Authentification for JCOP Tools on Eclipse IDE
_Developer
Hi everyone!
I downloaded the JCOP Tools plugin (version 5.32.0.4) a few days ago. I successfully obtained it and added it to Eclipse IDE 2024. I am following the training video for installing Eclipse/JCOP Tools available here:
https://www.nxp.com/design/design-center/training/TIP-SECURE-ELEMENT-COMMON-JCOP-TOOLS-PART-1
When I try to create a new Java Card project, an activation dialog appears with three activation methods for the plugin.
I attempted to use the first option, which involves activating the plugin with a licensed installation for JCOP Tools. However, I couldn’t find the activation workspace in my folder directory. I assume that NXP doesn’t provide it in the JCOP Tools package.
The second activation option requires running a JCOP engineering sample through a reader, but none of my readers qualify as "JCOP Engineering Samples".
Finally, I tried the last option, which involves using an activation code. I have a serial number provided by Eclipse IDE, and I found that I need to request the activation code by emailing [email protected] as mentioned here:
https://community.nxp.com/t5/Secure-Authentication/JCOP-Tools-Activation/m-p/1677996
However, I am unsure if this email address is still valid. I created a support case to get a response regarding this issue but couldn’t find anyone with access to the necessary JCOP information to assist me.
Here are my questions:
  1. Is [email protected] the correct email address to request an activation password?
  2. How does it work if we use multiple computers? Do I need a separate activation code for each computer?
  3. Is there an FAE assigned or a direct NXP contact we can discuss with to expedite this activation process?
We are eager to use this plugin as soon as possible. I hope someone can assist me with this matter.
Developer
Kan_Li
Hi @_Developer ,
Please kindly refer to https://community.nxp.com/t5/Secure-Authentication/JCOP-Tools-Activation/m-p/1677996#M1285 for details.
If you need on site technical support, please kindly contact your local Disti for help. Please refer to https://www.nxp.com/support/sample-and-buy/distributor-network:DISTRIBUTORS for details.
Kan
