Enable OPENSSL Debug Logs with Yocto
2,961 次查看
kharding
Has anyone had success enabling OPENSSL Debug Logs with Yocto? I am trying to troubleshoot the se05x-openssl-provider which is not working correctly.
kharding
2,938 次查看
Kan_Li
Hi @kharding ,
The openssl can be rebuilt with "-g" option to enable the debug, please kindly refer to https://stackoverflow.com/questions/11129826/build-openssl-on-linux-with-g-for-debugging/11129991 for more details.
Kan
2,919 次查看
kharding
Hi @Kan_Li ,
Thank you so much for your help! The thread suggests adding "-g" to a stand-alone build, but I was curious if anyone was successful enabling debug in a openssl bitbake recipe.
kharding
2,909 次查看
Kan_Li
Hi @kharding ,
Actually there is no difference between recipe building and standalone building, you may modify the recipe for openssl by adding this option in do_configure ().
Hope that makes sense,
Kan
