creating a Blob Image using IVT S32Z2
1,749 次查看
karthik_nikil
Hello Team,
I am using the S32Z2 Development Board with Boot Core R52 and creating a Flash Image using IVT.
I would like to know:
  • What is the RAM Start Pointer Address?
  • What is the RAM Entry Pointer Address?
  • How can I identify or calculate these addresses correctly for my application?
Please let me know where these addresses can be found, such as in the linker file, map file, startup file, or any specific documentation.
Thank you.
BR,
Karthik
标记 (2)
7 回复数
1,616 次查看
karthik_nikil
Hi Joey_z,
Thank you for your reply.
I tried changing to LINFlex_9 as shown in the image, but still no output is coming. No data is being printed on the UART terminal.
Could you please provide a solution for this issue? Also, is there any procedure document or application note available for UART print/output using the R52/M33 core on the S32Z280 Development Board?
Thank you.
BR,
Karthik
1,614 次查看
Joey_z
Hi,karthik_nikil
Do you have any debugger for testing of this UART Demo on R52 core? You can try to debug this code on R52 without IVT first.
Joey
1,734 次查看
Joey_z
Hi,karthik_nikil
Thank you for contacting us and information.
Which version of RTD are you using? what is the version of your Development Board?
Why do you want to boot S32Z from R52 directly?
Joey
1,729 次查看
karthik_nikil
Hi Joey,
Thank you for your response.
Screenshot 2026-05-08 160056.pngScreenshot 2026-05-08 160056.pngS32Z280-594EVBS32Z280-594EVB
I am trying to execute the Uart_Example_S32Z2XX_R52 project using the S32Z280 Development Board.
I successfully generated the .bin file, and now I am trying to create the Flash Image.
Please guide me regarding the correct RAM Start Pointer Address and RAM Entry Pointer Address required for IVT Flash Image creation.
Thank you.
BR,
Karthik
1,705 次查看
Joey_z
Hi,karthik_nikil
If you want to boot from R52 directly, please try to refer to the steps as the following.
1.Modify the file of startup.s to initial the RTU0 early. The patch file in the attachment.
2.Enable the partition1 before use the clock initial.
Joey_z_0-1778293470993.pngJoey_z_0-1778293470993.pngJoey_z_1-1778293482789.pngJoey_z_1-1778293482789.png
3.Find the address in .map file for generating IVT file.
Joey_z_2-1778293982381.pngJoey_z_2-1778293982381.pngJoey_z_3-1778293991905.pngJoey_z_3-1778293991905.png
Hope this information can help you.
Joey
1,657 次查看
karthik_nikil
Hi Joey,
Thank you for your guidance.
I completed all the modifications you suggested:
  1. Modified the startup.s file to initialize RTU0 early.
  2. Enabled partition1 before clock initialization.
Screenshot 2026-05-11 160929.pngScreenshot 2026-05-11 160929.pngScreenshot 2026-05-11 155917.pngScreenshot 2026-05-11 155917.pngScreenshot 2026-05-11 161511.pngScreenshot 2026-05-11 161511.png
After that, the project builds successfully, and I also created the Flash Image successfully.
Then I uploaded the program using the Flash Tool application. However, nothing is printing on the J199 UART port. I already configured the correct baud rate and other UART settings. I also tried sending "Hello" and waited for the MCU response, but no output is received.
I am attaching my .ld and .map files. Could you please help me identify what I might be doing wrong?
Thank you.
BR,
Karthik
1,653 次查看
Joey_z
Hi,karthik_nikil
What the Lin port are you using in code? Please try to use the LINFlex_9 as the following picture.
Joey
%3CLINGO-SUB%20id%3D%22lingo-sub-2362406%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BD%BF%E7%94%A8%20IVT%20S32Z2%20%E5%88%9B%E5%BB%BA%20Blob%20%E5%9B%BE%E5%83%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2362406%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E5%9B%A2%E9%98%9F%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E5%B8%A6%E6%9C%89%20%3CSTRONG%3EBoot%20Core%20R52%3C%2FSTRONG%3E%20%E7%9A%84%20S32Z2%20%E5%BC%80%E5%8F%91%E6%9D%BF%EF%BC%8C%E5%B9%B6%E4%BD%BF%E7%94%A8%20IVT%20%E5%88%9B%E5%BB%BA%20Flash%20%E9%95%9C%E5%83%8F%E3%80%82%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E6%88%91%E6%83%B3%E7%9F%A5%E9%81%93%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%3E%E4%BB%80%E4%B9%88%E6%98%AF%20RAM%20%E8%B5%B7%E5%A7%8B%E6%8C%87%E9%92%88%E5%9C%B0%E5%9D%80%EF%BC%9F%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3E%E4%BB%80%E4%B9%88%E6%98%AF%20RAM%20%E8%BE%93%E5%85%A5%E6%8C%87%E9%92%88%E5%9C%B0%E5%9D%80%EF%BC%9F%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3E%E5%A6%82%E4%BD%95%E5%9C%A8%E5%BA%94%E7%94%A8%E4%B8%AD%E6%AD%A3%E7%A1%AE%E8%AF%86%E5%88%AB%E6%88%96%E8%AE%A1%E7%AE%97%E8%BF%99%E4%BA%9B%E5%9C%B0%E5%9D%80%EF%BC%9F%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%202026-05-08%20145908.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-05-08%20145908.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-05-08%20145908.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-05-08%20145908.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-05-08%20145908.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-05-08%20145908.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F384787i1ABFA6DB0E6EAE46%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Screenshot%202026-05-08%20145908.png%22%20alt%3D%22Screenshot%202026-05-08%20145908.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EScreenshot%202026-05-08%20145908.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E5%9C%A8%E5%93%AA%E9%87%8C%E5%8F%AF%E4%BB%A5%E6%89%BE%E5%88%B0%E8%BF%99%E4%BA%9B%E5%9C%B0%E5%9D%80%EF%BC%8C%E4%BE%8B%E5%A6%82%E5%9C%A8%E9%93%BE%E6%8E%A5%E5%99%A8%E6%96%87%E4%BB%B6%E3%80%81%E6%98%A0%E5%B0%84%E6%96%87%E4%BB%B6%E3%80%81%E5%90%AF%E5%8A%A8%E6%96%87%E4%BB%B6%E6%88%96%E4%BB%BB%E4%BD%95%E7%89%B9%E5%AE%9A%E6%96%87%E6%A1%A3%E4%B8%AD%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EBR%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EKarthik%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2362634%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20creating%20a%20Blob%20Image%20using%20IVT%20S32Z2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2362634%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E4%BD%A0%E5%A5%BD%EF%BC%8Ckarthik_nikil%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E4%BD%A0%E6%83%B3%E7%9B%B4%E6%8E%A5%E4%BB%8E%20R52%20%E5%90%AF%E5%8A%A8%EF%BC%8C%E8%AF%B7%E5%B0%9D%E8%AF%95%E5%8F%82%E8%80%83%E4%BB%A5%E4%B8%8B%E6%AD%A5%E9%AA%A4%E3%80%82%3C%2FP%3E%0A%3CP%3E1.%E4%BF%AE%E6%94%B9%20startup.s%20%E6%96%87%E4%BB%B6%EF%BC%8C%E6%8F%90%E5%89%8D%E5%88%9D%E5%A7%8B%E5%8C%96%20RTU0%E3%80%82%E9%99%84%E4%BB%B6%E4%B8%AD%E7%9A%84%E8%A1%A5%E4%B8%81%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%0A%3CP%3E2.%E5%9C%A8%E4%BD%BF%E7%94%A8%E6%97%B6%E9%92%9F%E5%88%9D%E5%A7%8B%E5%80%BC%E4%B9%8B%E5%89%8D%E5%90%AF%E7%94%A8%E5%88%86%E5%8C%BA%201%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Joey_z_0-1778293470993.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_0-1778293470993.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_0-1778293470993.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_0-1778293470993.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_0-1778293470993.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_0-1778293470993.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F384840i4890A83A2D41530A%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Joey_z_0-1778293470993.png%22%20alt%3D%22Joey_z_0-1778293470993.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJoey_z_0-1778293470993.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Joey_z_1-1778293482789.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_1-1778293482789.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_1-1778293482789.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_1-1778293482789.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_1-1778293482789.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_1-1778293482789.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F384841iE8548D814FB5A433%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Joey_z_1-1778293482789.png%22%20alt%3D%22Joey_z_1-1778293482789.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJoey_z_1-1778293482789.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E3.%E5%9C%A8%20.%E5%9C%B0%E5%9B%BE%E4%B8%AD%E6%9F%A5%E6%89%BE%E5%9C%B0%E5%9D%80%E6%96%87%E4%BB%B6%EF%BC%8C%E7%94%A8%E4%BA%8E%E7%94%9F%E6%88%90%20IVT%20%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Joey_z_2-1778293982381.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_2-1778293982381.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_2-1778293982381.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_2-1778293982381.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_2-1778293982381.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_2-1778293982381.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F384842i87ACB7CA600EED43%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Joey_z_2-1778293982381.png%22%20alt%3D%22Joey_z_2-1778293982381.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJoey_z_2-1778293982381.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Joey_z_3-1778293991905.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_3-1778293991905.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_3-1778293991905.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_3-1778293991905.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_3-1778293991905.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_3-1778293991905.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F384843iF0AE45EF3BF06E7E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Joey_z_3-1778293991905.png%22%20alt%3D%22Joey_z_3-1778293991905.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJoey_z_3-1778293991905.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E5%B8%8C%E6%9C%9B%E8%BF%99%E4%BA%9B%E4%BF%A1%E6%81%AF%E8%83%BD%E5%AF%B9%E6%82%A8%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E4%B9%94%E4%BC%8A%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2362463%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20creating%20a%20Blob%20Image%20using%20IVT%20S32Z2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2362463%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E5%97%A8%EF%BC%8C%E4%B9%94%E4%BC%8A%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%8F%8D%E9%A6%88%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%202026-05-08%20160056.png%22%20style%3D%22width%3A%20578px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-05-08%20160056.png%22%20style%3D%22width%3A%20578px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-05-08%20160056.png%22%20style%3D%22width%3A%20578px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-05-08%20160056.png%22%20style%3D%22width%3A%20578px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-05-08%20160056.png%22%20style%3D%22width%3A%20578px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-05-08%20160056.png%22%20style%3D%22width%3A%20578px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F384806i8544AD944DB73C32%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Screenshot%202026-05-08%20160056.png%22%20alt%3D%22Screenshot%202026-05-08%20160056.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EScreenshot%202026-05-08%20160056.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22S32Z280-594EVB%22%20style%3D%22width%3A%20451px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32Z280-594EVB%22%20style%3D%22width%3A%20451px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32Z280-594EVB%22%20style%3D%22width%3A%20451px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32Z280-594EVB%22%20style%3D%22width%3A%20451px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32Z280-594EVB%22%20style%3D%22width%3A%20451px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32Z280-594EVB%22%20style%3D%22width%3A%20451px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F384808iD9F749FB3690B44A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22WhatsApp%20Image%202026-05-08%20at%204.27.03%20PM.jpeg%22%20alt%3D%22S32Z280-594EVB%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ES32Z280-594EVB%3C%2Fspan%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ES32Z280-594EVB%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ES32Z280-594EVB%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ES32Z280-594EVB%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ES32Z280-594EVB%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ES32Z280-594EVB%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20S32Z280%20%E5%BC%80%E5%8F%91%E6%9D%BF%E6%89%A7%E8%A1%8C%20UART_example_s32z2xx_R52%20%E9%A1%B9%E7%9B%AE%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E6%88%91%E6%88%90%E5%8A%9F%E7%94%9F%E6%88%90%E4%BA%86%20.bin%E6%96%87%E4%BB%B6%EF%BC%8C%E7%8E%B0%E5%9C%A8%E6%88%91%E6%AD%A3%E8%AF%95%E5%9B%BE%E5%88%9B%E5%BB%BA%20Flash%20%E6%98%A0%E5%83%8F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E8%AF%B7%E5%B0%B1%E5%88%9B%E5%BB%BA%20IVT%20%E9%97%AA%E5%AD%98%E6%98%A0%E5%83%8F%E6%89%80%E9%9C%80%E7%9A%84%E6%AD%A3%E7%A1%AE%20RAM%20%E8%B5%B7%E5%A7%8B%E6%8C%87%E9%92%88%E5%9C%B0%E5%9D%80%E5%92%8C%20RAM%20%E8%BE%93%E5%85%A5%E6%8C%87%E9%92%88%E5%9C%B0%E5%9D%80%E5%90%91%E6%88%91%E6%8F%90%E4%BE%9B%E6%8C%87%E5%AF%BC%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EBR%E3%80%81%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3EKarthik%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2362437%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20creating%20a%20Blob%20Image%20using%20IVT%20S32Z2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2362437%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E4%BD%A0%E5%A5%BD%EF%BC%8Ckarthik_nikil%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E4%B8%8E%E6%88%91%E4%BB%AC%E8%81%94%E7%B3%BB%E5%B9%B6%E6%8F%90%E4%BE%9B%E4%BF%A1%E6%81%AF%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E5%93%AA%E4%B8%AA%E7%89%88%E6%9C%AC%E7%9A%84%20RTD%EF%BC%9F%E4%BD%A0%E7%9A%84%E5%BC%80%E5%8F%91%E6%9D%BF%E6%98%AF%E4%BB%80%E4%B9%88%E7%89%88%E6%9C%AC%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E4%B8%BA%E4%BB%80%E4%B9%88%E8%A6%81%E7%9B%B4%E6%8E%A5%E4%BB%8E%20R52%20%E5%90%AF%E5%8A%A8%20S32Z%EF%BC%9F%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E4%B9%94%E4%BC%8A%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2363367%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20creating%20a%20Blob%20Image%20using%20IVT%20S32Z2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2363367%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E5%97%A8%EF%BC%8C%E4%B9%94%E4%BC%8A%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E6%8C%87%E5%AF%BC%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E6%88%91%E5%AE%8C%E6%88%90%E4%BA%86%E4%BD%A0%E5%BB%BA%E8%AE%AE%E7%9A%84%E6%89%80%E6%9C%89%E4%BF%AE%E6%94%B9%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3COL%3E%3CLI%3E%3CSPAN%3E%E4%BF%AE%E6%94%B9%E4%BA%86%20startup.s%E6%96%87%E4%BB%B6%E6%9D%A5%E6%8F%90%E5%89%8D%E5%88%9D%E5%A7%8B%E5%8C%96%20RTU0%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3E%E5%9C%A8%E6%97%B6%E9%92%9F%E5%88%9D%E5%A7%8B%E5%8C%96%E5%89%8D%E5%90%AF%E7%94%A8%20partition1%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%202026-05-11%20160929.png%22%20style%3D%22width%3A%20573px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-05-11%20160929.png%22%20style%3D%22width%3A%20573px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-05-11%20160929.png%22%20style%3D%22width%3A%20573px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-05-11%20160929.png%22%20style%3D%22width%3A%20573px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-05-11%20160929.png%22%20style%3D%22width%3A%20573px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F384969i3DE9F0C4603394DA%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Screenshot%202026-05-11%20160929.png%22%20alt%3D%22Screenshot%202026-05-11%20160929.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EScreenshot%202026-05-11%20160929.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%202026-05-11%20155917.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-05-11%20155917.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-05-11%20155917.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-05-11%20155917.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-05-11%20155917.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F384971iB55A9B5A596DEE2F%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Screenshot%202026-05-11%20155917.png%22%20alt%3D%22Screenshot%202026-05-11%20155917.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EScreenshot%202026-05-11%20155917.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%202026-05-11%20161511.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-05-11%20161511.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-05-11%20161511.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-05-11%20161511.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-05-11%20161511.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F384972iA7CFBA97BA752FE8%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Screenshot%202026-05-11%20161511.png%22%20alt%3D%22Screenshot%202026-05-11%20161511.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EScreenshot%202026-05-11%20161511.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E4%B9%8B%E5%90%8E%EF%BC%8C%E9%A1%B9%E7%9B%AE%E6%88%90%E5%8A%9F%E6%9E%84%E5%BB%BA%EF%BC%8C%E6%88%91%E8%BF%98%E6%88%90%E5%8A%9F%E5%88%9B%E5%BB%BA%E4%BA%86%20Flash%20%E9%95%9C%E5%83%8F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E7%84%B6%E5%90%8E%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%20Flash%20%E5%B7%A5%E5%85%B7%E7%A8%8B%E5%BA%8F%E4%B8%8A%E4%BC%A0%E4%BA%86%E7%A8%8B%E5%BA%8F%E3%80%82%E4%BD%86%E6%98%AF%EF%BC%8CJ199%20UART%20%E7%AB%AF%E5%8F%A3%E6%B2%A1%E6%9C%89%E6%89%93%E5%8D%B0%E4%BB%BB%E4%BD%95%E5%86%85%E5%AE%B9%E3%80%82%E6%88%91%E5%B7%B2%E7%BB%8F%E9%85%8D%E7%BD%AE%E4%BA%86%E6%AD%A3%E7%A1%AE%E7%9A%84%E6%B3%A2%E7%89%B9%E7%8E%87%E5%92%8C%E5%85%B6%E4%BB%96%20UART%20%E8%AE%BE%E7%BD%AE%E3%80%82%E6%88%91%E8%BF%98%E5%B0%9D%E8%AF%95%E5%8F%91%E9%80%81%22Hello%22%20%E5%B9%B6%E7%AD%89%E5%BE%85%20MCU%20%E5%93%8D%E5%BA%94%EF%BC%8C%E4%BD%86%E6%B2%A1%E6%9C%89%E6%94%B6%E5%88%B0%E4%BB%BB%E4%BD%95%E8%BE%93%E5%87%BA%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E7%8E%B0%E9%99%84%E4%B8%8A%E6%88%91%E7%9A%84%20.ld%E5%92%8C%20.map%E6%96%87%E4%BB%B6%E6%82%A8%E8%83%BD%E5%B8%AE%E6%88%91%E6%89%BE%E5%87%BA%E6%88%91%E5%8F%AF%E8%83%BD%E5%81%9A%E9%94%99%E7%9A%84%E5%9C%B0%E6%96%B9%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EBR%E3%80%81%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3EKarthik%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2363374%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20creating%20a%20Blob%20Image%20using%20IVT%20S32Z2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2363374%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%3CSPAN%3E%EF%BC%8Ckarthik_nikil%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E5%9C%A8%E4%BB%A3%E7%A0%81%E4%B8%AD%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E5%93%AA%E4%B8%AA%20Lin%20%E7%AB%AF%E5%8F%A3%EF%BC%9F%E8%AF%B7%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%E4%B8%8B%E5%9B%BE%E4%B8%AD%E7%9A%84%20LINFlex_9%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Joey_z_0-1778497185260.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_0-1778497185260.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_0-1778497185260.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_0-1778497185260.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F384974i1E2439576D3A1759%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Joey_z_0-1778497185260.png%22%20alt%3D%22Joey_z_0-1778497185260.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJoey_z_0-1778497185260.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EBR%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E4%B9%94%E4%BC%8A%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2363720%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20creating%20a%20Blob%20Image%20using%20IVT%20S32Z2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2363720%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8CJoey_z%E3%80%81%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E8%AF%95%E7%9D%80%E5%A6%82%E5%9B%BE%E6%89%80%E7%A4%BA%E6%9B%B4%E6%94%B9%E4%B8%BA%20LINFlex_9%EF%BC%8C%E4%BD%86%E4%BB%8D%E7%84%B6%E6%B2%A1%E6%9C%89%E8%BE%93%E5%87%BA%E3%80%82UART%20%E7%AB%AF%E5%AD%90%E4%B8%8A%E6%9C%AA%E6%89%93%E5%8D%B0%E6%95%B0%E6%8D%AE%E3%80%82%3C%2FP%3E%3CP%3E%E8%83%BD%E5%90%A6%E8%AF%B7%E6%82%A8%E6%8F%90%E4%BE%9B%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%80%E9%97%AE%E9%A2%98%E7%9A%84%E6%96%B9%E6%B3%95%EF%BC%9F%E5%8F%A6%E5%A4%96%EF%BC%8C%E6%98%AF%E5%90%A6%E6%9C%89%E4%BB%BB%E4%BD%95%E7%A8%8B%E5%BA%8F%E6%96%87%E6%A1%A3%E6%88%96%E5%BA%94%E7%94%A8%E7%AC%94%E8%AE%B0%E5%8F%AF%E4%BE%9B%E4%BD%BF%E7%94%A8%20S32Z280%20%E5%BC%80%E5%8F%91%E6%9D%BF%E4%B8%8A%E7%9A%84%20R52%2FM33%20%E5%86%85%E6%A0%B8%E8%BF%9B%E8%A1%8CUART%E6%89%93%E5%8D%B0%2F%E8%BE%93%E5%87%BA%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3EBR%2C%3CBR%20%2F%3EKarthik%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2363741%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20creating%20a%20Blob%20Image%20using%20IVT%20S32Z2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2363741%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%3CSPAN%3E%EF%BC%8Ckarthik_nikil%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%9C%89%E6%B2%A1%E6%9C%89%E8%B0%83%E8%AF%95%E5%99%A8%E5%8F%AF%E4%BB%A5%E6%B5%8B%E8%AF%95%20R52%20%E5%86%85%E6%A0%B8%E4%B8%8A%E7%9A%84%20UART%20Demo%EF%BC%9F%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%E5%85%88%E5%9C%A8%E6%B2%A1%E6%9C%89%20IVT%20%E7%9A%84%20R52%20%E4%B8%8A%E8%B0%83%E8%AF%95%E8%AF%A5%E4%BB%A3%E7%A0%81%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E4%B9%94%E4%BC%8A%3C%2FP%3E%3C%2FLINGO-BODY%3E
