Running S32E288 code from QSPI
HiddenSquid
My setup:
S32DS 3.6.4
S32 Flash Tool
S32 Debug Probe
S32E288-975EVB
I have a problem running a simple LED blinking code from QuadSPI Serial Flash with the S32E288-975EVB.
The code runs and builds with no issues when I use the S32 Debug Probe "S32E288_FreeRTOS_M33_Debug_RAM_S32Debug".
The problem:
I use the IVT tool to generate a BLOB. The BLOB contains:
1. the IVT image - I set the boot target as System Manager M33
2. a DCD file - for initialising RAM
3. The Application Bootloader binary - The .elf file format is too large to use as the application bootloader, which is why I use the raw binary. As I understand, the .elf adds some additional debug information, but shouldn't modify the code itself.
I then use the S32 Flash Tool to flash my BLOB on the board at location 0x0000_0000 (The start of QuadSPI_flash).
When I power on the board and attach to it using the S32 Debug Probe, I can see, that the Program Counter has gotten stuck at 0xefff_fffe, which seems to be outside the address range in general..? Also, when I attach to the board and set the program counter to the RAM_START, then everything seems to run fine at first, but at some point, the program counter ends up again at 0xefff_fffe. The Disassembly fails to read the command at that location.
Where or how can I find what leads to this erratic program counter value or does the value itself already somehow give an indication of the error?
I am also using freeRTOS, should that change anything in the bring up sequence?
What does the DEBUG_RAM version do extra, that my application bootloader or BLOB doesn't?
When writing my own application bootloader, what steps should I write in to my initialization script and what does the compiler take care of? For Example, do I need to initialize stack pointer, do I need to initialize any other peripheral besides RAM?
Joey_z
Hi,HiddenSquid
Please try to set the RAM entry pointer as the following picture, it is in the .map file.
Joey
Joey_z
Hi,HiddenSquid
Sorry for the reply late.
1.Could you please check your boot mode from QSPI is normal?
2.Do you boot another demo to generate Blob? Such as the Uart/LED demo in RTD.
3.Also, could you share your configuration of IVT?
Joey
HiddenSquid
Hey @Joey_z ,
I will share most of my project with you. I have tried to make it as simple as possible for the time being, but the issue remains.
I believe my board works fine, as I previously had the greenVIP demo running and booting successfully from flash. For BOOT_CFG pins, dip switches at index [2] and [3] are set 1 for booting from flash.
I managed to step through the code at some point, when I manually overwrite the XPSR register. Could that be part of the issue?
HiddenSquid
I have concluded, that the issue is in fact from the XPSR register. I don't have the T flag set and the ISR_NUMBER indicates a hard_fault, but for some reason I never really get to the hard fault. Also I don't understand, why or when does the T flag get unset?
Joey_z
Hi,HiddenSquid
Thank you for your reply.
How do you set the start/entry pointer? it also would seem that the pointer is not configured correctly.
Joey
HiddenSquid
I set the entry and start pointer both to 0x2500_0000, which is the start of RAM, which I have initalised with the DCD.
I have also confirmed that the entry pointer gets correctly set by checking the MC_ME.PRTN0_CORE0_ADDR register, which has a value of 0x2500_0000.
But it still doesn't explain how the Program Counter ever reaches 0xefff_fffe or when or how does the T flag get cleared?
Joey_z
Hi,HiddenSquid
Joey
Joey_z
Hi,HiddenSquid
Thank you for your reply and information.
I will help you to check this issue and will reply to you as soon as if I get result.
Joey
%3CLINGO-SUB%20id%3D%22lingo-sub-2324929%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERunning%20S32E288%20code%20from%20QSPI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2324929%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%3CP%3EMy%20setup%3A%3CBR%20%2F%3ES32DS%203.6.4%3CBR%20%2F%3ES32%20Flash%20Tool%3CBR%20%2F%3ES32%20Debug%20Probe%3CBR%20%2F%3ES32E288-975EVB%3C%2FP%3E%3CP%3EI%20have%20a%20problem%20running%20a%20simple%20LED%20blinking%20code%20from%20QuadSPI%20Serial%20Flash%20with%20the%20S32E288-975EVB.%26nbsp%3B%3C%2FP%3E%3CP%3EThe%20code%20runs%20and%20builds%20with%20no%20issues%20when%20I%20use%20the%20S32%20Debug%20Probe%20%22S32E288_FreeRTOS_M33_Debug_RAM_S32Debug%22.%3C%2FP%3E%3CP%3E%3CSTRONG%3EThe%20problem%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EI%20use%20the%20IVT%20tool%20to%20generate%20a%20BLOB.%20The%20BLOB%20contains%3A%3CBR%20%2F%3E1.%20the%20IVT%20image%20-%20I%20set%20the%20boot%20target%20as%20System%20Manager%20M33%3CBR%20%2F%3E2.%20a%20DCD%20file%20-%20for%20initialising%20RAM%3CBR%20%2F%3E3.%20The%20Application%20Bootloader%20binary%20-%20The%20.elf%20file%20format%20is%20too%20large%20to%20use%20as%20the%20application%20bootloader%2C%20which%20is%20why%20I%20use%20the%20raw%20binary.%20As%20I%20understand%2C%20the%20.elf%20adds%20some%20additional%20debug%20information%2C%20but%20shouldn't%20modify%20the%20code%20itself.%3C%2FP%3E%3CP%3EI%20then%20use%20the%20S32%20Flash%20Tool%20to%20flash%20my%20BLOB%20on%20the%20board%20at%20location%200x0000_0000%20(The%20start%20of%20QuadSPI_flash).%3C%2FP%3E%3CP%3EWhen%20I%20power%20on%20the%20board%20and%20attach%20to%20it%20using%20the%20S32%20Debug%20Probe%2C%20I%20can%20see%2C%20that%20the%20Program%20Counter%20has%20gotten%20stuck%20at%200xefff_fffe%2C%20which%20seems%20to%20be%20outside%20the%20address%20range%20in%20general..%3F%20Also%2C%20when%20I%20attach%20to%20the%20board%20and%20set%20the%20program%20counter%20to%20the%20RAM_START%2C%20then%20everything%20seems%20to%20run%20fine%20at%20first%2C%20but%20at%20some%20point%2C%20the%20program%20counter%20ends%20up%20again%20at%200xefff_fffe.%20The%20Disassembly%20fails%20to%20read%20the%20command%20at%20that%20location.%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3EWhere%20or%20how%20can%20I%20find%20what%20leads%20to%20this%20erratic%20program%20counter%20value%20or%20does%20the%20value%20itself%20already%20somehow%20give%20an%20indication%20of%20the%20error%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EI%20am%20also%20using%20freeRTOS%2C%20should%20that%20change%20anything%20in%20the%20bring%20up%20sequence%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EWhat%20does%20the%20DEBUG_RAM%20version%20do%20extra%2C%20that%20my%20application%20bootloader%20or%20BLOB%20doesn't%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EWhen%20writing%20my%20own%20application%20bootloader%2C%20what%20steps%20should%20I%20write%20in%20to%20my%20initialization%20script%20and%20what%20does%20the%20compiler%20take%20care%20of%3F%20For%20Example%2C%20do%20I%20need%20to%20initialize%20stack%20pointer%2C%20do%20I%20need%20to%20initialize%20any%20other%20peripheral%20besides%20RAM%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2326033%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Running%20S32E288%20code%20from%20QSPI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2326033%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20set%20the%20entry%20and%20start%20pointer%20both%20to%200x2500_0000%2C%20which%20is%20the%20start%20of%20RAM%2C%20which%20I%20have%20initalised%20with%20the%20DCD.%3CBR%20%2F%3EI%20have%20also%20confirmed%20that%20the%20entry%20pointer%20gets%20correctly%20set%20by%20checking%20the%20MC_ME.PRTN0_CORE0_ADDR%20register%2C%20which%20has%20a%20value%20of%200x2500_0000.%3C%2FP%3E%3CP%3EBut%20it%20still%20doesn't%20explain%20how%20the%20Program%20Counter%20ever%20reaches%200xefff_fffe%20or%20when%20or%20how%20does%20the%20T%20flag%20get%20cleared%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2325900%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Running%20S32E288%20code%20from%20QSPI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2325900%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3CSPAN%3EHiddenSquid%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EThank%20you%20for%20your%20reply.%3C%2FP%3E%0A%3CP%3EHow%20do%20you%20set%20the%20start%2Fentry%20pointer%3F%20it%20also%20would%20seem%20that%20the%20pointer%20is%20not%20configured%20correctly.%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EJoey%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2325509%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Running%20S32E288%20code%20from%20QSPI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2325509%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20have%20concluded%2C%20that%20the%20issue%20is%20in%20fact%20from%20the%20XPSR%20register.%20I%20don't%20have%20the%20T%20flag%20set%20and%20the%20ISR_NUMBER%20indicates%20a%20hard_fault%2C%20but%20for%20some%20reason%20I%20never%20really%20get%20to%20the%20hard%20fault.%20Also%20I%20don't%20understand%2C%20why%20or%20when%20does%20the%20T%20flag%20get%20unset%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2325439%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Running%20S32E288%20code%20from%20QSPI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2325439%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHey%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F236188%22%20target%3D%22_blank%22%3E%40Joey_z%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%3CP%3EI%20will%20share%20most%20of%20my%20project%20with%20you.%20I%20have%20tried%20to%20make%20it%20as%20simple%20as%20possible%20for%20the%20time%20being%2C%20but%20the%20issue%20remains.%3C%2FP%3E%3CP%3EI%20believe%20my%20board%20works%20fine%2C%20as%20I%20previously%20had%20the%20greenVIP%20demo%20running%20and%20booting%20successfully%20from%20flash.%20For%20BOOT_CFG%20pins%2C%20dip%20switches%20at%20index%20%5B2%5D%20and%20%5B3%5D%20are%20set%201%20for%20booting%20from%20flash.%3C%2FP%3E%3CP%3EI%20managed%20to%20step%20through%20the%20code%20at%20some%20point%2C%20when%20I%20manually%20overwrite%20the%20XPSR%20register.%20Could%20that%20be%20part%20of%20the%20issue%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2325290%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Running%20S32E288%20code%20from%20QSPI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2325290%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3CSPAN%3EHiddenSquid%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3ESorry%20for%20the%20reply%20late.%3C%2FP%3E%0A%3CP%3E1.Could%20you%20please%20check%20your%20boot%20mode%20from%20QSPI%20is%20normal%EF%BC%9F%3C%2FP%3E%0A%3CP%3E2.Do%20you%20boot%20another%20demo%20to%20generate%20Blob%3F%20Such%20as%20the%20Uart%2FLED%20demo%20in%20RTD.%3C%2FP%3E%0A%3CP%3E3.Also%2C%20could%20you%20share%20your%20configuration%20of%20IVT%3F%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EJoey%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2326354%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Running%20S32E288%20code%20from%20QSPI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2326354%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3CSPAN%3EHiddenSquid%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EThank%20you%20for%20your%20reply%20and%20information.%3C%2FP%3E%0A%3CP%3EI%20will%20help%20you%20to%20check%20this%20issue%20and%20will%20reply%20to%20you%20as%20soon%20as%20if%20I%20get%20result.%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EJoey%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2328691%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Running%20S32E288%20code%20from%20QSPI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2328691%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3CSPAN%3EHiddenSquid%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EPlease%20try%20to%20set%20the%26nbsp%3BRAM%20entry%20pointer%20as%20the%20following%20picture%2C%20it%20is%20in%20the%20.map%20file.%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EJoey%3C%2FP%3E%3C%2FLINGO-BODY%3E
