Running S32E288 code from QSPI
3,102 次查看
HiddenSquid
My setup:
S32DS 3.6.4
S32 Flash Tool
S32 Debug Probe
S32E288-975EVB
I have a problem running a simple LED blinking code from QuadSPI Serial Flash with the S32E288-975EVB.
The code runs and builds with no issues when I use the S32 Debug Probe "S32E288_FreeRTOS_M33_Debug_RAM_S32Debug".
The problem:
I use the IVT tool to generate a BLOB. The BLOB contains:
1. the IVT image - I set the boot target as System Manager M33
2. a DCD file - for initialising RAM
3. The Application Bootloader binary - The .elf file format is too large to use as the application bootloader, which is why I use the raw binary. As I understand, the .elf adds some additional debug information, but shouldn't modify the code itself.
I then use the S32 Flash Tool to flash my BLOB on the board at location 0x0000_0000 (The start of QuadSPI_flash).
When I power on the board and attach to it using the S32 Debug Probe, I can see, that the Program Counter has gotten stuck at 0xefff_fffe, which seems to be outside the address range in general..? Also, when I attach to the board and set the program counter to the RAM_START, then everything seems to run fine at first, but at some point, the program counter ends up again at 0xefff_fffe. The Disassembly fails to read the command at that location.
Where or how can I find what leads to this erratic program counter value or does the value itself already somehow give an indication of the error?
I am also using freeRTOS, should that change anything in the bring up sequence?
What does the DEBUG_RAM version do extra, that my application bootloader or BLOB doesn't?
When writing my own application bootloader, what steps should I write in to my initialization script and what does the compiler take care of? For Example, do I need to initialize stack pointer, do I need to initialize any other peripheral besides RAM?
标记 (3)
2,765 次查看
Joey_z
Hi,HiddenSquid
Please try to set the RAM entry pointer as the following picture, it is in the .map file.
Joey
7 回复数
3,074 次查看
Joey_z
Hi,HiddenSquid
Sorry for the reply late.
1.Could you please check your boot mode from QSPI is normal?
2.Do you boot another demo to generate Blob? Such as the Uart/LED demo in RTD.
3.Also, could you share your configuration of IVT?
Joey
3,066 次查看
HiddenSquid
Hey @Joey_z ,
I will share most of my project with you. I have tried to make it as simple as possible for the time being, but the issue remains.
I believe my board works fine, as I previously had the greenVIP demo running and booting successfully from flash. For BOOT_CFG pins, dip switches at index [2] and [3] are set 1 for booting from flash.
I managed to step through the code at some point, when I manually overwrite the XPSR register. Could that be part of the issue?
3,061 次查看
HiddenSquid
I have concluded, that the issue is in fact from the XPSR register. I don't have the T flag set and the ISR_NUMBER indicates a hard_fault, but for some reason I never really get to the hard fault. Also I don't understand, why or when does the T flag get unset?
3,032 次查看
Joey_z
Hi,HiddenSquid
Thank you for your reply.
How do you set the start/entry pointer? it also would seem that the pointer is not configured correctly.
Joey
3,023 次查看
HiddenSquid
I set the entry and start pointer both to 0x2500_0000, which is the start of RAM, which I have initalised with the DCD.
I have also confirmed that the entry pointer gets correctly set by checking the MC_ME.PRTN0_CORE0_ADDR register, which has a value of 0x2500_0000.
But it still doesn't explain how the Program Counter ever reaches 0xefff_fffe or when or how does the T flag get cleared?
2,766 次查看
Joey_z
Hi,HiddenSquid
Joey
3,010 次查看
Joey_z
Hi,HiddenSquid
Thank you for your reply and information.
I will help you to check this issue and will reply to you as soon as if I get result.
Joey
%3CLINGO-SUB%20id%3D%22lingo-sub-2324929%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BB%8E%20QSPI%20%E8%BF%90%E8%A1%8C%20S32E288%20%E4%BB%A3%E7%A0%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2324929%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%E8%AE%BE%E7%BD%AE%EF%BC%9A%3CBR%20%2F%3ES32DS%203.6.4%3CBR%20%2F%3ES32%20%E9%97%AA%E5%AD%98%E5%B7%A5%E5%85%B7%3CBR%20%2F%3ES32%20%E8%B0%83%E8%AF%95%E6%8E%A2%E9%92%88%3CBR%20%2F%3ES32E288-975EVB%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%E4%BD%BF%E7%94%A8%20S32E288-975EVB%20%E4%BB%8E%20QuadSPI%20%E4%B8%B2%E8%A1%8C%E9%97%AA%E5%AD%98%E8%BF%90%E8%A1%8C%E7%AE%80%E5%8D%95%E7%9A%84%20LED%20%E9%97%AA%E7%83%81%E4%BB%A3%E7%A0%81%E6%97%B6%E9%81%87%E5%88%B0%E4%BA%86%E9%97%AE%E9%A2%98%E3%80%82%20%3C%2FP%3E%3CP%3E%E5%BD%93%E6%88%91%E4%BD%BF%E7%94%A8%20S32%20Debug%20Probe%20%22%20s32e288_freerTos_m33_DEBUG_RAM_S32DEBUG%20%22%20%E6%97%B6%EF%BC%8C%E4%BB%A3%E7%A0%81%E5%8F%AF%E4%BB%A5%E6%AF%AB%E6%97%A0%E9%97%AE%E9%A2%98%E5%9C%B0%E8%BF%90%E8%A1%8C%E5%92%8C%E6%9E%84%E5%BB%BA%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E9%97%AE%E9%A2%98%E6%98%AF%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%20IVT%20%E5%B7%A5%E5%85%B7%E7%94%9F%E6%88%90%20BLOB%E3%80%82BLOB%20%E5%8C%85%E5%90%AB%EF%BC%9A%3CBR%20%2F%3E1.%20IVT%20%E6%98%A0%E5%83%8F%20%E2%80%94%E2%80%94%20%E6%88%91%E5%B0%86%E5%90%AF%E5%8A%A8%E7%9B%AE%E6%A0%87%E8%AE%BE%E7%BD%AE%E4%B8%BA%20System%20Manager%20M33%20%3CBR%20%2F%3E%202.%20%E4%B8%80%E4%B8%AA%20DCD%20%E6%96%87%E4%BB%B6%20%E2%80%94%E2%80%94%20%E7%94%A8%E4%BA%8E%E5%88%9D%E5%A7%8B%E5%8C%96%20RAM%203%E3%80%82%3CBR%20%2F%3E%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6-.elf%20%E6%96%87%E4%BB%B6%E6%A0%BC%E5%BC%8F%E5%A4%AA%E5%A4%A7%EF%BC%8C%E6%97%A0%E6%B3%95%E7%94%A8%E4%BD%9C%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%EF%BC%8C%E8%BF%99%E5%B0%B1%E6%98%AF%E6%88%91%E4%BD%BF%E7%94%A8%E5%8E%9F%E5%A7%8B%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E7%9A%84%E5%8E%9F%E5%9B%A0%E3%80%82%E6%8D%AE%E6%88%91%E6%89%80%E7%9F%A5%EF%BC%8C.elf%E6%B7%BB%E5%8A%A0%E4%BA%86%E4%B8%80%E4%BA%9B%E9%A2%9D%E5%A4%96%E7%9A%84%E8%B0%83%E8%AF%95%E4%BF%A1%E6%81%AF%EF%BC%8C%E4%BD%86%E4%B8%8D%E5%BA%94%E8%AF%A5%E4%BF%AE%E6%94%B9%E4%BB%A3%E7%A0%81%E6%9C%AC%E8%BA%AB%E3%80%82%3C%2FP%3E%3CP%3E%E7%84%B6%E5%90%8E%E6%88%91%E4%BD%BF%E7%94%A8%20S32%20Flash%20Tool%20%E5%9C%A8%200x0000_0000%EF%BC%88Quadspi_Flash%20%E7%9A%84%E5%BC%80%E5%A4%B4%EF%BC%89%E5%9C%A8%E4%B8%BB%E6%9D%BF%E4%B8%8A%E5%88%B7%E6%96%B0%20BLOB%E3%80%82%3C%2FP%3E%3CP%3E%E5%BD%93%E6%88%91%E6%89%93%E5%BC%80%E6%9D%BF%E5%B9%B6%E4%BD%BF%E7%94%A8%20S32%20%E8%B0%83%E8%AF%95%E6%8E%A2%E5%99%A8%E8%BF%9E%E6%8E%A5%E5%88%B0%E6%9D%BF%E6%97%B6%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E7%9C%8B%E5%87%BA%EF%BC%8C%E7%A8%8B%E5%BA%8F%E8%AE%A1%E6%95%B0%E5%99%A8%E5%B7%B2%E5%8D%A1%E5%9C%A8%200xefff_ffe%EF%BC%8C%E8%BF%99%E4%BC%BC%E4%B9%8E%E5%9C%A8%E5%9C%B0%E5%9D%80%E8%8C%83%E5%9B%B4%E4%B9%8B%E5%A4%96...%EF%BC%9F%E5%8F%A6%E5%A4%96%EF%BC%8C%E5%BD%93%E6%88%91%E8%BF%9E%E6%8E%A5%E5%88%B0%E6%9D%BF%E5%B9%B6%E5%B0%86%E7%A8%8B%E5%BA%8F%E8%AE%A1%E6%95%B0%E5%99%A8%E8%AE%BE%E7%BD%AE%E4%B8%BA%20RAM_START%20%E6%97%B6%EF%BC%8C%E8%B5%B7%E5%88%9D%E4%BC%BC%E4%B9%8E%E4%B8%80%E5%88%87%E6%AD%A3%E5%B8%B8%EF%BC%8C%E4%BD%86%E6%98%AF%E5%9C%A8%E6%9F%90%E4%B8%AA%E6%97%B6%E5%80%99%EF%BC%8C%E7%A8%8B%E5%BA%8F%E8%AE%A1%E6%95%B0%E5%99%A8%E5%86%8D%E6%AC%A1%E5%87%BA%E7%8E%B0%E5%9C%A8%200xefff_ffe%E3%80%82%E5%8F%8D%E6%B1%87%E7%BC%96%E6%97%A0%E6%B3%95%E8%AF%BB%E5%8F%96%E8%AF%A5%E4%BD%8D%E7%BD%AE%E7%9A%84%E5%91%BD%E4%BB%A4%E3%80%82%20%20%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E6%88%91%E5%9C%A8%E5%93%AA%E9%87%8C%E6%88%96%E5%A6%82%E4%BD%95%E6%89%BE%E5%88%B0%E5%AF%BC%E8%87%B4%E7%A8%8B%E5%BA%8F%E8%AE%A1%E6%95%B0%E5%99%A8%E5%80%BC%E4%B8%8D%E7%A8%B3%E5%AE%9A%E7%9A%84%E5%8E%9F%E5%9B%A0%EF%BC%8C%E6%88%96%E8%80%85%E8%AF%A5%E5%80%BC%E6%9C%AC%E8%BA%AB%E6%98%AF%E5%90%A6%E5%B7%B2%E7%BB%8F%E4%BB%A5%E6%9F%90%E7%A7%8D%E6%96%B9%E5%BC%8F%E8%A1%A8%E6%98%8E%E4%BA%86%E9%94%99%E8%AF%AF%EF%BC%9F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E4%B9%9F%E6%98%AF%20freeRTOS%EF%BC%8C%E8%BF%99%E6%98%AF%E5%90%A6%E4%BC%9A%E6%94%B9%E5%8F%98%E5%90%AF%E5%8A%A8%E9%A1%BA%E5%BA%8F%EF%BC%9F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EDEBUG_RAM%20%E7%89%88%E6%9C%AC%E6%9C%89%E4%BB%80%E4%B9%88%E9%A2%9D%E5%A4%96%E5%8A%9F%E8%83%BD%E6%98%AF%E6%88%91%E7%9A%84%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E6%88%96%20BLOB%20%E6%89%80%E6%B2%A1%E6%9C%89%E7%9A%84%EF%BC%9F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E5%9C%A8%E7%BC%96%E5%86%99%E8%87%AA%E5%B7%B1%E7%9A%84%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E6%97%B6%EF%BC%8C%E6%88%91%E5%BA%94%E8%AF%A5%E5%9C%A8%E5%88%9D%E5%A7%8B%E5%8C%96%E8%84%9A%E6%9C%AC%E4%B8%AD%E5%86%99%E5%85%A5%E5%93%AA%E4%BA%9B%E6%AD%A5%E9%AA%A4%EF%BC%8C%E7%BC%96%E8%AF%91%E5%99%A8%E4%BC%9A%E5%A4%84%E7%90%86%E5%93%AA%E4%BA%9B%E6%AD%A5%E9%AA%A4%EF%BC%9F%E4%BE%8B%E5%A6%82%EF%BC%8C%E6%98%AF%E5%90%A6%E9%9C%80%E8%A6%81%E5%88%9D%E5%A7%8B%E5%8C%96%E5%A0%86%E6%A0%88%E6%8C%87%E9%92%88%EF%BC%8C%E6%98%AF%E5%90%A6%E9%9C%80%E8%A6%81%E5%88%9D%E5%A7%8B%E5%8C%96%20RAM%20%E4%BB%A5%E5%A4%96%E7%9A%84%E5%85%B6%E4%BB%96%E5%A4%96%E8%AE%BE%EF%BC%9F%3C%2FSTRONG%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2326033%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Running%20S32E288%20code%20from%20QSPI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2326033%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E5%B0%86%E5%85%A5%E5%8F%A3%E6%8C%87%E9%92%88%E5%92%8C%E8%B5%B7%E5%A7%8B%E6%8C%87%E9%92%88%E9%83%BD%E8%AE%BE%E7%BD%AE%E4%B8%BA%200x2500_0000%EF%BC%8C%E8%BF%99%E6%98%AF%20RAM%20%E7%9A%84%E8%B5%B7%E7%82%B9%EF%BC%8C%E6%88%91%E7%94%A8%20DCD%20%E5%B0%86%E5%85%B6%E5%88%9D%E5%A7%8B%E5%8C%96%E3%80%82%3CBR%20%2F%3E%E6%88%91%E8%BF%98%E9%80%9A%E8%BF%87%E6%A3%80%E6%9F%A5%20MC_ME.PRTN0_CORE0_ADDR%20%E5%AF%84%E5%AD%98%E5%99%A8%E7%A1%AE%E8%AE%A4%E4%BA%86%E5%85%A5%E5%8F%A3%E6%8C%87%E9%92%88%E7%9A%84%E6%AD%A3%E7%A1%AE%E8%AE%BE%E7%BD%AE%EF%BC%8C%E8%AF%A5%E5%AF%84%E5%AD%98%E5%99%A8%E7%9A%84%E5%80%BC%E4%B8%BA%200x2500_0000%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%86%E8%BF%99%E4%BB%8D%E7%84%B6%E6%97%A0%E6%B3%95%E8%A7%A3%E9%87%8A%E7%A8%8B%E5%BA%8F%E8%AE%A1%E6%95%B0%E5%99%A8%E6%98%AF%E5%A6%82%E4%BD%95%E5%88%B0%E8%BE%BE%200xefff_fffe%20%E7%9A%84%EF%BC%8C%E4%B9%9F%E6%97%A0%E6%B3%95%E8%A7%A3%E9%87%8A%20T%20%E6%A0%87%E5%BF%97%E6%98%AF%E4%BD%95%E6%97%B6%E6%88%96%E5%A6%82%E4%BD%95%E8%A2%AB%E6%B8%85%E9%99%A4%E7%9A%84%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2325900%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Running%20S32E288%20code%20from%20QSPI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2325900%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%3CSPAN%3E%EF%BC%8CHiddenSquid%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E6%98%AF%E5%A6%82%E4%BD%95%E8%AE%BE%E7%BD%AE%E5%BC%80%E5%A7%8B%2F%E8%BF%9B%E5%85%A5%E6%8C%87%E9%92%88%E7%9A%84%EF%BC%9F%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E4%B9%94%E4%BC%8A%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2325509%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Running%20S32E288%20code%20from%20QSPI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2325509%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E7%9A%84%E7%BB%93%E8%AE%BA%E6%98%AF%EF%BC%8C%E9%97%AE%E9%A2%98%E5%AE%9E%E9%99%85%E4%B8%8A%E6%9D%A5%E8%87%AA%20XPSR%20%E5%AF%84%E5%AD%98%E5%99%A8%E3%80%82%E6%88%91%E6%B2%A1%E6%9C%89%E8%AE%BE%E7%BD%AE%20T%20%E6%A0%87%E5%BF%97%EF%BC%8CISR_NUMBER%20%E6%98%BE%E7%A4%BA%E7%9A%84%E6%98%AF%E7%A1%AC%E6%95%85%E9%9A%9C%EF%BC%8C%E4%BD%86%E7%94%B1%E4%BA%8E%E6%9F%90%E4%BA%9B%E5%8E%9F%E5%9B%A0%EF%BC%8C%E6%88%91%E4%BB%8E%E6%9C%AA%E7%9C%9F%E6%AD%A3%E8%BF%9B%E5%85%A5%E7%A1%AC%E6%95%85%E9%9A%9C%E3%80%82%E6%88%91%E8%BF%98%E4%B8%8D%E6%98%8E%E7%99%BD%EF%BC%8C%E4%B8%BA%E4%BB%80%E4%B9%88%E6%88%96%E4%BB%80%E4%B9%88%E6%97%B6%E5%80%99%20T%20%E6%A0%87%E8%AE%B0%E4%BC%9A%E8%A2%AB%E5%8F%96%E6%B6%88%E8%AE%BE%E7%BD%AE%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2325439%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Running%20S32E288%20code%20from%20QSPI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2325439%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%98%BF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F236188%22%20target%3D%22_blank%22%3E%40Joey_z%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%86%E4%B8%8E%E4%BD%A0%E4%BB%AC%E5%88%86%E4%BA%AB%E6%88%91%E7%9A%84%E5%A4%A7%E9%83%A8%E5%88%86%E9%A1%B9%E7%9B%AE%E3%80%82%E7%9B%AE%E5%89%8D%E6%88%91%E5%B7%B2%E5%B0%BD%E9%87%8F%E7%AE%80%E5%8C%96%E7%A8%8B%E5%BA%8F%EF%BC%8C%E4%BD%86%E9%97%AE%E9%A2%98%E4%BE%9D%E7%84%B6%E5%AD%98%E5%9C%A8%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E7%9B%B8%E4%BF%A1%E6%88%91%E7%9A%84%E6%9D%BF%E5%8F%AF%E4%BB%A5%E6%AD%A3%E5%B8%B8%E8%BF%90%E8%A1%8C%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%88%91%E4%B9%8B%E5%89%8D%E5%B7%B2%E7%BB%8F%E6%88%90%E5%8A%9F%E8%BF%90%E8%A1%8C%E4%BA%86%20GreenVIP%20%E6%BC%94%E7%A4%BA%E7%89%88%E5%B9%B6%E4%BB%8E%E9%97%AA%E5%AD%98%E4%B8%AD%E6%88%90%E5%8A%9F%E5%90%AF%E5%8A%A8%E3%80%82%E5%AF%B9%E4%BA%8E%20BOOT_CFG%20%E5%BC%95%E8%84%9A%EF%BC%8C%E7%B4%A2%E5%BC%95%20%5B2%5D%20%E5%92%8C%20%5B3%5D%20%E7%9A%84%20DIP%20%E5%BC%80%E5%85%B3%E8%AE%BE%E7%BD%AE%E4%B8%BA%201%EF%BC%8C%E7%94%A8%E4%BA%8E%E4%BB%8E%E9%97%AA%E5%AD%98%E5%90%AF%E5%8A%A8%E3%80%82%3C%2FP%3E%3CP%3E%E5%BD%93%E6%88%91%E6%89%8B%E5%8A%A8%E8%A6%86%E7%9B%96%20XPSR%20%E5%AF%84%E5%AD%98%E5%99%A8%E6%97%B6%EF%BC%8C%E6%88%91%E8%AE%BE%E6%B3%95%E5%9C%A8%E6%9F%90%E4%B8%80%E6%97%B6%E5%88%BB%E9%80%90%E6%AD%A5%E4%BF%AE%E6%94%B9%E4%BA%86%E4%BB%A3%E7%A0%81%E3%80%82%E8%BF%99%E5%8F%AF%E8%83%BD%E6%98%AF%E9%97%AE%E9%A2%98%E7%9A%84%E4%B8%80%E9%83%A8%E5%88%86%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2325290%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Running%20S32E288%20code%20from%20QSPI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2325290%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%3CSPAN%3E%EF%BC%8CHiddenSquid%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%8A%B1%E6%AD%89%EF%BC%8C%E5%9B%9E%E5%A4%8D%E6%99%9A%E4%BA%86%E3%80%82%3C%2FP%3E%0A%3CP%3E1.%20%E4%BD%A0%E8%83%BD%E6%A3%80%E6%9F%A5%E4%B8%80%E4%B8%8B%20QSPI%20%E7%9A%84%E5%90%AF%E5%8A%A8%E6%A8%A1%E5%BC%8F%E6%98%AF%E5%90%A6%E6%AD%A3%E5%B8%B8%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E2.%20%E4%BD%A0%E5%90%AF%E5%8A%A8%E5%8F%A6%E4%B8%80%E4%B8%AA%E6%BC%94%E7%A4%BA%E7%89%88%E6%9D%A5%E7%94%9F%E6%88%90%20Blob%20%E5%90%97%EF%BC%9F%E4%BE%8B%E5%A6%82%20RTD%20%E4%B8%AD%E7%9A%84%20Uart%2FLED%20%E6%BC%94%E7%A4%BA%E3%80%82%3C%2FP%3E%0A%3CP%3E3.%E5%8F%A6%E5%A4%96%EF%BC%8C%E8%83%BD%E5%90%A6%E4%BB%8B%E7%BB%8D%E4%B8%80%E4%B8%8B%20IVT%20%E7%9A%84%E9%85%8D%E7%BD%AE%EF%BC%9F%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E4%B9%94%E4%BC%8A%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2326354%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Running%20S32E288%20code%20from%20QSPI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2326354%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%3CSPAN%3E%EF%BC%8CHiddenSquid%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E7%AD%94%E5%A4%8D%E5%92%8C%E4%BF%A1%E6%81%AF%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E4%BC%9A%E5%B8%AE%E5%8A%A9%E6%82%A8%E6%A3%80%E6%9F%A5%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%9C%89%E7%BB%93%E6%9E%9C%EF%BC%8C%E6%88%91%E4%BC%9A%E5%B0%BD%E5%BF%AB%E5%9B%9E%E5%A4%8D%E6%82%A8%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E4%B9%94%E4%BC%8A%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2328691%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Running%20S32E288%20code%20from%20QSPI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2328691%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%3CSPAN%3E%EF%BC%8CHiddenSquid%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E5%B0%9D%E8%AF%95%E8%AE%BE%E7%BD%AE%20RAM%20%E5%85%A5%E5%8F%A3%E6%8C%87%E9%92%88%EF%BC%8C%E5%A6%82%E4%B8%8B%E5%9B%BE%E6%89%80%E7%A4%BA%EF%BC%8C%E5%AE%83%E4%BD%8D%E4%BA%8E%20.map%20%E4%B8%AD%E9%94%89%E5%88%80%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E4%B9%94%E4%BC%8A%3C%2FP%3E%3C%2FLINGO-BODY%3E
