052%E5%86%85%E3%81%A7RSA%E7%A7%98%E5%AF%86%E9%8D%B5%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E6%96%B0%E3%81%97%E3%81%84RSA%E7%A7%98%E5%AF%86%E9%8D%B5%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%E9%9A%9B%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E3%83%AD%E3%82%B0%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3ESE052%E5%86%85%E3%81%A7RSA%E3%82%AD%E3%83%BC%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%80%81TLS%E3%83%8F%E3%83%B3%E3%83%89%E3%82%B7%E3%82%A7%E3%82%A4%E3%82%AF%E5%87%A6%E7%90%86%E3%81%AB%E4%BD%BF%E3%81%84%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AFESP32c3devkitm%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3EZephyr%20RTOS%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AF3.7.0%E3%81%A7%E3%80%81TLS%E3%83%8F%E3%83%B3%E3%83%89%E3%82%B7%E3%82%A7%E3%82%A4%E3%82%AFv.1.2%E3%81%8C%E4%BD%BF%E3%82%8F%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A8%E3%83%AD%E3%82%B0%E3%82%82%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%BE%E3%81%99%E3%80%82RSA%E9%8D%B5%E3%81%AE%E7%94%9F%E6%88%90%E6%96%B9%E6%B3%95%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59276%22%20target%3D%22_blank%22%3E%40Kan_Li%3C%2FA%3E%3CBR%20%2F%3E%E3%83%AD%E3%82%B0%E3%81%AF.c%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20key_generation_failed.c%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2382586%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EA71CH%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ESE050%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2382854%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Generate%20Private%20RSA%20key%20Inside%20SE052%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2382854%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F262552%22%20target%3D%22_blank%22%3E%40MohitGediya%20%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ERSA%E3%82%AD%E3%83%BC%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AFSe05x_API_WriteRSAKey()%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E9%80%9A%E3%82%8A%E3%81%A7%E3%81%99%3A%3C%2FP%3E%0A%3CP%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20Se05x_API_WriteRSAKey(pSe05xSession%E3%80%81%3CBR%20%2F%3E%20(Se05xPolicy_t%20*)%26amp%3Bpolicy_for_auth_obj%E3%80%81%3CBR%20%2F%3E%20RSA_ATTESTATION_KEY_ID%E3%80%81%3CBR%20%2F%3E%202048%E5%B9%B4%3CBR%20%2F%3ESE05X_RSA_NO_p%E3%80%81%3CBR%20%2F%3E%20SE05X_RSA_NO_q%E3%80%81%3CBR%20%2F%3E%20SE05X_RSA_NO_dp%E3%80%81%3CBR%20%2F%3E%20SE05X_RSA_NO_dq%E3%80%81%3CBR%20%2F%3E%20SE05X_RSA_NO_qInv%E3%80%81%3CBR%20%2F%3E%20SE05X_RSA_NO_pubExp%E3%80%81%3CBR%20%2F%3E%20SE05X_RSA_NO_priv%E3%80%81%3CBR%20%2F%3E%20SE05X_RSA_NO_pubMod%E3%80%81%3CBR%20%2F%3E%20kSE05x_INS_NA%E3%80%81%3CBR%20%2F%3E%20kSE05x_%E3%82%AD%E3%83%BC%E3%83%91%E3%83%BC%E3%83%84%E3%83%9A%E3%82%A2%E3%80%81%3CBR%20%2F%3E%20kSE05x_RSAKeyFormat_CRT)%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%AD%E3%83%BC%E3%83%9A%E3%82%A2%E3%81%AB%E9%81%A9%E5%88%87%E3%81%AA%E3%83%9D%E3%83%AA%E3%82%B7%E3%83%BC%E3%82%92%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E7%89%B9%E3%81%AB%E5%89%8A%E9%99%A4%E3%82%92%E7%84%A1%E5%8A%B9%E5%8C%96%E3%81%97%E3%81%AA%E3%81%84%E3%81%A8%E3%80%81%E3%82%AD%E3%83%BC%E3%81%AF%E5%89%8A%E9%99%A4%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%99%E3%81%A6%E3%81%8D%E3%81%AA%E4%B8%80%E6%97%A5%E3%82%92%E3%80%81%3CBR%20%2F%3E%E3%82%AB%E3%83%B3%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%E8%A8%98%EF%BC%9A%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%8C%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%B8%E3%81%AE%E5%9B%9E%E7%AD%94%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%80%8C%E6%AD%A3%E8%A7%A3%E3%81%A8%E3%81%97%E3%81%A6%E3%83%9E%E3%83%BC%E3%82%AF%E3%80%8D%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99!%3CBR%20%2F%3E-%20%E5%89%8D%E5%9B%9E%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%8B%E3%82%897%E9%80%B1%E9%96%93Thread%E3%82%92%E3%83%95%E3%82%A9%E3%83%AD%E3%83%BC%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%81%9D%E3%81%AE%E5%BE%8C%E3%81%AE%E8%BF%94%E4%BF%A1%E3%81%AF%E7%84%A1%E8%A6%96%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%82%82%E3%81%97%E5%BE%8C%E3%81%A7%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81%E6%96%B0%E3%81%97%E3%81%84Thread%E3%82%92%E9%96%8B%E3%81%8D%E3%80%81%E9%96%89%E3%81%98%E3%81%9FThread%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2382848%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Generate%20Private%20RSA%20key%20Inside%20SE052%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2382848%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FSecure-Authentication%2FMbedTLS-Server-connection-with-client-using-SE052%2Fm-p%2F2370197%23U2370197%22%20class%3D%22lia-mention-container-editor-message%20lia-img-icon-forum-thread%20lia-fa-icon%20lia-fa-forum%20lia-fa-thread%20lia-fa%22%20target%3D%22_blank%22%3EMbedTLS%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%A8%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E9%96%93%E3%81%AESE052%3C%2FA%3E%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FSecure-Authentication%2FMbedTLS-v-1-2-handshake%2Fm-p%2F2374365%23U2374365%22%20class%3D%22lia-mention-container-editor-message%20lia-img-icon-forum-thread%20lia-fa-icon%20lia-fa-forum%20lia-fa-thread%20lia-fa%22%20target%3D%22_blank%22%3EMbedTLS%20v.1.2%E3%83%8F%E3%83%B3%E3%83%89%E3%82%B7%E3%82%A7%E3%82%A4%E3%82%AF%3C%2FA%3E%E3%81%AB%E3%82%88%E3%82%8B%E6%8E%A5%E7%B6%9A%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59276%22%20target%3D%22_blank%22%3E%40Kan_Li%20%E3%81%95%E3%82%93%3C%2FA%3E%E3%81%AB%E8%BF%94%E4%BF%A1%E3%82%92%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2382587%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Generate%20Private%20RSA%20key%20Inside%20SE052%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2382587%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%95%E3%82%8C%E3%82%8B%E9%96%A2%E6%95%B0%E3%81%AE%E5%AE%9A%E7%BE%A9%E3%81%AF%E6%9C%80%E5%BE%8C%E3%81%AB%E3%81%82%E3%82%8A%E3%80%81%E5%8F%82%E8%80%83%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%81%A8%E3%81%97%E3%81%A6%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E9%96%A2%E9%80%A3%E4%BB%98%E3%81%91%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%AD%E3%83%BCID%E3%81%AB%E4%BD%95%E3%81%8B%E5%95%8F%E9%A1%8C%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3CBR%20%2F%3E%E3%81%BE%E3%81%9F%E3%81%AFAPDU%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%80%82%3CBR%20%2F%3E%E7%A7%98%E5%AF%86%E9%8D%B5%E3%82%84key_pair%E3%81%A0%E3%81%91%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%E5%9E%8B%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E5%95%8F%E9%A1%8C%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3ESE052%E3%81%AE%E4%B8%AD%E3%81%AB%E3%80%81%E3%81%A9%E3%82%93%E3%81%AA%E7%A8%AE%E9%A1%9E%E3%81%AERSA%E7%A7%98%E5%AF%86%E9%8D%B5%E3%81%A7%E3%82%82%E3%81%84%E3%81%84%E3%81%AE%E3%81%A7%E5%85%A5%E3%82%8C%E3%81%9F%E3%81%84%E3%82%93%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
