Generate Private RSA key Inside SE052
1,047 次查看
MohitGediya
I use SE052 Secuere element IC.
I create zephyr based sample application which is generates RSA private key inside SE052.
But face the issue to generate new private RSA key, check this logs and fix it.
I want to Generate RSA key inside SE052 which can be use for TLS handshake process.
board is ESP32c3devkitm.
Zephyr RTOS version is 3.7.0 and TLS handshake v.1.2 is use.
I attach also sample application and logs with you. Please suggest how to generate RSA key.
@Kan_Li
Logs are in .c file key_generation_failed.c file
标签 (2)
标记 (2)
1,046 次查看
MohitGediya
Function defination of called function is in last and it's comment for your reference.
Is there any issue about associated keyID?
Or APDU command header.
Can i generate only private key or key_pair in any format. There is no issue about type.
I just want any type of private RSA key inside SE052.
1,002 次查看
MohitGediya
992 次查看
Kan_Li
Hi @MohitGediya ,
Please use Se05x_API_WriteRSAKey() to generate the RSA key, the sample code can be something like below:
status = Se05x_API_WriteRSAKey(pSe05xSession,
(Se05xPolicy_t *)&policy_for_auth_obj,
RSA_ATTESTATION_KEY_ID,
2048,
SE05X_RSA_NO_p,
SE05X_RSA_NO_q,
SE05X_RSA_NO_dp,
SE05X_RSA_NO_dq,
SE05X_RSA_NO_qInv,
SE05X_RSA_NO_pubExp,
SE05X_RSA_NO_priv,
SE05X_RSA_NO_pubMod,
kSE05x_INS_NA,
kSE05x_KeyPart_Pair,
kSE05x_RSAKeyFormat_CRT);
Please assign proper policy to the key pair, especially no disabling the deletion, otherwise the key can not be removed any more.
Kan
%3CLINGO-SUB%20id%3D%22lingo-sub-2382586%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9C%A8%20SE052%20%E5%86%85%E9%83%A8%E7%94%9F%E6%88%90%E7%A7%81%E9%92%A5%20RSA%20%E5%AF%86%E9%92%A5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2382586%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AFSE052%E5%AE%89%E5%85%A8%E5%85%83%E4%BB%B6%E9%9B%86%E6%88%90%E7%94%B5%E8%B7%AF%E3%80%82%3CBR%20%2F%3E%E6%88%91%E5%88%9B%E5%BB%BA%E4%BA%86%E4%B8%80%E4%B8%AA%E5%9F%BA%E4%BA%8E%20Zephyr%20%E7%9A%84%E7%A4%BA%E4%BE%8B%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E8%AF%A5%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%9C%A8%20SE052%20%E4%B8%AD%E7%94%9F%E6%88%90%20RSA%20%E7%A7%81%E9%92%A5%E3%80%82%3CBR%20%2F%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E5%9C%A8%E7%94%9F%E6%88%90%E6%96%B0%E7%9A%84%20RSA%20%E7%A7%81%E9%92%A5%E6%97%B6%E9%81%87%E5%88%B0%E4%BA%86%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E6%A3%80%E6%9F%A5%E6%AD%A4%E6%97%A5%E5%BF%97%E5%B9%B6%E4%BF%AE%E5%A4%8D%E5%AE%83%E3%80%82%3CBR%20%2F%3E%E6%88%91%E6%83%B3%E5%9C%A8%20SE052%20%E4%B8%AD%E7%94%9F%E6%88%90%20RSA%20%E5%AF%86%E9%92%A5%EF%BC%8C%E8%AF%A5%E5%AF%86%E9%92%A5%E5%8F%AF%E7%94%A8%E4%BA%8E%20TLS%20%E6%8F%A1%E6%89%8B%E8%BF%87%E7%A8%8B%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%E6%9D%BF%E6%98%AF%20ESP32c3devkitm%E3%80%82%3CBR%20%2F%3EZephyr%20RTOS%20%E7%89%88%E6%9C%AC%E4%B8%BA%203.7.0%EF%BC%8C%E4%BD%BF%E7%94%A8%20TLS%20%E6%8F%A1%E6%89%8B%20v.1.2%E3%80%82%3CBR%20%2F%3E%E6%88%91%E8%BF%98%E9%99%84%E4%B8%8A%E4%BA%86%E7%A4%BA%E4%BE%8B%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%92%8C%E6%97%A5%E5%BF%97%E3%80%82%E8%AF%B7%E9%97%AE%E5%A6%82%E4%BD%95%E7%94%9F%E6%88%90RSA%E5%AF%86%E9%92%A5%EF%BC%9F%3CBR%20%2F%3E%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59276%22%20target%3D%22_blank%22%3E%40Kan_Li%3C%2FA%3E%3CBR%20%2F%3E%E6%97%A5%E5%BF%97%E6%96%87%E4%BB%B6%E4%BD%8D%E4%BA%8E%20.c%20%E6%96%87%E4%BB%B6%E4%B8%AD%E3%80%82%E6%96%87%E4%BB%B6%20key_generation_failed.c%E6%96%87%E4%BB%B6%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2382586%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EA71CH%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ESE050%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2382854%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Generate%20Private%20RSA%20key%20Inside%20SE052%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2382854%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F262552%22%20target%3D%22_blank%22%3E%40MohitGediya%3C%2FA%3E%20%EF%BC%8C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%AF%B7%E4%BD%BF%E7%94%A8%20Se05x_API_WriteRSAKey()%20%E7%94%9F%E6%88%90%20RSA%20%E5%AF%86%E9%92%A5%EF%BC%8C%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%E5%A6%82%E4%B8%8B%E6%89%80%E7%A4%BA%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%E7%8A%B6%E6%80%81%20%3D%20Se05x_API_WriteRSAKey(pSe05xSession%2C%3CBR%20%2F%3E%20(Se05xPolicy_t%20*)%26amp%3Bpolicy_for_auth_obj%EF%BC%8C%3CBR%20%2F%3E%20RSA_ATTESTATION_KEY_ID%EF%BC%8C%3CBR%20%2F%3E%202048%E5%B9%B4%3CBR%20%2F%3ESE05X_RSA_NO_p%EF%BC%8C%3CBR%20%2F%3E%20SE05X_RSA_NO_q%EF%BC%8C%3CBR%20%2F%3E%20SE05X_RSA_NO_dp%EF%BC%8C%3CBR%20%2F%3E%20SE05X_RSA_NO_dq%EF%BC%8C%3CBR%20%2F%3E%20SE05X_RSA_NO_qInv%EF%BC%8C%3CBR%20%2F%3E%20SE05X_RSA_NO_pubExp%EF%BC%8C%3CBR%20%2F%3E%20SE05X_RSA_NO_priv%EF%BC%8C%3CBR%20%2F%3E%20SE05X_RSA_NO_pubMod%EF%BC%8C%3CBR%20%2F%3E%20kSE05x_INS_NA%EF%BC%8C%3CBR%20%2F%3E%20kSE05x_KeyPart_Pair%EF%BC%8C%3CBR%20%2F%3E%20kSE05x_RSAKeyFormat_CRT)%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%AF%B7%E4%B8%BA%E5%AF%86%E9%92%A5%E5%AF%B9%E5%88%86%E9%85%8D%E5%90%88%E9%80%82%E7%9A%84%E7%AD%96%E7%95%A5%EF%BC%8C%E5%B0%A4%E5%85%B6%E4%B8%8D%E8%A6%81%E7%A6%81%E7%94%A8%E5%88%A0%E9%99%A4%E5%8A%9F%E8%83%BD%EF%BC%8C%E5%90%A6%E5%88%99%E5%AF%86%E9%92%A5%E5%B0%86%E6%97%A0%E6%B3%95%E5%86%8D%E8%A2%AB%E5%88%A0%E9%99%A4%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%A5%9D%E4%BD%A0%E6%9C%89%E7%BE%8E%E5%A5%BD%E7%9A%84%E4%B8%80%E5%A4%A9%EF%BC%8C%3CBR%20%2F%3E%E5%9D%8E%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E7%AC%94%E8%AE%B0%EF%BC%9A%3CBR%20%2F%3E%20-%20%E5%A6%82%E6%9E%9C%E6%AD%A4%E5%9B%9E%E5%A4%8D%E8%A7%A3%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%E2%80%9C%E6%A0%87%E8%AE%B0%E4%B8%BA%E6%AD%A3%E7%A1%AE%E7%AD%94%E6%A1%88%E2%80%9D%E6%8C%89%E9%92%AE%E3%80%82%E8%B0%A2%E8%B0%A2%E4%BD%A0%EF%BC%81%3CBR%20%2F%3E%20-%20%E6%88%91%E4%BB%AC%E4%BC%9A%E6%8C%81%E7%BB%AD%E5%85%B3%E6%B3%A8%E5%B8%96%E5%AD%90%EF%BC%8C%E4%BB%8E%E6%9C%80%E5%90%8E%E4%B8%80%E6%9D%A1%E5%9B%9E%E5%A4%8D%E5%8F%91%E5%87%BA%E5%90%8E%E6%8C%81%E7%BB%AD7%E5%91%A8%EF%BC%8C%E4%B9%8B%E5%90%8E%E7%9A%84%E5%9B%9E%E5%A4%8D%E5%B0%86%E8%A2%AB%E5%BF%BD%E7%95%A5%E3%80%82%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%B9%8B%E5%90%8E%E6%9C%89%E7%9B%B8%E5%85%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E5%8F%A6%E5%BC%80%E6%96%B0%E5%B8%96%E5%B9%B6%E5%BC%95%E7%94%A8%E5%B7%B2%E5%85%B3%E9%97%AD%E7%9A%84%E5%B8%96%E5%AD%90%E3%80%82%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2382848%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Generate%20Private%20RSA%20key%20Inside%20SE052%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2382848%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%AF%B7%E5%9B%9E%E5%A4%8D%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FSecure-Authentication%2FMbedTLS-Server-connection-with-client-using-SE052%2Fm-p%2F2370197%23U2370197%22%20class%3D%22lia-mention-container-editor-message%20lia-img-icon-forum-thread%20lia-fa-icon%20lia-fa-forum%20lia-fa-thread%20lia-fa%22%20target%3D%22_blank%22%3E%E4%BD%BF%E7%94%A8%20SE052%3C%2FA%3E%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FSecure-Authentication%2FMbedTLS-v-1-2-handshake%2Fm-p%2F2374365%23U2374365%22%20class%3D%22lia-mention-container-editor-message%20lia-img-icon-forum-thread%20lia-fa-icon%20lia-fa-forum%20lia-fa-thread%20lia-fa%22%20target%3D%22_blank%22%3EMbedTLS%20v.1.2%20%E6%8F%A1%E6%89%8B%E5%8D%8F%E8%AE%AE%3C%2FA%3E%E8%BF%9E%E6%8E%A5%E5%AE%A2%E6%88%B7%E7%AB%AF%E5%92%8C%20MbedTLS%20%E6%9C%8D%E5%8A%A1%E5%99%A8%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59276%22%20target%3D%22_blank%22%3E%40Kan_Li%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2382587%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Generate%20Private%20RSA%20key%20Inside%20SE052%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2382587%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%A2%AB%E8%B0%83%E7%94%A8%E5%87%BD%E6%95%B0%E7%9A%84%E5%AE%9A%E4%B9%89%E5%9C%A8%E6%9C%80%E5%90%8E%EF%BC%8C%E5%B9%B6%E4%B8%94%E6%98%AF%E6%B3%A8%E9%87%8A%EF%BC%8C%E4%BE%9B%E6%82%A8%E5%8F%82%E8%80%83%E3%80%82%3CBR%20%2F%3E%E5%85%B3%E8%81%94%E7%9A%84%E5%AF%86%E9%92%A5ID%E6%98%AF%E5%90%A6%E5%AD%98%E5%9C%A8%E4%BB%BB%E4%BD%95%E9%97%AE%E9%A2%98%EF%BC%9F%3CBR%20%2F%3E%E6%88%96%E8%80%85%20APDU%20%E5%91%BD%E4%BB%A4%E5%A4%B4%E3%80%82%3CBR%20%2F%3E%E6%88%91%E5%8F%AF%E4%BB%A5%E5%8F%AA%E7%94%9F%E6%88%90%E7%A7%81%E9%92%A5%E6%88%96%E5%AF%86%E9%92%A5%E5%AF%B9%EF%BC%8C%E6%A0%BC%E5%BC%8F%E4%B8%8D%E9%99%90%E5%90%97%EF%BC%9F%E7%B1%BB%E5%9E%8B%E6%96%B9%E9%9D%A2%E6%B2%A1%E6%9C%89%E9%97%AE%E9%A2%98%E3%80%82%3CBR%20%2F%3E%E6%88%91%E5%8F%AA%E9%9C%80%E8%A6%81SE052%E4%B8%AD%E7%9A%84%E4%BB%BB%E4%BD%95%E7%B1%BB%E5%9E%8B%E7%9A%84RSA%E7%A7%81%E9%92%A5%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
