Encrypt more than 128 Byte of source data Using AES 128 on SE050
ソリューションへジャンプ
3,098件の閲覧回数
mohamedaslam_m
Hi Folks,
     I am using the SE050 development board for encryption purposes and I was checking the ex_symmetric example given in Plug and trust middleware. The example is given as 128 bits of Key, input data, and IV.
How do we encrypt if we have more than 128 bits of input data?
Aslam
ラベル(2)
3,090件の閲覧回数
Kan_Li
Hi @mohamedaslam_m ,
The following functions are provided for your case, the basic steps are init->update->update ... ->finish, as described in AN12413.
Hope that makes sense,
Kan
3,091件の閲覧回数
Kan_Li
Kan
