EdgeLock SE051: se05x_Minimal fails with SCP03 errors after loading OpenSSL Provider
890 次查看
Uc_S
I am trying to use the OpenSSL Provider with the EdgeLock SE051 and SCP03 on Linux. I have run into an issue where the se05x_Minimal example works perfectly at first, but fails with SCP03 authentication errors after I install the shared libraries for the OpenSSL Provider.
Could you please advise on what might be causing this conflict?
Environment:
  • Board: MCIMX8M-WEVK and OM-SE051ARD
  • SoC: i.MX 8M
  • Linux version: 6.1.151-cip46
  • OpenSSL version: 3.0.20
  • Plug & Trust MW version: 04.07.01
Steps Taken:
  1. Built the Plug & Trust MW with the following CMake configuration:
    cmake ../simw-top \
    -DPTMW_Applet=SE05X_C \
    -DPTMW_SE05X_Ver=07_02 \
    -DPTMW_Host=iMXLinux \
    -DPTMW_SMCOM=T1oI2C \
    -DPTMW_HostCrypto=OPENSSL \
    -DPTMW_RTOS=Default \
    -DPTMW_mbedTLS_ALT=None \
    -DPTMW_SCP=SCP03_SSS \
    -DPTMW_FIPS=None \
    -DPTMW_SBL=None \
    -DPTMW_SE05X_Auth=PlatfSCP03 \
    -DPTMW_Log=Default \
    -DCMAKE_BUILD_TYPE=Release \
    -DPTMW_SE_RESET_LOGIC=1
  2. Copied simw-top/demos/linux/common/openssl30_sss_se050.cnf from the Plug & Trust MW directory to /root on the i.MX 8M.
  3. Exported the configuration environment variable:
    export OPENSSL_CONF=/root/openssl30_sss_se050.cnf
  4. Executed se05x_Minimal to confirm that the SE051 with SCP03 works correctly. It succeeded.
    App   :INFO :Running bin/se05x_Minimal
    App   :INFO :If you want to over-ride the selection, use ENV=EX_SSS_BOOT_SSS_PORT or pass in command line arguments.
    App   :INFO :PlugAndTrust_v04.07.01_20250519
    App   :INFO :Using default PlatfSCP03 keys. You can use keys from file using ENV=EX_SSS_BOOT_SCP03_PATH
    sss   :INFO :atr (Len=35)
          (snip)
    App   :INFO :mem=17196
    App   :INFO :se05x_Minimal Example Success !!!...
    App   :INFO :ex_sss Finished
  5. Copied libsssapisw.so, libsss_pkcs11.so, and libsssProvider.so to /usr/local/lib/. (Note: /usr/local/lib/ is the path specified in the [nxp_prov_sec] section of /root/openssl30_sss_se050.cnf)
  6. Executed se05x_Minimal again. This time, it failed with the following errors:
Error Output:
      (snip)
      (snip)
sss   :ERROR:Error in RAND_pseudo_bytes
scp   :WARN :nxEnsure:'status == kStatus_SSS_Success' failed. At Line:121 Function:nxScp03_AuthenticateChannel
sss   :ERROR:Could not set SCP03 Secure Channel
App   :ERROR:sss_session_open failed
App   :WARN :nxEnsure:'kStatus_SSS_Success == status' failed. At Line:240 Function:OSSL_provider_init
smCom :ERROR:phNxpEseProto7816_DecodeFrame Max retry count reached!!!
smCom :ERROR:phNxpEseProto7816_Transceive Transceive failed, hard reset to proceed
smCom :ERROR: phNxpEse_Transceive phNxpEseProto7816_Transceive- Failed
smCom :ERROR: Transcive Failed
sss   :WARN :nxEnsure:'retStatus == SM_OK' failed. At Line:7977 Function:sss_se05x_channel_txn
sss   :WARN :nxEnsure:'ret == SM_OK' failed. At Line:7839 Function:sss_se05x_TXn
sss   :WARN :APDU Transaction Error: Error (0xFFFF)
scp   :ERROR:GP_InitializeUpdate Failure on communication Link FFFF
scp   :ERROR:nxScp03_GP_InitializeUpdate fails with Status 3C3C0000
App   :ERROR:ex_sss_session_open Failed
App   :ERROR:!ERROR! ret != 0.
It seems that once the OpenSSL provider is successfully loaded by the configuration, something (possibly related to RAND_pseudo_bytes) breaks the SCP03 channel establishment.
Has anyone encountered this or knows what additional configurations might be missing?
Thank you in advance for your help.
847 次查看
Kan_Li
Hi @Uc_S ,
Did you set up the proper openssl version?  Please use the following option:
-DPTMW_OpenSSL=3_0
BTW, for test purpose, please enable verbose log to have more debug info.
-DPTMW_Log=Verbose
Kan
848 次查看
Kan_Li
Hi @Uc_S ,
-DPTMW_OpenSSL=3_0
-DPTMW_Log=Verbose
Kan
836 次查看
Uc_S
Thank you very much for your advice. You were exactly right.
The root cause of the issue was indeed the missing "-DPTMW_OpenSSL=3_0" option in my CMake configuration.
After adding "-DPTMW_OpenSSL=3_0 -DPTMW_Log=Verbose" and rebuilding the MW, the problem was completely resolved. Here are the results:
Executing Step 6 no longer throws any errors. It successfully outputs "App :INFO :mem=17196" as expected.
I also confirmed that even when setting the log level back to my originally intended configuration ("-DPTMW_Log=Default"  instead of Verbose), the application still executes perfectly and outputs "App :INFO :mem=17196".
I will mark this topic as resolved.
%3CLINGO-SUB%20id%3D%22lingo-sub-2383849%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EEdgeLock%20SE051%EF%BC%9A%E5%8A%A0%E8%BD%BD%20OpenSSL%20%E6%8F%90%E4%BE%9B%E7%A8%8B%E5%BA%8F%E5%90%8E%EF%BC%8Cse05x_Minimal%20%E5%87%BA%E7%8E%B0%20SCP03%20%E9%94%99%E8%AF%AF%E8%80%8C%E5%A4%B1%E8%B4%A5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2383849%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E5%9C%A8%20Linux%20%E7%B3%BB%E7%BB%9F%E4%B8%8A%E4%BD%BF%E7%94%A8%20EdgeLock%20SE051%20%E5%92%8C%20SCP03%20%E4%BB%A5%E5%8F%8A%20OpenSSL%20%E6%8F%90%E4%BE%9B%E7%A8%8B%E5%BA%8F%E3%80%82%E6%88%91%E9%81%87%E5%88%B0%E4%BA%86%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8Cse05x_Minimal%20%E7%A4%BA%E4%BE%8B%E4%B8%80%E5%BC%80%E5%A7%8B%E8%BF%90%E8%A1%8C%E5%AE%8C%E7%BE%8E%EF%BC%8C%E4%BD%86%E5%9C%A8%E5%AE%89%E8%A3%85%20OpenSSL%20%E6%8F%90%E4%BE%9B%E7%A8%8B%E5%BA%8F%E7%9A%84%E5%85%B1%E4%BA%AB%E5%BA%93%3CI%3E%E5%90%8E%EF%BC%8C%3C%2FI%3E%E5%87%BA%E7%8E%B0%20SCP03%20%E8%BA%AB%E4%BB%BD%E9%AA%8C%E8%AF%81%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E9%97%AE%E9%80%A0%E6%88%90%E8%BF%99%E7%A7%8D%E5%86%B2%E7%AA%81%E7%9A%84%E5%8E%9F%E5%9B%A0%E5%8F%AF%E8%83%BD%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E7%8E%AF%E5%A2%83%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E6%9D%BF%EF%BC%9A%3C%2FSTRONG%3E%20MCIMX8M-WEVK%20%E5%92%8C%20OM-SE051ARD%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3ESoC%EF%BC%9A%3C%2FSTRONG%3E%20i.MX%208M%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3ELinux%20%E7%89%88%E6%9C%AC%EF%BC%9A%3C%2FSTRONG%3E%206.1.151-cip46%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3EOpenSSL%20%E7%89%88%E6%9C%AC%EF%BC%9A%3C%2FSTRONG%3E%203.0.20%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3EPlug%20%26amp%3B%20Trust%20MW%20%E7%89%88%E6%9C%AC%EF%BC%9A%3C%2FSTRONG%3E%2004.07.01%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSTRONG%3E%E5%B7%B2%E9%87%87%E5%8F%96%E7%9A%84%E6%AD%A5%E9%AA%A4%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3COL%3E%3CLI%3E%3CP%3E%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%20CMake%20%E9%85%8D%E7%BD%AE%E6%9E%84%E5%BB%BA%20Plug%20%26amp%3B%20Trust%20MW%EF%BC%9A%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CPRE%20translate%3D%22no%22%3Ecmake%20..%2Fsimw-top%20%5C%0A-DPTMW_Applet%3DSE05X_C%20%5C%0A-DPTMW_SE05X_Ver%3D07_02%20%5C%0A-DPTMW_Host%3DiMXLinux%20%5C%0A-DPTMW_SMCOM%3DT1oI2C%20%5C%0A-DPTMW_HostCrypto%3DOPENSSL%20%5C%0A-DPTMW_RTOS%3DDefault%20%5C%0A-DPTMW_mbedTLS_ALT%3DNone%20%5C%0A-DPTMW_SCP%3DSCP03_SSS%20%5C%0A-DPTMW_FIPS%3DNone%20%5C%0A-DPTMW_SBL%3DNone%20%5C%0A-DPTMW_SE05X_Auth%3DPlatfSCP03%20%5C%0A-DPTMW_Log%3DDefault%20%5C%0A-DCMAKE_BUILD_TYPE%3DRelease%20%5C%0A-DPTMW_SE_RESET_LOGIC%3D1%3C%2FPRE%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E5%B0%86%20Plug%20%26amp%3B%20Trust%20MW%20%E7%9B%AE%E5%BD%95%E4%B8%AD%E7%9A%84%20simw-top%2Fdemos%2Flinux%2Fcommon%2Fopenssl30_sss_se050.cnf%20%E5%A4%8D%E5%88%B6%E5%88%B0%20i.MX%208M%20%E7%9A%84%20%2Froot%20%E7%9B%AE%E5%BD%95%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E5%B7%B2%E5%AF%BC%E5%87%BA%E9%85%8D%E7%BD%AE%E7%8E%AF%E5%A2%83%E5%8F%98%E9%87%8F%EF%BC%9A%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CPRE%20translate%3D%22no%22%3E%3CSPAN%20class%3D%22%22%3Eexport%3C%2FSPAN%3E%20OPENSSL_CONF%3D%2Froot%2Fopenssl30_sss_se050.cnf%3C%2FPRE%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E6%89%A7%E8%A1%8C%20se05x_Minimal%20%E4%BB%A5%E7%A1%AE%E8%AE%A4%20SE051%20%E4%B8%8E%20SCP03%20%E8%83%BD%E5%A4%9F%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E3%80%82%3CSTRONG%3E%E5%AE%83%E6%88%90%E5%8A%9F%E4%BA%86%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CPRE%20translate%3D%22no%22%3EApp%20%20%20%3AINFO%20%3ARunning%20bin%2Fse05x_Minimal%0AApp%20%20%20%3AINFO%20%3AIf%20you%20want%20to%20over-ride%20the%20selection%2C%20use%20ENV%3DEX_SSS_BOOT_SSS_PORT%20or%20pass%20in%20command%20line%20arguments.%0AApp%20%20%20%3AINFO%20%3APlugAndTrust_v04.07.01_20250519%0AApp%20%20%20%3AINFO%20%3AUsing%20default%20PlatfSCP03%20keys.%20You%20can%20use%20keys%20from%20file%20using%20ENV%3DEX_SSS_BOOT_SCP03_PATH%0Asss%20%20%20%3AINFO%20%3Aatr%20(Len%3D35)%0A%20%20%20%20%20%20(snip)%0AApp%20%20%20%3AINFO%20%3Amem%3D17196%0AApp%20%20%20%3AINFO%20%3Ase05x_Minimal%20Example%20Success%20!!!...%0AApp%20%20%20%3AINFO%20%3Aex_sss%20Finished%3C%2FPRE%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E5%B7%B2%E5%A4%8D%E5%88%B6%20libsssapisw.so%EF%BC%8Clibsss_pkcs11.so%20%E5%92%8C%20libsssProvider.so%20%E5%88%B0%20%2Fusr%2Flocal%2Flib%2F%E3%80%82%3CI%3E%EF%BC%88%E6%B3%A8%EF%BC%9A%2Fusr%2Flocal%2Flib%2F%20%E6%98%AF%20%2Froot%2Fopenssl30_sss_se050.cnf%20%E7%9A%84%20%5Bnxp_prov_sec%5D%20%E9%83%A8%E5%88%86%E4%B8%AD%E6%8C%87%E5%AE%9A%E7%9A%84%E8%B7%AF%E5%BE%84%EF%BC%89%3C%2FI%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E5%86%8D%E6%AC%A1%E6%89%A7%E8%A1%8C%20se05x_Minimal%E3%80%82%E8%BF%99%E6%AC%A1%3CSTRONG%3E%E5%A4%B1%E8%B4%A5%E4%BA%86%EF%BC%8C%E5%87%BA%E7%8E%B0%3C%2FSTRONG%3E%E4%BA%86%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FP%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3CSTRONG%3E%E9%94%99%E8%AF%AF%E8%BE%93%E5%87%BA%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CPRE%20translate%3D%22no%22%3EApp%20%20%20%3AINFO%20%3ARunning%20bin%2Fse05x_Minimal%0AApp%20%20%20%3AINFO%20%3AIf%20you%20want%20to%20over-ride%20the%20selection%2C%20use%20ENV%3DEX_SSS_BOOT_SSS_PORT%20or%20pass%20in%20command%20line%20arguments.%0AApp%20%20%20%3AINFO%20%3APlugAndTrust_v04.07.01_20250519%0AApp%20%20%20%3AINFO%20%3AUsing%20default%20PlatfSCP03%20keys.%20You%20can%20use%20keys%20from%20file%20using%20ENV%3DEX_SSS_BOOT_SCP03_PATH%0Asss%20%20%20%3AINFO%20%3Aatr%20(Len%3D35)%0A%20%20%20%20%20%20(snip)%0AApp%20%20%20%3AINFO%20%3AIf%20you%20want%20to%20over-ride%20the%20selection%2C%20use%20ENV%3DEX_SSS_BOOT_SSS_PORT%20or%20pass%20in%20command%20line%20arguments.%0AApp%20%20%20%3AINFO%20%3AUsing%20default%20PlatfSCP03%20keys.%20You%20can%20use%20keys%20from%20file%20using%20ENV%3DEX_SSS_BOOT_SCP03_PATH%0Asss%20%20%20%3AINFO%20%3Aatr%20(Len%3D35)%0A%20%20%20%20%20%20(snip)%0Asss%20%20%20%3AERROR%3AError%20in%20RAND_pseudo_bytes%20%0Ascp%20%20%20%3AWARN%20%3AnxEnsure%3A'status%20%3D%3D%20kStatus_SSS_Success'%20failed.%20At%20Line%3A121%20Function%3AnxScp03_AuthenticateChannel%0Asss%20%20%20%3AERROR%3ACould%20not%20set%20SCP03%20Secure%20Channel%0AApp%20%20%20%3AERROR%3Asss_session_open%20failed%0AApp%20%20%20%3AWARN%20%3AnxEnsure%3A'kStatus_SSS_Success%20%3D%3D%20status'%20failed.%20At%20Line%3A240%20Function%3AOSSL_provider_init%0AsmCom%20%3AERROR%3AphNxpEseProto7816_DecodeFrame%20Max%20retry%20count%20reached!!!%20%0AsmCom%20%3AERROR%3AphNxpEseProto7816_Transceive%20Transceive%20failed%2C%20hard%20reset%20to%20proceed%20%0AsmCom%20%3AERROR%3A%20phNxpEse_Transceive%20phNxpEseProto7816_Transceive-%20Failed%20%0AsmCom%20%3AERROR%3A%20Transcive%20Failed%20%0Asss%20%20%20%3AWARN%20%3AnxEnsure%3A'retStatus%20%3D%3D%20SM_OK'%20failed.%20At%20Line%3A7977%20Function%3Asss_se05x_channel_txn%0Asss%20%20%20%3AWARN%20%3AnxEnsure%3A'ret%20%3D%3D%20SM_OK'%20failed.%20At%20Line%3A7839%20Function%3Asss_se05x_TXn%0Asss%20%20%20%3AWARN%20%3AAPDU%20Transaction%20Error%3A%20Error%20(0xFFFF)%0A%0Ascp%20%20%20%3AERROR%3AGP_InitializeUpdate%20Failure%20on%20communication%20Link%20FFFF%0Ascp%20%20%20%3AERROR%3AnxScp03_GP_InitializeUpdate%20fails%20with%20Status%203C3C0000%0Asss%20%20%20%3AERROR%3ACould%20not%20set%20SCP03%20Secure%20Channel%0AApp%20%20%20%3AERROR%3Asss_session_open%20failed%0AApp%20%20%20%3AERROR%3Aex_sss_session_open%20Failed%0AApp%20%20%20%3AERROR%3A!ERROR!%20ret%20!%3D%200.%3C%2FPRE%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3E%E4%BC%BC%E4%B9%8E%E4%B8%80%E6%97%A6%20OpenSSL%20%E6%8F%90%E4%BE%9B%E7%A8%8B%E5%BA%8F%E9%80%9A%E8%BF%87%E9%85%8D%E7%BD%AE%E6%88%90%E5%8A%9F%E5%8A%A0%E8%BD%BD%EF%BC%8C%E6%9F%90%E4%BA%9B%E4%B8%9C%E8%A5%BF%EF%BC%88%E5%8F%AF%E8%83%BD%E4%B8%8E%20RAND_pseudo_bytes%20%E6%9C%89%E5%85%B3%EF%BC%89%E5%B0%B1%E4%BC%9A%E7%A0%B4%E5%9D%8F%20SCP03%20%E9%80%9A%E9%81%93%E7%9A%84%E5%BB%BA%E7%AB%8B%E3%80%82%3C%2FP%3E%3CP%3E%E6%9C%89%E4%BA%BA%E9%81%87%E5%88%B0%E8%BF%87%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E5%90%97%EF%BC%9F%E6%88%96%E8%80%85%E7%9F%A5%E9%81%93%E5%8F%AF%E8%83%BD%E8%BF%98%E7%BC%BA%E5%B0%91%E5%93%AA%E4%BA%9B%E9%85%8D%E7%BD%AE%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%8F%90%E5%89%8D%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2384812%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20EdgeLock%20SE051%3A%20se05x_Minimal%20fails%20with%20SCP03%20errors%20after%20loading%20OpenSSL%20Provider%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2384812%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F259681%22%20target%3D%22_blank%22%3E%40Uc_S%3C%2FA%3E%20%EF%BC%8C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E4%BD%A0%E6%98%AF%E5%90%A6%E5%AE%89%E8%A3%85%E4%BA%86%E6%AD%A3%E7%A1%AE%E7%9A%84%20OpenSSL%20%E7%89%88%E6%9C%AC%EF%BC%9F%E8%AF%B7%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%E9%80%89%E9%A1%B9%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E-DPTMW_OpenSSL%3D3_0%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E5%8F%A6%E5%A4%96%EF%BC%8C%E4%B8%BA%E4%BA%86%E6%B5%8B%E8%AF%95%E7%9B%AE%E7%9A%84%EF%BC%8C%E8%AF%B7%E5%90%AF%E7%94%A8%E8%AF%A6%E7%BB%86%E6%97%A5%E5%BF%97%E4%BB%A5%E8%8E%B7%E5%8F%96%E6%9B%B4%E5%A4%9A%E8%B0%83%E8%AF%95%E4%BF%A1%E6%81%AF%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E-DPTMW_Log%3D%E8%AF%A6%E7%BB%86%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%A5%9D%E4%BD%A0%E6%9C%89%E7%BE%8E%E5%A5%BD%E7%9A%84%E4%B8%80%E5%A4%A9%EF%BC%8C%3CBR%20%2F%3E%E5%9D%8E%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E7%AC%94%E8%AE%B0%EF%BC%9A%3CBR%20%2F%3E%20-%20%E5%A6%82%E6%9E%9C%E6%AD%A4%E5%9B%9E%E5%A4%8D%E8%A7%A3%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%E2%80%9C%E6%A0%87%E8%AE%B0%E4%B8%BA%E6%AD%A3%E7%A1%AE%E7%AD%94%E6%A1%88%E2%80%9D%E6%8C%89%E9%92%AE%E3%80%82%E8%B0%A2%E8%B0%A2%E4%BD%A0%EF%BC%81%3CBR%20%2F%3E%20-%20%E6%88%91%E4%BB%AC%E4%BC%9A%E6%8C%81%E7%BB%AD%E5%85%B3%E6%B3%A8%E5%B8%96%E5%AD%90%EF%BC%8C%E4%BB%8E%E6%9C%80%E5%90%8E%E4%B8%80%E6%9D%A1%E5%9B%9E%E5%A4%8D%E5%8F%91%E5%87%BA%E5%90%8E%E6%8C%81%E7%BB%AD7%E5%91%A8%EF%BC%8C%E4%B9%8B%E5%90%8E%E7%9A%84%E5%9B%9E%E5%A4%8D%E5%B0%86%E8%A2%AB%E5%BF%BD%E7%95%A5%E3%80%82%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%B9%8B%E5%90%8E%E6%9C%89%E7%9B%B8%E5%85%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E5%8F%A6%E5%BC%80%E6%96%B0%E5%B8%96%E5%B9%B6%E5%BC%95%E7%94%A8%E5%B7%B2%E5%85%B3%E9%97%AD%E7%9A%84%E5%B8%96%E5%AD%90%E3%80%82%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2385344%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20EdgeLock%20SE051%3A%20se05x_Minimal%20fails%20with%20SCP03%20errors%20after%20loading%20OpenSSL%20Provider%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2385344%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%BB%BA%E8%AE%AE%E3%80%82%E4%BD%A0%E8%AF%B4%E5%BE%97%E5%AE%8C%E5%85%A8%E6%AD%A3%E7%A1%AE%E3%80%82%3C%2FP%3E%3CP%3E%E9%97%AE%E9%A2%98%E7%9A%84%E6%A0%B9%E6%9C%AC%E5%8E%9F%E5%9B%A0%E7%A1%AE%E5%AE%9E%E6%98%AF%E6%88%91%E7%9A%84%20CMake%20%E9%85%8D%E7%BD%AE%E4%B8%AD%E7%BC%BA%E5%B0%91%E2%80%9C-DPTMW_OpenSSL%3D3_0%E2%80%9D%E9%80%89%E9%A1%B9%E3%80%82%3C%2FP%3E%3CP%3E%E6%B7%BB%E5%8A%A0%E2%80%9C-DPTMW_OpenSSL%3D3_0%20%3CSPAN%3E-DPTMW_Log%3DVerbose%3C%2FSPAN%3E%20%E2%80%9D%E5%B9%B6%E9%87%8D%E6%96%B0%E6%9E%84%E5%BB%BA%20MW%20%E5%90%8E%EF%BC%8C%E9%97%AE%E9%A2%98%E5%AE%8C%E5%85%A8%E8%A7%A3%E5%86%B3%E4%BA%86%E3%80%82%E4%BB%A5%E4%B8%8B%E6%98%AF%E7%BB%93%E6%9E%9C%EF%BC%9A%3C%2FP%3E%3CP%3E%E6%89%A7%E8%A1%8C%E6%AD%A5%E9%AA%A4%206%20%E4%B8%8D%E5%86%8D%E5%87%BA%E7%8E%B0%E4%BB%BB%E4%BD%95%E9%94%99%E8%AF%AF%E3%80%82%E5%AE%83%E6%8C%89%E9%A2%84%E6%9C%9F%E6%88%90%E5%8A%9F%E8%BE%93%E5%87%BA%E2%80%9CApp%20%3AINFO%20%3Amem%3D17196%E2%80%9D%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E8%BF%98%E7%A1%AE%E8%AE%A4%EF%BC%8C%E5%8D%B3%E4%BD%BF%E5%B0%86%E6%97%A5%E5%BF%97%E7%BA%A7%E5%88%AB%E8%AE%BE%E7%BD%AE%E5%9B%9E%E6%88%91%E6%9C%80%E5%88%9D%E9%A2%84%E6%9C%9F%E7%9A%84%E9%85%8D%E7%BD%AE%EF%BC%88%E2%80%9C-DPTMW_Log%3DDefault%E2%80%9D%E8%80%8C%E4%B8%8D%E6%98%AF%20Verbose%EF%BC%89%EF%BC%8C%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E4%BB%8D%E7%84%B6%E5%8F%AF%E4%BB%A5%E5%AE%8C%E7%BE%8E%E6%89%A7%E8%A1%8C%E5%B9%B6%E8%BE%93%E5%87%BA%E2%80%9CApp%20%3AINFO%20%3Amem%3D17196%E2%80%9D%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%86%E6%8A%8A%E6%AD%A4%E9%97%AE%E9%A2%98%E6%A0%87%E8%AE%B0%E4%B8%BA%E5%B7%B2%E8%A7%A3%E5%86%B3%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
