MBDT_S32E2_Issue
MBDT_S32E2_Issue
RaviThade1
Hi Team, I am reaching out for assistance as I am currently unable to install the Model Based Design Toolbox for S32Z/E. I have MATLAB 2024b (even tried with MATLAB 2026a) installed on my system and also have an active NXP account. I downloaded the NXP_Support_Package_S32ZE_1.4.0_D2512.mltbx file, however when I attempt to proceed with the installation, the process remains stuck indefinitely without completing or progressing further. I would really appreciate your help in identifying what might be causing this issue and any guidance on how I can successfully complete the installation. Please let me know if there are any logs or additional details I should provide to assist in troubleshooting. Thank you in advance for your support.
Attached image is for your reference.
Joey_z
Hi,RaviThade1
Thank you for contacting us.
Please try to refer to this link for your application:
MBD Toolbox
Model-Based Design Toolbox | NXP Semiconductors
Joey
RaviThade1
Thanks Joey_z for your response.
I have followed the instructions provided in the MBD Toolbox S32Z/E Series quick start guide. But still facing the same issue.
Additionally, does this toolbox supports MATLAB 2026a?
Thanks and Regards
Ravi
Joey_z
Hi, RaviThade1
Refer to the start guide information.
The Model-Based Design Toolbox uses the Toolchain mechanism exposed by the
MATLAB/Simulink to enable automatic code generation with Embedded Coder toolbox. By
default, the toolchain is configured for the MATLAB 2022a release. For any other MATLAB
release, the user needs to execute a toolbox m-script to generate the appropriate settings for installation environment.
Joey
RaviThade1
Hi Joey_z,
Have you got chance to look at details that I have sent?. I have provided all the details.
your reply says "The user needs to execute a toolbox m-script" however the toolbox m-script is not getting generated for 2024b/2026a. What could be the reason?
Am I missing anything else?
Thanks in advance,
Ravi
Joey_z
Hi,RaviThade1
Thank you for your reply.
This channel mainly addresses technical issues related to S32Z/E.
Currently, MBDT related detail queries will be got more supported under the following MBDT community:
https://community.nxp.com/community/mbdt
Would you mind creating a new post in the community mentioned above? The engineers responsible for this topic actively monitor that forum and will be able to assist you further.
Joey
RaviThade1
Adding additional info with screenshot.
%3CLINGO-SUB%20id%3D%22lingo-sub-2408173%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMBDT_S32E2_Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408173%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Team%2C%20I%20am%20reaching%20out%20for%20assistance%20as%20I%20am%20currently%20unable%20to%20install%20the%20Model%20Based%20Design%20Toolbox%20for%20S32Z%2FE.%20I%20have%20MATLAB%202024b%20(even%20tried%20with%20MATLAB%202026a)%20installed%20on%20my%20system%20and%20also%20have%20an%20active%20NXP%20account.%20I%20downloaded%20the%20NXP_Support_Package_S32ZE_1.4.0_D2512.mltbx%20file%2C%20however%20when%20I%20attempt%20to%20proceed%20with%20the%20installation%2C%20the%20process%20remains%20stuck%20indefinitely%20without%20completing%20or%20progressing%20further.%20I%20would%20really%20appreciate%20your%20help%20in%20identifying%20what%20might%20be%20causing%20this%20issue%20and%20any%20guidance%20on%20how%20I%20can%20successfully%20complete%20the%20installation.%20Please%20let%20me%20know%20if%20there%20are%20any%20logs%20or%20additional%20details%20I%20should%20provide%20to%20assist%20in%20troubleshooting.%20Thank%20you%20in%20advance%20for%20your%20support.%3C%2FP%3E%3CP%3EAttached%20image%20is%20for%20your%20reference.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408339%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MBDT_S32E2_Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408339%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThanks%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F236188%22%20target%3D%22_blank%22%3E%3CSPAN%20class%3D%22%22%3EJoey_z%3C%2FSPAN%3E%3C%2FA%3E%26nbsp%3Bfor%20your%20response.%3C%2FP%3E%3CP%3EI%20have%20followed%20the%20instructions%20provided%20in%20the%20MBD%20Toolbox%26nbsp%3BS32Z%2FE%20Series%20quick%20start%20guide.%20But%20still%20facing%20the%20same%20issue.%3C%2FP%3E%3CP%3EAdditionally%2C%20does%20this%20toolbox%20supports%20MATLAB%202026a%3F%3C%2FP%3E%3CP%3EThanks%20and%20Regards%3C%2FP%3E%3CP%3ERavi%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408328%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MBDT_S32E2_Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408328%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%EF%BC%8C%3CSPAN%3ERaviThade1%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EThank%20you%20for%20contacting%20us.%3C%2FP%3E%0A%3CP%3EPlease%20try%20to%20refer%20to%20this%20link%20for%20your%20application%3A%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com.cn%2Fdocs%2Fen%2Fuser-guide%2FMBDT_S32ZE_Series_Quick_Start_Guide.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EMBD%20Toolbox%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fsoftware%2Fautomotive-software-and-tools%2Fmodel-based-design-toolbox-mbdt%3AMBDT%3Fadobe_mc%3DTS%253D1787714870%257CMCMID%253D48028588193863623953736068729907749694%257CMCORGID%253D26D5971254C83D130A4C98A4%252540AdobeOrg%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EModel-Based%20Design%20Toolbox%20%7C%20NXP%20Semiconductors%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EJoey%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408175%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MBDT_S32E2_Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408175%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EAdding%20additional%20info%20with%20screenshot.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408695%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MBDT_S32E2_Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408695%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHi%20Joey_z%2C%3CBR%20%2F%3EHave%20you%20got%20chance%20to%20look%20at%20details%20that%20I%20have%20sent%3F.%20I%20have%20provided%20all%20the%20details.%3CBR%20%2F%3Eyour%20reply%20says%20%22The%20user%20needs%20to%20execute%20a%20toolbox%20m-script%22%20however%20the%20toolbox%20m-script%20is%20not%20getting%20generated%20for%202024b%2F2026a.%20What%20could%20be%20the%20reason%3F%3CBR%20%2F%3EAm%20I%20missing%20anything%20else%3F%3CBR%20%2F%3E%3CBR%20%2F%3EThanks%20in%20advance%2C%3CBR%20%2F%3EBest%20Regards%2C%3CBR%20%2F%3ERavi%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408690%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MBDT_S32E2_Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408690%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%20RaviThade1%3C%2FP%3E%0A%3CP%3ERefer%20to%20the%26nbsp%3Bstart%20guide%20information.%3C%2FP%3E%0A%3CP%3EThe%20Model-Based%20Design%20Toolbox%20uses%20the%20Toolchain%20mechanism%20exposed%20by%20the%20%3CBR%20%2F%3EMATLAB%2FSimulink%20to%20enable%20automatic%20code%20generation%20with%20Embedded%20Coder%20toolbox.%20By%20%3CBR%20%2F%3Edefault%2C%20the%20toolchain%20is%20configured%20for%20the%20MATLAB%202022a%20release.%20For%20any%20other%20MATLAB%20%3CBR%20%2F%3Erelease%2C%20the%20user%20needs%20to%20execute%20a%20toolbox%20m-script%20to%20generate%20the%20appropriate%20settings%20for%20installation%20environment.%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EJoey%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408698%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MBDT_S32E2_Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408698%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2CRaviThade1%3C%2FP%3E%0A%3CP%3EThank%20you%20for%20your%20reply.%3C%2FP%3E%0A%3CP%3EThis%20channel%20mainly%20addresses%20technical%20issues%20related%20to%20S32Z%2FE.%3C%2FP%3E%0A%3CP%3E%3CSPAN%3ECurrently%2C%20MBDT%20related%20detail%20queries%20will%20be%20got%20more%20supported%20under%20the%20following%20MBDT%20community%3A%3C%2FSPAN%3E%3CBR%20clear%3D%22none%22%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fcommunity%2Fmbdt%22%20shape%3D%22rect%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fcommunity%2Fmbdt%3C%2FA%3E%3CBR%20clear%3D%22none%22%20%2F%3E%3CSPAN%3EWould%20you%20mind%20creating%20a%20new%20post%20in%20the%20community%20mentioned%20above%3F%20The%20engineers%20responsible%20for%20this%20topic%20actively%20monitor%20that%20forum%20and%20will%20be%20able%20to%20assist%20you%20further.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EBR%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EJoey%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
