Generate CSR inside SE050
3,969 次查看
jb2
I use SE050 MW in C on a esp32.
I can generate a key pair with sss_key function but I don't find any function to generate and sign the CSR.
I don't want to put private key out the SE050 and use mbedtls.
Thank you
5 回复数
3,937 次查看
jb2
This example is for self-signed certificate. Do you have the same to create a Certificate Signing Request ?
Thank you
3,919 次查看
Kan_Li
Hi @jb2 ,
So far we don't have such kind of demo available, but which openssl/mbedtls version are you using? We may try to create a generic example code based on that.
Kan
3,909 次查看
jb2
I used mbedtls functions and I succeed to create my CSR.
I used the mbedtls example https://github.com/Mbed-TLS/mbedtls/blob/development/programs/x509/cert_req.c and I modified the file `x509write_csr.c` to use my function instead of `mbedtls_pk_sign`.
But I juste saw that `mbedtls_pk_sign_restartable( ctx, ...` use `ctx->pk_info->sign_func(...` so I think that it's cleaner to change this variable. I'll try.
3,903 次查看
Kan_Li
Hi @jb2 ,
Great to know that! Please kindly let me know if you have any further questions.
Kan
3,942 次查看
Kan_Li
Hi @jb2 ,
We have a demo on this topic, please kindly refer to simw- top/doc/demos/se05x/certificate_demo/Readme.html for details, and the source code may be found in simw-top\demos\se05x\certificate_demo .
Hope that helps,
Kan
