question about FMEDA SEooC Static - S32K344 excel
764 次查看
shuaishuaifei
Hi I have download FMEDA SEooC Static - S32K344 excel from NDA group, we have a little question, Could you help us.
why all the GPIO Pads be thought to None Safety related in this HW analysis column.
S32K344.CUT_1_0.RELEASE.2021_R2.002-257pins
1 回复
754 次查看
ankur_yadav_07
Greetings of the day
In Safety Analysis Report it is mentioned that GPIO pins are general purpose and are configurable. The user shall select these pins as “Safety-related” or “Non-Safety related” based on the application use case, Where the failure modes are already provided in the FMEDA. The user shall assign the corresponding system level measure for these pins when they are selected as “Safety-Related”.
For reference you can look at <S32K344 Safety Analysis report>;<Page No. 13>;< PIN FMEDA >.
Thanx and Regards
Ankur Yadav
