Using C++ with Real-Time Drivers
smp9
I'm reviewing the Real-Time Drivers for the S32E288 and have only been able to find implementation examples in C.
Is it possible to also use them in a C++ project?
Thanks.
Joey_z
hi,smp9
Thank you for contacting us.
For the chapter 2.7 of ReleaseNote, the RTD drivers are not tested with the C++ compiler option. Also, about how to use the RTD to a C++ project, you can try should use different compilers to compile the RTD and C++ application. We do not more information for supporting this operation.
Joey
Joey_z
hi,smp9
Joey
%3CLINGO-SUB%20id%3D%22lingo-sub-2175978%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EUsing%20C%2B%2B%20with%20Real-Time%20Drivers%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2175978%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EI'm%20reviewing%20the%20Real-Time%20Drivers%20for%20the%20S32E288%20and%20have%20only%20been%20able%20to%20find%20implementation%20examples%20in%20C.%3C%2FP%3E%3CP%3EIs%20it%20possible%20to%20also%20use%20them%20in%20a%20C%2B%2B%20project%3F%3C%2FP%3E%3CP%3EThanks.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2176191%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Using%20C%2B%2B%20with%20Real-Time%20Drivers%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2176191%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ehi%EF%BC%8C%3CSPAN%3Esmp9%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EThank%20you%20for%20contacting%20us.%3C%2FP%3E%0A%3CP%3EFor%20the%20chapter%202.7%20of%20ReleaseNote%2C%20the%20RTD%20drivers%20are%20not%20tested%20with%20the%20C%2B%2B%20compiler%20option.%20Also%2C%20about%20how%20to%20use%20the%20RTD%20to%20a%26nbsp%3BC%2B%2B%20project%2C%20you%20can%20try%20should%26nbsp%3Buse%20different%20compilers%20to%20compile%20the%20RTD%20and%20C%2B%2B%20application.%20We%20do%20not%20more%20information%20for%20supporting%20this%20operation.%26nbsp%3B%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EJoey%3C%2FP%3E%3C%2FLINGO-BODY%3E
