C_GetAttributeValue(EC_PARAMS) failed for EC:secp521r1
1,534 次查看
vishwanchandapu
we are using latest SDK SE05x-MW-v04.03.00 and tried to generate EC:secp521r1 but failing with C_GetAttributeValue.
Steps to reproduce:
pkcs11-tool --module /usr/lib/libsss_pkcs11.so --keypairgen --key-type EC:secp521r1 --label "sss:20202021"
1,484 次查看
Kan_Li
Hi @vishwanchandapu ,
I just replied your private ticket on the same topic via the Case Portal , and we may continue the discussion there.
Thanks for your patience and understanding!
Kan
