DIS_SER_BOOT
DIS_SER_BOOT
AdamH_work
Quick question related to the DIS_SER_BOOT flag.  When FUSE_SEL is 1, BOOTMOD(0 0) boots from fuses (QuadSPI in our case) and BOOTMOD(1 0) does serial boot.  If we blow the DIS_SER_BOOT fuse, will BOOTMOD(1 0) boot from fuses (QuadSPI)?  What is the BOOTMOD(1 0) behavior when serial boot is disabled?
If we can get away with hardwiring the BOOTMOD pins to 1/0 on our product and having the pre-programmed QuadSPI flash blow the fuses to configure for QuadSPI as well as disabling serial boot, would the NXP S32 then always boot from QuadSPI?
alejandro_e
Hello @AdamH_work,
Thanks for reaching out to us again. About your question,I understand that you mean this configuration:
I was not able to find any explicit information on the behavior you describe, however, my understanding is that it will simply not boot, to ensure a boot from QSPI you should use BOOTMODE 00 or 01, when FUSE_SEL 1, both will cause a boot from fuses. Please note that setting DIS_SER_BOOT will prevent the chip from booting at all in case of a bad or corrupt image in the QSPI, since you won't be able to download any image using the serial boot.
Let me know if you have any other questions.
AdamH_work
Thanks for the quick reply!  We'll figure out a way to set the BOOTMOD pins then.
alejandro_e
Hello @AdamH_work,
Thank you for accepting my reply as the solution! If you find any other problems or need any kind of recommendation on your implementation feel free to create a new post.
alejandro_e
Hello @AdamH_work,
%3CLINGO-SUB%20id%3D%22lingo-sub-2356004%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EDIS_SER_BOOT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2356004%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EQuick%20question%20related%20to%20the%20DIS_SER_BOOT%20flag.%26nbsp%3B%20When%20FUSE_SEL%20is%201%2C%20BOOTMOD(0%200)%20boots%20from%20fuses%20(QuadSPI%20in%20our%20case)%20and%20BOOTMOD(1%200)%20does%20serial%20boot.%26nbsp%3B%20If%20we%20blow%20the%20DIS_SER_BOOT%20fuse%2C%20will%20BOOTMOD(1%200)%20boot%20from%20fuses%20(QuadSPI)%3F%26nbsp%3B%20What%20is%20the%20BOOTMOD(1%200)%20behavior%20when%20serial%20boot%20is%20disabled%3F%3C%2FP%3E%3CP%3EIf%20we%20can%20get%20away%20with%20hardwiring%20the%20BOOTMOD%20pins%20to%201%2F0%20on%20our%20product%20and%20having%20the%20pre-programmed%20QuadSPI%20flash%20blow%20the%20fuses%20to%20configure%20for%20QuadSPI%20as%20well%20as%20disabling%20serial%20boot%2C%20would%20the%20NXP%20S32%20then%20always%20boot%20from%20QuadSPI%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2356023%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20DIS_SER_BOOT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2356023%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F258968%22%20target%3D%22_blank%22%3E%40AdamH_work%3C%2FA%3E%2C%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThank%20you%20for%20accepting%20my%20reply%20as%20the%20solution!%20If%20you%20find%20any%20other%20problems%20or%20need%20any%20kind%20of%20recommendation%20on%20your%20implementation%20feel%20free%20to%20create%20a%20new%20post.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ERegards%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2356021%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20DIS_SER_BOOT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2356021%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThanks%20for%20the%20quick%20reply!%26nbsp%3B%20We'll%20figure%20out%20a%20way%20to%20set%20the%20BOOTMOD%20pins%20then.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2356019%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20DIS_SER_BOOT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2356019%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F258968%22%20target%3D%22_blank%22%3E%40AdamH_work%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EThanks%20for%20reaching%20out%20to%20us%20again.%20About%20your%20question%2CI%20understand%20that%20you%20mean%20this%20configuration%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22alejandro_e_0-1777063016137.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22alejandro_e_0-1777063016137.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F383526i2D308C25194CC0D1%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22alejandro_e_0-1777063016137.png%22%20alt%3D%22alejandro_e_0-1777063016137.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EI%20was%20not%20able%20to%20find%20any%20explicit%20information%20on%20the%20behavior%20you%20describe%2C%20however%2C%20my%20understanding%20is%20that%20it%20will%20simply%20not%20boot%2C%20to%20ensure%20a%20boot%20from%20QSPI%20you%20should%20use%20BOOTMODE%2000%20or%2001%2C%20when%20FUSE_SEL%201%2C%20both%20will%20cause%20a%20boot%20from%20fuses.%20Please%20note%20that%20setting%26nbsp%3BDIS_SER_BOOT%20will%20prevent%20the%20chip%20from%20booting%20at%20all%20in%20case%20of%20a%20bad%20or%20corrupt%20image%20in%20the%20QSPI%2C%20since%20you%20won't%20be%20able%20to%20download%20any%20image%20using%20the%20serial%20boot.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ELet%20me%20know%20if%20you%20have%20any%20other%20questions.%3C%2FP%3E%3C%2FLINGO-BODY%3E
