S32Z RTU0 core0 performance issue
2,434 次查看
DirkEtzler
I am running some test code on S32Z270 RTU0 core 0 (R52) with RTU0_CORE_CLK set to 1GHz where the execution time seems to too long.  In comparison I am running the same code on SS32K388 core 0 (CM7) with core clock set 320MHz.  Given the clock frequency increase I would have expected some faster execution but instead the execution time is longer.
Build/compilation flags are held identical for both binaries (see attached txt file buildinfo.h)
(1) Since the clock configuration in the S32 Configuration Tool is kind of sophisticated for the S32Z how can I make sure the RTU0 core 0 clock frequency is 1GHz as intended?
I have routed out the RTU0_CORE_DIV2_CLK via MC_CGM_3_MUX4_CSC (e.g., SEL_CTL = 0x3D) to CLKOUT_4 (PAD_040 of BGA594) including a divider of 10 in MC_CGM_3_MUX4_DC_0 (e.g., DIV = 0x9).  See also attached register readings.  If I measure 50MHz at CLKOUT_4, can I presume that (a) RTU0_CORE_DIV2_CLK is 500MHz and (b) RTU0_CORE_CLK is 1GHz?
(2) I have measured the execution time of pin writes to GPIO using S32Z RTD2.0.1 and measuring high/low times of scope channel CH5 - TESTFLAG which is roughly 3.4us. Is there the possibility that you could confirm whether they seem to be alright or too slow?
(3) I am not sure what I am missing.
标记 (3)
9 回复数
2,300 次查看
Joey_z
Hi,DirkEtzler
Sorry for the reply late.
(1) I have routed out the RTU0_CORE_DIV2_CLK via MC_CGM_3_MUX4_CSC (e.g., SEL_CTL = 0x3D) to CLKOUT_4 (PAD_040 of BGA594) including a divider of 10 in MC_CGM_3_MUX4_DC_0 (e.g., DIV = 0x9). See also attached register readings. If I measure 50MHz at CLKOUT_4, can I presume that (a) RTU0_CORE_DIV2_CLK is 500MHz and (b) RTU0_CORE_CLK is 1GHz?
>>>About this question, the number 7 is assigned to RTU0_CORE_DIV2_CLK, you also should program GPR3.CLKOUT4SE to set this value. Could you try to confirm if you have set this register?
Joey
1,972 次查看
DirkEtzler
Hello @Joey_z,
I am not sure my previous message went through and was recognized as a reply.  I have checked GPR3.CLKOUT4SEL[MUXSEL] is set to 0x7 and thus, routing RTU0_CORE_DIV2_CLK through the multiplexer.  Using the described configuration and seeing 50MHz at the output pin, I presume the RTU0 core is clocked with 1GHz.
If the core frequency is set to 1GHz and I still do not see the expected performance (e.g., using CoreMark testbench) what else could be incorrect configured?  How can I check if the cache is configured correctly?  I have been looking through the assembler startup script and also the used linker script and cannot find anything that looks suspicious.
标记 (3)
1,917 次查看
Joey_z
Hi,DirkEtzler
Thank you for your reply and detail information.
You can try to refer to the chapter 3,4 of AN14245 to check the cache configuration. Cache mechanisms help enhance the memory performance. You can download it as the following picture.
In addition, the GPIO turn over to the time of measurement, mainly reflects the "delay" access path of the peripheral, but there will be a deviation of CPU core computing performance. Also, have the contents of CoreMark in this application, you can as references for your testing.
Joey
1,684 次查看
DirkEtzler
Hello @Joey_z,
Thank you-I will review chapters 3 and 4 of the mentioned application note (AN14245 S32ZE Safe and Secure High-Performance Real-Time Processors) with respect to the correct setup of the caches.
As a side note, the obtained CoreMark scores are too low-that is the reason for the support case in the first place.
标记 (3)
2,151 次查看
DirkEtzler
Hello @Joey_z
With respect to this question:
I have checked register settings for GPR3.CLKOUT4SEL[MUXSEL] which is set to 7 to select RTU0_CORE_DIV2_CLK in the corresponding multiplexer.
标记 (3)
2,388 次查看
Joey_z
Hi,DirkEtzler
Thank you for contacting us.
1.Do you use the development board or customer board?
2. Are you using the IDE of S32DS? What is the version of IDE for you testing?
3. Could you share your testing code with me?
Joey
2,381 次查看
DirkEtzler
Hello @Joey_z,
thanks for the quick reply.  Please see below my answers to the questions:
1) I am using a combination of the S32Z2XX motherboard + S32Z2XX daughterboard.
    a) S32ZXX motherboard X-S32X-MB version A
    b) S32ZXX daughterboard SCH-50588 REV B2 / 700-50588 REV A2
2) Code is compiled and linked using S32DS Version 3.6.7 Build 260420.  There is no change when using previous releases of the S32DS such as Version 3.6.6 or 3.6.5.  I am using RTD2.0.1 for S32Z2XX.
3) I will send a copy of the project using DM.
标记 (3)
2,329 次查看
Joey_z
Hi,DirkEtzler
I will help you to check it and reply to you late.
Joey
2,380 次查看
DirkEtzler
Attached is also a photo of the package markings.
Scan from 2026-04-27 09_28_21 AM.jpg0
标记 (3)
%3CLINGO-SUB%20id%3D%22lingo-sub-2356091%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32Z%20RTU0%20core0%20%E6%80%A7%E8%83%BD%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2356091%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E5%9C%A8%20S32Z270%20RTU0%20%E5%86%85%E6%A0%B8%200%20(R52)%20%E4%B8%8A%E8%BF%90%E8%A1%8C%E4%B8%80%E4%BA%9B%E6%B5%8B%E8%AF%95%E4%BB%A3%E7%A0%81%EF%BC%8CRTU0_CORE_CLK%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%201GHz%EF%BC%8C%E6%89%A7%E8%A1%8C%E6%97%B6%E9%97%B4%E4%BC%BC%E4%B9%8E%E8%BF%87%E9%95%BF%E3%80%82%20%E7%9B%B8%E6%AF%94%E4%B9%8B%E4%B8%8B%EF%BC%8C%E6%88%91%E5%9C%A8%20SS32K388%20%E5%86%85%E6%A0%B8%200%20(CM7)%20%E4%B8%8A%E8%BF%90%E8%A1%8C%E7%9B%B8%E5%90%8C%E7%9A%84%E4%BB%A3%E7%A0%81%EF%BC%8C%E5%86%85%E6%A0%B8%E6%97%B6%E9%92%9F%E8%AE%BE%E7%BD%AE%E4%B8%BA%20320MHz%E3%80%82%20%E9%89%B4%E4%BA%8E%E6%97%B6%E9%92%9F%E9%A2%91%E7%8E%87%E7%9A%84%E6%8F%90%E9%AB%98%EF%BC%8C%E6%88%91%E6%9C%AC%E4%BB%A5%E4%B8%BA%E6%89%A7%E8%A1%8C%E9%80%9F%E5%BA%A6%E4%BC%9A%E6%9B%B4%E5%BF%AB%E4%B8%80%E4%BA%9B%EF%BC%8C%E4%BD%86%E6%89%A7%E8%A1%8C%E6%97%B6%E9%97%B4%E5%8F%8D%E8%80%8C%E6%9B%B4%E9%95%BF%E4%BA%86%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%B8%A4%E4%B8%AA%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E7%9A%84%E7%89%88%E6%9C%AC%2F%E7%BC%96%E8%AF%91%E6%A0%87%E5%BF%97%E4%BF%9D%E6%8C%81%E4%B8%8D%E5%8F%98%EF%BC%88%E5%8F%82%E8%A7%81%E9%9A%8F%E9%99%84%E7%9A%84%20txt%20%E6%96%87%E4%BB%B6%20buildinfo.h%EF%BC%89%3C%2FP%3E%3CP%3E(1)%20%E7%94%B1%E4%BA%8E%20S32%20%E9%85%8D%E7%BD%AE%E5%B7%A5%E5%85%B7%E4%B8%AD%E7%9A%84%E6%97%B6%E9%92%9F%E9%85%8D%E7%BD%AE%E5%AF%B9%E4%BA%8E%20S32Z%20%E6%9D%A5%E8%AF%B4%E6%9C%89%E7%82%B9%E5%A4%8D%E6%9D%82%EF%BC%8C%E6%88%91%E5%A6%82%E4%BD%95%E6%89%8D%E8%83%BD%E7%A1%AE%E4%BF%9D%20RTU0%20%E5%86%85%E6%A0%B8%200%20%E7%9A%84%E6%97%B6%E9%92%9F%E9%A2%91%E7%8E%87%E6%8C%89%E8%AE%A1%E5%88%92%E4%B8%BA%201GHz%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E9%80%9A%E8%BF%87%20MC_CGM_3_MUX4_CSC%EF%BC%88%E4%BE%8B%E5%A6%82%EF%BC%8CSEL_CTL%20%3D%200x3D%EF%BC%89%E5%B0%86%20RTU0_CORE_DIV2_CLK%20%E8%B7%AF%E7%94%B1%E5%88%B0%20CLKOUT_4%EF%BC%88BGA594%20%E7%9A%84%20PAD_040%EF%BC%89%EF%BC%8C%E5%8C%85%E6%8B%AC%20MC_CGM_3_MUX4_DC_0%EF%BC%88%E4%BE%8B%E5%A6%82%EF%BC%8CDIV%20%3D%200x9%EF%BC%89%E4%B8%AD%E4%B8%BA%2010%20%E7%9A%84%E5%88%86%E9%A2%91%E5%99%A8%E3%80%82%E5%8F%A6%E8%AF%B7%E5%8F%82%E8%A7%81%E6%89%80%E9%99%84%E7%9A%84%E7%99%BB%E8%AE%B0%E5%86%8C%E8%AF%BB%E6%95%B0%E3%80%82%20%E5%A6%82%E6%9E%9C%E6%88%91%E5%9C%A8%20CLKOUT_4%20%E6%B5%8B%E9%87%8F%E5%88%B0%2050MHz%EF%BC%8C%E6%88%91%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%E5%81%87%E5%AE%9A%20(a)%20RTU0_CORE_DIV2_CLK%20%E4%B8%BA%20500MHz%EF%BC%8C(b)%20RTU0_CORE_CLK%20%E4%B8%BA%201GHz%EF%BC%9F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22CGM_3_MUX_4_Register_Configuration.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CGM_3_MUX_4_Register_Configuration.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CGM_3_MUX_4_Register_Configuration.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CGM_3_MUX_4_Register_Configuration.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CGM_3_MUX_4_Register_Configuration.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CGM_3_MUX_4_Register_Configuration.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CGM_3_MUX_4_Register_Configuration.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CGM_3_MUX_4_Register_Configuration.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F383545i36C238F396D827E8%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22CGM_3_MUX_4_Register_Configuration.png%22%20alt%3D%22CGM_3_MUX_4_Register_Configuration.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22CLOCKOUT4_Measurements_RTU0_CORE_DIV2_CLK_50MHz.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CLOCKOUT4_Measurements_RTU0_CORE_DIV2_CLK_50MHz.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CLOCKOUT4_Measurements_RTU0_CORE_DIV2_CLK_50MHz.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CLOCKOUT4_Measurements_RTU0_CORE_DIV2_CLK_50MHz.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CLOCKOUT4_Measurements_RTU0_CORE_DIV2_CLK_50MHz.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CLOCKOUT4_Measurements_RTU0_CORE_DIV2_CLK_50MHz.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CLOCKOUT4_Measurements_RTU0_CORE_DIV2_CLK_50MHz.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CLOCKOUT4_Measurements_RTU0_CORE_DIV2_CLK_50MHz.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F383548iC98078EC49FA7E3B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22CLOCKOUT4_Measurements_RTU0_CORE_DIV2_CLK_50MHz.png%22%20alt%3D%22CLOCKOUT4_Measurements_RTU0_CORE_DIV2_CLK_50MHz.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E(2)%20%E6%88%91%E4%BD%BF%E7%94%A8%20S32Z%20RTD2.0.1%20%E6%B5%8B%E9%87%8F%E4%BA%86%E5%BC%95%E8%84%9A%E5%86%99%E5%85%A5%20GPIO%20%E7%9A%84%E6%89%A7%E8%A1%8C%E6%97%B6%E9%97%B4%EF%BC%8C%E5%B9%B6%E6%B5%8B%E9%87%8F%E4%BA%86%E7%A4%BA%E6%B3%A2%E5%99%A8%E9%80%9A%E9%81%93%20CH5%20-%20TESTFLAG%20%E7%9A%84%E9%AB%98%2F%E4%BD%8E%E6%97%B6%E9%97%B4%EF%BC%8C%E5%A4%A7%E7%BA%A6%E4%B8%BA%203.4us%E3%80%82%E6%82%A8%E6%98%AF%E5%90%A6%E6%9C%89%E5%8F%AF%E8%83%BD%E7%A1%AE%E8%AE%A4%E4%B8%80%E4%B8%8B%E5%AE%83%E4%BB%AC%E7%9C%8B%E8%B5%B7%E6%9D%A5%E6%98%AF%E6%AD%A3%E5%B8%B8%E8%BF%98%E6%98%AF%E5%A4%AA%E6%85%A2%E4%BA%86%EF%BC%9F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%202026-04-25%20123853.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-04-25%20123853.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-04-25%20123853.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-04-25%20123853.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-04-25%20123853.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-04-25%20123853.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-04-25%20123853.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-04-25%20123853.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F383551i953CE096312FD10E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Screenshot%202026-04-25%20123853.png%22%20alt%3D%22Screenshot%202026-04-25%20123853.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Setting_GPIO_Low_3.4us.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Setting_GPIO_Low_3.4us.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Setting_GPIO_Low_3.4us.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Setting_GPIO_Low_3.4us.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Setting_GPIO_Low_3.4us.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Setting_GPIO_Low_3.4us.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Setting_GPIO_Low_3.4us.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Setting_GPIO_Low_3.4us.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F383549i34C2E01D659469F5%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Setting_GPIO_Low_3.4us.png%22%20alt%3D%22Setting_GPIO_Low_3.4us.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Setting_GPIO_High_3.4us.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Setting_GPIO_High_3.4us.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Setting_GPIO_High_3.4us.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Setting_GPIO_High_3.4us.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Setting_GPIO_High_3.4us.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Setting_GPIO_High_3.4us.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Setting_GPIO_High_3.4us.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Setting_GPIO_High_3.4us.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F383550i91DC76C42E27B98D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Setting_GPIO_High_3.4us.png%22%20alt%3D%22Setting_GPIO_High_3.4us.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E(3)%20%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E6%88%91%E9%94%99%E8%BF%87%E4%BA%86%E4%BB%80%E4%B9%88%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E2%80%83%3C%2FP%3E%3CP%3E%E2%80%83%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2356609%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32Z%20RTU0%20core0%20performance%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2356609%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E9%9A%8F%E5%87%BD%E9%99%84%E4%B8%8A%E5%8C%85%E8%A3%85%E6%A0%87%E8%AE%B0%E7%9A%84%E7%85%A7%E7%89%87%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Scan%20from%202026-04-27%2009_28_21%20AM.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Scan%20from%202026-04-27%2009_28_21%20AM.jpg%22%20style%3D%22width%3A%20279px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Scan%20from%202026-04-27%2009_28_21%20AM.jpg%22%20style%3D%22width%3A%20279px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Scan%20from%202026-04-27%2009_28_21%20AM.jpg%22%20style%3D%22width%3A%20279px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Scan%20from%202026-04-27%2009_28_21%20AM.jpg%22%20style%3D%22width%3A%20279px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Scan%20from%202026-04-27%2009_28_21%20AM.jpg%22%20style%3D%22width%3A%20279px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Scan%20from%202026-04-27%2009_28_21%20AM.jpg%22%20style%3D%22width%3A%20279px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Scan%20from%202026-04-27%2009_28_21%20AM.jpg%22%20style%3D%22width%3A%20279px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F383703i21FECFF5B6C92395%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Scan%20from%202026-04-27%2009_28_21%20AM.jpg%22%20alt%3D%22Scan%20from%202026-04-27%2009_28_21%20AM.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E0%3C%2FP%3E%3CP%3E%E2%80%83%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2356604%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32Z%20RTU0%20core0%20performance%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2356604%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F236188%22%20target%3D%22_blank%22%3E%40Joey_z%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%BF%AB%E9%80%9F%E5%9B%9E%E5%A4%8D%E3%80%82%20%E4%B8%8B%E9%9D%A2%E6%98%AF%E6%88%91%E5%AF%B9%E8%BF%99%E4%BA%9B%E9%97%AE%E9%A2%98%E7%9A%84%E5%9B%9E%E7%AD%94%EF%BC%9A%3C%2FP%3E%3CP%3E1)%20%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20S32Z2XX%20%E4%B8%BB%E6%9D%BF%20%2B%20S32Z2XX%20%E5%AD%90%E6%9D%BF%E7%9A%84%E7%BB%84%E5%90%88%E3%80%82%3CBR%20%2F%3E%20%20a)%20S32ZXX%20%E4%B8%BB%E6%9D%BF%20X-S32X-MB%20A%20%E7%89%88%3CBR%20%2F%3E%20b)%20S32ZXX%20%E5%AD%90%E6%9D%BF%20SCH-50588%20REV%20B2%20%2F%20700-50588%20REV%20A2%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22S32Z2XX_Complete_Setup.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32Z2XX_Complete_Setup.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32Z2XX_Complete_Setup.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32Z2XX_Complete_Setup.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32Z2XX_Complete_Setup.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32Z2XX_Complete_Setup.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32Z2XX_Complete_Setup.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32Z2XX_Complete_Setup.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F383695iF5820893A0717FB2%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22S32Z2XX_Complete_Setup.jpg%22%20alt%3D%22S32Z2XX_Complete_Setup.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22S32Z2XX_Motherboard_Tag.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32Z2XX_Motherboard_Tag.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32Z2XX_Motherboard_Tag.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32Z2XX_Motherboard_Tag.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32Z2XX_Motherboard_Tag.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32Z2XX_Motherboard_Tag.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32Z2XX_Motherboard_Tag.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32Z2XX_Motherboard_Tag.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F383696i67693169B9569321%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22S32Z2XX_Motherboard_Tag.jpg%22%20alt%3D%22S32Z2XX_Motherboard_Tag.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22S32Z2XX_Daughterboard_Tag.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32Z2XX_Daughterboard_Tag.jpg%22%20style%3D%22width%3A%20311px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32Z2XX_Daughterboard_Tag.jpg%22%20style%3D%22width%3A%20311px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32Z2XX_Daughterboard_Tag.jpg%22%20style%3D%22width%3A%20311px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32Z2XX_Daughterboard_Tag.jpg%22%20style%3D%22width%3A%20311px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32Z2XX_Daughterboard_Tag.jpg%22%20style%3D%22width%3A%20311px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32Z2XX_Daughterboard_Tag.jpg%22%20style%3D%22width%3A%20311px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32Z2XX_Daughterboard_Tag.jpg%22%20style%3D%22width%3A%20311px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F383697i7DF2E8EEBDDCE198%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22S32Z2XX_Daughterboard_Tag.jpg%22%20alt%3D%22S32Z2XX_Daughterboard_Tag.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E2)%20%E4%BB%A3%E7%A0%81%E4%BD%BF%E7%94%A8%20S32DS%20%E7%89%88%E6%9C%AC%203.6.7%20Build%20260420%20%E8%BF%9B%E8%A1%8C%E7%BC%96%E8%AF%91%E5%92%8C%E9%93%BE%E6%8E%A5%E3%80%82%E4%BD%BF%E7%94%A8%20S32DS%20%E7%9A%84%E5%85%88%E5%89%8D%E7%89%88%E6%9C%AC%EF%BC%88%E4%BE%8B%E5%A6%82%E7%89%88%E6%9C%AC%203.6.6%20%E6%88%96%203.6.5%EF%BC%89%E6%97%B6%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E5%8F%98%E5%8C%96%E3%80%82%E6%88%91%E6%AD%A3%E5%9C%A8%E4%B8%BA%20S32Z2XX%20%E4%BD%BF%E7%94%A8%20RTD2.0.1%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%202026-04-27%20092032.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-04-27%20092032.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-04-27%20092032.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-04-27%20092032.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-04-27%20092032.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-04-27%20092032.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-04-27%20092032.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-04-27%20092032.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F383698iF5CBE97A41904962%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Screenshot%202026-04-27%20092032.png%22%20alt%3D%22Screenshot%202026-04-27%20092032.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%202026-04-27%20092336.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-04-27%20092336.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-04-27%20092336.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-04-27%20092336.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-04-27%20092336.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-04-27%20092336.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-04-27%20092336.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-04-27%20092336.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F383700i93421940C0E24948%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Screenshot%202026-04-27%20092336.png%22%20alt%3D%22Screenshot%202026-04-27%20092336.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E3)%20%E6%88%91%E4%BC%9A%E4%BD%BF%E7%94%A8%20DM%20%E5%8F%91%E9%80%81%E9%A1%B9%E7%9B%AE%E5%89%AF%E6%9C%AC%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2356207%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32Z%20RTU0%20core0%20performance%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2356207%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E5%BE%B7%E5%85%8B-%E5%9F%83%E5%85%B9%E5%8B%92%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E4%B8%8E%E6%88%91%E4%BB%AC%E8%81%94%E7%B3%BB%E3%80%82%20%3C%2FP%3E%0A%3CP%3E1.%20%E4%BD%A0%E4%BD%BF%E7%94%A8%E5%BC%80%E5%8F%91%E6%9D%BF%E8%BF%98%E6%98%AF%E5%AE%A2%E6%88%B7%E6%9D%BF%EF%BC%9F%3C%2FP%3E%0A%3CP%3E2.%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20S32DS%20%E7%9A%84%20IDE%20%E5%90%97%EF%BC%9F%E6%82%A8%E6%B5%8B%E8%AF%95%E7%9A%84%20IDE%20%E7%89%88%E6%9C%AC%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FP%3E%0A%3CP%3E3.%E8%83%BD%E5%90%A6%E4%B8%8E%E6%88%91%E5%88%86%E4%BA%AB%E6%82%A8%E7%9A%84%E6%B5%8B%E8%AF%95%E4%BB%A3%E7%A0%81%EF%BC%9F%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E4%B9%94%E4%BC%8A%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2357714%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32Z%20RTU0%20core0%20performance%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2357714%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CSPAN%3E%EF%BC%8C%E5%BE%B7%E5%85%8B-%E5%9F%83%E8%8C%A8%E5%8B%92%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E7%AD%94%E5%A4%8D%E5%92%8C%E8%AF%A6%E7%BB%86%E8%B5%84%E6%96%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E4%BC%9A%E5%B8%AE%E4%BD%A0%E6%A3%80%E6%9F%A5%EF%BC%8C%E5%B9%B6%E5%9C%A8%E6%99%9A%E4%BA%9B%E6%97%B6%E5%80%99%E5%9B%9E%E5%A4%8D%E4%BD%A0%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E4%B9%94%E4%BC%8A%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2358201%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32Z%20RTU0%20core0%20performance%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2358201%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E5%BE%B7%E5%85%8B-%E5%9F%83%E8%8C%A8%E5%8B%92%3C%2FP%3E%0A%3CP%3E%E6%8A%B1%E6%AD%89%EF%BC%8C%E5%9B%9E%E5%A4%8D%E6%99%9A%E4%BA%86%E3%80%82%3C%2FP%3E%0A%3CP%3E(1)%20%E6%88%91%E5%B7%B2%E7%BB%8F%E9%80%9A%E8%BF%87%20MC_CGM_3_MUX4_CSC%EF%BC%88%E4%BE%8B%E5%A6%82%EF%BC%8CSEL_CTL%20%3D%200x3D%EF%BC%89%E5%B0%86%20RTU0_CORE_DIV2_CLK%20%E8%B7%AF%E7%94%B1%E5%88%B0%20CLKOUT_4%EF%BC%88BGA594%20%E7%9A%84%20PAD_040%EF%BC%89%EF%BC%8C%E5%8C%85%E6%8B%AC%20MC_CGM_3_MUX4_DC_0%20%E4%B8%AD%E7%9A%84%E5%88%86%E9%A2%91%E5%99%A8%2010%EF%BC%88%E4%BE%8B%E5%A6%82%EF%BC%8CDIV%20%3D%200x9%EF%BC%89%E3%80%82%E5%8F%A6%E8%AF%B7%E5%8F%82%E8%A7%81%E6%89%80%E9%99%84%E7%9A%84%E7%99%BB%E8%AE%B0%E5%86%8C%E8%AF%BB%E6%95%B0%E3%80%82%E5%A6%82%E6%9E%9C%E6%88%91%E5%9C%A8%20CLKOUT_4%20%E6%B5%8B%E9%87%8F%E5%88%B0%2050MHz%EF%BC%8C%E6%88%91%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%E5%81%87%E5%AE%9A%20(a)%20RTU0_CORE_DIV2_CLK%20%E4%B8%BA%20500MHz%EF%BC%8C(b)%20RTU0_CORE_CLK%20%E4%B8%BA%201GHz%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%26gt%3B%26gt%3B%26gt%3B%E5%85%B3%E4%BA%8E%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E6%95%B0%E5%AD%97%207%20%E8%A2%AB%E5%88%86%E9%85%8D%E7%BB%99%20RTU0_CORE_DIV2_CLK%EF%BC%8C%E6%82%A8%E8%BF%98%E5%BA%94%E9%80%9A%E8%BF%87%E7%BC%96%E7%A8%8B%20GPR3.CLKOUT4SE%20%E6%9D%A5%E8%AE%BE%E7%BD%AE%E8%AF%A5%E5%80%BC%E3%80%82%E6%82%A8%E8%83%BD%E7%A1%AE%E8%AE%A4%E4%B8%80%E4%B8%8B%E6%98%AF%E5%90%A6%E8%AE%BE%E7%BD%AE%E4%BA%86%E8%BF%99%E4%B8%AA%E5%AF%84%E5%AD%98%E5%99%A8%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Joey_z_0-1777434680768.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_0-1777434680768.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_0-1777434680768.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_0-1777434680768.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_0-1777434680768.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_0-1777434680768.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F383922i342E3A6FCEE00F10%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Joey_z_0-1777434680768.png%22%20alt%3D%22Joey_z_0-1777434680768.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E4%B9%94%E4%BC%8A%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2359660%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32Z%20RTU0%20core0%20performance%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2359660%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F236188%22%20target%3D%22_blank%22%3E%40Joey_z%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%85%B3%E4%BA%8E%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CEM%3E%26gt%3B%26gt%3B%26gt%3B%E5%85%B3%E4%BA%8E%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E6%95%B0%E5%AD%97%207%20%E8%A2%AB%E5%88%86%E9%85%8D%E7%BB%99%20RTU0_CORE_DIV2_CLK%EF%BC%8C%E6%82%A8%E8%BF%98%E5%BA%94%E9%80%9A%E8%BF%87%E7%BC%96%E7%A8%8B%20GPR3.CLKOUT4SE%20%E6%9D%A5%E8%AE%BE%E7%BD%AE%E8%AF%A5%E5%80%BC%E3%80%82%20%E6%82%A8%E8%83%BD%E7%A1%AE%E8%AE%A4%E4%B8%80%E4%B8%8B%E6%98%AF%E5%90%A6%E8%AE%BE%E7%BD%AE%E4%BA%86%E8%BF%99%E4%B8%AA%E5%AF%84%E5%AD%98%E5%99%A8%E5%90%97%EF%BC%9F%3C%2FEM%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%A3%80%E6%9F%A5%E4%BA%86%20GPR3.CLKOUT4SEL%5BMUXSEL%5D%20%E7%9A%84%E5%AF%84%E5%AD%98%E5%99%A8%E8%AE%BE%E7%BD%AE%EF%BC%8C%E8%AF%A5%E5%AF%84%E5%AD%98%E5%99%A8%E8%AE%BE%E7%BD%AE%E4%B8%BA%207%EF%BC%8C%E7%94%A8%E4%BA%8E%E5%9C%A8%E7%9B%B8%E5%BA%94%E7%9A%84%E5%A4%9A%E8%B7%AF%E5%A4%8D%E7%94%A8%E5%99%A8%E4%B8%AD%E9%80%89%E6%8B%A9%20RTU0_CORE_DIV2_CLK%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2360478%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32Z%20RTU0%20core0%20performance%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2360478%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F236188%22%20target%3D%22_blank%22%3E%40Joey_z%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E6%88%91%E4%B8%8D%E7%A1%AE%E5%AE%9A%E6%88%91%E4%B9%8B%E5%89%8D%E7%9A%84%E7%95%99%E8%A8%80%E6%98%AF%E5%90%A6%E5%B7%B2%E8%A2%AB%E7%A1%AE%E8%AE%A4%E4%B8%BA%E5%9B%9E%E5%A4%8D%E3%80%82%20%E6%88%91%E6%A3%80%E6%9F%A5%E4%BA%86%20GPR3.CLKOUT4SEL%5BMUXSEL%5D%E6%98%AF%E5%90%A6%E8%AE%BE%E7%BD%AE%E4%B8%BA%200x7%EF%BC%8C%E5%9B%A0%E6%AD%A4%3CSPAN%3ERTU0_CORE_DIV2_CLK%20%E9%80%9A%E8%BF%87%E5%A4%9A%E8%B7%AF%E5%A4%8D%E7%94%A8%E5%99%A8%3C%2FSPAN%3E%E8%B7%AF%E7%94%B1%E3%80%82%20%20%E4%BD%BF%E7%94%A8%E6%89%80%E8%BF%B0%E9%85%8D%E7%BD%AE%E5%B9%B6%E5%9C%A8%E8%BE%93%E5%87%BA%E5%BC%95%E8%84%9A%E4%B8%8A%E7%9C%8B%E5%88%B0%2050MHz%EF%BC%8C%E6%88%91%E6%8E%A8%E6%B5%8B%20RTU0%20%E5%86%85%E6%A0%B8%E7%9A%84%E6%97%B6%E9%92%9F%E9%A2%91%E7%8E%87%E4%B8%BA%201GHz%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%E5%86%85%E6%A0%B8%E9%A2%91%E7%8E%87%E8%AE%BE%E7%BD%AE%E4%B8%BA%201GHz%EF%BC%8C%E4%BD%86%E6%88%91%E4%BB%8D%E7%84%B6%E6%B2%A1%E6%9C%89%E7%9C%8B%E5%88%B0%E9%A2%84%E6%9C%9F%E7%9A%84%E6%80%A7%E8%83%BD%EF%BC%88%E4%BE%8B%E5%A6%82%EF%BC%8C%E4%BD%BF%E7%94%A8%20CoreMark%20%E6%B5%8B%E8%AF%95%E5%8F%B0%EF%BC%89%EF%BC%8C%E8%BF%98%E6%9C%89%E4%BB%80%E4%B9%88%E5%85%B6%E4%BB%96%E4%B8%8D%E6%AD%A3%E7%A1%AE%E7%9A%84%E9%85%8D%E7%BD%AE%E5%90%97%EF%BC%9F%20%E5%A6%82%E4%BD%95%E6%A3%80%E6%9F%A5%E7%BC%93%E5%AD%98%E9%85%8D%E7%BD%AE%E6%98%AF%E5%90%A6%E6%AD%A3%E7%A1%AE%EF%BC%9F%20%E6%88%91%E6%9F%A5%E7%9C%8B%E4%BA%86%E6%B1%87%E7%BC%96%E5%99%A8%E5%90%AF%E5%8A%A8%E8%84%9A%E6%9C%AC%E5%92%8C%E4%BD%BF%E7%94%A8%E8%BF%87%E7%9A%84%E9%93%BE%E6%8E%A5%E5%99%A8%E8%84%9A%E6%9C%AC%EF%BC%8C%E6%B2%A1%E6%9C%89%E5%8F%91%E7%8E%B0%E4%BB%BB%E4%BD%95%E5%8F%AF%E7%96%91%E4%B9%8B%E5%A4%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2360805%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32Z%20RTU0%20core0%20performance%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2360805%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CSPAN%3E%EF%BC%8C%E5%BE%B7%E5%85%8B-%E5%9F%83%E8%8C%A8%E5%8B%92%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E7%AD%94%E5%A4%8D%E5%92%8C%E8%AF%A6%E7%BB%86%E8%B5%84%E6%96%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%E5%8F%82%E8%80%83%20AN14245%20%E7%9A%84%E7%AC%AC%203%E3%80%814%20%E7%AB%A0%E6%9D%A5%E6%A3%80%E6%9F%A5%E7%BC%93%E5%AD%98%E9%85%8D%E7%BD%AE%E3%80%82%20%E9%AB%98%E9%80%9F%E7%BC%93%E5%AD%98%E6%9C%BA%E5%88%B6%E6%9C%89%E5%8A%A9%E4%BA%8E%E6%8F%90%E9%AB%98%E5%86%85%E5%AD%98%E6%80%A7%E8%83%BD%E3%80%82%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%B8%8B%E8%BD%BD%E4%BB%A5%E4%B8%8B%E5%9B%BE%E7%89%87%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Joey_z_0-1778036409619.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_0-1778036409619.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_0-1778036409619.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F384427i4E75224FF4928D02%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Joey_z_0-1778036409619.png%22%20alt%3D%22Joey_z_0-1778036409619.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E5%A4%96%EF%BC%8CGPIO%20%E7%BF%BB%E8%BD%AC%E5%88%B0%E6%B5%8B%E9%87%8F%E6%97%B6%E9%97%B4%EF%BC%8C%E4%B8%BB%E8%A6%81%E5%8F%8D%E6%98%A0%E4%BA%86%E5%A4%96%E8%AE%BE%E7%9A%84%22%E5%BB%B6%E8%BF%9F%22%20%E8%AE%BF%E9%97%AE%E8%B7%AF%E5%BE%84%EF%BC%8C%E4%BD%86%E4%BC%9A%E5%AF%B9%20CPU%20%E5%86%85%E6%A0%B8%E8%BF%90%E7%AE%97%E6%80%A7%E8%83%BD%E4%BA%A7%E7%94%9F%E5%81%8F%E5%B7%AE%E3%80%82%E5%8F%A6%E5%A4%96%EF%BC%8C%E5%9C%A8%E6%AD%A4%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E4%B8%AD%E5%8C%85%E5%90%ABCoreMark%E7%9A%84%E5%86%85%E5%AE%B9%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BD%9C%E4%B8%BA%E6%B5%8B%E8%AF%95%E7%9A%84%E5%8F%82%E8%80%83%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E4%B9%94%E4%BC%8A%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2363445%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32Z%20RTU0%20core0%20performance%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2363445%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F236188%22%20target%3D%22_blank%22%3E%40Joey_z%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%8C%E6%88%91%E5%B0%86%E9%98%85%E8%AF%BB%E4%B8%8A%E8%BF%B0%E5%BA%94%E7%94%A8%E7%AC%94%E8%AE%B0%EF%BC%88AN14245%20S32ZE%20%E5%AE%89%E5%85%A8%E5%8F%AF%E9%9D%A0%E7%9A%84%E9%AB%98%E6%80%A7%E8%83%BD%E5%AE%9E%E6%97%B6%E5%A4%84%E7%90%86%E5%99%A8%EF%BC%89%E7%9A%84%E7%AC%AC%203%20%E7%AB%A0%E5%92%8C%E7%AC%AC%204%20%E7%AB%A0%EF%BC%8C%E4%BA%86%E8%A7%A3%E7%BC%93%E5%AD%98%E7%9A%84%E6%AD%A3%E7%A1%AE%E8%AE%BE%E7%BD%AE%E3%80%82%3C%2FP%3E%3CP%3E%E9%A1%BA%E4%BE%BF%E6%8F%90%E4%B8%80%E5%8F%A5%EF%BC%8C%E8%8E%B7%E5%BE%97%E7%9A%84%20CoreMark%20%E5%88%86%E6%95%B0%E5%A4%AA%E4%BD%8E%EF%BC%8C%E8%BF%99%E4%B9%9F%E6%98%AF%E6%94%AF%E6%8C%81%E6%A1%88%E4%BE%8B%E7%9A%84%E8%B5%B7%E5%9B%A0%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
